    4. Backitup für kein Automatisches Backup aus
    • ChrisNett
      ChrisNett @simatec last edited by
      @simatec
      sorry dachte da seht das bei..
      Started iobroker ...
      [DEBUG] [iobroker] - host.PI4 6271 states saved
      [DEBUG] [iobroker] - host.PI4 7753 objects saved
      [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_06_02-08_01_32_backupiobroker.tar.gz
      [DEBUG] [iobroker] - done
      [DEBUG] [historyDB] - compress from historyDB started ...
      [ERROR] [historyDB] - [IGNORED] Backitup cannot found source "undefined" for compress!
      [DEBUG] [zigbee] - found zigbee database: zigbee.0,zigbee.1
      [DEBUG] [zigbee] - done
      [DEBUG] [javascripts] - javascript directory "" not found
      [DEBUG] [javascripts] - done
      [DEBUG] [googledrive] - Google Drive: Copy iobroker_2021_06_02-08_01_32_backupiobroker.tar.gz...
      [ERROR] [googledrive] - Google Drive: File "/opt/iobroker/backups/historyDB_2021_06_02-08_01_45_backupiobroker.tar.gz" not found
      [DEBUG] [googledrive] - Google Drive: Copy zigbee.0_2021_06_02-08_01_45_backupiobroker.tar.gz...
      [DEBUG] [googledrive] - Google Drive: Copy zigbee.1_2021_06_02-08_01_45_backupiobroker.tar.gz...
      [ERROR] [googledrive] - Google Drive: File "/opt/iobroker/backups/javascripts_2021_06_02-08_01_46_backupiobroker.tar.gz" not found
      [DEBUG] [googledrive] - done
      [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
      [DEBUG] [clean] - done
      [DEBUG] [telegram] - done
      [DEBUG] [historyHTML] - new history html values created
      [DEBUG] [historyHTML] - done
      [DEBUG] [historyJSON] - new history json values created
      [DEBUG] [historyJSON] - done
      [EXIT] 0
      • Glasfaser
        Glasfaser @ChrisNett last edited by
        @christian-sandkaulen sagte in Backitup für kein Automatisches Backup aus:
        js-controller: 3.3.9
        Biste du im BETA Kanal unterwegs !?
        ChrisNett 1 Reply Last reply Reply Quote 0
        • ChrisNett
          ChrisNett @Glasfaser last edited by
          @glasfaser
          nicht das ich wüsste sol ich das ändern?
          • Glasfaser
            Zeige mal :
            iobroker version
            iobroker repo list
            which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
            • simatec
              simatec Developer Most Active @ChrisNett last edited by
              @christian-sandkaulen Du hast weder bei dem History Backup einen Pfad angegeben noch beim Javascript.
              Wenn du die beiden Optionen mitsichern willst, dann musst dort die Pfadangabe rein. Wenn nicht die beiden Optionen in den Haupteinstellungen deaktivieren
              • ChrisNett
                @glasfaser
                pi@PI4:~ $ iobroker version
                3.3.9
                pi@PI4:~ $ iobroker repo list
                Stable (default): http://download.iobroker.net/sources-dist.json
                Beta (latest): http://download.iobroker.net/sources-dist-latest.json
                Active repo: Stable (default)
                pi@PI4:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                v12.22.1
                v12.22.1
                6.14.12
                Holen:1 http://archive.raspberrypi.org/debian buster InRelease [32,7 kB]
                Holen:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
                Holen:3 http://packages.microsoft.com/repos/code stable InRelease [10,4 kB]
                OK:4 https://deb.nodesource.com/node_12.x buster InRelease
                Holen:5 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13,0 MB]
                Holen:6 http://packages.microsoft.com/repos/code stable/main armhf Packages [30,9 kB]
                Holen:7 http://packages.microsoft.com/repos/code stable/main arm64 Packages [30,9 kB]
                Holen:8 http://packages.microsoft.com/repos/code stable/main amd64 Packages [29,9 kB]
                Holen:9 http://archive.raspberrypi.org/debian buster/main armhf Packages [376 kB]
                Es wurden 13,5 MB in 13 s geholt (1.077 kB/s).
                Aktualisierung für 73 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                OK:2 http://archive.raspberrypi.org/debian buster InRelease
                OK:3 http://packages.microsoft.com/repos/code stable InRelease
                nodejs:
                  Installiert:           12.22.1-1nodesource1
                  Installationskandidat: 12.22.1-1nodesource1
                  Versionstabelle:
                 *** 12.22.1-1nodesource1 500
                        500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                        100 /var/lib/dpkg/status
                     10.24.0~dfsg-1~deb10u1 500
                • ChrisNett
                  @simatec
                  wie bekomme ich die Pfade raus ?
                  • simatec
                    @christian-sandkaulen Jeweils auf den Button ermitteln klicken.
                    Wenn Javascript und der History Adapter richtig konfiguriert sind, holt sich Backitup die Daten
                    https://github.com/simatec/ioBroker.backitup/blob/master/docs/de/backitup.md#Javascript-Backup
                      Thomas Braun Most Active @ChrisNett last edited by
                      Eigentlich alles richtig eingestellt.
                      Du musst aber irgendwann mal die Beta-Version des js-controllers eingespielt haben, 3.3.9 war nie im Stable verfügbar.
                      Die 73 hängenden Upgrades würde ich reinholen:
                      sudo apt dist-upgrade
                      sudo reboot
                      ChrisNett 2 Replies Last reply Reply Quote 0
                      • ChrisNett
                        ChrisNett @Thomas Braun last edited by
                        ja das kann sein als ich problem mit Zigbee hatte ist das gemacht worden, update mache ich gleich.
                        • ChrisNett
                          @simatec
                          danke JS habe ich ümgestellt aber was muss hier rein?
                            Bei mir habe ich da (analog zu den JS-skripten) ein Spiegelverzeichnis in /home/iobroker/history angelegt. Also außerhalb von /opt/iobroker
                            • ChrisNett
                              73 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                              Es müssen 149 MB an Archiven heruntergeladen werden.
                              Nach dieser Operation werden 4.907 kB Plattenplatz zusätzlich benutzt.
                              Möchten Sie fortfahren? [J/n] J
                              Abbruch.
                              pi@PI4:~ $
                              warum bricht der das mit "J" ab?
                                Keine Ahnung. Mit kleinem j mal probiert?
                                Oder y?
                                • ChrisNett
                                  ja auch und mit n bricht er auch ab...
                                  aber backup geht jetzt
                                  [DEBUG] [iobroker] - host.PI4 6316 states saved
                                  [DEBUG] [iobroker] - host.PI4 7766 objects saved
                                  [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_06_02-10_34_43_backupiobroker.tar.gz
                                  [DEBUG] [historyDB] - Backup created: /opt/iobroker/backups/historyDB_2021_06_02-10_34_54_backupiobroker.tar.gz
                                  [DEBUG] [historyDB] - done
                                  [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2021_06_02-10_34_55_backupiobroker.tar.gz
                                  [DEBUG] [googledrive] - Google Drive: Copy iobroker_2021_06_02-10_34_43_backupiobroker.tar.gz...
                                  [DEBUG] [googledrive] - Google Drive: Copy historyDB_2021_06_02-10_34_54_backupiobroker.tar.gz...
                                  [DEBUG] [googledrive] - Google Drive: Copy zigbee.0_2021_06_02-10_34_54_backupiobroker.tar.gz...
                                  [DEBUG] [googledrive] - Google Drive: Copy zigbee.1_2021_06_02-10_34_54_backupiobroker.tar.gz...
                                  [DEBUG] [googledrive] - Google Drive: Copy javascripts_2021_06_02-10_34_55_backupiobroker.tar.gz...
                                  [EXIT] 0
                                  🙂 danke
                                    Komisch.
                                    Versuch mal
                                    sudo apt update && sudo apt dist-upgrade -y
                                    • ChrisNett
                                      habe mal zuerst
                                      sudo reboot
                                      gemacht und dann noch mal das update
                                      jetzt läuft es
                                      • ChrisNett
                                        ChrisNett @ChrisNett last edited by
                                        ich Frage noch kann ich auch nur zigbee wiederherstellen oder ist da immer alles drin?
                                          Für zigbee gibt es eine eigene Einstellung im Backitup-Adapter.
                                          • ChrisNett
                                            Danke und der stellt auch nur zigbee wieder her ja?
                                            584
