    4. PH-Messung
    PH-Messung
    • Marc R
      Marc R @Anti last edited by
      @anti you mean load something like Tasmota on the existing ESP? I have a lot of Sonoff switches which I "tasmotized", so I know how that works, but I'm not sure if the PH-803W would be compatible?
        Anti @Marc R last edited by
        @marc-r I'm not so deep in the MQTT/Tasmota Topic. So not sure what you can do with Tasmota, here in this use case we want to put a serial Input somewhere. When Tasmota can do that, you should be okay with that. I was thinking about a little Programm on ESP putting the serial e.g. on a Webpage. This is probably a few minutes programming Job. I think i prefare this, because my Pool also will be controlled by an ESP. If a Server is in the middle is one more thing that can fail.
        But anyway i can wait if the other guys here find the "LAN Protocol" Solution. If i can use that from another ESP, i will probably make like this.
        Well i just thought i can connect the 803W serial connect directly my control ESP ... this is also a good failsafe alternative.
        • Marc R
          @anti Tasmota is an awesome open-source firmware for all kinds of ESP8266 devices to connect them via MQTT to automation systems such as Home Assistant and others. Have a look here: https://tasmota.github.io/docs/
          I virtually loaded it on about 60 devices so far, but try are Sonoff and Shelly switches and I'm not sure how the PH-803W would handle it.
          I'm just adding this as another alternative to the paths you guys are already following. I'm not saying it's better or worse. If you guys find a fairly simple way to send the PH-803W data to MQTT, I'm all for it!
            apollon77 last edited by
            Ok, mit weiteren Wireshark Mitschnitten von @coyote bin ich denke etwas weiter ... immer noch viele Annahmen, daber die kann man dann ja mal verifizieren. habe auch eine vermutung wo die Schaltwerte stecken (Bit flags) und würde tippen das andere Bits da drin vllt im Display für Anzeigen genutzt werden ...
            Ich habe mal alles unter https://github.com/Apollon77/node-ph803w/blob/main/PROTOCOL.md zusammengefasst.
            Als nächstes schaue ich mal das ich das als node.js Library implementiere
            Ich habe auch für "unsere ESP Freunde" mal eine vermutete minimale Kommunikation unter https://github.com/Apollon77/node-ph803w/blob/main/PROTOCOL.md#minimum-interaction-scheme aufgeschrieben ... wäre zu verifizieren ...
            Have fun
            C 1 Reply Last reply Reply Quote 2
              Chaosbrother @apollon77 last edited by
              @apollon77 Respekt.👍 Aber ich versteh nur noch Bahnhof🙄 . Mal abwarten wie es weitergeht.
              Trotzdem DANKE für die Info´s und deine Mühe
                apollon77 last edited by apollon77
                Ok, dann mal nächster Schritt ... ich hab mal was gebaut.
                • Man nehme am besten einen Rechner wo nodejs drauf ist (also der von iobroker ist super)
                • per SSH einloggen und in das Vezeichnis gehen
                • Man lege sich ein neues Verzechnis an, am besten direkt im User-Verzeichnis (also NICHT!! in /opt/iobroker)
                • npm install Apollon77/node-ph803w
                • cd node_modules/node-ph803w/example
                • node data.js 111.222.333.444 (mit 111.222.333.444 die IP des PH803W Geräts im lokalen Netzwerk
                Dann sollte sich das Beispielskript verbinden, Passcode holen, einloggen und jede Datenänderung die es gibt sollte eine Logzeile geben mit den Werten. Eine Datenzeile muss in jedem Fall kommen - hoffentlich mehr sobald sich was ändert. Das nehme ich gern mal.
                Falls irgendwas nicht geht bitte mal unter Linux mit DEBUG=ph803w* node data.js 111.222.333.444 starten, dann sollte mehr log kommen.
                Zu testen ist:
                • Das die werte mit dem Display passen und idealerweise auch was die "Schaltzustände" angeht
                • Das bei Änderungen neue Werte kommen (es ist immer noch ein bissl unklar welches Kommando das auslöst)
                • Die zwei "binFlag1/2" Felder haben vermutlich eine Verbindung zu DIngen im Display (annahme). Das wäre zu prüfen und hier schreiben zu was was gehört 🙂
                Dann schauen wir mal wie gut blindes Programmieren so tut 🙂
                Ingo
                  SoerenKaiser99 @apollon77 last edited by
                  @apollon77
                  Coole Nummer 😄
                  Es ginge aber auch (ein wenig einfacher) mit nem Wemos D1 / NodeMCU und ner analogen PH Sonde :D... Nur so nebenbei 👍
                  Wemos D1 PH-Sonde
                  U apollon77 2 Replies Last reply Reply Quote 0
                    Anti last edited by
                    Wo bleibt denn da der Spaß? 😛
                    Nein ist natürlich auch ein weg. Hab sowas sogar hier liegen war irgendwie nie dazu gekommen das weiterzuverfolgen 😕
                      SoerenKaiser99 @Anti last edited by
                      @anti weis ich doch. War ein wenig ironisch gemeint 🙂 Versteh schon.. Herrausforderung und so.
                      Hatte ich auch vor... Bin dann aber die Tage mangels Zeit umgeschwenkt. Jetzt regelt die phileo den pH wert, n shelly steuert den Chlorinator und die Pumpe ( danke an paul 😄 ) und n blueconnect sendet stündlich die Daten 😄 ... läuft!
                      • U
                        UncleB @SoerenKaiser99 last edited by
                        @soerenkaiser99 hast du ne Ahnung welche Sonde der Herr genau verwendet?
                          apollon77 @SoerenKaiser99 last edited by
                          @soerenkaiser99 ich denke nur eine Sonde ist einfacher als zwei weil die challenges bei zwei Sonden sind größer wegen galvanischer Trennung und Dingen das sich die Sonden nicht gegenseitig beeinflussen. Aber ja.
                          Ich persönlich bastele lieber mit Software als mit Hardware (hab gelernt das ich bei Zweiterem für mich ein besseres Aufwand-nutzen-Frust Verhältnis habe) ;-)) ich hab bei mir auch in Summe drei arduinos im Haus verbaut für Dinge und hoffe das geht nie wieder kaputt weil ich fadt nicht mehr weiß wie das alles war und worauf ich achten muss 😉
                          coyote S 2 Replies Last reply Reply Quote 1
                          • coyote
                            coyote Most Active @apollon77 last edited by
                            @apollon77
                            Wollte mal installieren, aber...
                            /home/coyote/ph803w# npm install Apollon77/node-ph803w
                            npm ERR! Can't install github:Apollon77/node-ph803w#f51066522bac3a191b11010126e6aaf2ccf48e7f: Missing package version
                            npm ERR!     /root/.npm/_logs/2021-05-28T05_48_51_894Z-debug.log
                              apollon77 @coyote last edited by
                              @coyote Erwischt ... retry please
                              • coyote
                                @apollon77
                                Schätze das ist ok so:
                                root@debian:/home/coyote/ph803w# npm install Apollon77/node-ph803w        npm WARN saveError ENOENT: no such file or directory, open '/home/coyote/ph803w/        package.json'
                                npm notice created a lockfile as package-lock.json. You should commit this file.
                                npm WARN enoent ENOENT: no such file or directory, open '/home/coyote/ph803w/pac        kage.json'
                                npm WARN ph803w No description
                                npm WARN ph803w No repository field.
                                npm WARN ph803w No README data
                                npm WARN ph803w No license field.
                                + node-ph803w@0.0.1
                                added 3 packages from 4 contributors and audited 3 packages in 4.175s
                                found 0 vulnerabilities
                                   │      New major version of npm available! 6.14.12 → 7.15.0      │
                                   │   Changelog: https://github.com/npm/cli/releases/tag/v7.15.0   │
                                   │               Run npm install -g npm to update!                │
                                  @coyote Ja
                                    skinni @apollon77 last edited by
                                    Hab keine Sonden angeschlossen, aber soweit siehts gut aus. Ich freu mich auf den adapter 😇
                                    Data: {"binFlags1":"11","binFlags2":"10","ph":7.77,"redox":-44,"phSwitch":false,"redoxSwitch":true}
                                    Data: {"binFlags1":"100","binFlags2":"10","ph":7.76,"redox":-44,"phSwitch":false,"redoxSwitch":true}
                                    Data: {"binFlags1":"100","binFlags2":"10","ph":7.76,"redox":-38,"phSwitch":false,"redoxSwitch":true}
                                    Data: {"binFlags1":"100","binFlags2":"10","ph":7.77,"redox":-68,"phSwitch":false,"redoxSwitch":true}
                                    Data: {"binFlags1":"100","binFlags2":"10","ph":7.8,"redox":-69,"phSwitch":false,"redoxSwitch":true}
                                    Data: {"binFlags1":"100","binFlags2":"10","ph":7.81,"redox":-70,"phSwitch":false,"redoxSwitch":true}
                                    Data: {"binFlags1":"100","binFlags2":"10","ph":7.83,"redox":-72,"phSwitch":false,"redoxSwitch":true}
                                    Data: {"binFlags1":"100","binFlags2":"10","ph":7.83,"redox":-73,"phSwitch":false,"redoxSwitch":true}
                                    Data: {"binFlags1":"100","binFlags2":"10","ph":7.82,"redox":-73,"phSwitch":false,"redoxSwitch":true}
                                      apollon77 @skinni last edited by
                                      @skinni Cool, Danke, Passen auch die Schalter-Zustände?
                                      Und ja jetzt wäre jemand mit Sonden im Wasser durchaus cool der mal mehr vergleichen kann was die Anzeigen im Display und Schaltzustände angeht und so 🙂
                                      S coyote 2 Replies Last reply Reply Quote 0
                                        @apollon77 Zustände passen, PH ist aus, ORP ist an
                                        • coyote
                                          @apollon77 👏 👏 👏 👏
                                          Mega👍 Das sieht schon sehr gut aus. Muss @skinni zustimmen, passt alles soweit, auch die Schaltzustände. Gute Arbeit Apollon
                                          S apollon77 2 Replies Last reply Reply Quote 0
                                            skinni @coyote last edited by skinni
                                            Hier hat sich ein Schaltzustand geändert
                                            Data: {"binFlags1":"100","binFlags2":"10","ph":7.15,"redox":6,"phSwitch":false,"redoxSwitch":true}
                                            Data: {"binFlags1":"100","binFlags2":"0","ph":7.12,"redox":51,"phSwitch":false,"redoxSwitch":false}
                                            und wieder zurück
                                            Data: {"binFlags1":"100","binFlags2":"0","ph":7.22,"redox":-2,"phSwitch":false,"redoxSwitch":false}
                                            Data: {"binFlags1":"100","binFlags2":"10","ph":7.22,"redox":-2,"phSwitch":false,"redoxSwitch":true}
                                            1.0k
                                            432
                                            102952
