    4. Material Design Widgets: List Widget
    • Scrounger
      Scrounger Developer @michihorn last edited by
      @michihorn sagte in Material Design Widgets: List Widget:
      Hallöchen
      ich möchte in einem Widget die Daten meiner Raspberrymatic darstellen, leider hänge ich da etwas.
      Im linken Widget klappt es, aber nicht in "schön" im rechten klappt es gar nicht. Wie sollte ich vorgehen?
      Linkes Widget:
      Das ist das IconList Widget. Schau bitte zuerst mal in der Doku und hier
      https://forum.iobroker.net/topic/30331/material-design-widgets-iconlist-widget
      Rechtes Widget:
      Hier musst du mit Bindings arbeiten, da das List Widget nicht automatisch den Wert anzeigt. Hab dein Beispiel mal erweitert:
      [{"tpl":"tplVis-materialdesign-List","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","listType":"buttonState","listItemDividerStyle":"padded","listLayout":"card","vibrateOnMobilDevices":"45","listItemDataMethod":"inputPerEditor","countListItems":"4","listItemAlignment":"left","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"oid0":"hm-rega.0.39564","groupHeader0":"","label0":"Uptime","oid1":"hm-rega.0.31888","label1":"Duty Cycle","listImageHeight":"","listImage0":"/hm-rega.admin/homematic.png","listImageColor0":"","groupHeader1":"","groupHeader2":"","groupHeader3":"","dividers1":true,"oid3":"hm-rega.0.37205","rightTextWidth":"150","oid2":"javascript.0.ccu.cpuFrequency","label2":"CPU Frequenz","listImageActive0":"/hm-rega.admin/homematic.png","dividers0":true,"distanceBetweenTextAndImage":"10","colorCheckBox":"#df2a2a","listImageActive2":"/hm-rega.admin/homematic.png","dividers2":true,"label3":"CPU Temperatur","subLabel2":"","subLabel0":"","rightSubLabel0":"","rightLabel0":"{hm-rega.0.39564}"},"style":{"left":"168px","top":"146px","width":"634px","height":"164px"},"widgetSet":"materialdesign"}]
      @oxident sagte in Material Design Widgets: List Widget:
      Wenn ich das Widget aber erstmal anzeige, dann sieht es aus, als wäre kein Wert ausgewählt.
      D.h. wenn du runtime neulädst? Wenn das der Fall ist sollte der Fehler in der nächsten Version behoben sein.
        killroy2 last edited by
        Hallo
        zum Problem:
        ich habe eine Auswahl an 5 Einstellung, davon ist immer nur eine aktiv.
        z.B. Lüftungsstufe Auto, Manuell Stufe 1-4
        Unter Android hätte ich listView mit singleChoice oder eine RadioButton Group.
        Was würde ich hier nehmen?
          HansWurst @killroy2 last edited by
          Ich habe einen Datenpunkt angelegt, dessen Daten ich später per Skript ändern möchte. Testweise habe ich einfach den JSON string der Doku eingefügt.
          Ich bekomme es aber einfach nicht hin, diesen Datenpunkt dem widget in vis zu übergeben. Geht das überhaupt? Im Feld für den JSON-String selbst kann ich das (verständlicher weise) nicht tun, aber komme ich irgendwie and die Struktur zu diesem Feld ran?
          • Glasfaser
            Glasfaser @HansWurst last edited by
            @HansWurst
            Mit Binding ...
            {0_userdata.0.vis.MaterialDesignWidgets.Wetter.Aktuell.Bewolkung}
              HansWurst @Glasfaser last edited by HansWurst
              @Glasfaser Wow, gar so einfach hätte ich mir das jetzt auch nicht vorgestellt. Ich hatte nun schon gedacht, durch debuggen der Webseite auf die Lösung kommen zu müssen 🙂
              Danke für den Hinweis.
              Kannst du eine Seite empfehlen, auf der man sich zum Thema Binding einlesen kann? (die Web-basierten Programmiersprachen sind noch Neuland für mich) Wenn man danach googled, schaut es aus, als wäre Binding eher etwas spezifisches vom jeweiligen Projekt.
                sk8er-boi last edited by
                @Scrounger sagte in Material Design Widgets: List Widget:
                @sk8er-boi sagte in Material Design Widgets: List Widget:
                Wäre es möglich, oder gehts vielleicht schon, das man in dem List Widget, das man nicht pro Liste sondern pro Listenelement den Typ auswählt ?
                Dann könnte man eine gemischte Liste erstellen.
                Steht schon auf der Todo Liste -> https://github.com/Scrounger/ioBroker.vis-materialdesign/issues/56
                Und wäre es möglich in der Liste auch Numbers oder Strings (Temperaturen) anzeigen zu lassen ?
                Geht wenn man bindings verwendet
                Und kann man ein Sliderelement in die Liste einbauen ?
                Das wird es nicht geben, einfach slider drüber legen, bsp:
                https://github.com/Scrounger/ioBroker.vis-materialdesign/issues/48
                Wie funktioniert das mit den bindings
                Scrounger created this issue in Scrounger/ioBroker.vis-materialdesign
                closed [List] Optimierungen #56
                OMCastle created this issue in Scrounger/ioBroker.vis-materialdesign
                closed Dimmerfunktion in List anbieten #48
                • Scrounger
                  Scrounger Developer @sk8er-boi last edited by
                  @sk8er-boi
                  Äh OK und was ist jetzt deine Frage? 😉
                    BobBruni @Scrounger last edited by
                    Ich habe das Widget mit den Custom Elementen aus der Doku importiert. Die Elemente sind bei mir dann aber alle Linksbündig. Wie bekomme ich diese nach rechts?
                    • Scrounger
                      Scrounger Developer @BobBruni last edited by
                      @bobbruni
                      An chrome nicht gedacht. man muss alle justify-content: right; durch justify-content: flex-end; ersetzen. Hab ich gleich mal für dich gemacht 😉
                      [{"tpl":"tplVis-materialdesign-List","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","vibrateOnMobilDevices":"50","listType":"text","listItemDividerStyle":"padded","listLayout":"card","showScrollbar":false,"listItemDataMethod":"inputPerEditor","countListItems":"5","listItemAlignment":"left","listItemBackground":"#mdwTheme:vis-materialdesign.0.colors.list.background_off","listItemBackgroundActive":"#mdwTheme:vis-materialdesign.0.colors.list.background_on","colorSwitchThumb":"#mdwTheme:vis-materialdesign.0.colors.switch.off","colorSwitchTrack":"#mdwTheme:vis-materialdesign.0.colors.switch.track","colorSwitchTrue":"#mdwTheme:vis-materialdesign.0.colors.switch.on","colorSwitchHover":"#mdwTheme:vis-materialdesign.0.colors.switch.off_hover","colorCheckBox":"#mdwTheme:vis-materialdesign.0.colors.checkbox.on","colorListItemHover":"#mdwTheme:vis-materialdesign.0.colors.list.hover","colorListItemSelected":"#mdwTheme:vis-materialdesign.0.colors.list.selected","colorListItemText":"#mdwTheme:vis-materialdesign.0.colors.list.text","colorListItemTextSecondary":"#mdwTheme:vis-materialdesign.0.colors.list.subText","colorListItemTextRight":"#mdwTheme:vis-materialdesign.0.colors.list.text_right","colorListItemTextSecondaryRight":"{mode:vis-materialdesign.0.colors.darkTheme;light:vis-materialdesign.0.colors.light.list.subText_right;dark:vis-materialdesign.0.colors.dark.list.subText_right; mode === \"true\" ? dark : light}","colorListItemHeaders":"#mdwTheme:vis-materialdesign.0.colors.list.header","colorListItemDivider":"#mdwTheme:vis-materialdesign.0.colors.list.divider","headerFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.list.header","listItemFont":"#mdwTheme:vis-materialdesign.0.fonts.list.text","listItemSubFont":"#mdwTheme:vis-materialdesign.0.fonts.list.subText","listItemRightFont":"#mdwTheme:vis-materialdesign.0.fonts.list.text_right","listItemSubRightFont":"#mdwTheme:vis-materialdesign.0.fonts.list.subText_right","listItemTextSize":"#mdwTheme:vis-materialdesign.0.fontSizes.list.text","listItemSubTextSize":"#mdwTheme:vis-materialdesign.0.fontSizes.list.subText","listItemTextRightSize":"#mdwTheme:vis-materialdesign.0.fontSizes.list.text_right","listItemSubTextRightSize":"#mdwTheme:vis-materialdesign.0.fontSizes.list.subText_right","listItemHeaderTextSize":"#mdwTheme:vis-materialdesign.0.fontSizes.list.header","listImageColor0":"#mdwTheme:vis-materialdesign.0.colors.list.icon_off","listImageActiveColor0":"#mdwTheme:vis-materialdesign.0.colors.list.icon_on","listImageColor1":"#mdwTheme:vis-materialdesign.0.colors.list.icon_off","listImageActiveColor1":"#mdwTheme:vis-materialdesign.0.colors.list.icon_on","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"groupHeader0":"List with HTML Widgets","label0":"Button Toggle","rightLabel0":"<div style=\"display: flex; justify-content: flex-end;\">\n    <div class='vis-widget materialdesign-widget materialdesign-button materialdesign-button-html-element'\n    \tstyle='width: 103px; height: 29px; position: relative; padding: 0px; margin-right: 10px;'\n    \tmdw-type='toggle_default'\n    \tmdw-oid='0_userdata.0.bool'\n    \tmdw-buttonStyle='raised'\n    \tmdw-toggleType='boolean'\n    \tmdw-stateIfNotTrueValue='on'\n    \tmdw-vibrateOnMobilDevices='50'\n    \tmdw-buttontext='off'\n    \tmdw-labelTrue='on'\n    \tmdw-textFontFamily='#mdwTheme:vis-materialdesign.0.fonts.button.default.text'\n    \tmdw-textFontSize='#mdwTheme:vis-materialdesign.0.fontSizes.button.default.text'\n    \tmdw-mdwButtonPrimaryColor='#mdwTheme:vis-materialdesign.0.colors.button.default.primary'\n    \tmdw-mdwButtonSecondaryColor='#mdwTheme:vis-materialdesign.0.colors.button.default.secondary'\n    \tmdw-colorBgTrue='green'\n    \tmdw-image='checkbox-blank-outline'\n    \tmdw-imageTrue='checkbox-marked'\n    \tmdw-iconPosition='left'\n    \tmdw-lockEnabled='false'\n    \tmdw-autoLockAfter='10'\n    \tmdw-lockIconColor='#mdwTheme:vis-materialdesign.0.colors.button.lock_icon'\n    \tmdw-lockFilterGrayscale='30'\n    ></div>\n</div>","rightTextWidth":"300","label1":"Switch","rightLabel1":"<div style=\"display: flex; justify-content: flex-end;\">\n    <div class='vis-widget materialdesign-widget materialdesign-switch materialdesign-switch-html-element'\n    \tstyle='height: 50px; position: relative; overflow: visible !important; display: flex; align-items: center;'\n    \tmdw-oid='0_userdata.0.bool'\n    \tmdw-toggleType='boolean'\n    \tmdw-stateIfNotTrueValue='on'\n    \tmdw-vibrateOnMobilDevices='50'\n    \tmdw-labelPosition='right'\n    \tmdw-labelClickActive='true'\n    \tmdw-valueFontFamily='#mdwTheme:vis-materialdesign.0.fonts.switch.value'\n    \tmdw-valueFontSize='#mdwTheme:vis-materialdesign.0.fontSizes.switch.value'\n    \tmdw-colorSwitchThumb='#mdwTheme:vis-materialdesign.0.colors.switch.off'\n    \tmdw-colorSwitchTrack='#mdwTheme:vis-materialdesign.0.colors.switch.track'\n    \tmdw-colorSwitchTrue='#mdwTheme:vis-materialdesign.0.colors.switch.on'\n    \tmdw-colorSwitchHover='#mdwTheme:vis-materialdesign.0.colors.switch.off_hover'\n    \tmdw-colorSwitchHoverTrue='#mdwTheme:vis-materialdesign.0.colors.switch.on_hover'\n    \tmdw-labelColorFalse='#mdwTheme:vis-materialdesign.0.colors.switch.text_off'\n    \tmdw-labelColorTrue='#mdwTheme:vis-materialdesign.0.colors.switch.text_on'\n    \tmdw-autoLockAfter='10'\n    \tmdw-lockIconTop='5'\n    \tmdw-lockIconLeft='5'\n    \tmdw-lockIconColor='#mdwTheme:vis-materialdesign.0.colors.switch.lock_icon'\n    \tmdw-lockFilterGrayscale='30'\n    ></div>\n</div>","listImageColor2":"#mdwTheme:vis-materialdesign.0.colors.list.icon_off","listImageActiveColor2":"#mdwTheme:vis-materialdesign.0.colors.list.icon_on","listImageColor3":"#mdwTheme:vis-materialdesign.0.colors.list.icon_off","listImageActiveColor3":"#mdwTheme:vis-materialdesign.0.colors.list.icon_on","listImageColor4":"#mdwTheme:vis-materialdesign.0.colors.list.icon_off","listImageActiveColor4":"#mdwTheme:vis-materialdesign.0.colors.list.icon_on","listImageColor5":"#mdwTheme:vis-materialdesign.0.colors.list.icon_off","listImageActiveColor5":"#mdwTheme:vis-materialdesign.0.colors.list.icon_on","listImageColor6":"#mdwTheme:vis-materialdesign.0.colors.list.icon_off","listImageActiveColor6":"#mdwTheme:vis-materialdesign.0.colors.list.icon_on","label2":"Slider","rightLabel2":"<div style=\"display: flex; justify-content: flex-end; overflow:visible !important;\">\n    <div class='vis-widget materialdesign-widget materialdesign-slider-vertical materialdesign-slider-html-element'\n    \tstyle='width: 100%; height: 100%; position: relative; overflow:visible !important; display: flex; align-items: center; padding: 0; margin-right: -6px;'\n    \tmdw-oid='0_userdata.0.number'\n    \tmdw-orientation='horizontal'\n    \tmdw-knobSize='knobSmall'\n    \tmdw-step='1'\n    \tmdw-vibrateOnMobilDevices='50'\n    \tmdw-showTicks='no'\n    \tmdw-tickTextColor='#mdwTheme:vis-materialdesign.0.colors.slider.tick'\n    \tmdw-tickFontFamily='#mdwTheme:vis-materialdesign.0.fonts.slider.ticks'\n    \tmdw-tickFontSize='#mdwTheme:vis-materialdesign.0.fontSizes.slider.ticks'\n    \tmdw-tickColorBefore='#mdwTheme:vis-materialdesign.0.colors.slider.tick_before'\n    \tmdw-tickColorAfter='#mdwTheme:vis-materialdesign.0.colors.slider.tick_after'\n    \tmdw-colorBeforeThumb='#mdwTheme:vis-materialdesign.0.colors.slider.control_before'\n    \tmdw-colorThumb='#mdwTheme:vis-materialdesign.0.colors.slider.control'\n    \tmdw-colorAfterThumb='#mdwTheme:vis-materialdesign.0.colors.slider.control_behind'\n    \tmdw-prepandTextColor='#mdwTheme:vis-materialdesign.0.colors.slider.text_prepand'\n    \tmdw-prepandTextFontSize='#mdwTheme:vis-materialdesign.0.fontSizes.slider.prepand'\n    \tmdw-prepandTextFontFamily='#mdwTheme:vis-materialdesign.0.fonts.slider.prepand'\n    \tmdw-valueLabelStyle='sliderValue'\n    \tmdw-valueFontFamily='#mdwTheme:vis-materialdesign.0.fonts.slider.value'\n    \tmdw-valueFontSize='#mdwTheme:vis-materialdesign.0.fontSizes.slider.value'\n    \tmdw-valueLabelColor='#mdwTheme:vis-materialdesign.0.colors.slider.text'\n    \tmdw-valueLabelWidth='50'\n    \tmdw-showThumbLabel='yes'\n    \tmdw-thumbBackgroundColor='#mdwTheme:vis-materialdesign.0.colors.slider.control_background'\n    \tmdw-thumbFontColor='#mdwTheme:vis-materialdesign.0.colors.slider.control_text'\n    \tmdw-thumbFontSize='#mdwTheme:vis-materialdesign.0.fontSizes.slider.control'\n    \tmdw-thumbFontFamily='#mdwTheme:vis-materialdesign.0.fonts.slider.control'\n    ></div>\n</div>","listOverflow2":true,"listItemRightAlignment":"left","rightLabel3":"<div style=\"display: flex; justify-content: flex-end; overflow:visible !important; margin-right: 10px;\">\n    <div class='vis-widget materialdesign-widget materialdesign-progress materialdesign-progress-html-element'\n    \tstyle='width: 100%; height: 30px; position: relative; padding: 0px;'\n    \tmdw-type='linear'\n    \tmdw-oid='0_userdata.0.number'\n    \tmdw-progressRounded='true'\n    \tmdw-colorProgressBackground='#mdwTheme:vis-materialdesign.0.colors.progress.track_background'\n    \tmdw-colorProgress='#mdwTheme:vis-materialdesign.0.colors.progress.track'\n    \tmdw-colorOneCondition='50'\n    \tmdw-colorOne='#mdwTheme:vis-materialdesign.0.colors.progress.track_condition1'\n    \tmdw-colorTwoCondition='70'\n    \tmdw-colorTwo='#mdwTheme:vis-materialdesign.0.colors.progress.track_condition2'\n    \tmdw-showValueLabel='true'\n    \tmdw-valueLabelStyle='progressPercent'\n    \tmdw-textColor='#000'\n    \tmdw-textFontSize='#mdwTheme:vis-materialdesign.0.fontSizes.progress.text'\n    \tmdw-textFontFamily='#mdwTheme:vis-materialdesign.0.fonts.progress.text'\n    \tmdw-textAlign='end'\n    ></div>\n</div>\n\n\n\n","rightSubLabel3":"","listOverflow1":true,"label3":"Progress","dividers0":true,"dividers1":true,"dividers2":true,"dividers3":true,"listImageHeight":"","listItemHeight":"40","listImage0":"gesture-tap-button","oid1":"","listImage1":"application-export","listImage2":"view-day","listImage3":"progress-download","label4":"Select","rightLabel4":"<div style=\"display: flex; justify-content: flex-end; margin-right: 10px;\">\n    <div class='vis-widget materialdesign-widget materialdesign-select materialdesign-select-html-element'\n    \tstyle='width: 183px; height: 28px; position: relative; overflow: visible; display: flex; align-items: center;'\n    \tmdw-oid='0_userdata.0.number'\n    \tmdw-inputType='text'\n    \tmdw-vibrateOnMobilDevices='50'\n    \tmdw-inputLayout='regular'\n    \tmdw-inputAlignment='left'\n    \tmdw-inputLayoutBorderColor='#mdwTheme:vis-materialdesign.0.colors.input.border'\n    \tmdw-inputLayoutBorderColorHover='#mdwTheme:vis-materialdesign.0.colors.input.border_hover'\n    \tmdw-inputLayoutBorderColorSelected='#mdwTheme:vis-materialdesign.0.colors.input.border_selected'\n    \tmdw-inputTextFontFamily='#mdwTheme:vis-materialdesign.0.fonts.input.text'\n    \tmdw-inputTextFontSize='#mdwTheme:vis-materialdesign.0.fontSizes.input.text'\n    \tmdw-inputTextColor='#mdwTheme:vis-materialdesign.0.colors.input.text'\n    \tmdw-inputLabelText='by Value List'\n    \tmdw-inputLabelColor='#mdwTheme:vis-materialdesign.0.colors.input.label'\n    \tmdw-inputLabelColorSelected='#mdwTheme:vis-materialdesign.0.colors.input.label_selected'\n    \tmdw-inputLabelFontFamily='#mdwTheme:vis-materialdesign.0.fonts.input.label'\n    \tmdw-inputLabelFontSize='#mdwTheme:vis-materialdesign.0.fontSizes.input.label'\n    \tmdw-inputTranslateX='-29'\n    \tmdw-inputAppendixColor='#mdwTheme:vis-materialdesign.0.colors.input.appendix'\n    \tmdw-inputAppendixFontSize='#mdwTheme:vis-materialdesign.0.fontSizes.input.appendix'\n    \tmdw-inputAppendixFontFamily='#mdwTheme:vis-materialdesign.0.fonts.input.appendix'\n    \tmdw-showInputMessageAlways='true'\n    \tmdw-inputMessageFontFamily='#mdwTheme:vis-materialdesign.0.fonts.input.message'\n    \tmdw-inputMessageFontSize='#mdwTheme:vis-materialdesign.0.fontSizes.input.message'\n    \tmdw-inputMessageColor='#mdwTheme:vis-materialdesign.0.colors.input.message'\n    \tmdw-inputCounterColor='#mdwTheme:vis-materialdesign.0.colors.input.counter'\n    \tmdw-inputCounterFontSize='#mdwTheme:vis-materialdesign.0.fontSizes.input.counter'\n    \tmdw-inputCounterFontFamily='#mdwTheme:vis-materialdesign.0.fonts.input.counter'\n    \tmdw-clearIconShow='true'\n    \tmdw-clearIconColor='#mdwTheme:vis-materialdesign.0.colors.input.icon_clear'\n    \tmdw-collapseIconColor='#mdwTheme:vis-materialdesign.0.colors.input.icon_collapse'\n    \tmdw-listDataMethod='valueList'\n    \tmdw-countSelectItems='0'\n    \tmdw-valueList='10;30;90'\n    \tmdw-valueListLabels='val1;val2;val3'\n    \tmdw-valueListIcons='home;home;home'\n    \tmdw-listPosition='auto'\n    \tmdw-listItemBackgroundColor='#mdwTheme:vis-materialdesign.0.colors.input.menu.background'\n    \tmdw-listItemBackgroundHoverColor='#mdwTheme:vis-materialdesign.0.colors.input.menu.hover'\n    \tmdw-listItemBackgroundSelectedColor='#mdwTheme:vis-materialdesign.0.colors.input.menu.selected'\n    \tmdw-listItemRippleEffectColor='#mdwTheme:vis-materialdesign.0.colors.input.menu.effect'\n    \tmdw-showSelectedIcon='prepend-inner'\n    \tmdw-listIconColor='#mdwTheme:vis-materialdesign.0.colors.input.menu.icon'\n    \tmdw-listItemFontSize='#mdwTheme:vis-materialdesign.0.fontSizes.input.dropdown.text'\n    \tmdw-listItemFont='#mdwTheme:vis-materialdesign.0.fonts.input.dropdown.text'\n    \tmdw-listItemFontColor='#mdwTheme:vis-materialdesign.0.colors.input.menu.text'\n    \tmdw-listItemSubFontSize='#mdwTheme:vis-materialdesign.0.fontSizes.input.dropdown.subText'\n    \tmdw-listItemSubFont='#mdwTheme:vis-materialdesign.0.fonts.input.dropdown.subText'\n    \tmdw-listItemSubFontColor='#mdwTheme:vis-materialdesign.0.colors.input.menu.subText'\n    \tmdw-showValue='true'\n    \tmdw-listItemValueFontSize='#mdwTheme:vis-materialdesign.0.fontSizes.input.dropdown.value'\n    \tmdw-listItemValueFont='#mdwTheme:vis-materialdesign.0.fonts.input.dropdown.value'\n    \tmdw-listItemValueFontColor='#mdwTheme:vis-materialdesign.0.colors.input.menu.value'\n    ></div>\n</div>\n\n\n\n","listImage4":"airplane-takeoff","dividers4":true,"label5":"Value","subLabel5":"","rightLabel5":"<div style=\"display: flex; justify-content: flex-end; overflow:visible !important; margin-right: 10px;\">\n    <div class='vis-widget materialdesign-widget materialdesign-value materialdesign-value-html-element'\n    \tstyle='width: 80px; height: 100%; position: relative; display: flex; align-items: center;'\n    \tmdw-debug='false'\n    \tmdw-oid='0_userdata.0.number'\n    \tmdw-targetType='auto'\n    \tmdw-textAlign='end'\n    \tmdw-valuesFontColor='#mdwTheme:vis-materialdesign.0.colors.value.text'\n    \tmdw-valuesFontFamily='#mdwTheme:vis-materialdesign.0.fonts.value.text'\n    \tmdw-valuesFontSize='#mdwTheme:vis-materialdesign.0.fontSizes.value.text'\n    \tmdw-prepandTextColor='#mdwTheme:vis-materialdesign.0.colors.value.prepand'\n    \tmdw-prepandTextFontFamily='#mdwTheme:vis-materialdesign.0.fonts.value.prepand'\n    \tmdw-prepandTextFontSize='#mdwTheme:vis-materialdesign.0.fontSizes.value.prepand'\n    \tmdw-appendTextColor='#mdwTheme:vis-materialdesign.0.colors.value.append'\n    \tmdw-appendTextFontFamily='#mdwTheme:vis-materialdesign.0.fonts.value.append'\n    \tmdw-appendTextFontSize='#mdwTheme:vis-materialdesign.0.fontSizes.value.append'\n    \tmdw-valueLabelUnit='%'\n    \tmdw-calculate='#value * 10'\n    \tmdw-image='information'\n    \tmdw-imageColor='#mdwTheme:vis-materialdesign.0.colors.value.icon'\n    \tmdw-iconPosition='left'\n    \tmdw-changeEffectEnabled='true'\n    \tmdw-effectFontColor='#00e640'\n    \tmdw-effectFontSize='16'\n    \tmdw-effectDuration='750'\n    ></div>\n    </div>","listOverflow5":false,"dividers5":true,"listImage5":"parachute","rightLabel6":"","subLabel4":"","listOverflow4":true,"listBackground":"#mdwTheme:vis-materialdesign.0.colors.list.background"},"style":{"left":"12px","top":"12px","width":"433px","height":"315px","overflow-x":""},"widgetSet":"materialdesign"}]
                        @scrounger
                        Gerade bemerkt, dass die Theme-Einstellungen von list.header und list.icon_off zwar im Editor aber nicht in der Runtime übernommen werden...?
                        Editor:
                        Runtime:
                        Bug oder liegts an mir?
                        • Scrounger
                          @bobbruni
                          Brauch den Export vom Widget
                            @scrounger
                            Hier der Export
                            [{"tpl":"tplVis-materialdesign-List","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","vibrateOnMobilDevices":"50","listType":"text","listItemDividerStyle":"standard","listLayout":"standard","showScrollbar":"true","listItemDataMethod":"inputPerEditor","countListItems":"1","listItemAlignment":"left","listBackground":"#mdwTheme:vis-materialdesign.0.colors.list.background","listItemBackground":"#mdwTheme:vis-materialdesign.0.colors.list.background_off","listItemBackgroundActive":"#mdwTheme:vis-materialdesign.0.colors.list.background_on","colorSwitchThumb":"#mdwTheme:vis-materialdesign.0.colors.switch.off","colorSwitchTrack":"#mdwTheme:vis-materialdesign.0.colors.switch.track","colorSwitchTrue":"#mdwTheme:vis-materialdesign.0.colors.switch.on","colorSwitchHover":"#mdwTheme:vis-materialdesign.0.colors.switch.off_hover","colorCheckBox":"#mdwTheme:vis-materialdesign.0.colors.checkbox.on","colorListItemHover":"#mdwTheme:vis-materialdesign.0.colors.list.hover","colorListItemSelected":"#mdwTheme:vis-materialdesign.0.colors.list.selected","colorListItemText":"#mdwTheme:vis-materialdesign.0.colors.list.text","colorListItemTextSecondary":"#mdwTheme:vis-materialdesign.0.colors.list.subText","colorListItemTextRight":"#mdwTheme:vis-materialdesign.0.colors.list.text_right","colorListItemTextSecondaryRight":"{mode:vis-materialdesign.0.colors.darkTheme;light:vis-materialdesign.0.colors.light.list.subText_right;dark:vis-materialdesign.0.colors.dark.list.subText_right; mode === \"true\" ? dark : light}","colorListItemHeaders":"#mdwTheme:vis-materialdesign.0.colors.list.header","colorListItemDivider":"#mdwTheme:vis-materialdesign.0.colors.list.divider","headerFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.list.header","listItemFont":"#mdwTheme:vis-materialdesign.0.fonts.list.text","listItemSubFont":"#mdwTheme:vis-materialdesign.0.fonts.list.subText","listItemRightFont":"#mdwTheme:vis-materialdesign.0.fonts.list.text_right","listItemSubRightFont":"#mdwTheme:vis-materialdesign.0.fonts.list.subText_right","listItemTextSize":"#mdwTheme:vis-materialdesign.0.fontSizes.list.text","listItemSubTextSize":"#mdwTheme:vis-materialdesign.0.fontSizes.list.subText","listItemTextRightSize":"#mdwTheme:vis-materialdesign.0.fontSizes.list.text_right","listItemSubTextRightSize":"#mdwTheme:vis-materialdesign.0.fontSizes.list.subText_right","listItemHeaderTextSize":"#mdwTheme:vis-materialdesign.0.fontSizes.list.header","listImageColor0":"#mdwTheme:vis-materialdesign.0.colors.list.icon_off","listImageActiveColor0":"#mdwTheme:vis-materialdesign.0.colors.list.icon_on","listImageColor1":"#mdwTheme:vis-materialdesign.0.colors.list.icon_off","listImageActiveColor1":"#mdwTheme:vis-materialdesign.0.colors.list.icon_on","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"groupHeader0":"TEST","listImage0":"ab-testing","listImage1":"abacus"},"style":{"left":"10px","top":"270px"},"widgetSet":"materialdesign"}]
                            • Scrounger
                              Scrounger Developer last edited by
                              @bobbruni
                              Also Header geht, evtl. DARK Themen aktiv?
                              Das andere ist ein Bug, wir in der nächsten Version behoben sein
                                @scrounger
                                Sorry, hab mich nicht präzise genug ausgedrückt.
                                Beim Header meinte ich nicht die Farbe, sondern die Schriftgröße, die nicht übernommen wird...
                                • Scrounger
                                  Scrounger Developer @BobBruni last edited by Scrounger
                                  @bobbruni
                                  Ok ist auch nen Bug, da wird gar keine Schriftgröße übernommen. Hab ich behoben.
                                  Zur Info, damit das auch angewendet wird musst du auch was bei Label eintragen.
                                    PatrickFro last edited by
                                    Gibt es einen Trick ein Element "einschieben" zu können? Ich habe etwa 70 Einträge und muss an 25. Stelle ein weiteres Gerät einfügen. Alles anzupassen ist so unkomfortabel 😉
                                      darkiop Most Active last edited by
                                      @Scrounger
                                      Ich nutze deine Liste mit Bindings zur Anzeige von Daten. Die OID habe ich dafür nicht befüllt - nur via Bindungs über zweiter Text / Text Rechts. Allerdings macht das auch keinen Unterschied, siehe Beispiel Projekt.
                                      Bei jedem Update der DPs werden dann die Fehler aus den Screenshot unten geworfen - bei meinem Hauptprojekt sind das ein paar und das ganze summiert sich innerhalb weniger Minuten zu einem Chrome.exe Prozess mit mehreren GB 🙂
                                      Test String - bei manuellem Update von diesem wirft der Browser den Fehler.
                                      createState("Test.Test-String", 'test1', {name: "Test-String", type: "string"});
                                      Beispiel-Projekt zum Nachvollziehen:
                                      2021-06-21-test6.zip
                                      Log - mit tausenden von Einträgen nach wenigen Sekunden:
                                      Hast du eine Idee woran das Liegen könnte?
                                      • Scrounger
                                        Scrounger Developer @darkiop last edited by Scrounger
                                        @darkiop
                                        Welche Version nutzt du?
                                        Sieht mir nach ne Log Meldung aus, die ich eingebaut habe um was zu analysieren und vergessen hab wieder raus zu nehmen
                                        Und noch nen Tipp anstatt der ganzen bindings würde ich das value Widget per html einbinden, ist von der Performance her besser
                                          darkiop Most Active @Scrounger last edited by darkiop
                                          @scrounger sagte in Material Design Widgets: List Widget:
                                          bin auf der 0.5.9
                                          Danke, das Teste ich mal - das gibt dann eine Fleißarbeit 🙂
                                          Edit:
                                          Ich habe in meinem Beispiel Projekt aus meinem Post von heute Morgen eine View mit dem Value-Widget + LIste erstellt - dann wird der Fehler nicht mehr geworfen. Das muss also mit Aktualisierung des DPs über Bindungs zusammenhängen. Heißt für mich: Nach der Fleißarbeit sollte mein Problem behoben sein ...
                                          Edit #2
                                          Denke das wird für die Werte rechts funktionieren, ich stelle da mal ein paar Listen um und beobachte die Anzahl an Meldungen. Ich schreibe allerdings in 'zweiter Text' den last change des DPs, den .lc bekomme ich aber nicht über die OID. Vieleicht wäre das noch eine Idee für eine Erweiterung.
                                          • Scrounger
                                            @darkiop sagte in Material Design Widgets: List Widget:
                                            Edit:
                                            Die Log Meldung hab ich bereits gefunden, war ein überbleibsel im code zum debuggen. Wird in der nächsten Version raus sein.
                                            Das kommt wahrscheinlich durch die Bindings und nicht durch die log meldung. Technik der Bidnings ist, dass wenn sich ein Wert ändert, wird das ganze Widget neu erzeugt, was letztendlich mehr speicher braucht - vorallem wenn die aktualisierung sehr niedrig ist, z.B. wird der Werte jede sekunde aktualsiert wird auch jede Sekunden das Widget neu erzeugt.
                                            Früher gab es deswegen auch mal das Problem mit dem Überlauf.
                                            Deshalb hab ich das Value Widget entwickelt, hier wird nur der Wert bei Veränderung aktualisert und nicht das ganze Widget.
                                            Edit #2
                                            Danach sollte deine Speicherauslastung auch runter gehen. Sollten beim Value Widget funktionen fehlen, schreib nen issue auf github und ich bau es ein.
                                            vis
                                            31
                                            103
                                            14161
