    4. [Gelöst] zigbee adapter wird nicht grün nach JS & Node upda
    • ChrisNett
      ChrisNett @Thomas Braun last edited by
      pi@PI4:~ $ iobroker update -i
      Used repository: Stable (default)
      Cannot download json from http://download.iobroker.net/sources-dist-hash.json. Error: Error: connect EHOSTUNREACH 79.143.182.215:80
      failed to download new sources, use cached sources
      update done
      Adapter    "admin"         : 4.2.1    , installed 4.2.1
      Adapter    "alexa2"        : 3.8.1    , installed 3.9.0
      Adapter    "backitup"      : 2.1.6    , installed 2.1.6
      Adapter    "broadlink2"    : 2.0.3    , installed 2.1.5
      Adapter    "cloud"         : 4.0.10   , installed 4.0.11
      Adapter    "coronavirus-statistics": 0.6.3   , installed 0.7.0-4
      Adapter    "denon"         : 1.10.4   , installed 1.10.7
      Adapter    "devices"       : 0.3.16   , installed 0.3.16
      Adapter    "discovery"     : 2.6.1    , installed 2.6.3
      Adapter    "dwd"           : 2.7.5    , installed 2.7.5
      Adapter    "email"         : 1.0.9    , installed 1.0.9
      Adapter    "feiertage"     : 1.0.17   , installed 1.0.20
      Adapter    "flot"          : 1.10.6   , installed 1.10.6
      Adapter    "fritzbox"      : 0.2.1    , installed 0.2.1
      Adapter    "history"       : 1.9.12   , installed 1.9.13
      Adapter    "hmip"          : 1.9.0    , installed 1.12.1
      Adapter    "ical"          : 1.7.4    , installed 1.9.3
      Adapter    "icons-addictive-flavour-png": 0.1.0   , installed 0.1.0
      Adapter    "icons-icons8"  : 0.0.1    , installed 0.0.1
      Adapter    "icons-ultimate-png": 1.0.1   , installed 1.0.1
      Adapter    "info"          : 1.7.14   , installed 1.7.15
      Adapter    "iot"           : 1.8.16   , installed 1.8.16
      Adapter    "javascript"    : 5.1.3    , installed 5.1.3
      Controller "js-controller" : 3.2.16   , installed 3.3.9
      Adapter    "landroid"      : 1.0.3    , installed 1.0.3
      Adapter    "logparser"     : 1.1.0    , installed 1.1.0
      Adapter    "mihome-vacuum" : 2.1.1    , installed 3.1.7
      Adapter    "mqtt"          : 2.3.5    , installed 2.4.0
      Adapter    "parser"        : 1.0.7    , installed 1.0.7
      Adapter    "ping"          : 1.4.12   , installed 1.4.12
      Adapter    "radar2"        : 1.0.9    , installed 2.0.1
      Adapter    "rpi2"          : 1.2.0    , installed 1.2.0
      Adapter    "samsung"       : 0.2.9    , installed 0.2.9
      Adapter    "seq"           : 0.2.10   , installed 0.2.10
      Adapter    "shelly"        : 4.0.7    , installed 4.0.8
      Adapter    "simple-api"    : 2.5.3    , installed 2.6.1
      Adapter    "socketio"      : 3.1.4    , installed 3.1.4
      Adapter    "sonoff"        : 2.4.0    , installed 2.4.0
      Adapter    "spotify-premium": 1.0.0   , installed 1.0.0
      Adapter    "tankerkoenig"  : 2.0.5    , installed 2.0.12
      Adapter    "telegram"      : 1.8.1    , installed 1.8.1
      Adapter    "tr-064"        : 4.2.12   , installed 4.2.12
      Adapter    "trashschedule" : 1.1.1    , installed 1.1.3
      Adapter    "upnp"          : 1.0.17   , installed 1.0.17
      Adapter    "vis"           : 1.3.8    , installed 1.3.9
      Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.7
      Adapter    "vis-icontwo"   : 0.67.0   , installed 0.67.0
      Adapter    "vis-inventwo"  : 2.8.3    , installed 2.9.7
      Adapter    "vis-metro"     : 1.1.2    , installed 1.1.2
      Adapter    "weatherunderground": 3.3.0   , installed 3.3.0
      Adapter    "web"           : 3.4.0    , installed 3.4.1
      Adapter    "wifilight"     : 1.1.0    , installed 1.1.0
      Adapter    "zigbee"        : 1.4.4    , installed 1.5.5
        Thomas Braun Most Active @legro last edited by
        @legro Wenn du das ändern willst: Mach einen eigenen Thread auf. Sonst wird das zu unübersichtlich hier.
        ChrisNett L 2 Replies Last reply Reply Quote 0
        • ChrisNett
          zigbee ist immer noch 1.5.5 oder?
          npm install zigbee@1.4.4
          oder?
            Thomas Braun Most Active @ChrisNett last edited by Thomas Braun
            @christian-sandkaulen
            Zuerst muss deine Kiste wieder Zugang zum Netz haben.
            Mit
            kommst du nicht weit.
            Wenn das wieder geht:
            iobroker update
            iobroker upgrade zigbee@1.4.4
            ChrisNett 1 Reply Last reply Reply Quote 0
              legro @Thomas Braun last edited by
              @thomas-braun said in zigbee adapter wird nicht grün nach JS & Node update:
              Ich habe mich hier angehängt, da auch ich node und nodejs aktualisiert habe. Vielleicht hängt das ja alles irgendwie zusammen.
              Da ich noch immer sehr eingespannt bin, unser System auf- und auszubauen, warte ich notgedrungen einfach ab.
                @legro
                Ohne irgendwelche Meldungen aus deiner Konsole kannst du damit nur zu Madame Medusa vom Jahrmarkt gehen. Vielleicht funktioniert deren Glaskugel ja.
                  @legro
                  .. kannst du damit nur zu Madame Medusa vom Jahrmarkt gehen. Vielleicht funktioniert deren Glaskugel ja.
                  Stimmt leider. Ich verfolge hier das Ganze aufmerksam. Wenn ich sehe, dass ich etwas dazu beitragen kann, werde ich morgen nochmals mir das Ganze bei unserer Installation anschauen und ggf. Daten liefern.
                    @legro sagte in zigbee adapter wird nicht grün nach JS & Node update:
                    Bei einer neuen Version von nodeJS muss zigbee bzw. der zigbee-herdsman gegen die neue Version gebaut werden. Insofern hängt das natürlich alles 'irgendwie zusammen'.
                      legro @Thomas Braun last edited by legro
                      Da war ich heute ganz offensichtlich viel zu voreillig. Ich werde wohl mein System wieder auf den alten Zustand zurücksetzen. Dank ApplePiBaker ist das glücklicherweise keine große Sache.
                      Anschließend aktualisiere ich einzeln den ein oder anderen der mehr als ein Dutzend zu aktualisierenden Adapter.
                      Danke für deine Hinweise.
                        Thomas Braun Most Active @legro last edited by Thomas Braun
                        @legro
                        Da würde ich den Verwahrort auf 'default/stable' setzen, wenn er es denn nicht ist und dann auf den dort aktuellen Stand gehen. Für alle Adapter.
                        Bei mehr als einem Dutzend Updates in der Pipeline solltest du das bedeutend regelmäßiger machen.
                        • ChrisNett
                          danke dir schonmal für deine Hilfe nun haben wir auch wieder internet...
                          hier der log
                          hash changed or no sources cached => force download of new sources
                          update done
                          pi@PI4:~ $ iobroker upgrade zigbee@1.4.4
                          Would you like to downgrade zigbee from @1.5.5 to @1.4.4 now? [(y)es, (n)o]: y
                          Update zigbee from @1.5.5 to @1.4.4
                          host.PI4 Adapter "system.adapter.zigbee.0" is stopped.
                          NPM version: 6.14.12
                          npm install iobroker.zigbee@1.4.4 --loglevel error --prefix "/opt/iobroker" (Sys        tem call)
                          test
                          Update "system.adapter.zigbee.0"
                          upload [250] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/smart9_ts0043.png img/smart9_ts0043.png image/png
                          upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_LCT002.png img/philips_hue_LCT002.png image/png
                          upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lifecontrol_water-sensor.png img/lifecontrol_water-sensor.png image/png
                          upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/hue_go.png img/hue_go.png image/png
                          upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/gledopto_spot.png img/gledopto_spot.png image/png
                          upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/flair_viyu_e27_rgbw.png img/flair_viyu_e27_rgbw.png image/png
                          upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ecozy.png img/ecozy.png image/png
                          upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ctrl_ln1.png img/ctrl_ln1.png image/png
                          upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/bitron_902010_24.png img/bitron_902010_24.png image/png
                          upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZS232000178.png img/ZS232000178.png image/png
                          upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Paulmann_79809.png img/Paulmann_79809.png image/png
                          ^[[A^[[A^[[Aupload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/HG06104A.png img/HG06104A.png image/png
                          upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/FLOALT.panel.WS.png img/FLOALT.panel.WS.png image/png
                          upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Eurotronic_Spirit_04.png img/Eurotronic_Spirit_04.png image/png
                          upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_R8_8.png img/DIYRuZ_R8_8.png image/png
                          upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_Geiger.png img/DIYRuZ_Geiger.png image/png
                          upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_FreePad_LeTV_8.png img/DIYRuZ_FreePad_LeTV_8.png image/png
                          upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_FreePad.png img/DIYRuZ_FreePad.png image/png
                          upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_Flower.png img/DIYRuZ_Flower.png image/png
                          upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_CO2.png img/DIYRuZ_CO2.png image/png
                          upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ.png img/DIYRuZ.png image/png
                          upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DGNWG05LM.png img/DGNWG05LM.png image/png
                          upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Bitron_AV201021A.png img/Bitron_AV201021A.png image/png
                          upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/BW-IS5.png img/BW-IS5.png image/png
                          upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/BW-IS3.png img/BW-IS3.png image/png
                          upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/AV2010_32.png img/AV2010_32.png image/png
                          upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw2.png img/86sw2.png image/png
                          upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw1.png img/86sw1.png image/png
                          upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86plug.png img/86plug.png image/png
                          upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/14147206L.png img/14147206L.png image/png
                          upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/admin.js admin.js application/javascript
                          upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/adapter-settings.js adapter-settings.js application/javascript
                          Adapter "zigbee" updated
                          host.PI4 Adapter "system.adapter.zigbee.0" is started
                          pi@PI4:~ $
                          • ChrisNett
                            ChrisNett @ChrisNett last edited by
                            und der log 😞
                            zigbee.0	2021-05-14 21:01:49.470	warn	(8280) Read-only state "zigbee.0.info.connection" has been written without ack-flag with value "false"
                            zigbee.0	2021-05-14 21:01:49.463	error	at /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
                            zigbee.0	2021-05-14 21:01:49.463	error	at SerialPort._error (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
                            zigbee.0	2021-05-14 21:01:49.463	error	at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49)
                            zigbee.0	2021-05-14 21:01:49.463	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12)
                            zigbee.0	2021-05-14 21:01:49.463	error	at new Promise (<anonymous>)
                            zigbee.0	2021-05-14 21:01:49.463	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71
                            zigbee.0	2021-05-14 21:01:49.463	error	at Generator.next (<anonymous>)
                            zigbee.0	2021-05-14 21:01:49.463	error	at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32)
                            zigbee.0	2021-05-14 21:01:49.463	error	(8280) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
                            zigbee.0	2021-05-14 21:01:49.461	error	(8280) Failed to start Zigbee
                            zigbee.0	2021-05-14 21:01:49.349	info	(8280) Installed Version: iobroker.zigbee@1.4.4
                            zigbee.0	2021-05-14 21:01:49.231	info	(8280) Starting Zigbee npm ...
                            zigbee.0	2021-05-14 21:01:49.230	info	(8280) Try to reconnect. 1 attempts left
                              crunchip Forum Testing Most Active @ChrisNett last edited by
                              @christian-sandkaulen sagte in zigbee adapter wird nicht grün nach JS & Node update:
                              Spasseshalber mal den usb Anschluss gewechselt?
                              • ChrisNett
                                ChrisNett @crunchip last edited by
                                @crunchip
                                ja habe alle mal druch.
                                • ChrisNett
                                  ich habe jetzt noch mal einen Instanz installier (eher versehentlich ... )
                                  jetzt ist er grün:-)
                                  huhu!
                                  weiß nicht ob das an der installatiion oder am auqra sensor aber das steht beim paaring im log
                                  Adapter    "zigbee"        : 1.4.4    , installed 1.4.4
                                  zigbee.0	2021-05-14 21:13:45.909	warn	(3862) Read-only state "zigbee.0.info.pairingMessage" has been written without ack-flag with value "Error: Failed to remove Error: AREQ - ZDO - mgmtLeaveRsp after 10000ms at Timeout._onTimeout (/o
                                  zigbee.0	2021-05-14 21:13:45.902	error	(3862) Failed to remove Error: AREQ - ZDO - mgmtLeaveRsp after 10000ms at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitress.js:37:35) at listOnTimeout (interna
                                  zigbee.0	2021-05-14 21:13:10.639	warn	(3862) Read-only state "zigbee.0.info.pairingMessage" has been written without ack-flag with value "Error: Device 0x00158d000693a729 "undefined" not described in statesMapping.. undefined"
                                  zigbee.0	2021-05-14 21:13:10.633	error	(3862) Device 0x00158d000693a729 "undefined" not described in statesMapping.
                                  zigbee.0	2021-05-14 21:13:10.587	warn	(3862) Read-only state "zigbee.0.info.connection" has been written without ack-flag with value "true"
                                  zigbee.0	2021-05-14 21:13:10.559	info	(3862) Zigbee started
                                  code_text
                                  • ChrisNett
                                    danke an alle der Adapter läuft wieder jetzt nur noch alles neu anlernen.
                                    Meine frau sagte gerade: "auch nicht selbstverständlich das dir geholfen wird ohne das einer was dafür bekommet!"
                                    Damit hat sie vollkommen Recht so ist es, deswegen hier noch mal ausdrücklich danke!
                                      Jan1 @ChrisNett last edited by Jan1
                                      Veto!
                                      Genau dafür sind Foren eigentlich da 😉
                                      Leider gibts auch einige Foren in denen viele kommerzielle User nur auf "Beute" lauern, aber normal ist eben helfen der Sinn eines Forum.
                                      Um schnell die richtige Hilfe zu erhalten, sollten dann eben auch alle relevanten Angaben am besten gleich in den ersten Post, dann läuft der Rest sehr schnell und Zielführend 🙂
                                      Ganz recht hast übrigens auch nicht wegen der Gegenleistung. Oft stößt man bei der Hilfe auch auf Probleme, die man selber noch nicht kannte und durch die Hilfe auch auf die Lösung, was einem dann selber auch weiterhilft.
                                        legro @Jan1 last edited by legro
                                        @jan1 said in [Gelöst] zigbee adapter wird nicht grün nach JS & Node upda:
                                        .., aber normal ist eben helfen der Sinn eines Forum. ..
                                        Das kann ich nur bestätigen.
                                        Als ich im Herbst letzten Jahres nach vier Jahren Leidenszeit unter MagentaSmartHome (MSH) zu ioBroker stieß, wollte ich meine - nicht bzw. nur rudimentär von ioBroker unterstützten - BITRON Rauchmelder und die zugehörige Außensirene partout nicht an die Mülltonne anschließen müssen, schließlich lassen sich die Sirenen in den Rauchmeldern ebenfalls für andere Alarmierungen ansteuern/nutzen.
                                        Hier kam mir @Asgothian in vorbildlicher Weise zu Hilfe. Er patchte mein System remote. Nachdem sich abzeichnete, dass alles stabil und vorbildlich funktionierte, wurde das Ganze in den ZigBee/Herdsman-Adapter integriert und unsereiner konnte damit ein ausgefeiltes Alarmsystem für Einbruch (Hüllschutz), Wasser-, Gas- und Rauchalarm aufbauen.
                                        Seither veröffentliche ich ungefragt - sozusagen - als Dankeschön die Grundlagen meiner Arbeiten. U.a. bin ich gerade dabei, nach ersten stümperhaften Versuchen mit allen möglichen Widgets und einer Einbettung unseres Systems in Apple Home Kit, mittels Iventwo&Icontwo meine dritte Visualisierung zu realisieren. Die beiden Jungs @jkvarel @skvarel von Inventwo&Icontwo leisten hierzu Großartiges.
                                        1415
