    4. Neuer Adapter vCard
    Neuer Adapter vCard
      crepp last edited by
      Vielen Dank für die Tipps - das war das Problem.
      crepp
      • 0
        0018 last edited by
        habe mir das große Widget eingebaut und die Übersetzung der Namen passt auch.
        Leider schaffe ich es nicht das Format an das Widget anzupassen.
        Wie kann ich das Format von vCard auf das ursprüngliche Format vom Fritzadapter anpassen?
        Mfg
          Brati last edited by
          wenn du z,B, den Channel "vcard.0.Outputs.ReplacedPhoneNumbersCh2" anzeigen lässt, musst du mit den Werten im Adapter probieren, insbesondere die px Anzahl bei width.
          Das wäre das passende Widget zu meinen Einstellungen im Channel 2 (verpasste Anrufe, Achtung nur sichtbar wenn neue Anrufe vorliegen)
          [{"tpl":"tplValueStringRaw","data":{"oid":"vcard.0.Outputs.ReplacedPhoneNumbersCh2","visibility-cond":">","visibility-val":"0","comment":"","visibility-oid":"fritzbox.0.calls.missedCount","name":"List Anrufer","visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false},"style":{"left":603,"top":352,"background":"rgb(107, 71, 75) none repeat scroll 0% 0% / auto padding-box border-box","width":"391px","height":"100px","padding":"","padding-left":"8px","padding-top":"8px","font-family":"\"Courier New\",Courier,monospace","color":"rgb(255, 255, 255)","text-align":"start","text-shadow":"none","font-style":"normal","font-variant":"normal","font-weight":"400","font-size":"13px","z-index":"1"},"widgetSet":"basic"}]
          Brati
          • 0
            0018 last edited by
            Danke, hab mich nach deinen Werten gerichtet und das Format scheint jetzt zu passen.
            Allerdings passt das Format der Spaltenüberschrift nicht zu dem Rest.
            Kann ich das auch irgendwie anpassen?
            Kann ich auch den Inhalt anpassen? Würde gerne das Amt rausnehmen.
              stephan61 last edited by
              hallo habe in log folgenden Fehlemeldung ??
              2016-11-21 12:43:56.467 - [31merror[39m: vcard.0 uncaught exception: srcString.charAt is not a function
              2016-11-21 12:43:56.493 - [31merror[39m: vcard.0 TypeError: srcString.charAt is not a function
              at performNumberString (/opt/iobroker/node_modules/iobroker.vcard/vcard.js:336:30)
              at Adapter. <anonymous>(/opt/iobroker/node_modules/iobroker.vcard/vcard.js:111:17)
              at emitTwo (events.js:87:13)
              at Adapter.emit (events.js:172:7)
              at null._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2220:38)
              at Timer.listOnTimeout (timers.js:92:15)
              2016-11-21 12:43:56.497 - [32minfo[39m: vcard.0 cleaned everything up…
              Gruß Stephan</anonymous>
                hometm last edited by
                Kannst du mir das vcf-file schicken, dann kann ich einmal debuggen
                Gesendet von meinem VT10416-2 mit Tapatalk
                • maloross
                  maloross last edited by
                  Klinke mich hier auch einmal ein. Soweit funktioniert alles bestens (Fritz-Telefonbuch als xlm gesichert und diese Datei mit der Freeware "Contact Conversion Wizard" konvertiert).
                  Allerdings habe ich jetzt das Phänomen, dass die Breite für die Spalte "externe Rufnummer" (dort erscheint dann der Klarname) zu gering bemessen ist, so dass der Name zweizeilig erscheint. Breite des Widgets ändern hat nicht zum Erfolg geführt.
                  • ruhr70
                    ruhr70 last edited by
                    die html Formatierung hat eine feste Breite. Je nach Länge der Rufnummer wird die Spalte mit Leerzeichen (nbsp) aufgefüllt.
                    Kannst Du nicht den Datenpunkt mit dem json nehmen und dann das json Widget?
                    • maloross
                      @ruhr70:
                      Kannst Du nicht den Datenpunkt mit dem json nehmen und dann das json Widget? `
                      Danke für den Tipp, werde ich ausprobieren. Bin noch nicht nicht in CSS, Programmierung usw. drin, werde da mal ein wenig basteln und schauen, wie ich das hinbekommen. Derzeit funzt es, wenn ich die Schriftgröße reduziere.
                      • bahnuhr
                        @hometm:
                        Dies kannst du direkt über ein standard-Widget z.B. "html unescaped" in vis anzeigen `
                        Dies steht auf Seite 3.
                        Nur hab ich so ein widget nicht !
                        Welches soll ich nun nehmen ???
                        Bitte kurze Rückinfo.
                        Danke.
                        mfg
                        Dieter
                        • bahnuhr
                          habs anders gelöst.
                          Trotzdem danke.
                          • ruhr70
                            wie denn?
                              jensus11 last edited by
                              würde mich auch interessieren.
                              • bahnuhr
                                Moin ruhr,
                                basic Table
                                und dann die Formatierung raus im Adapter!
                                filename="bild1.jpg" index="1">~~
                                Und dann siehts so aus (Spalten kann man dann auch selektieren im Widget).
                                filename="bild1.jpg" index="0">~~
                                mfg
                                Dieter
                                  genau so habe ich das bei dem aktiven Anruf auch gemacht.
                                  Wie kann man den im Widget selektieren?
                                  • bahnuhr
                                    meinst du das:
                                      genau. Sowas habe ich in meinen Widget nicht. Kannst das Widget mal posten?
                                      • bahnuhr
                                        Widget: basic-table
                                        [{"tpl":"tplTableBody","data":{"visibility-cond":"==","visibility-val":1,"static_value":"","table_oid":"vcard.0.Outputs.ReplacedPhoneNumbersCh2","colCount":"4","colWidth1":"60px","colWidth2":"60px","colWidth3":"15px","colName1":"Uhrzeit","colName2":"Rufnummer","colName3":"g/k","colAttr1":"date","colAttr2":"externalNumber","colAttr3":"callSymbolColor","colName5":"Dauer","colWidth5":"40px","colAttr5":"durationForm","visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"g_header_§3":true,"max_rows":"8","new_on_top":true,"hide_header":false,"detailed_wid":"","colName4":"Dauer","colAttr4":"durationForm","colWidth4":"20px","g_css_background":true,"g_css_border":false,"g_css_shadow_padding":false,"g_gestures":false,"show_scroll":false},"style":{"left":"235px","top":"60px","width":"360px","height":"185px","text-align":"center","font-size":"14px","z-index":"9","background":"","font-family":"","color":"white","background-color":"black"},"widgetSet":"basic"}]
                                          hast du im vCard Adapter die allTable.json angegeben?
                                          • bahnuhr
                                            ja,
                                            fritzbox.0.history.allTableJSON
                                            128
                                            26258
