    4. Test PV Forecast Adapter
    • Glasfaser
      Glasfaser @PatrickWalther last edited by
      @patrickwalther
      Bekomme den Adapter von GitHub nicht installiert.
      2021-05-25 20:38:19.533 - info: host.iobroker iobroker url "https://github.com/Patrick-Walther/ioBroker.pvforecast" --debug
      2021-05-25 20:38:21.423 - info: host.iobroker iobroker Info: Can not get current GitHub commit, we remember master branch only. Status: 422 (No commit found for SHA: master)
      2021-05-25 20:38:21.425 - info: host.iobroker iobroker install https://github.com/Patrick-Walther/ioBroker.pvforecast/tarball/master
      2021-05-25 20:38:21.898 - info: host.iobroker iobroker NPM version: 6.14.8
      2021-05-25 20:38:21.901 - info: host.iobroker iobroker npm install https://github.com/Patrick-Walther/ioBroker.pvforecast/tarball/master --loglevel error --prefix "/opt/iobroker" (System call)
      2021-05-25 20:38:39.558 - info: host.iobroker iobroker npm ERR! code E404
      2021-05-25 20:38:39.564 - info: host.iobroker iobroker npm ERR! 404 Not Found - GET https://codeload.github.com/Patrick-Walther/ioBroker.pvforecast/legacy.tar.gz/masternpm ERR! 404 npm ERR! 404 'https://github.com/Patrick-Walther/ioBroker.pvforecast/tarball/master' is not in the npm registry.npm ERR! 404 Your package name is not valid, because npm ERR! 404 1. name can only contain URL-friendly charactersnpm ERR! 404 2. name can no longer contain capital lettersnpm ERR! 404 npm ERR! 404 Note that you can also install from anpm ERR! 404 tarball, folder, http url, or git url.
      2021-05-25 20:38:39.619 - info: host.iobroker iobroker npm ERR! A complete log of this run can be found in:npm ERR! /opt/iobroker/.npm/_logs/2021-05-25T18_38_39_564Z-debug.log
      2021-05-25 20:38:39.656 - error: host.iobroker iobroker host.iobroker Cannot install https://github.com/Patrick-Walther/ioBroker.pvforecast/tarball/master: 1
      2021-05-25 20:38:40.734 - info: host.iobroker iobroker exit 25
        PatrickWalther Developer @Glasfaser last edited by
        Hi @glasfaser,
        welches nodejs, js-controller und npm version hast du in Benutzung?
        • Glasfaser
          Glasfaser @PatrickWalther last edited by Glasfaser
          @patrickwalther
          er sagt im Log
          404 Not Found
          und was hat das mit nodejs, js-controller und npm version zu tun ?
          Testsystem Beta-Zweig ( nicht aktuell )
          /usr/bin/nodejs
          v12.19.0
          /usr/bin/node
          v12.19.0
          /usr/bin/npm
          6.14.8
          JS 3.1.6
            @glasfaser bei mir klappt es nur auf dem aktuellen Stand sprich:
            Node.js: v12.22.1
            NPM: v6.14.12
            Js-controller: v3.2.16
            Kannst du gerne ausprobieren, ansonsten Schau was ich machen kann.
            • Glasfaser
              @patrickwalther
              Ok , teste es auf meinen anderen ...
              Wird schon gehen ..
              • JB_Sullivan
                JB_Sullivan @Glasfaser last edited by
                @glasfaser
                Nàbend - nach dem Hinweis von Glasfaser, das "unser" Skript jetzt auch in einen Adapter verpackt wurde, habe ich mich mal genötigt gesehen diesen zu installieren 😉
                Also Installation aus der Katze heraus unter Admin 5.1.0 und js-controller 3.3.11 funktioniert 1A. Was an sonstigen DP`s noch erzeugt wird, kann ich dann erst morgen frühen sehen.
                Allerdings finde ich es etwas Schade das der Adapter offensichtlich nur für Anlagen mit einer fixen Ausrichtung ist. OST/WEST Anlagen o.ä. mit unterschiedlichen kwp Belegungen wird (z.Zt. ?) wohl noch nicht berücksichtigt.
                Aber ansonsten - der Ansatz ist gut ....... obwohl ich sagen muss, in den 3 Monaten, in dem ich die js-skript Version der PV Prognose am laufen habe, waren echt extrem viele Tage dabei, die völlig daneben lagen und das obwohl ich schon die Personal Variante "gebucht" habe.
                • JB_Sullivan
                  JB_Sullivan last edited by JB_Sullivan
                  Gibt scheinbar doch einen Fehler. Der Adapter ist eine Zeit lang Grün und wird dann mit der folgenden Meldung Rot
                  host.GLT(GLT)	2021-05-25 22:28:00.634	info	Restart adapter system.adapter.pvforecast.0 because enabled
                  host.GLT(GLT)	2021-05-25 22:28:00.631	error	instance system.adapter.pvforecast.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                  pvforecast.0	2021-05-25 22:28:00.022	warn	(1160) Terminated (UNCAUGHT_EXCEPTION): Without reason
                  pvforecast.0	2021-05-25 22:28:00.021	info	(1160) terminating
                  pvforecast.0	2021-05-25 22:28:00.014	error	(1160) Cannot read property 'val' of null
                  pvforecast.0	2021-05-25 22:28:00.014	error	(1160) TypeError: Cannot read property 'val' of null at Immediate.<anonymous> (C:\iobroker\GLT\node_modules\iobroker.pvforecast\main.js:192:33) at processImmediate (internal/timers.js:463:21)
                  pvforecast.0	2021-05-25 22:28:00.012	error	(1160) uncaught exception: Cannot read property 'val' of null
                  pvforecast.0	2021-05-25 22:27:08.948	info	(1160) ThisUrl undefined
                  pvforecast.0	2021-05-25 22:27:08.930	info	(1160) starting. Version 0.0.1 in C:/iobroker/GLT/node_modules/iobroker.pvforecast, node: v14.16.0, js-controller: 3.3.11
                  Was für einen Link erwartet der Adapter denn? Das scheint ja der eigentliche Fehler zu sein. Das was unter den Instanz Einstellungen vorgeschlagen wird ( https://api.forecast.solar ), scheint nicht das zu sein, was erwartet wird - oder?
                  pvforecast.0	2021-05-26 07:16:30.955	info	(12860) ThisUrl undefined
                    PatrickWalther Developer @JB_Sullivan last edited by PatrickWalther
                    Hallo @JB_Sullivan,
                    kannst du bitte den adapter auf debug stellen und mir den log zu Verfügung stellen, bitte auch ein Screenshot der Eingaben in der Instanz.
                    Der abgegebene Link in der Instanz ist richtig.
                    Musste leider auch des Öfteren schon feststellen das der forecast gar nicht gestimmt hat.
                    Die Addition zweier Anlagen wird später auch noch kommen.
                    @Glasfaser hats jetzt bei dir geklappt?
                    JB_Sullivan Glasfaser 2 Replies Last reply Reply Quote 0
                    • JB_Sullivan
                      JB_Sullivan @PatrickWalther last edited by
                      @patrickwalther
                      Unter Debug kommt leider auch nicht viel mehr bei heraus. Längen / Breitengrad habe ich hier fürs Forum ge-x`t
                      host.GLT(GLT)	2021-05-26 10:10:00.618	info	Restart adapter system.adapter.pvforecast.0 because enabled
                      host.GLT(GLT)	2021-05-26 10:10:00.617	error	instance system.adapter.pvforecast.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                      pvforecast.0	2021-05-26 10:10:00.022	warn	(14260) Terminated (UNCAUGHT_EXCEPTION): Without reason
                      pvforecast.0	2021-05-26 10:10:00.021	info	(14260) terminating
                      pvforecast.0	2021-05-26 10:10:00.020	debug	(14260) cleaned everything up...
                      pvforecast.0	2021-05-26 10:10:00.013	error	(14260) Cannot read property 'val' of null
                      pvforecast.0	2021-05-26 10:10:00.013	error	(14260) TypeError: Cannot read property 'val' of null at Immediate.<anonymous> (C:\iobroker\GLT\node_modules\iobroker.pvforecast\main.js:192:33) at processImmediate (internal/timers.js:463:21)
                      pvforecast.0	2021-05-26 10:10:00.012	error	(14260) uncaught exception: Cannot read property 'val' of null
                      pvforecast.0	2021-05-26 10:10:00.010	debug	(14260) 2021-05-26 10:10
                      pvforecast.0	2021-05-26 10:09:46.811	info	(14260) ThisUrl undefined
                      pvforecast.0	2021-05-26 10:09:46.810	debug	(14260) setting-gps-iobroker: undefined
                      pvforecast.0	2021-05-26 10:09:46.809	debug	(14260) Account: account-Personal
                      pvforecast.0	2021-05-26 10:09:46.809	debug	(14260) plant name: JB
                      pvforecast.0	2021-05-26 10:09:46.809	debug	(14260) Link: https://api.forecast.solar
                      pvforecast.0	2021-05-26 10:09:46.808	debug	(14260) Plant-performance: 9,9
                      pvforecast.0	2021-05-26 10:09:46.808	debug	(14260) Azimuth: 90
                      pvforecast.0	2021-05-26 10:09:46.808	debug	(14260) Neigung: 40
                      pvforecast.0	2021-05-26 10:09:46.807	debug	(14260) Breitengrad: 52.xxxxxx
                      pvforecast.0	2021-05-26 10:09:46.807	debug	(14260) Längengrad: 10.xxxxxx
                      pvforecast.0	2021-05-26 10:09:46.791	info	(14260) starting. Version 0.0.1 in C:/iobroker/GLT/node_modules/iobroker.pvforecast, node: v14.16.0, js-controller: 3.3.11
                      host.GLT(GLT)	2021-05-26 10:09:43.242	info	instance system.adapter.pvforecast.0 started with pid 14260
                      host.GLT(GLT)	2021-05-26 10:09:43.210	info	"system.adapter.pvforecast.0" enabled
                      • Glasfaser
                        @patrickwalther sagte in Test PV Forecast Adapter:
                        Ja , alles Gut .
                        und was hast du weiter damit vor , machst du auch dafür ein JSONGraph wie im Script.
                        {"result":{"watts":{"2021-05-26 05:21:00":0,"2021-05-26 05:33:00":2,"2021-05-26 05:45:00":16,"2021-05-26 06:00:00":27,"2021-05-26 07:00:00":90,"2021-05-26 08:00:00":179,"2021-05-26 09:00:00":276,"2021-05-26 10:00:00":396,"2021-05-26 11:00:00":609,"2021-05-26 12:00:00":573,"2021-05-26 13:00:00":654,"2021-05-26 14:00:00":759,"2021-05-26 15:00:00":780,"2021-05-26 16:00:00":710,"2021-05-26 17:00:00":594,"2021-05-26 18:00:00":500,"2021-05-26 19:00:00":332,"2021-05-26 20:00:00":164,"2021-05-26 20:51:00":22,"2021-05-26 21:41:00":0,"2021-05-27 05:20:00":0,"2021-05-27 05:33:00":2,"2021-05-27 05:45:00":11,"2021-05-27 06:00:00":22,"2021-05-27 07:00:00":81,"2021-05-27 08:00:00":170,"2021-05-27 09:00:00":269,"2021-05-27 10:00:00":352,"2021-05-27 11:00:00":459,"2021-05-27 12:00:00":540,"2021-05-27 13:00:00":596,"2021-05-27 14:00:00":623,"2021-05-27 15:00:00":605,"2021-05-27 16:00:00":596,"2021-05-27 17:00:00":547,"2021-05-27 18:00:00":461,"2021-05-27 19:00:00":352,"2021-05-27 20:00:00":193,"2021-05-27 20:51:00":27,"2021-05-27 21:42:00":0},"watt_hours":{"2021-05-26 05:21:00":0,"2021-05-26 05:33:00":0,"2021-05-26 05:45:00":4,"2021-05-26 06:00:00":11,"2021-05-26 07:00:00":101,"2021-05-26 08:00:00":280,"2021-05-26 09:00:00":556,"2021-05-26 10:00:00":952,"2021-05-26 11:00:00":1561,"2021-05-26 12:00:00":2135,"2021-05-26 13:00:00":2789,"2021-05-26 14:00:00":3548,"2021-05-26 15:00:00":4328,"2021-05-26 16:00:00":5038,"2021-05-26 17:00:00":5631,"2021-05-26 18:00:00":6131,"2021-05-26 19:00:00":6462,"2021-05-26 20:00:00":6626,"2021-05-26 20:51:00":6644,"2021-05-26 21:41:00":6644,"2021-05-27 05:20:00":0,"2021-05-27 05:33:00":0,"2021-05-27 05:45:00":2,"2021-05-27 06:00:00":9,"2021-05-27 07:00:00":90,"2021-05-27 08:00:00":260,"2021-05-27 09:00:00":529,"2021-05-27 10:00:00":880,"2021-05-27 11:00:00":1340,"2021-05-27 12:00:00":1879,"2021-05-27 13:00:00":2475,"2021-05-27 14:00:00":3098,"2021-05-27 15:00:00":3703,"2021-05-27 16:00:00":4299,"2021-05-27 17:00:00":4845,"2021-05-27 18:00:00":5307,"2021-05-27 19:00:00":5658,"2021-05-27 20:00:00":5851,"2021-05-27 20:51:00":5873,"2021-05-27 21:42:00":5873},"watt_hours_day":{"2021-05-26":6644,"2021-05-27":5873}},"message":{"code":0,"type":"success","text":"","info":{"place":"Nordrhein-Westfalen, DE","timezone":"Europe/Berlin","distance":24.35},"ratelimit":{"period":3600,"limit":12,"remaining":9}}}
                          @jb_sullivan werde ich mir gerne am Wochenende an schauen, klappt bei die Public Version?
                          @Glasfaser gerne kann ich versuchen die Json Daten Punkte zu übernehmen.
                          Für Ideen bin ich auch offen, bis jetzt war nur die Basic Version angedacht.
                          • JB_Sullivan
                            @patrickwalther Public habe ich auch probiert - die Datenpunkte bleiben alle leer und der Adapter geht in den oben beschriebenen Fehler - egal ob Public oder Personal.
                              PatrickWalther Developer last edited by
                              @jb_sullivan hast du im Link ein Leerzeichen am Ende? Dann wurde es auch nicht Funktionieren.
                              • michl75
                                michl75 @PatrickWalther last edited by michl75
                                Guten Morgen, habe diesen Adapter eben auch ausprobiert da es mich sehr interessiert....
                                ...funktioniert gut, super - genau das was ich gesucht habe.
                                  @glasfaser
                                  Hast du eine Wunschliste?
                                  • JosnGraph
                                  • zwei Anlagen (Gesamt Leistung)
                                    holgerwolf @PatrickWalther last edited by
                                    Geht das nicht mit zwei Instanzen?
                                      PatrickWalther Developer last edited by PatrickWalther
                                      @holgerwolf
                                      Man könnte zwei Instanzen installieren und die addieren.
                                        PatrickWalther Developer @PatrickWalther last edited by
                                        Die Tage kommt da neue Updaten mit Jsontabelle & Jsongraph. Desweiteren können zwei Anlagen eingetragen werden, diese werden auch zusammen gerechnet und als extra Datenpunkte angelegt.
                                        H L 2 Replies Last reply Reply Quote 1
                                          @patrickwalther 👍
                                          • michl75
                                            @patrickwalther
                                            Hallo, ich habe mir den Adapter installiert und über Public getestet. Mir gefällt es super und habe mir so dann auch den "Personal" API Schlüssel gegen € geholt.
                                            Habe nun festgestellt, das seit dem 28.5. die Daten nicht mehr aktualisiert werden. Habe es zum testen heute eben wieder umgestellt auf Public und schon sind Daten wieder vorhanden.
                                            Auf Personal passiert anscheinen keine Aktualisierung... Habe auch einmal vorsichtshalber neu installiert und auch nochmal einen API Schlüssel geholt. Trotzdem keine Aktualisierung....
                                            Das Log gibt nichts aus !
                                            Viele Grüße M.
                                            1.0k
                                            forecast photovoltaik
                                            113
                                            879
                                            279448
