    5. [gelöst] hex oder dezimal in binär wandeln und Text ausgeben
      fastfoot @Aiouh last edited by
      @aiouh sagte in [gelöst] hex oder dezimal in binär wandeln und Text ausgeben:
      @fastfoot 32 🙂
      dann probiere mal das hier
       <variables>
         <variable id="~4XVmfvrQ+ySl(:9JVJc">Wert</variable>
         <variable id="VP$OhC~T$WcZDn*b$rrv">BitNr</variable>
         <variable id="b|iK5R#T_Tzw8N{JxO}a">isHex</variable>
         <variable id="rDm0aw]TmX|[Mq?uwvnQ">i</variable>
       </variables>
       <block type="procedures_defcustomreturn" id="m(]X4r-qtRj$L)uSXkJK" x="38" y="63">
         <mutation statements="false">
           <arg name="Wert" varid="~4XVmfvrQ+ySl(:9JVJc"></arg>
           <arg name="BitNr" varid="VP$OhC~T$WcZDn*b$rrv"></arg>
           <arg name="isHex" varid="b|iK5R#T_Tzw8N{JxO}a"></arg>
         </mutation>
         <field name="NAME">checkBit</field>
         <field name="SCRIPT">aWYoaXNIZXgpIFdlcnQgPSBwYXJzZUludChXZXJ0LDE2KTsNCg0KcmV0dXJuIFdlcnQgJiBNYXRoLnBvdygyLEJpdE5yKTs=</field>
       <block type="controls_for" id="$0gxy_`l_(rqS]{JgLmn" x="38" y="88">
         <field name="VAR" id="rDm0aw]TmX|[Mq?uwvnQ">i</field>
         <value name="FROM">
           <shadow type="math_number" id=":[KDu9]L0OPo{e@cPNf)">
             <field name="NUM">0</field>
         <value name="TO">
           <shadow type="math_number" id="#VTiStLRY%eVOueyoM,P">
             <field name="NUM">31</field>
         <value name="BY">
           <shadow type="math_number" id="?dw[-0|8JL+ntq!:*$kO">
             <field name="NUM">1</field>
         <statement name="DO">
           <block type="controls_if" id="W1OpnNrm$:WbJ4zClz2u">
               <block type="procedures_callcustomreturn" id="46okMPY9]=`1;8xF?8sm" inline="true">
                 <mutation name="checkBit">
                   <arg name="Wert"></arg>
                   <arg name="BitNr"></arg>
                   <arg name="isHex"></arg>
                 </mutation>
                 <value name="ARG0">
                   <block type="text" id=";nm%Y[%ax#E3EKX_J3k@">
                     <field name="TEXT">23764358181</field>
                 <value name="ARG1">
                   <block type="variables_get" id="IkLUvT=L,4MJ(W#,64(T">
                 <value name="ARG2">
                   <block type="logic_boolean" id="ycMGtWrRu2%Ox*)W?`4p">
               <block type="debug" id="6n@fW#/%Q1;;ZT%9K^^A">
                 <value name="TEXT">
                   <shadow type="text" id="i2edXykhQDvwzu3Ad$tp">
                     <field name="TEXT">Bit ist gesetzt</field>
                   <block type="text_join" id="D_+N]6YFps`sCn|Oq]!x" inline="true">
                     <value name="ADD0">
                       <block type="text" id="pZ1@kK=ej|`+gETt~j18">
                         <field name="TEXT">Bit Nr </field>
                     <value name="ADD1">
                       <block type="variables_get" id="-CPwQC+5Qg]5[GH$qh,v">
                     <value name="ADD2">
                       <block type="text" id="puh5UqxeZ!NEE2[UCYwI">
                         <field name="TEXT"> ist gesetzt</field>
             <statement name="ELSE">
               <block type="debug" id="I|]eK/esDMO+LrcXlFod">
                 <value name="TEXT">
                   <shadow type="text" id="vQt^2+/sr.HRwTHU3S9m">
                     <field name="TEXT">Bit ist nicht gesetzt</field>
                   <block type="text_join" id="JweA|hrMj@w+Q0{t%s-/" inline="true">
                     <value name="ADD0">
                       <block type="text" id="qEy7J;g}K[bx?shhGX*4">
                     <value name="ADD1">
                       <block type="variables_get" id="_B`*@Fqf5=XJpSd8|b=7">
                     <value name="ADD2">
                       <block type="text" id="$Qdm]X-=JSHYsl9~!H4k">
                         <field name="TEXT"> ist nicht gesetzt</field>
        Aiouh @fastfoot last edited by
        @fastfoot Wow das klappt ja super. Jetzt fehlt mir nur noch, dass ich jedem gesetzten Bit einen Text zuordnen kann. Also falls Bit1 gesetzt (true?) dann "Text für Bit1" in entsprechendes Objekt schreiben. Bei einfachen scripts krieg ich das ja noch hin aber wie baue ich das hier ein ? Auch wenn das blöd ist, dass ich das nicht selbst hinkriege bin ich natürlich echt dankbar für die Hilfe.
        21:50:04.135	info	javascript.0 (20021) script.js.test.binärtest_2: Bit Nr 1 ist nicht gesetzt
        21:50:04.135	info	javascript.0 (20021) script.js.test.binärtest_2: Bit Nr 2 ist gesetzt
        21:50:04.135	info	javascript.0 (20021) script.js.test.binärtest_2: Bit Nr 3 ist nicht gesetzt
        21:50:04.135	info	javascript.0 (20021) script.js.test.binärtest_2: Bit Nr 4 ist nicht gesetzt
        21:50:04.135	info	javascript.0 (20021) script.js.test.binärtest_2: Bit Nr 5 ist gesetzt
        21:50:04.136	info	javascript.0 (20021) script.js.test.binärtest_2: Bit Nr 6 ist nicht gesetzt
        21:50:04.136	info	javascript.0 (20021) script.js.test.binärtest_2: Bit Nr 7 ist nicht gesetzt
        21:50:04.136	info	javascript.0 (20021) script.js.test.binärtest_2: Bit Nr 8 ist nicht gesetzt
        21:50:04.136	info	javascript.0 (20021) script.js.test.binärtest_2: Bit Nr 9 ist nicht gesetzt
        21:50:04.136	info	javascript.0 (20021) script.js.test.binärtest_2: Bit Nr 10 ist gesetzt
        21:50:04.136	info	javascript.0 (20021) script.js.test.binärtest_2: Bit Nr 11 ist nicht gesetzt
        21:50:04.136	info	javascript.0 (20021) script.js.test.binärtest_2: Bit Nr 12 ist gesetzt
        21:50:04.136	info	javascript.0 (20021) script.js.test.binärtest_2: Bit Nr 13 ist nicht gesetzt
        21:50:04.136	info	javascript.0 (20021) script.js.test.binärtest_2: Bit Nr 14 ist gesetzt
        21:50:04.136	info	javascript.0 (20021) script.js.test.binärtest_2: Bit Nr 15 ist nicht gesetzt
        21:50:04.136	info	javascript.0 (20021) script.js.test.binärtest_2: Bit Nr 16 ist gesetzt
        21:50:04.137	info	javascript.0 (20021) script.js.test.binärtest_2: Bit Nr 17 ist gesetzt
        21:50:04.137	info	javascript.0 (20021) script.js.test.binärtest_2: Bit Nr 18 ist gesetzt
        21:50:04.137	info	javascript.0 (20021) script.js.test.binärtest_2: Bit Nr 19 ist nicht gesetzt
        21:50:04.137	info	javascript.0 (20021) script.js.test.binärtest_2: Bit Nr 20 ist gesetzt
        21:50:04.137	info	javascript.0 (20021) script.js.test.binärtest_2: Bit Nr 21 ist gesetzt
        21:50:04.137	info	javascript.0 (20021) script.js.test.binärtest_2: Bit Nr 22 ist gesetzt
        21:50:04.137	info	javascript.0 (20021) script.js.test.binärtest_2: Bit Nr 23 ist nicht gesetzt
        21:50:04.137	info	javascript.0 (20021) script.js.test.binärtest_2: Bit Nr 24 ist nicht gesetzt
        21:50:04.137	info	javascript.0 (20021) script.js.test.binärtest_2: Bit Nr 25 ist nicht gesetzt
        21:50:04.137	info	javascript.0 (20021) script.js.test.binärtest_2: Bit Nr 26 ist nicht gesetzt
        21:50:04.138	info	javascript.0 (20021) script.js.test.binärtest_2: Bit Nr 27 ist gesetzt
        21:50:04.138	info	javascript.0 (20021) script.js.test.binärtest_2: Bit Nr 28 ist nicht gesetzt
        21:50:04.138	info	javascript.0 (20021) script.js.test.binärtest_2: Bit Nr 29 ist nicht gesetzt
        21:50:04.138	info	javascript.0 (20021) script.js.test.binärtest_2: Bit Nr 30 ist nicht gesetzt
        21:50:04.138	info	javascript.0 (20021) script.js.test.binärtest_2: Bit Nr 31 ist gesetzt
          @aiouh Da bleiben wohl nur 32xFalls Blöcke
          A paul53 3 Replies Last reply Reply Quote 0
            @fastfoot Vielen Vielen Dank. Die Texte wurden jetzt einmal geschrieben und werden nicht mehr aktualisiert. Ist wohl zu spät. Ich setz mich morgen nochmal mit frischem Kopf dran.
              paul53 @Aiouh last edited by paul53
              @aiouh
              Der Wert muss eine Zahl sein - kein String. Ich habe die Funktion checkBit(val, bit) korrigiert:
              return val >> bit & 1;
              Test mit einem Byte:
                paul53 @fastfoot last edited by paul53
                @fastfoot sagte: Da bleiben wohl nur 32xFalls Blöcke
                Man kann es mit einer ID-Liste lösen, wobei die ID für nicht benötigte Bit-Positionen ein Leerstring ist. Das Ergebnis der Bit-Prüfung soll sicherlich in einen Datenpunkt vom Typ "boolean" geschrieben werden?
                Zwar etwas umständlicher, geht das auch ohne Javascript-Funktion. Beispiel für ein 4-Bit-Wort:
                  Aiouh @paul53 last edited by
                  @paul53 Hallo, ich sag schon mal Danke. Komme wahrscheinlich erst wieder am Wochenende zum testen.
                  Das Ergebnis soll so aussehen, dass im Falle eines gesetzten Bits (0-31) dessen Erklärung in ein Objekt geschrieben wird. Habe schon mal angefangen da mir nichts besseres, z.B. mit Tabellen, eingefallen ist....
                  Die Objekte sind angelegt, die Texte runtergeschrieben, jetzt klemmts nur noch an der Funktion.
                    @fastfoot
                    Noch klappt es nicht... egal welches Bit ich auf "1" setze, es wird immer nur das Textobjekt für Bit0 geschrieben.
                      @fastfoot
                      Du arbeitest ja nicht mit dem Wert des Triggers! Nimm zum Testen einfach ma den Wert FF, da sind alle Bits gesetzt
                        Aiouh @fastfoot last edited by Aiouh
                        @fastfoot Ok ...wenn ich "FF" als "Wert" nehme werden alle Textobjekte geschrieben, was zum Test OK ist, aber das will ich ja am Ende nicht. Es sollen ja nur die Texte geschrieben werden deren Bit "1" ist, ansonsten soll das Objekt leer bleiben oder mit z.B. "--" beschrieben werden. Nehme ich statt "FF" den "Wert" Triggers rein, passiert gar nix. 😞 Ich steh wohl total auf der Leitung
                          Also funktioniert die Funktion ja wie sie soll 🙂 Ist der Wert eine Dezimalzahl oder HEX? Danach richtet sich ja dann auch der Parameter isHex. Ausserdem kannst du in einem Debug-Block den Wert des Triggers ausgeben lassen. Poste doch mal dein Script als xml-Export und auch einen Wert des Triggers
                            @fastfoot Den Wert habe ich als Binärzahl oder auch Dezimal zur Verfügung.
                            Wenn ich den Wert des triggers mit debug-Block ausgebe bekomme ich "Triggerundefined" sowohl bei Binär als auch bei Dezimal als Eingangswert.
                            Hier das Script
                            var Wert, BitNr, isHex, i;
                            // Beschreibe diese Funktion …
                            async function checkBit(Wert, BitNr, isHex) {
                                if(isHex) Wert = parseInt(Wert,16);
                                return Wert & Math.pow(2,BitNr);
                            on({id: 'mqtt.1.solaranzeige.box1.diag_status', change: "ne"}, async function (obj) {
                              var value = obj.state.val;
                              console.log(('Trigger' + String(Wert)));
                              for (i = 0; i <= 31; i++) {
                                if (await checkBit(Wert, i, true)) {
                                  console.log(Wert);
                                  if (i == 0) {
                                    setState("javascript.0.Eigene_Datenpunkte.solaranzeige.diag_bit0"/*diag_bit0*/, ('Battery doesn’t discharge because of low voltage'), true);
                                  if (i == 1) {
                                    setState("javascript.0.Eigene_Datenpunkte.solaranzeige.diag_bit1"/*diag_bit1*/, ('Battery doesn’t discharge because of low SOC'), true);
                                  if (i == 2) {
                                    setState("javascript.0.Eigene_Datenpunkte.solaranzeige.diag_bit2"/*diag_bit2*/, ('Battery SOC doesn’t recover to dischargeable level'), true);
                            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
                            paul53 F 3 Replies Last reply Reply Quote 0
                              paul53 @Aiouh last edited by
                              @aiouh
                              Wert darf nicht eine selbst erstellte Variable sein, sondern ist aus den Trigger-Blöcken zu nehmen!
                                fastfoot @Aiouh last edited by
                                @aiouh Das ist kein XML-Export, dafür gibt es einen Button oben rechts. Dein Wert ist aber eine von dir angelegte Variable, nicht der Wert des Triggers. lösche diese und nimm aus dem Trigger Block ObjectID und wähle dann Wert aus. Ausserdem setze isHex auf falsch wenn es ein Dezimalwert ist!
                                  fastfoot @Aiouh last edited by fastfoot
                                  @aiouh sagte in [gelöst] hex oder dezimal in binär wandeln und Text ausgeben:
                                  @fastfoot Den Wert habe ich als Binärzahl oder auch Dezimal zur Verfügung.
                                  Diese Werte passen nicht zueinander!
                                  000000000011010100010010011100 = 000D449C = 869532
                                  000010000110000000000000000000 = 02180000 = 35127296
                                  110101000100100111001010010110 = 35127296 = 890401430
                                    Aiouh @fastfoot last edited by
                                    @fastfoot @paul53 Vielen Dank fü Eure Hilfe und vor Allem die Geduld...😊 wieder viel gelernt, wobei ich über den Wert des Triggers vs. Variable schon mal gestolpert bin...
                                    Ich denke dass die Auswertung jetzt funktioniert, wobei ich noch klären muss weshalb die Werte nicht zueinander passen. Darauf dass sie falsch sind wäre ich nicht gekommen, da ich die einfach ungeprüft übernommen habe, aber das bekomme ich geklärt.
                                    Anbei der aktuelle Stand, wobei ich noch zuerst jeden Datenpunkt mit "-" überschreiben werde, um den Text zu leeren.
                                    Das ginge alles sicher eleganter wenn man z.B. die Texte mit scripting in eine Tabelle bringen würde, aber das krieg ich nicht hin und für mich ist das erst mal OK so.
                                      <variables>
                                        <variable id="~4XVmfvrQ+ySl(:9JVJc">Wert</variable>
                                        <variable id="VP$OhC~T$WcZDn*b$rrv">BitNr</variable>
                                        <variable id="b|iK5R#T_Tzw8N{JxO}a">isHex</variable>
                                        <variable id="rDm0aw]TmX|[Mq?uwvnQ">i</variable>
                                      </variables>
                                      <block type="procedures_defcustomreturn" id="}#eBZ=xEhFudaC67I!p$" x="-988" y="-738">
                                        <mutation statements="false">
                                          <arg name="Wert" varid="~4XVmfvrQ+ySl(:9JVJc"></arg>
                                          <arg name="BitNr" varid="VP$OhC~T$WcZDn*b$rrv"></arg>
                                          <arg name="isHex" varid="b|iK5R#T_Tzw8N{JxO}a"></arg>
                                        </mutation>
                                        <field name="NAME">checkBit</field>
                                        <field name="SCRIPT">aWYoaXNIZXgpIFdlcnQgPSBwYXJzZUludChXZXJ0LDE2KTsNCg0KcmV0dXJuIFdlcnQgJiBNYXRoLnBvdygyLEJpdE5yKTs=</field>
                                      <block type="on_ext" id="Em)nR02qtY%1;/]3NZ{B" x="-987" y="-687">
                                        <value name="OID0">
                                          <shadow type="field_oid" id="kIUref~pO,#_@G|?V;7e">
                                            <field name="oid">mqtt.1.solaranzeige.box1.diag_status</field>
                                          <block type="debug" id="K@8/C*j@rBw%nNX`SqAM">
                                            <value name="TEXT">
                                              <shadow type="text" id="`q;vc#/}agPQ$_!},4c6">
                                              <block type="text_join" id="Yj?/;NJ!+sJvm?XTR,CN">
                                                <value name="ADD0">
                                                  <block type="text" id="oro7hz3e8v:6I6p(/Q8+">
                                                    <field name="TEXT">Trigger_dec  :</field>
                                                <value name="ADD1">
                                                  <block type="on_source" id="|=LQU]JKDU6-sn6eHsVx">
                                              <block type="debug" id="?e4=I;C}?Gld)})HKTyK">
                                                <value name="TEXT">
                                                  <shadow type="text">
                                                  <block type="text_join" id="x$va_ZM}TE:=cQj7$RYM">
                                                    <value name="ADD0">
                                                      <block type="text" id="h]v]We50cI`4lh,sV2*x">
                                                        <field name="TEXT">Value_bin  :</field>
                                                    <value name="ADD1">
                                                      <block type="get_value" id="*,UZRwz4`e[i!~b?^Z`n">
                                                        <field name="OID">mqtt.1.solaranzeige.box1.diag_binary</field>
                                                  <block type="controls_for" id="$0gxy_`l_(rqS]{JgLmn">
                                                    <field name="VAR" id="rDm0aw]TmX|[Mq?uwvnQ">i</field>
                                                    <value name="FROM">
                                                      <shadow type="math_number" id=":[KDu9]L0OPo{e@cPNf)">
                                                        <field name="NUM">0</field>
                                                    <value name="TO">
                                                      <shadow type="math_number" id="#VTiStLRY%eVOueyoM,P">
                                                        <field name="NUM">31</field>
                                                    <value name="BY">
                                                      <shadow type="math_number" id="?dw[-0|8JL+ntq!:*$kO">
                                                        <field name="NUM">1</field>
                                                    <statement name="DO">
                                                      <block type="controls_if" id="W1OpnNrm$:WbJ4zClz2u">
                                                          <block type="procedures_callcustomreturn" id="+f}L7Uq#jDNV$-WlVVjC">
                                                            <mutation name="checkBit">
                                                              <arg name="Wert"></arg>
                                                              <arg name="BitNr"></arg>
                                                              <arg name="isHex"></arg>
                                                            </mutation>
                                                            <value name="ARG0">
                                                              <block type="on_source" id="w$_i?nI2?Fnn`LKd,T@6">
                                                            <value name="ARG1">
                                                              <block type="variables_get" id="=AG[UwGJ{%6i?j~c}HH|">
                                                            <value name="ARG2">
                                                              <block type="logic_boolean" id="o?R3:3y:AF#1V~g|2w[[">
                                                          <block type="controls_if" id="ykbn;-xn2?DeByaAR9bG">
                                                              <block type="logic_compare" id="Ji,?;//44]gbFJU:Bct$">
        <field name="OP">EQ</field>
        <block type="variables_get" id="uV/TiL@SoK!5AC.Q.0(o">
        <block type="math_number" id="!A-H/zrP*3kkP_XJQ4?,">
                                                              <block type="update" id="F-3)v,|5e/mI,06lKU3p">
        <field name="OID">javascript.0.Eigene_Datenpunkte.solaranzeige.diag_bit0</field>
        <block type="text_join" id="4O^,U5*LdLnbs_9HS0uj">
        <value name="ADD0">
        <block type="text" id="XY3E@5nMe,{#-70VN/KN">
        <field name="TEXT">Battery doesn’t discharge because of low voltage</field>
                                                              <block type="controls_if" id=":|!]}BD!Ble|N45x!qG*">
        <block type="logic_compare" id="x/{9$1)i*gS9#y6U$Vi:">
        <block type="variables_get" id=",IHBX($2QvS^m4xhlR?X">
        <block type="math_number" id="lD%FABfVV_?//iW_7,Fx">
        <block type="update" id="%x9N0Btr3-yz4~}|7oJS">
        <field name="OID">javascript.0.Eigene_Datenpunkte.solaranzeige.diag_bit1</field>
        <block type="text_join" id="x?YJ9jPKj2D~C0%VtS|n">
        <value name="ADD0">
        <block type="text" id="xYya!U+$y?_Fhz6[b1|R">
        <field name="TEXT">Battery doesn’t discharge because of low SOC</field>
        <block type="controls_if" id="K~uM6mkp(?9$h+4hTX*T">
        <block type="logic_compare" id=",`/WGs+l_l$l9}mgNlZJ">
        <block type="variables_get" id="1EONq-$52fmX0WzsjYC#">
        <block type="math_number" id="qtF#Tm(TexJed)B%$e*n">
        <field name="NUM">2</field>
        <block type="update" id="s+s:!k(f)h*)PSp^4ffk">
        <field name="OID">javascript.0.Eigene_Datenpunkte.solaranzeige.diag_bit2</field>
        <block type="text_join" id="4127)$OZP*|bB(Z{!}Z^">
        <value name="ADD0">
        <block type="text" id="BDiac@u.8WJnvOmgfL9d">
        <field name="TEXT">Battery SOC doesn’t recover to dischargeable level</field>
                                      paul53 @Aiouh last edited by paul53
                                      @aiouh sagte: wobei ich noch zuerst jeden Datenpunkt mit "-" überschreiben werde, um den Text zu leeren.
                                      Das geht besser.
                                       <variables>
                                         <variable id="NN$!TQM$dj]:[h_~@#=I">Liste</variable>
                                         <variable id="#+(5N8{Z=btno-kv;*%v">txt</variable>
                                       </variables>
                                       <block type="variables_set" id="=-N*/f*P%2$Un,N:D?UF" x="-987" y="-738">
                                         <field name="VAR" id="NN$!TQM$dj]:[h_~@#=I">Liste</field>
                                           <block type="lists_create_with" id="s2c8!!10X=!;wlpPIYy)">
                                             <value name="ADD0">
                                             <value name="ADD1">
                                             <value name="ADD2">
                                           <block type="on_ext" id="Em)nR02qtY%1;/]3NZ{B">
                                             <value name="OID0">
                                                 <value name="TEXT">
                                                     <value name="ADD0">
                                                     <value name="ADD1">
                                                     <value name="TEXT">
                                                         <value name="ADD0">
                                                         <value name="ADD1">
                                                         <value name="FROM">
                                                         <value name="TO">
                                                         <value name="BY">
                                                               <block type="procedures_callcustomreturn" id="+f}L7Uq#jDNV$-WlVVjC" inline="true">
        </mutation>
        <value name="ARG0">
        <value name="ARG1">
        <value name="ARG2">
                                                               <block type="variables_set" id="T1D2~cx@V_s65s[ni/c,">
        <field name="VAR" id="#+(5N8{Z=btno-kv;*%v">txt</field>
        <block type="lists_getIndex" id="b#q^2.eypLz(17cfV~l/">
        <block type="variables_get" id="qaNKxsP6MFE3/vc=%?mX">
        <value name="AT">
        <block type="math_arithmetic" id=")*tg6+;hJ5M4C7@O_(/|">
        <field name="OP">ADD</field>
        <shadow type="math_number" id="W6KMqthXK?I08@?itGVr">
        <block type="variables_get" id="zc+[/8UZ1^f:I%C)}7JI">
        <shadow type="math_number" id="bnqn^Yf8fyKS}Wuj0fZH">
                                                             <statement name="ELSE">
                                                               <block type="variables_set" id="oV]RKLr!`Bc3{341gF$Y">
        <block type="text" id="O/8mGIwh!Tg~q~$NB`2?">
        <field name="TEXT">--</field>
                                                               <block type="control_ex" id="]I)ADN_0ewwE!;2.LF;;">
        <field name="TYPE">true</field>
        <value name="OID">
        <shadow type="field_oid" id="~RuaEasRDSTw$0Y!7Y9y">
        <field name="oid">Object ID</field>
        <block type="text_join" id="ao{:rZ$$i|ObZl*[S.G9">
        <value name="ADD0">
        <block type="text" id="*@~MUgHq%t_;f(Z?O:EU">
        <field name="TEXT">javascript.0.Eigene_Datenpunkte.solaranzeige.diag_bit</field>
        <value name="ADD1">
        <block type="variables_get" id="NEw8Txa/gNTtg4-91:mD">
        <shadow type="logic_boolean" id="IsSp?h[[R+ZJCvdF~Bn~">
        <block type="variables_get" id="ookDZ6DO$fq27$oliRGz">
        <value name="DELAY_MS">
        <shadow type="math_number" id="P1MnHm43VOK-?:QZaMN+">
                                       <block type="procedures_defcustomreturn" id="}#eBZ=xEhFudaC67I!p$" x="-738" y="-613">
                                         </mutation>
                                      Du hast hoffentlich schon alle 32 Datenpunkte erstellt?
                                        Aiouh @paul53 last edited by
                                        @paul53 said in [gelöst] hex oder dezimal in binär wandeln und Text ausgeben:
                                        Das geht besser.
                                        Das dachte ich schon 😉 aber da ich ja noch mit den Grundlagen kämpe bin ich froh über alles was "irgendwie" funktioniert.
                                        Ja da habe ich.
                                        Ich werde Dein Skript gerne kopieren und auch versuchen es zu verstehen. Danke
                                          @aiouh sagte: Ja da habe ich.
                                          Dann ergänze auch die Liste um die 29 noch fehlenden Texte.
                                          A 2 Replies Last reply Reply Quote 0
                                            Ja, die kopiere ich dann einfach rüber
                                            4128
