    4. Erstinstallation iob mit CC26X2R1 - failed to start zigbee
      arteck Developer Most Active @Aprozz last edited by
      @aprozz und das board hast du geflasht ?
        Aprozz @arteck last edited by
        @arteck
        Das Board habe ich mit dem Uniflash 6.3 und dem image "CC2652R_coordinator_20210120.hex" geflasht. Die Pruefung viel positiv aus.
          arteck Developer Most Active @Aprozz last edited by arteck
          @aprozz das gibts doch nicht...hast due kiste mal neu gestartet ?
          wenn ja dann bitte adapter auf debug stellen und LOG posten
          A 3 Replies Last reply Reply Quote 0
            @arteck
            Hab den PI heute morgen mit "sudo shutdown -r now" neugestartet. Kann ich gleich nochmals probieren.
            v522533 1 Reply Last reply Reply Quote 0
              @arteck
              at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:220:55)
              at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:240:16)
              at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:303:31)
              at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:228:49)
              at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:222:43)
              at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:214:42)
              at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:385:20)
              at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:696:41)
              at processTicksAndRejections (internal/process/task_queues.js:97:5)
              2021-05-27 10:14:21.281 - error: zigbee.0 (1444) Cannot read property 'getEntries' of null
              2021-05-27 10:14:21.823 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2021-05-27 10:52:40.652 - info: host.raspberrypi "system.adapter.zigbee.0" enabled
              2021-05-27 10:52:40.707 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 1503
              2021-05-27 10:52:43.127 - info: zigbee.0 (1503) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.2.16
              2021-05-27 10:52:43.222 - info: zigbee.0 (1503) Starting Zigbee npm ...
              2021-05-27 10:52:43.441 - error: zigbee.0 (1503) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-idusb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100MXG-if00'"
              2021-05-27 10:52:43.442 - error: zigbee.0 (1503) Failed to start Zigbee
              2021-05-27 10:52:43.442 - error: zigbee.0 (1503) Error herdsman start
              2021-05-27 10:52:43.507 - info: zigbee.0 (1503) Installed Version: ioBroker/ioBroker.zigbee#50d5b069ff6756f41fcda6af42a9faf01969462d
              2021-05-27 10:52:53.444 - info: zigbee.0 (1503) Try to reconnect. 1 attempts left
              2021-05-27 10:52:53.446 - info: zigbee.0 (1503) Starting Zigbee npm ...
              2021-05-27 10:52:53.455 - error: zigbee.0 (1503) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-idusb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100MXG-if00'"
              2021-05-27 10:52:53.456 - error: zigbee.0 (1503) Failed to start Zigbee
              2021-05-27 10:52:53.458 - error: zigbee.0 (1503) Error herdsman start
              2021-05-27 10:52:53.467 - info: zigbee.0 (1503) Installed Version: ioBroker/ioBroker.zigbee#50d5b069ff6756f41fcda6af42a9faf01969462d
              • v522533
                v522533 @Aprozz last edited by
                @aprozz
                ich hatte das auch schonmal. Versuch mal folgendes:
                1. Zigbee Adapter stoppen
                2. Stick abziehen
                3. ca. 10 Sek warten
                4. Stick wieder einstecken
                5. Adapter starten
                Bei mir hat das funktioniert, warum weiss ich nicht 😉
                  @arteck
                  Und jetzt der log nach dem Neustart;
                  2021-05-27 10:55:27.239 - info: zigbee.0 (1503) Got terminate signal TERMINATE_YOURSELF
                  2021-05-27 10:55:27.288 - info: zigbee.0 (1503) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                  2021-05-27 10:55:27.743 - info: host.raspberrypi instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                  2021-05-27 10:55:27.774 - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                  2021-05-27 10:55:27.785 - info: host.raspberrypi instance system.adapter.info.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                  2021-05-27 10:55:27.844 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                  2021-05-27 10:55:27.845 - info: host.raspberrypi All instances are stopped.
                  2021-05-27 10:55:27.957 - info: host.raspberrypi terminated
                  2021-05-27 10:55:46.720 - info: host.raspberrypi iobroker.js-controller version 3.2.16 js-controller starting
                  2021-05-27 10:55:46.726 - info: host.raspberrypi Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
                  2021-05-27 10:55:46.726 - info: host.raspberrypi hostname: raspberrypi, node: v12.22.1
                  2021-05-27 10:55:46.727 - info: host.raspberrypi ip addresses: 192.168.178.47 fe80::c55c:c16:1073:a262
                  2021-05-27 10:55:47.116 - info: host.raspberrypi connected to Objects and States
                  2021-05-27 10:55:47.143 - info: host.raspberrypi added notifications configuration of host
                  2021-05-27 10:55:47.634 - info: host.raspberrypi 4 instances found
                  2021-05-27 10:55:47.651 - info: host.raspberrypi starting 4 instances
                  2021-05-27 10:55:47.708 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 579
                  2021-05-27 10:55:49.902 - info: admin.0 (579) starting. Version 4.2.1 in /opt/iobroker/node_modules/iobroker.admin, node: v12.22.1, js-controller: 3.2.16
                  2021-05-27 10:55:49.953 - info: admin.0 (579) requesting all states
                  2021-05-27 10:55:49.954 - info: admin.0 (579) requesting all objects
                  2021-05-27 10:55:50.228 - info: admin.0 (579) received all objects
                  2021-05-27 10:55:50.363 - info: admin.0 (579) http server listening on port 8081
                  2021-05-27 10:55:50.364 - info: admin.0 (579) Use link "http://localhost:8081" to configure.
                  2021-05-27 10:55:51.700 - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 594
                  2021-05-27 10:55:53.265 - info: discovery.0 (594) starting. Version 2.6.1 in /opt/iobroker/node_modules/iobroker.discovery, node: v12.22.1, js-controller: 3.2.16
                  2021-05-27 10:55:55.709 - info: host.raspberrypi instance system.adapter.info.0 started with pid 609
                  2021-05-27 10:55:58.582 - info: info.0 (609) starting. Version 1.7.14 in /opt/iobroker/node_modules/iobroker.info, node: v12.22.1, js-controller: 3.2.16
                  2021-05-27 10:55:59.671 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 815
                  2021-05-27 10:56:17.071 - info: zigbee.0 (815) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.2.16
                  2021-05-27 10:56:17.200 - info: zigbee.0 (815) Starting Zigbee npm ...
                  2021-05-27 10:56:17.511 - error: zigbee.0 (815) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-idusb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100MXG-if00'"
                  2021-05-27 10:56:17.512 - error: zigbee.0 (815) Failed to start Zigbee
                  2021-05-27 10:56:17.512 - error: zigbee.0 (815) Error herdsman start
                  2021-05-27 10:56:17.581 - info: zigbee.0 (815) Installed Version: ioBroker/ioBroker.zigbee#50d5b069ff6756f41fcda6af42a9faf01969462d
                  2021-05-27 10:56:27.514 - info: zigbee.0 (815) Try to reconnect. 1 attempts left
                  2021-05-27 10:56:27.515 - info: zigbee.0 (815) Starting Zigbee npm ...
                  2021-05-27 10:56:27.523 - error: zigbee.0 (815) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-idusb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100MXG-if00'"
                  2021-05-27 10:56:27.524 - error: zigbee.0 (815) Failed to start Zigbee
                  2021-05-27 10:56:27.525 - error: zigbee.0 (815) Error herdsman start
                  2021-05-27 10:56:27.530 - info: zigbee.0 (815) Installed Version: ioBroker/ioBroker.zigbee#50d5b069ff6756f41fcda6af42a9faf01969462d
                    Aprozz @v522533 last edited by
                    @v522533
                    Danke fuer den Tipp, kann ich leider erst heute Abend ausprobieren...
                      @aprozz
                      hier ist das problem
                      so muss das
                      /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100MXG-if00
                      wenns immer noch nicht geht zeigmal
                      ls -l /dev/serial/by-id
                        @arteck
                        Ich fress einen Besen! hab bestimmt schon zwei oder dreimal den Pfad kopiert.
                        Danke fuer die Hilfe, es laeuft jetzt. 👍
                          @aprozz setzt bitte den Beitrag auf gelöst
                          gelöst
                          705
