    4. Admin 4.2.1
    Admin 4.2.1
    • sissiwup
      sissiwup @Glasfaser last edited by
      @glasfaser
      Klar, killall und neu gestartet
      Es läuft auch alles, nur keine Instanzen Anzeige```
      admin.0 2021-05-14 18:46:58.695 info (16024) Use link "http://localhost:8081" to configure.
      admin.0 2021-05-14 18:46:58.695 info (16024) http server listening on port 8081
      admin.0 2021-05-14 18:46:58.638 info (16024) received all objects
      admin.0 2021-05-14 18:46:57.992 info (16024) requesting all objects
      admin.0 2021-05-14 18:46:57.991 info (16024) requesting all states
      admin.0 2021-05-14 18:46:57.977 info (16024) starting. Version 4.2.1 in /opt/iobroker/node_modules/iobroker.admin, node: v12.22.1, js-controller: 3.2.16
      admin.0 2021-05-14 18:46:51.766 info (13196) Terminated (NO_ERROR): Without reason
      admin.0 2021-05-14 18:46:51.765 info (13196) terminating
      admin.0 2021-05-14 18:46:51.764 info (13196) Got terminate signal TERMINATE_YOURSELF
      admin.0 2021-05-14 18:46:51.763 info (13196) terminating http server on port 8081
      admin.0 2021-05-14 18:46:51.759 info (13196) Adapter is disabled => stop
      • Glasfaser
        Glasfaser @sissiwup last edited by
        @sissiwup
        Browser Cache gelöscht ?
        F12 Konsole sagt was , zeigt sie Fehler !?
        sissiwup 1 Reply Last reply Reply Quote 0
        • sissiwup
          @glasfaser
          Anderer Browser genommen. Ging auch nicht.
          jquery.fancytree-all.js:113 Fancytree@1 Fancytree.filterNodes() leavesOnly option is deprecated since 2.9.0 / 2015-04-19. Use opts.leavesOnly instead.
          v @ jquery.fancytree-all.js:113
          warn @ jquery.fancytree-all.js:3019
          e.ui.fancytree._FancytreeClass.filterNodes @ jquery.fancytree-all.js:7944
          (anonymous) @ adminAdapters.js:558
          setTimeout (async)
          (anonymous) @ adminAdapters.js:544
          dispatch @ jquery-3.2.1.min.js:3
          m.handle @ jquery-3.2.1.min.js:3
          trigger @ jquery-3.2.1.min.js:4
          (anonymous) @ jquery-3.2.1.min.js:4
          each @ jquery-3.2.1.min.js:2
          i @ adminAdapters.js:252
          Adapters.prepare @ adminAdapters.js:573
          (anonymous) @ admin.js:2005
          setTimeout (async)
          (anonymous) @ admin.js:1869
          r.onack @ index.js:83
          r.onpacket @ index.js:83
          (anonymous) @ index.js:83
          r.emit @ index.js:83
          r.ondecoded @ index.js:83
          a.add @ index.js:83
          r.ondata @ index.js:83
          r.onPacket @ index.js:83
          r.onData @ index.js:83
          ws.onmessage @ index.js:83
          admin.js:153 Cannot compare "" and "1.0.1"
          upToDate @ admin.js:153
          (anonymous) @ adminAdapters.js:1417
          (anonymous) @ adminAdapters.js:672
          setTimeout (async)
          (anonymous) @ adminAdapters.js:671
          a.add @ index.js:83
          admin.js:153 Cannot compare "" and "0.14.1"
          setTimeout (async)
          a.add @ index.js:83
          admin.js:153 Cannot compare "" and "0.1.3"
          setTimeout (async)
          a.add @ index.js:83
          admin.js:153 Cannot compare "" and "0.0.3"
          setTimeout (async)
          a.add @ index.js:83
          admin.js:153 Cannot compare "" and "0.5.5"
          setTimeout (async)
          a.add @ index.js:83
          admin.js:153 Cannot compare "" and "0.0.6"
          setTimeout (async)
          a.add @ index.js:83
          adminInstances.js:64 Uncaught TypeError: e.match is not a function
              at n (adminInstances.js:64)
              at Instances.replaceInLink (adminInstances.js:142)
              at d (adminInstances.js:433)
              at Instances._postInit (adminInstances.js:1063)
              at adminInstances.js:1152
              at r.<anonymous> (adminInstances.js:1119)
              at r.onack (index.js:83)
              at r.onpacket (index.js:83)
              at r.<anonymous> (index.js:83)
              at r.emit (index.js:83)
          • Glasfaser
            Glasfaser last edited by Glasfaser
            @sissiwup
            Installiere mal über Adapter /+ bei der Auswahl bestimmter Adapter / die 4.1.12 und dann nochmal nach der Installation ein Upload dort machen .
            EDIT :
            Nach update auf Admin 4.2.1
            da hast aber schon lange kein Update auf deinem System gemacht ... die ist schon über 4 Monate in Stable !
            • sissiwup
              @glasfaser
              Hi, habe zwischenzeitlich ein reinstall gemacht. Keine Besserung
              Mache jetzt deinen Tipp
              • sissiwup
                sissiwup @sissiwup last edited by
                @sissiwup sagte in Admin 4.2.1:
                @glasfaser
                Hat leider auch nix gebracht.
                • Glasfaser
                  @sissiwup
                  und nochmal über Putty
                  iobroker stop
                  iobroker upload admin
                  iobroker fix
                  iobroker start
                  EDIT :
                  das später mal zeigen :
                  iobroker list instances
                  • sissiwup
                    @glasfaser sagte in Admin 4.2.1:
                    @sissiwup
                    iobroker stop
                    iobroker start
                    Hi, genau das habe ich gemacht.
                    Habe jetzt das Backup vorm update eingespielt. War da scheinbar auch schon kaputt (Reiter Instanzen brauche ich seltener)
                    Das letzt was ich vorher gemacht habe (so weit ich mich erinnere) bin von beta auf stable gewechselt und habe alle Adapter die weiter waren wieder auf stabel zurückgesetzt. Kann es daran liegen?
                    • Glasfaser
                      Das heißt du schleppst den defekt immer schon mit dir !?
                      • sissiwup
                        Scheinbar. Wenn ich Admin auf 5.x anheben, dann zeigt er wieder alles an.
                        Eigentlich wollt eich aber auf stable gehen, da im beta leider die Gruppen (Heizungen) schon seit längeren defekt sind (-1 Maximaler Wert usw)
                          Kallo last edited by
                          Ich hatte das gleiche Problem. Ich hatte aus dem latest den Admin 5.0.24 installiert. Nach einem Einspielen des Backups wurde automatisch der 4.xx aus stable installiert. Damit war auch der Reiter "Instanzen" leer, die Übersicht im übrigen auch. Ich bin dann wieder zurück auf Admin 5.0.24, damit sind die installierten Adapter wieder in den Instanzen zu sehen. Das Problem tritt wohl nach einem Downgrade des Admin-Adapters auf.
                          307
