    4. PH-Messung
    PH-Messung
    • coyote
      coyote Most Active @apollon77 last edited by
      @apollon77
      Wollte mal installieren, aber...
      /home/coyote/ph803w# npm install Apollon77/node-ph803w
      npm ERR! Can't install github:Apollon77/node-ph803w#f51066522bac3a191b11010126e6aaf2ccf48e7f: Missing package version
      npm ERR!     /root/.npm/_logs/2021-05-28T05_48_51_894Z-debug.log
        apollon77 @coyote last edited by
        @coyote Erwischt ... retry please
        • coyote
          @apollon77
          Schätze das ist ok so:
          root@debian:/home/coyote/ph803w# npm install Apollon77/node-ph803w        npm WARN saveError ENOENT: no such file or directory, open '/home/coyote/ph803w/        package.json'
          npm notice created a lockfile as package-lock.json. You should commit this file.
          npm WARN enoent ENOENT: no such file or directory, open '/home/coyote/ph803w/pac        kage.json'
          npm WARN ph803w No description
          npm WARN ph803w No repository field.
          npm WARN ph803w No README data
          npm WARN ph803w No license field.
          + node-ph803w@0.0.1
          added 3 packages from 4 contributors and audited 3 packages in 4.175s
          found 0 vulnerabilities
             │      New major version of npm available! 6.14.12 → 7.15.0      │
             │   Changelog: https://github.com/npm/cli/releases/tag/v7.15.0   │
             │               Run npm install -g npm to update!                │
            @coyote Ja
              skinni @apollon77 last edited by
              Hab keine Sonden angeschlossen, aber soweit siehts gut aus. Ich freu mich auf den adapter 😇
              Data: {"binFlags1":"11","binFlags2":"10","ph":7.77,"redox":-44,"phSwitch":false,"redoxSwitch":true}
              Data: {"binFlags1":"100","binFlags2":"10","ph":7.76,"redox":-44,"phSwitch":false,"redoxSwitch":true}
              Data: {"binFlags1":"100","binFlags2":"10","ph":7.76,"redox":-38,"phSwitch":false,"redoxSwitch":true}
              Data: {"binFlags1":"100","binFlags2":"10","ph":7.77,"redox":-68,"phSwitch":false,"redoxSwitch":true}
              Data: {"binFlags1":"100","binFlags2":"10","ph":7.8,"redox":-69,"phSwitch":false,"redoxSwitch":true}
              Data: {"binFlags1":"100","binFlags2":"10","ph":7.81,"redox":-70,"phSwitch":false,"redoxSwitch":true}
              Data: {"binFlags1":"100","binFlags2":"10","ph":7.83,"redox":-72,"phSwitch":false,"redoxSwitch":true}
              Data: {"binFlags1":"100","binFlags2":"10","ph":7.83,"redox":-73,"phSwitch":false,"redoxSwitch":true}
              Data: {"binFlags1":"100","binFlags2":"10","ph":7.82,"redox":-73,"phSwitch":false,"redoxSwitch":true}
                apollon77 @skinni last edited by
                @skinni Cool, Danke, Passen auch die Schalter-Zustände?
                Und ja jetzt wäre jemand mit Sonden im Wasser durchaus cool der mal mehr vergleichen kann was die Anzeigen im Display und Schaltzustände angeht und so 🙂
                S coyote 2 Replies Last reply Reply Quote 0
                  @apollon77 Zustände passen, PH ist aus, ORP ist an
                  • coyote
                    @apollon77 👏 👏 👏 👏
                    Mega👍 Das sieht schon sehr gut aus. Muss @skinni zustimmen, passt alles soweit, auch die Schaltzustände. Gute Arbeit Apollon
                    S apollon77 2 Replies Last reply Reply Quote 0
                      skinni @coyote last edited by skinni
                      Hier hat sich ein Schaltzustand geändert
                      Data: {"binFlags1":"100","binFlags2":"10","ph":7.15,"redox":6,"phSwitch":false,"redoxSwitch":true}
                      Data: {"binFlags1":"100","binFlags2":"0","ph":7.12,"redox":51,"phSwitch":false,"redoxSwitch":false}
                      und wieder zurück
                      Data: {"binFlags1":"100","binFlags2":"0","ph":7.22,"redox":-2,"phSwitch":false,"redoxSwitch":false}
                      Data: {"binFlags1":"100","binFlags2":"10","ph":7.22,"redox":-2,"phSwitch":false,"redoxSwitch":true}
                        apollon77 @coyote last edited by apollon77
                        @coyote was idealerweise noch fehlt ist die Verbindung zwischen dem „binFlag1“ Inhalt und dem Display oder so herzustellen. Bisher kennen wir nur die Bedeutung der zwei Bits von binFlag2.
                        Aber denke da muss man echt mal mehr anschauen wenn sich da mal Dinge ändern.
                        @coyote bei dir hatte sind bei dem einen Test mit Wasser letztens 3 Bits in dem binFlag1 geändert über die Zeit. Meine Vermutung ist das das Display anzeigen sind. Also beobachtet bitte mal in die Richtung ob es da Zusammenhänge gibt. Dann hätten wir noch mehr Infos.
                        Als Nächstes würde ich noch discovery einbauen um die Geräte im Netzwerk zu finden. Und dann kann man da nen adapter zusammenklöppeln.
                        Achja: testet bitte auch mal den Auto reconnect. Also schaltet gerät aus während lib verbunden ist und wieder an und schaut das danach wieder Daten kommen.
                        Bitte vor dem Test nochmal die aktuellste Version installieren (das npm install nochmal machen)
                          Reconnect hatte vorhin nicht geklappt, das hatte ich als erstes versucht. Dachte soweit sind wir noch nicht.
                          Update geht leider nicht:
                          npm ERR! code ENOSELF
                          npm ERR! Refusing to install package with name "node-ph803w" under a package
                          npm ERR! also called "node-ph803w". Did you name your project the same
                          npm ERR! as the dependency you're installing?
                          npm ERR!
                          npm ERR! For more information, see:
                          npm ERR!     <https://docs.npmjs.com/cli/install#limitations-of-npms-install-algorithm>
                          npm ERR!     /home/pi/.npm/_logs/2021-05-28T07_30_16_009Z-debug.log
                          foxriver76 coyote 2 Replies Last reply Reply Quote 0
                          • foxriver76
                            foxriver76 Developer @skinni last edited by foxriver76
                            @skinni Du musst den Schritt wieder im gleichen Folder wie beim ersten mal ausführen und nicht im Folder des Packages, sonst würde er eine Abhängigkeit zu sich selbst herstellen.
                            Im Folder des Packages sollte npm update tun, aber noch nie selbst probiert.
                            • coyote
                              @apollon77 das binFlag2 könnte was mit den Relais Ausgängen zu tun haben oder?
                              Oben bei skinni ist es 0, wenn bei Ausgänge "false" und 10 wenn RedoxSwitch "true"
                              Auf dem Display sind noch 2 Pfeile (wobei eigentlich 4) die blinken, wenn die Ausgänge geschaltet sind, es gibt für beide Werte jeweils einen pfeil nach oben und nach unten.
                              • coyote
                                coyote Most Active @skinni last edited by
                                @skinni also bei mir funktioniert die npm Installation, wenn ich es im User Verzeichnis nochmal drüber bügele
                                  SoerenKaiser99 @UncleB last edited by
                                  @uncleb ist drunter Kommentiert, diese https://amzn.to/3ft8qOj
                                    SoerenKaiser99 @apollon77 last edited by
                                    @apollon77 Hast ja recht, war auch eher mit nem Augenzwinkern gemeint 😜 sorry für den Offtopic
                                      skinni @foxriver76 last edited by
                                      sorry mein Fehler, bin aus dem Verzeichnis raus, dann hats geklappt.
                                      Reconnect geht aber immer noch nicht:
                                        ph803w:device Send ping +4s
                                        ph803w:device received pong +3ms
                                        ph803w:device Retrieved data: {"binFlags1":"100","binFlags2":"10","ph":7.7,"redox":-151,"phSwitch":false,"redoxSwitch":true} +2s
                                      Data: {"binFlags1":"100","binFlags2":"10","ph":7.7,"redox":-151,"phSwitch":false,"redoxSwitch":true}
                                        ph803w:device Ignore resolve for message type 145 because no promise stored: {"binFlags1":"100","binFlags2":"10","ph":7.7,"redox":-151,"phSwitch":false,"redoxSwitch":true} +0ms
                                        ph803w:device Send ping +2s
                                        ph803w:device Ping response overdue, reconnect +8s
                                      Ab da kommt nix mehr
                                        @skinni ok dann schaue ich heute abend nochmal
                                          @coyote also ja die beiden Relais hab ich ja in binFlag2 gefunden. Da holt er die True/false auch her. Frage ist jetzt ob noch andere Dinge vom Display (Annahme vor allem in binFlag1) eine Korrelation haben. Mal mindestens drei der Bits haben sich bisher generell mal geändert.
                                          • coyote
                                            @apollon77 wo find ich denn binFlag1/2 in Wireshark?
                                            1.0k
                                            432
                                            102952
