    4. Test Adapter luxtronik2 v0.4.x
      lessthanmore @UncleSam last edited by lessthanmore
      @unclesam
      erst einmal vielen Dank für den Adapter. Ich bekomme die Leistung meiner Novelan nun über den Adapter + SAE in meinem SMA Sunny Home Manager 2.0 angezeigt.
      Allerdings häufen sich bei mir die Fehler im Log zum Adapter.
      luxtronik2.0	2021-05-19 15:26:08.388	info	(15703) Connecting to xxxx:8889
      luxtronik2.0	2021-05-19 15:26:07.148	info	(15703) Connected to ws://xxxx:8214
      luxtronik2.0	2021-05-19 15:26:07.137	info	(15703) Connecting to ws://xxxx:8214
      luxtronik2.0	2021-05-19 15:26:07.033	info	(15703) starting. Version 0.2.0 in /opt/iobroker/node_modules/iobroker.luxtronik2, node: v12.22.1, js-controller: 3.2.16
      host.raspberrypi	2021-05-19 15:26:05.744	info	instance system.adapter.luxtronik2.0 started with pid 15703
      host.raspberrypi	2021-05-19 15:25:35.712	info	Restart adapter system.adapter.luxtronik2.0 because enabled
      host.raspberrypi	2021-05-19 15:25:35.711	info	instance system.adapter.luxtronik2.0 terminated with code 0 (NO_ERROR)
      luxtronik2.0	2021-05-19 15:25:35.148	info	(15672) Terminated (NO_ERROR): Without reason
      luxtronik2.0	2021-05-19 15:25:35.147	info	(15672) terminating
      luxtronik2.0	2021-05-19 15:25:35.137	warn	(15672) Restart initiated
      luxtronik2.0	2021-05-19 15:25:35.137	error	(15672) Didn't receive data from Lux port after 3 retries, restarting adapter
      Dieser Fehler wiederholt sich genau drei Mal und dann kommt der folgende:
      luxtronik2.0	2021-05-19 14:23:02.604	error	(15624) Exception-Code: ERR_OUT_OF_RANGE: The value of "offset" is out of range. It must be >= 0 and <= 4. Received 8
      luxtronik2.0	2021-05-19 14:23:02.603	error	at TCP.onStreamRead (internal/stream_base_commons.js:188:23)
      luxtronik2.0	2021-05-19 14:23:02.603	error	at Socket.Readable.push (_stream_readable.js:213:10)
      luxtronik2.0	2021-05-19 14:23:02.603	error	at readableAddChunk (_stream_readable.js:272:9)
      luxtronik2.0	2021-05-19 14:23:02.603	error	at addChunk (_stream_readable.js:297:12)
      luxtronik2.0	2021-05-19 14:23:02.603	error	at Socket.emit (events.js:314:20)
      luxtronik2.0	2021-05-19 14:23:02.603	error	at Luxtronik.<anonymous> (/opt/iobroker/node_modules/luxtronik2/luxtronik.js:480:41)
      luxtronik2.0	2021-05-19 14:23:02.603	error	at Buffer.readInt32BE (internal/buffer.js:478:5)
      luxtronik2.0	2021-05-19 14:23:02.603	error	at boundsError (internal/buffer.js:82:9)
      luxtronik2.0	2021-05-19 14:23:02.603	error	(15624) RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 4. Received 8
      luxtronik2.0	2021-05-19 14:23:02.603	error	(15624) uncaught exception: The value of "offset" is out of range. It must be >= 0 and <= 4. Received 8
      Mache ich etwas falsch? Leider bin ich technisch nicht so versiert, dass ich die Fehler bei github melden kann.
      Der Status des Adapters springt auch immer von grün, kurz auf rot und wieder zurück auf grün.
      So sieht meine Konfig aus:
      Kann es auch am Intervall liegen?
      Lieben Dank vorab und viele Grüße
      Michael
      //edit: Hab jetzt mal den Lux-Port entfernt und bislang sieht es sauber aus. Keine neuen Logs und die Leistung ist weiterhin da.
      UncleSam 1 Reply Last reply Reply Quote 0
      • UncleSam
        UncleSam Developer @lessthanmore last edited by
        @lessthanmore sagte in Test Adapter luxtronik2 v0.2.x:
        Ja, das hätte ich dir jetzt auch vorgeschlagen. Wenn du den Port entfernst, wird er diese Daten nicht mehr abfragen. Es kann sein, dass bei dir der Luxtronik Port anders ist als hier eingestellt (z.B. 8888). Dummerweise fällt mir gerade keine einfache Art ein, das rauszufinden.
          @unclesam said in Test Adapter luxtronik2 v0.2.x:
          Beim Port 8888 geht er direkt auf die Bretter:
          (23206) Luxtronik read error, will retry later: Error: connect ECONNREFUSED xxxx:8888
          • UncleSam
            @lessthanmore Dumme Frage (und auch etwas eine gefährliche): hast du mal die WP neu gestartet? Eventuell hängt bei dir die Applikation, die Port 8889 bedienen sollte. Und wenn das auch nicht hilft: dann halt wirklich den Port ausschalten. Sollte ja dann zumindest der WebSocket Teil einwandfrei gehen. Einige Einstellungen wirst du halt nicht machen können.
            L 4 Replies Last reply Reply Quote 0
              Hab sie gerade neugestartet, gleiches Ergebnis:
              host.raspberrypi	2021-05-20 18:46:43.619	error	instance system.adapter.luxtronik2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
              luxtronik2.0	2021-05-20 18:46:43.077	warn	(4467) Terminated (UNCAUGHT_EXCEPTION): Without reason
              luxtronik2.0	2021-05-20 18:46:43.076	info	(4467) terminating
              luxtronik2.0	2021-05-20 18:46:43.057	error	(4467) Exception-Code: ERR_OUT_OF_RANGE: The value of "offset" is out of range. It must be >= 0 and <= 4. Received 8
              luxtronik2.0	2021-05-20 18:46:43.057	error	at TCP.onStreamRead (internal/stream_base_commons.js:188:23)
              luxtronik2.0	2021-05-20 18:46:43.057	error	at Socket.Readable.push (_stream_readable.js:213:10)
              luxtronik2.0	2021-05-20 18:46:43.057	error	at readableAddChunk (_stream_readable.js:272:9)
              luxtronik2.0	2021-05-20 18:46:43.057	error	at addChunk (_stream_readable.js:297:12)
              luxtronik2.0	2021-05-20 18:46:43.057	error	at Socket.emit (events.js:314:20)
              luxtronik2.0	2021-05-20 18:46:43.057	error	at Luxtronik.<anonymous> (/opt/iobroker/node_modules/luxtronik2/luxtronik.js:480:41)
              luxtronik2.0	2021-05-20 18:46:43.057	error	at Buffer.readInt32BE (internal/buffer.js:478:5)
              luxtronik2.0	2021-05-20 18:46:43.057	error	at boundsError (internal/buffer.js:82:9)
              luxtronik2.0	2021-05-20 18:46:43.057	error	(4467) RangeError [ERR_OUT_OF_RANGE]: The value of "offset" is out of range. It must be >= 0 and <= 4. Received 8
              luxtronik2.0	2021-05-20 18:46:43.056	error	(4467) uncaught exception: The value of "offset" is out of range. It must be >= 0 and <= 4. Received 8
              Passt aber bei mir soweit. Da die WP eh nur bei Anforderung läuft, macht es bei mir keinen Sinn die Werte zu schreiben oder zu setzen. Will nur den Verbrauch im SHM 2.0 von SMA sehen und das funktioniert einwandfrei. Danke nochmal.
                @unclesam Mal noch ein kleines Update.
                Habe gerade rausgefunden, dass ich die Parameter lediglich über den luktronik Port schreiben kann. Das funktioniert auch ohne Probleme. Obwohl mein Log nun überläuft.
                Alles sehr merkwürdig.
                Evtl. ist die FW noch relevant: V3.82.5 (r3553).
                chrid88 1 Reply Last reply Reply Quote 0
                • chrid88
                  chrid88 @lessthanmore last edited by
                  @lessthanmore da ich nicht weiß wie/ob man hier private Nachrichten schreiben kann:
                  ich habe das gleiche Setup: WP mit Luxtronik und eine PV mit SMA SHM 2.0 und nen SAE.
                  Ich war bisher immer der Meinung, dass ich die WP nur einbinden kann, wenn ich denn Zähler an die WP angebunden habe (also entweder über S0, Modbus oder wie auch immer). Ich verstehe daher nicht ganz wie du das mit diesem Adapter löst?
                  Ihren eigenen Stromverbrauch kennt die WP doch nicht und hat diesen daher auch nicht als Wert abgelegt?
                  • chrid88
                    chrid88 @UncleSam last edited by
                    @unclesam kann ich die neue Version irgendwie drüber installieren? Oder geht nur alten Adapter löschen und dann neu installieren?
                      lessthanmore @chrid88 last edited by
                      @chrid88 said in Test Adapter luxtronik2 v0.2.x:
                      So sieht es momentan bei mir aus:
                      Ich habe den Luxtronik Adapter mit zwei Instanzen laufen, einmal über den websocket und einmal über den luxtronik Port. Vom ersten lese ich und auf den zweiten schreibe, auch wenn der ständig neugestartet wird wegen Fehlern.
                      Die WP gibt mir die aktuelle Leistung (also Verbrauch) über den Parameter luxtronik2.0.Informationen.Anlagenstatus.Leistung-Ist aus.
                      Zusätzlich habe ich den Adapter Smart Appliance Enabler laufen und bekomme somit die WP als Verbraucher im Sunny Home Manager 2.0 angezeigt.
                      Über SMA-EM bekomme ich die Werte vom SHM 2.0 in den ioBroker.
                      Mit Blocky habe ich mir die drei folgenden Skripte erstellt:
                      Soll-Temp der WP rauf:
                      Sobald also WW angefordert wird (Soll-Wert - Hysterese; bei mir im Standard 48° - 6.0 K) und dementsprechend der Betriebszustand sich ändert (1. Instanz vom luxtronik Adapter), prüfe ich, ob die PV Einspeisung größer 2000 ist. Ich versuche dann den Wert der WP auf 62 zu schreiben. 12 Mal mit einer Verzögerung, da es teilweise so lange dauert, bis die Instanz am luxtronik Port neugestartet ist. 62, weil mein Ziel 60 sind. Über den Parameter luxtronik2.1.parameters.warmwater_temperature kann man ja eigentlich nur die Deckung einstellen.
                      Soll-Temp wieder runter:
                      Ändert sich erneut der Betriebszustand (z. B. wenn die WP fertig mit WW ist), so prüfe ich, ob das WW über 54° liegt und wenn ja, setze ich die neue Soll-Temp auf 48°, also zurück auf meinen Standard.
                      Prüfung:
                      Da natürlich die Sonne weiterscheinen kann, prüfe ich nochmal, sobald die Temp unter 55 fällt, sich also 60 - 6.0 K nähert - denn bei 54 würde die Pumpe ja erneut WW anfordern wenn nicht auf 48 gestellt - ob weiterhin genug Energie erzeugt wird. Wenn ja, setze ich den Wert erneut auf 62 (-2.0 K, wegen Deckung; zumindest glaube ich das irgendwie aus der Anleitung verstanden zu haben), so dass die Pumpe ab 54° wieder auf 62 bzw. 60 hochheizt.
                      ABER, ich hab das vorgestern bzw. gestern erst alles eingerichtet und es sollte noch ausgiebig getestet werden.
                      Ich schaue mal, ob oder wie man private Nachricht schreib und schreibe dich an.
                        @unclesam Ist es eigentlich möglich den watchdog für den Luxtronik Port zu deaktivieren?
                        • chrid88
                          @lessthanmore danke für die ausführliche Rückmeldung. Die Regelung habe ich etwas simpler gelöst.
                          Das Leistung-ist Feld gibts leider bei meiner wp nicht.
                          Daher muss ich wohl dann doch über s0 gehen.
                          • UncleSam
                            @lessthanmore welche Version des Adapters hast du? Der Fehler sollte behoben sein.
                            • UncleSam
                              UncleSam Developer @chrid88 last edited by
                              @chrid88 Sollte wie bei jedem anderen Adapter auch gehen mit drüber installieren.
                                @unclesam Mal wieder ein kleines Update. Hatte den watchdog für den LuxPort deaktiviert, aber gesehen, dass der config.luxPort gar nicht gesetzt wird und es auch kein "Connected to" - Statement gibt.
                                Hab es nun wie folgt geändert:
                                createLuxtronikConnection(host, port)  {
                                       if (!this.config.luxPort)  }                                           <-- Geändert
                                           return;
                                      this.log.info(`Connecting to ${host}:${port}`);
                                      this.log.info(`Connected to ${host}:${port}`);             <-- Hinzugefügt; sieht besser aus wenn auch nur als Info. Für alles andere reicht mein "Wissen" nicht -.-
                                Etwas weiter später ist mir aufgefallen, warum der Adapter ständig neustartet für den LuxPort.
                                Der Failcounter wird nicht zurückgesetzt.
                                Habe es wie folgt geändert:
                                requestAllContect()  {
                                        this.wsFailCounter = 0;
                                        this.luxFailCounter = 0;                                           <-- Hinzugefügt
                                Watchdog läuft nun für beide Ports, ich kann direkt auf den luxport schreiben bzw. auf dessen Parameter, da die Instanz nicht ständig neustartet. Läuft prima.
                                So sieht mein Log aus nach guten fünf Minuten:
                                luxtronik2.0	2021-05-23 20:54:30.653	info	(14926) Connected to 10.0.1.23:8889
                                luxtronik2.0	2021-05-23 20:54:30.653	info	(14926) Connecting to 10.0.1.23:8889
                                luxtronik2.0	2021-05-23 20:54:29.451	info	(14926) Connected to ws://10.0.1.23:8214
                                luxtronik2.0	2021-05-23 20:54:29.440	info	(14926) Connecting to ws://10.0.1.23:8214
                                Jetzt kann ich die Wiederholungen in Blocky endlich entfernen 🙂
                                Und nur noch eine Instanz aktiv.
                                Wundert mich aber, warum ich der einzige bin, der die restarts hatte und Meldungen bekommen hat.
                                /edit: Gerade deine Frage gesehen. Adapterversion 0.2.0.
                                  lessthanmore @chrid88 last edited by lessthanmore
                                  @chrid88 Darf ich fragen wie du die Regelung bei dir hast?
                                  Habe eben nochmal getestet und gesehen, dass ich mit dem Warmwasser nicht höher als 59° komme, da vorher die max. Vorlauftemperatur von 66° erreicht wird.
                                  Habe die WW-Temperatur jetzt bei 55° wenn die Sonne scheint. Sollte auch passen.
                                  Welche Firmware hast du auf der WP (habe meine gerade eben auf den neusten Stand gebracht)?
                                  Ich sehe bei mir die Leistung auch im Webinterface.
                                  • UncleSam
                                    UncleSam Developer @lessthanmore last edited by UncleSam
                                    Was meinst du mit "gar nicht gesetzt wird"? Das ist die Konfigurationsvariable, die aus dem Admin-GUI kommt.
                                               return;
                                    Lustige Lösung: wenn die Verbindung nicht klappt, dann schreibe ich einfach mal ein Log, dann sieht es so aus, als würde die Verbindung klappen... 🤔
                                    requestAllContent() fragt nur die Daten über den WS-Port ab. Wenn ich da den Watchdog für den Luxtronik-Port zurücksetze, dann wird der natürlich nie zuschlagen. Aber dann müsste ich gar keinen Watchdog haben!
                                    Der luxFailCounter wird sehr wohl zurückgesetzt:
                                    https://github.com/UncleSamSwiss/ioBroker.luxtronik2/blob/e4048aeec8e024ee47cb5b1a130ece3de2a9acd6/src/main.ts#L183
                                    Nein, der Watchdog für den Luxtronik Port ist nun nicht mehr aktiv. Mag prima laufen, ist aber leider überhaupt nicht die Lösung.
                                    Weil bei dir etwas nicht richtig funktioniert und du nun einfach den Watchdog unterdrückst. Bei dir gibt es ein Problem mit dem Luxtronik-Port und das muss gefixt werden, nicht einfach den Watchdog unterdrücken.
                                    OK, danke.
                                      @unclesam
                                      Ich habe ja geschrieben, dass es nicht korrekt ist, aber für mich besser aussieht. Ich hatte kein Statement gefunden "connected to" falls die Verbindung zum luxPort steht. Habe ich die übersehen?
                                      Beim Websocket kommt ja die Meldung nach der erfolgreichen Prüfung.
                                      https://github.com/UncleSamSwiss/ioBroker.luxtronik2/blob/e4048aeec8e024ee47cb5b1a130ece3de2a9acd6/src/main.ts#L98
                                      Das mit dem Zurücksetzen des Failcounter hatte ich übersehen, sorry.
                                      So ganz verstehe ich es nicht, da es jetzt bei mir einwandfrei läuft. Die Verbindung zum luxPort steht ja und ich kann problemlos darauf zugreifen.
                                      Die Frage ist nur, warum die Instanz alle paar Sekunden neustartet weil der watchdog sagt, dass die Verbindung nach drei Versuchen nicht hergestellt werden konnte (obwohl sie aktiv ist).
                                      Hatte jetzt bei requestAllContent() den luxFailCounter wieder auskommentiert und direkt geht die Instanz wieder in den Fehler und startet alle paar Sekunden neu.
                                      Eine Idee, wie ich rausfinden kann warum?
                                      /edit: Softwarestand meiner WP V3.85.7 (r6978)
                                      • chrid88
                                        chrid88 @lessthanmore last edited by chrid88
                                        @lessthanmore Ich hab das ganze sehr simpel gelöst. Ich habe aber bei dem schwankenden Wetter im Mai gemerkt, dass ich dadurch auch fast 100 Verdichterimpulse im Monat mehr hatte als sonst. Daher habe ich (weil momentan keine Zeit zum Grübeln) das Abfrageintervall einfach auf alle 60min gelegt.
                                        Psurplus_float ist der gleitende Mittelwert über die letzten 15min des PV Überschusses.
                                        Der Rest sollte sich eigentlich so verstehen lassen
                                        Softwarestand ist V3.85.0 (r5663)
                                        @UncleSam drüber installieren hat geklappt!
                                          @chrid88 Vielen Dank.
                                          Habe mein Skript in den letzten Tag auch vereinfacht bzw. auf ein Skript gekürzt.
                                          Das mit den VD-Impulsen hat mich erst hierher gebracht, da unser Heizungsbauer die WP unsauber eingestellt hatte und wir nach nun fast 3 Jahren uns schon der 30.000er Marke an Impulsen nähern.
                                          Deswegen hatte ich auch im Skript darauf geachtet. Ich prüfe ausschließlich wenn Warmwasser gemacht wird, ob die PV Leistung ausreicht und nur dann erhöhe ich; sprich wenn die WP eh schon dabei ist WW zu machen. Andernfalls ist die WP gerade fertig mit dem Standard-Warmwasser und bekommt dann vom Skript erneut eine neue Solltemperatur und fährt wieder an.
                                          Über was liest du Float aus? Im SMA-EM Adapter finde ich den Wert nicht.
                                          Lese bei mir mittlerweile den Wechselrichter direkt per Modbus aus und da auch nur die aktuelle Erzeugung unabhängig davon ob ich gerade etwas einspeise oder beziehe.
                                          Als Ziel habe ich mir jetzt gesetzt dass die WP morgens beim WW und genug PV-Energie auf den erhöhten Wert geht und dort so lange bleibt bis die Energie nicht mehr ausreicht.
                                            pgBroker @lessthanmore last edited by pgBroker
                                            Ich habe leider auch das Problem, dass der Watchdog in der v0.2 im Schnitt alle 5 Minuten den Adapter neu startet, da er 3x in Folge keine Antwort bekommen hat.
                                            Am Netzwerk kann es nicht liegen. Habe sogar einen neuen Switch und ein neues CAT 6 Kabel eingebaut. Keine Änderung in der Häufigkeit der Neustarts.
                                            Port 8889 stimmt auch laut Log.
                                            Ich glaube nicht, dass der Watchdog erst dann zuschlägt, wenn sich die Verbindung zur Luxtronik komplett aufgehängt hat. Vor dem Einbau des Watchdog lief der Adapter in der Regel mehrere Wochen problemlos. Warum soll sich das mit Watchdog auf 5 Minuten reduzieren.
                                            Vielleicht braucht die Luxtronik manchmal etwas länger bis eine Antwort kommt und der Watchdog interpretiert das als dauerhafte Unterbrechung und veranlasst einen Neustart des Adapters.
                                            @UncleSam Vielleicht kannst du einen Parameter einbauen mit dem man den Timeout setzen kann und die Anzahl der missglückten Abfragen bevor der Watchdog einen Neustart auslöst.
                                            Im Ergebnis ist es nat. besser, wenn der Adapter nicht alle paar Wochen komplett hängt, aber ein Adapter der alle 5 Minuten neu startet, füllt sich für mich auch nicht gut an.
                                            adapter luxtronik wp websocket
                                            52
                                            289
                                            68116
