    3. Cloud Dienste
    4. Neue Version vom Cloud Adapter
    • Bluefox
      Bluefox last edited by
      @blauholsten:
      @Bluefox:
      Bitte die neue Version vom cloud adapter vom git testen.
      Bluefox `
      habe festgestellt das folgende error Meldungen auflaufen:
      host.iobroker	2017-01-20 20:12:09.807	info	Restart adapter system.adapter.cloud.0 because enabled
      host.iobroker	2017-01-20 20:12:09.805	error	instance system.adapter.cloud.0 terminated with code 0 (OK)
      cloud.0	2017-01-20 20:12:09.790	info	terminating
      cloud.0	2017-01-20 20:12:09.758	info	Connection changed: DISCONNECTED
      cloud.0	2017-01-20 20:12:09.756	error	at Decoder.add (/opt/iobroker/node_modules/iobroker.cloud/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:246:12)
      cloud.0	2017-01-20 20:12:09.756	error	at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.cloud/node_modules/socket.io-client/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
      cloud.0	2017-01-20 20:12:09.756	error	at Decoder. (/opt/iobroker/node_modules/iobroker.cloud/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      cloud.0	2017-01-20 20:12:09.756	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.cloud/node_modules/socket.io-client/lib/manager.js:332:8)
      cloud.0	2017-01-20 20:12:09.756	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.cloud/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      cloud.0	2017-01-20 20:12:09.756	error	at Manager. (/opt/iobroker/node_modules/iobroker.cloud/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      cloud.0	2017-01-20 20:12:09.756	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.cloud/node_modules/socket.io-client/lib/socket.js:228:12)
      cloud.0	2017-01-20 20:12:09.756	error	at Socket.onevent (/opt/iobroker/node_modules/iobroker.cloud/node_modules/socket.io-client/lib/socket.js:270:10)
      cloud.0	2017-01-20 20:12:09.756	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.cloud/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      cloud.0	2017-01-20 20:12:09.756	error	at Socket. (/opt/iobroker/node_modules/iobroker.cloud/main.js:695:44)
      cloud.0	2017-01-20 20:12:09.756	error	TypeError: Cannot read property 'additionalApplianceDetails' of undefined
      cloud.0	2017-01-20 20:12:09.746	error	uncaught exception: Cannot read property 'additionalApplianceDetails' of undefined
      Danke.
      Habe gefixt und bitte vom git updaten (version ist gleich)
      • blauholsten
        blauholsten Developer last edited by
        @Bluefox:
        Habe gefixt und bitte vom git updaten (version ist gleich) `
        Okay danke.
        Habe das update gemacht, werde heute Abend berichten.
        • blauholsten
          Fehler tritt nicht mehr auf!!!
            snudel last edited by
            habs auch installiert. leider funktioniert die verbindung zu alexa im moment nicht.
            ansonsten sieht es gut aus. musste aber auch noch zur console und update machen
              Lumumba last edited by
              Erst einmal ein fettes Danke für dieses super Feature!
              Leider habe ich gerade ein git update gemacht und bekomme nun folgende Fehler:
              host.raspberrypi	2017-01-24 20:43:11.081	error	instance system.adapter.cloud.0 terminated with code 0 (OK)
              cloud.0	2017-01-24 20:43:11.055	info	terminating
              cloud.0	2017-01-24 20:43:11.027	error	at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:322:16)
              cloud.0	2017-01-24 20:43:11.027	error	at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:246:12)
              cloud.0	2017-01-24 20:43:11.027	error	at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
              cloud.0	2017-01-24 20:43:11.027	error	at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
              cloud.0	2017-01-24 20:43:11.027	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
              cloud.0	2017-01-24 20:43:11.027	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
              cloud.0	2017-01-24 20:43:11.027	error	at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
              cloud.0	2017-01-24 20:43:11.027	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
              cloud.0	2017-01-24 20:43:11.027	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
              cloud.0	2017-01-24 20:43:11.027	error	at Socket. (/opt/iobroker/node_modules/iobroker.cloud/main.js:322:77)
              cloud.0	2017-01-24 20:43:11.027	error	TypeError: Cannot read property 'de' of null
              cloud.0	2017-01-24 20:43:11.020	error	uncaught exception: Cannot read property 'de' of null
              HELP!!! 😉
                Schechinger last edited by
                …ist bei mr genau so. cloud Adapter geht ständig an und aus...
                • Bluefox
                  Habe ein Fehler auf git gefixt. Bitte berichten.
                  • Bluefox
                    @Schechinger:
                    …ist bei mr genau so. cloud Adapter geht ständig an und aus... `
                    Gleiche Fehlermeldung?
                    Denk immer dran. Ich habe kein Kristallkugel und ich brauche "input" 😉 😉 Logs passen gut als input.
                      So einen Support hätte ich gerne von einem Dienstleister, der Geld dafür bekommt…
                      Lieben Dank, hat aber leider nicht geholfen.
                      Der gleiche Fehler tritt weiterhin auf.
                      Edit sagt zum 1.:
                      Moment, die main.js hat sich nicht geändert im ioBroker... Oo
                      Ist es "nur" die Zeile 322?
                      Edit sagt zum 2.:
                      Ich habe es...
                      Die Änderung aus Zeile 322 auch in den Zeilen 337 und 352 übernehmen.
                      Für die die es schnell so fixen wollen:
                      Zeile 322 von
                      if (typeof smartName === 'object') smartName = smartName[lang] || smartName.en;
                      in
                      if (smartName && typeof smartName === 'object') smartName = smartName[lang] || smartName.en;
                      ändern.
                      in den Zeilen 337 und 352 auch einfach "smartName && " vor das typeof smartName === 'object' setzen.
                        @Bluefox:
                        @Schechinger:
                        Denk immer dran. Ich habe kein Kristallkugel und ich brauche "input" 😉 😉 Logs passen gut als input. `
                        Ja gleiche Fehlermeldung. Sorry für den nicht vorhandenen LOG. Bei mir läuft der Adapter wieder VIELEN DANK !
                        • Bluefox
                          @Lumumba:
                          Edit sagt zum 1.:
                          Edit sagt zum 2.:
                          Ich habe es...
                          Zeile 322 von
                          in
                          ändern.
                          in den Zeilen 337 und 352 auch einfach "smartName && " vor das typeof smartName === 'object' setzen. `
                          Danke. Erledigt.
                          • Meistertr
                            habe gerade die Version 6.2 installiert, nun sind meine Smartname dureinander (Jalousien sind nun auf einla alle in einem)und wenn ich einen anderen Namen vergeben will, für Heizung Temperatur, steht da nciht temperatur und alle Regler sind wieder in einem.Siehe Bilder
                            Auch der Smartname in den Geräten lässt sich nciht mehr verändern, spring immer wieder auf den alten namen
                            • bahnuhr
                              @Bluefox:
                              Gruß,
                              Bluefox `
                              Guten Morgen,
                              wie testet man die neue Version vom git ?
                              Was muss ich da wie wo eingeben ?
                              mfg
                              Dieter
                              Nachtrag:
                              habs gefunden; man muss auf dieses runde Symbol auf der Adapter Seite gehen.
                                @bahnuhr:
                                wie testet man die neue Version vom git ? `
                                http://www.iobroker.net/?page_id=5379&l … stallieren
                                Rainer
                                  fwshibby last edited by
                                  Guten Tag liebes Forum,
                                  bevor ich meinen ersten Beitrag hier poste, wollte ich mich für die Arbeit hier bedanken.
                                  Es ist wirklich erstaunlich was IOBroker alles kann und Bluefox für Arbeit reingesteckt hat.
                                  Vollen Respekt für diese Leistung.
                                  Es ist auch traurig das ein renomierter Hersteller wie Homematic, die Anbindung zu Alexa nicht auf die Reihe bekommt und den Markteinstieg so verpasst.
                                  Nun zu meinem Anliegen. Ich habe seit heute morgen ein gelbes Zeichen im Cloud Adapter.
                                  Alexa kann keine Verbindung herstellen. Habe leider keine Informatikkenntnisse und wurschtel mich von Beitrag zu Beitrag.
                                  Ich habe versucht eine neue Version von github zu installieren, leider kam hier folgender Fehler:
                                  Und mein LOG welches mir folgendes gelb anzeigt :
                                  Hat jemand einen Lösungvorschlag ? Ich bedanke mich im Vorraus.
                                    Smartuser last edited by
                                    ich hab nun den Cloud-Adapter aus dem Git installiert.
                                    Die neue Funktion "Platziere Funktionsnamen vorne" wird bei mir nur bei <u>einem</u> "Smartnamen" verwendet. (bei Esszimmer)
                                    Die anderen bleiben gleich.
                                    Muss ich an andere Stelle noch etwas beachten? (Kann man z.B. Umlaute verwenden?)
                                      @fwshibby
                                      mach foldendes in der console
                                      npm install https://github.com/ioBroker/ioBroker.cloud.git
                                      nicht per admin menü
                                        Vielen Dank für den Hinweis.
                                        Leider kommt folgende Meldung :
                                        Mein cloudadapter ist immer noch gelb.
                                        Mhh weiß jemand Rat ?
                                        • Bluefox
                                          @arteck:
                                          @fwshibby
                                          nicht per admin menü `
                                          Ein bisschen falsch.
                                          cd /opt/iobroker
                                          npm install https://github.com/ioBroker/ioBroker.cloud/tarball/master
                                          iobroker u cloud
                                          iobroker restart cloud
                                            vielen Dank für die schnelle Hilfe.
                                            Leider kommt auch hier eine Meldung:
                                            1.5k
                                            135
                                            26070
