    4. Backitup für kein Automatisches Backup aus
    • ChrisNett
      ChrisNett @simatec last edited by ChrisNett
      @simatec
      ja das Backup läuft jetzt aber nur die beiden fehler, was müss ich da angeben?
      backitup.0	2021-06-02 07:51:15.521	info	(22053) [iobroker] backup was activated at 07:49 every 1 day(s)
      backitup.0	2021-06-02 07:51:15.420	info	(22053) starting. Version 2.1.6 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.22.1, js-controller: 3.3.9
      backitup.0	2021-06-02 07:51:07.730	info	(20698) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      backitup.0	2021-06-02 07:51:07.728	info	(20698) terminating
      backitup.0	2021-06-02 07:51:07.727	info	(20698) cleaned everything up...
      backitup.0	2021-06-02 07:51:07.726	info	(20698) Got terminate signal TERMINATE_YOURSELF
      backitup.0	2021-06-02 07:45:44.462	info	(20698) [iobroker] backup was activated at 07:49 every 1 day(s)
      backitup.0	2021-06-02 07:45:44.351	info	(20698) starting. Version 2.1.6 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.22.1, js-controller: 3.3.9
      backitup.0	2021-06-02 07:45:36.733	info	(18982) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      backitup.0	2021-06-02 07:45:36.730	info	(18982) terminating
      backitup.0	2021-06-02 07:45:36.729	info	(18982) cleaned everything up...
      backitup.0	2021-06-02 07:45:36.727	info	(18982) Got terminate signal TERMINATE_YOURSELF
      simatec Glasfaser 2 Replies Last reply Reply Quote 0
      • simatec
        simatec Developer Most Active @ChrisNett last edited by
        @christian-sandkaulen Der Log sagt leider nichts aus, außer dass du den Adapter neu gestartet hast
        ChrisNett 1 Reply Last reply Reply Quote 0
        • ChrisNett
          @simatec
          sorry dachte da seht das bei..
          Started iobroker ...
          [DEBUG] [iobroker] - host.PI4 6271 states saved
          [DEBUG] [iobroker] - host.PI4 7753 objects saved
          [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_06_02-08_01_32_backupiobroker.tar.gz
          [DEBUG] [iobroker] - done
          [DEBUG] [historyDB] - compress from historyDB started ...
          [ERROR] [historyDB] - [IGNORED] Backitup cannot found source "undefined" for compress!
          [DEBUG] [zigbee] - found zigbee database: zigbee.0,zigbee.1
          [DEBUG] [zigbee] - done
          [DEBUG] [javascripts] - javascript directory "" not found
          [DEBUG] [javascripts] - done
          [DEBUG] [googledrive] - Google Drive: Copy iobroker_2021_06_02-08_01_32_backupiobroker.tar.gz...
          [ERROR] [googledrive] - Google Drive: File "/opt/iobroker/backups/historyDB_2021_06_02-08_01_45_backupiobroker.tar.gz" not found
          [DEBUG] [googledrive] - Google Drive: Copy zigbee.0_2021_06_02-08_01_45_backupiobroker.tar.gz...
          [DEBUG] [googledrive] - Google Drive: Copy zigbee.1_2021_06_02-08_01_45_backupiobroker.tar.gz...
          [ERROR] [googledrive] - Google Drive: File "/opt/iobroker/backups/javascripts_2021_06_02-08_01_46_backupiobroker.tar.gz" not found
          [DEBUG] [googledrive] - done
          [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
          [DEBUG] [clean] - done
          [DEBUG] [telegram] - done
          [DEBUG] [historyHTML] - new history html values created
          [DEBUG] [historyHTML] - done
          [DEBUG] [historyJSON] - new history json values created
          [DEBUG] [historyJSON] - done
          [EXIT] 0
          • Glasfaser
            Glasfaser @ChrisNett last edited by
            @christian-sandkaulen sagte in Backitup für kein Automatisches Backup aus:
            Biste du im BETA Kanal unterwegs !?
            • ChrisNett
              ChrisNett @Glasfaser last edited by
              @glasfaser
              nicht das ich wüsste sol ich das ändern?
              • Glasfaser
                Zeige mal :
                iobroker version
                iobroker repo list
                which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
                • simatec
                  @christian-sandkaulen Du hast weder bei dem History Backup einen Pfad angegeben noch beim Javascript.
                  Wenn du die beiden Optionen mitsichern willst, dann musst dort die Pfadangabe rein. Wenn nicht die beiden Optionen in den Haupteinstellungen deaktivieren
                  • ChrisNett
                    @glasfaser
                    pi@PI4:~ $ iobroker version
                    3.3.9
                    pi@PI4:~ $ iobroker repo list
                    Stable (default): http://download.iobroker.net/sources-dist.json
                    Beta (latest): http://download.iobroker.net/sources-dist-latest.json
                    Active repo: Stable (default)
                    pi@PI4:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
                    /usr/bin/nodejs
                    /usr/bin/node
                    /usr/bin/npm
                    v12.22.1
                    v12.22.1
                    6.14.12
                    Holen:1 http://archive.raspberrypi.org/debian buster InRelease [32,7 kB]
                    Holen:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
                    Holen:3 http://packages.microsoft.com/repos/code stable InRelease [10,4 kB]
                    OK:4 https://deb.nodesource.com/node_12.x buster InRelease
                    Holen:5 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13,0 MB]
                    Holen:6 http://packages.microsoft.com/repos/code stable/main armhf Packages [30,9 kB]
                    Holen:7 http://packages.microsoft.com/repos/code stable/main arm64 Packages [30,9 kB]
                    Holen:8 http://packages.microsoft.com/repos/code stable/main amd64 Packages [29,9 kB]
                    Holen:9 http://archive.raspberrypi.org/debian buster/main armhf Packages [376 kB]
                    Es wurden 13,5 MB in 13 s geholt (1.077 kB/s).
                    Aktualisierung für 73 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                    OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                    OK:2 http://archive.raspberrypi.org/debian buster InRelease
                    OK:3 http://packages.microsoft.com/repos/code stable InRelease
                    nodejs:
                      Installiert:           12.22.1-1nodesource1
                      Installationskandidat: 12.22.1-1nodesource1
                      Versionstabelle:
                     *** 12.22.1-1nodesource1 500
                            500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                            100 /var/lib/dpkg/status
                         10.24.0~dfsg-1~deb10u1 500
                    • ChrisNett
                      @simatec
                      wie bekomme ich die Pfade raus ?
                      • simatec
                        @christian-sandkaulen Jeweils auf den Button ermitteln klicken.
                        Wenn Javascript und der History Adapter richtig konfiguriert sind, holt sich Backitup die Daten
                        https://github.com/simatec/ioBroker.backitup/blob/master/docs/de/backitup.md#Javascript-Backup
                          Thomas Braun Most Active @ChrisNett last edited by
                          Eigentlich alles richtig eingestellt.
                          Du musst aber irgendwann mal die Beta-Version des js-controllers eingespielt haben, 3.3.9 war nie im Stable verfügbar.
                          Die 73 hängenden Upgrades würde ich reinholen:
                          sudo apt dist-upgrade
                          sudo reboot
                          ChrisNett 2 Replies Last reply Reply Quote 0
                          • ChrisNett
                            ChrisNett @Thomas Braun last edited by
                            ja das kann sein als ich problem mit Zigbee hatte ist das gemacht worden, update mache ich gleich.
                            • ChrisNett
                              @simatec
                              danke JS habe ich ümgestellt aber was muss hier rein?
                                Bei mir habe ich da (analog zu den JS-skripten) ein Spiegelverzeichnis in /home/iobroker/history angelegt. Also außerhalb von /opt/iobroker
                                • ChrisNett
                                  73 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                                  Es müssen 149 MB an Archiven heruntergeladen werden.
                                  Nach dieser Operation werden 4.907 kB Plattenplatz zusätzlich benutzt.
                                  Möchten Sie fortfahren? [J/n] J
                                  Abbruch.
                                  pi@PI4:~ $
                                  warum bricht der das mit "J" ab?
                                    Keine Ahnung. Mit kleinem j mal probiert?
                                    Oder y?
                                    • ChrisNett
                                      ja auch und mit n bricht er auch ab...
                                      aber backup geht jetzt
                                      [DEBUG] [iobroker] - host.PI4 6316 states saved
                                      [DEBUG] [iobroker] - host.PI4 7766 objects saved
                                      [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_06_02-10_34_43_backupiobroker.tar.gz
                                      [DEBUG] [historyDB] - Backup created: /opt/iobroker/backups/historyDB_2021_06_02-10_34_54_backupiobroker.tar.gz
                                      [DEBUG] [historyDB] - done
                                      [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2021_06_02-10_34_55_backupiobroker.tar.gz
                                      [DEBUG] [googledrive] - Google Drive: Copy iobroker_2021_06_02-10_34_43_backupiobroker.tar.gz...
                                      [DEBUG] [googledrive] - Google Drive: Copy historyDB_2021_06_02-10_34_54_backupiobroker.tar.gz...
                                      [DEBUG] [googledrive] - Google Drive: Copy zigbee.0_2021_06_02-10_34_54_backupiobroker.tar.gz...
                                      [DEBUG] [googledrive] - Google Drive: Copy zigbee.1_2021_06_02-10_34_54_backupiobroker.tar.gz...
                                      [DEBUG] [googledrive] - Google Drive: Copy javascripts_2021_06_02-10_34_55_backupiobroker.tar.gz...
                                      [EXIT] 0
                                      🙂 danke
                                        Komisch.
                                        Versuch mal
                                        sudo apt update && sudo apt dist-upgrade -y
                                        • ChrisNett
                                          habe mal zuerst
                                          sudo reboot
                                          gemacht und dann noch mal das update
                                          jetzt läuft es
                                          • ChrisNett
                                            ChrisNett @ChrisNett last edited by
                                            ich Frage noch kann ich auch nur zigbee wiederherstellen oder ist da immer alles drin?
                                            584
