    4. Test Adapter Mihome-vacuum v3.1.6 Next Generarition
    • Diginix
      Diginix @Meistertr last edited by
      @meistertr Mit 3.1.9 hat die Kartenaktualisierung bei den eben gesaugten 2 Räumen funktioniert.
      Übermorgen sind wieder 6 Räume dran. Dann wissen wir noch mehr.
        denbo last edited by
        @Meistertr
        Ich verwende den S7 und grundsätzlich läuft alles soweit schon wirklich gut. Wie oben bereits gemeldet habe auch ich auch regelmäßig Abstürze des Adapters, wenn ich eine Raumreinigung starte. Das tritt aber nur sporadisch auf:
        2021-05-18 18:10:59.437 - info: mihome-vacuum.0 (1065) trigger cleaning segment 18
        2021-05-18 18:11:08.185 - info: mihome-vacuum.0 (1065) should trigger cleaning segment 22, but is currently active(18). Add to queue
        2021-05-18 18:13:27.481 - info: mihome-vacuum.0 (1065) should trigger cleaning segment 23, but is currently active(18). Add to queue
        2021-05-18 18:13:29.487 - error: mihome-vacuum.0 (1065) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2021-05-18 18:13:29.487 - error: mihome-vacuum.0 (1065) unhandled promise rejection: undefined
        2021-05-18 18:13:29.488 - error: mihome-vacuum.0 (1065) undefined
        2021-05-18 18:13:29.721 - info: mihome-vacuum.0 (1065) terminating
        2021-05-18 18:13:29.722 - warn: mihome-vacuum.0 (1065) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2021-05-18 18:13:30.547 - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
        2021-05-18 18:13:30.550 - error: host.iobroker Caught by controller[1]: MESSAGE TIMEOUT
        2021-05-18 18:13:30.550 - error: host.iobroker instance system.adapter.mihome-vacuum.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        2021-05-18 18:13:30.551 - info: host.iobroker Restart adapter system.adapter.mihome-vacuum.0 because enabled
        Meistertr 1 Reply Last reply Reply Quote 0
        • Crazy32
          Crazy32 @Meistertr last edited by
          @meistertr sagte in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
          @audi1503 Der Hauptaugenmerk liegt noch auf bugfixes, wenn die 3er ins stable geht kümmere ich mich um die Dreame Sauger. Das Protokoll hab ich schon drin, Fehlt nur das mappen der States.
          Super, das hört sich gut an. Mein Dreame L10 Pro befindet sich in der Zustellung. Da kann ich ja doch noch hoffen, dass ich den irgendwann in iobroker einbinden kann. Das sind super Nachrichten, nachdem ich nach einem Dreame-Adapter gesucht und nicht gefunden hatte. Ich hatte mich schon damit abgefunden, dass ich für den Sauger keine View in meiner VIS anlegen kann.
          Ich sage jetzt schon mal danke!
          • Meistertr
            Meistertr Developer @denbo last edited by
            @denbo die debug Einträge im Vorfeld wären super, so kann ich da nicht viel raus deuten
            • Diginix
              Diginix @Diginix last edited by
              @diginix sagte in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
              @Meistertr
              Heute habe ich 6 Räume saugen lassen. Immer 2 am Stück danach ins Dock. Karte wurde immer sauber mit v3.1.9 aktualisiert. 👍
                denbo @Meistertr last edited by
                @meistertr Sobald der Fehler wieder auftritt werde ich das Debug-Log hier posten.
                  SchuetzeSchulz last edited by SchuetzeSchulz
                  Ich habe ein kleines Problem mit der neuen Version.
                  Früher habe ich aus der VIS heraus mit einem Schiebeschalter den Datenpunkt "clean_home" auf true (für reinigen) oder false (für stoppen) gesetzt.
                  Das geht komischerweise immer noch, obwohl es die Datenpunkte nicht mehr gibt?
                  Dummerweise setzt sich nach einer Reinigung "clean_home" aber nicht mehr auf false zurück.
                  EDIT: Hat sich erledigt. Die Option "Füge einen Status für Alexa hinzu" hat gefehlt.
                    saeft_2003 Most Active @Meistertr last edited by
                    @meistertr
                    Ich hab da noch was. Und zwar wenn ich zum Beispiel über den Reset DP die Reinigung der Sensoren zurücksetze dann springen die % in der app sofort auf 100%, der Adapter aber behält noch sehr lange den alten stand.
                    Könnte sich der Adapter nicht nach einem Reset der Verbrauchsartikel die Prozent neu holen und nicht warten bis diese eh aktualisiert werden, oder liege ich irgendwie falsch?
                    • Meistertr
                      Meistertr Developer @saeft_2003 last edited by
                      @saeft_2003 ist in der 3.2.0 mit drin, die ist dann jetzt auch die RC version wenn keiner mehr große fehler zu bemängeln hat, bei mir läuft sie jetzt eigentlich mehrere Wochen Stabil
                        @meistertr
                        Alles klar 👍 Das letzte was ich noch vermisse ist, dass man in den Räumen den Zyklus einstellen kann. Wie stehen die Chancen das du das noch „einbauen“ kannst? Sonst läufts wunderbar ☺️
                        • Meistertr
                          @saeft_2003 ich kann nur immer wieder betonen, dass die liste lang ist die ich umsetzten will,. also kann es in ein paar Wochen oder Monaten kommen
                          F S 2 Replies Last reply Reply Quote 0
                            @meistertr Das Problem mit der sporadischen Fehlermeldung bei der Raumauswahl ist bei mir seitdem jetzt nicht mehr aufgetreten. Läuft soweit alles gut.
                              Frank579 @Meistertr last edited by Frank579
                              @meistertr
                              Ich bin gerade meinen IOBroker am neu aufsetzen, jetzt habe ich mit einer Instanz des Adapters (3.2.0) das Problem das die Räume nicht geladen werden, ist jetzt schon gut 2 Stunden her alle daten sind da,auch die Karte,nur eben die Räume nicht, beider 2. Instanz sofort ohne Probleme. Hast du eine Idee was ich noch testen kann 🙂 Was benötigst du noch an infos 😉
                              • Meistertr
                                Meistertr Developer @Frank579 last edited by
                                @frank579 welches modell? bitte einen debug logauszug vom start
                                  @meistertr
                                  Beide Instanzen S5 Max einer geht der andere Läd die räume einfach nicht Hab ihn auch schon mal komplett saugen lassen ... Log kommt gleich
                                    @meistertr
                                    Hier noch den Log 🙂
                                    2021-06-03 20:28:51.080 - debug: mihome-vacuum.0 (4034) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                    2021-06-03 20:28:51.108 - debug: mihome-vacuum.0 (4034) Objects client ready ... initialize now
                                    2021-06-03 20:28:51.110 - debug: mihome-vacuum.0 (4034) Objects create System PubSub Client
                                    2021-06-03 20:28:51.118 - debug: mihome-vacuum.0 (4034) Objects create User PubSub Client
                                    2021-06-03 20:28:51.118 - debug: mihome-vacuum.0 (4034) Objects client initialize lua scripts
                                    2021-06-03 20:28:51.126 - debug: mihome-vacuum.0 (4034) Objects connected to redis: 127.0.0.1:9001
                                    2021-06-03 20:28:51.129 - debug: mihome-vacuum.0 (4034) objectDB connected
                                    2021-06-03 20:28:51.130 - debug: mihome-vacuum.0 (4034) Redis States: Use Redis connection: 127.0.0.1:9000
                                    2021-06-03 20:28:51.134 - debug: mihome-vacuum.0 (4034) States create System PubSub Client
                                    2021-06-03 20:28:51.134 - debug: mihome-vacuum.0 (4034) States create User PubSub Client
                                    2021-06-03 20:28:51.139 - debug: mihome-vacuum.0 (4034) States connected to redis: 127.0.0.1:9000
                                    2021-06-03 20:28:51.140 - debug: mihome-vacuum.0 (4034) statesDB connected
                                    2021-06-03 20:28:51.338 - debug: mihome-vacuum.0 (4034) Plugin sentry Initialize Plugin (enabled=true)
                                    2021-06-03 20:28:51.423 - info: mihome-vacuum.0 (4034) starting. Version 3.2.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.22.1, js-controller: 3.2.16
                                    2021-06-03 20:28:51.529 - info: mihome-vacuum.0 (4034) check user admin pw iobroker: true
                                    2021-06-03 20:28:51.531 - info: mihome-vacuum.0 (4034) check group user admin group admin: false
                                    2021-06-03 20:28:51.542 - debug: mihome-vacuum.0 (4034) load Map creator... true
                                    2021-06-03 20:28:51.545 - debug: mihome-vacuum.0 (4034) Create State for deviceInfomac
                                    2021-06-03 20:28:51.546 - debug: mihome-vacuum.0 (4034) Create State for deviceInfomodel
                                    2021-06-03 20:28:51.546 - debug: mihome-vacuum.0 (4034) Create State for deviceInfofw_ver
                                    2021-06-03 20:28:51.546 - debug: mihome-vacuum.0 (4034) Create State for deviceInfowifi_signal
                                    2021-06-03 20:28:51.546 - debug: mihome-vacuum.0 (4034) MIIO: Config: ip:192.168.50.41 token: XXXXXXXXX
                                    2021-06-03 20:28:51.548 - info: mihome-vacuum.0 (4034) IOT disabled, delete state
                                    2021-06-03 20:28:51.549 - debug: mihome-vacuum.0 (4034) server started on 0.0.0.0:53421
                                    2021-06-03 20:28:51.557 - debug: mihome-vacuum.0 (4034) Receive <<< Helo <<< 2131002000000000131824dc60b91f63ffffffffffffffffffffffffffffffff
                                    2021-06-03 20:28:51.557 - debug: mihome-vacuum.0 (4034) MAIN: Connected to device, try to get model..
                                    2021-06-03 20:28:51.560 - debug: mihome-vacuum.0 (4034) GETMODELFROMAPI: objModel: {"val":"roborock.vacuum.s5e","ack":true,"ts":1622744524482,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1622713779552}
                                    2021-06-03 20:28:51.560 - debug: mihome-vacuum.0 (4034) Message= {"id":1,"method":"miIO.info"}
                                    2021-06-03 20:28:51.566 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"partner_id":"","id":1,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_1410","ap":{"ssid":"SmartHome","bssid":"e2:63:da:6e:c7:8d","rssi":-83},"netif":{"localIp":"192.168.50.41","mask":"255.255.255.0","gw":"192.168.50.1"},"miio_ver":"miio-client 3.5.8","model":"roborock.vacuum.s5e","mac":"64:90:C1:02:20:BF","token":"XXXXXXXXXXXXXXX","life":62521}}
                                    2021-06-03 20:28:51.566 - debug: mihome-vacuum.0 (4034) GETMODELFROMAPI:Data: {"partner_id":"","id":1,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_1410","ap":{"ssid":"SmartHome","bssid":"e2:63:da:6e:c7:8d","rssi":-83},"netif":{"localIp":"192.168.50.41","mask":"255.255.255.0","gw":"192.168.50.1"},"miio_ver":"miio-client 3.5.8","model":"roborock.vacuum.s5e","mac":"64:90:C1:02:20:BF","token":"XXXXXXXXXXXX","life":62521}}
                                    2021-06-03 20:28:51.566 - debug: mihome-vacuum.0 (4034) Get Device data..0
                                    2021-06-03 20:28:51.566 - debug: mihome-vacuum.0 (4034) Get Device data from robot..
                                    2021-06-03 20:28:51.567 - debug: mihome-vacuum.0 (4034) DeviceModel selected to: roborock.vacuum.s5e
                                    2021-06-03 20:28:51.567 - info: mihome-vacuum.0 (4034) select standard vacuum protocol....
                                    2021-06-03 20:28:51.569 - debug: mihome-vacuum.0 (4034) Xiaomi Cloud: Logging in
                                    2021-06-03 20:28:51.603 - debug: mihome-vacuum.0 (4034) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                                    2021-06-03 20:28:52.074 - info: mihome-vacuum.0 (4034) settest next timer: not available
                                    2021-06-03 20:28:52.658 - debug: mihome-vacuum.0 (4034) Login step1: &&&START&&&{"result":"error","serviceParam":"{\"checkSafePhone\":false,\"checkSafeAddress\":false,\"lsrp_score\":0.0}","qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","code":70016,"captchaUrl":null,"callback":"https://sts.api.io.mi.com/sts","location":"https://account.xiaomi.com/fe/service/login?_json=true&sid=xiaomiio&qs=%253Fsid%253Dxiaomiio%2526_json%253Dtrue&callback=https%3A%2F%2Fsts.api.io.mi.com%2Fsts&_sign=0psXfr43eNI0IX6q9Suk3qWbRqU%3D&serviceParam=%7B%22checkSafePhone%22%3Afalse%2C%22checkSafeAddress%22%3Afalse%2C%22lsrp_score%22%3A0.0%7D&showActiveX=false&theme=&needTheme=false&bizDeviceType=","securityStatus":0,"pwd":0,"_sign":"0psXfr43eNI0IX6q9Suk3qWbRqU=","sid":"xiaomiio","desc":"登录验证失败"}
                                    2021-06-03 20:28:53.535 - debug: mihome-vacuum.0 (4034) Login step2: &&&START&&&{"qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","ssecurity":"o3W5w1oCXFHVd1aHvZNi3Q==","code":0,"passToken":"V1:bVc+HLNQkn0wITZpdR20IOLv1XQtV1PICexQU7S61KGti5bw/7h3oYzN/j+L5+9zp10jf/8sxzW0rGLKEhXYPwpua4SIjFmOm17RxnV1GiPsIZ2z97jAtSepjnTJ1kgGrO79ZZv9s7+eTQ7kxY+oPJGl1ptFHmy9lyPX0rsRwZOtkAoBEsGMaC5XrQPc9eTM8IYKvL1rlKD2u81VRQyA+j7HqPZV/tpXWdCGfSWAcbFXtRRR0CDsEi9YhQAq4O9f8UFazaQhBNJD/PQqxAzo3TUXFgzjQiMu4t7i9UxKPYU=","securityStatus":0,"nonce":4582086323101018112,"userId":6353965320,"cUserId":"2Xh3BEW_HsDJAdUD4fg6WPU8B0A","result":"ok","psecurity":"Kp+ASNrVyl7bjsWoDxRmPw==","captchaUrl":null,"location":"https://sts.api.io.mi.com/sts?d=rpadrj&ticket=0&pwd=1&p_ts=1622744933000&fid=0&p_lm=1&auth=at58%2FopYpD2bVeqpJ3C6bhdjUAG6Of72aRZiSaz%2BOXbxfC%2F8H9ffGwzKqaYi6WRY1C1u5RMqcig%2Bl0QUSTZZy5stz%2F%2BoKun12OecRFSi7XdMkbhXZEY1IofUhqLzD3mKOLO6%2BMB3ocXRq%2BLNy4T5c6RNwi1tsI14MUJvKq%2FWJgE%3D&m=1&tsl=0&nonce=9pCgOu31CK4BnK90&_ssign=0pV2Q70xZSwecm1Qdu7eHxtblCk%3D","pwd":1,"desc":"成功"}
                                    2021-06-03 20:28:53.665 - debug: mihome-vacuum.0 (4034) Login step3: [{"key":"userId","value":"6353965320","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2021-06-03T18:28:53.654Z","lastAccessed":"2021-06-03T18:28:53.665Z"},{"key":"cUserId","value":"2Xh3BEW_HsDJAdUD4fg6WPU8B0A","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2021-06-03T18:28:53.660Z","lastAccessed":"2021-06-03T18:28:53.665Z"},{"key":"serviceToken","value":"u4XTQ/K8NyjIh6l2H9fTFPpzG4cKaMMHxXbqDwMz4GPBGFXvl3E4RB7R2RVOJ5l/vzz1LzxuEWvHxXa7wRGB9UZhqIKm5pZQO2FpjJZMcc4HWHK7nnOzXaXZe8YoB+MN94ZnL85roewPeIZxNDwm8d3Zn/DcSKel5StGAUTUpBM=","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2021-06-03T18:28:53.662Z","lastAccessed":"2021-06-03T18:28:53.665Z"}]
                                    2021-06-03 20:28:53.665 - debug: mihome-vacuum.0 (4034) Xiaomi Cloud: Login successful
                                    2021-06-03 20:28:53.670 - debug: mihome-vacuum.0 (4034) Create State for deviceInfoundefined
                                    2021-06-03 20:28:53.671 - debug: mihome-vacuum.0 (4034) Create State for deviceInfoundefined
                                    2021-06-03 20:28:53.672 - debug: mihome-vacuum.0 (4034) Create State for deviceInfoundefined
                                    2021-06-03 20:28:53.683 - debug: mihome-vacuum.0 (4034) Create State for stockInfoundefined
                                    2021-06-03 20:28:53.686 - debug: mihome-vacuum.0 (4034) Create State for stockInfoundefined
                                    2021-06-03 20:28:53.687 - debug: mihome-vacuum.0 (4034) Create State for stockInfoundefined
                                    2021-06-03 20:28:53.690 - debug: mihome-vacuum.0 (4034) Create State for stockConsumableundefined
                                    2021-06-03 20:28:53.691 - debug: mihome-vacuum.0 (4034) Create State for stockConsumableundefined
                                    2021-06-03 20:28:53.697 - debug: mihome-vacuum.0 (4034) Create State for stockHistoryundefined
                                    2021-06-03 20:28:53.698 - debug: mihome-vacuum.0 (4034) Create State for stockHistoryundefined
                                    2021-06-03 20:28:53.702 - debug: mihome-vacuum.0 (4034) Create State for Queue: queue
                                    2021-06-03 20:28:53.702 - debug: mihome-vacuum.0 (4034) Create State for Queue: clearQueue
                                    2021-06-03 20:28:53.704 - debug: mihome-vacuum.0 (4034) Create State for enableResumeZoneundefined
                                    2021-06-03 20:28:53.704 - info: mihome-vacuum.0 (4034) Map selected create states...
                                    2021-06-03 20:28:53.708 - debug: mihome-vacuum.0 (4034) Create State for map: map64
                                    2021-06-03 20:28:53.708 - debug: mihome-vacuum.0 (4034) Create State for map: actualMap
                                    2021-06-03 20:28:53.708 - debug: mihome-vacuum.0 (4034) Create State for map: mapStatus
                                    2021-06-03 20:28:53.708 - debug: mihome-vacuum.0 (4034) Create State for map: mapURL
                                    2021-06-03 20:28:53.708 - debug: mihome-vacuum.0 (4034) Create State for map: loadMap
                                    2021-06-03 20:28:53.708 - debug: mihome-vacuum.0 (4034) Create State done!
                                    2021-06-03 20:28:53.709 - debug: mihome-vacuum.0 (4034) get params for stock Vacuum
                                    2021-06-03 20:28:53.709 - debug: mihome-vacuum.0 (4034) Message= {"id":2,"method":"get_status"}
                                    2021-06-03 20:28:53.717 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":3367,"state":8,"battery":100,"clean_time":332,"clean_area":5422500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"fan_power":106,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":204,"water_box_carriage_status":1,"mop_forbidden_enable":1}],"id":2}
                                    2021-06-03 20:28:53.717 - debug: mihome-vacuum.0 (4034) setGetStatus {"msg_ver":2,"msg_seq":3367,"state":8,"battery":100,"clean_time":332,"clean_area":5422500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"fan_power":106,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":204,"water_box_carriage_status":1,"mop_forbidden_enable":1,"error_text":"No error"}
                                    2021-06-03 20:28:53.717 - info: mihome-vacuum.0 (4034) change states from State control.fan_power
                                    2021-06-03 20:28:53.729 - info: mihome-vacuum.0 (4034) create states for water box
                                    2021-06-03 20:28:53.730 - info: mihome-vacuum.0 (4034) create states for water box mode
                                    2021-06-03 20:28:53.731 - info: mihome-vacuum.0 (4034) create states for mop
                                    2021-06-03 20:28:53.793 - debug: mihome-vacuum.0 (4034) Message= {"id":3,"method":"get_map_v1"}
                                    2021-06-03 20:28:53.801 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":["retry"],"id":3}
                                    2021-06-03 20:28:54.101 - debug: mihome-vacuum.0 (4034) Message= {"id":4,"method":"get_map_v1"}
                                    2021-06-03 20:28:54.108 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":["retry"],"id":4}
                                    2021-06-03 20:28:54.408 - debug: mihome-vacuum.0 (4034) Message= {"id":5,"method":"get_map_v1"}
                                    2021-06-03 20:28:54.415 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":["rubyslite%2F320349404%2F7"],"id":5}
                                    2021-06-03 20:28:54.416 - debug: mihome-vacuum.0 (4034) Mappointer_updated
                                    2021-06-03 20:28:54.416 - debug: mihome-vacuum.0 (4034) update_Map Mimap enabled
                                    2021-06-03 20:28:54.416 - debug: mihome-vacuum.0 (4034) update_Map need new mapurl
                                    2021-06-03 20:28:54.418 - debug: mihome-vacuum.0 (4034) Message= {"id":6,"method":"get_room_mapping"}
                                    2021-06-03 20:28:54.427 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[],"id":6}
                                    2021-06-03 20:28:54.427 - debug: mihome-vacuum.0 (4034) Message= {"id":7,"method":"get_consumable"}
                                    2021-06-03 20:28:54.428 - debug: mihome-vacuum.0 (4034) Message= {"id":8,"method":"get_network_info"}
                                    2021-06-03 20:28:54.437 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[{"main_brush_work_time":69237,"side_brush_work_time":69237,"filter_work_time":69237,"filter_element_work_time":59372,"sensor_dirty_time":69219}],"id":7}
                                    2021-06-03 20:28:54.437 - debug: mihome-vacuum.0 (4034) Message= {"id":9,"method":"get_clean_summary"}
                                    2021-06-03 20:28:54.454 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":{"ssid":"SmartHome","ip":"192.168.50.41","mac":"64:90:c1:02:20:bf","bssid":"e2:63:da:6e:c7:8d","rssi":-81},"id":8}
                                    2021-06-03 20:28:54.459 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[69219,1176440000,49,[1622711457,1622709889,1621759219,1621757141,1621754893,1621158710,1620568308,1619975461,1619949343,1618733615,1616845998,1615721681,1615127170,1614445195,1613896540,1612608025,1612000844,1611384765,1610874479,1610280635]],"id":9}
                                    2021-06-03 20:28:54.460 - debug: mihome-vacuum.0 (4034) Message= {"id":10,"method":"get_clean_record","params":[1622711457]}
                                    2021-06-03 20:28:54.464 - debug: mihome-vacuum.0 (4034) Message= {"id":11,"method":"get_sound_volume"}
                                    2021-06-03 20:28:54.472 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1622711457,1622711789,332,5422500,0,1,2,3,56]],"id":10}
                                    2021-06-03 20:28:54.472 - debug: mihome-vacuum.0 (4034) Message= {"id":12,"method":"get_clean_record","params":[1622709889]}
                                    2021-06-03 20:28:54.473 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[62],"id":11}
                                    2021-06-03 20:28:54.473 - debug: mihome-vacuum.0 (4034) Message= {"id":13,"method":"get_multi_maps_list"}
                                    2021-06-03 20:28:54.482 - debug: mihome-vacuum.0 (4034) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/320349404/7?Expires=1622746734000&GalaxyAccessKeyId=5271733786445&Signature=W1R8N53zTY3P7ZdS+Emboe4UQmA=
                                    2021-06-03 20:28:54.482 - debug: mihome-vacuum.0 (4034) update_Map got new expires:1622746734
                                    2021-06-03 20:28:54.482 - debug: mihome-vacuum.0 (4034) update_Map got new time:1622744934
                                    2021-06-03 20:28:54.489 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1622709889,1622710194,305,5252500,0,1,2,3,56]],"id":12}
                                    2021-06-03 20:28:54.489 - debug: mihome-vacuum.0 (4034) Message= {"id":14,"method":"get_clean_record","params":[1621759219]}
                                    2021-06-03 20:28:54.490 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[{"max_multi_map":4,"max_bak_map":0,"multi_map_count":1,"map_info":[{"mapFlag":0,"add_time":1621757005,"length":12,"name":"Obergeschoss","bak_maps":[]}]}],"id":13}
                                    2021-06-03 20:28:54.490 - debug: mihome-vacuum.0 (4034) States for 1 Map: [{"mapFlag":0,"add_time":1621757005,"length":12,"name":"Obergeschoss","bak_maps":[]}]
                                    2021-06-03 20:28:54.490 - debug: mihome-vacuum.0 (4034) States for Map: {"0":"Obergeschoss"}
                                    2021-06-03 20:28:54.491 - debug: mihome-vacuum.0 (4034) Startup: getMultiMapsList Anser: true
                                    2021-06-03 20:28:54.491 - debug: mihome-vacuum.0 (4034) Startup: Delete getMultiMapsList
                                    2021-06-03 20:28:54.491 - debug: mihome-vacuum.0 (4034) Message= {"id":15,"method":"get_clean_summary"}
                                    2021-06-03 20:28:54.497 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1621759219,1621759912,693,6577500,0,1,2,3,56]],"id":14}
                                    2021-06-03 20:28:54.497 - debug: mihome-vacuum.0 (4034) Message= {"id":16,"method":"get_clean_record","params":[1621757141]}
                                    2021-06-03 20:28:54.511 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[69219,1176440000,49,[1622711457,1622709889,1621759219,1621757141,1621754893,1621158710,1620568308,1619975461,1619949343,1618733615,1616845998,1615721681,1615127170,1614445195,1613896540,1612608025,1612000844,1611384765,1610874479,1610280635]],"id":15}
                                    2021-06-03 20:28:54.511 - debug: mihome-vacuum.0 (4034) Startup: setGetCleanSummary Anser: true
                                    2021-06-03 20:28:54.511 - debug: mihome-vacuum.0 (4034) Startup: Delete setGetCleanSummary
                                    2021-06-03 20:28:54.511 - debug: mihome-vacuum.0 (4034) Message= {"id":17,"method":"get_consumable"}
                                    2021-06-03 20:28:54.512 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1621757141,1621757598,457,8490000,0,1,2,3,56]],"id":16}
                                    2021-06-03 20:28:54.512 - debug: mihome-vacuum.0 (4034) Message= {"id":18,"method":"get_clean_record","params":[1621754893]}
                                    2021-06-03 20:28:54.522 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[{"main_brush_work_time":69237,"side_brush_work_time":69237,"filter_work_time":69237,"filter_element_work_time":59372,"sensor_dirty_time":69219}],"id":17}
                                    2021-06-03 20:28:54.525 - debug: mihome-vacuum.0 (4034) Startup: setGetConsumable Anser: true
                                    2021-06-03 20:28:54.526 - debug: mihome-vacuum.0 (4034) Startup: Delete setGetConsumable
                                    2021-06-03 20:28:54.526 - debug: mihome-vacuum.0 (4034) Message= {"id":19,"method":"get_map_v1"}
                                    2021-06-03 20:28:54.526 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1621754893,1621756979,2086,35620000,0,1,2,1,52]],"id":18}
                                    2021-06-03 20:28:54.526 - debug: mihome-vacuum.0 (4034) Message= {"id":20,"method":"get_clean_record","params":[1621158710]}
                                    2021-06-03 20:28:54.534 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":["rubyslite%2F320349404%2F7"],"id":19}
                                    2021-06-03 20:28:54.535 - debug: mihome-vacuum.0 (4034) Mappointer_updated
                                    2021-06-03 20:28:54.535 - debug: mihome-vacuum.0 (4034) update_Map Mimap enabled
                                    2021-06-03 20:28:54.535 - debug: mihome-vacuum.0 (4034) update_Map use old mapurl
                                    2021-06-03 20:28:54.535 - debug: mihome-vacuum.0 (4034) Message= {"id":21,"method":"get_carpet_mode"}
                                    2021-06-03 20:28:54.536 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1621158710,1621160901,2191,35707500,0,1,2,1,52]],"id":20}
                                    2021-06-03 20:28:54.536 - debug: mihome-vacuum.0 (4034) Message= {"id":22,"method":"get_clean_record","params":[1620568308]}
                                    2021-06-03 20:28:54.551 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":21}
                                    2021-06-03 20:28:54.551 - info: mihome-vacuum.0 (4034) create state for carpet_mode
                                    2021-06-03 20:28:54.551 - debug: mihome-vacuum.0 (4034) Message= {"id":23,"method":"get_carpet_mode"}
                                    2021-06-03 20:28:54.552 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1620568308,1620570593,2285,36180000,0,1,2,1,52]],"id":22}
                                    2021-06-03 20:28:54.552 - debug: mihome-vacuum.0 (4034) Message= {"id":24,"method":"get_clean_record","params":[1619975461]}
                                    2021-06-03 20:28:54.565 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":23}
                                    2021-06-03 20:28:54.566 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1619975461,1619975962,501,6510000,0,1,2,3,56]],"id":24}
                                    2021-06-03 20:28:54.566 - debug: mihome-vacuum.0 (4034) Message= {"id":25,"method":"get_clean_record","params":[1619949343]}
                                    2021-06-03 20:28:54.574 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1619949343,1619951478,2135,35587500,0,1,2,1,52]],"id":25}
                                    2021-06-03 20:28:54.575 - debug: mihome-vacuum.0 (4034) Message= {"id":26,"method":"get_clean_record","params":[1618733615]}
                                    2021-06-03 20:28:54.582 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1618733615,1618735576,1961,35317500,0,1,2,1,52]],"id":26}
                                    2021-06-03 20:28:54.584 - debug: mihome-vacuum.0 (4034) Message= {"id":27,"method":"get_clean_record","params":[1616845998]}
                                    2021-06-03 20:28:54.649 - debug: mihome-vacuum.0 (4034) 25401
                                    2021-06-03 20:28:54.787 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1616845998,1616848181,2183,36225000,0,1,2,1,52]],"id":27}
                                    2021-06-03 20:28:54.787 - debug: mihome-vacuum.0 (4034) Message= {"id":28,"method":"get_clean_record","params":[1615721681]}
                                    2021-06-03 20:28:54.800 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1615721681,1615723823,2142,36732500,0,1,2,1,52]],"id":28}
                                    2021-06-03 20:28:54.800 - debug: mihome-vacuum.0 (4034) Message= {"id":29,"method":"get_clean_record","params":[1615127170]}
                                    2021-06-03 20:28:54.810 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1615127170,1615129241,2071,36080000,0,1,2,1,52]],"id":29}
                                    2021-06-03 20:28:54.811 - debug: mihome-vacuum.0 (4034) Message= {"id":30,"method":"get_clean_record","params":[1614445195]}
                                    2021-06-03 20:28:54.816 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1614445195,1614447210,2015,35935000,0,1,2,1,52]],"id":30}
                                    2021-06-03 20:28:54.817 - debug: mihome-vacuum.0 (4034) Message= {"id":31,"method":"get_clean_record","params":[1613896540]}
                                    2021-06-03 20:28:54.825 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1613896540,1613898735,2195,36522500,0,1,2,1,52]],"id":31}
                                    2021-06-03 20:28:54.825 - debug: mihome-vacuum.0 (4034) Message= {"id":32,"method":"get_clean_record","params":[1612608025]}
                                    2021-06-03 20:28:54.891 - debug: mihome-vacuum.0 (4034) 25401
                                    2021-06-03 20:28:55.030 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1612608025,1612610154,2129,36230000,0,1,2,1,52]],"id":32}
                                    2021-06-03 20:28:55.030 - debug: mihome-vacuum.0 (4034) Message= {"id":33,"method":"get_clean_record","params":[1612000844]}
                                    2021-06-03 20:28:55.051 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1612000844,1612002933,2089,36487500,0,1,2,1,52]],"id":33}
                                    2021-06-03 20:28:55.051 - debug: mihome-vacuum.0 (4034) Message= {"id":34,"method":"get_clean_record","params":[1611384765]}
                                    2021-06-03 20:28:55.057 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1611384765,1611386844,2079,36262500,0,1,2,1,52]],"id":34}
                                    2021-06-03 20:28:55.057 - debug: mihome-vacuum.0 (4034) Message= {"id":35,"method":"get_clean_record","params":[1610874479]}
                                    2021-06-03 20:28:55.066 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1610874479,1610877149,2670,35790000,0,1,2,1,52]],"id":35}
                                    2021-06-03 20:28:55.066 - debug: mihome-vacuum.0 (4034) Message= {"id":36,"method":"get_clean_record","params":[1610280635]}
                                    2021-06-03 20:28:55.072 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1610280635,1610280980,345,6717500,0,1,2,3,56]],"id":36}
                                    2021-06-03 20:28:55.073 - debug: mihome-vacuum.0 (4034) finish logs all [{"Datum":"3.6","Start":"11:10","Saugzeit":"6 min","Fläche":"5.42 m²","Error":0,"Ende":true},{"Datum":"3.6","Start":"10:44","Saugzeit":"5 min","Fläche":"5.25 m²","Error":0,"Ende":true},{"Datum":"23.5","Start":"10:40","Saugzeit":"12 min","Fläche":"6.58 m²","Error":0,"Ende":true},{"Datum":"23.5","Start":"10:05","Saugzeit":"8 min","Fläche":"8.49 m²","Error":0,"Ende":true},{"Datum":"23.5","Start":"09:28","Saugzeit":"35 min","Fläche":"35.62 m²","Error":0,"Ende":true},{"Datum":"16.5","Start":"11:51","Saugzeit":"37 min","Fläche":"35.71 m²","Error":0,"Ende":true},{"Datum":"9.5","Start":"15:51","Saugzeit":"38 min","Fläche":"36.18 m²","Error":0,"Ende":true},{"Datum":"2.5","Start":"19:11","Saugzeit":"8 min","Fläche":"6.51 m²","Error":0,"Ende":true},{"Datum":"2.5","Start":"11:55","Saugzeit":"36 min","Fläche":"35.59 m²","Error":0,"Ende":true},{"Datum":"18.4","Start":"10:13","Saugzeit":"33 min","Fläche":"35.32 m²","Error":0,"Ende":true},{"Datum":"27.3","Start":"12:53","Saugzeit":"36 min","Fläche":"36.23 m²","Error":0,"Ende":true},{"Datum":"14.3","Start":"12:34","Saugzeit":"36 min","Fläche":"36.73 m²","Error":0,"Ende":true},{"Datum":"7.3","Start":"15:26","Saugzeit":"35 min","Fläche":"36.08 m²","Error":0,"Ende":true},{"Datum":"27.2","Start":"17:59","Saugzeit":"34 min","Fläche":"35.94 m²","Error":0,"Ende":true},{"Datum":"21.2","Start":"09:35","Saugzeit":"37 min","Fläche":"36.52 m²","Error":0,"Ende":true},{"Datum":"6.2","Start":"11:40","Saugzeit":"35 min","Fläche":"36.23 m²","Error":0,"Ende":true},{"Datum":"30.1","Start":"11:00","Saugzeit":"35 min","Fläche":"36.49 m²","Error":0,"Ende":true},{"Datum":"23.1","Start":"07:52","Saugzeit":"35 min","Fläche":"36.26 m²","Error":0,"Ende":true},{"Datum":"17.1","Start":"10:07","Saugzeit":"45 min","Fläche":"35.79 m²","Error":0,"Ende":true},{"Datum":"10.1","Start":"13:10","Saugzeit":"6 min","Fläche":"6.72 m²","Error":0,"Ende":true}]
                                    2021-06-03 20:29:01.561 - debug: mihome-vacuum.0 (4034) Receive <<< Helo <<< 2131002000000000131824dc60b91f6dffffffffffffffffffffffffffffffff
                                    2021-06-03 20:29:11.567 - debug: mihome-vacuum.0 (4034) Receive <<< Helo <<< 2131002000000000131824dc60b91f77ffffffffffffffffffffffffffffffff
                                    2021-06-03 20:29:12.816 - info: mihome-vacuum.0 (4034) Got terminate signal TERMINATE_YOURSELF
                                    2021-06-03 20:29:12.816 - info: mihome-vacuum.0 (4034) terminating
                                    2021-06-03 20:29:12.816 - debug: mihome-vacuum.0 (4034) Plugin sentry destroyed
                                    2021-06-03 20:29:12.817 - info: mihome-vacuum.0 (4034) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                      Alles klar das verstehe ich natürlich. Falls ich bei irgendwelchen simplen Sachen helfen kann was dazu hilft den Zyklus zu integrieren, dann sag Bescheid.
                                      • U
                                        UHT last edited by
                                        gibt es das vis widget nicht mehr?
                                        • Ronny Gerndt
                                          Ronny Gerndt last edited by
                                          hab seit letzter Wochen einen Roborock S7 und wollte den mit iobroker verbinden.
                                          Die Verbindung bekomme ich soweit auch hin. Token usw. hat geklappt.
                                          Ich habe Version 3.20 am laufen und bekomme in endlosschleife diese Log Ausgaben.
                                          mihome-vacuum.0	2021-06-07 10:11:32.591	debug	(17421) Helo message Timeout
                                          mihome-vacuum.0	2021-06-07 10:11:20.589	debug	(17421) Time difference between Mihome Vacuum and ioBroker: -1623027974 sec
                                          mihome-vacuum.0	2021-06-07 10:11:20.588	debug	(17421) Receive <<< Helo <<< 213100200000000018cf43ce000063a2ffffffffffffffffffffffffffffffff
                                          mihome-vacuum.0	2021-06-07 10:11:19.784	debug	(17421) MIIO RECIVE: {"id":326,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":100}
                                          mihome-vacuum.0	2021-06-07 10:11:19.576	debug	(17421) Message= {"id":326,"method":"get_carpet_mode"}
                                          mihome-vacuum.0	2021-06-07 10:11:19.575	debug	(17421) MIIO RECIVE: {"id":325,"result":[90],"exe_time":200}
                                          mihome-vacuum.0	2021-06-07 10:11:19.285	debug	(17421) Message= {"id":325,"method":"get_sound_volume"}
                                          mihome-vacuum.0	2021-06-07 10:11:19.274	debug	(17421) MIIO RECIVE: {"id":324,"result":{"ssid":"Familie-Gerndt","ip":"192.168.178.70","mac":"b0:4a:39:15:75:03","bssid":"2c:91:ab:a5:2f:9a","rssi":-47},"exe_time":100}
                                          mihome-vacuum.0	2021-06-07 10:11:19.085	debug	(17421) Message= {"id":324,"method":"get_network_info"}
                                          mihome-vacuum.0	2021-06-07 10:11:19.083	debug	(17421) setGetStatus {"msg_ver":2,"msg_seq":609,"state":8,"battery":90,"clean_time":2399,"clean_area":30630000,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1
                                          mihome-vacuum.0	2021-06-07 10:11:19.082	debug	(17421) MIIO RECIVE: {"id":323,"result":[{"msg_ver":2,"msg_seq":609,"state":8,"battery":90,"clean_time":2399,"clean_area":30630000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_f
                                          mihome-vacuum.0	2021-06-07 10:11:18.814	debug	(17421) Message= {"id":323,"method":"get_status"}
                                          mihome-vacuum.0	2021-06-07 10:11:18.813	debug	(17421) get params for stock Vacuum
                                          mihome-vacuum.0	2021-06-07 10:11:10.583	debug	(17421) Time difference between Mihome Vacuum and ioBroker: -1623027974 sec
                                          mihome-vacuum.0	2021-06-07 10:11:10.582	debug	(17421) Receive <<< Helo <<< 213100200000000018cf43ce00006398ffffffffffffffffffffffffffffffff
                                          mihome-vacuum.0	2021-06-07 10:11:00.533	debug	(17421) Helo message Timeout
                                          mihome-vacuum.0	2021-06-07 10:10:58.811	debug	(17421) MIIO Receive Timeout<<<
                                          mihome-vacuum.0	2021-06-07 10:10:56.809	debug	(17421) Message= {"id":322,"method":"get_carpet_mode"}
                                          mihome-vacuum.0	2021-06-07 10:10:56.809	debug	(17421) ERROR at setGetSoundVolume: MESSAGE TIMEOUT
                                          mihome-vacuum.0	2021-06-07 10:10:56.807	debug	(17421) MIIO Receive Timeout<<<
                                          mihome-vacuum.0	2021-06-07 10:10:54.805	debug	(17421) Message= {"id":321,"method":"get_sound_volume"}
                                          mihome-vacuum.0	2021-06-07 10:10:54.797	debug	(17421) MIIO RECIVE: {"id":320,"result":{"ssid":"Familie-Gerndt","ip":"192.168.178.70","mac":"b0:4a:39:15:75:03","bssid":"2c:91:ab:a5:2f:9a","rssi":-52},"exe_time":101}
                                          mihome-vacuum.0	2021-06-07 10:10:53.045	debug	(17421) Message= {"id":320,"method":"get_network_info"}
                                          mihome-vacuum.0	2021-06-07 10:10:53.043	debug	(17421) setGetStatus {"msg_ver":2,"msg_seq":607,"state":8,"battery":89,"clean_time":2399,"clean_area":30630000,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1
                                          mihome-vacuum.0	2021-06-07 10:10:53.030	debug	(17421) MIIO RECIVE: {"id":319,"result":[{"msg_ver":2,"msg_seq":607,"state":8,"battery":89,"clean_time":2399,"clean_area":30630000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_f
                                          mihome-vacuum.0	2021-06-07 10:10:52.839	debug	(17421) Message= {"id":319,"method":"get_status"}
                                          mihome-vacuum.0	2021-06-07 10:10:52.838	debug	(17421) get params for stock Vacuum
                                          Es kommt also ständig ein Timeout und das es eine Zeitdifferenz gibt. Kann man da was dagegen tun?
                                          Danke und Grüße
                                          Ronny
                                            tobitobsta last edited by
                                            hat irgendwer die 3.2.0 Version mit einem S5 am Laufen? Ich habe ihn nicht zum Laufen bekommen hinsichtlich "load rooms" - zurück auf 2.5.5 funktioniert wieder alles einwandfrei.
                                            Im debug protokoll ist mir aufgefallen, dass er bei 3.2.0 irgendwas mit "unknown device model" sagte...
                                            und Frage 2: funktioniert beim S5 die Detektion der Wischeinheit? bei mir bleibt der "water_box" Datenpunkt immer auf false - mag aber sein, dass das der S5 das gar nicht kann.
                                            1198
                                            361584
