    4. (gelöst)USV
    (gelöst)USV
    • ostseereiter
      ostseereiter last edited by
      So hier nochmal die einzelnen Schritte.
      In der sudo nano /etc/nut/ups.conf
      habe ich das eingetragen außer den pollinterval nicht.
      # The general form is:
       [serverups]
             driver = usbhid-ups
               port = auto
              desc = "Eeaton UPS"
      # The section header ([upsname]) can be just about anything as long as
      # it is a single word inside brackets.  upsd uses this to uniquely
      # identify a UPS on this system.
      in der sudo nano /etc/nut/nut.conf das
      # IMPORTANT NOTE:
      #  This file is intended to be sourced by shell scripts.
      #  You MUST NOT use spaces around the equal sign!
      MODE=netserver
      nun kommt sudo nano /etc/nut/upsd.conf da habe ich das drin
      # you can specify if upsd requests or requires client's' certificates.
      # Possible values are :
      #  - 0 to not request to clients to provide any certificate
      #  - 1 to require to all clients a certificate
      #  - 2 to require to all clients a valid certificate
      # See 'docs/security.txt' or the Security chapter of NUT user manual
      # for more information on the SSL support in NUT.
      LISTEN 127.0.0.1 3493
      LISTEN 192.168.178.109 3493
      nun die Benutzerkonten ich nehme gleich den 3 raus.sudo nano /etc/nut/upsd.users
      # MONITOR myups@localhost 1 upsmon pass master  (or slave)
      [upsmaster]
       password = test
       actions = SET
       instcmds = ALL
       upsmon master
      [raspiuser]
       password = secret
       upsmon slave
      in der sudo nano /etc/systemd/system/multi-user.target.wants/nut-server.service steht das:
      Wants=nut-driver.service
      Before=nut-monitor.service
      [Service]
      ExecStartPre=/bin/sleep 30
      ExecStart=/sbin/upsd
      Type=forking
      [Install]
      WantedBy=multi-user.target
      Jetzt das Monitoring sudo nano /etc/nut/upsmon.conf
      da habe ich diese Zeile hinzugefügt:
      MONITOR serverups@localhost 1 upsmaster test master
      Dann habe ich den dienst neugestartet mit sudo systemctl restart nut-server
      mit
      andy@debian:~$ sudo systemctl restart nut-server
      Dann kam dieses bei raus
      Warning: The unit file, source configuration file or drop-ins of nut-server.service changed on disk. Run 'systemctl daemon-reload' to reload units.
      Job for nut-server.service failed because the control process exited with error code.
      See "systemctl status nut-server.service" and "journalctl -xe" for details.
      Nun sollte der Server eingerichtet sein
      Jetzt gehen wir zu den Client der Raspi
      dort habe ich erst mal installiert mit sudo apt install nut-client
      jetzt editiert mit sudo nano /etc/nut/nut.conf
      dort steht drin
      # - netserver: same as for the standalone configuration, but also need
      #   some more network access controls (firewall, tcp-wrappers) and possibly a
      #   specific LISTEN directive in upsd.conf.
      #   Since this MODE is opened to the network, a special care should be applied
      #   to security concerns.
      # - netclient: this mode only requires upsmon.
      # IMPORTANT NOTE:
      MODE=netclient
      jetzt diese Datei sudo nano /etc/nut/upsmon.conf
      When compiled with SSL, specify that a secured connection must be used
      # to communicate with upsd.
      # If you don't use 'CERTVERIFY 1', then this will at least make sure
      # that nobody can sniff your sessions without a large effort.  Setting
      # this will make upsmon drop connections if the remote upsd doesn't
      # support SSL, so don't use it unless all of them have it running.
      # When compiled with NSS support of SSL, can be overriden for host
      # specified with a CERTHOST directive.
      MONITOR serverups@192.168.178.109 1 raspiuser testslave
      nun den Clientserver neu starten mit sudo systemctl restart nut-client
      jetzt kommt diese Ausgabe.
      pi@SVPi-hole:~ $ sudo systemctl restart nut-client
      Broadcast message from nut@SVPi-hole (somewhere) (Fri May 21 11:03:50 2021):
      Communications with UPS serverups@192.168.178.109 lost
      Broadcast message from nut@SVPi-hole (somewhere) (Fri May 21 11:03:55 2021):
      UPS serverups@192.168.178.109 is unavailable
      und nach einer gewissen Zeit diese Ausgabe
      pi@SVPi-hole:~ $ ^C
      Broadcast message from nut@SVPi-hole (somewhere) (Fri May 21 11:09:00 2021):
      Homoran crunchip 3 Replies Last reply Reply Quote 0
        Homoran Global Moderator Administrators @ostseereiter last edited by
        @ostseereiter sagte in USV:
        Beim Server oder bei den Clients?
        ostseereiter 1 Reply Last reply Reply Quote 0
          aber das davor hast du schon gelesen?
          Warning: The unit file, source configuration file or drop-ins of nut-server.service changed on disk. Run 'systemctl daemon-reload' to reload units. Job for nut-server.service failed because the control process exited with error code. See "systemctl status nut-server.service" and "journalctl -xe" for details.
          und behoben?
          wohl eher nicht!
          denn der Controller schgeint weiter nicht erreichbar zu sein
          • ostseereiter
            ostseereiter @Homoran last edited by
            im Server
              Thomas Braun Most Active @ostseereiter last edited by
              @ostseereiter
              Ich lese da wieder pihole. Muss da ggf. auch noch was eingestellt werden?
              • ostseereiter
                @homoran sagte in USV:
                und behoben?
                wohl eher nicht!
                jetzt habe ich versucht das zu beheben.
                andy@debian:~$ sudo systemctl daemon-reload
                [sudo] Passwort für andy:
                andy@debian:~$ ^C
                andy@debian:~$ sudo systemctl status nut-server.service
                ● nut-server.service - Network UPS Tools - power devices information server
                   Loaded: loaded (/lib/systemd/system/nut-server.service; enabled; vendor prese
                   Active: failed (Result: exit-code) since Fri 2021-05-21 12:11:20 CEST; 45s ag
                  Process: 1409 ExecStartPre=/bin/sleep 30 (code=exited, status=0/SUCCESS)
                  Process: 2130 ExecStart=/sbin/upsd (code=exited, status=1/FAILURE)
                Mai 21 12:10:50 debian systemd[1]: Starting Network UPS Tools - power devices in
                Mai 21 12:11:20 debian upsd[2130]: Network UPS Tools upsd 2.7.4
                Mai 21 12:11:20 debian upsd[2130]: Fatal error: A previous upsd instance is alre
                Mai 21 12:11:20 debian upsd[2130]: Either stop the previous instance first, or u
                Mai 21 12:11:20 debian systemd[1]: nut-server.service: Control process exited, c
                Mai 21 12:11:20 debian systemd[1]: nut-server.service: Failed with result 'exit-
                Mai 21 12:11:20 debian systemd[1]: Failed to start Network UPS Tools - power dev
                lines 1-13/13 (END)...skipping...
                   Loaded: loaded (/lib/systemd/system/nut-server.service; enabled; vendor preset: enabled)
                   Active: failed (Result: exit-code) since Fri 2021-05-21 12:11:20 CEST; 45s ago
                Mai 21 12:10:50 debian systemd[1]: Starting Network UPS Tools - power devices information server...
                Mai 21 12:11:20 debian upsd[2130]: Fatal error: A previous upsd instance is already running!
                Mai 21 12:11:20 debian upsd[2130]: Either stop the previous instance first, or use the 'reload' command.
                Mai 21 12:11:20 debian systemd[1]: nut-server.service: Control process exited, code=exited, status=1/FAILURE
                Mai 21 12:11:20 debian systemd[1]: nut-server.service: Failed with result 'exit-code'.
                Mai 21 12:11:20 debian systemd[1]: Failed to start Network UPS Tools - power devices information server.
                lines 1-13/13 (END)
                lines 1-13/13 (END)
                Homoran BBTown 2 Replies Last reply Reply Quote 0
                  entscheidend ist vielmehr die Frage was du gemacht hast bevor/so dass es zu dieser Fehlermeldung kam:
                  was hast du da im System verstellt?
                  • ostseereiter
                    eigentlich nichts
                      @ostseereiter
                      Da läuft schon ein daemon.
                        crunchip Forum Testing Most Active @ostseereiter last edited by
                        [raspiuser]
                        password = secret
                        upsmon slave
                        nano /etc/nut/upsmon.conf, der Eintrag ist ebenfalls falsch
                        du bekommst deinen service nicht zum laufen, hatte ich damals auch diese Meldung, als ich beim ersten mal die config falsch eingestellt hatte. Selbst als die Config dann richtig war, kam diese Meldung.
                        Lösung war bei mir letztendlich, das ich den (Nut- server und nut - client) nochmal de/installiert habe, anschliessend die config der Reihe nach eingestellt habe und lief dann.
                        • ostseereiter
                          ostseereiter @Thomas Braun last edited by
                          ja und das heißt ? Ich bin total überfordert im moment.Nicht böse sein wegen meiner Dummheit
                          • ostseereiter
                            ostseereiter @ostseereiter last edited by
                            @ostseereiter
                            andy@debian:~$ sudo upsd
                            fopen /var/run/nut/upsd.pid: No such file or directory
                            listening on 192.168.178.109 port 3493
                            listening on 127.0.0.1 port 3493
                            Can't connect to UPS [serverups] (usbhid-ups-serverups): No such file or directory
                            andy@debian:~$
                            • BBTown
                              BBTown @ostseereiter last edited by
                              @ostseereiter
                              gehört dort nicht ein Leerzeichen rein?
                                crunchip Forum Testing Most Active @BBTown last edited by
                                @bbtown deswegen schrieb ich, dieser Eintrag ist falsch, zum einen ein Leerzeichen und zum anderen muss das passwort übereinstimmen, zumal ich keine Ahnung hab ob er das secret bzw test wirklich so eingetragen hat.
                                  crunchip Forum Testing Most Active @ostseereiter last edited by crunchip
                                  @ostseereiter keine Ahnung wo du etwas veraemmelt hast, ich rate dir, wie bereits geschrieben, deinstalliere nochmal incl, config
                                  Und installiere dann neu, dann ist deine config wieder default und du kannst von neu nach Anleitung ansetzen, alles andere zieht sich nur ewig in die Länge
                                  sudo apt-get purge --auto-remove nut
                                  Danach nochmal nach Anleitung
                                  • ostseereiter
                                    ostseereiter @crunchip last edited by ostseereiter
                                    @crunchip sagte in USV:
                                    andy@debian:~$ sudo apt-get purge --auto-remove nut
                                    Paket »nut« ist nicht installiert, wird also auch nicht entfernt.
                                    0 aktualisiert, 0 neu installiert, 0 zu entfernen und 1 nicht aktualisiert.
                                    andy@debian:~$
                                    das kommt dabei raus. jetzt habe ich bestimmt irgendwo was versaut wenn es sich nicht deinstallieren lässt
                                    Thomas Braun Meister Mopper 2 Replies Last reply Reply Quote 0
                                      Thomas Braun Most Active @ostseereiter last edited by Thomas Braun
                                      @ostseereiter
                                      Die Pakete heißen auch anders, wenn mich nicht alles täuscht.
                                      nut-server und nut-client vielleicht?
                                      TabCompletion macht dich schlauer, bzw. solltest du ja noch wissen was du da gestern installiert hast.
                                        @thomas-braun sagte in USV:
                                        @ostseereiter
                                        Mit welchem Befehl hast du es denn installiert?
                                        sudo apt install nut usbutils?????
                                        • Meister Mopper
                                          Meister Mopper @ostseereiter last edited by
                                          @ostseereiter Installiert wird mit sudo apt-get install nut-client nut-server usbutils
                                          • ostseereiter
                                            nein mit
                                            sudo apt install nut-server
                                            11314
