    • a200
      a200 @SBorg last edited by
      @sborg Die neue Version läuft super. Vielen Dank für deine Mühe!
      • SBorg
        Irgendwas läuft da aber noch schief:
        SUCCESS (valid measurements count: 9, valid station info count: 0)
        9 Werte schicke ich auch, nur fehlt in der Windy-DB dann "Windböe" und "UV-Index", mal abgesehen vom Nonsens bei der "Windstärke". Aber die steht zumindest mit plausiblen Werten in der Windy-DB als m/s, wird dann im Web nur mit "x g:y" angezeigt:
        "wind":[null,null,1.29,1.78,0.58,1.51,2.01,0.58,1.38,2.59,0.8,0.98,0.98,0.71,1.92,3.21,2.1,3.08,2.41,1.51,3.7,2.27,1.29,2.18,2.41,2.18,0.89,3.39,2.1,0.98,0.31,2.59,1.51,1.92,2.1,0,2.41,0,0,0.58,0.31,1.78,0.98,0.4,0.98,1.6,0.4,0,0.31,0,2.01,0.17,0,0,0.98,0.17,0,0,2.01,0.4,0.58,0.49,0,2.68,0.17,0,0,2.01,1.51,1.11,0.8,0,0.31,0.08,0.4,0,0,0,0,0,0.71,0,0.58,0.4,1.29,0.08,0.31,0,0,0,0.31,0,0,0.08,0.17,0.31,0.58,0,0,0,0.31,1.11,1.11,0.58,1.2,0.08,0.8,0.58,0.08,0.4,0.08,0,0.31,0,0,0,0.31,0.17,0.98,0,0.8,0.08,0.17,0,0.4,0,0.31,0,0,0.31,0,0.49,0.17,0,0.08,0.31,0,0.89,0.4,0,0.98,0,0.08,0.08,0,0,2.41,0.4,0,1.11,1.6,0.4,0.31,0,0,1.51,0.58,0.98,0.08,0,0,0,0.08,0,0,0.17,0,0.08,1.29,0,0,1.11,0,0.4,0.4,0,0,1.2,0,0.49,0.89,0,0,0.31,0,0,0,0,0.08,1.29,1.11,0.49,0,0.31,0.08,0.98,0,0,0,0.58,0,0,0,0,1.2,0.17,0,0.8,0.8,0,0,1.69,0.58,0,0.08,0.17,0.89,0.08,0.98,0.49,0.49,0,1.38,0.31,0,0.08,0,1.11,1.6,1.2,0.8,0.98,0.49,0.31,0.08,0.17,1.69,0,0.31,0,0,0.08,0,0,2.27,0,0,0.8,0,0.08,0.08,0,0,0.71,0.17,0,0,0,0,1.11,0.31,0,0,0.31,0.31,0.58,1.11,0.08,0,0.4,0.8,0.58,0.31,1.78,1.29,0.08,0.58,0,0.58,0.31,0.49,0.08,0,0,0,2.41,0.58,0.31,0.08,0.58,1.2,0.98,0,0.31,0,0.08,1.2,0.08,0.31,0.08,1.51,0,0.4,0.17,0.08,0.98,0.8,0.58,0,0,0.08,0,0.08,1.38,0,0.71,0,0.08,0.49,0,0.4,0.17,0.08,0,0,1.11,0.31,0.49,0,0,0,0,0.31,0.17,0,0,0.08,0,0,0,0.71,0,0,0,0,0,0,0.08,0,0,0,0,0,0,0.71,0,0,0.08,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0.8,0.98,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0.31,0,0,0,0,0,0,0,0,0.31,0,0,0,0,0,0.58,0,1.29,0,0.08,0,0,0,0,0,0,0,0,0,0,1.69,0.17,0.89,0.4,0,1.11,0,0.8,0.58,0,0,1.51]
        Werde es wohl nach Konvertierung mal als "mph" probieren...
        Negalein SBorg 2 Replies Last reply Reply Quote 0
        • Negalein
          Negalein Global Moderator @SBorg last edited by
          @sborg sagte in [Linux Shell-Skript] WLAN-Wetterstation:
          manchmal steht sogar eine ganze Zahl ohne dem g:y
          Kommt aber nur gaaaanz selten vor.
          • Rene55
            Rene55 last edited by
            @Negalein Hoppsa, hab ich da was verpasst? Ich hab ja gesehen, das SBorg eine Erweiterung für Windy vorgenommen hat. Ist ja auch eine tolle Seite. Wie krieg ich denn meine Station in Windy integriert? Gab es da was zu?
            • SBorg
              Als Beispiel aus der Doku: wind=2.8 (kommt mit meinen Werten ja hin, s.o.)
              lt Doku: wind - real number [m/s]; wind speed
              ...und die Umrechnung ist dann "unsere" xx km/h geteilt durch 3.6 = m/s
              Fehler sehe ich da keinen...
              @Rene55 steht ca. 10 Posts weiter oben bei der Ankündigung (oder siehe einfach updaten auf eine neue Version + bzgl. Windy dann in der Wiki 😉 )
              • SBorg
                SBorg Forum Testing Most Active @SBorg last edited by
                Oder auch nicht 🙃
                Die Anzeige bedeutet wohl Windgeschwindigkeit in m/s und Böen in m/s
                Eine Anzeige von bspw. 4 g:6 bedeutet also nichts weiter als Wind mit 4 m/s und Windböen ("g" für gust) mit 6 m/s
                • Rene55
                  @SBorg Danke für die schnelle Info. Auch Danke für das Script. Habe ich gestern eingespielt und läuft. Hab mir auch bei Windy einen Account geholt, Daten im .conf angepasst. Nur -blöde Frage- wie sehe ich meine Station in/auf Windy?
                  • SBorg
                    SBorg Forum Testing Most Active @Rene55 last edited by
                    @rene55 Nach ? Stunden nach Start gebe ich bei der Suche meinen Wohnort (so habe ich auch meine Station genannt) ein, dann erscheint als Treffer mein Wohnort und eine "Wx station" mit der ID-Nummer meiner Station:
                    • Rene55
                      @SBorg Ja, sowas hab ich gesucht. Bin eigentlich seit gestern (auch etwa so um diese Zeit) mit Windy aktiv. Habs gerade mal so versucht - kommt aber noch nichts. Ich versuchs irgendwie weiter (english ist nicht so meine Stärke).
                        Protheus last edited by
                        @SBorg
                        in Deinem Grafana Dashboard (was ich sehr geil finde und auch umgesetzt habe) ist ein kleiner Fehler.
                        "Letzter Regen" steht in der Source noch auf "Testvalue" oder sowas. Da kamen immer Zufallswerte aber nicht der Text "Vor 21 Stunden".
                        Habs mal angepasst bei mir:
                        So passt es jetzt 🙂
                        Vielen Dank für Deine Super Arbeit.
                        Viele Grüße
                        Protheus
                        • da_Woody
                          da_Woody last edited by
                          @protheus dann musst du ein älteres dash haben, bei mir passt das...
                          hat gerade geschüttet... 😄
                            Protheus @da_Woody last edited by
                            @da_woody sagte in [Linux Shell-Skript] WLAN-Wetterstation:
                            Nope.
                            Hatte ich gestern, ne halbe Stunde vor meinem Post heruntergeladen von Github.
                            Ist aber auch nicht ausgeschlossen, dass beim Import was falsch lief (aber alles andere wurde ja korrekt angezeigt)
                            Viele Grüße
                            Protheus
                            • da_Woody
                              da_Woody @Protheus last edited by
                              @protheus sültsam... aber es gibt ja mehrere dashs, da du nur den eintrag zeigst... vllt haben wir verschiedene dashs
                                Vermutlich nicht 🙂
                                I ch habe das komplette Dashboard so übernommen
                                Allerdings habe ich auch das Problem das das Hintergrundbild nicht kommt. (Ja, Plugin ist installiert und neu gestartet)
                                Ich stecke auch nich so tief in Grafana drin.
                                Viele Grüße
                                Protheus
                                • da_Woody
                                  @protheus hmm, ist im prinzip das selbe, bis auf die sonnenschein dauer...
                                  und du hast rechts von luftdruck noch 2x No Data, die hab ich rausgeschmissen. war glaub ich was mit update....
                                  am letzten regen hab ich allerdings nicht geschraubt... HG hab ich auch keinen. dazu bräuchts das pic und das an der richtigen stelle, denk ich mal...
                                    Die No Data habe ich mir angeschaut...das ist ein Indikator für Kommunikationsfehler
                                    Allerdings sind die Pfade/Namen falsch (Kommunikationsfehler muss ein Unterstrich davor und FW_Update liegt unter Info)
                                    Dann passts auch (Hab noch ne Bezeichnung dazu gemacht):
                                    Ich dachte das HG kommt durch daswetter oder wunderground, hab aber keine ahnung wie ich das einstelle.
                                    Viele Grüße
                                    Protheus
                                    Negalein da_Woody 2 Replies Last reply Reply Quote 0
                                    • Negalein
                                      Negalein Global Moderator @Protheus last edited by
                                      @protheus sagte in [Linux Shell-Skript] WLAN-Wetterstation:
                                      da musst du Boom Theme installieren.
                                      Näheres ist im Beitrag von @crunchip erklärt.
                                      da_Woody P 2 Replies Last reply Reply Quote 0
                                      • da_Woody
                                        @protheus ah, guter tip! schau ich mir bei gelegenheit mal an.
                                        jo, das mit dem HG hab ich auch nicht behirnt... 😞
                                        • Negalein
                                          Negalein Global Moderator @da_Woody last edited by
                                          war gerade am schreiben. Kuckst du eins drüber 😉
                                          • da_Woody
                                            da_Woody @Negalein last edited by da_Woody
                                            is ja installiert...
                                            ah, i c, muss da wirklich nochmal drüber...
                                            1.0k
                                            152
                                            5661
                                            3781436
