    4. Probleme mit Serialport bei zwave2
      Esmax666 @Thomas Braun last edited by
      @thomas-braun said in Test Adapter Z-Wave 2 v1.10.x:
      /dev/ttyUSB0
      danke
      Habe mit USB0 und 1 probiert (sogar auch 2 und 3)
        Thomas Braun Most Active @Esmax666 last edited by
        @esmax666
        Kann ich nicht lesen. Bitte Text in Textform (in CodeTags) ins Forum kopieren.
          zwave2.0	2021-05-15 21:32:36.443	error	(7091) The Z-Wave driver could not be started: Error: No such file or directory, cannot open /dev/ttyUSB3
          zwave2.0	2021-05-15 21:32:36.301	info	(7091) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
          zwave2.0	2021-05-15 21:32:36.010	error	(7091) Cannot find search "folder" in "system"
          host.raspberrypi	2021-05-15 21:32:33.965	info	instance system.adapter.zwave2.0 started with pid 7091
          host.raspberrypi	2021-05-15 21:32:31.435	info	instance system.adapter.zwave2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          zwave2.0	2021-05-15 21:32:30.851	info	(7074) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          zwave2.0	2021-05-15 21:32:30.850	info	(7074) terminating
          zwave2.0	2021-05-15 21:32:30.848	info	(7074) Shutting down driver...
          zwave2.0	2021-05-15 21:32:30.847	info	(7074) Got terminate signal TERMINATE_YOURSELF
          host.raspberrypi	2021-05-15 21:32:30.847	info	stopInstance system.adapter.zwave2.0 send kill signal
          host.raspberrypi	2021-05-15 21:32:30.839	info	stopInstance system.adapter.zwave2.0 (force=false, process=true)
          zwave2.0	2021-05-15 21:32:19.537	error	(7074) The Z-Wave driver could not be started: Error: No such file or directory, cannot open /dev/ttyUSB2
          zwave2.0	2021-05-15 21:32:19.402	info	(7074) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
          zwave2.0	2021-05-15 21:32:19.096	error	(7074) Cannot find search "folder" in "system"
          host.raspberrypi	2021-05-15 21:32:17.022	info	instance system.adapter.zwave2.0 started with pid 7074
          host.raspberrypi	2021-05-15 21:32:14.431	info	instance system.adapter.zwave2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          host.raspberrypi	2021-05-15 21:32:13.861	info	stopInstance system.adapter.zwave2.0 send kill signal
          zwave2.0	2021-05-15 21:32:13.843	info	(6946) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          zwave2.0	2021-05-15 21:32:13.841	info	(6946) terminating
          zwave2.0	2021-05-15 21:32:13.839	info	(6946) Shutting down driver...
          zwave2.0	2021-05-15 21:32:13.837	info	(6946) Got terminate signal TERMINATE_YOURSELF
          host.raspberrypi	2021-05-15 21:32:13.792	info	stopInstance system.adapter.zwave2.0 (force=false, process=true)
          zwave2.0	2021-05-15 21:31:08.286	error	(6946) The Z-Wave driver could not be started: Error: No such file or directory, cannot open /dev/ttyUSB1
          zwave2.0	2021-05-15 21:31:08.145	info	(6946) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
          zwave2.0	2021-05-15 21:31:07.802	error	(6946) Cannot find search "folder" in "system"
          host.raspberrypi	2021-05-15 21:31:05.810	info	instance system.adapter.zwave2.0 started with pid 6946
          host.raspberrypi	2021-05-15 21:31:03.270	info	instance system.adapter.zwave2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          zwave2.0	2021-05-15 21:31:02.675	info	(5112) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          zwave2.0	2021-05-15 21:31:02.674	info	(5112) terminating
          zwave2.0	2021-05-15 21:31:02.673	info	(5112) Shutting down driver...
          zwave2.0	2021-05-15 21:31:02.671	info	(5112) Got terminate signal TERMINATE_YOURSELF
          host.raspberrypi	2021-05-15 21:31:02.671	info	stopInstance system.adapter.zwave2.0 send kill signal
          host.raspberrypi	2021-05-15 21:31:02.655	info	stopInstance system.adapter.zwave2.0 (force=false, process=true)
          zwave2.0	2021-05-15 21:30:44.425	error	(5112) The Z-Wave driver could not be started: Error: No such file or directory, cannot open /dev/ttyUSB0
          zwave2.0	2021-05-15 21:30:44.282	info	(5112) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
          zwave2.0	2021-05-15 21:30:43.974	error	(5112) Cannot find search "folder" in "system"
          host.raspberrypi	2021-05-15 21:30:41.842	info	instance system.adapter.zwave2.0 started with pid 5112
          host.raspberrypi	2021-05-15 21:30:39.348	info	instance system.adapter.zwave2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          zwave2.0	2021-05-15 21:30:38.761	info	(16918) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          zwave2.0	2021-05-15 21:30:38.760	info	(16918) terminating
          zwave2.0	2021-05-15 21:30:38.758	info	(16918) Shutting down driver...
          zwave2.0	2021-05-15 21:30:38.756	info	(16918) Got terminate signal TERMINATE_YOURSELF
          host.raspberrypi	2021-05-15 21:30:38.757	info	stopInstance system.adapter.zwave2.0 send kill signal
          host.raspberrypi	2021-05-15 21:30:38.750	info	stopInstance system.adapter.zwave2.0 (force=false, process=true)
          host.raspberrypi	2021-05-15 21:30:26.403	info	instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
          ical.0	2021-05-15 21:30:25.828	info	(3424) Terminated (NO_ERROR): Without reason
          ical.0	2021-05-15 21:30:20.617	info	(3424) processing URL: calendar1 https://calendar.google.com/calendar/ical/57.schneider%40gmail.com/private-b963e159ce3e88a349db6f5e92dd3c86/basic.ics
          ical.0	2021-05-15 21:30:20.019	info	(3424) starting. Version 1.7.4 in /opt/iobroker/node_modules/iobroker.ical, node: v12.22.1, js-controller: 3.2.16
          ical.0	2021-05-15 21:30:20.004	info	(3424) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
          host.raspberrypi	2021-05-15 21:30:18.286	info	instance system.adapter.ical.0 started with pid 3424
            @esmax666
            lsusb
            Stick rausnehmen, warten, Stick wieder rein,
            letzte Zeilen von
            dmesg -T
            anschauen.
              Esmax666 @Thomas Braun last edited by Esmax666
              pi@raspberrypi:~ $ lsusb
              Bus 002 Device 002: ID 0781:5581 SanDisk Corp. Ultra
              Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
              Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
              Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
              pi@raspberrypi:~ $ dmesg -T
              [Sa Mai 15 21:06:14 2021] Booting Linux on physical CPU 0x0
              [Sa Mai 15 21:06:14 2021] Linux version 5.10.17-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1414 SMP Fri Apr 30 13:20:47 BST 2021
              [Sa Mai 15 21:06:14 2021] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
              [Sa Mai 15 21:06:14 2021] CPU: div instructions available: patching division code
              [Sa Mai 15 21:06:14 2021] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
              [Sa Mai 15 21:06:14 2021] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.4
              [Sa Mai 15 21:06:14 2021] Memory policy: Data cache writealloc
              [Sa Mai 15 21:06:14 2021] Reserved memory: created CMA memory pool at 0x000000001ec00000, size 256 MiB
              [Sa Mai 15 21:06:14 2021] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
              [Sa Mai 15 21:06:14 2021] Zone ranges:
              [Sa Mai 15 21:06:14 2021]   DMA      [mem 0x0000000000000000-0x000000002fffffff]
              [Sa Mai 15 21:06:14 2021]   Normal   empty
              [Sa Mai 15 21:06:14 2021]   HighMem  [mem 0x0000000030000000-0x00000001ffffffff]
              [Sa Mai 15 21:06:14 2021] Movable zone start for each node
              [Sa Mai 15 21:06:14 2021] Early memory node ranges
              [Sa Mai 15 21:06:14 2021]   node   0: [mem 0x0000000000000000-0x000000003b2fffff]
              [Sa Mai 15 21:06:14 2021]   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
              [Sa Mai 15 21:06:14 2021]   node   0: [mem 0x0000000100000000-0x00000001ffffffff]
              [Sa Mai 15 21:06:14 2021] Initmem setup node 0 [mem 0x0000000000000000-0x00000001ffffffff]
              [Sa Mai 15 21:06:14 2021] On node 0 totalpages: 2061056
              [Sa Mai 15 21:06:14 2021]   DMA zone: 2304 pages used for memmap
              [Sa Mai 15 21:06:14 2021]   DMA zone: 0 pages reserved
              [Sa Mai 15 21:06:14 2021]   DMA zone: 196608 pages, LIFO batch:63
              [Sa Mai 15 21:06:14 2021]   HighMem zone: 1864448 pages, LIFO batch:63
              [Sa Mai 15 21:06:14 2021] percpu: Embedded 20 pages/cpu s50700 r8192 d23028 u81920
              [Sa Mai 15 21:06:14 2021] pcpu-alloc: s50700 r8192 d23028 u81920 alloc=20*4096
              [Sa Mai 15 21:06:14 2021] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
              [Sa Mai 15 21:06:14 2021] Built 1 zonelists, mobility grouping on.  Total pages: 2058752
              [Sa Mai 15 21:06:14 2021] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:1B:22:9D vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=c7534f19-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
              [Sa Mai 15 21:06:14 2021] Kernel parameter elevator= does not have any effect anymore.
                                        Please use sysfs to set IO scheduler for individual devices.
              [Sa Mai 15 21:06:14 2021] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
              [Sa Mai 15 21:06:14 2021] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
              [Sa Mai 15 21:06:14 2021] mem auto-init: stack:off, heap alloc:off, heap free:off
              [Sa Mai 15 21:06:14 2021] software IO TLB: mapped [mem 0x0000000014c00000-0x0000000018c00000] (64MB)
              [Sa Mai 15 21:06:14 2021] Memory: 7799068K/8244224K available (10240K kernel code, 1358K rwdata, 3160K rodata, 2048K init, 890K bss, 183012K reserved, 262144K cma-reserved, 7457792K highmem)
              [Sa Mai 15 21:06:14 2021] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
              [Sa Mai 15 21:06:14 2021] ftrace: allocating 33942 entries in 67 pages
              [Sa Mai 15 21:06:14 2021] ftrace: allocated 67 pages with 3 groups
              [Sa Mai 15 21:06:14 2021] rcu: Hierarchical RCU implementation.
              [Sa Mai 15 21:06:14 2021]       Rude variant of Tasks RCU enabled.
              [Sa Mai 15 21:06:14 2021]       Tracing variant of Tasks RCU enabled.
              [Sa Mai 15 21:06:14 2021] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
              [Sa Mai 15 21:06:14 2021] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
              [Sa Mai 15 21:06:14 2021] GIC: Using split EOI/Deactivate mode
              [Sa Mai 15 21:06:14 2021] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=0
              [Sa Mai 15 21:06:14 2021] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
              [Sa Mai 15 21:06:14 2021] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
              [Sa Mai 15 21:06:14 2021] bcm2835: system timer (irq = 25)
              [Sa Mai 15 21:06:14 2021] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
              [Sa Mai 15 21:06:14 2021] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
              [Sa Mai 15 21:06:14 2021] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
              [Sa Mai 15 21:06:14 2021] Switching to timer-based delay loop, resolution 18ns
              [Sa Mai 15 21:06:14 2021] Console: colour dummy device 80x30
              [Sa Mai 15 21:06:14 2021] printk: console [tty1] enabled
              [Sa Mai 15 21:06:14 2021] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
              [Sa Mai 15 21:06:14 2021] pid_max: default: 32768 minimum: 301
              [Sa Mai 15 21:06:14 2021] LSM: Security Framework initializing
              [Sa Mai 15 21:06:14 2021] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
              [Sa Mai 15 21:06:14 2021] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
              [Sa Mai 15 21:06:14 2021] Disabling memory control group subsystem
              [Sa Mai 15 21:06:14 2021] CPU: Testing write buffer coherency: ok
              [Sa Mai 15 21:06:14 2021] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
              [Sa Mai 15 21:06:14 2021] Setting up static identity map for 0x200000 - 0x20003c
              [Sa Mai 15 21:06:14 2021] rcu: Hierarchical SRCU implementation.
              [Sa Mai 15 21:06:14 2021] smp: Bringing up secondary CPUs ...
              [Sa Mai 15 21:06:14 2021] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
              [Sa Mai 15 21:06:14 2021] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
              [Sa Mai 15 21:06:14 2021] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
              [Sa Mai 15 21:06:14 2021] smp: Brought up 1 node, 4 CPUs
              [Sa Mai 15 21:06:14 2021] SMP: Total of 4 processors activated (432.00 BogoMIPS).
              [Sa Mai 15 21:06:14 2021] CPU: All CPU(s) started in HYP mode.
              [Sa Mai 15 21:06:14 2021] CPU: Virtualization extensions available.
              [Sa Mai 15 21:06:14 2021] devtmpfs: initialized
              [Sa Mai 15 21:06:14 2021] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
              [Sa Mai 15 21:06:14 2021] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
              [Sa Mai 15 21:06:14 2021] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
              [Sa Mai 15 21:06:14 2021] pinctrl core: initialized pinctrl subsystem
              [Sa Mai 15 21:06:14 2021] NET: Registered protocol family 16
              [Sa Mai 15 21:06:14 2021] DMA: preallocated 1024 KiB pool for atomic coherent allocations
              [Sa Mai 15 21:06:14 2021] audit: initializing netlink subsys (disabled)
              [Sa Mai 15 21:06:14 2021] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
              [Sa Mai 15 21:06:14 2021] thermal_sys: Registered thermal governor 'step_wise'
              [Sa Mai 15 21:06:14 2021] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
              [Sa Mai 15 21:06:14 2021] hw-breakpoint: maximum watchpoint size is 8 bytes.
              [Sa Mai 15 21:06:14 2021] Serial: AMBA PL011 UART driver
              [Sa Mai 15 21:06:14 2021] bcm2835-mbox fe00b880.mailbox: mailbox enabled
              [Sa Mai 15 21:06:14 2021] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-04-30T13:45:52, variant start
              [Sa Mai 15 21:06:14 2021] raspberrypi-firmware soc:firmware: Firmware hash is d7f29d96450abfc77cd6cf011af1faf1e03e5e56
              [Sa Mai 15 21:06:14 2021] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
              [Sa Mai 15 21:06:14 2021] vgaarb: loaded
              [Sa Mai 15 21:06:14 2021] SCSI subsystem initialized
              [Sa Mai 15 21:06:14 2021] usbcore: registered new interface driver usbfs
              [Sa Mai 15 21:06:14 2021] usbcore: registered new interface driver hub
              [Sa Mai 15 21:06:14 2021] usbcore: registered new device driver usb
              [Sa Mai 15 21:06:14 2021] usb_phy_generic phy: supply vcc not found, using dummy regulator
              [Sa Mai 15 21:06:14 2021] clocksource: Switched to clocksource arch_sys_counter
              [Sa Mai 15 21:06:15 2021] VFS: Disk quotas dquot_6.6.0
              [Sa Mai 15 21:06:15 2021] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
              [Sa Mai 15 21:06:15 2021] FS-Cache: Loaded
              [Sa Mai 15 21:06:15 2021] CacheFiles: Loaded
              [Sa Mai 15 21:06:15 2021] NET: Registered protocol family 2
              [Sa Mai 15 21:06:15 2021] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
              [Sa Mai 15 21:06:15 2021] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
              [Sa Mai 15 21:06:15 2021] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
              [Sa Mai 15 21:06:15 2021] TCP: Hash tables configured (established 8192 bind 8192)
              [Sa Mai 15 21:06:15 2021] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
              [Sa Mai 15 21:06:15 2021] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
              [Sa Mai 15 21:06:15 2021] NET: Registered protocol family 1
              [Sa Mai 15 21:06:15 2021] RPC: Registered named UNIX socket transport module.
              [Sa Mai 15 21:06:15 2021] RPC: Registered udp transport module.
              [Sa Mai 15 21:06:15 2021] RPC: Registered tcp transport module.
              [Sa Mai 15 21:06:15 2021] RPC: Registered tcp NFSv4.1 backchannel transport module.
              [Sa Mai 15 21:06:15 2021] PCI: CLS 0 bytes, default 64
              [Sa Mai 15 21:06:15 2021] Initialise system trusted keyrings
              [Sa Mai 15 21:06:15 2021] workingset: timestamp_bits=14 max_order=21 bucket_order=7
              [Sa Mai 15 21:06:15 2021] zbud: loaded
              [Sa Mai 15 21:06:15 2021] FS-Cache: Netfs 'nfs' registered for caching
              [Sa Mai 15 21:06:15 2021] NFS: Registering the id_resolver key type
              [Sa Mai 15 21:06:15 2021] Key type id_resolver registered
              [Sa Mai 15 21:06:15 2021] Key type id_legacy registered
              [Sa Mai 15 21:06:15 2021] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
              [Sa Mai 15 21:06:15 2021] Key type asymmetric registered
              [Sa Mai 15 21:06:15 2021] Asymmetric key parser 'x509' registered
              [Sa Mai 15 21:06:15 2021] bounce: pool size: 64 pages
              [Sa Mai 15 21:06:15 2021] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
              [Sa Mai 15 21:06:15 2021] io scheduler mq-deadline registered
              [Sa Mai 15 21:06:15 2021] io scheduler kyber registered
              [Sa Mai 15 21:06:15 2021] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
              [Sa Mai 15 21:06:15 2021] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
              [Sa Mai 15 21:06:15 2021] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
              [Sa Mai 15 21:06:15 2021] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
              [Sa Mai 15 21:06:15 2021] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
              [Sa Mai 15 21:06:15 2021] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
              [Sa Mai 15 21:06:15 2021] pci_bus 0000:00: root bus resource [bus 00-ff]
              [Sa Mai 15 21:06:15 2021] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
              [Sa Mai 15 21:06:15 2021] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
              [Sa Mai 15 21:06:15 2021] pci 0000:00:00.0: PME# supported from D0 D3hot
              [Sa Mai 15 21:06:15 2021] PCI: bus0: Fast back to back transfers disabled
              [Sa Mai 15 21:06:15 2021] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
              [Sa Mai 15 21:06:15 2021] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
              [Sa Mai 15 21:06:15 2021] pci 0000:01:00.0: PME# supported from D0 D3hot
              [Sa Mai 15 21:06:15 2021] PCI: bus1: Fast back to back transfers disabled
              [Sa Mai 15 21:06:15 2021] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
              [Sa Mai 15 21:06:15 2021] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
              [Sa Mai 15 21:06:15 2021] pci 0000:00:00.0: PCI bridge to [bus 01]
              [Sa Mai 15 21:06:15 2021] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
              [Sa Mai 15 21:06:15 2021] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
              [Sa Mai 15 21:06:15 2021] pcieport 0000:00:00.0: PME: Signaling with IRQ 62
              [Sa Mai 15 21:06:15 2021] iproc-rng200 fe104000.rng: hwrng registered
              [Sa Mai 15 21:06:15 2021] vc-mem: phys_addr:0x00000000 mem_base=0x3eb00000 mem_size:0x3ff00000(1023 MiB)
              [Sa Mai 15 21:06:15 2021] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
              [Sa Mai 15 21:06:15 2021] brd: module loaded
              [Sa Mai 15 21:06:15 2021] loop: module loaded
              [Sa Mai 15 21:06:15 2021] Loading iSCSI transport class v2.0-870.
              [Sa Mai 15 21:06:15 2021] libphy: Fixed MDIO Bus: probed
              [Sa Mai 15 21:06:15 2021] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
              [Sa Mai 15 21:06:15 2021] libphy: bcmgenet MII bus: probed
              [Sa Mai 15 21:06:15 2021] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
              [Sa Mai 15 21:06:15 2021] usbcore: registered new interface driver r8152
              [Sa Mai 15 21:06:15 2021] usbcore: registered new interface driver lan78xx
              [Sa Mai 15 21:06:15 2021] usbcore: registered new interface driver smsc95xx
              [Sa Mai 15 21:06:15 2021] xhci_hcd 0000:01:00.0: xHCI Host Controller
              [Sa Mai 15 21:06:15 2021] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
              [Sa Mai 15 21:06:15 2021] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000030000000890
              [Sa Mai 15 21:06:15 2021] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
              [Sa Mai 15 21:06:15 2021] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
              [Sa Mai 15 21:06:15 2021] usb usb1: Product: xHCI Host Controller
              [Sa Mai 15 21:06:15 2021] usb usb1: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
              [Sa Mai 15 21:06:15 2021] usb usb1: SerialNumber: 0000:01:00.0
              [Sa Mai 15 21:06:15 2021] hub 1-0:1.0: USB hub found
              [Sa Mai 15 21:06:15 2021] hub 1-0:1.0: 1 port detected
              [Sa Mai 15 21:06:15 2021] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
              [Sa Mai 15 21:06:15 2021] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
              [Sa Mai 15 21:06:15 2021] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
              [Sa Mai 15 21:06:15 2021] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
              [Sa Mai 15 21:06:15 2021] usb usb2: Product: xHCI Host Controller
              [Sa Mai 15 21:06:15 2021] usb usb2: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
              [Sa Mai 15 21:06:15 2021] usb usb2: SerialNumber: 0000:01:00.0
              [Sa Mai 15 21:06:15 2021] hub 2-0:1.0: USB hub found
              [Sa Mai 15 21:06:15 2021] hub 2-0:1.0: 4 ports detected
              [Sa Mai 15 21:06:15 2021] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
              [Sa Mai 15 21:06:15 2021] dwc_otg: FIQ enabled
              [Sa Mai 15 21:06:15 2021] dwc_otg: NAK holdoff enabled
              [Sa Mai 15 21:06:15 2021] dwc_otg: FIQ split-transaction FSM enabled
              [Sa Mai 15 21:06:15 2021] Module dwc_common_port init
              [Sa Mai 15 21:06:15 2021] usbcore: registered new interface driver uas
              [Sa Mai 15 21:06:15 2021] usbcore: registered new interface driver usb-storage
              [Sa Mai 15 21:06:15 2021] mousedev: PS/2 mouse device common for all mice
              [Sa Mai 15 21:06:15 2021] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
              [Sa Mai 15 21:06:15 2021] sdhci: Secure Digital Host Controller Interface driver
              [Sa Mai 15 21:06:15 2021] sdhci: Copyright(c) Pierre Ossman
              [Sa Mai 15 21:06:15 2021] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
              [Sa Mai 15 21:06:15 2021] sdhci-pltfm: SDHCI platform and OF driver helper
              [Sa Mai 15 21:06:15 2021] ledtrig-cpu: registered to indicate activity on CPUs
              [Sa Mai 15 21:06:15 2021] hid: raw HID events driver (C) Jiri Kosina
              [Sa Mai 15 21:06:15 2021] usbcore: registered new interface driver usbhid
              [Sa Mai 15 21:06:15 2021] usbhid: USB HID core driver
              [Sa Mai 15 21:06:15 2021] Initializing XFRM netlink socket
              [Sa Mai 15 21:06:15 2021] NET: Registered protocol family 17
              [Sa Mai 15 21:06:15 2021] Key type dns_resolver registered
              [Sa Mai 15 21:06:15 2021] Registering SWP/SWPB emulation handler
              [Sa Mai 15 21:06:15 2021] registered taskstats version 1
              [Sa Mai 15 21:06:15 2021] Loading compiled-in X.509 certificates
              [Sa Mai 15 21:06:15 2021] Key type ._fscrypt registered
              [Sa Mai 15 21:06:15 2021] Key type .fscrypt registered
              [Sa Mai 15 21:06:15 2021] Key type fscrypt-provisioning registered
              [Sa Mai 15 21:06:15 2021] uart-pl011 fe201000.serial: there is not valid maps for state default
              [Sa Mai 15 21:06:15 2021] uart-pl011 fe201000.serial: cts_event_workaround enabled
              [Sa Mai 15 21:06:15 2021] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
              [Sa Mai 15 21:06:15 2021] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
              [Sa Mai 15 21:06:15 2021] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
              [Sa Mai 15 21:06:15 2021] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
              [Sa Mai 15 21:06:15 2021] of_cfs_init
              [Sa Mai 15 21:06:15 2021] of_cfs_init: OK
              [Sa Mai 15 21:06:15 2021] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
              [Sa Mai 15 21:06:15 2021] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
              [Sa Mai 15 21:06:15 2021] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
              [Sa Mai 15 21:06:15 2021] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
              [Sa Mai 15 21:06:15 2021] Waiting for root device PARTUUID=c7534f19-02...
              [Sa Mai 15 21:06:15 2021] random: fast init done
              [Sa Mai 15 21:06:15 2021] mmc1: new high speed SDIO card at address 0001
              [Sa Mai 15 21:06:15 2021] usb 1-1: new high-speed USB device number 2 using xhci_hcd
              [Sa Mai 15 21:06:15 2021] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
              [Sa Mai 15 21:06:15 2021] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
              [Sa Mai 15 21:06:15 2021] usb 1-1: Product: USB2.0 Hub
              [Sa Mai 15 21:06:15 2021] hub 1-1:1.0: USB hub found
              [Sa Mai 15 21:06:15 2021] hub 1-1:1.0: 4 ports detected
              [Sa Mai 15 21:06:16 2021] usb 2-2: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
              [Sa Mai 15 21:06:16 2021] usb 2-2: New USB device found, idVendor=0781, idProduct=5581, bcdDevice= 1.00
              [Sa Mai 15 21:06:16 2021] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
              [Sa Mai 15 21:06:16 2021] usb 2-2: Product: Ultra
              [Sa Mai 15 21:06:16 2021] usb 2-2: Manufacturer: SanDisk
              [Sa Mai 15 21:06:16 2021] usb 2-2: SerialNumber: 4C530000211114109264
              [Sa Mai 15 21:06:16 2021] usb-storage 2-2:1.0: USB Mass Storage device detected
              [Sa Mai 15 21:06:16 2021] scsi host0: usb-storage 2-2:1.0
              [Sa Mai 15 21:06:17 2021] scsi 0:0:0:0: Direct-Access     SanDisk  Ultra            1.00 PQ: 0 ANSI: 6
              [Sa Mai 15 21:06:17 2021] sd 0:0:0:0: [sda] 121307136 512-byte logical blocks: (62.1 GB/57.8 GiB)
              [Sa Mai 15 21:06:17 2021] sd 0:0:0:0: [sda] Write Protect is off
              [Sa Mai 15 21:06:17 2021] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
              [Sa Mai 15 21:06:17 2021] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
              [Sa Mai 15 21:06:17 2021]  sda: sda1 sda2
              [Sa Mai 15 21:06:17 2021] sd 0:0:0:0: [sda] Attached SCSI removable disk
              [Sa Mai 15 21:06:17 2021] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
              [Sa Mai 15 21:06:17 2021] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
              [Sa Mai 15 21:06:17 2021] devtmpfs: mounted
              [Sa Mai 15 21:06:17 2021] Freeing unused kernel memory: 2048K
              [Sa Mai 15 21:06:17 2021] Run /sbin/init as init process
              [Sa Mai 15 21:06:17 2021]   with arguments:
              [Sa Mai 15 21:06:17 2021]     /sbin/init
              [Sa Mai 15 21:06:17 2021]     splash
              [Sa Mai 15 21:06:17 2021]   with environment:
              [Sa Mai 15 21:06:17 2021]     HOME=/
              [Sa Mai 15 21:06:17 2021]     TERM=linux
              [Sa Mai 15 21:06:17 2021] systemd[1]: System time before build time, advancing clock.
              [Sa Mai 15 21:06:17 2021] NET: Registered protocol family 10
              [Sa Mai 15 21:06:17 2021] Segment Routing with IPv6
              [Sa Mai 15 21:06:17 2021] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
              [Sa Mai 15 21:06:17 2021] systemd[1]: Detected architecture arm.
              [Sa Mai 15 21:06:17 2021] systemd[1]: Set hostname to <raspberrypi>.
              [Sa Mai 15 21:06:18 2021] systemd[1]: /lib/systemd/system/xrdp.service:8: PIDFile= references path below legacy directory /var/run/, updating /var/run/xrdp/xrdp.pid → /run/xrdp/xrdp.pid; please update the unit file accordingly.
              [Sa Mai 15 21:06:18 2021] systemd[1]: /lib/systemd/system/xrdp-sesman.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/xrdp/xrdp-sesman.pid → /run/xrdp/xrdp-sesman.pid; please update the unit file accordingly.
              [Sa Mai 15 21:06:18 2021] random: systemd: uninitialized urandom read (16 bytes read)
              [Sa Mai 15 21:06:18 2021] systemd[1]: Listening on udev Control Socket.
              [Sa Mai 15 21:06:18 2021] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
              [Sa Mai 15 21:06:18 2021] systemd[1]: Created slice User and Session Slice.
              [Sa Mai 15 21:06:18 2021] systemd[1]: Reached target Swap.
              [Sa Mai 15 21:06:18 2021] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
              [Sa Mai 15 21:06:19 2021] i2c /dev entries driver
              [Sa Mai 15 21:06:19 2021] EXT4-fs (sda2): re-mounted. Opts: (null)
              [Sa Mai 15 21:06:19 2021] systemd-journald[113]: Received request to flush runtime journal from PID 1
              [Sa Mai 15 21:06:20 2021] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
              [Sa Mai 15 21:06:20 2021] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
              [Sa Mai 15 21:06:20 2021] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
              [Sa Mai 15 21:06:20 2021] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
              [Sa Mai 15 21:06:20 2021] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
              [Sa Mai 15 21:06:20 2021] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
              [Sa Mai 15 21:06:20 2021] [vc_sm_connected_init]: start
              [Sa Mai 15 21:06:20 2021] [vc_sm_connected_init]: installed successfully
              [Sa Mai 15 21:06:20 2021] mc: Linux media interface: v0.10
              [Sa Mai 15 21:06:20 2021] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
              [Sa Mai 15 21:06:20 2021] bcm2835_audio bcm2835_audio: card created with 8 channels
              [Sa Mai 15 21:06:20 2021] videodev: Linux video capture interface: v2.00
              [Sa Mai 15 21:06:20 2021] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
              [Sa Mai 15 21:06:20 2021] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
              [Sa Mai 15 21:06:20 2021] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
              [Sa Mai 15 21:06:20 2021] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
              [Sa Mai 15 21:06:20 2021] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
              [Sa Mai 15 21:06:20 2021] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
              [Sa Mai 15 21:06:20 2021] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
              [Sa Mai 15 21:06:20 2021] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
              [Sa Mai 15 21:06:20 2021] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
              [Sa Mai 15 21:06:20 2021] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
              [Sa Mai 15 21:06:20 2021] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
              [Sa Mai 15 21:06:20 2021] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
              [Sa Mai 15 21:06:20 2021] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
              [Sa Mai 15 21:06:20 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
              [Sa Mai 15 21:06:20 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
              [Sa Mai 15 21:06:20 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
              [Sa Mai 15 21:06:20 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
              [Sa Mai 15 21:06:20 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
              [Sa Mai 15 21:06:20 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
              [Sa Mai 15 21:06:20 2021] cfg80211: Loading compiled-in X.509 certificates for regulatory database
              [Sa Mai 15 21:06:20 2021] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
              [Sa Mai 15 21:06:20 2021] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
              [Sa Mai 15 21:06:21 2021] brcmfmac: F1 signature read @0x18000000=0x15264345
              [Sa Mai 15 21:06:21 2021] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
              [Sa Mai 15 21:06:21 2021] usbcore: registered new interface driver brcmfmac
              [Sa Mai 15 21:06:21 2021] [drm] No displays found. Consider forcing hotplug if HDMI is attached
              [Sa Mai 15 21:06:21 2021] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
              [Sa Mai 15 21:06:21 2021] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
              [Sa Mai 15 21:06:21 2021] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
              [Sa Mai 15 21:06:21 2021] sd 0:0:0:0: Attached scsi generic sg0 type 0
              [Sa Mai 15 21:06:21 2021] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
              [Sa Mai 15 21:06:22 2021] random: crng init done
              [Sa Mai 15 21:06:22 2021] random: 7 urandom warning(s) missed due to ratelimiting
              [Sa Mai 15 21:06:23 2021] uart-pl011 fe201000.serial: no DMA platform data
              [Sa Mai 15 21:06:23 2021] 8021q: 802.1Q VLAN Support v1.8
              [Sa Mai 15 21:06:24 2021] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k FS
              [Sa Mai 15 21:06:24 2021] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
              [Sa Mai 15 21:06:24 2021] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
              [Sa Mai 15 21:06:24 2021] bcmgenet fd580000.ethernet eth0: Link is Down
              [Sa Mai 15 21:06:26 2021] broken atomic modeset userspace detected, disabling atomic
              [Sa Mai 15 21:06:27 2021] broken atomic modeset userspace detected, disabling atomic
              [Sa Mai 15 21:06:28 2021] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
              [Sa Mai 15 21:06:28 2021] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
              [Sa Mai 15 21:06:28 2021] broken atomic modeset userspace detected, disabling atomic
              [Sa Mai 15 21:06:29 2021] broken atomic modeset userspace detected, disabling atomic
              [Sa Mai 15 21:06:30 2021] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
              [Sa Mai 15 21:06:30 2021] broken atomic modeset userspace detected, disabling atomic
              [Sa Mai 15 21:06:30 2021] Bluetooth: Core ver 2.22
              [Sa Mai 15 21:06:30 2021] NET: Registered protocol family 31
              [Sa Mai 15 21:06:30 2021] Bluetooth: HCI device and connection manager initialized
              [Sa Mai 15 21:06:30 2021] Bluetooth: HCI socket layer initialized
              [Sa Mai 15 21:06:30 2021] Bluetooth: L2CAP socket layer initialized
              [Sa Mai 15 21:06:30 2021] Bluetooth: SCO socket layer initialized
              [Sa Mai 15 21:06:30 2021] Bluetooth: HCI UART driver ver 2.3
              [Sa Mai 15 21:06:30 2021] Bluetooth: HCI UART protocol H4 registered
              [Sa Mai 15 21:06:30 2021] Bluetooth: HCI UART protocol Three-wire (H5) registered
              [Sa Mai 15 21:06:30 2021] Bluetooth: HCI UART protocol Broadcom registered
              [Sa Mai 15 21:06:30 2021] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
              [Sa Mai 15 21:06:30 2021] Bluetooth: BNEP filters: protocol multicast
              [Sa Mai 15 21:06:30 2021] Bluetooth: BNEP socket layer initialized
              [Sa Mai 15 21:06:31 2021] broken atomic modeset userspace detected, disabling atomic
              [Sa Mai 15 21:06:32 2021] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
              [Sa Mai 15 21:06:32 2021] broken atomic modeset userspace detected, disabling atomic
              [Sa Mai 15 21:06:33 2021] broken atomic modeset userspace detected, disabling atomic
              [Sa Mai 15 21:06:34 2021] broken atomic modeset userspace detected, disabling atomic
              [Sa Mai 15 21:06:34 2021] Bluetooth: hci0: command 0x1003 tx timeout
              [Sa Mai 15 21:06:35 2021] broken atomic modeset userspace detected, disabling atomic
              [Sa Mai 15 21:06:36 2021] Bluetooth: hci0: command 0x1001 tx timeout
              [Sa Mai 15 21:06:37 2021] broken atomic modeset userspace detected, disabling atomic
              [Sa Mai 15 21:06:38 2021] broken atomic modeset userspace detected, disabling atomic
              [Sa Mai 15 21:06:39 2021] Bluetooth: hci0: command 0x1009 tx timeout
              [Sa Mai 15 21:06:39 2021] broken atomic modeset userspace detected, disabling atomic
              [Sa Mai 15 21:06:40 2021] broken atomic modeset userspace detected, disabling atomic
              [Sa Mai 15 21:06:41 2021] broken atomic modeset userspace detected, disabling atomic
              [Sa Mai 15 21:06:42 2021] broken atomic modeset userspace detected, disabling atomic
              [Sa Mai 15 21:07:32 2021] fuse: init (API version 7.32)
              (usb stick ist auf USB2 angeschlossen)
                @esmax666
                Schalt den Desktop aus
                Das device dürfte unter /dev/ttyAMA0 zu finden sein, nicht unter ttyUSBx
                  Geht auch nicht
                  zwave2.0	2021-05-15 22:01:06.588	info	(18812) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
                  zwave2.0	2021-05-15 22:01:06.307	error	(18812) Cannot find search "folder" in "system"
                  host.raspberrypi	2021-05-15 22:01:04.335	info	instance system.adapter.zwave2.0 started with pid 18812
                  host.raspberrypi	2021-05-15 22:01:04.009	info	"system.adapter.zwave2.0" enabled
                  host.raspberrypi	2021-05-15 22:00:59.765	info	instance system.adapter.zwave2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  zwave2.0	2021-05-15 22:00:59.157	info	(18779) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  zwave2.0	2021-05-15 22:00:59.155	info	(18779) terminating
                  zwave2.0	2021-05-15 22:00:59.153	info	(18779) Shutting down driver...
                  host.raspberrypi	2021-05-15 22:00:59.152	info	stopInstance system.adapter.zwave2.0 send kill signal
                  zwave2.0	2021-05-15 22:00:59.151	info	(18779) Got terminate signal TERMINATE_YOURSELF
                  host.raspberrypi	2021-05-15 22:00:59.138	info	stopInstance system.adapter.zwave2.0 (force=false, process=true)
                  host.raspberrypi	2021-05-15 22:00:59.135	info	"system.adapter.zwave2.0" disabled
                  host.raspberrypi	2021-05-15 22:00:08.488	info	instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                  ical.0	2021-05-15 22:00:07.955	info	(18794) Terminated (NO_ERROR): Without reason
                  host.raspberrypi	2021-05-15 22:00:00.086	info	instance system.adapter.ical.0 started with pid 18794
                  zwave2.0	2021-05-15 21:59:38.971	info	(18779) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
                  zwave2.0	2021-05-15 21:59:38.641	error	(18779) Cannot find search "folder" in "system"
                  host.raspberrypi	2021-05-15 21:59:36.598	info	instance system.adapter.zwave2.0 started with pid 18779
                  host.raspberrypi	2021-05-15 21:59:34.134	info	instance system.adapter.zwave2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  zwave2.0	2021-05-15 21:59:33.527	info	(17983) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  zwave2.0	2021-05-15 21:59:33.526	info	(17983) terminating
                  zwave2.0	2021-05-15 21:59:33.525	info	(17983) Shutting down driver...
                  host.raspberrypi	2021-05-15 21:59:33.523	info	stopInstance system.adapter.zwave2.0 send kill signal
                  zwave2.0	2021-05-15 21:59:33.523	info	(17983) Got terminate signal TERMINATE_YOURSELF
                  host.raspberrypi	2021-05-15 21:59:33.512	info	stopInstance system.adapter.zwave2.0 (force=false, process=true)
                  zwave2.0	2021-05-15 21:48:05.284	error	(17983) The Z-Wave driver could not be started: Error: No such file or directory, cannot open /dev/ttyUSB2
                    @esmax666 Zumindest das Gerät wird gefunden.
                    Und nimm Mal den ical Link da raus...
                      @thomas-braun was meinst du wie soll ich das weg machrn?
                        @esmax666 Editieren und die Zeilen zu ical löschen
                          @thomas-braun Ach so ok done
                          Aber wo können das Problem kommen?
                            @esmax666
                            iobroker stop
                            iobroker setup first
                            iobroker start
                              Ich bekomme das
                              zwave2.0	2021-05-15 22:42:36.595	info	(20844) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
                              host.raspberrypi	2021-05-15 22:42:34.299	info	instance system.adapter.zwave2.0 started with pid 20844
                              host.raspberrypi	2021-05-15 22:42:34.149	info	"system.adapter.zwave2.0" enabled
                              host.raspberrypi	2021-05-15 22:42:19.970	info	Do not restart adapter system.adapter.zwave2.0 because disabled or deleted
                              host.raspberrypi	2021-05-15 22:42:19.968	error	instance system.adapter.zwave2.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
                              zwave2.0	2021-05-15 22:42:19.322	warn	(20832) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
                              zwave2.0	2021-05-15 22:42:19.309	error	(20832) adapter disabled
                              Aber ich hatte für die raspi pi3 schon usb0 als parameter. Ich bin fast sicher
                              Eventuell muss man driver installieren?
                                @esmax666 Jetzt müsstest du den Adapter einstellen können.
                                  Was.soll ich genau einstellen? Und wo?
                                  Soll ich das auch installieren?
                                  Install additional packages
                                  On some systems it will be necessary to install additional packages. Therefore run the following on the console before installing the adapter:
                                  apt-get install pkg-config libudev-dev
                                    @esmax666 Wenn du das noch nicht getan hast...
                                    E 1 Reply Last reply Reply Quote -1
                                      @thomas-braun war schon da habe gerade geprüft
                                        @esmax666 Wie sieht denn jetzt die Adapter config aus?
                                          @thomas-braun wie immer gleich
                                            @esmax666
                                            Da kann ich nicht weiterhelfen. Hab den Adapter nicht im Einsatz. Aber die 17 Updates könntest du schon mal einspielen.
                                            1.2k
                                            9833
