    4. Probleme mit Serialport bei zwave2
      Esmax666 @Thomas Braun last edited by
      @thomas-braun said in Test Adapter Z-Wave 2 v1.10.x:
      Nimm den Adapter aus der Adapterliste im Admin.
      Hatte ich schon gemacht.
      sogar sogar instance weg gemacht und neu gemacht
      leider geht es nicht mehr
        Thomas Braun Most Active @Esmax666 last edited by
        @esmax666 sagte in Test Adapter Z-Wave 2 v1.10.x:
        Stimmt dann wohl.
        Leider kann man aus deiner 'Fehlerbeschreibung' nichts herauslesen.
          @thomas-braun was kann ich sonst noch als info geben ?
          sonst habe ich noch 2 warn und 1 error
          info.0	2021-05-16 13:07:15.628	warn	(2791) State "info.0.uuid" has no existing object, this might lead to an error in future versions
          host.raspberrypi	2021-05-16 13:00:08.345	info	instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
          host.raspberrypi	2021-05-16 13:00:00.042	info	instance system.adapter.ical.0 started with pid 5361
          zwave2.0	2021-05-16 12:59:53.829	info	(5346) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
          host.raspberrypi	2021-05-16 12:59:51.487	info	instance system.adapter.zwave2.0 started with pid 5346
          host.raspberrypi	2021-05-16 12:59:21.429	info	Restart adapter system.adapter.zwave2.0 because enabled
          host.raspberrypi	2021-05-16 12:59:21.428	info	instance system.adapter.zwave2.0 terminated with code NaN ()
          host.raspberrypi	2021-05-16 12:59:21.427	warn	instance system.adapter.zwave2.0 terminated due to SIGABRT
          host.raspberrypi	2021-05-16 12:59:21.422	error	Caught by controller[0]: FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
          zwave2.0	2021-05-16 12:45:57.264	info	(5176) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
          host.raspberrypi	2021-05-16 12:45:55.024	info	instance system.adapter.zwave2.0 started with pid 5176
          host.raspberrypi	2021-05-16 12:45:24.958	info	Restart adapter system.adapter.zwave2.0 because enabled
          host.raspberrypi	2021-05-16 12:45:24.957	info	instance system.adapter.zwave2.0 terminated with code NaN ()
          host.raspberrypi	2021-05-16 12:45:24.956	warn	instance system.adapter.zwave2.0 terminated due to SIGABRT
          host.raspberrypi	2021-05-16 12:45:24.950	error	Caught by controller[0]: FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
          info.0	2021-05-16 12:37:15.604	warn	(2791) State "info.0.uuid" has no existing object, this might lead to an error in future versions
          zwave2.0	2021-05-16 12:32:01.208	info	(5010) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
          host.raspberrypi	2021-05-16 12:31:58.911	info	instance system.adapter.zwave2.0 started with pid 5010
          host.raspberrypi	2021-05-16 12:31:28.859	info	Restart adapter system.adapter.zwave2.0 because enabled
          host.raspberrypi	2021-05-16 12:31:28.859	info	instance system.adapter.zwave2.0 terminated with code NaN ()
          host.raspberrypi	2021-05-16 12:31:28.858	warn	instance system.adapter.zwave2.0 terminated due to SIGABRT
          host.raspberrypi	2021-05-16 12:31:28.857	error	Caught by controller[0]: FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
            @esmax666
            Speicher dicht?
            free -ht
            anschauen.
                @esmax666
                Bitte keine Bilderchen posten, KonsolenTEXT in CodeTags eingebettet hier rein.
                • AlCalzone
                  @Esmax666 die Datei brauchst du inzwischen nicht mehr manuell bearbeiten. Auf Pi 4 sind das die Schritte, die ausreichen: Konsole auf,
                  sudo raspi-config
                  • 3 Interface Options
                  • P6 Serial Port
                  • "Would you like a login shell to be accessible over serial?" => NO
                  • "Would you like the serial port hardware to be enabled?" => YES
                  Danach sollte der Adapter funktionieren, wenn du /dev/serial0 einträgst - ist leider nicht in der Liste zu finden.
                  Thomas Braun E 3 Replies Last reply Reply Quote 0
                    Thomas Braun Most Active @AlCalzone last edited by
                    @alcalzone
                    An den Hardware-Part hatte ich noch gar nicht gedacht, bzw. vorausgesetzt das der natürlich auch aktiviert wurde.
                    Wobei dann /dev/serial0 'nur' ein symlink auf das device node /dev/ttyAMA0 sein dürfte.
                      Esmax666 @AlCalzone last edited by
                      @alcalzone
                      ok ist jetzt aktviert
                      und auch neu gestartet
                      aber immer Driver could not be started
                      zwave2.0	2021-05-16 15:32:12.067	error	(17665) The Z-Wave driver could not be started: Error: No such file or directory, cannot open /dev/serial0
                      zwave2.0	2021-05-16 15:32:11.921	info	(17665) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
                      host.raspberrypi	2021-05-16 15:32:09.511	info	instance system.adapter.zwave2.0 started with pid 17665
                      host.raspberrypi	2021-05-16 15:32:07.043	info	instance system.adapter.zwave2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      zwave2.0	2021-05-16 15:32:06.372	info	(5742) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      zwave2.0	2021-05-16 15:32:06.371	info	(5742) terminating
                      zwave2.0	2021-05-16 15:32:06.369	info	(5742) Shutting down driver...
                      zwave2.0	2021-05-16 15:32:06.367	info	(5742) Got terminate signal TERMINATE_YOURSELF
                      host.raspberrypi	2021-05-16 15:32:06.367	info	stopInstance system.adapter.zwave2.0 send kill signal
                      host.raspberrypi	2021-05-16 15:32:06.359	info	stopInstance system.adapter.zwave2.0 (force=false, process=true)
                      host.raspberrypi	2021-05-16 15:30:27.733	info	instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                      ical.0	2021-05-16 15:30:27.198	info	(8661) Terminated (NO_ERROR): Without reason
                        Thomas Braun Most Active @Esmax666 last edited by Thomas Braun
                        @esmax666
                        Und wenn du das device direkt anrufst? Unter /dev/ttyAMA0
                        Gibt es das Gerät?
                        ls -la /dev/ttyAMA0
                        sudo -u iobroker groups
                          Esmax666 @Thomas Braun last edited by Esmax666
                          @thomas-braun said in Probleme mit Serialport bei zwave2:
                          /dev/ttyAMA0
                          dann bekomme ich wie davor
                          zwave2.0	2021-05-16 15:39:28.776	info	(15581) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
                          host.raspberrypi	2021-05-16 15:39:26.309	info	instance system.adapter.zwave2.0 started with pid 15581
                          host.raspberrypi	2021-05-16 15:39:23.743	info	instance system.adapter.zwave2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          zwave2.0	2021-05-16 15:39:23.146	info	(17665) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          zwave2.0	2021-05-16 15:39:23.145	info	(17665) terminating
                          zwave2.0	2021-05-16 15:39:23.143	info	(17665) Shutting down driver...
                          host.raspberrypi	2021-05-16 15:39:23.141	info	stopInstance system.adapter.zwave2.0 send kill signal
                          zwave2.0	2021-05-16 15:39:23.141	info	(17665) Got terminate signal TERMINATE_YOURSELF
                          host.raspberrypi	2021-05-16 15:39:23.126	info	stopInstance system.adapter.zwave2.0 (force=false, process=true)
                          und als "debug level" bekomme ich das :
                          zwave2.0	2021-05-16 15:41:19.769	info	(24494) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
                          zwave2.0	2021-05-16 15:41:19.518	debug	(24494) statesDB connected
                          zwave2.0	2021-05-16 15:41:19.517	debug	(24494) States connected to redis: 127.0.0.1:9000
                          zwave2.0	2021-05-16 15:41:19.510	debug	(24494) States create User PubSub Client
                          zwave2.0	2021-05-16 15:41:19.508	debug	(24494) States create System PubSub Client
                          zwave2.0	2021-05-16 15:41:19.501	debug	(24494) Redis States: Use Redis connection: 127.0.0.1:9000
                          zwave2.0	2021-05-16 15:41:19.498	debug	(24494) objectDB connected
                          zwave2.0	2021-05-16 15:41:19.469	debug	(24494) Objects connected to redis: 127.0.0.1:9001
                          zwave2.0	2021-05-16 15:41:19.455	debug	(24494) Objects client initialize lua scripts
                          zwave2.0	2021-05-16 15:41:19.453	debug	(24494) Objects create User PubSub Client
                          zwave2.0	2021-05-16 15:41:19.451	debug	(24494) Objects create System PubSub Client
                          zwave2.0	2021-05-16 15:41:19.448	debug	(24494) Objects client ready ... initialize now
                          zwave2.0	2021-05-16 15:41:19.402	debug	(24494) Redis Objects: Use Redis connection: 127.0.0.1:9001
                          host.raspberrypi	2021-05-16 15:41:17.450	info	instance system.adapter.zwave2.0 started with pid 24494
                          host.raspberrypi	2021-05-16 15:41:17.338	info	"system.adapter.zwave2.0" enabled
                          host.raspberrypi	2021-05-16 15:41:15.669	info	instance system.adapter.zwave2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          host.raspberrypi	2021-05-16 15:41:15.087	info	stopInstance system.adapter.zwave2.0 send kill signal
                          zwave2.0	2021-05-16 15:41:15.048	info	(22847) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          zwave2.0	2021-05-16 15:41:15.046	info	(22847) terminating
                          zwave2.0	2021-05-16 15:41:15.044	info	(22847) Shutting down driver...
                          zwave2.0	2021-05-16 15:41:15.042	info	(22847) Got terminate signal TERMINATE_YOURSELF
                          host.raspberrypi	2021-05-16 15:41:15.029	info	stopInstance system.adapter.zwave2.0 (force=false, process=true)
                          host.raspberrypi	2021-05-16 15:41:15.027	info	"system.adapter.zwave2.0" disabled
                          zwave2.0	2021-05-16 15:40:59.111	info	(22847) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
                          zwave2.0	2021-05-16 15:40:58.808	debug	(22847) statesDB connected
                          zwave2.0	2021-05-16 15:40:58.807	debug	(22847) States connected to redis: 127.0.0.1:9000
                          zwave2.0	2021-05-16 15:40:58.795	debug	(22847) States create User PubSub Client
                          zwave2.0	2021-05-16 15:40:58.794	debug	(22847) States create System PubSub Client
                          zwave2.0	2021-05-16 15:40:58.783	debug	(22847) Redis States: Use Redis connection: 127.0.0.1:9000
                          zwave2.0	2021-05-16 15:40:58.781	debug	(22847) objectDB connected
                          zwave2.0	2021-05-16 15:40:58.751	debug	(22847) Objects connected to redis: 127.0.0.1:9001
                          zwave2.0	2021-05-16 15:40:58.737	debug	(22847) Objects client initialize lua scripts
                          zwave2.0	2021-05-16 15:40:58.736	debug	(22847) Objects create User PubSub Client
                          zwave2.0	2021-05-16 15:40:58.735	debug	(22847) Objects create System PubSub Client
                          zwave2.0	2021-05-16 15:40:58.732	debug	(22847) Objects client ready ... initialize now
                          zwave2.0	2021-05-16 15:40:58.696	debug	(22847) Redis Objects: Use Redis connection: 127.0.0.1:9001
                          host.raspberrypi	2021-05-16 15:40:56.599	info	instance system.adapter.zwave2.0 started with pid 22847
                          host.raspberrypi	2021-05-16 15:40:56.462	info	"system.adapter.zwave2.0" enabled
                          host.raspberrypi	2021-05-16 15:40:50.698	info	instance system.adapter.zwave2.0 terminated with code null ()
                          host.raspberrypi	2021-05-16 15:40:50.697	warn	instance system.adapter.zwave2.0 terminated due to SIGTERM
                          host.raspberrypi	2021-05-16 15:40:50.626	info	stopInstance system.adapter.zwave2.0 killing pid 22283
                          host.raspberrypi	2021-05-16 15:40:49.624	info	stopInstance system.adapter.zwave2.0 send kill signal
                          host.raspberrypi	2021-05-16 15:40:49.613	info	stopInstance system.adapter.zwave2.0 (force=false, process=true)
                          host.raspberrypi	2021-05-16 15:40:49.613	info	"system.adapter.zwave2.0" disabled
                          host.raspberrypi	2021-05-16 15:40:49.345	info	instance system.adapter.zwave2.0 started with pid 22283
                          host.raspberrypi	2021-05-16 15:40:46.840	info	instance system.adapter.zwave2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          zwave2.0	2021-05-16 15:40:46.228	info	(15581) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          zwave2.0	2021-05-16 15:40:46.226	info	(15581) terminating
                          zwave2.0	2021-05-16 15:40:46.225	info	(15581) Shutting down driver...
                          zwave2.0	2021-05-16 15:40:46.223	info	(15581) Got terminate signal TERMINATE_YOURSELF
                          host.raspberrypi	2021-05-16 15:40:46.223	info	stopInstance system.adapter.zwave2.0 send kill signal
                          host.raspberrypi	2021-05-16 15:40:46.210	info	stopInstance system.adapter.zwave2.0 (force=false, process=true)
                            @esmax666
                            ls -la /dev/ttyAMA0
                              auch nicht
                              zwave2.0	2021-05-16 15:44:27.972	info	(7201) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
                              host.raspberrypi	2021-05-16 15:44:25.611	info	instance system.adapter.zwave2.0 started with pid 7201
                              host.raspberrypi	2021-05-16 15:44:25.529	info	"system.adapter.zwave2.0" enabled
                              host.raspberrypi	2021-05-16 15:44:24.965	info	instance system.adapter.zwave2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              zwave2.0	2021-05-16 15:44:24.304	info	(30224) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              zwave2.0	2021-05-16 15:44:24.302	info	(30224) terminating
                              zwave2.0	2021-05-16 15:44:24.301	info	(30224) Shutting down driver...
                              host.raspberrypi	2021-05-16 15:44:24.299	info	stopInstance system.adapter.zwave2.0 send kill signal
                              zwave2.0	2021-05-16 15:44:24.298	info	(30224) Got terminate signal TERMINATE_YOURSELF
                              host.raspberrypi	2021-05-16 15:44:24.285	info	stopInstance system.adapter.zwave2.0 (force=false, process=true)
                              host.raspberrypi	2021-05-16 15:44:24.278	info	"system.adapter.zwave2.0" disabled
                              zwave2.0	2021-05-16 15:44:11.075	debug	(30224) system.adapter.admin.0: logging true
                              zwave2.0	2021-05-16 15:44:06.538	debug	(30224) system.adapter.admin.0: logging false
                              • AlCalzone
                                AlCalzone Developer @Esmax666 last edited by
                                @esmax666 Starte den Adapter mal auf der Konsole, da sieht man ggf. mehr:
                                cd /opt/iobroker/node_modules/iobroker.zwave2
                                node build/main.js --force --logs
                                E 2 Replies Last reply Reply Quote 0
                                  @alcalzone said in Probleme mit Serialport bei zwave2:
                                  pi@raspberrypi:~ $ cd /opt/iobroker/node_modules/iobroker.zwave2
                                  pi@raspberrypi:/opt/iobroker/node_modules/iobroker.zwave2 $ node build/main.js --force --logs        2021-05-16 16:43:17.078  - info: zwave2.0 (17697) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
                                  Logging to file:
                                          /opt/iobroker/node_modules/iobroker.zwave2/build/zwavejs_2021-05-16.log
                                  2021-05-16 16:43:17.235  - error: zwave2.0 (17697) The Z-Wave driver could not be started: Error Resource temporarily unavailable Cannot lock port
                                  ^C2021-05-16 16:43:47.907  - info: zwave2.0 (17697) Shutting down driver...
                                  2021-05-16 16:43:47.916  - info: zwave2.0 (17697) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                  • AlCalzone
                                    @esmax666 sagte in Probleme mit Serialport bei zwave2:
                                    Cannot lock port
                                    Da greift schon irgendwas anderes auf den Port zu.
                                      @Esmax666
                                      sudo lsof /dev/ttyAMA0
                                        pi@raspberrypi:/opt/iobroker/node_modules/iobroker.zwave2 $ sudo lsof /dev/ttyAMA0
                                        COMMAND     PID     USER   FD   TYPE DEVICE SIZE/OFF NODE NAME
                                        hciattach   596     root    3u   CHR 204,64      0t0  135 /dev/ttyAMA0
                                        node      25167 iobroker   27uW  CHR 204,64      0t0  135 /dev/ttyAMA0
                                        dann
                                        pi@raspberrypi:/opt/iobroker/node_modules/iobroker.zwave2 $ cd /opt/iobroker/node_modules/iobroker.zwave2
                                        2021-05-16 17:01:01.719  - info: zwave2.0 (5111) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16
                                        Logging to file:
                                        2021-05-16 17:01:01.877  - error: zwave2.0 (5111) The Z-Wave driver could not be started: Error Resource temporarily unavailable Cannot lock port
                                        ^C2021-05-16 17:01:47.959  - info: zwave2.0 (5111) Shutting down driver...
                                        2021-05-16 17:01:47.968  - info: zwave2.0 (5111) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                        @AlCalzone
                                        wie soll ich port freischalten ? die installation ist neu
                                          Da greift bluetooth schon auf das Gerät zu. Merkwürden...
                                          Ich bin jetzt nicht ganz sicher ob /dev/tttyAMA0 nicht doch das falsche Device ist. Oder da die Zuordnung falsch ist. Zieh den stick mal raus, starte neu ohne den Stick und dann schau nochmal nach
                                          dmesg -T
                                          kurz nachdem du den stick eingesteckt hast.
                                            @thomas-braun was soll ich dann machen ?
                                            1.2k
                                            9843
