    4. Einmal Hilfe bitte bei nem mini script
    • Marko1974
      Marko1974 @paul53 last edited by
      @paul53 wo finde ich denn setze CMD auf?
        Jan1 @Marko1974 last edited by
        @marko1974
        Das ist ne Variable und die erstellst Du selber 😉
        Marko1974 1 Reply Last reply Reply Quote 0
        • Marko1974
          Marko1974 @Jan1 last edited by
          @jan1 funktioniert irgendwie nicht
          cul.0	2021-06-05 16:40:14.911	debug	(11975) system.adapter.admin.0: logging true
          cul.0	2021-06-05 16:40:08.853	debug	(11975) ->
          cul.0	2021-06-05 16:40:08.853	info	(11975) Send RAW command received. FF000F000FFF
          cul.0	2021-06-05 16:40:00.707	debug	(11975) ->
          cul.0	2021-06-05 16:40:00.706	info	(11975) Send RAW command received. FF000F000FF0
          cul.0	2021-06-05 16:40:00.171	debug	(11975) system.adapter.admin.0: logging false
          cul.0	2021-06-05 16:39:35.073	debug	(11975) ->
          cul.0	2021-06-05 16:39:33.211	info	(11975) starting. Version 1.3.5 in /opt/iobroker/node_modules/iobroker.cul, node: v12.22.1, js-controller: 3.2.16
          cul.0	2021-06-05 16:39:32.936	debug	(11975) Plugin sentry Initialize Plugin (enabled=true)
          cul.0	2021-06-05 16:39:32.693	debug	(11975) statesDB connected
          cul.0	2021-06-05 16:39:32.692	debug	(11975) States connected to redis: 127.0.0.1:9000
          cul.0	2021-06-05 16:39:32.682	debug	(11975) States create User PubSub Client
          cul.0	2021-06-05 16:39:32.680	debug	(11975) States create System PubSub Client
          cul.0	2021-06-05 16:39:32.671	debug	(11975) Redis States: Use Redis connection: 127.0.0.1:9000
          cul.0	2021-06-05 16:39:32.668	debug	(11975) objectDB connected
          cul.0	2021-06-05 16:39:32.658	debug	(11975) Objects connected to redis: 127.0.0.1:9003
          cul.0	2021-06-05 16:39:32.641	debug	(11975) Objects client initialize lua scripts
          cul.0	2021-06-05 16:39:32.640	debug	(11975) Objects create User PubSub Client
          cul.0	2021-06-05 16:39:32.638	debug	(11975) Objects create System PubSub Client
          cul.0	2021-06-05 16:39:32.628	debug	(11975) Objects client ready ... initialize now
          cul.0	2021-06-05 16:39:32.583	debug	(11975) Redis Objects: Use Redis connection: 127.0.0.1:9003
          • Marko1974
            Marko1974 @Marko1974 last edited by
            @marko1974 juchuuuuuuu @Jan1 @paul53 es geht....wenn ich jetzt oben das device per hand in true ändere geht er an.
            Jetzt ist noch die Frage....wie bekomme ich ein Alexa Gläserschrank an und aus hin....die kennt den ja gar nicht, den Herrn Gläserschrank
              @marko1974
              Dann mach den mit Ihr bekannt, entweder über den IoT oder den Node-Red Adapter 😉
              • Marko1974
                @jan1 och neee....dann hätte ich die Sachen ja auch im openhab lassen könnren. dachte es gäbe eine möglichkeit die an alexa zu koppeln. ioT kostet Geld....und node-red.....hmmm mag ich nicht.
                Gibts nichts anderes? Der grund für den weggang von openhab war eigentlich dass zu vieles aufeinander zugreift
                J Homoran 2 Replies Last reply Reply Quote 0
                  Jan1 @Marko1974 last edited by Jan1
                  @marko1974
                  Node-Red ist kostenlos und für solch einfach Anbindung recht easy. Alternativ kannst den Gläserscharank auch an eine Steckdose mit Tasmota hängen, da Tasmota von sich aus mit Alex kann 😉
                  • Marko1974
                    @jan1 ich bräuchte dann 11 Steckdosen....das wäre etwas drüber....
                    Krieg ich das schnell hin? also einfach node-red adapter installieren und .....
                      @marko1974
                      na wie sind denn die 11 Gläser-schränke denn derzeit im IOBroker drin?
                      • Marko1974
                        @jan1 so wie wir es gerade gemacht haben. 433mhz cul stick und 433mhz steckdosen
                          Homoran Global Moderator Administrators @Marko1974 last edited by
                          @marko1974 sagte in Einmal Hilfe bitte bei nem mini script:
                          ioT kostet Geld
                          muss immer alles kostenlos sein?
                          ich weiß nicht was im Moment die Jahreslizenz für iot kostet, aber teuer ist etwas anderes
                          • Marko1974
                            Marko1974 @Homoran last edited by
                            @homoran Ja im Prinzip ist das ja auch eine sehr gute Lösung....ich hab das halt bei meinen Eltern ....ich würde das investieren, jedoch haben die nun schon so viel in irgendwelche Komponenten investiert.
                            Ist wahrhaftig kein Geiz
                              @marko1974
                              ach Du Kacke, das sind Funk Dinger. Da halte ich nicht viel von, weil kein Rückkanal und deshalb nicht wirklich was man haben möchte.
                              Die willst wirklich alle 11 einzeln schalten können, oder eher in Gruppen?
                              Mit der Sonoff Bridge müsste das funktionieren, die kann 16 Geräte, wobei wohl nur 8, da an und aus schon zwei verschiedene Codes sein könnten.
                              • Marko1974
                                @jan1 alle 11 einzeln....und vorher hatte ich den stick halt bei openhab drin und habe dann jetzt openhab hier eingebunden.
                                Ich finde openhab aber zu wartungsintensiv....wenn da irgendwas nicht funktioniert ist direkt vorbei mit ner homekit anbindung und meistens wurschtel ich dann tage rum. Da hätte ich es auch drinlassen können, denn ne Steuerung der Dosen war darüber auch in ioB gegeben.
                                Ich will halt alles nun in einem system haben.
                                  @marko1974
                                  Oh, dann ist der IObroker aber nix für Dich, oder Du hast den vollkommen falsch verstanden 😉
                                  IOBroker ist kein System in dem Sinne, sondern lässt herstellerübergreifend verschiedene Systeme miteinander arbeiten. Heißt Du hast dann immer noch viele einzelne Systeme, die dann zentral über den IOBroker steuerbar sind.
                                  Egal, Funk mit 344MHz ist halt nichts was man haben möchte und ich habe deshalb sogar meine Funk Rollladenmotoren gegen "normale" ausgetauscht, weil einfach einfacher.
                                  • Marko1974
                                    @jan1 ja...ich hab auch noch homebridge laufen und das in ein paar instanzen....aber vieles läßt sich ja hier einbinden.
                                    dann mache ich openhab neu und lasse da alexa und schalter laufen....da weiss ich wenigstens wie das geht
                                      @marko1974
                                      Es gibt hier viele Möglichkeiten das zu lösen und vielleicht fällt ja einem was dazu ein, dass ich nicht auf dem Schirm habe. Mach doch einfach mal ein Thread auf und frage direkt danach. Funk ist eben nicht wirklich zuverlässig und nicht meine erste Wahl.
                                      • Marko1974
                                        @jan1 Es funktioniert ja...dank eurer hilfe...brauche nun nur die Anbindung an alexa
                                          @marko1974
                                          Ja wir sind etwas vom Thema abgekommen, aber schau Dir mal den Node-Red an. Dort muss über die Pallette die Amazon Nodes nachinstallieren und dann kannst recht easy die gewünschten DPs steuern. Da hilft die dann @mickym weiter, der hat zwar nix mit Alexa am Hut, ist aber Node-Red kompatibel 😉
                                          • Marko1974
                                            @jan1 ich hatte gaaaaanz früher mal was mit node red gemacht....ich hatte gerade geschaut, jedoch hab ich es nichtmals hinbekommen, das olle alexa ding zu installieren
                                            2430
