    4. [Gelöst] zigbee adapter wird nicht grün nach JS & Node upda
    • ChrisNett
      ChrisNett @ChrisNett last edited by
      zigbee.0	2021-05-14 07:06:59.674	info	(25180) Installed Version: ioBroker/ioBroker.zigbee#master
      zigbee.0	2021-05-14 07:06:59.345	info	(25180) Starting Zigbee npm ...
      zigbee.0	2021-05-14 07:06:59.236	info	(25180) starting. Version 1.5.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.3.9
      zigbee.0	2021-05-14 07:06:53.085	error	(23929) Cannot read property 'getEntries' of null
      zigbee.0	2021-05-14 07:06:53.082	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
      zigbee.0	2021-05-14 07:06:53.082	error	at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:696:41)
      zigbee.0	2021-05-14 07:06:53.082	error	at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:367:20)
      zigbee.0	2021-05-14 07:06:53.082	error	at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:196:42)
      zigbee.0	2021-05-14 07:06:53.082	error	at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:222:43)
      zigbee.0	2021-05-14 07:06:53.082	error	at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:210:49)
      zigbee.0	2021-05-14 07:06:53.082	error	at Controller.getDevices (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/controller.js:303:31)
      zigbee.0	2021-05-14 07:06:53.082	error	at Function.all (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/device.js:241:16)
      zigbee.0	2021-05-14 07:06:53.082	error	at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/device.js:221:55)
      zigbee.0	2021-05-14 07:06:53.082	error	(23929) TypeError: Cannot read property 'getEntries' of null
      zigbee.0	2021-05-14 07:06:53.080	error	(23929) unhandled promise rejection: Cannot read property 'getEntries' of null
      zigbee.0	2021-05-14 07:06:53.079	error	(23929) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      zigbee.0	2021-05-14 07:06:53.077	info	(23929) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      zigbee.0	2021-05-14 07:06:53.075	info	(23929) terminating
      zigbee.0	2021-05-14 07:06:53.074	warn	(23929) Failed to stop zigbee during startup
      zigbee.0	2021-05-14 07:06:53.070	info	(23929) Zigbee: disabling joining new devices.
      zigbee.0	2021-05-14 07:06:53.042	info	(23929) cleaned everything up...
      zigbee.0	2021-05-14 07:06:53.033	info	(23929) Got terminate signal TERMINATE_YOURSELF
      zigbee.0	2021-05-14 07:02:40.294	error	at /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
      zigbee.0	2021-05-14 07:02:40.294	error	at SerialPort._error (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
      zigbee.0	2021-05-14 07:02:40.294	error	at SerialPort.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49)
      zigbee.0	2021-05-14 07:02:40.294	error	at __awaiter (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12)
      zigbee.0	2021-05-14 07:02:40.294	error	at new Promise (<anonymous>)
      zigbee.0	2021-05-14 07:02:40.294	error	at /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71
      zigbee.0	2021-05-14 07:02:40.294	error	at Generator.next (<anonymous>)
      zigbee.0	2021-05-14 07:02:40.294	error	at Znp.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32)
      zigbee.0	2021-05-14 07:02:40.294	error	(23929) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
      zigbee.0	2021-05-14 07:02:40.293	error	(23929) Failed to start Zigbee
      zigbee.0	2021-05-14 07:02:40.094	info	(23929) Installed Version: ioBroker/ioBroker.zigbee#master
      zigbee.0	2021-05-14 07:02:40.060	info	(23929) Starting Zigbee npm ...
      zigbee.0	2021-05-14 07:02:40.058	info	(23929) Try to reconnect. 1 attempts left
      zigbee.0	2021-05-14 07:02:30.058	error	at rejected (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:25:65)
      zigbee.0	2021-05-14 07:02:30.058	error	at Generator.throw (<anonymous>)
      zigbee.0	2021-05-14 07:02:30.058	error	at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:93:31)
      zigbee.0	2021-05-14 07:02:30.058	error	(23929) Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
      zigbee.0	2021-05-14 07:02:30.056	error	(23929) Failed to start Zigbee
      zigbee.0	2021-05-14 07:02:10.395	info	(23929) Installed Version: ioBroker/ioBroker.zigbee#master
      zigbee.0	2021-05-14 07:02:10.057	info	(23929) Starting Zigbee npm ...
      zigbee.0	2021-05-14 07:02:09.927	info	(23929) starting. Version 1.5.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.3.9
      noch mehr fehler im log 😞
        Thomas Braun Most Active @ChrisNett last edited by
        @christian-sandkaulen
        iobroker stop
        iobroker fix
        ChrisNett 1 Reply Last reply Reply Quote 0
          Jan1 @ChrisNett last edited by
          Da Du nicht in der Lage bist die geforderten Angaben oben richtig auszufüllen und nicht mal schreibst von wo Du nach was upgedatet hast, brauchst auch nicht mit viel Hilfe rechnen.
          Der Fixer wirds wohl nicht richten, obwohl das Log in die Richtung deutet, aber mein Zigbee Adapter läuft auch ohne Fixer nach dem Node Update von vorgestern.
          • ChrisNett
            ChrisNett @Jan1 last edited by
            @jan1
            Hallo Jan,
            Sorry ich kenne mich da nicht 100% aus aber wenn was fehlt liefere ich das gerne nach.
            ich habe von 10X auf 12X und von 3.1 auf 3.3. ein update gemacht.
            mein Image stammt von www.raspberrypi.org
            hilft das Bild hie rnoch ?
            • ChrisNett
              ChrisNett @Thomas Braun last edited by
              den fix hatte nach node update ausgeführt soll ich das noch mal machen?
                @christian-sandkaulen Lass Mal sehen ob nodeJS sauber installiert wurde. Link in meiner Signatur.
                  Es reicht schon wenn man alles ausfüllt, denn das was Thomas jetzt fragt, fehlt oben und wäre somit schon geklärt 😉
                  • ChrisNett
                    danke, habe gerade erst wieder zugriff auf die Konsole.
                    pi@PI4:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
                    /usr/bin/nodejs
                    /usr/bin/node
                    /usr/bin/npm
                    v12.22.1
                    v12.22.1
                    6.14.12
                    nodejs:
                      Installiert:           12.22.1-1nodesource1
                      Installationskandidat: 12.22.1-1nodesource1
                      Versionstabelle:
                     *** 12.22.1-1nodesource1 500
                            500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                            100 /var/lib/dpkg/status
                         10.24.0~dfsg-1~deb10u1 500
                    pi@PI4:~ $
                    sieht für mich jetzt okay aus oder?
                      Ja, passt.
                        legro @Jan1 last edited by
                        Heute habe ich nach ewiger Zeit mal wieder mein System zu aktualisieren gesucht. Leider nicht immer erfolgreich. So ging nach der Aktualisierung des ZigBee-Adapter von 1.4.1 auf die neueste Version 1.5.5 nichts mehr.
                        Fehler ..
                        Der Adapter wird nicht mehr grün.
                        Es wird gemeldet, dass keine Geräte gepairt seien.
                        Nachdem ich wieder zurück zu 1.4.1 ging, funktioniert alles wieder.
                        Thomas Braun ChrisNett 3 Replies Last reply Reply Quote 0
                        • ChrisNett
                          soll ich den fix noch mal ausführen?
                            Thomas Braun Most Active @legro last edited by
                            @legro sagte in zigbee adapter wird nicht grün nach JS & Node update:
                            Fehler ..
                            Welche?
                              Den fix kannst du immer ausführen, das ist nie verkehrt.
                              • ChrisNett
                                ChrisNett @legro last edited by
                                @legro
                                die 1.5.5 lief bei mir aber schon ein ganze zeit
                                  Aktuelle Stable ist 1.4.4.
                                  K ChrisNett L 3 Replies Last reply Reply Quote 0
                                  • ChrisNett
                                    leider immer noch keine Verbindung zum stick, kann ich sonst noch was machen?
                                    zigbee.0	2021-05-14 15:54:16.232	error	(26275) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port' at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/z
                                    zigbee.0	2021-05-14 15:54:16.231	error	(26275) Failed to start Zigbee
                                    zigbee.0	2021-05-14 15:54:16.019	info	(26275) Installed Version: ioBroker/ioBroker.zigbee#master
                                    zigbee.0	2021-05-14 15:54:15.993	info	(26275) Starting Zigbee npm ...
                                    zigbee.0	2021-05-14 15:54:15.992	info	(26275) Try to reconnect. 1 attempts left
                                    zigbee.0	2021-05-14 15:54:05.991	error	at fulfilled (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/manager.js:24:58)
                                    zigbee.0	2021-05-14 15:54:05.991	error	at Generator.next (<anonymous>)
                                    zigbee.0	2021-05-14 15:54:05.991	error	at ZnpAdapterManager.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/manager.js:178:37)
                                    zigbee.0	2021-05-14 15:54:05.991	error	(26275) TypeError: Cannot read property 'warn' of undefined
                                    zigbee.0	2021-05-14 15:54:05.990	error	(26275) Failed to start Zigbee
                                    zigbee.0	2021-05-14 15:54:04.057	info	(26275) Installed Version: ioBroker/ioBroker.zigbee#master
                                    zigbee.0	2021-05-14 15:54:03.428	info	(26275) Starting Zigbee npm ...
                                    zigbee.0	2021-05-14 15:54:03.245	info	(26275) starting. Version 1.5.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.3.9
                                      klassisch Most Active @Thomas Braun last edited by
                                      @thomas-braun sagte in zigbee adapter wird nicht grün nach JS & Node update:
                                      die nutze ich auch. Mit der 1.5er hatte ich sporadisch Probleme
                                      • ChrisNett
                                        habe über die admin oberfläche 1.4.1 instaliert leider weiter nix, eine 1.4.4 finde ich nicht
                                          Thomas Braun Most Active @ChrisNett last edited by Thomas Braun
                                          zigbee-Adapter
                                          github:	1.5.5
                                          latest:	1.5.5 for 10 days
                                          stable:	1.4.4 for 88 days
                                          Was sagt
                                          iobroker update -i
                                          Fahr die Kiste mal komplett runter, also für ein paar Minuten komplett aus.
                                            legro @Thomas Braun last edited by legro
                                            ZigBee 1.4.4 funktioniert bei mir auch nicht; auch diese Version wird bei mir nicht grün; kein einziges Gerät wird als verbunden angezeigt.
                                            Ich musste zurück auf 1.4.1.😕
                                            1415
