    4. Probleme mit Serialport bei zwave2
      Esmax666 @Esmax666 last edited by
      @thomas-braun said in Test Adapter Z-Wave 2 v1.10.x:
      Windows User, oder? Der Treiber ist im Linux-Kernel schon drin.
      warum windows User ?
      steht sogar in log
      host.raspberrypi	2021-05-16 08:00:00.072	info	instance system.adapter.ical.0 started with pid 29746
      zwave2.0	2021-05-16 07:55:56.747	error	(12308) The Z-Wave driver could not be started: Error: Is a directory, cannot open /dev/
      zwave2.0	2021-05-16 07:55:56.584	info	(12308) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
      host.raspberrypi	2021-05-16 07:55:54.148	info	instance system.adapter.zwave2.0 started with pid 12308
      host.raspberrypi	2021-05-16 07:55:51.659	info	instance system.adapter.zwave2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      zwave2.0	2021-05-16 07:55:51.028	info	(6004) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      zwave2.0	2021-05-16 07:55:51.026	info	(6004) terminating
      E Thomas Braun 2 Replies Last reply Reply Quote 0
        Linux raspberrypi 5.10.17-v7l+ #1414 SMP Fri Apr 30 13:20:47 BST 2021 armv7l
        The programs included with the Debian GNU/Linux system are free software;
        the exact distribution terms for each program are described in the
        individual files in /usr/share/doc/*/copyright.
        Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
        permitted by applicable law.
        Last login: Sun May 16 00:06:39 2021
        pi@raspberrypi:~ $ npm i iobroker.zwave2
        > @serialport/bindings@9.0.7 install /home/pi/node_modules/@serialport/bindings
        > prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
        prebuild-install WARN install No prebuilt binaries found (target=12.22.1 runtime=node arch=arm libc= platform=linux)
        make: Verzeichnis „/home/pi/node_modules/@serialport/bindings/build“ wird betreten
          CXX(target) Release/obj.target/bindings/src/serialport.o
        ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
           uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
        ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
           uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
        ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
           uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
        ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
           uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
        ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/serialport.cpp:271:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
           uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
        ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/serialport.cpp:316:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
           uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
        ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/serialport.cpp:366:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
         _queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
        ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/serialport.cpp:412:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
           uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
        ../src/serialport.cpp: At global scope:
        ../src/serialport.cpp:433:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
         SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
        ../src/serialport.cpp:452:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
         SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
        In file included from ../../../nan/nan.h:56,
                         from ../src/./serialport.h:6,
                         from ../src/serialport.cpp:1:
        /home/pi/.cache/node-gyp/12.22.1/include/node/node.h:736:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
               (node::addon_register_func) (regfunc),                          \
        /home/pi/.cache/node-gyp/12.22.1/include/node/node.h:770:3: note: in expansion of macro ‘NODE_MODULE_X’
           NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
        ../src/serialport.cpp:486:1: note: in expansion of macro ‘NODE_MODULE’
         NODE_MODULE(serialport, init);
          CXX(target) Release/obj.target/bindings/src/serialport_unix.o
        ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
        ../src/serialport_unix.cpp:176:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
             snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);
        ../src/serialport_unix.cpp:176:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024
        ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
        ../src/serialport_unix.cpp:86:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
             snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);
        ../src/serialport_unix.cpp:86:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024
          CXX(target) Release/obj.target/bindings/src/poller.o
          CXX(target) Release/obj.target/bindings/src/serialport_linux.o
          SOLINK_MODULE(target) Release/obj.target/bindings.node
          COPY Release/bindings.node
        make: Verzeichnis „/home/pi/node_modules/@serialport/bindings/build“ wird verlassennpm WARN saveError ENOENT: no such file or directory, open '/home/pi/package.json'
        npm notice created a lockfile as package-lock.json. You should commit this file.
        npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
        npm WARN pi No description
        npm WARN pi No repository field.
        npm WARN pi No README data
        npm WARN pi No license field.
        + iobroker.zwave2@1.10.0
        added 168 packages from 189 contributors and audited 168 packages in 41.299s
        29 packages are looking for funding
          run `npm fund` for details
        found 0 vulnerabilities
        pi@raspberrypi:~ $ npm i zwave-js
        + zwave-js@7.4.0
        updated 1 package and audited 309 packages in 6.047s
        pi@raspberrypi:~ $
          Esmax666 @AlCalzone last edited by
          @alcalzone
          Das ist die Raspi3 die die funktionniert (npm version vielleicht passt nicht)
          (hier ist ACM0) auf raspi4 geht auch nicht fehlt etwas ?
            Thomas Braun Most Active @Esmax666 last edited by Thomas Braun
            @esmax666 sagte in Test Adapter Z-Wave 2 v1.10.x:
            steht sogar in log
            Da steht, dass /dev kein device node ist sondern ein Verzeichnis. Vermutlich hast du /dev in den Einstellungen des Adapters drin.
            Ist falsch. Jetzt hast du das im /home-Verzeichnis von pi installiert.
            Nimm den Adapter aus der Adapterliste im Admin.
            Aus deinem dmesg:
            [Sa Mai 15 21:06:15 2021] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
            Das ist der für das Gerät geladene Treiber. Und da sieht man auch, dass das Device auf ttyAMA0 liegt.
              Esmax666 @Thomas Braun last edited by
              Hatte ich schon gemacht.
              sogar sogar instance weg gemacht und neu gemacht
              leider geht es nicht mehr
                Stimmt dann wohl.
                Leider kann man aus deiner 'Fehlerbeschreibung' nichts herauslesen.
                  @thomas-braun was kann ich sonst noch als info geben ?
                  sonst habe ich noch 2 warn und 1 error
                  info.0	2021-05-16 13:07:15.628	warn	(2791) State "info.0.uuid" has no existing object, this might lead to an error in future versions
                  host.raspberrypi	2021-05-16 13:00:08.345	info	instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                  host.raspberrypi	2021-05-16 13:00:00.042	info	instance system.adapter.ical.0 started with pid 5361
                  zwave2.0	2021-05-16 12:59:53.829	info	(5346) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
                  host.raspberrypi	2021-05-16 12:59:51.487	info	instance system.adapter.zwave2.0 started with pid 5346
                  host.raspberrypi	2021-05-16 12:59:21.429	info	Restart adapter system.adapter.zwave2.0 because enabled
                  host.raspberrypi	2021-05-16 12:59:21.428	info	instance system.adapter.zwave2.0 terminated with code NaN ()
                  host.raspberrypi	2021-05-16 12:59:21.427	warn	instance system.adapter.zwave2.0 terminated due to SIGABRT
                  host.raspberrypi	2021-05-16 12:59:21.422	error	Caught by controller[0]: FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
                  zwave2.0	2021-05-16 12:45:57.264	info	(5176) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
                  host.raspberrypi	2021-05-16 12:45:55.024	info	instance system.adapter.zwave2.0 started with pid 5176
                  host.raspberrypi	2021-05-16 12:45:24.958	info	Restart adapter system.adapter.zwave2.0 because enabled
                  host.raspberrypi	2021-05-16 12:45:24.957	info	instance system.adapter.zwave2.0 terminated with code NaN ()
                  host.raspberrypi	2021-05-16 12:45:24.956	warn	instance system.adapter.zwave2.0 terminated due to SIGABRT
                  host.raspberrypi	2021-05-16 12:45:24.950	error	Caught by controller[0]: FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
                  info.0	2021-05-16 12:37:15.604	warn	(2791) State "info.0.uuid" has no existing object, this might lead to an error in future versions
                  zwave2.0	2021-05-16 12:32:01.208	info	(5010) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
                  host.raspberrypi	2021-05-16 12:31:58.911	info	instance system.adapter.zwave2.0 started with pid 5010
                  host.raspberrypi	2021-05-16 12:31:28.859	info	Restart adapter system.adapter.zwave2.0 because enabled
                  host.raspberrypi	2021-05-16 12:31:28.859	info	instance system.adapter.zwave2.0 terminated with code NaN ()
                  host.raspberrypi	2021-05-16 12:31:28.858	warn	instance system.adapter.zwave2.0 terminated due to SIGABRT
                  host.raspberrypi	2021-05-16 12:31:28.857	error	Caught by controller[0]: FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
                    @esmax666
                    Speicher dicht?
                    free -ht
                    anschauen.
                        @esmax666
                        Bitte keine Bilderchen posten, KonsolenTEXT in CodeTags eingebettet hier rein.
                        • AlCalzone
                          @Esmax666 die Datei brauchst du inzwischen nicht mehr manuell bearbeiten. Auf Pi 4 sind das die Schritte, die ausreichen: Konsole auf,
                          sudo raspi-config
                          • 3 Interface Options
                          • P6 Serial Port
                          • "Would you like a login shell to be accessible over serial?" => NO
                          • "Would you like the serial port hardware to be enabled?" => YES
                          Danach sollte der Adapter funktionieren, wenn du /dev/serial0 einträgst - ist leider nicht in der Liste zu finden.
                          Thomas Braun E 3 Replies Last reply Reply Quote 0
                            Thomas Braun Most Active @AlCalzone last edited by
                            @alcalzone
                            An den Hardware-Part hatte ich noch gar nicht gedacht, bzw. vorausgesetzt das der natürlich auch aktiviert wurde.
                            Wobei dann /dev/serial0 'nur' ein symlink auf das device node /dev/ttyAMA0 sein dürfte.
                              @alcalzone
                              ok ist jetzt aktviert
                              und auch neu gestartet
                              aber immer Driver could not be started
                              zwave2.0	2021-05-16 15:32:12.067	error	(17665) The Z-Wave driver could not be started: Error: No such file or directory, cannot open /dev/serial0
                              zwave2.0	2021-05-16 15:32:11.921	info	(17665) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
                              host.raspberrypi	2021-05-16 15:32:09.511	info	instance system.adapter.zwave2.0 started with pid 17665
                              host.raspberrypi	2021-05-16 15:32:07.043	info	instance system.adapter.zwave2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              zwave2.0	2021-05-16 15:32:06.372	info	(5742) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              zwave2.0	2021-05-16 15:32:06.371	info	(5742) terminating
                              zwave2.0	2021-05-16 15:32:06.369	info	(5742) Shutting down driver...
                              zwave2.0	2021-05-16 15:32:06.367	info	(5742) Got terminate signal TERMINATE_YOURSELF
                              host.raspberrypi	2021-05-16 15:32:06.367	info	stopInstance system.adapter.zwave2.0 send kill signal
                              host.raspberrypi	2021-05-16 15:32:06.359	info	stopInstance system.adapter.zwave2.0 (force=false, process=true)
                              host.raspberrypi	2021-05-16 15:30:27.733	info	instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                              ical.0	2021-05-16 15:30:27.198	info	(8661) Terminated (NO_ERROR): Without reason
                                @esmax666
                                Und wenn du das device direkt anrufst? Unter /dev/ttyAMA0
                                Gibt es das Gerät?
                                ls -la /dev/ttyAMA0
                                sudo -u iobroker groups
                                  Esmax666 @Thomas Braun last edited by Esmax666
                                  @thomas-braun said in Probleme mit Serialport bei zwave2:
                                  /dev/ttyAMA0
                                  dann bekomme ich wie davor
                                  zwave2.0	2021-05-16 15:39:28.776	info	(15581) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
                                  host.raspberrypi	2021-05-16 15:39:26.309	info	instance system.adapter.zwave2.0 started with pid 15581
                                  host.raspberrypi	2021-05-16 15:39:23.743	info	instance system.adapter.zwave2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  zwave2.0	2021-05-16 15:39:23.146	info	(17665) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  zwave2.0	2021-05-16 15:39:23.145	info	(17665) terminating
                                  zwave2.0	2021-05-16 15:39:23.143	info	(17665) Shutting down driver...
                                  host.raspberrypi	2021-05-16 15:39:23.141	info	stopInstance system.adapter.zwave2.0 send kill signal
                                  zwave2.0	2021-05-16 15:39:23.141	info	(17665) Got terminate signal TERMINATE_YOURSELF
                                  host.raspberrypi	2021-05-16 15:39:23.126	info	stopInstance system.adapter.zwave2.0 (force=false, process=true)
                                  und als "debug level" bekomme ich das :
                                  zwave2.0	2021-05-16 15:41:19.769	info	(24494) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
                                  zwave2.0	2021-05-16 15:41:19.518	debug	(24494) statesDB connected
                                  zwave2.0	2021-05-16 15:41:19.517	debug	(24494) States connected to redis: 127.0.0.1:9000
                                  zwave2.0	2021-05-16 15:41:19.510	debug	(24494) States create User PubSub Client
                                  zwave2.0	2021-05-16 15:41:19.508	debug	(24494) States create System PubSub Client
                                  zwave2.0	2021-05-16 15:41:19.501	debug	(24494) Redis States: Use Redis connection: 127.0.0.1:9000
                                  zwave2.0	2021-05-16 15:41:19.498	debug	(24494) objectDB connected
                                  zwave2.0	2021-05-16 15:41:19.469	debug	(24494) Objects connected to redis: 127.0.0.1:9001
                                  zwave2.0	2021-05-16 15:41:19.455	debug	(24494) Objects client initialize lua scripts
                                  zwave2.0	2021-05-16 15:41:19.453	debug	(24494) Objects create User PubSub Client
                                  zwave2.0	2021-05-16 15:41:19.451	debug	(24494) Objects create System PubSub Client
                                  zwave2.0	2021-05-16 15:41:19.448	debug	(24494) Objects client ready ... initialize now
                                  zwave2.0	2021-05-16 15:41:19.402	debug	(24494) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                  host.raspberrypi	2021-05-16 15:41:17.450	info	instance system.adapter.zwave2.0 started with pid 24494
                                  host.raspberrypi	2021-05-16 15:41:17.338	info	"system.adapter.zwave2.0" enabled
                                  host.raspberrypi	2021-05-16 15:41:15.669	info	instance system.adapter.zwave2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  host.raspberrypi	2021-05-16 15:41:15.087	info	stopInstance system.adapter.zwave2.0 send kill signal
                                  zwave2.0	2021-05-16 15:41:15.048	info	(22847) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  zwave2.0	2021-05-16 15:41:15.046	info	(22847) terminating
                                  zwave2.0	2021-05-16 15:41:15.044	info	(22847) Shutting down driver...
                                  zwave2.0	2021-05-16 15:41:15.042	info	(22847) Got terminate signal TERMINATE_YOURSELF
                                  host.raspberrypi	2021-05-16 15:41:15.029	info	stopInstance system.adapter.zwave2.0 (force=false, process=true)
                                  host.raspberrypi	2021-05-16 15:41:15.027	info	"system.adapter.zwave2.0" disabled
                                  zwave2.0	2021-05-16 15:40:59.111	info	(22847) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
                                  zwave2.0	2021-05-16 15:40:58.808	debug	(22847) statesDB connected
                                  zwave2.0	2021-05-16 15:40:58.807	debug	(22847) States connected to redis: 127.0.0.1:9000
                                  zwave2.0	2021-05-16 15:40:58.795	debug	(22847) States create User PubSub Client
                                  zwave2.0	2021-05-16 15:40:58.794	debug	(22847) States create System PubSub Client
                                  zwave2.0	2021-05-16 15:40:58.783	debug	(22847) Redis States: Use Redis connection: 127.0.0.1:9000
                                  zwave2.0	2021-05-16 15:40:58.781	debug	(22847) objectDB connected
                                  zwave2.0	2021-05-16 15:40:58.751	debug	(22847) Objects connected to redis: 127.0.0.1:9001
                                  zwave2.0	2021-05-16 15:40:58.737	debug	(22847) Objects client initialize lua scripts
                                  zwave2.0	2021-05-16 15:40:58.736	debug	(22847) Objects create User PubSub Client
                                  zwave2.0	2021-05-16 15:40:58.735	debug	(22847) Objects create System PubSub Client
                                  zwave2.0	2021-05-16 15:40:58.732	debug	(22847) Objects client ready ... initialize now
                                  zwave2.0	2021-05-16 15:40:58.696	debug	(22847) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                  host.raspberrypi	2021-05-16 15:40:56.599	info	instance system.adapter.zwave2.0 started with pid 22847
                                  host.raspberrypi	2021-05-16 15:40:56.462	info	"system.adapter.zwave2.0" enabled
                                  host.raspberrypi	2021-05-16 15:40:50.698	info	instance system.adapter.zwave2.0 terminated with code null ()
                                  host.raspberrypi	2021-05-16 15:40:50.697	warn	instance system.adapter.zwave2.0 terminated due to SIGTERM
                                  host.raspberrypi	2021-05-16 15:40:50.626	info	stopInstance system.adapter.zwave2.0 killing pid 22283
                                  host.raspberrypi	2021-05-16 15:40:49.624	info	stopInstance system.adapter.zwave2.0 send kill signal
                                  host.raspberrypi	2021-05-16 15:40:49.613	info	stopInstance system.adapter.zwave2.0 (force=false, process=true)
                                  host.raspberrypi	2021-05-16 15:40:49.613	info	"system.adapter.zwave2.0" disabled
                                  host.raspberrypi	2021-05-16 15:40:49.345	info	instance system.adapter.zwave2.0 started with pid 22283
                                  host.raspberrypi	2021-05-16 15:40:46.840	info	instance system.adapter.zwave2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  zwave2.0	2021-05-16 15:40:46.228	info	(15581) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  zwave2.0	2021-05-16 15:40:46.226	info	(15581) terminating
                                  zwave2.0	2021-05-16 15:40:46.225	info	(15581) Shutting down driver...
                                  zwave2.0	2021-05-16 15:40:46.223	info	(15581) Got terminate signal TERMINATE_YOURSELF
                                  host.raspberrypi	2021-05-16 15:40:46.223	info	stopInstance system.adapter.zwave2.0 send kill signal
                                  host.raspberrypi	2021-05-16 15:40:46.210	info	stopInstance system.adapter.zwave2.0 (force=false, process=true)
                                    @esmax666
                                    ls -la /dev/ttyAMA0
                                      auch nicht
                                      zwave2.0	2021-05-16 15:44:27.972	info	(7201) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
                                      host.raspberrypi	2021-05-16 15:44:25.611	info	instance system.adapter.zwave2.0 started with pid 7201
                                      host.raspberrypi	2021-05-16 15:44:25.529	info	"system.adapter.zwave2.0" enabled
                                      host.raspberrypi	2021-05-16 15:44:24.965	info	instance system.adapter.zwave2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      zwave2.0	2021-05-16 15:44:24.304	info	(30224) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                      zwave2.0	2021-05-16 15:44:24.302	info	(30224) terminating
                                      zwave2.0	2021-05-16 15:44:24.301	info	(30224) Shutting down driver...
                                      host.raspberrypi	2021-05-16 15:44:24.299	info	stopInstance system.adapter.zwave2.0 send kill signal
                                      zwave2.0	2021-05-16 15:44:24.298	info	(30224) Got terminate signal TERMINATE_YOURSELF
                                      host.raspberrypi	2021-05-16 15:44:24.285	info	stopInstance system.adapter.zwave2.0 (force=false, process=true)
                                      host.raspberrypi	2021-05-16 15:44:24.278	info	"system.adapter.zwave2.0" disabled
                                      zwave2.0	2021-05-16 15:44:11.075	debug	(30224) system.adapter.admin.0: logging true
                                      zwave2.0	2021-05-16 15:44:06.538	debug	(30224) system.adapter.admin.0: logging false
                                      • AlCalzone
                                        AlCalzone Developer @Esmax666 last edited by
                                        @esmax666 Starte den Adapter mal auf der Konsole, da sieht man ggf. mehr:
                                        cd /opt/iobroker/node_modules/iobroker.zwave2
                                        node build/main.js --force --logs
                                        E 2 Replies Last reply Reply Quote 0
                                          @alcalzone said in Probleme mit Serialport bei zwave2:
                                          pi@raspberrypi:~ $ cd /opt/iobroker/node_modules/iobroker.zwave2
                                          pi@raspberrypi:/opt/iobroker/node_modules/iobroker.zwave2 $ node build/main.js --force --logs        2021-05-16 16:43:17.078  - info: zwave2.0 (17697) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
                                          Logging to file:
                                                  /opt/iobroker/node_modules/iobroker.zwave2/build/zwavejs_2021-05-16.log
                                          2021-05-16 16:43:17.235  - error: zwave2.0 (17697) The Z-Wave driver could not be started: Error Resource temporarily unavailable Cannot lock port
                                          ^C2021-05-16 16:43:47.907  - info: zwave2.0 (17697) Shutting down driver...
                                          2021-05-16 16:43:47.916  - info: zwave2.0 (17697) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                          • AlCalzone
                                            @esmax666 sagte in Probleme mit Serialport bei zwave2:
                                            Cannot lock port
                                            Da greift schon irgendwas anderes auf den Port zu.
                                            9833
