    2. Русский
    3. ioBroker
    4. ioBroker драйвера
    5. Node red
    Node red
    • I
      instalator last edited by
      @Bluefox:
      Ну в принципе именно так:
       var h = context.global.Hot_curr.toString();
       msg.Hot_curr = h.substr(0, h.length - 2);
      Вроде работал код, сегодня решил проверить ругается на toString. Было обновление?
      Добавлено:
      Нодред не подхватывает значения счетчиков воды.
      От электросчетчика подхватывает.
      [{"id":"249fe99a.db6016","type":"debug","name":"","active":true,"console":"false","complete":"true","x":701,"y":802,"z":"2c2981e2.d3d67e","wires":[]},{"id":"4ad0b93e.b52f48","type":"function","name":"Текущие показания Холодной воды","func":"context.global.Cold_curr = msg.payload.val;\nreturn msg;","outputs":1,"valid":true,"x":426,"y":789,"z":"2c2981e2.d3d67e","wires":[["249fe99a.db6016"]]},{"id":"c6b46d56.394b9","type":"function","name":"Текущие показания Горячей воды","func":"context.global.Hot_curr = msg.payload.val;\nreturn msg;","outputs":1,"valid":true,"x":420,"y":846,"z":"2c2981e2.d3d67e","wires":[["249fe99a.db6016"]]},{"id":"4c6b878d.b39478","type":"ioBroker in","name":"myhome/Mother/Electro_counter","topic":"mqtt.0.myhome.Mother.Electro_counter","payloadType":"value","x":134,"y":904,"z":"2c2981e2.d3d67e","wires":[["269c6eea.d96392"]]},{"id":"269c6eea.d96392","type":"function","name":"Текущие показания Электросчетчика","func":"context.global.Electro_curr = msg.payload;\nreturn msg;","outputs":1,"valid":true,"x":436,"y":904,"z":"2c2981e2.d3d67e","wires":[[]]},{"id":"fca376ea.035c88","type":"ioBroker in","name":"myhome/Bathroom/Cold_water","topic":"mqtt.0.myhome.Bathroom.Cold_water","payloadType":"value","x":128.5,"y":789,"z":"2c2981e2.d3d67e","wires":[["4ad0b93e.b52f48"]]},{"id":"3729a205.c8d65e","type":"ioBroker in","name":"myhome/Bathroom/Hot_water","topic":"mqtt.0.myhome.Bathroom.Hot_water","payloadType":"value","x":126,"y":846,"z":"2c2981e2.d3d67e","wires":[["c6b46d56.394b9"]]}]
      Добавлено:
      Чудеса, сегодня все работает ок.
      • I
        Как через Node red создать переменную в iobrokere?
        • I
          Node red вообще заглючил.
          Завис на http reqest.
          Код не подсвечивает.
          Перезапустил в логе ошибки
          ! node-red-0 2015-06-17 10:49:38 warn
          ! node-red-0 2015-06-17 10:49:38 warn 17 Jun 10:49:36 - [warn] –----------------------------------------
          ! node-red-0 2015-06-17 10:49:38 warn 17 Jun 10:49:36 - [warn] [redisout] Error: Cannot find module 'redis'
          ! node-red-0 2015-06-17 10:49:38 warn 17 Jun 10:49:36 - [warn] [tail] Info : Currently not supported on Windows.
          ! node-red-0 2015-06-17 10:49:38 warn 17 Jun 10:49:36 - [warn] [rpi-gpio] Info : Ignoring Raspberry Pi specific node.
          ! node-red-0 2015-06-17 10:49:38 warn 17 Jun 10:49:36 - [warn] [arduino] Error: Cannot find module 'arduino-firmata'
          ! node-red-0 2015-06-17 10:49:36 warn
          ! node-red-0 2015-06-17 10:49:36 warn js-bson: Failed to load c++ bson extension, using pure JS version
          ! node-red-0 2015-06-17 10:49:34 warn
          ! node-red-0 2015-06-17 10:49:34 warn js-bson: Failed to load c++ bson extension, using pure JS version
            bondrogeen last edited by
            @instalator:
            Как через Node red создать переменную в iobrokere? `
            Возник тот же вопрос.
            В корне получается создать (пример test) , а вот чтобы добавить сразу топик нет (пример stat/test)
            И вообще где можно почитать про создание переменных "для чайников" в iobroker?
            • I
              @bondrogeen:
              И вообще где можно почитать про создание переменных "для чайников" в iobroker? А если так - stat.test ? > И вообще где можно почитать про создание переменных "для чайников" в iobroker? `
              В JS например так - createState('Climat.Mode_Pritochka_GuestRoom', '');
                @instalator:
                @bondrogeen:
                В iobrokere как создать переменную вроде-бы научился.
                У меня при работе с ним возникло ложное, как сейчас понял, восприятия древовидной структуры папок и под папок где хранятся переменные.
                Это сейчас я уже вроде-бы понял, что это переменные типа «object» и сделана это для удобства поиска.
                Я правильно понял? если нет поправьте меня.
                Получается нужно создавать переменную test.test.test1, test.test.test2 и т.д.
                тогда получится
                test
                ____test
                ________test1 1
                ________test2 2
                В NODE RED не хочет.
                Не получается, как только делаешь точку в топике, то не создает переменную вообще.
                Просто "test" создает переменную и значение.
                Хотел настроить чтобы NODE RED сам создавал переменные в iobrokere.
                  electric69 last edited by
                  Через консоль не устанавливается node-red. Права chmod 777 для папки /opt/iobroker. Версии nodejs v4.4.4 npm 2.15.1.
                    Однако через WEB-интерфейс драйвер устанавливается, но не работает, в логе видно как циклически падает с предупреждениями.
                    Лог:
                    ! node-red.0 2016-05-10 10:59:57 info node-red.0 node-red exited with 1 node-red.0 2016-05-10 10:59:57 warn node-red.0 at require (internal/module.js:12:17) node-red.0 2016-05-10 10:59:57 warn node-red.0 Error: Cannot find module 'brace-expansion' at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:1 node-red.0 2016-05-10 10:59:57 warn node-red.0 node-red.0 2016-05-10 10:59:57 warn node-red.0 ^ node-red.0 2016-05-10 10:59:57 warn node-red.0 throw err; node-red.0 2016-05-10 10:59:57 warn node-red.0 module.js:327 node-red.0 2016-05-10 10:59:57 info node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js node-red.0 2016-05-10 10:59:52 info node-red.0 node-red exited with 1 node-red.0 2016-05-10 10:59:52 warn node-red.0 at require (internal/module.js:12:17) node-red.0 2016-05-10 10:59:52 warn node-red.0 Error: Cannot find module 'brace-expansion' at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:1 node-red.0 2016-05-10 10:59:52 warn node-red.0 node-red.0 2016-05-10 10:59:52 warn node-red.0 ^ node-red.0 2016-05-10 10:59:52 warn node-red.0 throw err; node-red.0 2016-05-10 10:59:52 warn node-red.0 module.js:327 node-red.0 2016-05-10 10:59:52 info node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js node-red.0 2016-05-10 10:59:47 info node-red.0 node-red exited with 1 node-red.0 2016-05-10 10:59:47 warn node-red.0 at require (internal/module.js:12:17) node-red.0 2016-05-10 10:59:47 warn node-red.0 Error: Cannot find module 'brace-expansion' at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:1 node-red.0 2016-05-10 10:59:47 warn node-red.0 node-red.0 2016-05-10 10:59:47 warn node-red.0 ^ node-red.0 2016-05-10 10:59:47 warn node-red.0 throw err; node-red.0 2016-05-10 10:59:47 warn node-red.0 module.js:327 node-red.0 2016-05-10 10:59:46 info node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js node-red.0 2016-05-10 10:59:41 info node-red.0 node-red exited with 1 node-red.0 2016-05-10 10:59:41 warn node-red.0 at require (internal/module.js:12:17) node-red.0 2016-05-10 10:59:41 warn node-red.0 Error: Cannot find module 'brace-expansion' at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:1 node-red.0 2016-05-10 10:59:41 warn node-red.0 node-red.0 2016-05-10 10:59:41 warn node-red.0 ^ node-red.0 2016-05-10 10:59:41 warn node-red.0 throw err; node-red.0 2016-05-10 10:59:41 warn node-red.0 module.js:327 node-red.0 2016-05-10 10:59:41 info node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js node-red.0 2016-05-10 10:59:36 info node-red.0 node-red exited with 1 node-red.0 2016-05-10 10:59:36 warn node-red.0 at require (internal/module.js:12:17) node-red.0 2016-05-10 10:59:36 warn node-red.0 Error: Cannot find module 'brace-expansion' at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:1 node-red.0 2016-05-10 10:59:36 warn node-red.0 node-red.0 2016-05-10 10:59:36 warn node-red.0 ^ node-red.0 2016-05-10 10:59:36 warn node-red.0 throw err; node-red.0 2016-05-10 10:59:36 warn node-red.0 module.js:327 node-red.0 2016-05-10 10:59:36 info node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js node-red.0 2016-05-10 10:59:31 info node-red.0 node-red exited with 1 node-red.0 2016-05-10 10:59:31 warn node-red.0 at require (internal/module.js:12:17) node-red.0 2016-05-10 10:59:31 warn node-red.0 Error: Cannot find module 'brace-expansion' at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:1 node-red.0 2016-05-10 10:59:31 warn node-red.0 node-red.0 2016-05-10 10:59:31 warn node-red.0 ^ node-red.0 2016-05-10 10:59:31 warn node-red.0 throw err; node-red.0 2016-05-10 10:59:31 warn node-red.0 module.js:327 node-red.0 2016-05-10 10:59:31 info node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js node-red.0 2016-05-10 10:59:26 info node-red.0 node-red exited with 1 node-red.0 2016-05-10 10:59:26 warn node-red.0 at require (internal/module.js:12:17) node-red.0 2016-05-10 10:59:26 warn node-red.0 Error: Cannot find module 'brace-expansion' at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:1 node-red.0 2016-05-10 10:59:26 warn node-red.0 node-red.0 2016-05-10 10:59:26 warn node-red.0 ^ node-red.0 2016-05-10 10:59:26 warn node-red.0 throw err; node-red.0 2016-05-10 10:59:26 warn node-red.0 module.js:327 node-red.0 2016-05-10 10:59:26 info node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js node-red.0 2016-05-10 10:59:21 info node-red.0 node-red exited with 1 node-red.0 2016-05-10 10:59:21 warn node-red.0 at require (internal/module.js:12:17) node-red.0 2016-05-10 10:59:21 warn node-red.0 Error: Cannot find module 'brace-expansion' at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:1 node-red.0 2016-05-10 10:59:21 warn node-red.0 node-red.0 2016-05-10 10:59:21 warn node-red.0 ^ node-red.0 2016-05-10 10:59:21 warn node-red.0 throw err; node-red.0 2016-05-10 10:59:21 warn node-red.0 module.js:327 node-red.0 2016-05-10 10:59:20 info node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js node-red.0 2016-05-10 10:59:15 info node-red.0 node-red exited with 1 node-red.0 2016-05-10 10:59:15 warn node-red.0 at require (internal/module.js:12:17) node-red.0 2016-05-10 10:59:15 warn node-red.0 Error: Cannot find module 'brace-expansion' at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:1 node-red.0 2016-05-10 10:59:15 warn node-red.0 node-red.0 2016-05-10 10:59:15 warn node-red.0 ^ node-red.0 2016-05-10 10:59:15 warn node-red.0 throw err; node-red.0 2016-05-10 10:59:15 warn node-red.0 module.js:327 node-red.0 2016-05-10 10:59:15 info node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js node-red.0 2016-05-10 10:59:10 info node-red.0 node-red exited with 1 node-red.0 2016-05-10 10:59:10 warn node-red.0 at require (internal/module.js:12:17) node-red.0 2016-05-10 10:59:10 warn node-red.0 Error: Cannot find module 'brace-expansion' at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:1 node-red.0 2016-05-10 10:59:10 warn node-red.0 node-red.0 2016-05-10 10:59:10 warn node-red.0 ^ node-red.0 2016-05-10 10:59:10 warn node-red.0 throw err; node-red.0 2016-05-10 10:59:10 warn node-red.0 module.js:327 node-red.0 2016-05-10 10:59:10 info node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js node-red.0 2016-05-10 10:59:05 info node-red.0 node-red exited with 1 node-red.0 2016-05-10 10:59:05 warn node-red.0 ^ Error: Cannot find module 'brace-expansion' at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.j node-red.0 2016-05-10 10:59:05 warn node-red.0 throw err; node-red.0 2016-05-10 10:59:05 warn node-red.0 module.js:327 node-red.0 2016-05-10 10:59:05 info node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js node-red.0 2016-05-10 10:59:00 info node-red.0 node-red exited with 1 node-red.0 2016-05-10 10:59:00 warn node-red.0 at require (internal/module.js:12:17) node-red.0 2016-05-10 10:59:00 warn node-red.0 Error: Cannot find module 'brace-expansion' at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:1 node-red.0 2016-05-10 10:59:00 warn node-red.0 node-red.0 2016-05-10 10:59:00 warn node-red.0 ^ node-red.0 2016-05-10 10:59:00 warn node-red.0 throw err; node-red.0 2016-05-10 10:59:00 warn node-red.0 module.js:327 node-red.0 2016-05-10 10:58:59 info node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js node-red.0 2016-05-10 10:58:54 info node-red.0 node-red exited with 1 node-red.0 2016-05-10 10:58:54 warn node-red.0 at require (internal/module.js:12:17) node-red.0 2016-05-10 10:58:54 warn node-red.0 Error: Cannot find module 'brace-expansion' at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:1 node-red.0 2016-05-10 10:58:54 warn node-red.0 node-red.0 2016-05-10 10:58:54 warn node-red.0 ^ node-red.0 2016-05-10 10:58:54 warn node-red.0 throw err; node-red.0 2016-05-10 10:58:54 warn node-red.0 module.js:327 node-red.0 2016-05-10 10:58:54 info node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js node-red.0 2016-05-10 10:58:49 info node-red.0 node-red exited with 1 node-red.0 2016-05-10 10:58:49 warn node-red.0 at require (internal/module.js:12:17) node-red.0 2016-05-10 10:58:49 warn node-red.0 Error: Cannot find module 'brace-expansion' at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:1 node-red.0 2016-05-10 10:58:49 warn node-red.0 node-red.0 2016-05-10 10:58:49 warn node-red.0 ^ node-red.0 2016-05-10 10:58:49 warn node-red.0 throw err; node-red.0 2016-05-10 10:58:49 warn node-red.0 module.js:327 node-red.0 2016-05-10 10:58:49 info node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js node-red-0 2016-05-10 10:58:44 info node-red exited with 1 node-red-0 2016-05-10 10:58:44 warn at require (internal/module.js:12:17) node-red-0 2016-05-10 10:58:44 warn at Module.require (module.js:353:17) node-red-0 2016-05-10 10:58:44 warn at Function.Module._load (module.js:300:12) node-red-0 2016-05-10 10:58:44 warn at Module.load (module.js:343:32) node-red-0 2016-05-10 10:58:44 warn at Object.Module._extensions..js (module.js:416:10) node-red-0 2016-05-10 10:58:44 warn at Module._compile (module.js:409:26) node-red-0 2016-05-10 10:58:44 warn at Object. (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/fs-extra/node_modules/rimraf/node_modules/glob/node_modules/minimatch/minimatch.js:10:14) node-red-0 2016-05-10 10:58:44 warn at require (internal/module.js:12:17) node-red-0 2016-05-10 10:58:44 warn at Module.require (module.js:353:17) node-red-0 2016-05-10 10:58:44 warn at Function.Module._load (module.js:276:25) node-red-0 2016-05-10 10:58:44 warn at Function.Module._resolveFilename (module.js:325:15) node-red-0 2016-05-10 10:58:44 warn Error: Cannot find module 'brace-expansion' node-red-0 2016-05-10 10:58:44 warn node-red-0 2016-05-10 10:58:44 warn ^ node-red-0 2016-05-10 10:58:44 warn throw err; node-red-0 2016-05-10 10:58:44 warn module.js:327 node-red-0 2016-05-10 10:58:44 info Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js admin-0 2016-05-10 10:58:42 info successful connection to socket.io from ::ffff:109.194.66.17 node-red-0 2016-05-10 10:58:39 info node-red exited with 1 node-red-0 2016-05-10 10:58:39 warn at require (internal/module.js:12:17) node-red-0 2016-05-10 10:58:39 warn at Module.require (module.js:353:17) node-red-0 2016-05-10 10:58:39 warn at Function.Module._load (module.js:300:12) node-red-0 2016-05-10 10:58:39 warn at Module.load (module.js:343:32) node-red-0 2016-05-10 10:58:39 warn at Object.Module._extensions..js (module.js:416:10) node-red-0 2016-05-10 10:58:39 warn at Module._compile (module.js:409:26) node-red-0 2016-05-10 10:58:39 warn at Object. (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/fs-extra/node_modules/rimraf/node_modules/glob/node_modules/minimatch/minimatch.js:10:14) node-red-0 2016-05-10 10:58:39 warn at require (internal/module.js:12:17) node-red-0 2016-05-10 10:58:39 warn at Module.require (module.js:353:17) node-red-0 2016-05-10 10:58:39 warn at Function.Module._load (module.js:276:25) node-red-0 2016-05-10 10:58:39 warn at Function.Module._resolveFilename (module.js:325:15) node-red-0 2016-05-10 10:58:39 warn Error: Cannot find module 'brace-expansion' node-red-0 2016-05-10 10:58:39 warn node-red-0 2016-05-10 10:58:39 warn ^ node-red-0 2016-05-10 10:58:39 warn throw err; node-red-0 2016-05-10 10:58:39 warn module.js:327 node-red-0 2016-05-10 10:58:38 info Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js node-red-0 2016-05-10 10:58:38 info starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.node-red iobroker 2016-05-10 10:58:38 info exit 0 iobroker 2016-05-10 10:58:38 info host.vm32test object system.adapter.node-red.0 created host-vm32test 2016-05-10 10:58:38 info instance system.adapter.node-red.0 started with pid 3965 host-vm32test 2016-05-10 10:58:38 info object change system.adapter.node-red.0 iobroker 2016-05-10 10:58:38 info host.vm32test object system.adapter.node-red.0.alive created iobroker 2016-05-10 10:58:38 info host.vm32test object system.adapter.node-red.0.connected created iobroker 2016-05-10 10:58:38 info host.vm32test object system.adapter.node-red.0.memHeapUsed created iobroker 2016-05-10 10:58:38 info host.vm32test object system.adapter.node-red.0.memHeapTotal created iobroker 2016-05-10 10:58:38 info host.vm32test object system.adapter.node-red.0.memRss created iobroker 2016-05-10 10:58:38 info host.vm32test object system.adapter.node-red.0.uptime created iobroker 2016-05-10 10:58:38 info host.vm32test object node-red.0 created iobroker 2016-05-10 10:58:38 info host.vm32test create instance node-red iobroker 2016-05-10 10:58:38 info host.vm32test object system.adapter.node-red created iobroker 2016-05-10 10:58:38 info upload [0] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/index.html index.html text/html iobroker 2016-05-10 10:58:38 info upload [1] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/node-red.png node-red.png image/png iobroker 2016-05-10 10:58:38 info got /opt/iobroker/node_modules/iobroker.node-red/admin iobroker 2016-05-10 10:58:38 info host.vm32test install adapter node-red iobroker 2016-05-10 10:58:37 info add node-red !
                    • V
                      VictorS last edited by
                      Добрый вечер,
                      столкнулся с загадочной проблемой. nodered падает если добавить вот такую ноду:
                      "id": "b63c97fe.3efc08",
                      "type": "mqtt in",
                      "z": "c608cffb.e48a7",
                      "name": "Ver1 Light",
                      "topic": "/sh-esp-ver1/output14",
                      "qos": "2",
                      "broker": "15a9d586.42d9ba",
                      "x": 130,
                      "y": 248,
                      "wires": [
                      "id": "15a9d586.42d9ba",
                      "type": "mqtt-broker",
                      "z": "",
                      "broker": "localhost",
                      "port": "1883",
                      "clientid": "nodered.0",
                      "usetls": false,
                      "compatmode": true,
                      "keepalive": "60",
                      "cleansession": true,
                      "willTopic": "",
                      "willQos": "0",
                      "willPayload": "",
                      "birthTopic": "",
                      "birthQos": "0",
                      "birthPayload": ""
                      т.е. input от mqtt завязанную на gpio от esp. при изменения состояния с "0" -> "1" или "1" -> "0" nodered отваливается от mqtt в логе:
                      warn Client error [nodered.0]: Error: Invalid message id
                      потом соединение восстанавливается, значение из mqtt в ноду получено.
                      где я что сделал не так?
                      • I
                        @VictorS:
                        Добрый вечер,
                        "type": "mqtt in",
                        "qos": "2",
                        "x": 130,
                        "y": 248,
                        "wires": [
                        "z": "",
                        "port": "1883",
                        "usetls": false,
                        "compatmode": true,
                        "keepalive": "60",
                        "willTopic": "",
                        "willQos": "0",
                        "willPayload": "",
                        "birthTopic": "",
                        "birthQos": "0",
                        "birthPayload": ""
                        где я что сделал не так? `
                        Попробуй использовать не mqtt, а объект из иоб
                        • V
                          @instalator:
                          Попробуй использовать не mqtt, а объект из иоб `
                          Спасибо, помогло 🙂
                          Еще вопросы:
                          1. В настройках nodered есть "Convert ioBroker values to string" - какой в этом смысл? Удобнее наверное принимать значения в том виде в котором они в IOB?
                          2. По настройкам выходов с IOB с nodered. Type ("command", "value"). А в чем разница?
                          • Bluefox
                            Bluefox last edited by
                            @VictorS:
                            @instalator:
                            Спасибо, помогло 🙂
                            Еще вопросы:
                            2. По настройкам выходов с IOB с nodered. Type ("command", "value"). А в чем разница? `
                            Первую настройку я что то не могу найти. :lol:
                            А вот вторую я попытался объяснить тут: https://github.com/ioBroker/ioBroker/wi … d-statuses
                            • V
                              @Bluefox:
                              @VictorS:
                              Еще вопросы:
                              А вот вторую я попытался объяснить тут: https://github.com/ioBroker/ioBroker/wi … d-statuses `
                              первая - это настройки адаптера nodered, вот тут;
                              • Bluefox
                                @VictorS:
                                @Bluefox:
                                @VictorS:
                                Еще вопросы:
                                ! nodered-settings.jpg `
                                Ну node-red раньше обрабатывал все значения, как строки. Сейчас вроде бы можно любые использовать настройка больше не актуальна.
                                  maxmen last edited by
                                  Сначала поставил Nodered, настроил что мне было нужно, потом ставил iobroker.
                                  Потом из iobroker поставил драйвер nodered в надежде что при установке просто в nodered Добавятся модули iobroker.
                                  Драйвер после установки не запускается, т.к. на порту 1880 уже висит nodered изначально установленный.
                                  Модули IObroker в Nodered естественно, не появились.
                                  Сейчас 3 варианта:
                                  1. менять порты (смысла нет держать пару запущенных nodered)
                                  2. сносить тот что был изначально и ставить драйвер
                                  3. как-то пытаться добавить модуль iobroker в стандартную установку Nodered.
                                  Отличаются ли версии nodered в драйвере iobroker и если ставить Nodered обычным способом?
                                  Если отличаются, то насколько быстро обновления nodered появляются в драйвере?
                                  Существует ли отдельно устанавливаемый модуль Npm iobroker для nodered?
                                  • I
                                    @maxmen:
                                    Сейчас 3 варианта:
                                    Существует ли отдельно устанавливаемый модуль Npm iobroker для nodered? `
                                    снеси сторонний нодред, а лучше использовать javasript
                                      @instalator:
                                      снеси сторонний нодред, а лучше использовать javasript `
                                      Javascript круто, но nodered для меня нагляднее и понятнее.
                                      Вот в том-то и вопрос - кто из этих nodered сторонний и насколько быстро доходят обновления с оригинального до стороннего.
                                      • I
                                        @maxmen:
                                        @instalator:
                                        Вот в том-то и вопрос - кто из этих nodered сторонний и насколько быстро доходят обновления с оригинального до стороннего. ` что за обновления? у тебя два независимых нодрнда сейчас работают они никак не пересекаются кроме используемых портов. в итоге потом все равно придётся все переписывать на javascript
                                          Если просто ставить Nodered, то ставится версия 0.17.5, если ставить драйвер nodered для iobroker - ставится версия 0.16.2
                                          В драйвере ставится дополнительно несколько полезных модулей кроме iobroker, которых я не нашел в стандартных доступных для установки NPMов. Можно ли их поставить отдельно или когда планируется обновление драйвера?
                                          node-red-dashboard и node-red-contrib-os в npm нашлись. Не нашел только iobroker модлуь.
                                          • I
                                            @maxmen:
                                            node-red-dashboard и node-red-contrib-os в npm нашлись. Не нашел только iobroker модлуь. ` драйвер на то и драйвер что работает только из иоброкера
                                            19467
