    4. ZigBee neue Version 1.5.x
    • Vumer
      Vumer last edited by
      lohnt sich dieser Umbau https://zigbee.blakadder.com/Lidl_TYGWZ-01.html
      wird das mit dem Adapter funktionieren?
        anno171986 last edited by
        Hallo ich habe leider auch mit dem Zigbee Adapter 1.5.6 Probleme, hier das Log dazu:
        host.raspberrypi	2021-06-03 23:51:58.771	info	Restart adapter system.adapter.zigbee.0 because enabled
        host.raspberrypi	2021-06-03 23:51:58.770	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        host.raspberrypi	2021-06-03 23:51:58.770	error	Caught by controller[0]: }
        host.raspberrypi	2021-06-03 23:51:58.770	error	Caught by controller[0]: ]
        host.raspberrypi	2021-06-03 23:51:58.769	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.zigbee/main.js'
        host.raspberrypi	2021-06-03 23:51:58.769	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js',
        host.raspberrypi	2021-06-03 23:51:58.769	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.zigbee/lib/utils.js',
        host.raspberrypi	2021-06-03 23:51:58.769	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman-converters/index.js',
        host.raspberrypi	2021-06-03 23:51:58.768	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman-converters/devices/danfoss.js',
        host.raspberrypi	2021-06-03 23:51:58.768	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman-converters/lib/ota/index.js',
        host.raspberrypi	2021-06-03 23:51:58.768	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman-converters/lib/ota/ledvance.js',
        host.raspberrypi	2021-06-03 23:51:58.767	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman-converters/lib/ota/common.js',
        host.raspberrypi	2021-06-03 23:51:58.767	error	Caught by controller[0]: requireStack: [
        host.raspberrypi	2021-06-03 23:51:58.767	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
        host.raspberrypi	2021-06-03 23:51:58.766	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19) {
        host.raspberrypi	2021-06-03 23:51:58.766	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
        host.raspberrypi	2021-06-03 23:51:58.766	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
        host.raspberrypi	2021-06-03 23:51:58.766	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
        host.raspberrypi	2021-06-03 23:51:58.765	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
        host.raspberrypi	2021-06-03 23:51:58.765	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman-converters/lib/ota/common.js:5:15)
        host.raspberrypi	2021-06-03 23:51:58.765	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
        host.raspberrypi	2021-06-03 23:51:58.764	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
        host.raspberrypi	2021-06-03 23:51:58.764	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:667:27)
        host.raspberrypi	2021-06-03 23:51:58.764	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
        host.raspberrypi	2021-06-03 23:51:58.764	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/main.js
        host.raspberrypi	2021-06-03 23:51:58.763	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js
        host.raspberrypi	2021-06-03 23:51:58.763	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/lib/utils.js
        host.raspberrypi	2021-06-03 23:51:58.763	error	Caught by controller[0]: - /opt/iobroker/node_modules/zigbee-herdsman-converters/index.js
        host.raspberrypi	2021-06-03 23:51:58.762	error	Caught by controller[0]: - /opt/iobroker/node_modules/zigbee-herdsman-converters/devices/danfoss.js
        host.raspberrypi	2021-06-03 23:51:58.762	error	Caught by controller[0]: - /opt/iobroker/node_modules/zigbee-herdsman-converters/lib/ota/index.js
        host.raspberrypi	2021-06-03 23:51:58.762	error	Caught by controller[0]: - /opt/iobroker/node_modules/zigbee-herdsman-converters/lib/ota/ledvance.js
        host.raspberrypi	2021-06-03 23:51:58.762	error	Caught by controller[0]: - /opt/iobroker/node_modules/zigbee-herdsman-converters/lib/ota/common.js
        host.raspberrypi	2021-06-03 23:51:58.761	error	Caught by controller[0]: Require stack:
        host.raspberrypi	2021-06-03 23:51:58.761	error	Caught by controller[0]: Error: Cannot find module 'buffer-crc32'
        host.raspberrypi	2021-06-03 23:51:58.761	error	Caught by controller[0]: ^
        host.raspberrypi	2021-06-03 23:51:58.760	error	Caught by controller[0]: throw err;
        host.raspberrypi	2021-06-03 23:51:58.760	error	Caught by controller[0]: internal/modules/cjs/loader.js:818
        host.raspberrypi	2021-06-03 23:51:56.709	info	instance system.adapter.zigbee.0 started with pid 3229
        RPi 3
        Zigbee 1.5.6
        CC2538 Stick
        Hat jemand einen Tipp?
          arteck Developer Most Active @anno171986 last edited by arteck
          @anno171986 bei dir scheint der adapter nicht richtig installier zu sein..
          installier nochmal drüber von GIT https://github.com/ioBroker/ioBroker.zigbee/wiki/GIT-install
          @bjoern77
          adapter stopp
          dann
          rm /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json
          adapter starten
          A Bjoern77 2 Replies Last reply Reply Quote 0
            anno171986 @arteck last edited by
            @arteck said in ZigBee neue Version 1.5.x:
            Ich habe schon folgendes gemacht:
            @mr-x said in ZigBee neue Version 1.5.x:
            @arteck sagte in ZigBee neue Version 1.5.x:
            @Mr-X
            bevor du anfängst was wild auszuprobieren
            adapter stoppen DEN RICHTIGEN
            console auf AUF DEM RICHTIGEN HOST AUF
            rm -R /opt/iobroker/node_modules/zigbee-herdsman
            rm -R /opt/iobroker/node_modules/zigbee-herdsman-converter
            rm -R /opt/iobroker/node_modules/@serialport
            rm -R /opt/iobroker/node_modules/iobroker.zigbee
            dann von GIT ... AUF DEM RICHTIGEN HOST installieren https://github.com/ioBroker/ioBroker.zigbee/wiki/GIT-install
            nix löschen... nix deinstallieren... nur das machen was da oben steht
            Hey, sorry, soll ich das ganze auf dem Master machen, oder auf dem Slave, wo Zigbee nicht mehr tut?
            Bei
            hat er einen Fehler ausgegeben, dass er das modul nicht entfernen kann, da nicht gefunden (oder so).
            Bevor ich das (über GIT installiert) gemacht habe, gab es einen ähnlichen Fehler, jedoch war dort der Fehler dass ein "Serial" (oder so ähnlich) nicht gefunden werden konnte.
            Soll ich es einfach nochmal probieren?
              @anno171986 ich kann dir nicht folgen .. aber ja
              • david83
                david83 last edited by
                Hallo zusammen, ich habe gestern das Update von 1.4.4 auf 1.5.6 gemacht. Soweit ist erstmal alles in Ordnung. Das einzige was jetzt gar nicht mehr funktioniert ist der Firmware aktualisieren Button. Wenn ich diesen drücke, passiert garnichts. Ich habe verschiedene Browser ausprobiert. Ich habe mir das Log angeschaut und habe keine Warnungen oder Error Einträge. Ist da was bekannt? Gerne stelle ich weitere Infos zur Verfügung. Was wird gebraucht?
                Mfg
                David
                arteck mickym 2 Replies Last reply Reply Quote 0
                  arteck Developer Most Active @david83 last edited by arteck
                  @david83 doch ... schau im LOG..da wird der start des checks Protokolliert
                  david83 1 Reply Last reply Reply Quote 0
                    @arteck Ich habe gestern auch von Version 1.4.4 auf 1.5.6 geupdated. Dann kam ein Fehlerbild, was ähnlich dem ist, was ich oben gepostet habe, jedoch war dort von einem "serialport" Modul (oder so ähnlich die Rede, welches nicht gefunden wurde.
                    Nach dem ich etwas gesucht habe, hatte ich dieses Thema hier gefunden und habe dann folgendes gemacht:
                    iobroker stoppen
                    Bei
                    kam der Fehler dass er diesen nicht entfernen konnte, da nicht vorhanden.
                    Danach von den Adapter von GIT installiert installieren https://github.com/ioBroker/ioBroker.zigbee/wiki/GIT-install
                    iobroker starten
                    Das ist der aktuelle Stand und ich bekomme folgenden Fehler:
                    Ich probiere heute Abend dann nochmal folgendes:
                    iobroker stoppen
                    iobroker starten
                      @anno171986 sagte in ZigBee neue Version 1.5.x:
                      hier fehlt ein Buchstabe am ende.. mein Fehler
                      rm -R /opt/iobroker/node_modules/zigbee-herdsman-converters
                      ALSO SO MUSS DAS
                      E A 2 Replies Last reply Reply Quote 1
                        eMd @arteck last edited by
                        @arteck
                        Benutzt du immernoch das zigbee Modul aus deiner Signatur? Hast du damit keine Probleme in 1.5.6?
                        MfG
                        eMd
                        arteck 1 Reply Last reply Reply Quote 1
                          arteck Developer Most Active @eMd last edited by arteck
                          @emd ich habe mehrere Coordinatoren.. auch zum testen..sowie unterschiedliche Hardware (pi,vm,rock64) und Betriebsysteme
                          • mickym
                            mickym Most Active @david83 last edited by mickym
                            @david83 hast Du auch die Kacheln umgedreht? Das Ergebnis des OTA Firmware Checks siehst Du auf der Rückseite (früher Vorderseite)
                              ALSO SO MUSS DAS
                              Nach dem ersten Befehl kommt jetzt folgende Frage:
                              rm: in schreibgeschütztes Verzeichnis '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build' absteigen?
                                msauer @anno171986 last edited by
                                @anno171986 sudo davor..dann sollte es gehen
                                  anno171986 @msauer last edited by
                                  @msauer said in ZigBee neue Version 1.5.x:
                                  Das hat geklappt, jetzt kommt
                                  pi@raspberrypi:~ $ sudo rm -R /opt/iobroker/node_modules/@serialport
                                  rm: das Entfernen von '/opt/iobroker/node_modules/@serialport' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
                                  • Asgothian
                                    Asgothian Developer @anno171986 last edited by
                                    @anno171986
                                    Dann ist schon alles gut - das Verzeichnis ist weg.
                                    A.
                                      anno171986 @Asgothian last edited by
                                      @asgothian said in ZigBee neue Version 1.5.x:
                                      @anno171986
                                      A.
                                      Ok. Ich habe jetzt alle 4 Zeilen ausgeführt und den iobroker wieder gestartet. Wenn ich jetzt bei Instanzen gucke, ist da immer noch ein "zigbee.0", ist das richtig so? Habe ich das nicht gerade über die Konsole deinstalliert? Auch unter Adapter steht bei Zigbee "Installierte Version: 1.5.6" und "Installierte Instanzen: 1"
                                        @anno171986 na klar ist die noch da.. aber wird nicht laufen.... da der sourcecode dazu fehlt..den hast du gerade hintenrum gelöscht
                                        also musst du neu über GIT installieren..
                                          anno171986 @arteck last edited by anno171986
                                          Installation lief erfolgreich durch. Jetzt ist der Adapter schon mal gelb und nicht mehr rot. "Verbunden mit zigbee: falsch", die anderen beiden sind wahr.
                                          zigbee.0	2021-06-04 12:03:38.064	error	(16566) Error herdsman start
                                          zigbee.0	2021-06-04 12:03:38.063	error	(16566) Failed to start Zigbee
                                          zigbee.0	2021-06-04 12:03:38.061	error	(16566) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                                            luie last edited by luie
                                            Der Link auf die Modelnummer in beiden Kacheln ist fehlerhaft.
                                            Richtig ist Link Text
                                            Und
                                            betrifft das nur den Link in der Geräteinformation. Der richtige Link.
                                            31.7k
                                            79.9k
                                            579
                                            111078
