    4. Zigbee Adapter keine Verbindung zu CC2531
      Stefan_TR96 @Asgothian last edited by
      @asgothian
      Danke, läuft wieder! Keine Ahnung wieso, nach ein paar Stunden ist er plötzlich auf grün gesprungen. Mal schauen wie lange es jetzt läuft 😉
      • DK43
        DK43 last edited by
        so sieht der Log aus nachdem ich IoBroker auf mitte April wiederhergestellt habe. Da hat noch alles funktioniert.
        host.raspberrypi	2021-05-27 23:25:48.853	warn	Do not restart adapter system.adapter.zigbee.0 because restart loop detected
        host.raspberrypi	2021-05-27 23:25:48.851	info	Restart adapter system.adapter.zigbee.0 because enabled
        host.raspberrypi	2021-05-27 23:25:48.844	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        zigbee.0	2021-05-27 23:25:47.960	warn	(20546) Terminated (UNCAUGHT_EXCEPTION): Without reason
        zigbee.0	2021-05-27 23:25:47.957	info	(20546) terminating
        zigbee.0	2021-05-27 23:25:47.952	info	(20546) cleaned everything up...
        zigbee.0	2021-05-27 23:25:47.864	error	(20546) Cannot read property 'split' of undefined
        zigbee.0	2021-05-27 23:25:47.862	error	at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8479:34
        zigbee.0	2021-05-27 23:25:47.862	error	at Zigbee.emit (events.js:314:20)
        zigbee.0	2021-05-27 23:25:47.862	error	at Zigbee.onReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:122:14)
        zigbee.0	2021-05-27 23:25:47.862	error	at Zigbee.applyExternalConverters (/opt/iobroker/node_modules/iobroker.zigbee/main.js:172:20)
        zigbee.0	2021-05-27 23:25:47.862	error	at getExternalDefinition.next (<anonymous>)
        zigbee.0	2021-05-27 23:25:47.862	error	at Zigbee.getExternalDefinition (/opt/iobroker/node_modules/iobroker.zigbee/main.js:150:47)
        zigbee.0	2021-05-27 23:25:47.862	error	(20546) TypeError: Cannot read property 'split' of undefined
        zigbee.0	2021-05-27 23:25:47.851	error	(20546) unhandled promise rejection: Cannot read property 'split' of undefined
        zigbee.0	2021-05-27 23:25:47.848	error	(20546) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        zigbee.0	2021-05-27 23:25:47.758	info	(20546) starting. Version 1.4.4 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.20.1, js-controller: 3.2.16
        host.raspberrypi	2021-05-27 23:25:41.023	info	instance system.adapter.zigbee.0 started with pid 20546
        host.raspberrypi	2021-05-27 23:25:10.950	info	Restart adapter system.adapter.zigbee.0 because enabled
        host.raspberrypi	2021-05-27 23:25:10.947	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        zigbee.0	2021-05-27 23:25:10.039	warn	(20531) Terminated (UNCAUGHT_EXCEPTION): Without reason
        zigbee.0	2021-05-27 23:25:10.035	info	(20531) terminating
        zigbee.0	2021-05-27 23:25:10.029	info	(20531) cleaned everything up...
        zigbee.0	2021-05-27 23:25:09.942	error	(20531) Cannot read property 'split' of undefined
        zigbee.0	2021-05-27 23:25:09.940	error	at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8479:34
        zigbee.0	2021-05-27 23:25:09.940	error	at Zigbee.emit (events.js:314:20)
        zigbee.0	2021-05-27 23:25:09.940	error	at Zigbee.onReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:122:14)
        zigbee.0	2021-05-27 23:25:09.940	error	at Zigbee.applyExternalConverters (/opt/iobroker/node_modules/iobroker.zigbee/main.js:172:20)
        zigbee.0	2021-05-27 23:25:09.940	error	at getExternalDefinition.next (<anonymous>)
        zigbee.0	2021-05-27 23:25:09.940	error	at Zigbee.getExternalDefinition (/opt/iobroker/node_modules/iobroker.zigbee/main.js:150:47)
        zigbee.0	2021-05-27 23:25:09.940	error	(20531) TypeError: Cannot read property 'split' of undefined
        zigbee.0	2021-05-27 23:25:09.929	error	(20531) unhandled promise rejection: Cannot read property 'split' of undefined
        zigbee.0	2021-05-27 23:25:09.927	error	(20531) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        zigbee.0	2021-05-27 23:25:09.835	info	(20531) starting. Version 1.4.4 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.20.1, js-controller: 3.2.16
        host.raspberrypi	2021-05-27 23:25:03.000	info	instance system.adapter.zigbee.0 started with pid 20531
        host.raspberrypi	2021-05-27 23:24:32.928	info	Restart adapter system.adapter.zigbee.0 because enabled
        host.raspberrypi	2021-05-27 23:24:32.924	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        zigbee.0	2021-05-27 23:24:32.048	warn	(20515) Terminated (UNCAUGHT_EXCEPTION): Without reason
        zigbee.0	2021-05-27 23:24:32.044	info	(20515) terminating
        zigbee.0	2021-05-27 23:24:32.039	info	(20515) cleaned everything up...
        zigbee.0	2021-05-27 23:24:31.915	error	(20515) Cannot read property 'split' of undefined
        zigbee.0	2021-05-27 23:24:31.913	error	at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8479:34
        zigbee.0	2021-05-27 23:24:31.913	error	at Zigbee.emit (events.js:314:20)
        zigbee.0	2021-05-27 23:24:31.913	error	at Zigbee.onReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:122:14)
        zigbee.0	2021-05-27 23:24:31.913	error	at Zigbee.applyExternalConverters (/opt/iobroker/node_modules/iobroker.zigbee/main.js:172:20)
        zigbee.0	2021-05-27 23:24:31.913	error	at getExternalDefinition.next (<anonymous>)
        zigbee.0	2021-05-27 23:24:31.913	error	at Zigbee.getExternalDefinition (/opt/iobroker/node_modules/iobroker.zigbee/main.js:150:47)
        zigbee.0	2021-05-27 23:24:31.913	error	(20515) TypeError: Cannot read property 'split' of undefined
        zigbee.0	2021-05-27 23:24:31.903	error	(20515) unhandled promise rejection: Cannot read property 'split' of undefined
        zigbee.0	2021-05-27 23:24:31.900	error	(20515) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        zigbee.0	2021-05-27 23:24:31.810	info	(20515) starting. Version 1.4.4 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.20.1, js-controller: 3.2.16
        host.raspberrypi	2021-05-27 23:24:22.608	info	instance system.adapter.zigbee.0 started with pid 20515
        host.raspberrypi	2021-05-27 23:24:22.536	info	"system.adapter.zigbee.0" enabled
        echarts.0	2021-05-27 23:24:05.226	info	(20500) starting. Version 0.4.13 in /opt/iobroker/node_modules/iobroker.echarts, node: v12.20.1, js-controller: 3.2.16
        host.raspberrypi	2021-05-27 23:24:01.737	info	instance system.adapter.echarts.0 started with pid 20500
        host.raspberrypi	2021-05-27 23:24:01.637	info	"system.adapter.echarts.0" enabled
        backitup.0	2021-05-27 23:22:39.776	error	(20458) [object Object]
        backitup.0	2021-05-27 23:22:39.773	error	(20458) [object Object]
        • Thomas4170
          Thomas4170 last edited by Thomas4170
          vorhin Update 1.5.5 gemacht und nun funktioniert nichts mehr. Im Adapter gibt es nicht mehr die Möglichkeit auf eine vorherige Version zurückzugehen. Adapter gelöscht und versucht neu zu installieren. Bevor das Update gestartet wurde hat alles super funktioniert. Ich nutze ein CC2652RB
          Folgende Fehlermeldung kommt
          Fertig mit Fehler: internal/modules/cjs/loader.js:1044 throw err; ^SyntaxError: /opt/iobroker/node_modules/iobroker.zigbee/io-package.json: Unexpected token } in JSON at position 167 at parse () at Object.Module._extensions..json (internal/modules/cjs/loader.js:1041:22) at Module.load (internal/modules/cjs/loader.js:863:32) at Function.Module._load (internal/modules/cjs/loader.js:708:14) at Module.require (internal/modules/cjs/loader.js:887:19) at require (internal/modules/cjs/helpers.js:74:18) at Upload.uploadAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:480:19) at Immediate. (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:847:20) at processImmediate (internal/timers.js:463:21)
          $ ./iobroker add zigbee  --host PI-IOBROKER
          ERROR: internal/modules/cjs/loader.js:1044    throw err;    ^SyntaxError: /opt/iobroker/node_modules/iobroker.zigbee/io-package.json: Unexpected token } in JSON at position 167    at parse (<anonymous>)    at Object.Module._extensions..json (internal/modules/cjs/loader.js:1041:22)    at Module.load (internal/modules/cjs/loader.js:863:32)    at Function.Module._load (internal/modules/cjs/loader.js:708:14)    at Module.require (internal/modules/cjs/loader.js:887:19)    at require (internal/modules/cjs/helpers.js:74:18)    at Upload.uploadAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:480:19)    at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:847:20)    at processImmediate (internal/timers.js:463:21)
          ERROR: process exited with code 1
          host.PI-IOBROKER	2021-05-28 22:18:35.148	info	iobroker exit 1
          host.PI-IOBROKER	2021-05-28 22:18:35.133	error	iobroker internal/modules/cjs/loader.js:1044 throw err; ^SyntaxError: /opt/iobroker/node_modules/iobroker.zigbee/io-package.json: Unexpected token } in JSON at position 167 at parse (<anonym
          host.PI-IOBROKER	2021-05-28 22:18:33.268	info	iobroker add zigbee --host PI-IOBROKER
          host.PI-IOBROKER	2021-05-28 22:11:12.291	info	iobroker exit 1
          host.PI-IOBROKER	2021-05-28 22:11:12.276	error	iobroker internal/modules/cjs/loader.js:1044 throw err; ^SyntaxError: /opt/iobroker/node_modules/iobroker.zigbee/io-package.json: Unexpected token } in JSON at position 167 at parse (<anonym
          host.PI-IOBROKER	2021-05-28 22:11:10.433	info	iobroker add zigbee --host PI-IOBROKER
          Bitte um Hilfe
          VG Thomas
          • mickym
            mickym Most Active @Thomas4170 last edited by mickym
            @thomas4170 Kann Dir zwar nicht helfen, mir ist es mit CC2531 genauso ergangen, weil die Version 1.5.5 plötzlich im stable aufgetaucht ist. Mehrfach gebootet, Stick abgezogen usw. Und alles mehrfach. Nachdem es mit der 1.5.5. kein einziges Mal geklappt hat, habe ich das Image vor dem Update eingespielt - das enthielt 1.4.4 - und auf Anhieb war alles wieder da!!!
            Problem ist immer und immer wieder die Kommunikation mit dem seriellen Port - und das scheint bei der Version einfach nicht so zu funktionieren wie bei der letzten 1.4er Version.
            Die Installation selbst ist problemlos durchgelaufen. Soweit ich verstehe ist die 1.5.5 auch die neueste Version - verstehe nicht, wieso das schon im stable auftaucht.
            Thomas4170 1 Reply Last reply Reply Quote 0
              luie last edited by
              Das Problem hängt bestimmt hiermit zusammen.
              Link Text
              • Thomas4170
                Thomas4170 @mickym last edited by
                @mickym Gibt es eine Anleitung wie man ein Image einer vorherigen Version einspielt? Dafür bin noch zu viel Anfänger um das hinzubekommen
                • mickym
                  @thomas4170 Na wenn Du kein Image gemacht hast, dann kannst auch keines einspielen. Ich mach vor jedem kritischen Adapterupdate ein Image der SSD Karte auf meine Windowsmaschine.
                  • Thomas4170
                    Thomas4170 @mickym last edited by Thomas4170
                    @mickym Ja dann sollte ich mal lernen wie das gemacht wird für das Update 😉
                    Aber wenigstens hat das Update des MQTT-Adapters geklappt
                    • mickym
                      @thomas4170 Unter Windows nutze ich immer noch den guten alten
                      Win32 Disk Imager. 😉
                      • Thomas4170
                        @mickym Den habe ich auch aber wüsste jetzt nicht wie ich da ein Image von ioBroker erstellen könnte. Einen SD-Karte flashen für eine Neuinstallation eines Raspi, kein Problem aber sonst 😄
                        • mickym
                          @thomas4170 Na Du machst kein Image von iobroker, sondern von der ganzen SD Karte. Das ist doch das Problem, dass Du exakt den Stand des Gesamtsystem wieder zurück laden kannst, als alles noch funktionierte. Einfach das Laufwerk der SD KArte auswählen, eine Datei angeben, wohin das Image geschrieben wird und dann auf Lesen klicken.
                          • Thomas4170
                            @mickym Ja jetzt habe ich verstanden, ist ja echt einfach
                            • mickym
                              @thomas4170 Genau - Du kopierst quasi die ganze SSD in eine Datei und spielst die auch wieder zurück. Es wird quasi Sektorweise zurückgeschrieben - also ein identischer Klon Deiner Platte gemacht.
                              Deswegen nehme ich keine große SSD - das ist nämlich der Nachteil wenn man Images macht. Die Datei ist immer so groß wie die SSD.
                              • Thomas4170
                                @mickym Jetzt heißt es aber erstmal warten bis es was neues gibt. Leider funktionieren meine Thermostate, Tür/Fensterkontakte nicht mehr. Werde morgen Zigbee solange bis es in ioBroker wieder funktioniert auf FHEM installieren. Ist zwar mega umständlich aber egal
                                • mickym
                                  @thomas4170 Wie ich in dem Parallelthread geschrieben habe. Du kannst mal folgendes versuchen.
                                  1. Adapter komplett vom System runter schmeissen. Also nicht nur Instanz, sondern kompletten Adapter löschen.
                                  2. Dann auf Kommandozeile:
                                    iobroker install zigbee@1.4.4
                                  die letzte Version von 1.4 installieren.
                                  3. Die Geräte über den zigbee Backup des backitup Adapter zurückspielen.
                                  Und wenn das funktioniert hat - ein Image erstellen. 😉 😉
                                  • Thomas4170
                                    @mickym said in Zigbee Adapter keine Verbindung zu CC2531:
                                    Bin ja noch ein Frischling mit ioBroker, wo finde ich die Kommandozeile?
                                    • mickym
                                      @thomas4170 du kannst es auch über die Adminoberfläche und dann Adapter und Expertenmodus machen. Da gibt es dann ganz rechts so eine Schaltgläche um eine Version zu installieren. Da wird Dir dann eine Version 1.4.1 angeboten, die dann auf 1.4.4 aktualisiert werden kann (s. Parallelthread). Ansonsten ist mit Kommandozeile einfach die Shell oder im Windowsjargon einfach die Eingabeaufforderung des Systems, auf dem das System läuft gemeint. Wenn es auf einem Raspberry läuft und Du Dich via ssh mit dem System verbindest, dann stellt Dir ssh ein kommandobasiertes Eingabefenster zur Verfügung. Das ist gemeint.
                                      • Thomas4170
                                        @mickym Guten Morgen, danke für die Erklärung, in FHEM gibt nämlich tatsächlich eine Kommandozeile wo ma solche Befehle absetzen kann und deshalb fragte ich.
                                        Wenn ich versuche die 1.4.1 zu installieren erscheint
                                        und von der Shel aus dieses hier
                                        adapter "zigbee" already installed. Use "upgrade" to upgrade to a newer version.
                                        • mickym
                                          @thomas4170 sagte in Zigbee Adapter keine Verbindung zu CC2531:
                                          Ja das Läuft bei mir auch noch mit. 😉
                                          • mickym
                                            @thomas4170 Na dann erst die bisherige Version komplett löschen oder es mit Upgrade versuchen.
                                            zigbee cc2531
                                            10
                                            33
                                            2216
