    4. Test Adaper Tado v0.1.x
      TDCroPower last edited by TDCroPower
      Dank an @HGlab für die Implementierung des Offset-Wertes in der PreRelease Version des Adapters!
      Siehe Info dazu hier...
      https://github.com/DrozmotiX/ioBroker.tado/issues/11#issuecomment-844212895
      Der Datenpunkt ist zu finden unter...
      tado.[x].[yyyy].Räume.[z].Geräte.[GeräteID].offset.offsetCelsius
      Ein passendes Blockly-Script, um den Offset-Wert sinnvoll zu nutzen, habe ich mit dem Java-Script von Mic-M erstellt...
      https://github.com/Mic-M/iobroker-homematic-3rd-party-temp-sensors
      Hier wird die gemessene Temperatur des tado mit einem eigenen Temperatursensor, in meinem Beispiel ein Xiaomi-Temperatursensor, verglichen und der ideale Offset-Wert berechnet.
      Ich habe das Skript für die tados angepasst und als Blockly verwendet.
      Blockly Export:
      https://pastebin.com/aimKBmQ8
      a-i-ks created this issue in DrozmotiX/ioBroker.tado
      closed [Feature_Request] Set the offset temperature for a room #11
      Slowman 1 Reply Last reply Reply Quote 1
        HGlab last edited by HGlab
        Pre-Release v0.3.0-0
        Today a pre-release was finalized on Github.
        This version includes intensive refactorings and breaking changes. Some names/path of states changed in this version.
        More details at
        https://github.com/DrozmotiX/ioBroker.tado/blob/generic/README.md
        Breaking changes in v0.3.x
        Upgrade from 0.2.x to v0.3.x includes a technical re-factioring with breaking changes (e.g. temperature setting is now located at tado.[x]].[yyyyy]].Rooms.[z].setting.temperature.celsius).
        Changelog
        0.3.0-0 (2021-05-19)
        • implement offset functionality
        • technical re-factoring of state management !BREAKING CHANGES! (see above)
        Can be installed by using
        DrozmotiX/ioBroker.tado#4d069d77e239cf50d0529fbd7b2d20a35dc7bb76
        as URL like this
        Feel free to test and to provide feedback. For defects please create a Github issue
        Own topic created
        https://forum.iobroker.net/topic/45301/test-adapter-tado-v0-3-0-x-prerelease
        • Slowman
          Slowman @TDCroPower last edited by
          @tdcropower
          Verstehe das mit den Offset Wert nicht 🙄
          Es wird der Temperaturwert von Tado gemessen z.B. 22 Grad (auch der Wert den man eingestellt hat) und der Temperatursensor 24 Grad. Wird jetzt der Offset Wert auf 22 Grad gesetzt?
            TDCroPower @Slowman last edited by TDCroPower
            @slowman der gesetzte Offsetwert wird bei tado auf den gemessenen Wert drauf addiert und dieser Wert wird dem Adapter so als „gefakter“ Wert übermittelt.
            Daher ziehe ich den gesetzten Offset Wert vom gemessenen tado Temperatur Wert ab.
            So habe ich 3 Werte…
            Gemessenen Tado Wert, gesetzten tado Offset Wert und den gemessenen Wert vom eigenen Temperatur Sensor.
            Die Idee des Offsets...
            Mit dem Offset gleicht man die Ungenauigkeit der gemessenen Temperatur aus.
            Wenn also der HKT 20Grad an der Heizung misst und der Wert im Raum jedoch 22Grad beträgt, muss man den Messwert mit dem Offset=2 hoch korrigieren.
            Problem bei dem festen setzen des Offsets, die Differenz ist leider nicht immer gleich.
            Liegt halt an der Messposition des HKT direkt in der Nähe der Heizung.
            Das Script springt hier ein, sodass er die Differenz alle 30 Minuten (kann über den globalSchedule Wert am Anfang geändert werden) erneut berechnet.
            Sobald der Offset Wert sich verändert hat wird dieser erneut gesetzt, ansonsten springt das Script raus (falls Prüfung!)
            Habe das System schon damals bei meinen Homematic IP HKT verwendet und hatte so genau den Temp Wert den ich im Raum gemessenen habe durch die Heizung erreicht.
            Slowman 1 Reply Last reply Reply Quote 0
            • Slowman
              @tdcropower
              Ah, danke verstanden. Habe den Offset Wert einzeln betrachtet.
                Andy_68 @Slowman last edited by
                mir fehlen plötzlich die Datenpunkte openWindowDetectet im Ioboker. Hat jemand einen Tip, warum diese fehlen?
                Adapter habe ich schon mal aktualisiert, komme aber nicht wirklich weiter ...
                Danke und allen schönes Pfingstmontag
                Thomas Braun H 2 Replies Last reply Reply Quote 0
                  Thomas Braun Most Active @Andy_68 last edited by
                  @andy_68
                  Versionsnummer?
                    HGlab @Andy_68 last edited by
                    @andy_68
                    wenn noch nie ein offenes Fenster erkannt wurde kam von der API auch noch nie ein State dafür und somit gibt es auch keinen Datenpunkt. Also einfach mal das Fenster aufmachen, dann sollte es den Datenpunkt geben
                      Andy_68 @Thomas Braun last edited by
                      @thomas-braun :
                      Beim Adapter wird mir 0.2.7 angezeigt
                        Andy_68 @HGlab last edited by
                        @hglab :
                        guter tip, dann reisse ich mal die Fenster & Türen auf. Mal schauen ob das funktioniert 😉
                          Andy_68 @Andy_68 last edited by Andy_68
                          ein Tado hat endlich mal ein offenes Fenster erkannt und auch einen neuen Ordner "openWindow" angelegt.
                          Der Datenpunkt openWindowDetected fehlt allerdings weiterhin (diesen habe ich zuvor mit heatingcontrol zur Absenkung der Temp. genutzt, da ich kein Abo bei Tado abgeschlossen habe)
                          Nun weis ich leider nicht weiter, wie ich an diesen Datenpunkt kommen soll....
                          Danke im Voraus für jeden Tip...
                            @andy_68
                            The API only delivers these four:
                              @hglab said in Test Adaper Tado v0.1.x:
                              Is that new?
                              in the past there was a datapoint in the folder Rooms
                              tado.0.xxxxxx.Rooms.3.openWindowDetected
                                @andy_68
                                I cannot tell you. I just looked at the API and there was no additional info
                                  @hglab
                                  thks. but allow me one question:
                                  in this adapter https://github.com/DrozmotiX/ioBroker.tado i found the following entry for V 0.1.3.
                                  0.1.3 Several fixes for reported error's
                                  (DutchmanNL) boilerId / onDemandLogRetrievalEnabled / openWindowDetected / onDemandLogRetrievalEnabled
                                  (DutchmanNL) Open Window detection implemented, only by device not by room
                                  Did the API change in the last weeks (it works until last week)
                                    @andy_68
                                    I can only tell you what the API is currently providing. I am not monitoring the API and maybe in some cases the API delivers the state.
                                    I only can ensure that the API content is proper handled.
                                      JohnnyBahama last edited by
                                      Hi, ich habe nach dem gesamt update auf Node 12.x den Adapter auch auf latest Version aktualisiert aufgrund der ganzen Meldungen. Leider kommen jetzt keine Werte/Geofencing mehr rein , außer Name und Id je mobilem Gerät. Gab es schonmal ein Feedback dazu?
                                        Thomas Braun Most Active @JohnnyBahama last edited by
                                        @johnnybahama Hier funktioniert Geofencing.
                                        V 0.3.0-4
                                          JohnnyBahama @Thomas Braun last edited by JohnnyBahama
                                          @thomas-braun die Version ist installiert, trotzdem leer
                                          Hier auch der Log. Der schmeist auch keine Fehler aus.
                                          tado.0	2021-06-09 23:17:30.945	info	(2555) Initialisation finished, connected to Tado cloud service refreshing every 30 seconds
                                          tado.0	2021-06-09 23:17:20.641	info	(2555) Connected to Tado cloud, initialyzing ...
                                          tado.0	2021-06-09 23:17:19.952	info	(2555) Started with JSON-Explorer version 0.1.0
                                          tado.0	2021-06-09 23:17:19.886	info	(2555) starting. Version 0.3.0-4 in /opt/iobroker/node_modules/iobroker.tado, node: v12.22.1, js-controller: 3.3.12
                                          tado.0	2021-06-09 23:17:19.840	info	(2555) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                                          Edit: Nur die mobile devices bekommen keine Werte/Geofencing rein. Die Hardware Thermostate DP zeigen alles an
                                          Edit2: Nach dem löschen der Objekte und Neustart des Adapters sind diese wieder zu sehen. Jetzt sehe ich momentan nur die Raumtemperatur pro Gerät nicht. Mal sehen, ob sich da noch was tut.
                                            HGlab @JohnnyBahama last edited by
                                            @johnnybahama
                                            wenn das Raumthermostat OFF ist, schickt die Tado-App keine Temperatur, Dann wird auch kein Datenpubnkt angelegt
                                            Die Aktualisierung von "Home" und "MobileDevices" findet ab 0.3.x stündlich statt um nicht unnötig viele Datenpinkte in kurzen Intervallen zu schreiben. Beim Neustart des Adapters werden die Datenpunkte natürlöich geschrieben bzw. aktualisiert.
                                            adapter tado testing team
                                            62
                                            868
                                            202634
