    3. Entwicklung
    4. UniFi Adapter v0.5.7 stable
    • Nashra
      Nashra Most Active Forum Testing last edited by Nashra
      Moin, die obigen Fehlermeldungen habe ich gefunden. Unifi macht um 2:40 Uhr ein Backup
      und wohl daher nicht erreichbar 🤦‍♂️
      Aber die "Returned data is not in valid format" usw. die kommen weiterhin sporadisch.
      • Tom Son
        Tom Son last edited by
        Frage, wann werden die Probleme von 0.5.9 gefixt? oder hab ich was verpasst? 🙂
          crunchip Forum Testing Most Active @Tom Son last edited by
          @tom-son gibts dazu ein issue?
          Tom Son 1 Reply Last reply Reply Quote 0
          • Tom Son
            Tom Son @crunchip last edited by Tom Son
            @crunchip Fehler wie weiter oben schon beschrieben... nur der Rückschritt auf 0.5.5 bringt Ruhe ins Log
            das ist das Log:
            unifi.0
            	2021-05-23 12:04:56.237	error	fetchAlarms: Returned data is not in valid format
            unifi.0
            	2021-05-23 12:03:56.602	error	fetchAlarms: Returned data is not in valid format
            unifi.0
            	2021-05-23 12:02:56.467	error	fetchAlarms: Returned data is not in valid format
            unifi.0
            	2021-05-23 12:01:56.481	error	fetchAlarms: Returned data is not in valid format
            unifi.0
            	2021-05-23 12:00:56.977	error	fetchAlarms: Returned data is not in valid format
            unifi.0
            	2021-05-23 11:59:56.508	error	fetchAlarms: Returned data is not in valid format
            unifi.0
            	2021-05-23 11:58:56.899	error	fetchAlarms: Returned data is not in valid format
            unifi.0
            	2021-05-23 11:57:56.624	error	fetchAlarms: Returned data is not in valid format
            unifi.0
            	2021-05-23 11:56:56.670	error	fetchAlarms: Returned data is not in valid format
            unifi.0
            	2021-05-23 11:55:56.245	error	fetchAlarms: Returned data is not in valid format
            unifi.0
            	2021-05-23 11:54:56.588	error	fetchAlarms: Returned data is not in valid format
            unifi.0
            	2021-05-23 11:53:57.702	error	fetchAlarms: Returned data is not in valid format
            unifi.0
            	2021-05-23 11:52:56.563	error	fetchAlarms: Returned data is not in valid format
            unifi.0
            	2021-05-23 11:51:58.842	error	fetchAlarms: Returned data is not in valid format
            unifi.0
            	2021-05-23 11:50:56.417	error	fetchAlarms: Returned data is not in valid format
            unifi.0
            	2021-05-23 11:50:28.197	error	fetchAlarms: Returned data is not in valid format
              @tom-son ich habe 0.5.8 und wie oben geschrieben, in der config den Punkt Alarm herausgenommen
              • Tom Son
                @crunchip kann ich mal versuchen, aber was ist mit damit dass er nicht mit dem Host verbunden ist?
                • Tom Son
                  Bin wieder zurück auf 0.5.5 bis das Problem gefixt wurde...
                    @tom-son das liegt an der 0.5.9 hab doch geschrieben, habe 0.5.8
                    Tom Son 2 Replies Last reply Reply Quote 0
                    • Tom Son
                      @crunchip Funktioniert bei mir leider nicht, alles was höher ist als 0.5.5 kann keine Verbindung zu den Geräten oder Diensten aufbauen, siehe Bild oben...
                      • Tom Son
                        @crunchip Habe heute nun die neue Version 0.5.10 installiert, auch diese Version kann bei mir keine Verbindung zu Geräten oder Dienste aufbauen (siehe Bild weiter oben) Was mach ich denn falsch?
                        Die general Einstellungen hab ich nicht verändert, da kann man auch nicht viel machen, mit dem eingetragenen Benutzer kann ich mich auf dem Unifi Kontroller (Cloudkey gen2 plus) anmelden, das klappt.
                        Wenn ich wieder zurück gehe auf 0.5.5 (alle nächst höheren Versionen haben das selbe Feherlbild) dann läuft alles wie es soll... Bin ich der einzige bei dem das nicht klappt??
                        Mein CC läuft mit der Firmware 2.0.26
                        UI 6.0.44
                        Backend 6.0.45
                        Build atag_6.0.45_14358
                        integer63 crunchip 2 Replies Last reply Reply Quote 0
                        • integer63
                          integer63 @Tom Son last edited by integer63
                          @tom-son Also bei mir läuft der Unifi Controller in der Version 6.2.25 (oder wie er neuerdings genannt wird: UniFi Network Application) auf einer Linux VM (also self-hosted). Ich bekomme alle paar Minuten ein Update aller Datenpunkte, welche ich zuvor in der Konfiguration des Adapters aktiviert habe.
                          [edit] und ich habe aktuell 0.5.8 installiert
                          • Tom Son
                            Tom Son @integer63 last edited by
                            @integer63 hab ich gesehen, werde die Aktualisierung morgen machen, habe heute keine Lust was wieder her zu stellen, falls was schiefläuft...
                              @tom-son hab die Version noch nicht getestet, bin noch auf 0.5.8
                                Georgius last edited by
                                Hi
                                Wo finde ich in dem Adapter die Temperatur der Dream Mashine Pro?
                                • Tom Son
                                  Ich habe jetzt den neuesten Adapter zum laufen bekommen, fragt mich nicht genau wie 🙂 auf jedenfall muss man bei den Alarms alle Hacken rausnehmen, auch den ganz oben "Alarmmeldungen aktualisieren" und der Tipp mit dem Passwort neu eingeben (obwohl es das gleiche ist) hat auch geholfen...
                                  Zudem hab ich noch ein FW update vom CC 2k+ bekommen und den Netzwerk Kontroller auf den letzten Stand gebracht.
                                  Bis heute alles grün...
                                    @tom-son sagte in UniFi Adapter v0.5.7 stable:
                                    das hatte ich weiter oben schon geschrieben
                                    • Negalein
                                      @Scrounger
                                      Ich hab gesehn, dass du auch am Unifi-Adapter mitarbeitest.
                                      Ich bekomm laufend die Meldung unifi.0.default.num_new_alarms" is missing the required property "common.type
                                      Issue gibt es schon.
                                      Adapter: 0.5.10
                                      Admin: 5.1.25
                                      JS-Controller: 3.3.18
                                      Node.js: v14.17.1
                                      NPM: 6.14.13
                                      Hast du einen Tipp dazu?
                                      • Scrounger
                                        Scrounger Developer @Negalein last edited by
                                        @negalein
                                        Jup das Alarm Zeug hatte ich damals implementiert.
                                        Schau ich mir an, aber wird sicher etwas dauern hab Grad nicht soviel Zeit. Außerdem ist das doch nur nen "Schönheitsfehler" der das Log zu spamt?
                                        • Negalein
                                          Negalein Global Moderator @Scrounger last edited by
                                          @scrounger sagte in UniFi Adapter v0.5.7 stable:
                                          Ja, nur ein Schönheitsfehler, aber spamt das Log sehr zu.
                                          stable unifi update v0.5.7
                                          16
                                          54
                                          6244
