    4. PH-Messung
    PH-Messung
      Chaosbrother last edited by
      Hi, maybe it would be easier to make a backup of the firmware from the ESP and then just change the gateway and play back again. Something like that works with Esptool.py , but I don't know my way around that well either.
        apollon77 last edited by apollon77
        Hey,
        I hope I also get my device in next 1 days (just ordered yesterday). When the code I found telling anything AND when it is right that the App also switches to "local" communication when in same WLAN then honestly I would start really analyzing that. That could be way more easy!
        Code wise it seemed to me that locally the device itself acts as a simple mqtt server hopefully.
        So if someone wants to do stuff in between:
        • maybe start with a nmap scan against the local IP ... is there anything open and what can be found there?
        • start (like @coyote started) with Wireshark but focus on mobile device/App-with-ph-803w communication ... there should be some
        Anyone up for that?
        PS: @Marc-R
        Hi yall, my first post so be gentle...
        We are always 🙂
        To maybe see more in the data would be a good idea to also see what data the device was showing as you tried it, maybe the "calculation rules" that @Anti was able to decode also apply. ALso interesting would be which part o fthe message is changing when the values change and which part stays static. So now you need to start "data crunching", I expect the data needs to be in there
        • coyote
          coyote Most Active @apollon77 last edited by coyote
          Today I made a local scan in the same network. At the first attempt it was over the VPN connection and therefore "Remote"
          Maybe you like that better @apollon77 😉
          39484	33.259423	192.168.66.54	192.168.66.8	TCP	62	12416 → 48158 [PSH, ACK] Seq=94 Ack=83 Win=5758 Len=8
          29590	29.524847	192.168.66.54	192.168.66.8	TCP	62	12416 → 48158 [PSH, ACK] Seq=86 Ack=75 Win=5766 Len=8
          26127	28.341450	192.168.66.54	192.168.66.8	UDP	151	12414 → 37038 Len=109
          18180	25.193896	192.168.66.54	192.168.66.8	TCP	62	12416 → 48158 [PSH, ACK] Seq=78 Ack=67 Win=5774 Len=8
          8826	21.298249	192.168.66.54	192.168.66.8	TCP	62	12416 → 48158 [PSH, ACK] Seq=70 Ack=59 Win=5782 Len=8
          8700	21.257654	192.168.66.54	192.168.66.8	TCP	76	12416 → 48158 [PSH, ACK] Seq=48 Ack=51 Win=5790 Len=22
          8696	21.255005	192.168.66.54	192.168.66.8	UDP	151	12414 → 37038 Len=109
          7288	20.836871	192.168.66.54	192.168.66.8	TCP	72	12416 → 48158 [PSH, ACK] Seq=30 Ack=38 Win=5803 Len=18
          7287	20.824022	192.168.66.54	192.168.66.8	TCP	54	12416 → 48158 [ACK] Seq=30 Ack=38 Win=5803 Len=0
          6978	20.574620	192.168.66.54	192.168.66.8	UDP	151	12414 → 37038 Len=109
          5694	20.118304	192.168.66.54	192.168.66.8	TCP	63	12416 → 48158 [PSH, ACK] Seq=21 Ack=29 Win=5812 Len=9
          5643	20.100519	192.168.66.54	192.168.66.8	TCP	74	12416 → 48158 [PSH, ACK] Seq=1 Ack=9 Win=5832 Len=20
          5607	20.088883	192.168.66.54	192.168.66.8	TCP	58	12416 → 48158 [SYN, ACK] Seq=0 Ack=1 Win=5840 Len=0 MSS=1460
          3855	19.504039	192.168.66.54	192.168.66.8	UDP	151	12414 → 37038 Len=109
          2761	18.290828	192.168.66.54	192.168.66.8	UDP	151	12414 → 37038 Len=109
          2567	17.284353	192.168.66.54	192.168.66.8	UDP	151	12414 → 37038 Len=109
          2381	16.220137	192.168.66.54	192.168.66.8	UDP	151	12414 → 37038 Len=109
          2210	15.190409	192.168.66.54	192.168.66.8	UDP	151	12414 → 37038 Len=109
          2063	14.544840	192.168.66.54	192.168.66.8	UDP	151	12414 → 37038 Len=109
          1906	13.514199	192.168.66.54	192.168.66.8	UDP	151	12414 → 37038 Len=109
          1662	12.248355	192.168.66.54	192.168.66.8	UDP	151	12414 → 37038 Len=109
            apollon77 @coyote last edited by apollon77
            @coyote yes. Via VPN normally all UDP messages are not transferred 😉
            Can you send me that wireshark file via email to iobroker@fischer-ka.de
            Ps: i assume .54 is the ph803 and the .8 is mobile device?
            coyote 2 Replies Last reply Reply Quote 0
            • coyote
              @apollon77 ok, i didn't know.
              Sure, think it'll take another hour, then I can send it to you.
              Yes exactly. .54 is the 803W and .8 is the smartphone
              • coyote
                @apollon77 you have mail 😉
                  Chaosbrother last edited by Chaosbrother
                  Das mal zur App vieleicht kann jemand was damit anfangen.
                  https://docs.gizwits.com/en-us/AppDev/AndroidSDKA2.html#5-Device-control
                  Dafür ist mein Englich zu schlecht. Wenn ich das richtig verstehe kann und darf man an der App was ändern mit
                  Android Studio
                    @coyote Ok, I start to collect here the stuff I saw in the Wireshark:
                    • (01) App sends a UDP broadcast with data "00 00 00 03 03 00 00 03" to port 12414
                    • App sends MDNS query to 224.0.0.251 _%9E5E7C8F47989526C9BCD95D24084F6F0B27C5ED._sub._googlecast._tcp.local, "QU" question PTR _googlecast._tcp.local, "QU" question
                    • (02) Device Answers with UDP message from port 12414 to App
                      00:00:00:03:68:00:00:04:00:16:43:46:71:70:4a:54:53:79:6d:43:45:39:50:4c:6c:70:31:44:70:62:68:59:00:06:48:3f:da:87:dc:47:00:00:00:20:32:64:33:64:39:35:34:64:39:62:62:37:34:31:62:34:61:31:39:62:61:31:31:35:33:31:30:34:39:33:32:62:00:00:00:00:00:00:00:02:61:70:69:2e:67:69:7a:77:69:74:73:2e:63:6f:6d:3a:38:30:00:34:2e:30:2e:38:00
                      ( hCFqpJTSymCE9PLlp1DpbhYH?ÚÜG 2d3d954d9bb741b4a19ba1153104932bapi.gizwits.com:804.0.8)
                    • App connects to device on port 12416 and Device and App communicates on that port
                    • (03) App sends 00:00:00:03:03:00:00:06
                    • (04) Device answers: 00:00:00:03:0f:00:00:07:00:0a:X1:X2:X3:X4:X5:X6:X7:X8:X9:X0
                    • (05) App sends : 00:00:00:03:0f:00:00:08:00:0a:X1:X2:X3:X4:X5:X6:X7:X8:X9:X0
                    • (06) Device answers: 00:00:00:03:04:00:00:09:00
                    • (07) App sends : 00:00:00:03:04:00:00:90:02
                    • (08) Device answers: 00:00:00:03:0d:00:00:91:03:00:02:dc:08:9d:00:00:00:00
                    • (09) App sends : 00:00:00:03:08:00:00:93:00:00:00:04:02
                    • (10) Device answers: 00:00:00:03:11:00:00:94:00:00:00:04:03:00:02:dc:08:9d:00:00:00:00
                    • (11) App sends : 00:00:00:03:03:00:00:15
                    • (12) Device answers: 00:00:00:03:03:00:00:16
                    ... and the last two repeat every 4s (seems like a ping/pong)
                    Das passt grob spontan zu dem Protokoll von hier https://github.com/gizwits/gokit-GAgent/blob/master/software/lan/lan.c#L291
                    • 00 00 00 03 sind immer die lokalen ersten Bytes
                    • byte Nummer 8 ist das "Kommando" (also wenn App->Device) ... damit von oben
                      • (---) code 01 -- UDP to device - onBoarding message ... 00 XX <XX bytes ssid> 00 YY <YY bytes ssidpwd> (unsure with 00xx/yy or if only xx/yy?)
                      • (---) code 02 -- UDP from device - onBoarding response ... just as OK message
                      • (01): code 03 -- UDP to device - Discover message
                      • (02): code 04 ?? -- UDP from device - Discover response
                      • (---) code 05 ?? -- UDP from device active broadcast from device
                      • (03): code 06 -- TCP to device: user bind passcode; Device returns passcode for login command
                      • (04): code 07 -- TCP from device: device answers with data and 10 chars as passcode
                      • (05): code 08 -- TCP to device: user login : Device wants to see the same passcode as sent above
                      • (06): code 09 -- TCP from device: login result: 00=ok, 01=error
                      • (07): code 90 -- TCP to device: send p0 to uart ... schreibt "02" ans Device
                      • (08): code 91 ?? TCP answer from serial?? 03:00 02:dc 08:9d 00:00 00:00
                      • (09): code 93 ?? -- TCP to device - unknown 00:00:00:04:02
                      • (10): code 94 ?? -- TCP from device - unknown 00:00 00:04 03:00 02:dc 08:9d 00:00 00:00
                      • (11) code 15: -- TCP to device: "tick" aka ping
                      • (12) code 16: should be "pong" then
                    If we now would have info on the values on display vs data it would help 🙂
                    • 02dc could be 732 with idea from above with /100 == 7,32 ... PH??
                    • 089d could be 2205 with idea from above -2000 === 205 ... ORP?
                      @coyote ??
                    The two other 00 00 at the end could be the switch states ... but also would need to be verified.
                    Ingo
                    coyote 1 Reply Last reply Reply Quote 1
                    • coyote
                      @apollon77 sounds good 😉
                      Will do more test today with wireshark and and will write down the values from the display or take pictures.
                      The switches cannot be triggered manually.
                      The device is currently not in use by me, there are no probes connected, so the values are not directly plausible (ORP 0.2 etc.)
                        Anti @Marc R last edited by
                        @marc-r Thats nice Marc-r. So the ESP just bring the Serial kommunikation to the Network. What I allready suspected but didn't checked. I think, like you, is the most simple way to flash the original ESP (or put a second one if you want to keep the original).
                        for the completness: 9600 8N1
                        I think I will make that, to don't have the MQTT in the middle.
                        apollon77 Marc R 2 Replies Last reply Reply Quote 1
                          apollon77 @Anti last edited by apollon77
                          @anti Why you dio not implement the LAN protocol? (or wait until I did?) For me personally hardware modifications are meeh ... but I think everyone has it's own opinion here 🙂
                          But in gfact does not hatter ... so we need to dectode the values ... we know 4 bytes already 🙂 So assumption stay that the 2x 0000 at the end are the states of the switches
                          • Marc R
                            Marc R @Anti last edited by
                            @anti you mean load something like Tasmota on the existing ESP? I have a lot of Sonoff switches which I "tasmotized", so I know how that works, but I'm not sure if the PH-803W would be compatible?
                              @marc-r I'm not so deep in the MQTT/Tasmota Topic. So not sure what you can do with Tasmota, here in this use case we want to put a serial Input somewhere. When Tasmota can do that, you should be okay with that. I was thinking about a little Programm on ESP putting the serial e.g. on a Webpage. This is probably a few minutes programming Job. I think i prefare this, because my Pool also will be controlled by an ESP. If a Server is in the middle is one more thing that can fail.
                              But anyway i can wait if the other guys here find the "LAN Protocol" Solution. If i can use that from another ESP, i will probably make like this.
                              Well i just thought i can connect the 803W serial connect directly my control ESP ... this is also a good failsafe alternative.
                              • Marc R
                                @anti Tasmota is an awesome open-source firmware for all kinds of ESP8266 devices to connect them via MQTT to automation systems such as Home Assistant and others. Have a look here: https://tasmota.github.io/docs/
                                I virtually loaded it on about 60 devices so far, but try are Sonoff and Shelly switches and I'm not sure how the PH-803W would handle it.
                                I'm just adding this as another alternative to the paths you guys are already following. I'm not saying it's better or worse. If you guys find a fairly simple way to send the PH-803W data to MQTT, I'm all for it!
                                  Ok, mit weiteren Wireshark Mitschnitten von @coyote bin ich denke etwas weiter ... immer noch viele Annahmen, daber die kann man dann ja mal verifizieren. habe auch eine vermutung wo die Schaltwerte stecken (Bit flags) und würde tippen das andere Bits da drin vllt im Display für Anzeigen genutzt werden ...
                                  Ich habe mal alles unter https://github.com/Apollon77/node-ph803w/blob/main/PROTOCOL.md zusammengefasst.
                                  Als nächstes schaue ich mal das ich das als node.js Library implementiere
                                  Ich habe auch für "unsere ESP Freunde" mal eine vermutete minimale Kommunikation unter https://github.com/Apollon77/node-ph803w/blob/main/PROTOCOL.md#minimum-interaction-scheme aufgeschrieben ... wäre zu verifizieren ...
                                  Have fun
                                  C 1 Reply Last reply Reply Quote 2
                                    Chaosbrother @apollon77 last edited by
                                    @apollon77 Respekt.👍 Aber ich versteh nur noch Bahnhof🙄 . Mal abwarten wie es weitergeht.
                                    Trotzdem DANKE für die Info´s und deine Mühe
                                      Ok, dann mal nächster Schritt ... ich hab mal was gebaut.
                                      • Man nehme am besten einen Rechner wo nodejs drauf ist (also der von iobroker ist super)
                                      • per SSH einloggen und in das Vezeichnis gehen
                                      • Man lege sich ein neues Verzechnis an, am besten direkt im User-Verzeichnis (also NICHT!! in /opt/iobroker)
                                      • npm install Apollon77/node-ph803w
                                      • cd node_modules/node-ph803w/example
                                      • node data.js 111.222.333.444 (mit 111.222.333.444 die IP des PH803W Geräts im lokalen Netzwerk
                                      Dann sollte sich das Beispielskript verbinden, Passcode holen, einloggen und jede Datenänderung die es gibt sollte eine Logzeile geben mit den Werten. Eine Datenzeile muss in jedem Fall kommen - hoffentlich mehr sobald sich was ändert. Das nehme ich gern mal.
                                      Falls irgendwas nicht geht bitte mal unter Linux mit DEBUG=ph803w* node data.js 111.222.333.444 starten, dann sollte mehr log kommen.
                                      Zu testen ist:
                                      • Das die werte mit dem Display passen und idealerweise auch was die "Schaltzustände" angeht
                                      • Das bei Änderungen neue Werte kommen (es ist immer noch ein bissl unklar welches Kommando das auslöst)
                                      • Die zwei "binFlag1/2" Felder haben vermutlich eine Verbindung zu DIngen im Display (annahme). Das wäre zu prüfen und hier schreiben zu was was gehört 🙂
                                      Dann schauen wir mal wie gut blindes Programmieren so tut 🙂
                                      Ingo
                                        SoerenKaiser99 @apollon77 last edited by
                                        @apollon77
                                        Coole Nummer 😄
                                        Es ginge aber auch (ein wenig einfacher) mit nem Wemos D1 / NodeMCU und ner analogen PH Sonde :D... Nur so nebenbei 👍
                                        Wemos D1 PH-Sonde
                                        U apollon77 2 Replies Last reply Reply Quote 0
                                          Anti last edited by
                                          Wo bleibt denn da der Spaß? 😛
                                          Nein ist natürlich auch ein weg. Hab sowas sogar hier liegen war irgendwie nie dazu gekommen das weiterzuverfolgen 😕
                                            SoerenKaiser99 @Anti last edited by
                                            @anti weis ich doch. War ein wenig ironisch gemeint 🙂 Versteh schon.. Herrausforderung und so.
                                            Hatte ich auch vor... Bin dann aber die Tage mangels Zeit umgeschwenkt. Jetzt regelt die phileo den pH wert, n shelly steuert den Chlorinator und die Pumpe ( danke an paul 😄 ) und n blueconnect sendet stündlich die Daten 😄 ... läuft!
                                            432
                                            102970
