    4. Zigbee Adapter Probleme
      Dragon @arteck last edited by
      @arteck
      Entschuldige, bin heut Abend erst wieder daheim, dann werde ich das aber sofort machen. Du hast selbstverständlich Recht damit.
        @arteck
        zigbee.0
        2021-06-02 13:06:38.980	info	Installed Version: iobroker.zigbee@1.5.5
        zigbee.0
        2021-06-02 13:06:38.857	error	Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_TI_CC2538_USB_CDC-if00' at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32) at Generator.next (<anonymous>) at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71 at new Promise (<anonymous>) at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12) at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49) at SerialPort._error (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14) at /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
        zigbee.0
        2021-06-02 13:06:38.854	error	Failed to start Zigbee
        zigbee.0
        2021-06-02 13:06:38.581	info	Starting Zigbee npm ...
        zigbee.0
        2021-06-02 13:06:38.409	info	starting. Version 1.5.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.2.16
        host.raspberrypi
        2021-06-02 13:06:34.863	info	instance system.adapter.zigbee.0 started with pid 24718
        host.raspberrypi
        2021-06-02 13:06:34.809	info	"system.adapter.zigbee.0" enabled
        mit der Version hatte es vor dem neu aufsetzen ohne Probleme funktioniert.
          Dragon last edited by Dragon
          Deaktivieren des Adapters führt hier zu:
          host.raspberrypi
          2021-06-02 13:10:27.976	info	instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          zigbee.0
          2021-06-02 13:10:27.327	error	Cannot read property 'getEntries' of null
          zigbee.0
          2021-06-02 13:10:27.327	error	TypeError: Cannot read property 'getEntries' of null at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:220:55) at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:240:16) at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:303:31) at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:210:49) at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:222:43) at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:196:42) at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:368:20) at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:696:41) at processTicksAndRejections (internal/process/task_queues.js:97:5)
          zigbee.0
          2021-06-02 13:10:27.325	error	unhandled promise rejection: Cannot read property 'getEntries' of null
          zigbee.0
          2021-06-02 13:10:27.324	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          zigbee.0
          2021-06-02 13:10:27.322	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          zigbee.0
          2021-06-02 13:10:27.321	info	terminating
          zigbee.0
          2021-06-02 13:10:27.319	warn	Failed to stop zigbee during startup
          zigbee.0
          2021-06-02 13:10:27.315	info	Zigbee: disabling joining new devices.
          zigbee.0
          2021-06-02 13:10:27.309	info	cleaned everything up...
          host.raspberrypi
          2021-06-02 13:10:27.313	info	stopInstance system.adapter.zigbee.0 send kill signal
          zigbee.0
          2021-06-02 13:10:27.307	info	Got terminate signal TERMINATE_YOURSELF
          host.raspberrypi
          2021-06-02 13:10:27.290	info	stopInstance system.adapter.zigbee.0 (force=false, process=true)
          host.raspberrypi
          2021-06-02 13:10:27.286	info	"system.adapter.zigbee.0" disabled
          Er ist dann aber deaktiviert.
          mit der 1.5.6 habe ich mir das System zerschossen. Darum habe ich die nicht wieder genutzt... Am Ende zeigte er eine Instanz von Zigbee an, aber unter Adapter war der Adapter nicht installiert.... Darum musste ich das ganze dann neu machen.
            robbsen last edited by
            Bin mir nicht sicher ob es der selbe Fehler ist aber ich vermute es:
            Version eist 1.5.6
            zigbee.0
            2021-06-02 17:20:31.236	error	Error herdsman start
            zigbee.0
            2021-06-02 17:20:31.234	error	Failed to start Zigbee
            zigbee.0
            2021-06-02 17:20:31.230	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
            zigbee.0
            2021-06-02 17:20:30.313	info	Installed Version: iobroker.zigbee
            zigbee.0
            2021-06-02 17:20:30.237	info	Starting Zigbee npm ...
            zigbee.0
            2021-06-02 17:20:30.233	info	Try to reconnect. 1 attempts left
            zigbee.0
            2021-06-02 17:20:20.228	error	Error herdsman start
            zigbee.0
            2021-06-02 17:20:20.226	error	Failed to start Zigbee
            zigbee.0
            2021-06-02 17:20:20.224	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
            zigbee.0
            2021-06-02 17:20:20.219	error	Re-commissioning your network will require re-pairing of all devices!
            zigbee.0
            2021-06-02 17:20:20.217	error	If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
            zigbee.0
            2021-06-02 17:20:20.215	error	Please update configuration to prevent further issues.
            zigbee.0
            2021-06-02 17:20:20.213	error	- Channel List: configured=11, adapter=11
            zigbee.0
            2021-06-02 17:20:20.211	error	- Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
            zigbee.0
            2021-06-02 17:20:20.209	error	- Extended PAN ID: configured=00124b0008c985f1, adapter=00124b0008c985f1
            zigbee.0
            2021-06-02 17:20:20.206	error	- PAN ID: configured=6754, adapter=6756
            zigbee.0
            2021-06-02 17:20:20.203	error	Configuration is not consistent with adapter state/backup!"
              Dragon @robbsen last edited by
              @robbsen den Error herdsman start hatte ich mit der 1.5.6 auch. Da es mir leider nicht möglich war auf
              1.5.5 zurück zu gehen musste ich den Broker neu aufsetzen. Mit der 1.5.5 gab es dann den Fehler hier und ich befürchte hardwaremäßig etwas zerstört zu haben an dem Stick oder firmwaremäßig.... Aber warten wir Mal auf die Antwort von arteck...
                robbsen @Dragon last edited by
                @dragon ohje....
                ich muss dringend von der Raspberry Slave Lösung weg... die sicher ich einfach zu selten.
                an einen Hardwaredefekt glaube ich aber nicht, wieso sollte die Software den Stick zerstören... 😉
                  robbsen @Dragon last edited by robbsen
                  @dragon hardwaremäßig etwas zerstört zu haben an dem Stick oder firmwaremäßig....
                  da kann ich beruhigen. Habe einen zweiten Stick auf meinem Master mit Proxmox hängen. Dort habe ich eben nen Backup mit Version 1.5.5 eingespielt und dieser ist zumindest wieder grün. Scheint als "lediglich" ein Software und Einstellungsproblem zu sein.
                  Nachtrag: Nachdem ich dort das Update wieder auf 1.5.6 gemacht habt ist auch dort der Stick wieder Tod!
                  Noch ein Nachtrag.. habe nach sehr viel Neuinstallieren, deinstallieren , Neustarten irgendwann Glück gehabt:
                  Dafür habe ich rm -R /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json genutzt und B: die PAN-ID geändert, diese stand bei mir auf 6754 erwartet wurde aber lt. LOG 6755
                  Die 6754 wird auf meinem Master bei der anderen Instanz verwendet, also irgendwie auch logisch.
                  nur verbunden sind die Geräte noch nicht, ggf. muss ich diese also noch manuell neu anlernen. Aber ein Fortschritt
                  seitdem ist auch Version 1.5.6 auf dem Slave grün und alle Geräte scheinbar auch wieder da
                    Dragon @robbsen last edited by Dragon
                    @robbsen Tja, das Problem ist gelöst.... Mit einer sehr verrückten Maßnahme... Ich habe die PAN-ID auf 6755 geändert und schon läuft der Adapter..... Die 6754 die vorher eingestellt war akzeptiert er nicht. Naja mir solls egal sein.... Hauptsache es läuft wieder. Sogar die 1.5.6 läuft jetzt.....
                      mit einer Änderung der PANID wird das Netz neu aufgebaut.. das wird immer funktionieren ...da hier die /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json neu geschrieben wird..
                      also nix ungewöhnliches.. musst ihr halt alles neu anlernen
                        robbsen @arteck last edited by robbsen
                        @arteck danke für die Aufklärung 🙂
                        habe gestern noch mal auf meinem Master von 1.5.5 auf 1.5.6 geupdatet auch dort blieb der Adapter rot, habe auch dort die PAN-ID auf 6755 geändert. Ich musste in diesem Fall nichts neu anlernen. Kann es sein, dass das Update die vorherige PAN-ID schlicht nicht übernimmt?
                          arteck Developer Most Active @robbsen last edited by
                          @robbsen es sind viele Probleme die wir gerade analysieren..
                            @arteck dann weiterhin viel Erfolg 🙂
                            916
