Probleme mit Serialport bei zwave2
@esmax666
Und wenn du das device direkt anrufst? Unter /dev/ttyAMA0Gibt es das Gerät?
ls -la /dev/ttyAMA0 sudo -u iobroker groups -
@thomas-braun said in Probleme mit Serialport bei zwave2:
/dev/ttyAMA0
dann bekomme ich wie davor
zwave2.0 2021-05-16 15:39:28.776 info (15581) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16 host.raspberrypi 2021-05-16 15:39:26.309 info instance system.adapter.zwave2.0 started with pid 15581 host.raspberrypi 2021-05-16 15:39:23.743 info instance system.adapter.zwave2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) zwave2.0 2021-05-16 15:39:23.146 info (17665) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason zwave2.0 2021-05-16 15:39:23.145 info (17665) terminating zwave2.0 2021-05-16 15:39:23.143 info (17665) Shutting down driver... host.raspberrypi 2021-05-16 15:39:23.141 info stopInstance system.adapter.zwave2.0 send kill signal zwave2.0 2021-05-16 15:39:23.141 info (17665) Got terminate signal TERMINATE_YOURSELF host.raspberrypi 2021-05-16 15:39:23.126 info stopInstance system.adapter.zwave2.0 (force=false, process=true)und als "debug level" bekomme ich das :
zwave2.0 2021-05-16 15:41:19.769 info (24494) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16 zwave2.0 2021-05-16 15:41:19.518 debug (24494) statesDB connected zwave2.0 2021-05-16 15:41:19.517 debug (24494) States connected to redis: 127.0.0.1:9000 zwave2.0 2021-05-16 15:41:19.510 debug (24494) States create User PubSub Client zwave2.0 2021-05-16 15:41:19.508 debug (24494) States create System PubSub Client zwave2.0 2021-05-16 15:41:19.501 debug (24494) Redis States: Use Redis connection: 127.0.0.1:9000 zwave2.0 2021-05-16 15:41:19.498 debug (24494) objectDB connected zwave2.0 2021-05-16 15:41:19.469 debug (24494) Objects connected to redis: 127.0.0.1:9001 zwave2.0 2021-05-16 15:41:19.455 debug (24494) Objects client initialize lua scripts zwave2.0 2021-05-16 15:41:19.453 debug (24494) Objects create User PubSub Client zwave2.0 2021-05-16 15:41:19.451 debug (24494) Objects create System PubSub Client zwave2.0 2021-05-16 15:41:19.448 debug (24494) Objects client ready ... initialize now zwave2.0 2021-05-16 15:41:19.402 debug (24494) Redis Objects: Use Redis connection: 127.0.0.1:9001 host.raspberrypi 2021-05-16 15:41:17.450 info instance system.adapter.zwave2.0 started with pid 24494 host.raspberrypi 2021-05-16 15:41:17.338 info "system.adapter.zwave2.0" enabled host.raspberrypi 2021-05-16 15:41:15.669 info instance system.adapter.zwave2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) host.raspberrypi 2021-05-16 15:41:15.087 info stopInstance system.adapter.zwave2.0 send kill signal zwave2.0 2021-05-16 15:41:15.048 info (22847) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason zwave2.0 2021-05-16 15:41:15.046 info (22847) terminating zwave2.0 2021-05-16 15:41:15.044 info (22847) Shutting down driver... zwave2.0 2021-05-16 15:41:15.042 info (22847) Got terminate signal TERMINATE_YOURSELF host.raspberrypi 2021-05-16 15:41:15.029 info stopInstance system.adapter.zwave2.0 (force=false, process=true) host.raspberrypi 2021-05-16 15:41:15.027 info "system.adapter.zwave2.0" disabled zwave2.0 2021-05-16 15:40:59.111 info (22847) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16 zwave2.0 2021-05-16 15:40:58.808 debug (22847) statesDB connected zwave2.0 2021-05-16 15:40:58.807 debug (22847) States connected to redis: 127.0.0.1:9000 zwave2.0 2021-05-16 15:40:58.795 debug (22847) States create User PubSub Client zwave2.0 2021-05-16 15:40:58.794 debug (22847) States create System PubSub Client zwave2.0 2021-05-16 15:40:58.783 debug (22847) Redis States: Use Redis connection: 127.0.0.1:9000 zwave2.0 2021-05-16 15:40:58.781 debug (22847) objectDB connected zwave2.0 2021-05-16 15:40:58.751 debug (22847) Objects connected to redis: 127.0.0.1:9001 zwave2.0 2021-05-16 15:40:58.737 debug (22847) Objects client initialize lua scripts zwave2.0 2021-05-16 15:40:58.736 debug (22847) Objects create User PubSub Client zwave2.0 2021-05-16 15:40:58.735 debug (22847) Objects create System PubSub Client zwave2.0 2021-05-16 15:40:58.732 debug (22847) Objects client ready ... initialize now zwave2.0 2021-05-16 15:40:58.696 debug (22847) Redis Objects: Use Redis connection: 127.0.0.1:9001 host.raspberrypi 2021-05-16 15:40:56.599 info instance system.adapter.zwave2.0 started with pid 22847 host.raspberrypi 2021-05-16 15:40:56.462 info "system.adapter.zwave2.0" enabled host.raspberrypi 2021-05-16 15:40:50.698 info instance system.adapter.zwave2.0 terminated with code null () host.raspberrypi 2021-05-16 15:40:50.697 warn instance system.adapter.zwave2.0 terminated due to SIGTERM host.raspberrypi 2021-05-16 15:40:50.626 info stopInstance system.adapter.zwave2.0 killing pid 22283 host.raspberrypi 2021-05-16 15:40:49.624 info stopInstance system.adapter.zwave2.0 send kill signal host.raspberrypi 2021-05-16 15:40:49.613 info stopInstance system.adapter.zwave2.0 (force=false, process=true) host.raspberrypi 2021-05-16 15:40:49.613 info "system.adapter.zwave2.0" disabled host.raspberrypi 2021-05-16 15:40:49.345 info instance system.adapter.zwave2.0 started with pid 22283 host.raspberrypi 2021-05-16 15:40:46.840 info instance system.adapter.zwave2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) zwave2.0 2021-05-16 15:40:46.228 info (15581) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason zwave2.0 2021-05-16 15:40:46.226 info (15581) terminating zwave2.0 2021-05-16 15:40:46.225 info (15581) Shutting down driver... zwave2.0 2021-05-16 15:40:46.223 info (15581) Got terminate signal TERMINATE_YOURSELF host.raspberrypi 2021-05-16 15:40:46.223 info stopInstance system.adapter.zwave2.0 send kill signal host.raspberrypi 2021-05-16 15:40:46.210 info stopInstance system.adapter.zwave2.0 (force=false, process=true) zwave2.0 2021-05-16 15:39:28.776 info (15581) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16 -
auch nicht
zwave2.0 2021-05-16 15:44:27.972 info (7201) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16 host.raspberrypi 2021-05-16 15:44:25.611 info instance system.adapter.zwave2.0 started with pid 7201 host.raspberrypi 2021-05-16 15:44:25.529 info "system.adapter.zwave2.0" enabled host.raspberrypi 2021-05-16 15:44:24.965 info instance system.adapter.zwave2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) zwave2.0 2021-05-16 15:44:24.304 info (30224) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason zwave2.0 2021-05-16 15:44:24.302 info (30224) terminating zwave2.0 2021-05-16 15:44:24.301 info (30224) Shutting down driver... host.raspberrypi 2021-05-16 15:44:24.299 info stopInstance system.adapter.zwave2.0 send kill signal zwave2.0 2021-05-16 15:44:24.298 info (30224) Got terminate signal TERMINATE_YOURSELF host.raspberrypi 2021-05-16 15:44:24.285 info stopInstance system.adapter.zwave2.0 (force=false, process=true) host.raspberrypi 2021-05-16 15:44:24.278 info "system.adapter.zwave2.0" disabled zwave2.0 2021-05-16 15:44:11.075 debug (30224) system.adapter.admin.0: logging true zwave2.0 2021-05-16 15:44:06.538 debug (30224) system.adapter.admin.0: logging false -
@esmax666 Starte den Adapter mal auf der Konsole, da sieht man ggf. mehr:
cd /opt/iobroker/node_modules/iobroker.zwave2 node build/main.js --force --logs -
@alcalzone said in Probleme mit Serialport bei zwave2:
node build/main.js --force --logspi@raspberrypi:~ $ cd /opt/iobroker/node_modules/iobroker.zwave2 pi@raspberrypi:/opt/iobroker/node_modules/iobroker.zwave2 $ node build/main.js --force --logs 2021-05-16 16:43:17.078 - info: zwave2.0 (17697) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16 Logging to file: /opt/iobroker/node_modules/iobroker.zwave2/build/zwavejs_2021-05-16.log 2021-05-16 16:43:17.235 - error: zwave2.0 (17697) The Z-Wave driver could not be started: Error Resource temporarily unavailable Cannot lock port ^C2021-05-16 16:43:47.907 - info: zwave2.0 (17697) Shutting down driver... 2021-05-16 16:43:47.916 - info: zwave2.0 (17697) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason pi@raspberrypi:/opt/iobroker/node_modules/iobroker.zwave2 $ -
@esmax666 sagte in Probleme mit Serialport bei zwave2:
Cannot lock port
Da greift schon irgendwas anderes auf den Port zu.
sudo lsof /dev/ttyAMA0 -
pi@raspberrypi:/opt/iobroker/node_modules/iobroker.zwave2 $ sudo lsof /dev/ttyAMA0 COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME hciattach 596 root 3u CHR 204,64 0t0 135 /dev/ttyAMA0 node 25167 iobroker 27uW CHR 204,64 0t0 135 /dev/ttyAMA0dann
pi@raspberrypi:/opt/iobroker/node_modules/iobroker.zwave2 $ cd /opt/iobroker/node_modules/iobroker.zwave2 pi@raspberrypi:/opt/iobroker/node_modules/iobroker.zwave2 $ node build/main.js --force --logs 2021-05-16 17:01:01.719 - info: zwave2.0 (5111) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16 Logging to file: /opt/iobroker/node_modules/iobroker.zwave2/build/zwavejs_2021-05-16.log 2021-05-16 17:01:01.877 - error: zwave2.0 (5111) The Z-Wave driver could not be started: Error Resource temporarily unavailable Cannot lock port ^C2021-05-16 17:01:47.959 - info: zwave2.0 (5111) Shutting down driver... 2021-05-16 17:01:47.968 - info: zwave2.0 (5111) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason@AlCalzone
wie soll ich port freischalten ? die installation ist neu -
Da greift bluetooth schon auf das Gerät zu. Merkwürden...
Ich bin jetzt nicht ganz sicher ob /dev/tttyAMA0 nicht doch das falsche Device ist. Oder da die Zuordnung falsch ist. Zieh den stick mal raus, starte neu ohne den Stick und dann schau nochmal nachdmesg -Tkurz nachdem du den stick eingesteckt hast.
@thomas-braun was soll ich dann machen ?
@esmax666 Und deaktiviere den zwave2-Adapter vorerst mal für die ganze Prozedur.
ohne stick und zwave2 pausiert
pi@raspberrypi:~ $ dmesg -T [So Mai 16 17:10:10 2021] Booting Linux on physical CPU 0x0 [So Mai 16 17:10:10 2021] Linux version 5.10.17-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1414 SMP Fri Apr 30 13:20:47 BST 2021 [So Mai 16 17:10:10 2021] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d [So Mai 16 17:10:10 2021] CPU: div instructions available: patching division code [So Mai 16 17:10:10 2021] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache [So Mai 16 17:10:10 2021] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.4 [So Mai 16 17:10:10 2021] Memory policy: Data cache writealloc [So Mai 16 17:10:10 2021] Reserved memory: created CMA memory pool at 0x000000001ec00000, size 256 MiB [So Mai 16 17:10:10 2021] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool [So Mai 16 17:10:10 2021] Zone ranges: [So Mai 16 17:10:10 2021] DMA [mem 0x0000000000000000-0x000000002fffffff] [So Mai 16 17:10:10 2021] Normal empty [So Mai 16 17:10:10 2021] HighMem [mem 0x0000000030000000-0x00000001ffffffff] [So Mai 16 17:10:10 2021] Movable zone start for each node [So Mai 16 17:10:10 2021] Early memory node ranges [So Mai 16 17:10:10 2021] node 0: [mem 0x0000000000000000-0x000000003b2fffff] [So Mai 16 17:10:10 2021] node 0: [mem 0x0000000040000000-0x00000000fbffffff] [So Mai 16 17:10:10 2021] node 0: [mem 0x0000000100000000-0x00000001ffffffff] [So Mai 16 17:10:10 2021] Initmem setup node 0 [mem 0x0000000000000000-0x00000001ffffffff] [So Mai 16 17:10:10 2021] On node 0 totalpages: 2061056 [So Mai 16 17:10:10 2021] DMA zone: 2304 pages used for memmap [So Mai 16 17:10:10 2021] DMA zone: 0 pages reserved [So Mai 16 17:10:10 2021] DMA zone: 196608 pages, LIFO batch:63 [So Mai 16 17:10:10 2021] HighMem zone: 1864448 pages, LIFO batch:63 [So Mai 16 17:10:10 2021] percpu: Embedded 20 pages/cpu s50700 r8192 d23028 u81920 [So Mai 16 17:10:10 2021] pcpu-alloc: s50700 r8192 d23028 u81920 alloc=20*4096 [So Mai 16 17:10:10 2021] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [So Mai 16 17:10:10 2021] Built 1 zonelists, mobility grouping on. Total pages: 2058752 [So Mai 16 17:10:10 2021] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 smsc95xx.macaddr=E4:5F:01:1B:22:9D vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000 console=tty1 root=PARTUUID=c7534f19-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles [So Mai 16 17:10:10 2021] Kernel parameter elevator= does not have any effect anymore. Please use sysfs to set IO scheduler for individual devices. [So Mai 16 17:10:10 2021] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear) [So Mai 16 17:10:10 2021] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear) [So Mai 16 17:10:10 2021] mem auto-init: stack:off, heap alloc:off, heap free:off [So Mai 16 17:10:10 2021] software IO TLB: mapped [mem 0x0000000014c00000-0x0000000018c00000] (64MB) [So Mai 16 17:10:10 2021] Memory: 7799068K/8244224K available (10240K kernel code, 1358K rwdata, 3160K rodata, 2048K init, 890K bss, 183012K reserved, 262144K cma-reserved, 7457792K highmem) [So Mai 16 17:10:10 2021] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [So Mai 16 17:10:10 2021] ftrace: allocating 33942 entries in 67 pages [So Mai 16 17:10:10 2021] ftrace: allocated 67 pages with 3 groups [So Mai 16 17:10:10 2021] rcu: Hierarchical RCU implementation. [So Mai 16 17:10:10 2021] Rude variant of Tasks RCU enabled. [So Mai 16 17:10:10 2021] Tracing variant of Tasks RCU enabled. [So Mai 16 17:10:10 2021] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies. [So Mai 16 17:10:10 2021] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 [So Mai 16 17:10:10 2021] GIC: Using split EOI/Deactivate mode [So Mai 16 17:10:10 2021] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=0 [So Mai 16 17:10:10 2021] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns [So Mai 16 17:10:10 2021] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns [So Mai 16 17:10:10 2021] bcm2835: system timer (irq = 25) [So Mai 16 17:10:10 2021] arch_timer: cp15 timer(s) running at 54.00MHz (phys). [So Mai 16 17:10:10 2021] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns [So Mai 16 17:10:10 2021] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns [So Mai 16 17:10:10 2021] Switching to timer-based delay loop, resolution 18ns [So Mai 16 17:10:10 2021] Console: colour dummy device 80x30 [So Mai 16 17:10:10 2021] printk: console [tty1] enabled [So Mai 16 17:10:10 2021] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000) [So Mai 16 17:10:10 2021] pid_max: default: 32768 minimum: 301 [So Mai 16 17:10:10 2021] LSM: Security Framework initializing [So Mai 16 17:10:10 2021] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear) [So Mai 16 17:10:10 2021] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear) [So Mai 16 17:10:10 2021] Disabling memory control group subsystem [So Mai 16 17:10:10 2021] CPU: Testing write buffer coherency: ok [So Mai 16 17:10:10 2021] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [So Mai 16 17:10:10 2021] Setting up static identity map for 0x200000 - 0x20003c [So Mai 16 17:10:10 2021] rcu: Hierarchical SRCU implementation. [So Mai 16 17:10:10 2021] smp: Bringing up secondary CPUs ... [So Mai 16 17:10:10 2021] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 [So Mai 16 17:10:10 2021] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002 [So Mai 16 17:10:10 2021] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003 [So Mai 16 17:10:10 2021] smp: Brought up 1 node, 4 CPUs [So Mai 16 17:10:10 2021] SMP: Total of 4 processors activated (432.00 BogoMIPS). [So Mai 16 17:10:10 2021] CPU: All CPU(s) started in HYP mode. [So Mai 16 17:10:10 2021] CPU: Virtualization extensions available. [So Mai 16 17:10:10 2021] devtmpfs: initialized [So Mai 16 17:10:10 2021] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0 [So Mai 16 17:10:10 2021] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [So Mai 16 17:10:10 2021] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) [So Mai 16 17:10:10 2021] pinctrl core: initialized pinctrl subsystem [So Mai 16 17:10:10 2021] NET: Registered protocol family 16 [So Mai 16 17:10:10 2021] DMA: preallocated 1024 KiB pool for atomic coherent allocations [So Mai 16 17:10:10 2021] audit: initializing netlink subsys (disabled) [So Mai 16 17:10:10 2021] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1 [So Mai 16 17:10:10 2021] thermal_sys: Registered thermal governor 'step_wise' [So Mai 16 17:10:10 2021] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [So Mai 16 17:10:10 2021] hw-breakpoint: maximum watchpoint size is 8 bytes. [So Mai 16 17:10:10 2021] Serial: AMBA PL011 UART driver [So Mai 16 17:10:10 2021] bcm2835-mbox fe00b880.mailbox: mailbox enabled [So Mai 16 17:10:10 2021] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-04-30T13:45:52, variant start [So Mai 16 17:10:10 2021] raspberrypi-firmware soc:firmware: Firmware hash is d7f29d96450abfc77cd6cf011af1faf1e03e5e56 [So Mai 16 17:10:10 2021] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1 [So Mai 16 17:10:10 2021] vgaarb: loaded [So Mai 16 17:10:10 2021] SCSI subsystem initialized [So Mai 16 17:10:10 2021] usbcore: registered new interface driver usbfs [So Mai 16 17:10:10 2021] usbcore: registered new interface driver hub [So Mai 16 17:10:10 2021] usbcore: registered new device driver usb [So Mai 16 17:10:10 2021] usb_phy_generic phy: supply vcc not found, using dummy regulator [So Mai 16 17:10:10 2021] clocksource: Switched to clocksource arch_sys_counter [So Mai 16 17:10:11 2021] VFS: Disk quotas dquot_6.6.0 [So Mai 16 17:10:11 2021] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [So Mai 16 17:10:11 2021] FS-Cache: Loaded [So Mai 16 17:10:11 2021] CacheFiles: Loaded [So Mai 16 17:10:11 2021] NET: Registered protocol family 2 [So Mai 16 17:10:11 2021] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear) [So Mai 16 17:10:11 2021] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear) [So Mai 16 17:10:11 2021] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear) [So Mai 16 17:10:11 2021] TCP: Hash tables configured (established 8192 bind 8192) [So Mai 16 17:10:11 2021] UDP hash table entries: 512 (order: 2, 16384 bytes, linear) [So Mai 16 17:10:11 2021] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear) [So Mai 16 17:10:11 2021] NET: Registered protocol family 1 [So Mai 16 17:10:11 2021] RPC: Registered named UNIX socket transport module. [So Mai 16 17:10:11 2021] RPC: Registered udp transport module. [So Mai 16 17:10:11 2021] RPC: Registered tcp transport module. [So Mai 16 17:10:11 2021] RPC: Registered tcp NFSv4.1 backchannel transport module. [So Mai 16 17:10:11 2021] PCI: CLS 0 bytes, default 64 [So Mai 16 17:10:11 2021] Initialise system trusted keyrings [So Mai 16 17:10:11 2021] workingset: timestamp_bits=14 max_order=21 bucket_order=7 [So Mai 16 17:10:11 2021] zbud: loaded [So Mai 16 17:10:11 2021] FS-Cache: Netfs 'nfs' registered for caching [So Mai 16 17:10:11 2021] NFS: Registering the id_resolver key type [So Mai 16 17:10:11 2021] Key type id_resolver registered [So Mai 16 17:10:11 2021] Key type id_legacy registered [So Mai 16 17:10:11 2021] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [So Mai 16 17:10:11 2021] Key type asymmetric registered [So Mai 16 17:10:11 2021] Asymmetric key parser 'x509' registered [So Mai 16 17:10:11 2021] bounce: pool size: 64 pages [So Mai 16 17:10:11 2021] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249) [So Mai 16 17:10:11 2021] io scheduler mq-deadline registered [So Mai 16 17:10:11 2021] io scheduler kyber registered [So Mai 16 17:10:11 2021] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges: [So Mai 16 17:10:11 2021] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff] [So Mai 16 17:10:11 2021] brcm-pcie fd500000.pcie: MEM 0x0600000000..0x063fffffff -> 0x00c0000000 [So Mai 16 17:10:11 2021] brcm-pcie fd500000.pcie: IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000 [So Mai 16 17:10:11 2021] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC) [So Mai 16 17:10:11 2021] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00 [So Mai 16 17:10:11 2021] pci_bus 0000:00: root bus resource [bus 00-ff] [So Mai 16 17:10:11 2021] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff]) [So Mai 16 17:10:11 2021] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400 [So Mai 16 17:10:11 2021] pci 0000:00:00.0: PME# supported from D0 D3hot [So Mai 16 17:10:11 2021] PCI: bus0: Fast back to back transfers disabled [So Mai 16 17:10:11 2021] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330 [So Mai 16 17:10:11 2021] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit] [So Mai 16 17:10:11 2021] pci 0000:01:00.0: PME# supported from D0 D3hot [So Mai 16 17:10:11 2021] PCI: bus1: Fast back to back transfers disabled [So Mai 16 17:10:11 2021] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff] [So Mai 16 17:10:11 2021] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit] [So Mai 16 17:10:11 2021] pci 0000:00:00.0: PCI bridge to [bus 01] [So Mai 16 17:10:11 2021] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff] [So Mai 16 17:10:11 2021] pcieport 0000:00:00.0: enabling device (0140 -> 0142) [So Mai 16 17:10:11 2021] pcieport 0000:00:00.0: PME: Signaling with IRQ 63 [So Mai 16 17:10:11 2021] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled [So Mai 16 17:10:11 2021] bcm2835-aux-uart fe215040.serial: there is not valid maps for state default [So Mai 16 17:10:11 2021] iproc-rng200 fe104000.rng: hwrng registered [So Mai 16 17:10:11 2021] vc-mem: phys_addr:0x00000000 mem_base=0x3eb00000 mem_size:0x3ff00000(1023 MiB) [So Mai 16 17:10:11 2021] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000 [So Mai 16 17:10:11 2021] brd: module loaded [So Mai 16 17:10:11 2021] loop: module loaded [So Mai 16 17:10:11 2021] Loading iSCSI transport class v2.0-870. [So Mai 16 17:10:11 2021] libphy: Fixed MDIO Bus: probed [So Mai 16 17:10:11 2021] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000 [So Mai 16 17:10:11 2021] libphy: bcmgenet MII bus: probed [So Mai 16 17:10:11 2021] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus [So Mai 16 17:10:11 2021] usbcore: registered new interface driver r8152 [So Mai 16 17:10:11 2021] usbcore: registered new interface driver lan78xx [So Mai 16 17:10:11 2021] usbcore: registered new interface driver smsc95xx [So Mai 16 17:10:11 2021] xhci_hcd 0000:01:00.0: xHCI Host Controller [So Mai 16 17:10:11 2021] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1 [So Mai 16 17:10:11 2021] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000030000000890 [So Mai 16 17:10:11 2021] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [So Mai 16 17:10:11 2021] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [So Mai 16 17:10:11 2021] usb usb1: Product: xHCI Host Controller [So Mai 16 17:10:11 2021] usb usb1: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd [So Mai 16 17:10:11 2021] usb usb1: SerialNumber: 0000:01:00.0 [So Mai 16 17:10:11 2021] hub 1-0:1.0: USB hub found [So Mai 16 17:10:11 2021] hub 1-0:1.0: 1 port detected [So Mai 16 17:10:11 2021] xhci_hcd 0000:01:00.0: xHCI Host Controller [So Mai 16 17:10:11 2021] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2 [So Mai 16 17:10:11 2021] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed [So Mai 16 17:10:11 2021] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10 [So Mai 16 17:10:11 2021] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [So Mai 16 17:10:11 2021] usb usb2: Product: xHCI Host Controller [So Mai 16 17:10:11 2021] usb usb2: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd [So Mai 16 17:10:11 2021] usb usb2: SerialNumber: 0000:01:00.0 [So Mai 16 17:10:11 2021] hub 2-0:1.0: USB hub found [So Mai 16 17:10:11 2021] hub 2-0:1.0: 4 ports detected [So Mai 16 17:10:11 2021] dwc_otg: version 3.00a 10-AUG-2012 (platform bus) [So Mai 16 17:10:11 2021] dwc_otg: FIQ enabled [So Mai 16 17:10:11 2021] dwc_otg: NAK holdoff enabled [So Mai 16 17:10:11 2021] dwc_otg: FIQ split-transaction FSM enabled [So Mai 16 17:10:11 2021] Module dwc_common_port init [So Mai 16 17:10:11 2021] usbcore: registered new interface driver uas [So Mai 16 17:10:11 2021] usbcore: registered new interface driver usb-storage [So Mai 16 17:10:11 2021] mousedev: PS/2 mouse device common for all mice [So Mai 16 17:10:11 2021] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer [So Mai 16 17:10:11 2021] sdhci: Secure Digital Host Controller Interface driver [So Mai 16 17:10:11 2021] sdhci: Copyright(c) Pierre Ossman [So Mai 16 17:10:11 2021] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe [So Mai 16 17:10:11 2021] sdhci-pltfm: SDHCI platform and OF driver helper [So Mai 16 17:10:11 2021] ledtrig-cpu: registered to indicate activity on CPUs [So Mai 16 17:10:11 2021] hid: raw HID events driver (C) Jiri Kosina [So Mai 16 17:10:11 2021] usbcore: registered new interface driver usbhid [So Mai 16 17:10:11 2021] usbhid: USB HID core driver [So Mai 16 17:10:11 2021] Initializing XFRM netlink socket [So Mai 16 17:10:11 2021] NET: Registered protocol family 17 [So Mai 16 17:10:11 2021] Key type dns_resolver registered [So Mai 16 17:10:11 2021] Registering SWP/SWPB emulation handler [So Mai 16 17:10:11 2021] registered taskstats version 1 [So Mai 16 17:10:11 2021] Loading compiled-in X.509 certificates [So Mai 16 17:10:11 2021] Key type ._fscrypt registered [So Mai 16 17:10:11 2021] Key type .fscrypt registered [So Mai 16 17:10:11 2021] Key type fscrypt-provisioning registered [So Mai 16 17:10:11 2021] uart-pl011 fe201000.serial: there is not valid maps for state default [So Mai 16 17:10:11 2021] uart-pl011 fe201000.serial: cts_event_workaround enabled [So Mai 16 17:10:11 2021] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2 [So Mai 16 17:10:11 2021] bcm2835-aux-uart fe215040.serial: there is not valid maps for state default [So Mai 16 17:10:11 2021] fe215040.serial: ttyS0 at MMIO 0xfe215040 (irq = 37, base_baud = 62500000) is a 16550 [So Mai 16 17:10:11 2021] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver [So Mai 16 17:10:11 2021] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0 [So Mai 16 17:10:11 2021] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated [So Mai 16 17:10:11 2021] of_cfs_init [So Mai 16 17:10:11 2021] of_cfs_init: OK [So Mai 16 17:10:11 2021] mmc1: queuing unknown CIS tuple 0x80 (2 bytes) [So Mai 16 17:10:11 2021] mmc1: queuing unknown CIS tuple 0x80 (3 bytes) [So Mai 16 17:10:11 2021] mmc1: queuing unknown CIS tuple 0x80 (3 bytes) [So Mai 16 17:10:11 2021] mmc1: queuing unknown CIS tuple 0x80 (7 bytes) [So Mai 16 17:10:11 2021] mmc1: queuing unknown CIS tuple 0x80 (3 bytes) [So Mai 16 17:10:11 2021] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA [So Mai 16 17:10:11 2021] Waiting for root device PARTUUID=c7534f19-02... [So Mai 16 17:10:11 2021] random: fast init done [So Mai 16 17:10:11 2021] mmc1: new high speed SDIO card at address 0001 [So Mai 16 17:10:11 2021] usb 1-1: new high-speed USB device number 2 using xhci_hcd [So Mai 16 17:10:12 2021] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21 [So Mai 16 17:10:12 2021] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [So Mai 16 17:10:12 2021] usb 1-1: Product: USB2.0 Hub [So Mai 16 17:10:12 2021] hub 1-1:1.0: USB hub found [So Mai 16 17:10:12 2021] hub 1-1:1.0: 4 ports detected [So Mai 16 17:10:12 2021] usb 2-2: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd [So Mai 16 17:10:12 2021] usb 2-2: New USB device found, idVendor=0781, idProduct=5581, bcdDevice= 1.00 [So Mai 16 17:10:12 2021] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [So Mai 16 17:10:12 2021] usb 2-2: Product: Ultra [So Mai 16 17:10:12 2021] usb 2-2: Manufacturer: SanDisk [So Mai 16 17:10:12 2021] usb 2-2: SerialNumber: 4C530000211114109264 [So Mai 16 17:10:12 2021] usb-storage 2-2:1.0: USB Mass Storage device detected [So Mai 16 17:10:12 2021] scsi host0: usb-storage 2-2:1.0 [So Mai 16 17:10:13 2021] scsi 0:0:0:0: Direct-Access SanDisk Ultra 1.00 PQ: 0 ANSI: 6 [So Mai 16 17:10:13 2021] sd 0:0:0:0: [sda] 121307136 512-byte logical blocks: (62.1 GB/57.8 GiB) [So Mai 16 17:10:13 2021] sd 0:0:0:0: [sda] Write Protect is off [So Mai 16 17:10:13 2021] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00 [So Mai 16 17:10:13 2021] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA [So Mai 16 17:10:13 2021] sda: sda1 sda2 [So Mai 16 17:10:13 2021] sd 0:0:0:0: [sda] Attached SCSI removable disk [So Mai 16 17:10:13 2021] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null) [So Mai 16 17:10:13 2021] VFS: Mounted root (ext4 filesystem) readonly on device 8:2. [So Mai 16 17:10:13 2021] devtmpfs: mounted [So Mai 16 17:10:13 2021] Freeing unused kernel memory: 2048K [So Mai 16 17:10:13 2021] Run /sbin/init as init process [So Mai 16 17:10:13 2021] with arguments: [So Mai 16 17:10:13 2021] /sbin/init [So Mai 16 17:10:13 2021] splash [So Mai 16 17:10:13 2021] with environment: [So Mai 16 17:10:13 2021] HOME=/ [So Mai 16 17:10:13 2021] TERM=linux [So Mai 16 17:10:13 2021] systemd[1]: System time before build time, advancing clock. [So Mai 16 17:10:13 2021] NET: Registered protocol family 10 [So Mai 16 17:10:13 2021] Segment Routing with IPv6 [So Mai 16 17:10:13 2021] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid) [So Mai 16 17:10:13 2021] systemd[1]: Detected architecture arm. [So Mai 16 17:10:13 2021] systemd[1]: Set hostname to <raspberrypi>. [So Mai 16 17:10:14 2021] systemd[1]: /lib/systemd/system/xrdp.service:8: PIDFile= references path below legacy directory /var/run/, updating /var/run/xrdp/xrdp.pid → /run/xrdp/xrdp.pid; please update the unit file accordingly. [So Mai 16 17:10:14 2021] systemd[1]: /lib/systemd/system/xrdp-sesman.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/xrdp/xrdp-sesman.pid → /run/xrdp/xrdp-sesman.pid; please update the unit file accordingly. [So Mai 16 17:10:14 2021] random: systemd: uninitialized urandom read (16 bytes read) [So Mai 16 17:10:14 2021] random: systemd: uninitialized urandom read (16 bytes read) [So Mai 16 17:10:14 2021] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [So Mai 16 17:10:14 2021] random: systemd: uninitialized urandom read (16 bytes read) [So Mai 16 17:10:14 2021] systemd[1]: Listening on initctl Compatibility Named Pipe. [So Mai 16 17:10:14 2021] systemd[1]: Created slice system-getty.slice. [So Mai 16 17:10:14 2021] systemd[1]: Listening on udev Kernel Socket. [So Mai 16 17:10:14 2021] systemd[1]: Listening on Journal Audit Socket. [So Mai 16 17:10:15 2021] i2c /dev entries driver [So Mai 16 17:10:15 2021] EXT4-fs (sda2): re-mounted. Opts: (null) [So Mai 16 17:10:15 2021] systemd-journald[113]: Received request to flush runtime journal from PID 1 [So Mai 16 17:10:16 2021] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000 [So Mai 16 17:10:16 2021] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000 [So Mai 16 17:10:16 2021] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000 [So Mai 16 17:10:16 2021] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000 [So Mai 16 17:10:16 2021] mc: Linux media interface: v0.10 [So Mai 16 17:10:16 2021] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned. [So Mai 16 17:10:16 2021] bcm2835_audio bcm2835_audio: card created with 8 channels [So Mai 16 17:10:16 2021] videodev: Linux video capture interface: v2.00 [So Mai 16 17:10:16 2021] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned. [So Mai 16 17:10:16 2021] bcm2835_vc_sm_cma_probe: Videocore shared memory driver [So Mai 16 17:10:16 2021] [vc_sm_connected_init]: start [So Mai 16 17:10:16 2021] [vc_sm_connected_init]: installed successfully [So Mai 16 17:10:16 2021] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned. [So Mai 16 17:10:16 2021] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned. [So Mai 16 17:10:16 2021] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned. [So Mai 16 17:10:16 2021] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned. [So Mai 16 17:10:16 2021] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned. [So Mai 16 17:10:16 2021] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13 [So Mai 16 17:10:16 2021] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14 [So Mai 16 17:10:16 2021] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15 [So Mai 16 17:10:16 2021] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16 [So Mai 16 17:10:16 2021] bcm2835-isp bcm2835-isp: Register output node 0 with media controller [So Mai 16 17:10:16 2021] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller [So Mai 16 17:10:16 2021] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller [So Mai 16 17:10:16 2021] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller [So Mai 16 17:10:16 2021] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp [So Mai 16 17:10:16 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video10 [So Mai 16 17:10:16 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 decode [So Mai 16 17:10:16 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video11 [So Mai 16 17:10:16 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 encode [So Mai 16 17:10:16 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video12 [So Mai 16 17:10:16 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 isp [So Mai 16 17:10:16 2021] cfg80211: Loading compiled-in X.509 certificates for regulatory database [So Mai 16 17:10:16 2021] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [So Mai 16 17:10:16 2021] [drm] No displays found. Consider forcing hotplug if HDMI is attached [So Mai 16 17:10:16 2021] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4]) [So Mai 16 17:10:17 2021] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1 [So Mai 16 17:10:17 2021] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0 [So Mai 16 17:10:17 2021] brcmfmac: F1 signature read @0x18000000=0x15264345 [So Mai 16 17:10:17 2021] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6 [So Mai 16 17:10:17 2021] usbcore: registered new interface driver brcmfmac [So Mai 16 17:10:17 2021] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2 [So Mai 16 17:10:17 2021] sd 0:0:0:0: Attached scsi generic sg0 type 0 [So Mai 16 17:10:17 2021] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6 [So Mai 16 17:10:17 2021] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan 4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e [So Mai 16 17:10:18 2021] random: crng init done [So Mai 16 17:10:18 2021] random: 7 urandom warning(s) missed due to ratelimiting [So Mai 16 17:10:19 2021] uart-pl011 fe201000.serial: no DMA platform data [So Mai 16 17:10:19 2021] 8021q: 802.1Q VLAN Support v1.8 [So Mai 16 17:10:20 2021] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k FS [So Mai 16 17:10:20 2021] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled [So Mai 16 17:10:20 2021] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay) [So Mai 16 17:10:20 2021] bcmgenet fd580000.ethernet eth0: Link is Down [So Mai 16 17:10:22 2021] broken atomic modeset userspace detected, disabling atomic [So Mai 16 17:10:23 2021] broken atomic modeset userspace detected, disabling atomic [So Mai 16 17:10:24 2021] broken atomic modeset userspace detected, disabling atomic [So Mai 16 17:10:24 2021] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off [So Mai 16 17:10:24 2021] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [So Mai 16 17:10:25 2021] broken atomic modeset userspace detected, disabling atomic [So Mai 16 17:10:26 2021] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready [So Mai 16 17:10:26 2021] broken atomic modeset userspace detected, disabling atomic [So Mai 16 17:10:26 2021] Bluetooth: Core ver 2.22 [So Mai 16 17:10:26 2021] NET: Registered protocol family 31 [So Mai 16 17:10:26 2021] Bluetooth: HCI device and connection manager initialized [So Mai 16 17:10:26 2021] Bluetooth: HCI socket layer initialized [So Mai 16 17:10:26 2021] Bluetooth: L2CAP socket layer initialized [So Mai 16 17:10:26 2021] Bluetooth: SCO socket layer initialized [So Mai 16 17:10:26 2021] Bluetooth: HCI UART driver ver 2.3 [So Mai 16 17:10:26 2021] Bluetooth: HCI UART protocol H4 registered [So Mai 16 17:10:26 2021] Bluetooth: HCI UART protocol Three-wire (H5) registered [So Mai 16 17:10:26 2021] Bluetooth: HCI UART protocol Broadcom registered [So Mai 16 17:10:26 2021] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [So Mai 16 17:10:26 2021] Bluetooth: BNEP filters: protocol multicast [So Mai 16 17:10:26 2021] Bluetooth: BNEP socket layer initialized [So Mai 16 17:10:26 2021] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead [So Mai 16 17:10:26 2021] broken atomic modeset userspace detected, disabling atomic [So Mai 16 17:10:27 2021] broken atomic modeset userspace detected, disabling atomic [So Mai 16 17:10:28 2021] broken atomic modeset userspace detected, disabling atomic [So Mai 16 17:10:29 2021] broken atomic modeset userspace detected, disabling atomic [So Mai 16 17:10:29 2021] broken atomic modeset userspace detected, disabling atomic [So Mai 16 17:10:30 2021] Bluetooth: hci0: command 0x1003 tx timeout [So Mai 16 17:10:32 2021] Bluetooth: hci0: command 0x1001 tx timeout [So Mai 16 17:10:34 2021] Bluetooth: hci0: command 0x1009 tx timeout pi@raspberrypi:~ $ -
@esmax666
Nutzt du bluetooth?
Und schalt den Desktop aus!
Auch den Remote Desktop, der da läuft.
Auf dem Server wird sich per ssh angemeldet.Steck den Stick mal wieder rein und dann schaust du dir die neuen Zeilen in
dmesg -Tan.
@thomas-braun desktop brauche ich
bluetooth momentan nicht, habe ich jetzt raus gemacht, aber geht immer nocht nicht
port ist aber immer beleg
pi@raspberrypi:~ $ cd /opt/iobroker/node_modules/iobroker.zwave2 pi@raspberrypi:/opt/iobroker/node_modules/iobroker.zwave2 $ node build/main.js - -force --logs 2021-05-16 17:40:02.553 - info: zwave2.0 (9243) starting. Version 1.9.3 in /opt /iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16 Logging to file: /opt/iobroker/node_modules/iobroker.zwave2/build/zwavejs_2021-05-16.log 2021-05-16 17:40:02.711 - error: zwave2.0 (9243) The Z-Wave driver could not be started: Error Resource temporarily unavailable Cannot lock port ^C2021-05-16 17:40:24.084 - info: zwave2.0 (9243) Shutting down driver... 2021-05-16 17:40:24.092 - info: zwave2.0 (9243) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason pi@raspberrypi:/opt/iobroker/node_modules/iobroker.zwave2 $pi@raspberrypi:/opt/iobroker/node_modules/iobroker.zwave2 $ sudo lsof /dev/ttyAMA0 lsof: WARNING: can't stat() fuse.xrdp-chansrv file system /home/pi/thinclient_drives Output information may be incomplete. lsof: WARNING: can't stat() fuse.gvfsd-fuse file system /run/user/1000/gvfs Output information may be incomplete. COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME hciattach 586 root 3u CHR 204,64 0t0 135 /dev/ttyAMA0 node 5352 iobroker 27uW CHR 204,64 0t0 135 /dev/ttyApi@raspberrypi:/opt/iobroker/node_modules/iobroker.zwave2 $ dmesg -T [So Mai 16 17:37:56 2021] Booting Linux on physical CPU 0x0 [So Mai 16 17:37:56 2021] Linux version 5.10.17-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1414 SMP Fri Apr 30 13:20:47 BST 2021 [So Mai 16 17:37:56 2021] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d [So Mai 16 17:37:56 2021] CPU: div instructions available: patching division code [So Mai 16 17:37:56 2021] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache [So Mai 16 17:37:56 2021] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.4 [So Mai 16 17:37:56 2021] Memory policy: Data cache writealloc [So Mai 16 17:37:56 2021] Reserved memory: created CMA memory pool at 0x000000001ec00000, size 256 MiB [So Mai 16 17:37:56 2021] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool [So Mai 16 17:37:56 2021] Zone ranges: [So Mai 16 17:37:56 2021] DMA [mem 0x0000000000000000-0x000000002fffffff] [So Mai 16 17:37:56 2021] Normal empty [So Mai 16 17:37:56 2021] HighMem [mem 0x0000000030000000-0x00000001ffffffff] [So Mai 16 17:37:56 2021] Movable zone start for each node [So Mai 16 17:37:56 2021] Early memory node ranges [So Mai 16 17:37:56 2021] node 0: [mem 0x0000000000000000-0x000000003b2fffff] [So Mai 16 17:37:56 2021] node 0: [mem 0x0000000040000000-0x00000000fbffffff] [So Mai 16 17:37:56 2021] node 0: [mem 0x0000000100000000-0x00000001ffffffff] [So Mai 16 17:37:56 2021] Initmem setup node 0 [mem 0x0000000000000000-0x00000001ffffffff] [So Mai 16 17:37:56 2021] On node 0 totalpages: 2061056 [So Mai 16 17:37:56 2021] DMA zone: 2304 pages used for memmap [So Mai 16 17:37:56 2021] DMA zone: 0 pages reserved [So Mai 16 17:37:56 2021] DMA zone: 196608 pages, LIFO batch:63 [So Mai 16 17:37:56 2021] HighMem zone: 1864448 pages, LIFO batch:63 [So Mai 16 17:37:56 2021] percpu: Embedded 20 pages/cpu s50700 r8192 d23028 u81920 [So Mai 16 17:37:56 2021] pcpu-alloc: s50700 r8192 d23028 u81920 alloc=20*4096 [So Mai 16 17:37:56 2021] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [So Mai 16 17:37:56 2021] Built 1 zonelists, mobility grouping on. Total pages: 2058752 [So Mai 16 17:37:56 2021] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 smsc95xx.macaddr=E4:5F:01:1B:22:9D vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000 console=tty1 root=PARTUUID=c7534f19-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles [So Mai 16 17:37:56 2021] Kernel parameter elevator= does not have any effect anymore. Please use sysfs to set IO scheduler for individual devices. [So Mai 16 17:37:56 2021] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear) [So Mai 16 17:37:56 2021] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear) [So Mai 16 17:37:56 2021] mem auto-init: stack:off, heap alloc:off, heap free:off [So Mai 16 17:37:56 2021] software IO TLB: mapped [mem 0x0000000014c00000-0x0000000018c00000] (64MB) [So Mai 16 17:37:56 2021] Memory: 7799068K/8244224K available (10240K kernel code, 1358K rwdata, 3160K rodata, 2048K init, 890K bss, 183012K reserved, 262144K cma-reserved, 7457792K highmem) [So Mai 16 17:37:56 2021] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [So Mai 16 17:37:56 2021] ftrace: allocating 33942 entries in 67 pages [So Mai 16 17:37:56 2021] ftrace: allocated 67 pages with 3 groups [So Mai 16 17:37:56 2021] rcu: Hierarchical RCU implementation. [So Mai 16 17:37:56 2021] Rude variant of Tasks RCU enabled. [So Mai 16 17:37:56 2021] Tracing variant of Tasks RCU enabled. [So Mai 16 17:37:56 2021] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies. [So Mai 16 17:37:56 2021] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 [So Mai 16 17:37:56 2021] GIC: Using split EOI/Deactivate mode [So Mai 16 17:37:56 2021] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=0 [So Mai 16 17:37:56 2021] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns [So Mai 16 17:37:56 2021] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns [So Mai 16 17:37:56 2021] bcm2835: system timer (irq = 25) [So Mai 16 17:37:56 2021] arch_timer: cp15 timer(s) running at 54.00MHz (phys). [So Mai 16 17:37:56 2021] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns [So Mai 16 17:37:56 2021] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns [So Mai 16 17:37:56 2021] Switching to timer-based delay loop, resolution 18ns [So Mai 16 17:37:56 2021] Console: colour dummy device 80x30 [So Mai 16 17:37:56 2021] printk: console [tty1] enabled [So Mai 16 17:37:56 2021] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000) [So Mai 16 17:37:56 2021] pid_max: default: 32768 minimum: 301 [So Mai 16 17:37:56 2021] LSM: Security Framework initializing [So Mai 16 17:37:56 2021] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear) [So Mai 16 17:37:56 2021] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear) [So Mai 16 17:37:56 2021] Disabling memory control group subsystem [So Mai 16 17:37:56 2021] CPU: Testing write buffer coherency: ok [So Mai 16 17:37:56 2021] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [So Mai 16 17:37:56 2021] Setting up static identity map for 0x200000 - 0x20003c [So Mai 16 17:37:56 2021] rcu: Hierarchical SRCU implementation. [So Mai 16 17:37:56 2021] smp: Bringing up secondary CPUs ... [So Mai 16 17:37:56 2021] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 [So Mai 16 17:37:56 2021] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002 [So Mai 16 17:37:56 2021] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003 [So Mai 16 17:37:56 2021] smp: Brought up 1 node, 4 CPUs [So Mai 16 17:37:56 2021] SMP: Total of 4 processors activated (432.00 BogoMIPS). [So Mai 16 17:37:56 2021] CPU: All CPU(s) started in HYP mode. [So Mai 16 17:37:56 2021] CPU: Virtualization extensions available. [So Mai 16 17:37:56 2021] devtmpfs: initialized [So Mai 16 17:37:56 2021] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0 [So Mai 16 17:37:56 2021] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [So Mai 16 17:37:56 2021] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) [So Mai 16 17:37:56 2021] pinctrl core: initialized pinctrl subsystem [So Mai 16 17:37:56 2021] NET: Registered protocol family 16 [So Mai 16 17:37:56 2021] DMA: preallocated 1024 KiB pool for atomic coherent allocations [So Mai 16 17:37:56 2021] audit: initializing netlink subsys (disabled) [So Mai 16 17:37:56 2021] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1 [So Mai 16 17:37:56 2021] thermal_sys: Registered thermal governor 'step_wise' [So Mai 16 17:37:56 2021] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [So Mai 16 17:37:56 2021] hw-breakpoint: maximum watchpoint size is 8 bytes. [So Mai 16 17:37:56 2021] Serial: AMBA PL011 UART driver [So Mai 16 17:37:56 2021] bcm2835-mbox fe00b880.mailbox: mailbox enabled [So Mai 16 17:37:56 2021] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-04-30T13:45:52, variant start [So Mai 16 17:37:56 2021] raspberrypi-firmware soc:firmware: Firmware hash is d7f29d96450abfc77cd6cf011af1faf1e03e5e56 [So Mai 16 17:37:56 2021] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1 [So Mai 16 17:37:56 2021] vgaarb: loaded [So Mai 16 17:37:56 2021] SCSI subsystem initialized [So Mai 16 17:37:56 2021] usbcore: registered new interface driver usbfs [So Mai 16 17:37:56 2021] usbcore: registered new interface driver hub [So Mai 16 17:37:56 2021] usbcore: registered new device driver usb [So Mai 16 17:37:56 2021] usb_phy_generic phy: supply vcc not found, using dummy regulator [So Mai 16 17:37:56 2021] clocksource: Switched to clocksource arch_sys_counter [So Mai 16 17:37:57 2021] VFS: Disk quotas dquot_6.6.0 [So Mai 16 17:37:57 2021] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [So Mai 16 17:37:57 2021] FS-Cache: Loaded [So Mai 16 17:37:57 2021] CacheFiles: Loaded [So Mai 16 17:37:57 2021] NET: Registered protocol family 2 [So Mai 16 17:37:57 2021] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear) [So Mai 16 17:37:57 2021] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear) [So Mai 16 17:37:57 2021] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear) [So Mai 16 17:37:57 2021] TCP: Hash tables configured (established 8192 bind 8192) [So Mai 16 17:37:57 2021] UDP hash table entries: 512 (order: 2, 16384 bytes, linear) [So Mai 16 17:37:57 2021] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear) [So Mai 16 17:37:57 2021] NET: Registered protocol family 1 [So Mai 16 17:37:57 2021] RPC: Registered named UNIX socket transport module. [So Mai 16 17:37:57 2021] RPC: Registered udp transport module. [So Mai 16 17:37:57 2021] RPC: Registered tcp transport module. [So Mai 16 17:37:57 2021] RPC: Registered tcp NFSv4.1 backchannel transport module. [So Mai 16 17:37:57 2021] PCI: CLS 0 bytes, default 64 [So Mai 16 17:37:57 2021] Initialise system trusted keyrings [So Mai 16 17:37:57 2021] workingset: timestamp_bits=14 max_order=21 bucket_order=7 [So Mai 16 17:37:57 2021] zbud: loaded [So Mai 16 17:37:57 2021] FS-Cache: Netfs 'nfs' registered for caching [So Mai 16 17:37:57 2021] NFS: Registering the id_resolver key type [So Mai 16 17:37:57 2021] Key type id_resolver registered [So Mai 16 17:37:57 2021] Key type id_legacy registered [So Mai 16 17:37:57 2021] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [So Mai 16 17:37:57 2021] Key type asymmetric registered [So Mai 16 17:37:57 2021] Asymmetric key parser 'x509' registered [So Mai 16 17:37:57 2021] bounce: pool size: 64 pages [So Mai 16 17:37:57 2021] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249) [So Mai 16 17:37:57 2021] io scheduler mq-deadline registered [So Mai 16 17:37:57 2021] io scheduler kyber registered [So Mai 16 17:37:57 2021] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges: [So Mai 16 17:37:57 2021] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff] [So Mai 16 17:37:57 2021] brcm-pcie fd500000.pcie: MEM 0x0600000000..0x063fffffff -> 0x00c0000000 [So Mai 16 17:37:57 2021] brcm-pcie fd500000.pcie: IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000 [So Mai 16 17:37:57 2021] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC) [So Mai 16 17:37:57 2021] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00 [So Mai 16 17:37:57 2021] pci_bus 0000:00: root bus resource [bus 00-ff] [So Mai 16 17:37:57 2021] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff]) [So Mai 16 17:37:57 2021] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400 [So Mai 16 17:37:57 2021] pci 0000:00:00.0: PME# supported from D0 D3hot [So Mai 16 17:37:57 2021] PCI: bus0: Fast back to back transfers disabled [So Mai 16 17:37:57 2021] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330 [So Mai 16 17:37:57 2021] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit] [So Mai 16 17:37:57 2021] pci 0000:01:00.0: PME# supported from D0 D3hot [So Mai 16 17:37:57 2021] PCI: bus1: Fast back to back transfers disabled [So Mai 16 17:37:57 2021] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff] [So Mai 16 17:37:57 2021] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit] [So Mai 16 17:37:57 2021] pci 0000:00:00.0: PCI bridge to [bus 01] [So Mai 16 17:37:57 2021] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff] [So Mai 16 17:37:57 2021] pcieport 0000:00:00.0: enabling device (0140 -> 0142) [So Mai 16 17:37:57 2021] pcieport 0000:00:00.0: PME: Signaling with IRQ 63 [So Mai 16 17:37:57 2021] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled [So Mai 16 17:37:57 2021] bcm2835-aux-uart fe215040.serial: there is not valid maps for state default [So Mai 16 17:37:57 2021] iproc-rng200 fe104000.rng: hwrng registered [So Mai 16 17:37:57 2021] vc-mem: phys_addr:0x00000000 mem_base=0x3eb00000 mem_size:0x3ff00000(1023 MiB) [So Mai 16 17:37:57 2021] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000 [So Mai 16 17:37:57 2021] brd: module loaded [So Mai 16 17:37:57 2021] loop: module loaded [So Mai 16 17:37:57 2021] Loading iSCSI transport class v2.0-870. [So Mai 16 17:37:57 2021] libphy: Fixed MDIO Bus: probed [So Mai 16 17:37:57 2021] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000 [So Mai 16 17:37:57 2021] libphy: bcmgenet MII bus: probed [So Mai 16 17:37:57 2021] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus [So Mai 16 17:37:57 2021] usbcore: registered new interface driver r8152 [So Mai 16 17:37:57 2021] usbcore: registered new interface driver lan78xx [So Mai 16 17:37:57 2021] usbcore: registered new interface driver smsc95xx [So Mai 16 17:37:57 2021] xhci_hcd 0000:01:00.0: xHCI Host Controller [So Mai 16 17:37:57 2021] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1 [So Mai 16 17:37:57 2021] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000030000000890 [So Mai 16 17:37:57 2021] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [So Mai 16 17:37:57 2021] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [So Mai 16 17:37:57 2021] usb usb1: Product: xHCI Host Controller [So Mai 16 17:37:57 2021] usb usb1: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd [So Mai 16 17:37:57 2021] usb usb1: SerialNumber: 0000:01:00.0 [So Mai 16 17:37:57 2021] hub 1-0:1.0: USB hub found [So Mai 16 17:37:57 2021] hub 1-0:1.0: 1 port detected [So Mai 16 17:37:57 2021] xhci_hcd 0000:01:00.0: xHCI Host Controller [So Mai 16 17:37:57 2021] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2 [So Mai 16 17:37:57 2021] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed [So Mai 16 17:37:57 2021] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10 [So Mai 16 17:37:57 2021] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [So Mai 16 17:37:57 2021] usb usb2: Product: xHCI Host Controller [So Mai 16 17:37:57 2021] usb usb2: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd [So Mai 16 17:37:57 2021] usb usb2: SerialNumber: 0000:01:00.0 [So Mai 16 17:37:57 2021] hub 2-0:1.0: USB hub found [So Mai 16 17:37:57 2021] hub 2-0:1.0: 4 ports detected [So Mai 16 17:37:57 2021] dwc_otg: version 3.00a 10-AUG-2012 (platform bus) [So Mai 16 17:37:57 2021] dwc_otg: FIQ enabled [So Mai 16 17:37:57 2021] dwc_otg: NAK holdoff enabled [So Mai 16 17:37:57 2021] dwc_otg: FIQ split-transaction FSM enabled [So Mai 16 17:37:57 2021] Module dwc_common_port init [So Mai 16 17:37:57 2021] usbcore: registered new interface driver uas [So Mai 16 17:37:57 2021] usbcore: registered new interface driver usb-storage [So Mai 16 17:37:57 2021] mousedev: PS/2 mouse device common for all mice [So Mai 16 17:37:57 2021] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer [So Mai 16 17:37:57 2021] sdhci: Secure Digital Host Controller Interface driver [So Mai 16 17:37:57 2021] sdhci: Copyright(c) Pierre Ossman [So Mai 16 17:37:57 2021] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe [So Mai 16 17:37:57 2021] sdhci-pltfm: SDHCI platform and OF driver helper [So Mai 16 17:37:57 2021] ledtrig-cpu: registered to indicate activity on CPUs [So Mai 16 17:37:57 2021] hid: raw HID events driver (C) Jiri Kosina [So Mai 16 17:37:57 2021] usbcore: registered new interface driver usbhid [So Mai 16 17:37:57 2021] usbhid: USB HID core driver [So Mai 16 17:37:57 2021] Initializing XFRM netlink socket [So Mai 16 17:37:57 2021] NET: Registered protocol family 17 [So Mai 16 17:37:57 2021] Key type dns_resolver registered [So Mai 16 17:37:57 2021] Registering SWP/SWPB emulation handler [So Mai 16 17:37:57 2021] registered taskstats version 1 [So Mai 16 17:37:57 2021] Loading compiled-in X.509 certificates [So Mai 16 17:37:57 2021] Key type ._fscrypt registered [So Mai 16 17:37:57 2021] Key type .fscrypt registered [So Mai 16 17:37:57 2021] Key type fscrypt-provisioning registered [So Mai 16 17:37:57 2021] uart-pl011 fe201000.serial: there is not valid maps for state default [So Mai 16 17:37:57 2021] uart-pl011 fe201000.serial: cts_event_workaround enabled [So Mai 16 17:37:57 2021] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2 [So Mai 16 17:37:57 2021] bcm2835-aux-uart fe215040.serial: there is not valid maps for state default [So Mai 16 17:37:57 2021] fe215040.serial: ttyS0 at MMIO 0xfe215040 (irq = 37, base_baud = 62500000) is a 16550 [So Mai 16 17:37:57 2021] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver [So Mai 16 17:37:57 2021] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0 [So Mai 16 17:37:57 2021] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated [So Mai 16 17:37:57 2021] of_cfs_init [So Mai 16 17:37:57 2021] of_cfs_init: OK [So Mai 16 17:37:57 2021] mmc1: queuing unknown CIS tuple 0x80 (2 bytes) [So Mai 16 17:37:57 2021] mmc1: queuing unknown CIS tuple 0x80 (3 bytes) [So Mai 16 17:37:57 2021] mmc1: queuing unknown CIS tuple 0x80 (3 bytes) [So Mai 16 17:37:57 2021] mmc1: queuing unknown CIS tuple 0x80 (7 bytes) [So Mai 16 17:37:57 2021] mmc1: queuing unknown CIS tuple 0x80 (3 bytes) [So Mai 16 17:37:57 2021] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA [So Mai 16 17:37:57 2021] Waiting for root device PARTUUID=c7534f19-02... [So Mai 16 17:37:57 2021] random: fast init done [So Mai 16 17:37:57 2021] mmc1: new high speed SDIO card at address 0001 [So Mai 16 17:37:57 2021] usb 1-1: new high-speed USB device number 2 using xhci_hcd [So Mai 16 17:37:57 2021] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21 [So Mai 16 17:37:57 2021] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [So Mai 16 17:37:57 2021] usb 1-1: Product: USB2.0 Hub [So Mai 16 17:37:57 2021] hub 1-1:1.0: USB hub found [So Mai 16 17:37:57 2021] hub 1-1:1.0: 4 ports detected [So Mai 16 17:37:58 2021] usb 2-2: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd [So Mai 16 17:37:58 2021] usb 2-2: New USB device found, idVendor=0781, idProduct=5581, bcdDevice= 1.00 [So Mai 16 17:37:58 2021] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [So Mai 16 17:37:58 2021] usb 2-2: Product: Ultra [So Mai 16 17:37:58 2021] usb 2-2: Manufacturer: SanDisk [So Mai 16 17:37:58 2021] usb 2-2: SerialNumber: 4C530000211114109264 [So Mai 16 17:37:58 2021] usb-storage 2-2:1.0: USB Mass Storage device detected [So Mai 16 17:37:58 2021] scsi host0: usb-storage 2-2:1.0 [So Mai 16 17:37:59 2021] scsi 0:0:0:0: Direct-Access SanDisk Ultra 1.00 PQ: 0 ANSI: 6 [So Mai 16 17:37:59 2021] sd 0:0:0:0: [sda] 121307136 512-byte logical blocks: (62.1 GB/57.8 GiB) [So Mai 16 17:37:59 2021] sd 0:0:0:0: [sda] Write Protect is off [So Mai 16 17:37:59 2021] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00 [So Mai 16 17:37:59 2021] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA [So Mai 16 17:37:59 2021] sda: sda1 sda2 [So Mai 16 17:37:59 2021] sd 0:0:0:0: [sda] Attached SCSI removable disk [So Mai 16 17:37:59 2021] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null) [So Mai 16 17:37:59 2021] VFS: Mounted root (ext4 filesystem) readonly on device 8:2. [So Mai 16 17:37:59 2021] devtmpfs: mounted [So Mai 16 17:37:59 2021] Freeing unused kernel memory: 2048K [So Mai 16 17:37:59 2021] Run /sbin/init as init process [So Mai 16 17:37:59 2021] with arguments: [So Mai 16 17:37:59 2021] /sbin/init [So Mai 16 17:37:59 2021] splash [So Mai 16 17:37:59 2021] with environment: [So Mai 16 17:37:59 2021] HOME=/ [So Mai 16 17:37:59 2021] TERM=linux [So Mai 16 17:37:59 2021] systemd[1]: System time before build time, advancing clock. [So Mai 16 17:37:59 2021] NET: Registered protocol family 10 [So Mai 16 17:37:59 2021] Segment Routing with IPv6 [So Mai 16 17:37:59 2021] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid) [So Mai 16 17:37:59 2021] systemd[1]: Detected architecture arm. [So Mai 16 17:37:59 2021] systemd[1]: Set hostname to <raspberrypi>. [So Mai 16 17:38:00 2021] systemd[1]: /lib/systemd/system/xrdp.service:8: PIDFile= references path below legacy directory /var/run/, updating /var/run/xrdp/xrdp.pid → /run/xrdp/xrdp.pid; please update the unit file accordingly. [So Mai 16 17:38:00 2021] systemd[1]: /lib/systemd/system/xrdp-sesman.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/xrdp/xrdp-sesman.pid → /run/xrdp/xrdp-sesman.pid; please update the unit file accordingly. [So Mai 16 17:38:00 2021] random: systemd: uninitialized urandom read (16 bytes read) [So Mai 16 17:38:00 2021] random: systemd: uninitialized urandom read (16 bytes read) [So Mai 16 17:38:00 2021] systemd[1]: Created slice User and Session Slice. [So Mai 16 17:38:00 2021] random: systemd: uninitialized urandom read (16 bytes read) [So Mai 16 17:38:00 2021] systemd[1]: Listening on fsck to fsckd communication Socket. [So Mai 16 17:38:00 2021] systemd[1]: Listening on Syslog Socket. [So Mai 16 17:38:00 2021] systemd[1]: Listening on udev Kernel Socket. [So Mai 16 17:38:00 2021] systemd[1]: Listening on Journal Socket (/dev/log). [So Mai 16 17:38:01 2021] i2c /dev entries driver [So Mai 16 17:38:01 2021] EXT4-fs (sda2): re-mounted. Opts: (null) [So Mai 16 17:38:01 2021] systemd-journald[113]: Received request to flush runtime journal from PID 1 [So Mai 16 17:38:02 2021] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000 [So Mai 16 17:38:02 2021] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000 [So Mai 16 17:38:02 2021] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000 [So Mai 16 17:38:02 2021] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000 [So Mai 16 17:38:02 2021] mc: Linux media interface: v0.10 [So Mai 16 17:38:02 2021] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned. [So Mai 16 17:38:02 2021] videodev: Linux video capture interface: v2.00 [So Mai 16 17:38:02 2021] bcm2835_audio bcm2835_audio: card created with 8 channels [So Mai 16 17:38:02 2021] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned. [So Mai 16 17:38:02 2021] bcm2835_vc_sm_cma_probe: Videocore shared memory driver [So Mai 16 17:38:02 2021] [vc_sm_connected_init]: start [So Mai 16 17:38:02 2021] [vc_sm_connected_init]: installed successfully [So Mai 16 17:38:02 2021] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned. [So Mai 16 17:38:02 2021] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned. [So Mai 16 17:38:02 2021] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned. [So Mai 16 17:38:02 2021] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13 [So Mai 16 17:38:02 2021] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14 [So Mai 16 17:38:02 2021] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0 [So Mai 16 17:38:02 2021] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15 [So Mai 16 17:38:02 2021] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16 [So Mai 16 17:38:02 2021] bcm2835-isp bcm2835-isp: Register output node 0 with media controller [So Mai 16 17:38:02 2021] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller [So Mai 16 17:38:02 2021] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller [So Mai 16 17:38:02 2021] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller [So Mai 16 17:38:02 2021] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp [So Mai 16 17:38:02 2021] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned. [So Mai 16 17:38:02 2021] cfg80211: Loading compiled-in X.509 certificates for regulatory database [So Mai 16 17:38:02 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video10 [So Mai 16 17:38:02 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 decode [So Mai 16 17:38:02 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video11 [So Mai 16 17:38:02 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 encode [So Mai 16 17:38:03 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video12 [So Mai 16 17:38:03 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 isp [So Mai 16 17:38:03 2021] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [So Mai 16 17:38:03 2021] [drm] No displays found. Consider forcing hotplug if HDMI is attached [So Mai 16 17:38:03 2021] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4]) [So Mai 16 17:38:03 2021] sd 0:0:0:0: Attached scsi generic sg0 type 0 [So Mai 16 17:38:03 2021] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1 [So Mai 16 17:38:03 2021] brcmfmac: F1 signature read @0x18000000=0x15264345 [So Mai 16 17:38:03 2021] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6 [So Mai 16 17:38:03 2021] usbcore: registered new interface driver brcmfmac [So Mai 16 17:38:03 2021] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2 [So Mai 16 17:38:03 2021] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6 [So Mai 16 17:38:03 2021] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan 4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e [So Mai 16 17:38:05 2021] random: crng init done [So Mai 16 17:38:05 2021] random: 7 urandom warning(s) missed due to ratelimiting [So Mai 16 17:38:05 2021] uart-pl011 fe201000.serial: no DMA platform data [So Mai 16 17:38:05 2021] 8021q: 802.1Q VLAN Support v1.8 [So Mai 16 17:38:06 2021] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k FS [So Mai 16 17:38:06 2021] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled [So Mai 16 17:38:06 2021] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay) [So Mai 16 17:38:06 2021] bcmgenet fd580000.ethernet eth0: Link is Down [So Mai 16 17:38:08 2021] broken atomic modeset userspace detected, disabling atomic [So Mai 16 17:38:09 2021] broken atomic modeset userspace detected, disabling atomic [So Mai 16 17:38:10 2021] broken atomic modeset userspace detected, disabling atomic [So Mai 16 17:38:11 2021] broken atomic modeset userspace detected, disabling atomic [So Mai 16 17:38:12 2021] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off [So Mai 16 17:38:12 2021] broken atomic modeset userspace detected, disabling atomic [So Mai 16 17:38:12 2021] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [So Mai 16 17:38:12 2021] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready [So Mai 16 17:38:12 2021] Bluetooth: Core ver 2.22 [So Mai 16 17:38:12 2021] NET: Registered protocol family 31 [So Mai 16 17:38:12 2021] Bluetooth: HCI device and connection manager initialized [So Mai 16 17:38:12 2021] Bluetooth: HCI socket layer initialized [So Mai 16 17:38:12 2021] Bluetooth: L2CAP socket layer initialized [So Mai 16 17:38:12 2021] Bluetooth: SCO socket layer initialized [So Mai 16 17:38:12 2021] Bluetooth: HCI UART driver ver 2.3 [So Mai 16 17:38:12 2021] Bluetooth: HCI UART protocol H4 registered [So Mai 16 17:38:12 2021] Bluetooth: HCI UART protocol Three-wire (H5) registered [So Mai 16 17:38:12 2021] Bluetooth: HCI UART protocol Broadcom registered [So Mai 16 17:38:12 2021] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [So Mai 16 17:38:12 2021] Bluetooth: BNEP filters: protocol multicast [So Mai 16 17:38:12 2021] Bluetooth: BNEP socket layer initialized [So Mai 16 17:38:12 2021] broken atomic modeset userspace detected, disabling atomic [So Mai 16 17:38:13 2021] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead [So Mai 16 17:38:13 2021] broken atomic modeset userspace detected, disabling atomic [So Mai 16 17:38:14 2021] broken atomic modeset userspace detected, disabling atomic [So Mai 16 17:38:15 2021] broken atomic modeset userspace detected, disabling atomic [So Mai 16 17:38:15 2021] broken atomic modeset userspace detected, disabling atomic [So Mai 16 17:41:10 2021] fuse: init (API version 7.32) -
Da läuft ja immer noch ein gnome / fuse usw. mit.
sudo raspi-configDann dort:
1 System Options Configure system settings S5 Boot / Auto Login Select boot into desktop or to command line B1 Console Text console, requiring user to login -
@thomas-braun ja, ich brauche Desktop brauche generel
hätte nie gedacht das Desktop probleme macht mit Z wave
ist jetzt weg aber geht immer noch nicht ok
pi@raspberrypi:~ $ dmesg -T [So Mai 16 17:53:13 2021] Booting Linux on physical CPU 0x0 [So Mai 16 17:53:13 2021] Linux version 5.10.17-v7l+ (dom@buildbot) (arm-linux-g nueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ub untu) 2.34) #1414 SMP Fri Apr 30 13:20:47 BST 2021 [So Mai 16 17:53:13 2021] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr =30c5383d [So Mai 16 17:53:13 2021] CPU: div instructions available: patching division cod e [So Mai 16 17:53:13 2021] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruct ion cache [So Mai 16 17:53:13 2021] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.4 [So Mai 16 17:53:13 2021] Memory policy: Data cache writealloc [So Mai 16 17:53:13 2021] Reserved memory: created CMA memory pool at 0x00000000 1ec00000, size 256 MiB [So Mai 16 17:53:13 2021] OF: reserved mem: initialized node linux,cma, compatib le id shared-dma-pool [So Mai 16 17:53:13 2021] Zone ranges: [So Mai 16 17:53:13 2021] DMA [mem 0x0000000000000000-0x000000002fffffff] [So Mai 16 17:53:13 2021] Normal empty [So Mai 16 17:53:13 2021] HighMem [mem 0x0000000030000000-0x00000001ffffffff] [So Mai 16 17:53:13 2021] Movable zone start for each node [So Mai 16 17:53:13 2021] Early memory node ranges [So Mai 16 17:53:13 2021] node 0: [mem 0x0000000000000000-0x000000003b2fffff ] [So Mai 16 17:53:13 2021] node 0: [mem 0x0000000040000000-0x00000000fbffffff ] [So Mai 16 17:53:13 2021] node 0: [mem 0x0000000100000000-0x00000001ffffffff ] [So Mai 16 17:53:13 2021] Initmem setup node 0 [mem 0x0000000000000000-0x0000000 1ffffffff] [So Mai 16 17:53:13 2021] On node 0 totalpages: 2061056 [So Mai 16 17:53:13 2021] DMA zone: 2304 pages used for memmap [So Mai 16 17:53:13 2021] DMA zone: 0 pages reserved [So Mai 16 17:53:13 2021] DMA zone: 196608 pages, LIFO batch:63 [So Mai 16 17:53:13 2021] HighMem zone: 1864448 pages, LIFO batch:63 [So Mai 16 17:53:13 2021] percpu: Embedded 20 pages/cpu s50700 r8192 d23028 u819 20 [So Mai 16 17:53:13 2021] pcpu-alloc: s50700 r8192 d23028 u81920 alloc=20*4096 [So Mai 16 17:53:13 2021] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [So Mai 16 17:53:13 2021] Built 1 zonelists, mobility grouping on. Total pages: 2058752 [So Mai 16 17:53:13 2021] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 smsc95xx.macaddr=E4: 5F:01:1B:22:9D vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000 console=tt y1 root=PARTUUID=c7534f19-02 rootfstype=ext4 elevator=deadline fsck.repair=yes r ootwait quiet splash plymouth.ignore-serial-consoles [So Mai 16 17:53:13 2021] Kernel parameter elevator= does not have any effect an ymore. Please use sysfs to set IO scheduler for individual de vices. [So Mai 16 17:53:13 2021] Dentry cache hash table entries: 131072 (order: 7, 524 288 bytes, linear) [So Mai 16 17:53:13 2021] Inode-cache hash table entries: 65536 (order: 6, 26214 4 bytes, linear) [So Mai 16 17:53:13 2021] mem auto-init: stack:off, heap alloc:off, heap free:of f [So Mai 16 17:53:13 2021] software IO TLB: mapped [mem 0x0000000014c00000-0x0000 000018c00000] (64MB) [So Mai 16 17:53:13 2021] Memory: 7799068K/8244224K available (10240K kernel cod e, 1358K rwdata, 3160K rodata, 2048K init, 890K bss, 183012K reserved, 262144K c ma-reserved, 7457792K highmem) [So Mai 16 17:53:13 2021] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nod es=1 [So Mai 16 17:53:13 2021] ftrace: allocating 33942 entries in 67 pages [So Mai 16 17:53:13 2021] ftrace: allocated 67 pages with 3 groups [So Mai 16 17:53:13 2021] rcu: Hierarchical RCU implementation. [So Mai 16 17:53:13 2021] Rude variant of Tasks RCU enabled. [So Mai 16 17:53:13 2021] Tracing variant of Tasks RCU enabled. [So Mai 16 17:53:13 2021] rcu: RCU calculated value of scheduler-enlistment dela y is 10 jiffies. [So Mai 16 17:53:13 2021] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 [So Mai 16 17:53:13 2021] GIC: Using split EOI/Deactivate mode [So Mai 16 17:53:13 2021] random: get_random_bytes called from start_kernel+0x3c 8/0x59c with crng_init=0 [So Mai 16 17:53:13 2021] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wr aps every 2147483647500ns [So Mai 16 17:53:13 2021] clocksource: timer: mask: 0xffffffff max_cycles: 0xfff fffff, max_idle_ns: 1911260446275 ns [So Mai 16 17:53:13 2021] bcm2835: system timer (irq = 25) [So Mai 16 17:53:13 2021] arch_timer: cp15 timer(s) running at 54.00MHz (phys). [So Mai 16 17:53:13 2021] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns [So Mai 16 17:53:13 2021] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns [So Mai 16 17:53:13 2021] Switching to timer-based delay loop, resolution 18ns [So Mai 16 17:53:13 2021] Console: colour dummy device 80x30 [So Mai 16 17:53:13 2021] printk: console [tty1] enabled [So Mai 16 17:53:13 2021] Calibrating delay loop (skipped), value calculated usi ng timer frequency.. 108.00 BogoMIPS (lpj=540000) [So Mai 16 17:53:13 2021] pid_max: default: 32768 minimum: 301 [So Mai 16 17:53:13 2021] LSM: Security Framework initializing [So Mai 16 17:53:13 2021] Mount-cache hash table entries: 2048 (order: 1, 8192 b ytes, linear) [So Mai 16 17:53:13 2021] Mountpoint-cache hash table entries: 2048 (order: 1, 8 192 bytes, linear) [So Mai 16 17:53:13 2021] Disabling memory control group subsystem [So Mai 16 17:53:13 2021] CPU: Testing write buffer coherency: ok [So Mai 16 17:53:13 2021] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [So Mai 16 17:53:13 2021] Setting up static identity map for 0x200000 - 0x20003c [So Mai 16 17:53:13 2021] rcu: Hierarchical SRCU implementation. [So Mai 16 17:53:13 2021] smp: Bringing up secondary CPUs ... [So Mai 16 17:53:13 2021] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 [So Mai 16 17:53:13 2021] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002 [So Mai 16 17:53:13 2021] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003 [So Mai 16 17:53:13 2021] smp: Brought up 1 node, 4 CPUs [So Mai 16 17:53:13 2021] SMP: Total of 4 processors activated (432.00 BogoMIPS) . [So Mai 16 17:53:13 2021] CPU: All CPU(s) started in HYP mode. [So Mai 16 17:53:13 2021] CPU: Virtualization extensions available. [So Mai 16 17:53:13 2021] devtmpfs: initialized [So Mai 16 17:53:13 2021] VFP support v0.3: implementor 41 architecture 3 part 4 0 variant 8 rev 0 [So Mai 16 17:53:13 2021] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xf fffffff, max_idle_ns: 19112604462750000 ns [So Mai 16 17:53:13 2021] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) [So Mai 16 17:53:13 2021] pinctrl core: initialized pinctrl subsystem [So Mai 16 17:53:13 2021] NET: Registered protocol family 16 [So Mai 16 17:53:13 2021] DMA: preallocated 1024 KiB pool for atomic coherent al locations [So Mai 16 17:53:13 2021] audit: initializing netlink subsys (disabled) [So Mai 16 17:53:13 2021] audit: type=2000 audit(0.030:1): state=initialized aud it_enabled=0 res=1 [So Mai 16 17:53:13 2021] thermal_sys: Registered thermal governor 'step_wise' [So Mai 16 17:53:13 2021] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [So Mai 16 17:53:13 2021] hw-breakpoint: maximum watchpoint size is 8 bytes. [So Mai 16 17:53:13 2021] Serial: AMBA PL011 UART driver [So Mai 16 17:53:13 2021] bcm2835-mbox fe00b880.mailbox: mailbox enabled [So Mai 16 17:53:13 2021] raspberrypi-firmware soc:firmware: Attached to firmwar e from 2021-04-30T13:45:52, variant start [So Mai 16 17:53:13 2021] raspberrypi-firmware soc:firmware: Firmware hash is d7 f29d96450abfc77cd6cf011af1faf1e03e5e56 [So Mai 16 17:53:13 2021] bcm2835-dma fe007000.dma: DMA legacy API manager, dmac hans=0x1 [So Mai 16 17:53:13 2021] vgaarb: loaded [So Mai 16 17:53:13 2021] SCSI subsystem initialized [So Mai 16 17:53:13 2021] usbcore: registered new interface driver usbfs [So Mai 16 17:53:13 2021] usbcore: registered new interface driver hub [So Mai 16 17:53:13 2021] usbcore: registered new device driver usb [So Mai 16 17:53:13 2021] usb_phy_generic phy: supply vcc not found, using dummy regulator [So Mai 16 17:53:13 2021] clocksource: Switched to clocksource arch_sys_counter [So Mai 16 17:53:14 2021] VFS: Disk quotas dquot_6.6.0 [So Mai 16 17:53:14 2021] VFS: Dquot-cache hash table entries: 1024 (order 0, 40 96 bytes) [So Mai 16 17:53:14 2021] FS-Cache: Loaded [So Mai 16 17:53:14 2021] CacheFiles: Loaded [So Mai 16 17:53:14 2021] NET: Registered protocol family 2 [So Mai 16 17:53:14 2021] tcp_listen_portaddr_hash hash table entries: 512 (orde r: 0, 6144 bytes, linear) [So Mai 16 17:53:14 2021] TCP established hash table entries: 8192 (order: 3, 32 768 bytes, linear) [So Mai 16 17:53:14 2021] TCP bind hash table entries: 8192 (order: 4, 65536 byt es, linear) [So Mai 16 17:53:14 2021] TCP: Hash tables configured (established 8192 bind 819 2) [So Mai 16 17:53:14 2021] UDP hash table entries: 512 (order: 2, 16384 bytes, li near) [So Mai 16 17:53:14 2021] UDP-Lite hash table entries: 512 (order: 2, 16384 byte s, linear) [So Mai 16 17:53:14 2021] NET: Registered protocol family 1 [So Mai 16 17:53:14 2021] RPC: Registered named UNIX socket transport module. [So Mai 16 17:53:14 2021] RPC: Registered udp transport module. [So Mai 16 17:53:14 2021] RPC: Registered tcp transport module. [So Mai 16 17:53:14 2021] RPC: Registered tcp NFSv4.1 backchannel transport modu le. [So Mai 16 17:53:14 2021] PCI: CLS 0 bytes, default 64 [So Mai 16 17:53:14 2021] Initialise system trusted keyrings [So Mai 16 17:53:14 2021] workingset: timestamp_bits=14 max_order=21 bucket_orde r=7 [So Mai 16 17:53:14 2021] zbud: loaded [So Mai 16 17:53:14 2021] FS-Cache: Netfs 'nfs' registered for caching [So Mai 16 17:53:14 2021] NFS: Registering the id_resolver key type [So Mai 16 17:53:14 2021] Key type id_resolver registered [So Mai 16 17:53:14 2021] Key type id_legacy registered [So Mai 16 17:53:14 2021] nfs4filelayout_init: NFSv4 File Layout Driver Register ing... [So Mai 16 17:53:14 2021] Key type asymmetric registered [So Mai 16 17:53:14 2021] Asymmetric key parser 'x509' registered [So Mai 16 17:53:14 2021] bounce: pool size: 64 pages [So Mai 16 17:53:14 2021] Block layer SCSI generic (bsg) driver version 0.4 load ed (major 249) [So Mai 16 17:53:14 2021] io scheduler mq-deadline registered [So Mai 16 17:53:14 2021] io scheduler kyber registered [So Mai 16 17:53:14 2021] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d50000 0 ranges: [So Mai 16 17:53:14 2021] brcm-pcie fd500000.pcie: No bus range found for /scb /pcie@7d500000, using [bus 00-ff] [So Mai 16 17:53:14 2021] brcm-pcie fd500000.pcie: MEM 0x0600000000..0x063f ffffff -> 0x00c0000000 [So Mai 16 17:53:14 2021] brcm-pcie fd500000.pcie: IB MEM 0x0000000000..0x00bf ffffff -> 0x0400000000 [So Mai 16 17:53:14 2021] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SS C) [So Mai 16 17:53:14 2021] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:0 0 [So Mai 16 17:53:14 2021] pci_bus 0000:00: root bus resource [bus 00-ff] [So Mai 16 17:53:14 2021] pci_bus 0000:00: root bus resource [mem 0x600000000-0x 63fffffff] (bus address [0xc0000000-0xffffffff]) [So Mai 16 17:53:14 2021] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400 [So Mai 16 17:53:14 2021] pci 0000:00:00.0: PME# supported from D0 D3hot [So Mai 16 17:53:14 2021] PCI: bus0: Fast back to back transfers disabled [So Mai 16 17:53:14 2021] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330 [So Mai 16 17:53:14 2021] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit] [So Mai 16 17:53:14 2021] pci 0000:01:00.0: PME# supported from D0 D3hot [So Mai 16 17:53:14 2021] PCI: bus1: Fast back to back transfers disabled [So Mai 16 17:53:14 2021] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6 000fffff] [So Mai 16 17:53:14 2021] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x6 00000fff 64bit] [So Mai 16 17:53:14 2021] pci 0000:00:00.0: PCI bridge to [bus 01] [So Mai 16 17:53:14 2021] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6 000fffff] [So Mai 16 17:53:14 2021] pcieport 0000:00:00.0: enabling device (0140 -> 0142) [So Mai 16 17:53:14 2021] pcieport 0000:00:00.0: PME: Signaling with IRQ 63 [So Mai 16 17:53:14 2021] Serial: 8250/16550 driver, 1 ports, IRQ sharing enable d [So Mai 16 17:53:14 2021] bcm2835-aux-uart fe215040.serial: there is not valid m aps for state default [So Mai 16 17:53:14 2021] iproc-rng200 fe104000.rng: hwrng registered [So Mai 16 17:53:14 2021] vc-mem: phys_addr:0x00000000 mem_base=0x3eb00000 mem_s ize:0x3ff00000(1023 MiB) [So Mai 16 17:53:14 2021] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registe rs at 0xfe200000 [So Mai 16 17:53:14 2021] brd: module loaded [So Mai 16 17:53:14 2021] loop: module loaded [So Mai 16 17:53:14 2021] Loading iSCSI transport class v2.0-870. [So Mai 16 17:53:14 2021] libphy: Fixed MDIO Bus: probed [So Mai 16 17:53:14 2021] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000 [So Mai 16 17:53:14 2021] libphy: bcmgenet MII bus: probed [So Mai 16 17:53:14 2021] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus [So Mai 16 17:53:14 2021] usbcore: registered new interface driver r8152 [So Mai 16 17:53:14 2021] usbcore: registered new interface driver lan78xx [So Mai 16 17:53:14 2021] usbcore: registered new interface driver smsc95xx [So Mai 16 17:53:14 2021] xhci_hcd 0000:01:00.0: xHCI Host Controller [So Mai 16 17:53:14 2021] xhci_hcd 0000:01:00.0: new USB bus registered, assigne d bus number 1 [So Mai 16 17:53:14 2021] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci versi on 0x100 quirks 0x0000030000000890 [So Mai 16 17:53:14 2021] usb usb1: New USB device found, idVendor=1d6b, idProdu ct=0002, bcdDevice= 5.10 [So Mai 16 17:53:14 2021] usb usb1: New USB device strings: Mfr=3, Product=2, Se rialNumber=1 [So Mai 16 17:53:14 2021] usb usb1: Product: xHCI Host Controller [So Mai 16 17:53:14 2021] usb usb1: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd [So Mai 16 17:53:14 2021] usb usb1: SerialNumber: 0000:01:00.0 [So Mai 16 17:53:14 2021] hub 1-0:1.0: USB hub found [So Mai 16 17:53:14 2021] hub 1-0:1.0: 1 port detected [So Mai 16 17:53:14 2021] xhci_hcd 0000:01:00.0: xHCI Host Controller [So Mai 16 17:53:14 2021] xhci_hcd 0000:01:00.0: new USB bus registered, assigne d bus number 2 [So Mai 16 17:53:14 2021] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpee d [So Mai 16 17:53:14 2021] usb usb2: New USB device found, idVendor=1d6b, idProdu ct=0003, bcdDevice= 5.10 [So Mai 16 17:53:14 2021] usb usb2: New USB device strings: Mfr=3, Product=2, Se rialNumber=1 [So Mai 16 17:53:14 2021] usb usb2: Product: xHCI Host Controller [So Mai 16 17:53:14 2021] usb usb2: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd [So Mai 16 17:53:14 2021] usb usb2: SerialNumber: 0000:01:00.0 [So Mai 16 17:53:14 2021] hub 2-0:1.0: USB hub found [So Mai 16 17:53:14 2021] hub 2-0:1.0: 4 ports detected [So Mai 16 17:53:14 2021] dwc_otg: version 3.00a 10-AUG-2012 (platform bus) [So Mai 16 17:53:14 2021] dwc_otg: FIQ enabled [So Mai 16 17:53:14 2021] dwc_otg: NAK holdoff enabled [So Mai 16 17:53:14 2021] dwc_otg: FIQ split-transaction FSM enabled [So Mai 16 17:53:14 2021] Module dwc_common_port init [So Mai 16 17:53:14 2021] usbcore: registered new interface driver uas [So Mai 16 17:53:14 2021] usbcore: registered new interface driver usb-storage [So Mai 16 17:53:14 2021] mousedev: PS/2 mouse device common for all mice [So Mai 16 17:53:14 2021] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog tim er [So Mai 16 17:53:14 2021] sdhci: Secure Digital Host Controller Interface driver [So Mai 16 17:53:14 2021] sdhci: Copyright(c) Pierre Ossman [So Mai 16 17:53:14 2021] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferri ng probe [So Mai 16 17:53:14 2021] sdhci-pltfm: SDHCI platform and OF driver helper [So Mai 16 17:53:14 2021] ledtrig-cpu: registered to indicate activity on CPUs [So Mai 16 17:53:14 2021] hid: raw HID events driver (C) Jiri Kosina [So Mai 16 17:53:14 2021] usbcore: registered new interface driver usbhid [So Mai 16 17:53:14 2021] usbhid: USB HID core driver [So Mai 16 17:53:14 2021] Initializing XFRM netlink socket [So Mai 16 17:53:14 2021] NET: Registered protocol family 17 [So Mai 16 17:53:14 2021] Key type dns_resolver registered [So Mai 16 17:53:14 2021] Registering SWP/SWPB emulation handler [So Mai 16 17:53:14 2021] registered taskstats version 1 [So Mai 16 17:53:14 2021] Loading compiled-in X.509 certificates [So Mai 16 17:53:14 2021] Key type ._fscrypt registered [So Mai 16 17:53:14 2021] Key type .fscrypt registered [So Mai 16 17:53:14 2021] Key type fscrypt-provisioning registered [So Mai 16 17:53:14 2021] uart-pl011 fe201000.serial: there is not valid maps fo r state default [So Mai 16 17:53:14 2021] uart-pl011 fe201000.serial: cts_event_workaround enabl ed [So Mai 16 17:53:14 2021] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2 [So Mai 16 17:53:14 2021] bcm2835-aux-uart fe215040.serial: there is not valid m aps for state default [So Mai 16 17:53:14 2021] fe215040.serial: ttyS0 at MMIO 0xfe215040 (irq = 37, b ase_baud = 62500000) is a 16550 [So Mai 16 17:53:14 2021] bcm2835-power bcm2835-power: Broadcom BCM2835 power do mains driver [So Mai 16 17:53:14 2021] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0 [So Mai 16 17:53:14 2021] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated [So Mai 16 17:53:14 2021] of_cfs_init [So Mai 16 17:53:14 2021] of_cfs_init: OK [So Mai 16 17:53:14 2021] mmc1: queuing unknown CIS tuple 0x80 (2 bytes) [So Mai 16 17:53:14 2021] mmc1: queuing unknown CIS tuple 0x80 (3 bytes) [So Mai 16 17:53:14 2021] mmc1: queuing unknown CIS tuple 0x80 (3 bytes) [So Mai 16 17:53:14 2021] mmc1: queuing unknown CIS tuple 0x80 (7 bytes) [So Mai 16 17:53:14 2021] mmc1: queuing unknown CIS tuple 0x80 (3 bytes) [So Mai 16 17:53:14 2021] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emm c2] using ADMA [So Mai 16 17:53:14 2021] Waiting for root device PARTUUID=c7534f19-02... [So Mai 16 17:53:14 2021] random: fast init done [So Mai 16 17:53:14 2021] mmc1: new high speed SDIO card at address 0001 [So Mai 16 17:53:14 2021] usb 1-1: new high-speed USB device number 2 using xhci _hcd [So Mai 16 17:53:14 2021] usb 1-1: New USB device found, idVendor=2109, idProduc t=3431, bcdDevice= 4.21 [So Mai 16 17:53:14 2021] usb 1-1: New USB device strings: Mfr=0, Product=1, Ser ialNumber=0 [So Mai 16 17:53:14 2021] usb 1-1: Product: USB2.0 Hub [So Mai 16 17:53:14 2021] hub 1-1:1.0: USB hub found [So Mai 16 17:53:14 2021] hub 1-1:1.0: 4 ports detected [So Mai 16 17:53:15 2021] usb 2-2: new SuperSpeed Gen 1 USB device number 2 usin g xhci_hcd [So Mai 16 17:53:15 2021] usb 2-2: New USB device found, idVendor=0781, idProduc t=5581, bcdDevice= 1.00 [So Mai 16 17:53:15 2021] usb 2-2: New USB device strings: Mfr=1, Product=2, Ser ialNumber=3 [So Mai 16 17:53:15 2021] usb 2-2: Product: Ultra [So Mai 16 17:53:15 2021] usb 2-2: Manufacturer: SanDisk [So Mai 16 17:53:15 2021] usb 2-2: SerialNumber: 4C530000211114109264 [So Mai 16 17:53:15 2021] usb-storage 2-2:1.0: USB Mass Storage device detected [So Mai 16 17:53:15 2021] scsi host0: usb-storage 2-2:1.0 [So Mai 16 17:53:16 2021] scsi 0:0:0:0: Direct-Access SanDisk Ultra 1.00 PQ: 0 ANSI: 6 [So Mai 16 17:53:16 2021] sd 0:0:0:0: [sda] 121307136 512-byte logical blocks: ( 62.1 GB/57.8 GiB) [So Mai 16 17:53:16 2021] sd 0:0:0:0: [sda] Write Protect is off [So Mai 16 17:53:16 2021] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00 [So Mai 16 17:53:16 2021] sd 0:0:0:0: [sda] Write cache: disabled, read cache: e nabled, doesn't support DPO or FUA [So Mai 16 17:53:16 2021] sda: sda1 sda2 [So Mai 16 17:53:16 2021] sd 0:0:0:0: [sda] Attached SCSI removable disk [So Mai 16 17:53:16 2021] EXT4-fs (sda2): mounted filesystem with ordered data m ode. Opts: (null) [So Mai 16 17:53:16 2021] VFS: Mounted root (ext4 filesystem) readonly on device 8:2. [So Mai 16 17:53:16 2021] devtmpfs: mounted [So Mai 16 17:53:16 2021] Freeing unused kernel memory: 2048K [So Mai 16 17:53:16 2021] Run /sbin/init as init process [So Mai 16 17:53:16 2021] with arguments: [So Mai 16 17:53:16 2021] /sbin/init [So Mai 16 17:53:16 2021] splash [So Mai 16 17:53:16 2021] with environment: [So Mai 16 17:53:16 2021] HOME=/ [So Mai 16 17:53:16 2021] TERM=linux [So Mai 16 17:53:16 2021] systemd[1]: System time before build time, advancing c lock. [So Mai 16 17:53:16 2021] NET: Registered protocol family 10 [So Mai 16 17:53:16 2021] Segment Routing with IPv6 [So Mai 16 17:53:16 2021] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GN UTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hie rarchy=hybrid) [So Mai 16 17:53:16 2021] systemd[1]: Detected architecture arm. [So Mai 16 17:53:16 2021] systemd[1]: Set hostname to <raspberrypi>. [So Mai 16 17:53:17 2021] systemd[1]: /lib/systemd/system/xrdp.service:8: PIDFil e= references path below legacy directory /var/run/, updating /var/run/xrdp/xrdp .pid → /run/xrdp/xrdp.pid; please update the unit file accordingly. [So Mai 16 17:53:17 2021] systemd[1]: /lib/systemd/system/xrdp-sesman.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/xr dp/xrdp-sesman.pid → /run/xrdp/xrdp-sesman.pid; please update the unit file acco rdingly. [So Mai 16 17:53:17 2021] random: systemd: uninitialized urandom read (16 bytes read) [So Mai 16 17:53:17 2021] random: systemd: uninitialized urandom read (16 bytes read) [So Mai 16 17:53:17 2021] systemd[1]: Listening on Journal Audit Socket. [So Mai 16 17:53:17 2021] random: systemd: uninitialized urandom read (16 bytes read) [So Mai 16 17:53:17 2021] systemd[1]: Reached target Swap. [So Mai 16 17:53:17 2021] systemd[1]: Created slice User and Session Slice. [So Mai 16 17:53:17 2021] systemd[1]: Listening on Syslog Socket. [So Mai 16 17:53:17 2021] systemd[1]: Listening on Journal Socket. [So Mai 16 17:53:18 2021] i2c /dev entries driver [So Mai 16 17:53:18 2021] EXT4-fs (sda2): re-mounted. Opts: (null) [So Mai 16 17:53:18 2021] systemd-journald[115]: Received request to flush runti me journal from PID 1 [So Mai 16 17:53:19 2021] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initi alised: Registers at 0xfeb00000 length 0x00010000 [So Mai 16 17:53:19 2021] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000 [So Mai 16 17:53:19 2021] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initi alised: Registers at 0xfeb20000 length 0x00010000 [So Mai 16 17:53:19 2021] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initial ised: Registers at 0xfeb30000 length 0x00010000 [So Mai 16 17:53:19 2021] vc_sm_cma: module is from the staging directory, the q uality is unknown, you have been warned. [So Mai 16 17:53:19 2021] bcm2835_vc_sm_cma_probe: Videocore shared memory drive r [So Mai 16 17:53:19 2021] [vc_sm_connected_init]: start [So Mai 16 17:53:19 2021] [vc_sm_connected_init]: installed successfully [So Mai 16 17:53:19 2021] mc: Linux media interface: v0.10 [So Mai 16 17:53:19 2021] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned. [So Mai 16 17:53:19 2021] bcm2835_audio bcm2835_audio: card created with 8 chann els [So Mai 16 17:53:19 2021] videodev: Linux video capture interface: v2.00 [So Mai 16 17:53:19 2021] bcm2835_mmal_vchiq: module is from the staging directo ry, the quality is unknown, you have been warned. [So Mai 16 17:53:19 2021] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned. [So Mai 16 17:53:19 2021] bcm2835-isp bcm2835-isp: Device node output[0] registe red as /dev/video13 [So Mai 16 17:53:19 2021] bcm2835-isp bcm2835-isp: Device node capture[0] regist ered as /dev/video14 [So Mai 16 17:53:19 2021] bcm2835-isp bcm2835-isp: Device node capture[1] regist ered as /dev/video15 [So Mai 16 17:53:19 2021] bcm2835-isp bcm2835-isp: Device node stats[2] register ed as /dev/video16 [So Mai 16 17:53:19 2021] bcm2835-isp bcm2835-isp: Register output node 0 with m edia controller [So Mai 16 17:53:19 2021] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller [So Mai 16 17:53:19 2021] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller [So Mai 16 17:53:19 2021] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller [So Mai 16 17:53:19 2021] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp [So Mai 16 17:53:19 2021] bcm2835_codec: module is from the staging directory, t he quality is unknown, you have been warned. [So Mai 16 17:53:19 2021] bcm2835_v4l2: module is from the staging directory, th e quality is unknown, you have been warned. [So Mai 16 17:53:19 2021] bcm2835-codec bcm2835-codec: Device registered as /dev /video10 [So Mai 16 17:53:19 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 decode [So Mai 16 17:53:19 2021] bcm2835-codec bcm2835-codec: Device registered as /dev /video11 [So Mai 16 17:53:19 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 encode [So Mai 16 17:53:19 2021] bcm2835-codec bcm2835-codec: Device registered as /dev /video12 [So Mai 16 17:53:19 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 isp [So Mai 16 17:53:19 2021] cfg80211: Loading compiled-in X.509 certificates for r egulatory database [So Mai 16 17:53:20 2021] sd 0:0:0:0: Attached scsi generic sg0 type 0 [So Mai 16 17:53:20 2021] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9c ea7' [So Mai 16 17:53:20 2021] brcmfmac: F1 signature read @0x18000000=0x15264345 [So Mai 16 17:53:20 2021] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0 [So Mai 16 17:53:20 2021] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4 3455-sdio for chip BCM4345/6 [So Mai 16 17:53:20 2021] usbcore: registered new interface driver brcmfmac [So Mai 16 17:53:20 2021] brcmfmac mmc1:0001:1: Direct firmware load for brcm/br cmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2 [So Mai 16 17:53:20 2021] [drm] No displays found. Consider forcing hotplug if H DMI is attached [So Mai 16 17:53:20 2021] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ ops [vc4]) [So Mai 16 17:53:20 2021] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1 [So Mai 16 17:53:20 2021] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4 3455-sdio for chip BCM4345/6 [So Mai 16 17:53:20 2021] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 w l0: Jan 4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e [So Mai 16 17:53:21 2021] random: crng init done [So Mai 16 17:53:21 2021] random: 7 urandom warning(s) missed due to ratelimitin g [So Mai 16 17:53:22 2021] uart-pl011 fe201000.serial: no DMA platform data [So Mai 16 17:53:22 2021] 8021q: 802.1Q VLAN Support v1.8 [So Mai 16 17:53:23 2021] Adding 102396k swap on /var/swap. Priority:-2 extents :1 across:102396k FS [So Mai 16 17:53:23 2021] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save en abled [So Mai 16 17:53:23 2021] bcmgenet fd580000.ethernet: configuring instance for e xternal RGMII (RX delay) [So Mai 16 17:53:23 2021] bcmgenet fd580000.ethernet eth0: Link is Down [So Mai 16 17:53:26 2021] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Fu ll - flow control off [So Mai 16 17:53:26 2021] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes read y [So Mai 16 17:53:28 2021] ICMPv6: process `dhcpcd' is using deprecated sysctl (s yscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ ms instead [So Mai 16 17:53:28 2021] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes rea dy [So Mai 16 17:53:29 2021] Bluetooth: Core ver 2.22 [So Mai 16 17:53:29 2021] NET: Registered protocol family 31 [So Mai 16 17:53:29 2021] Bluetooth: HCI device and connection manager initializ ed [So Mai 16 17:53:29 2021] Bluetooth: HCI socket layer initialized [So Mai 16 17:53:29 2021] Bluetooth: L2CAP socket layer initialized [So Mai 16 17:53:29 2021] Bluetooth: SCO socket layer initialized [So Mai 16 17:53:29 2021] Bluetooth: HCI UART driver ver 2.3 [So Mai 16 17:53:29 2021] Bluetooth: HCI UART protocol H4 registered [So Mai 16 17:53:29 2021] Bluetooth: HCI UART protocol Three-wire (H5) registere d [So Mai 16 17:53:29 2021] Bluetooth: HCI UART protocol Broadcom registered [So Mai 16 17:53:29 2021] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [So Mai 16 17:53:29 2021] Bluetooth: BNEP filters: protocol multicast [So Mai 16 17:53:29 2021] Bluetooth: BNEP socket layer initialized pi@raspberrypi:~ $pi@raspberrypi:~ $ cd /opt/iobroker/node_modules/iobroker.zwave2 pi@raspberrypi:/opt/iobroker/node_modules/iobroker.zwave2 $ node build/main.js --force --logs 2021-05-16 17:59:39.521 - info: zwave2.0 (30261) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v12.22.1, js-controller: 3.2.16 Logging to file: /opt/iobroker/node_modules/iobroker.zwave2/build/zwavejs_2021-05-16.log 2021-05-16 17:59:39.677 - error: zwave2.0 (30261) The Z-Wave driver could not be started: Error Resource temporarily unavailable Cannot lock port -
@esmax666 sagte in Probleme mit Serialport bei zwave2:
[So Mai 16 17:53:17 2021] systemd[1]: /lib/systemd/system/xrdp.service:8: PIDFile= references path below legacy directory /var/run/, updating /var/run/xrdp/xrdp.pid → /run/xrdp/xrdp.pid; please update the unit file accordingly. [So Mai 16 17:53:17 2021] systemd[1]: /lib/systemd/system/xrdp-sesman.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/xrdp/xrdp-sesman.pid → /run/xrdp/xrdp-sesman.pid; please update the unit file accordingly.Da läuft immer noch Quark mit (Und die service-Datei ist auch falsch). Hast du VNC in raspi-config aktiv? Mach das da aus.
Steck den Stick jetzt mal wieder rein und schau ob / welche Zeilen am Ende von
dmesg -Tneu dazu gekommen sind. Und nimm den EIntrag /dev/ttyAMA0 mal aus der Adapterkonfig raus. Da hab ich einen Denkfehler drin, das ist wohl das Bluetooth-Device.
@thomas-braun na dann was dann eintragen in serial
@thomas-braun said in Probleme mit Serialport bei zwave2:
wie soll ich das desaktivieren ?
Wie/wo hast du es denn aktiviert? Denn in der Grundkonfiguration läuft das nicht mit.
In raspi-config gibt es aber eine Einstellung aus der Ecke:
3 Interface Options Configure connections to peripherals P3 VNC Enable/disable graphical remote access using RealVNCStell denn da mal aus, wenn der aktiv sein sollte.
Zum Port: Was passiert wenn du den auf /dev/ttyS0 stellst?
