    4. (gelöst)USV
    (gelöst)USV
    • ostseereiter
      ostseereiter @Homoran last edited by
      @homoran sagte in USV:
      wo hast du denn das maxretry eingegeben?
      garnicht
        Homoran Global Moderator Administrators @ostseereiter last edited by
        @ostseereiter sagte in USV:
        garnicht
        steht außer der drei Zeilen nichts sonstiges in der conf?
        ostseereiter 1 Reply Last reply Reply Quote 0
        • ostseereiter
          ja
          # The section header ([upsname]) can be just about anything as long as
          # it is a single word inside brackets.  upsd uses this to uniquely
          # identify a UPS on this system.
          # If you have a UPS called snoopy, your section header would be "[snoopy]".
          # On a system called "doghouse", the line in your upsmon.conf to monitor
          # it would look something like this:
          #       MONITOR snoopy@doghouse 1 upsmonuser mypassword master
          # It might look like this if monitoring in slave mode:
          #       MONITOR snoopy@doghouse 1 upsmonuser mypassword slave
          # Configuration directives
          # These directives are used by upsdrvctl only and should be specified outside
          # of a driver definition:
          #    maxretry: Optional.  Specify the number of attempts to start the driver(s),
          #              in case of failure, before giving up. A delay of 'retrydelay' is
          #              inserted between each attempt. Caution should be taken when using
          #              this option, since it can impact the time taken by your system to
          #              start.
          #              The default is 1 attempt.
          #  retrydelay: Optional.  Specify the delay between each restart attempt of the
          #              driver(s), as specified by 'maxretry'. Caution should be taken
          #              when using this option, since it can impact the time taken by your
          #              system to start.
          #              The default is 5 seconds.
          # These directives are common to all drivers that support ups.conf:
          #  driver: REQUIRED.  Specify the program to run to talk to this UPS.
          #          apcsmart, bestups, and sec are some examples.
          #              start.
          #              system to start.
          #    port: REQUIRED.  The serial port where your UPS is connected.
          #          /dev/ttyS0 is usually the first port on Linux boxes, for example.
          # sdorder: optional.  When you have multiple UPSes on your system, you
          #          usually need to turn them off in a certain order.  upsdrvctl
          #          shuts down all the 0s, then the 1s, 2s, and so on.  To exclude
          #          a UPS from the shutdown sequence, set this to -1.
          #          The default value for this parameter is 0.
          #  nolock: optional, and not recommended for use in this file.
          #          If you put nolock in here, the driver will not lock the
          #          serial port every time it starts.  This may allow other
          #          processes to seize the port if you start more than one by
          #          mistake.
          #          This is only intended to be used on systems where locking
          #          absolutely must be disabled for the software to work.
          # maxstartdelay: optional.  This can be set as a global variable
          #                above your first UPS definition and it can also be
          #                set in a UPS section.  This value controls how long
          #          mistake.
          #                upsdrvctl will wait for the driver to finish starting.
          #                This keeps your system from getting stuck due to a
          #                broken driver or UPS.
          #                The default is 45 seconds.
          # synchronous: optional.  The driver work by default in asynchronous
          #              mode (i.e *synchronous=no*).  This means that all data
          #              are pushed by the driver on the communication socket to
          #              upsd (Unix socket on Unix, Named pipe on Windows) without
          #              waiting for these data to be actually consumed.  With
          #              some HW, such as ePDUs, that can produce a lot of data,
          #              asynchronous mode may cause some congestion, resulting in
          #              the socket to be full, and the driver to appear as not
          #              connected.  By enabling the 'synchronous' flag
          #              (value = 'yes'), the driver will wait for data to be
          #              consumed by upsd, prior to publishing more.  This can be
          #              enabled either globally or per driver.
          #              The default is 'no' (i.e. asynchronous mode) for backward
          #              compatibility of the driver behavior.
          # Anything else is passed through to the hardware-specific part of
          # the driver.
          # Examples
          # A simple example for a UPS called "powerpal" that uses the blazer_ser
          # driver on /dev/ttyS0 is:
          # [powerpal]
          #       driver = blazer_ser
          #       port = /dev/ttyS0
          #       desc = "Web server"
          # If your UPS driver requires additional settings, you can specify them
          # here.  For example, if it supports a setting of "1234" for the
          # variable "cable", it would look like this:
          # [myups]
          #       driver = mydriver
          #       port = /dev/ttyS1
          #       cable = 1234
          #       desc = "Something descriptive"
           the driver.
          # Examples
          # [powerpal]
          #       port = /dev/ttyS0
          # [myups]
          #       driver = mydriver
          #       port = /dev/ttyS1
          #       cable = 1234
          # To find out if your driver supports any extra settings, start it with
          # the -h option and/or read the driver's documentation.
          # Set maxretry to 3 by default, this should mitigate race with slow devices:
          maxretry = 3
            Homoran Global Moderator Administrators @ostseereiter last edited by Homoran
            maxretry = 3
            und wo ist da deine Konfig?
            oder wo kommt der code jetzt her?
            • ostseereiter
              Hier die komplette Config:
              # Network UPS Tools: example ups.conf
              # --- SECURITY NOTE ---
              # If you use snmp-ups and set a community string in here, you
              # will have to secure this file to keep other users from obtaining
              # that string.  It needs to be readable by upsdrvctl and any drivers,
              # and by upsd.
              # This is where you configure all the UPSes that this system will be
              # monitoring directly.  These are usually attached to serial ports, but
              # USB devices and SNMP devices are also supported.
              # This file is used by upsdrvctl to start and stop your driver(s), and
              # is also used by upsd to determine which drivers to monitor.  The
              # drivers themselves also read this file for configuration directives.
              # The general form is:
               [serverups]
                     driver = usbhid-ups
                       port = auto
                      desc = "Eeaton UPS"
              #              start.
              #              system to start.
              #              system to start.
              #          mistake.
              #          mistake.
              # the driver.
              # Examples
              # [powerpal]
              # the driver.
              # Examples
              # [powerpal]
              #       port = /dev/ttyS0
              # [myups]
              #       driver = mydriver
              #       port = /dev/ttyS1
              #       cable = 1234
              maxretry = 3
                endlich!
                Ob das korrekt ist mitten in der Anleitung die # zu entfernen und das als Config zu nehmen weiß ich nicht.
                Ansonsten würde ich zum testen jetzt einfach die Zeile mit den maxretry auskommentieren.
                EDIT:
                das Problem wird die Zeile vor maxretry sein. Die war doch eben noch auskommentiert, oder?
                Dort unbedingt ein # vorsetzen sonst ist das ein (ungültiger) Befehl -> set maxretry....
                • ostseereiter
                  habe ich auskommentiert jetzt sieht es so aus: das ist schon mal besser
                  andy@debian:~$ sudo nano /etc/nut/ups.conf
                  andy@debian:~$ sudo upsdrvctl start
                  Network UPS Tools - UPS driver controller 2.7.4
                  Network UPS Tools - Generic HID driver 0.41 (2.7.4)
                  USB communication driver 0.33
                  Using subdriver: MGE HID 1.39
                  andy@debian:~$
                    was?
                    • den Kommentar?
                    • den Wert?
                    • beides?
                    • ostseereiter
                      dies hier
                      # maxretry = 3
                        dies hier
                        dann nimm das zweite vor maxretry=3 wieder weg
                        ja, dann weiter im Text!
                        aber bitte wirklich
                        1:1 übernommen
                        Wir müssen uns darauf verlassen könne, wenn du so etwas sagst, dass du nicht an anderen Stellen alles verstellt hast
                        • ostseereiter
                          ja wenn ich den Gartenzaun wieder wegnehme dann kommt wieder die Fehlermeldung:
                          Fatal error: 'maxretry' is not a valid variable name for this driver.
                          Look in the man page or call this driver with -h for a list of
                          valid variable names and flags.
                          Ich lese auch eure Beiträge zwei mal bevor ich was mache
                          • ostseereiter
                            ostseereiter @ostseereiter last edited by
                            Das maxretry' muss aus kommentiert werden.
                            • ostseereiter
                              als nächstes habe ich das eingestellt:
                              # IMPORTANT NOTE:
                              #  This file is intended to be sourced by shell scripts.
                              #  You MUST NOT use spaces around the equal sign!
                              MODE=netserver
                              • ostseereiter
                                nun kommt der Zugriff unter sudo nano /etc/nut/upsd.conf
                                da ja auch Clients zufgreifen sollen,soll man dort LISTEN 0.0.0.0 eintragen.
                                Nun stehe ich wieder wie der Ochse vor dem Scheunentor. wo hier?
                                # STATEPATH <path>
                                # STATEPATH /var/run/nut
                                # Tell upsd to look for the driver state sockets in 'path' rather
                                # than the default that was compiled into the program.
                                # LISTEN <address> [<port>]
                                # LISTEN 127.0.0.1 3493
                                # LISTEN ::1 3493
                                # This defaults to the localhost listening addresses and port 3493.
                                # In case of IP v4 or v6 disabled kernel, only the available one will be used.
                                # You may specify each interface
                                  ich möchte dir nochmals den Thread von @klassisch ans Herz legen (wenigstens parallel lesen!).
                                  https://forum.iobroker.net/topic/23688/howto-usv-nut-server-auf-sbc-installieren?_=1621345610029
                                  der macht nämlich vorher noch einen test:
                                  Eintragen:
                                  MODE=netserver
                                  Danach den Dienst starten:
                                  sudo upsd
                                  Wenn alles funktioniert hat, kann man jetzt Daten ausgeben:
                                  sudo upsc ups@localhost
                                  Hier muss eine sinnvolle Liste gelistet werden:
                                  Erst dann wird die /etc/nut/upsd.conf editiert und die IPs eingegeben.
                                  0.0.0.0 macht alles auf....
                                  • ostseereiter
                                    ok ich lese erst mal melde mich wieder.
                                    • ostseereiter
                                      beim ersten Befehl sudo upsd kommt
                                      Network UPS Tools upsd 2.7.4
                                      Fatal error: A previous upsd instance is already running!
                                      Either stop the previous instance first, or use the 'reload' command.
                                      beim zweiten Befehl: sudo upsc ups@localhost kommt dies
                                      andy@debian:~$ sudo upsc ups@localhost
                                      Init SSL without certificate database
                                      Error: Unknown UPS
                                      andy@debian:~$
                                        klar du hast ja schon gestartet
                                        aber du hast alles an deine Bezeichnungen angepasst?
                                        EDIT:
                                        eher nicht:
                                        Error: Unknown UPS
                                        heisst deine nicht serverups?
                                        • ostseereiter
                                          ja so heißt sie
                                          • ostseereiter
                                            reagieren tut der server schon.
                                            andy@debian:~$ sudo upsd -c stop
                                            fopen /var/run/nut/upsd.pid: No such file or directory
                                            listening on 127.0.0.1 port 3493
                                            listening on ::1 port 3493
                                            Connected to UPS [serverups]: usbhid-ups-serverups
                                            11314
