    4. (gelöst)USV
    (gelöst)USV
      Thomas Braun Most Active @ostseereiter last edited by
      @ostseereiter
      Ich lese da wieder pihole. Muss da ggf. auch noch was eingestellt werden?
      • ostseereiter
        ostseereiter @Homoran last edited by
        @homoran sagte in USV:
        Warning: The unit file, source configuration file or drop-ins of nut-server.service changed on disk. Run 'systemctl daemon-reload' to reload units. Job for nut-server.service failed because the control process exited with error code. See "systemctl status nut-server.service" and "journalctl -xe" for details.
        und behoben?
        wohl eher nicht!
        denn der Controller schgeint weiter nicht erreichbar zu sein
        @ostseereiter sagte in USV:
        jetzt habe ich versucht das zu beheben.
        andy@debian:~$ sudo systemctl daemon-reload
        [sudo] Passwort für andy:
        andy@debian:~$ sudo systemctl restart nut-server
        andy@debian:~$ ^C
        andy@debian:~$ sudo systemctl status nut-server.service
        ● nut-server.service - Network UPS Tools - power devices information server
           Loaded: loaded (/lib/systemd/system/nut-server.service; enabled; vendor prese
           Active: failed (Result: exit-code) since Fri 2021-05-21 12:11:20 CEST; 45s ag
          Process: 1409 ExecStartPre=/bin/sleep 30 (code=exited, status=0/SUCCESS)
          Process: 2130 ExecStart=/sbin/upsd (code=exited, status=1/FAILURE)
        Mai 21 12:10:50 debian systemd[1]: Starting Network UPS Tools - power devices in
        Mai 21 12:11:20 debian upsd[2130]: Network UPS Tools upsd 2.7.4
        Mai 21 12:11:20 debian upsd[2130]: Fatal error: A previous upsd instance is alre
        Mai 21 12:11:20 debian upsd[2130]: Either stop the previous instance first, or u
        Mai 21 12:11:20 debian systemd[1]: nut-server.service: Control process exited, c
        Mai 21 12:11:20 debian systemd[1]: nut-server.service: Failed with result 'exit-
        Mai 21 12:11:20 debian systemd[1]: Failed to start Network UPS Tools - power dev
        lines 1-13/13 (END)...skipping...
           Loaded: loaded (/lib/systemd/system/nut-server.service; enabled; vendor preset: enabled)
           Active: failed (Result: exit-code) since Fri 2021-05-21 12:11:20 CEST; 45s ago
        Mai 21 12:10:50 debian systemd[1]: Starting Network UPS Tools - power devices information server...
        Mai 21 12:11:20 debian upsd[2130]: Fatal error: A previous upsd instance is already running!
        Mai 21 12:11:20 debian upsd[2130]: Either stop the previous instance first, or use the 'reload' command.
        Mai 21 12:11:20 debian systemd[1]: nut-server.service: Control process exited, code=exited, status=1/FAILURE
        Mai 21 12:11:20 debian systemd[1]: nut-server.service: Failed with result 'exit-code'.
        Mai 21 12:11:20 debian systemd[1]: Failed to start Network UPS Tools - power devices information server.
        lines 1-13/13 (END)
        lines 1-13/13 (END)
        Homoran BBTown 2 Replies Last reply Reply Quote 0
          Homoran Global Moderator Administrators @ostseereiter last edited by
          entscheidend ist vielmehr die Frage was du gemacht hast bevor/so dass es zu dieser Fehlermeldung kam:
          was hast du da im System verstellt?
          ostseereiter 1 Reply Last reply Reply Quote 0
          • ostseereiter
            eigentlich nichts
              @ostseereiter
              Da läuft schon ein daemon.
                crunchip Forum Testing Most Active @ostseereiter last edited by
                [raspiuser]
                password = secret
                upsmon slave
                nano /etc/nut/upsmon.conf, der Eintrag ist ebenfalls falsch
                MONITOR serverups@192.168.178.109 1 raspiuser testslave
                du bekommst deinen service nicht zum laufen, hatte ich damals auch diese Meldung, als ich beim ersten mal die config falsch eingestellt hatte. Selbst als die Config dann richtig war, kam diese Meldung.
                Lösung war bei mir letztendlich, das ich den (Nut- server und nut - client) nochmal de/installiert habe, anschliessend die config der Reihe nach eingestellt habe und lief dann.
                • ostseereiter
                  ostseereiter @Thomas Braun last edited by
                  ja und das heißt ? Ich bin total überfordert im moment.Nicht böse sein wegen meiner Dummheit
                  • ostseereiter
                    ostseereiter @ostseereiter last edited by
                    @ostseereiter
                    andy@debian:~$ sudo upsd
                    fopen /var/run/nut/upsd.pid: No such file or directory
                    listening on 192.168.178.109 port 3493
                    listening on 127.0.0.1 port 3493
                    Can't connect to UPS [serverups] (usbhid-ups-serverups): No such file or directory
                    andy@debian:~$
                    • BBTown
                      BBTown @ostseereiter last edited by
                      @ostseereiter
                      gehört dort nicht ein Leerzeichen rein?
                        crunchip Forum Testing Most Active @BBTown last edited by
                        @bbtown deswegen schrieb ich, dieser Eintrag ist falsch, zum einen ein Leerzeichen und zum anderen muss das passwort übereinstimmen, zumal ich keine Ahnung hab ob er das secret bzw test wirklich so eingetragen hat.
                          crunchip Forum Testing Most Active @ostseereiter last edited by crunchip
                          @ostseereiter keine Ahnung wo du etwas veraemmelt hast, ich rate dir, wie bereits geschrieben, deinstalliere nochmal incl, config
                          Und installiere dann neu, dann ist deine config wieder default und du kannst von neu nach Anleitung ansetzen, alles andere zieht sich nur ewig in die Länge
                          sudo apt-get purge --auto-remove nut
                          Danach nochmal nach Anleitung
                          • ostseereiter
                            ostseereiter @crunchip last edited by ostseereiter
                            @crunchip sagte in USV:
                            andy@debian:~$ sudo apt-get purge --auto-remove nut
                            Paket »nut« ist nicht installiert, wird also auch nicht entfernt.
                            0 aktualisiert, 0 neu installiert, 0 zu entfernen und 1 nicht aktualisiert.
                            andy@debian:~$
                            das kommt dabei raus. jetzt habe ich bestimmt irgendwo was versaut wenn es sich nicht deinstallieren lässt
                            Thomas Braun Meister Mopper 2 Replies Last reply Reply Quote 0
                              Thomas Braun Most Active @ostseereiter last edited by Thomas Braun
                              @ostseereiter
                              Die Pakete heißen auch anders, wenn mich nicht alles täuscht.
                              nut-server und nut-client vielleicht?
                              TabCompletion macht dich schlauer, bzw. solltest du ja noch wissen was du da gestern installiert hast.
                                @thomas-braun sagte in USV:
                                @ostseereiter
                                Mit welchem Befehl hast du es denn installiert?
                                sudo apt install nut usbutils?????
                                • Meister Mopper
                                  Meister Mopper @ostseereiter last edited by
                                  @ostseereiter Installiert wird mit sudo apt-get install nut-client nut-server usbutils
                                  • ostseereiter
                                    nein mit
                                    sudo apt install nut-server
                                      @ostseereiter
                                      Dann musst du die Rolle rückwärts (deinstallieren) auch mit dem Paketnamen vornehmen.
                                      Woher soll die Kiste auch wissen das du mit 'nut' den nut-server meinst?
                                      (Jaaaaaaa, es gibt Meta-Pakete... Weiß ich auch...)
                                      • ostseereiter
                                        ostseereiter @Thomas Braun last edited by ostseereiter
                                        habe jetzt das deinstalliert
                                        andy@debian:~$ sudo apt-get purge --auto-remove nut-server
                                        Die folgenden Pakete werden ENTFERNT:
                                          nut-server*
                                        0 aktualisiert, 0 neu installiert, 1 zu entfernen und 1 nicht aktualisiert.
                                        Nach dieser Operation werden 5.062 kB Plattenplatz freigegeben.
                                        Möchten Sie fortfahren? [J/n] j
                                        (Lese Datenbank ... 51406 Dateien und Verzeichnisse sind derzeit installiert.)
                                        Entfernen von nut-server (2.7.4-8) ...
                                        Failed to stop nut.service: Unit nut.service not loaded.
                                        invoke-rc.d: initscript nut, action "stop" failed.
                                        Trigger für man-db (2.8.5-2) werden verarbeitet ...
                                        (Lese Datenbank ... 51282 Dateien und Verzeichnisse sind derzeit installiert.)
                                        Löschen der Konfigurationsdateien von nut-server (2.7.4-8) ...
                                        Trigger für systemd (241-7~deb10u7) werden verarbeitet ...
                                        das sieht doch schon mal anders aus
                                          Homoran Global Moderator Administrators @Meister Mopper last edited by
                                          @meister-mopper sagte in USV:
                                          sicher?
                                          ich habe mich damals nach der Anleitung von @klassisch langgehangelt. da wurde es (anschließend funktionierend!!) mit dem eben von mir geposteten Befehl installiert.
                                          • ostseereiter
                                            nun habe ich ja mehrere Vorschläge wie soll ich nun wieder installieren mit
                                            11314
