    4. Zigbee Adapter keine Verbindung zu CC2531
    • DK43
      DK43 last edited by
      Hab seit 1 Woche das gleiche Problem. Es wurde nichts gemacht. Keine Updates oder ähnliches.
      Hab dann versucht mit Backitup eine ältere Sicherung wiederherzustellen. Ohne Erfolg.
      Verbunden mit ZigBee : Falsch
      Wenn ich die Adapterkonfiguration öffne kommt :
      Error
      You need save and run adapter before pairing!
      zigbee.0	2021-05-17 00:14:05.540	error	at /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
      zigbee.0	2021-05-17 00:14:05.540	error	at SerialPort._error (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
      zigbee.0	2021-05-17 00:14:05.540	error	at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49)
      zigbee.0	2021-05-17 00:14:05.540	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12)
      zigbee.0	2021-05-17 00:14:05.540	error	at new Promise (<anonymous>)
      zigbee.0	2021-05-17 00:14:05.540	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71
      zigbee.0	2021-05-17 00:14:05.540	error	at Generator.next (<anonymous>)
      zigbee.0	2021-05-17 00:14:05.540	error	at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32)
      zigbee.0	2021-05-17 00:14:05.540	error	(31283) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
      zigbee.0	2021-05-17 00:14:05.538	error	(31283) Failed to start Zigbee
      zigbee.0	2021-05-17 00:14:00.214	info	(31283) Installed Version: iobroker.zigbee@1.4.4
      zigbee.0	2021-05-17 00:14:00.167	info	(31283) Starting Zigbee npm ...
      zigbee.0	2021-05-17 00:14:00.164	info	(31283) Try to reconnect. 1 attempts left
      zigbee.0	2021-05-17 00:13:50.160	error	at rejected (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:25:65)
      zigbee.0	2021-05-17 00:13:50.160	error	at Generator.throw (<anonymous>)
      zigbee.0	2021-05-17 00:13:50.160	error	at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:94:31)
      zigbee.0	2021-05-17 00:13:50.160	error	(31283) Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
      zigbee.0	2021-05-17 00:13:50.155	error	(31283) Failed to start Zigbee
      zigbee.0	2021-05-17 00:13:10.524	info	(31283) Installed Version: iobroker.zigbee@1.4.4
      zigbee.0	2021-05-17 00:13:08.658	info	(31283) Starting Zigbee npm ...
      zigbee.0	2021-05-17 00:13:08.337	info	(31283) starting. Version 1.4.4 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.20.1, js-controller: 3.2.16
      host.raspberrypi	2021-05-17 00:13:00.535	info	instance system.adapter.zigbee.0 started with pid 31283
      host.raspberrypi	2021-05-17 00:12:54.340	info	Do not restart adapter system.adapter.zigbee.0 because desired by instance
      host.raspberrypi	2021-05-17 00:12:54.338	error	instance system.adapter.zigbee.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
      host.raspberrypi	2021-05-17 00:12:30.454	info	Restart adapter system.adapter.zigbee.0 because enabled
      host.raspberrypi	2021-05-17 00:12:30.438	error	instance system.adapter.zigbee.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      zigbee.0	2021-05-17 00:12:29.502	warn	(31271) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      zigbee.0	2021-05-17 00:12:29.495	error	(31271) zigbee.0 already running
      zigbee.0	2021-05-17 00:12:17.892	warn	(22529) Got terminate signal. Checking desired PID: 31271 vs own PID 22529
      zigbee.0	2021-05-17 00:12:17.843	error	(22529) Cannot read property 'getEntries' of null
      zigbee.0	2021-05-17 00:12:17.841	error	at stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8620:22)
      zigbee.0	2021-05-17 00:12:17.841	error	at Zigbee.emit (events.js:314:20)
      zigbee.0	2021-05-17 00:12:17.841	error	at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:581:41)
      zigbee.0	2021-05-17 00:12:17.841	error	at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:310:20)
      zigbee.0	2021-05-17 00:12:17.841	error	at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:192:42)
      zigbee.0	2021-05-17 00:12:17.841	error	at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:222:43)
      zigbee.0	2021-05-17 00:12:17.841	error	at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:206:49)
      zigbee.0	2021-05-17 00:12:17.841	error	at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:295:31)
      zigbee.0	2021-05-17 00:12:17.841	error	at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:241:16)
      zigbee.0	2021-05-17 00:12:17.841	error	at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:221:55)
      zigbee.0	2021-05-17 00:12:17.841	error	(22529) TypeError: Cannot read property 'getEntries' of null
      zigbee.0	2021-05-17 00:12:17.810	error	(22529) unhandled promise rejection: Cannot read property 'getEntries' of null
      zigbee.0	2021-05-17 00:12:17.809	error	(22529) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      zigbee.0	2021-05-17 00:12:17.805	info	(22529) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      zigbee.0	2021-05-17 00:12:17.801	info	(22529) terminating
      zigbee.0	2021-05-17 00:12:17.799	warn	(22529) Failed to stop zigbee during startup
      zigbee.0	2021-05-17 00:12:17.793	info	(22529) Zigbee: disabling joining new devices.
      zigbee.0	2021-05-17 00:12:17.722	info	(22529) cleaned everything up...
      zigbee.0	2021-05-17 00:12:17.692	warn	(22529) Got terminate signal. Checking desired PID: 0 vs own PID 22529
      host.raspberrypi	2021-05-17 00:12:17.820	info	instance system.adapter.zigbee.0 started with pid 31271
      latform
      linux
      Betriebssystem
      linux
      Architektur
      arm
      CPUs
      Geschwindigkeit
      600 MHz
      Modell
      ARMv7 Processor rev 4 (v7l)
      RAM
      924.21 MB
      System Betriebszeit
      36 T. 05:57:46
      Node.js
      v12.20.1 (Es gibt eine neuere Version: v12.22.1)
      NPM
      6.14.10
      Festplatte Größe
      14.33 GB
      Festplatte frei
      7.52 GB
      Anzahl der Adapter
      340
      Betriebszeit
      5 T. 02:19:30
      Aktive Instanzen
      13
      Hostname
      raspberrypi
      • Asgothian
        Asgothian Developer @DK43 last edited by Asgothian
        @davut-karabulut
        • Es fehlt die initiale Fehlermeldung. Die Meldungen die du gepostet hast (Insbesondere die untere von 00:12:17.805) deuten darauf hin das der Zigbee Adapter beendet wird nachdem er nicht sauber starten konnte. Das bedeutet das es davor noch Meldungen geben muss die auf den eigentlichen Fehler hin deuten
        • Die Meldung "resource temporarily unavailable cannot lock port" deutet darauf hin das der serielle Port belegt ist
        • Die Meldung "(Error: SRSP - SYS - ping after 6000ms)" Deutet darauf hin das die Firmware auf dem cc2531 sich nicht meldet.
        Es bleiben daher die Folgenden Ursachen übrig:
        • die Firmware auf dem Stick ist abgestürzt. Lösung dazu: Stick abziehen, 30 sekunden warten, Stick anstecken.
        • Es gibt Störungen auf dem USB Zweig (oft verursacht durch USB3 Geräte, insbesondere Festplatten / SSD's)
        • Die Firmware auf dem Stick ist defekt. Der Stick muss neu geflashed werden.
          Stefan_TR96 @Asgothian last edited by
          Habe ebenfalls seit kurzem ein Problem. Das System ist über einen Zeitraum von rund 2 Jahren fehlerfrei gelaufen. Raspberry Pi 3 ist dann plötzlich abgestürzt und ließ sich nicht mehr starten. Wohl ein Defekt an der SD Karte. Also Raspbian auf einer neuen Karte installiert, IO Broker installiert und Fixer laufen gelassen. Dann mittels BackitUp ein Backup vom NAS eingespielt. Alles läuft wieder wie zuvor nur der Zigbee Adapter macht Probleme.
          In der Instanzen Ansicht bleibt er immer gelb. Entweder Verbunden mit Host: Wahr, Lebenszeichen: Wahr, Verbunden mit Zigbee: Falsch oder Verbunden mit Host und Lebenszeichen: Falsch und Verbunden mit Zigbee: Wahr.
          Beim Öffnen der Konfiguration: Error You need save and run adapter before pairing!
          Log gibt folgendes aus:
          zigbee.0	2021-05-20 09:09:59.084	warn	(13725) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          zigbee.0	2021-05-20 09:09:59.080	error	(13725) zigbee.0 already running
          zigbee.0	2021-05-20 09:09:54.269	warn	(12999) Got terminate signal. Checking desired PID: 13725 vs own PID 12999
          zigbee.0	2021-05-20 09:09:54.214	error	(12999) Cannot read property 'getEntries' of null
          zigbee.0	2021-05-20 09:09:54.212	error	at stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8620:22)
          zigbee.0	2021-05-20 09:09:54.212	error	at Zigbee.emit (events.js:314:20)
          zigbee.0	2021-05-20 09:09:54.212	error	at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:581:41)
          zigbee.0	2021-05-20 09:09:54.212	error	at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:310:20)
          zigbee.0	2021-05-20 09:09:54.212	error	at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:192:42)
          zigbee.0	2021-05-20 09:09:54.212	error	at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:222:43)
          zigbee.0	2021-05-20 09:09:54.212	error	at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:206:49)
          zigbee.0	2021-05-20 09:09:54.212	error	at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:303:31)
          zigbee.0	2021-05-20 09:09:54.212	error	at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:240:16)
          zigbee.0	2021-05-20 09:09:54.212	error	at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:220:55)
          zigbee.0	2021-05-20 09:09:54.212	error	(12999) TypeError: Cannot read property 'getEntries' of null
          zigbee.0	2021-05-20 09:09:54.205	error	(12999) unhandled promise rejection: Cannot read property 'getEntries' of null
          zigbee.0	2021-05-20 09:09:54.204	error	(12999) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          zigbee.0	2021-05-20 09:09:54.202	info	(12999) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          zigbee.0	2021-05-20 09:09:54.194	info	(12999) terminating
          zigbee.0	2021-05-20 09:09:54.192	warn	(12999) Failed to stop zigbee during startup
          zigbee.0	2021-05-20 09:09:54.189	info	(12999) Zigbee: disabling joining new devices.
          zigbee.0	2021-05-20 09:09:54.183	info	(12999) cleaned everything up...
          zigbee.0	2021-05-20 09:09:54.180	warn	(12999) Got terminate signal. Checking desired PID: 0 vs own PID 12999
          Bin mit meinem Latein am Ende. Hab bereits Raspbian mehrfach neu aufgesetzt und IO Broker neu installiert, Unterschiedlichste Backups aufgespielt, CC2531 Stick neu verbunden usw.
          ls-la /dev/serial/by-id gibt folgendes aus:
          drwxr-xr-x 2 root root 60 Mai 20 07:37 .
          drwxr-xr-x 4 root root 80 Mai 20 07:37 ..
          lrwxrwxrwx 1 root root 13 Mai 20 07:37 usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001949C9BC-if00 -> ../../ttyACM0
          COM Port ist auch richtig im Adapter eingetragen.
          Hat jemand eine Idee woran es liegen kann?
            Stefan_TR96 @Stefan_TR96 last edited by
            Kurzes Update: Stick neu geflasht (erfolgreich), IO broker auf einem anderen Raspberry neu aufgesetz, nur den Zigbee Adapter installiert, keine änderung (verbunden mit Zigbee: falsch)
            • Asgothian
              Asgothian Developer @Stefan_TR96 last edited by
              @stefan_tr96
              Bitte ein vollständiges Log vom Startversuch posten. Das Log welches du gepostet hast zeigt einen Fehler beim Versuch den Zigbee-Adapter zu beenden.
              Das deutet darauf hin das davor ein Problem aufgetreten ist welches dazu führt das der Adapter sich beenden will.
              A.
              • Bluelinux
                Bluelinux last edited by
                Also ich habe wieder auf die 1.4.1 Version zurück gestellt da es bei mir nicht ging ... das nervt echt das der nicht stabil läuft nach einem update
                  arteck Developer Most Active @Bluelinux last edited by arteck
                  @bluelinux und das resultiert aus ???
                  wenn das so bei dir ist ..dann bleib bei Stable.. wenn ihr von GIT oder beta installiert muss man damit rechnen..
                  ausserdem wenn ihr noch den den cc2531 im einsatz habt würde ich den schleunigst tauschen.. die Dinger sind nicht dazu gedacht über längeres Zeitraum stabil ein Netzwerk zu betreiben. vor allem wenn ihr das Netz immer wieder ausbaut
                    @asgothian
                    Danke, läuft wieder! Keine Ahnung wieso, nach ein paar Stunden ist er plötzlich auf grün gesprungen. Mal schauen wie lange es jetzt läuft 😉
                    • DK43
                      DK43 last edited by
                      so sieht der Log aus nachdem ich IoBroker auf mitte April wiederhergestellt habe. Da hat noch alles funktioniert.
                      host.raspberrypi	2021-05-27 23:25:48.853	warn	Do not restart adapter system.adapter.zigbee.0 because restart loop detected
                      host.raspberrypi	2021-05-27 23:25:48.851	info	Restart adapter system.adapter.zigbee.0 because enabled
                      host.raspberrypi	2021-05-27 23:25:48.844	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                      zigbee.0	2021-05-27 23:25:47.960	warn	(20546) Terminated (UNCAUGHT_EXCEPTION): Without reason
                      zigbee.0	2021-05-27 23:25:47.957	info	(20546) terminating
                      zigbee.0	2021-05-27 23:25:47.952	info	(20546) cleaned everything up...
                      zigbee.0	2021-05-27 23:25:47.864	error	(20546) Cannot read property 'split' of undefined
                      zigbee.0	2021-05-27 23:25:47.862	error	at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8479:34
                      zigbee.0	2021-05-27 23:25:47.862	error	at Zigbee.emit (events.js:314:20)
                      zigbee.0	2021-05-27 23:25:47.862	error	at Zigbee.onReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:122:14)
                      zigbee.0	2021-05-27 23:25:47.862	error	at Zigbee.applyExternalConverters (/opt/iobroker/node_modules/iobroker.zigbee/main.js:172:20)
                      zigbee.0	2021-05-27 23:25:47.862	error	at getExternalDefinition.next (<anonymous>)
                      zigbee.0	2021-05-27 23:25:47.862	error	at Zigbee.getExternalDefinition (/opt/iobroker/node_modules/iobroker.zigbee/main.js:150:47)
                      zigbee.0	2021-05-27 23:25:47.862	error	(20546) TypeError: Cannot read property 'split' of undefined
                      zigbee.0	2021-05-27 23:25:47.851	error	(20546) unhandled promise rejection: Cannot read property 'split' of undefined
                      zigbee.0	2021-05-27 23:25:47.848	error	(20546) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      zigbee.0	2021-05-27 23:25:47.758	info	(20546) starting. Version 1.4.4 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.20.1, js-controller: 3.2.16
                      host.raspberrypi	2021-05-27 23:25:41.023	info	instance system.adapter.zigbee.0 started with pid 20546
                      host.raspberrypi	2021-05-27 23:25:10.950	info	Restart adapter system.adapter.zigbee.0 because enabled
                      host.raspberrypi	2021-05-27 23:25:10.947	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                      zigbee.0	2021-05-27 23:25:10.039	warn	(20531) Terminated (UNCAUGHT_EXCEPTION): Without reason
                      zigbee.0	2021-05-27 23:25:10.035	info	(20531) terminating
                      zigbee.0	2021-05-27 23:25:10.029	info	(20531) cleaned everything up...
                      zigbee.0	2021-05-27 23:25:09.942	error	(20531) Cannot read property 'split' of undefined
                      zigbee.0	2021-05-27 23:25:09.940	error	at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8479:34
                      zigbee.0	2021-05-27 23:25:09.940	error	at Zigbee.emit (events.js:314:20)
                      zigbee.0	2021-05-27 23:25:09.940	error	at Zigbee.onReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:122:14)
                      zigbee.0	2021-05-27 23:25:09.940	error	at Zigbee.applyExternalConverters (/opt/iobroker/node_modules/iobroker.zigbee/main.js:172:20)
                      zigbee.0	2021-05-27 23:25:09.940	error	at getExternalDefinition.next (<anonymous>)
                      zigbee.0	2021-05-27 23:25:09.940	error	at Zigbee.getExternalDefinition (/opt/iobroker/node_modules/iobroker.zigbee/main.js:150:47)
                      zigbee.0	2021-05-27 23:25:09.940	error	(20531) TypeError: Cannot read property 'split' of undefined
                      zigbee.0	2021-05-27 23:25:09.929	error	(20531) unhandled promise rejection: Cannot read property 'split' of undefined
                      zigbee.0	2021-05-27 23:25:09.927	error	(20531) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      zigbee.0	2021-05-27 23:25:09.835	info	(20531) starting. Version 1.4.4 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.20.1, js-controller: 3.2.16
                      host.raspberrypi	2021-05-27 23:25:03.000	info	instance system.adapter.zigbee.0 started with pid 20531
                      host.raspberrypi	2021-05-27 23:24:32.928	info	Restart adapter system.adapter.zigbee.0 because enabled
                      host.raspberrypi	2021-05-27 23:24:32.924	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                      zigbee.0	2021-05-27 23:24:32.048	warn	(20515) Terminated (UNCAUGHT_EXCEPTION): Without reason
                      zigbee.0	2021-05-27 23:24:32.044	info	(20515) terminating
                      zigbee.0	2021-05-27 23:24:32.039	info	(20515) cleaned everything up...
                      zigbee.0	2021-05-27 23:24:31.915	error	(20515) Cannot read property 'split' of undefined
                      zigbee.0	2021-05-27 23:24:31.913	error	at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8479:34
                      zigbee.0	2021-05-27 23:24:31.913	error	at Zigbee.emit (events.js:314:20)
                      zigbee.0	2021-05-27 23:24:31.913	error	at Zigbee.onReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:122:14)
                      zigbee.0	2021-05-27 23:24:31.913	error	at Zigbee.applyExternalConverters (/opt/iobroker/node_modules/iobroker.zigbee/main.js:172:20)
                      zigbee.0	2021-05-27 23:24:31.913	error	at getExternalDefinition.next (<anonymous>)
                      zigbee.0	2021-05-27 23:24:31.913	error	at Zigbee.getExternalDefinition (/opt/iobroker/node_modules/iobroker.zigbee/main.js:150:47)
                      zigbee.0	2021-05-27 23:24:31.913	error	(20515) TypeError: Cannot read property 'split' of undefined
                      zigbee.0	2021-05-27 23:24:31.903	error	(20515) unhandled promise rejection: Cannot read property 'split' of undefined
                      zigbee.0	2021-05-27 23:24:31.900	error	(20515) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      zigbee.0	2021-05-27 23:24:31.810	info	(20515) starting. Version 1.4.4 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.20.1, js-controller: 3.2.16
                      host.raspberrypi	2021-05-27 23:24:22.608	info	instance system.adapter.zigbee.0 started with pid 20515
                      host.raspberrypi	2021-05-27 23:24:22.536	info	"system.adapter.zigbee.0" enabled
                      echarts.0	2021-05-27 23:24:05.226	info	(20500) starting. Version 0.4.13 in /opt/iobroker/node_modules/iobroker.echarts, node: v12.20.1, js-controller: 3.2.16
                      host.raspberrypi	2021-05-27 23:24:01.737	info	instance system.adapter.echarts.0 started with pid 20500
                      host.raspberrypi	2021-05-27 23:24:01.637	info	"system.adapter.echarts.0" enabled
                      backitup.0	2021-05-27 23:22:39.776	error	(20458) [object Object]
                      backitup.0	2021-05-27 23:22:39.773	error	(20458) [object Object]
                      • Thomas4170
                        Thomas4170 last edited by Thomas4170
                        vorhin Update 1.5.5 gemacht und nun funktioniert nichts mehr. Im Adapter gibt es nicht mehr die Möglichkeit auf eine vorherige Version zurückzugehen. Adapter gelöscht und versucht neu zu installieren. Bevor das Update gestartet wurde hat alles super funktioniert. Ich nutze ein CC2652RB
                        Folgende Fehlermeldung kommt
                        Fertig mit Fehler: internal/modules/cjs/loader.js:1044 throw err; ^SyntaxError: /opt/iobroker/node_modules/iobroker.zigbee/io-package.json: Unexpected token } in JSON at position 167 at parse () at Object.Module._extensions..json (internal/modules/cjs/loader.js:1041:22) at Module.load (internal/modules/cjs/loader.js:863:32) at Function.Module._load (internal/modules/cjs/loader.js:708:14) at Module.require (internal/modules/cjs/loader.js:887:19) at require (internal/modules/cjs/helpers.js:74:18) at Upload.uploadAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:480:19) at Immediate. (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:847:20) at processImmediate (internal/timers.js:463:21)
                        $ ./iobroker add zigbee  --host PI-IOBROKER
                        ERROR: internal/modules/cjs/loader.js:1044    throw err;    ^SyntaxError: /opt/iobroker/node_modules/iobroker.zigbee/io-package.json: Unexpected token } in JSON at position 167    at parse (<anonymous>)    at Object.Module._extensions..json (internal/modules/cjs/loader.js:1041:22)    at Module.load (internal/modules/cjs/loader.js:863:32)    at Function.Module._load (internal/modules/cjs/loader.js:708:14)    at Module.require (internal/modules/cjs/loader.js:887:19)    at require (internal/modules/cjs/helpers.js:74:18)    at Upload.uploadAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:480:19)    at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:847:20)    at processImmediate (internal/timers.js:463:21)
                        ERROR: process exited with code 1
                        host.PI-IOBROKER	2021-05-28 22:18:35.148	info	iobroker exit 1
                        host.PI-IOBROKER	2021-05-28 22:18:35.133	error	iobroker internal/modules/cjs/loader.js:1044 throw err; ^SyntaxError: /opt/iobroker/node_modules/iobroker.zigbee/io-package.json: Unexpected token } in JSON at position 167 at parse (<anonym
                        host.PI-IOBROKER	2021-05-28 22:18:33.268	info	iobroker add zigbee --host PI-IOBROKER
                        host.PI-IOBROKER	2021-05-28 22:11:12.291	info	iobroker exit 1
                        host.PI-IOBROKER	2021-05-28 22:11:12.276	error	iobroker internal/modules/cjs/loader.js:1044 throw err; ^SyntaxError: /opt/iobroker/node_modules/iobroker.zigbee/io-package.json: Unexpected token } in JSON at position 167 at parse (<anonym
                        host.PI-IOBROKER	2021-05-28 22:11:10.433	info	iobroker add zigbee --host PI-IOBROKER
                        Bitte um Hilfe
                        VG Thomas
                        • mickym
                          mickym Most Active @Thomas4170 last edited by mickym
                          @thomas4170 Kann Dir zwar nicht helfen, mir ist es mit CC2531 genauso ergangen, weil die Version 1.5.5 plötzlich im stable aufgetaucht ist. Mehrfach gebootet, Stick abgezogen usw. Und alles mehrfach. Nachdem es mit der 1.5.5. kein einziges Mal geklappt hat, habe ich das Image vor dem Update eingespielt - das enthielt 1.4.4 - und auf Anhieb war alles wieder da!!!
                          Problem ist immer und immer wieder die Kommunikation mit dem seriellen Port - und das scheint bei der Version einfach nicht so zu funktionieren wie bei der letzten 1.4er Version.
                          Die Installation selbst ist problemlos durchgelaufen. Soweit ich verstehe ist die 1.5.5 auch die neueste Version - verstehe nicht, wieso das schon im stable auftaucht.
                          Thomas4170 1 Reply Last reply Reply Quote 0
                            luie last edited by
                            Das Problem hängt bestimmt hiermit zusammen.
                            Link Text
                            • Thomas4170
                              Thomas4170 @mickym last edited by
                              @mickym Gibt es eine Anleitung wie man ein Image einer vorherigen Version einspielt? Dafür bin noch zu viel Anfänger um das hinzubekommen
                              • mickym
                                @thomas4170 Na wenn Du kein Image gemacht hast, dann kannst auch keines einspielen. Ich mach vor jedem kritischen Adapterupdate ein Image der SSD Karte auf meine Windowsmaschine.
                                • Thomas4170
                                  Thomas4170 @mickym last edited by Thomas4170
                                  @mickym Ja dann sollte ich mal lernen wie das gemacht wird für das Update 😉
                                  Aber wenigstens hat das Update des MQTT-Adapters geklappt
                                  • mickym
                                    @thomas4170 Unter Windows nutze ich immer noch den guten alten
                                    Win32 Disk Imager. 😉
                                    • Thomas4170
                                      @mickym Den habe ich auch aber wüsste jetzt nicht wie ich da ein Image von ioBroker erstellen könnte. Einen SD-Karte flashen für eine Neuinstallation eines Raspi, kein Problem aber sonst 😄
                                      • mickym
                                        @thomas4170 Na Du machst kein Image von iobroker, sondern von der ganzen SD Karte. Das ist doch das Problem, dass Du exakt den Stand des Gesamtsystem wieder zurück laden kannst, als alles noch funktionierte. Einfach das Laufwerk der SD KArte auswählen, eine Datei angeben, wohin das Image geschrieben wird und dann auf Lesen klicken.
                                        • Thomas4170
                                          @mickym Ja jetzt habe ich verstanden, ist ja echt einfach
                                          • mickym
                                            @thomas4170 Genau - Du kopierst quasi die ganze SSD in eine Datei und spielst die auch wieder zurück. Es wird quasi Sektorweise zurückgeschrieben - also ein identischer Klon Deiner Platte gemacht.
                                            Deswegen nehme ich keine große SSD - das ist nämlich der Nachteil wenn man Images macht. Die Datei ist immer so groß wie die SSD.
                                            zigbee cc2531
                                            10
                                            33
                                            2216
