    4. Admin 4.2.1
    Admin 4.2.1
    • Glasfaser
      Glasfaser @sissiwup last edited by
      @sissiwup
      Browser Cache gelöscht ?
      F12 Konsole sagt was , zeigt sie Fehler !?
      sissiwup 1 Reply Last reply Reply Quote 0
      • sissiwup
        sissiwup @Glasfaser last edited by
        @glasfaser
        Anderer Browser genommen. Ging auch nicht.
        jquery.fancytree-all.js:113 Fancytree@1 Fancytree.filterNodes() leavesOnly option is deprecated since 2.9.0 / 2015-04-19. Use opts.leavesOnly instead.
        v @ jquery.fancytree-all.js:113
        warn @ jquery.fancytree-all.js:3019
        e.ui.fancytree._FancytreeClass.filterNodes @ jquery.fancytree-all.js:7944
        (anonymous) @ adminAdapters.js:558
        setTimeout (async)
        (anonymous) @ adminAdapters.js:544
        dispatch @ jquery-3.2.1.min.js:3
        m.handle @ jquery-3.2.1.min.js:3
        trigger @ jquery-3.2.1.min.js:4
        (anonymous) @ jquery-3.2.1.min.js:4
        each @ jquery-3.2.1.min.js:2
        i @ adminAdapters.js:252
        Adapters.prepare @ adminAdapters.js:573
        (anonymous) @ admin.js:2005
        setTimeout (async)
        (anonymous) @ admin.js:1869
        r.onack @ index.js:83
        r.onpacket @ index.js:83
        (anonymous) @ index.js:83
        r.emit @ index.js:83
        r.ondecoded @ index.js:83
        a.add @ index.js:83
        r.ondata @ index.js:83
        r.onPacket @ index.js:83
        r.onData @ index.js:83
        ws.onmessage @ index.js:83
        admin.js:153 Cannot compare "" and "1.0.1"
        upToDate @ admin.js:153
        (anonymous) @ adminAdapters.js:1417
        (anonymous) @ adminAdapters.js:672
        setTimeout (async)
        (anonymous) @ adminAdapters.js:671
        a.add @ index.js:83
        admin.js:153 Cannot compare "" and "0.14.1"
        setTimeout (async)
        a.add @ index.js:83
        admin.js:153 Cannot compare "" and "0.1.3"
        setTimeout (async)
        a.add @ index.js:83
        admin.js:153 Cannot compare "" and "0.0.3"
        setTimeout (async)
        a.add @ index.js:83
        admin.js:153 Cannot compare "" and "0.5.5"
        setTimeout (async)
        a.add @ index.js:83
        admin.js:153 Cannot compare "" and "0.0.6"
        setTimeout (async)
        a.add @ index.js:83
        adminInstances.js:64 Uncaught TypeError: e.match is not a function
            at n (adminInstances.js:64)
            at Instances.replaceInLink (adminInstances.js:142)
            at d (adminInstances.js:433)
            at Instances._postInit (adminInstances.js:1063)
            at adminInstances.js:1152
            at r.<anonymous> (adminInstances.js:1119)
            at r.onack (index.js:83)
            at r.onpacket (index.js:83)
            at r.<anonymous> (index.js:83)
            at r.emit (index.js:83)
        • Glasfaser
          Glasfaser last edited by Glasfaser
          @sissiwup
          Installiere mal über Adapter /+ bei der Auswahl bestimmter Adapter / die 4.1.12 und dann nochmal nach der Installation ein Upload dort machen .
          EDIT :
          Nach update auf Admin 4.2.1
          da hast aber schon lange kein Update auf deinem System gemacht ... die ist schon über 4 Monate in Stable !
          • sissiwup
            @glasfaser
            Hi, habe zwischenzeitlich ein reinstall gemacht. Keine Besserung
            Mache jetzt deinen Tipp
            • sissiwup
              sissiwup @sissiwup last edited by
              @sissiwup sagte in Admin 4.2.1:
              @glasfaser
              Hat leider auch nix gebracht.
              • Glasfaser
                @sissiwup
                und nochmal über Putty
                iobroker stop
                iobroker upload admin
                iobroker fix
                iobroker start
                EDIT :
                das später mal zeigen :
                iobroker list instances
                • sissiwup
                  @glasfaser sagte in Admin 4.2.1:
                  @sissiwup
                  iobroker stop
                  iobroker start
                  Hi, genau das habe ich gemacht.
                  Habe jetzt das Backup vorm update eingespielt. War da scheinbar auch schon kaputt (Reiter Instanzen brauche ich seltener)
                  Das letzt was ich vorher gemacht habe (so weit ich mich erinnere) bin von beta auf stable gewechselt und habe alle Adapter die weiter waren wieder auf stabel zurückgesetzt. Kann es daran liegen?
                  • Glasfaser
                    Das heißt du schleppst den defekt immer schon mit dir !?
                    • sissiwup
                      Scheinbar. Wenn ich Admin auf 5.x anheben, dann zeigt er wieder alles an.
                      Eigentlich wollt eich aber auf stable gehen, da im beta leider die Gruppen (Heizungen) schon seit längeren defekt sind (-1 Maximaler Wert usw)
                        Kallo last edited by
                        Ich hatte das gleiche Problem. Ich hatte aus dem latest den Admin 5.0.24 installiert. Nach einem Einspielen des Backups wurde automatisch der 4.xx aus stable installiert. Damit war auch der Reiter "Instanzen" leer, die Übersicht im übrigen auch. Ich bin dann wieder zurück auf Admin 5.0.24, damit sind die installierten Adapter wieder in den Instanzen zu sehen. Das Problem tritt wohl nach einem Downgrade des Admin-Adapters auf.
                        307
