      Einstein2002 @s.bormann last edited by
      @s-bormann
      toolbarContextMenu end via TOUCHEND/MOUSEUP index.js:3964:11
      toolbarContextMenu end function index.js:4014:10
      viewDeviceContextMenu end via TOUCHEND/MOUSEUP index.js:7183:11
      viewDeviceContextMenu end function index.js:7235:10
      >>>>>> setState hm-rpc.2.INT0000002.1.SET_POINT_MODE: 0 --> 0 index.js:2143:11
      [Socket] setState hm-rpc.2.INT0000002.1.SET_POINT_MODE index.js:1523:10
      viewTimestampElapsedTimer for 0 states index.js:6710:12
      toolbarContextMenu end function - find active Toolbar Index index.js:4019:11
      >> ack: false val: 0 newVal: 0 index.js:2361:11
      deliverState done index.js:1526:11
      toolbarContextMenu end function - end ignoreStart index.js:4033:11
      viewDeviceContextMenu end function - end ignoreStart 3 index.js:7240:11
      >> ack: true val: 0 newVal: 0 index.js:2361:11
      << ack-val reached new val: preventUpdate regular ended. index.js:2364:11
      "Auto": {"en": "Auto", "de": "Auto", "ru": "Auto", "pt": "Auto", "nl": "Auto", "fr": "Auto"}, 2 translate.js:24:17
      >>>>>> setState hm-rpc.2.INT0000002.1.BOOST_MODE: true --> true index.js:2143:11
      [Socket] setState hm-rpc.2.INT0000002.1.BOOST_MODE --> val: true index.js:1523:10
      >> ack: false val: true newVal: true index.js:2361:11
      Add timestamp to Partykeller with value Aus index.js:6931:10
      !stateFillsDevice or badge is invisible - remove padding-top index.js:7129:11
      "W": {"en": "W", "de": "W", "ru": "W", "pt": "W", "nl": "W", "fr": "W"}, translate.js:24:17
      "A": {"en": "A", "de": "A", "ru": "A", "pt": "A", "nl": "A", "fr": "A"}, translate.js:24:17
      "Auto": {"en": "Auto", "de": "Auto", "ru": "Auto", "pt": "Auto", "nl": "Auto", "fr": "Auto"}, translate.js:24:17
      >> ack: true val: true newVal: true index.js:2361:11
      >>>>>> setState hm-rpc.2.INT0000002.1.SET_POINT_MODE: 0 --> 1 index.js:2143:11
      [Socket] setState hm-rpc.2.INT0000002.1.SET_POINT_MODE --> val: 1 index.js:1523:10
      >> ack: false val: 1 newVal: 1 index.js:2361:11
      >> ack: true val: 0 newVal: 1 2 index.js:2361:11
      << preventUpdate dexpired. index.js:2239:13
      • dslraser
        dslraser Forum Testing Most Active @s.bormann last edited by
        @s-bormann
        ich bin ab jetzt nur mal zwischendurch anwesend...Ich muß jetzt was anderes machen, leider.
          Einstein2002 @dslraser last edited by
          @dslraser Bin zwar keine große Hilfe aber ich bleib da. Brauche nur eine geführte Anleitung.
          Und wenn Sebastian möchte gerne auch per Teamviewer.
          • s.bormann
            s.bormann Most Active @Einstein2002 last edited by
            @einstein2002 sagte in Test Adapter iQontrol 1.8.x Vis:
            Melde mich gleich wieder
              @s-bormann Alles gut... 🙂
              • dirk1962
                dirk1962 @dslraser last edited by dirk1962
                @dslraser
                "Dann vielleicht erstmal einen alias machen bis EQ3 das gefixt hat."
                Auf den Vorschlag des Experten habe ich gewartet 😀 😀 .
                Wenn Du das gemacht hast wäre es super, wenn Du das erklären würdest.
                  Alle noch da? Schon was passiert?
                  • s.bormann
                    @einstein2002 Hallo, habe jetzt noch mal beides überarbeitet (autocreate und die Kachel). Bitte noch einmal testen. Wenn das nicht geht, können wir es ja tatsächlich mal über Teamviewer versuchen.
                    E 5 Replies Last reply Reply Quote 0
                      @s-bormann Mach ich
                        Einstein2002 @s.bormann last edited by Einstein2002
                        @s-bormann Sorry hat nicht das gewünschte Ergebnis gebracht. In den Optionen ändert es sich kurzzeitig aber springt dann wieder zurück.
                        Bleibt dann immer auf Automatik, egal ob Manu oder Boost gedrückt wurde.
                          @s-bormann Moment....
                          wenn ich Automatic drücke dann springt er auf Manuell, wenn ich Manuell drücke auf Automatic
                            @s-bormann Boost Mode geht auf True, Time kurz auf 300 dann wieder auf 0
                              @s-bormann Im Thermostat steht OFF Manu im Display
                              • s.bormann
                                Ich schreib Dich mal per Chat an, dann können wir uns per TeamViewer verabreden. Ich muss das mal sehen, vielleicht erkenne ich dann meine Fehler.
                                  @s-bormann Perfekt
                                  • dslraser
                                    dslraser Forum Testing Most Active @dirk1962 last edited by dslraser
                                    @dirk1962 sagte in Test Adapter iQontrol 1.8.x Vis:
                                    @dslraser
                                    Ich habe zum testen nur kurz Boost eingeschaltet.
                                    EDIT: die Boost Restlaufzeit könnte man ja auch per Blockly/Script in einem eigenen Datenpunkt runter laufen lassen, da der original Datenpunkt ja nicht ständig aktualisiert wird (wegen dem polling)
                                    dirk1962 1 Reply Last reply Reply Quote 1
                                    • dirk1962
                                      @dslraser
                                      Funktioniert perfekt, vielen Dank.
                                      Ich habe im Schlafzimmer zwei Heizkörper, deshalb auch zwei Ventilöffnungen.
                                      Die beiden Heizkörper sind zur Gruppe zusammengefasst.
                                      Was ich noch nicht hinbekomme ist, dass ich die Boost-Funktion wie Du an/aus schalten kann.
                                      Habe es unter Additional Controls, weiß aber nicht, was ich noch einstellen muss.
                                      Edit: alle Heizkörperventile stehen auf ON, deshalb 100% geöffnet.
                                      • dslraser
                                        @dirk1962
                                        • dslraser
                                          @dirk1962
                                          Boost Restlaufzeit---eigener Datenpunkt. Kannst ja mal probieren. iQontrol Boost Restlaufzeit auf den eigenen Datenpunkt verlinken. Die Restlaufzeit zählt im Sekundentakt runter.
                                           <variables>
                                             <variable id="=yzQW{xe](*q)[.G4RO(">Boost_Zeit</variable>
                                             <variable type="interval" id="Intervall">Intervall</variable>
                                           </variables>
                                           <block type="create" id="HHlmtV`-A_7.m9zR85D$" x="-263" y="13">
                                             <field name="NAME">0_userdata.0.Heizungen.Wohnzimmer_Boost_Restlaufzeit</field>
                                               <block type="math_number" id="}#?sOH5I|R{/z+j~@guP">
                                                 <field name="NUM">0</field>
                                             <value name="COMMON">
                                               <block type="text" id="s,QEs/JoRn:|wD~*,1/-">
                                                 <field name="TEXT">{ "role" : "number" , "type" : "number" , "min": 0 , "max": 300 , "name" : "Wohnzimmer_Boost_Restlaufzeit" }</field>
                                               <block type="variables_set" id="`j.%R9KyW}54;1d3AST9">
                                                 <field name="VAR" id="=yzQW{xe](*q)[.G4RO(">Boost_Zeit</field>
                                                   <block type="math_number" id="H[XRzP+,jlePabqg,^.2">
                                                     <field name="NUM">300</field>
                                                   <block type="on_ext" id="t+ye_(`.~#-QgBEBQy:)">
                                                     <value name="OID0">
                                                       <shadow type="field_oid" id="Ls;!NT[E]n%1.S?d()el">
                                                         <field name="oid">hm-rpc.2.INT0000008.1.BOOST_MODE</field>
                                                       <block type="controls_if" id="/jnA1P-V^!NGNw9wT!W6">
                                                           <block type="on_source" id="uYkiY6~nOZaR!N6#kr/4">
                                                           <block type="timeouts_setinterval" id=";g-vwXu*fxnIQDP,?Fxo">
                                                             <field name="NAME">Intervall</field>
                                                             <field name="INTERVAL">1000</field>
                                                             <field name="UNIT">ms</field>
                                                               <block type="math_change" id="_jvI1n#z(%|+xb#0@~|#">
        <value name="DELTA">
        <shadow type="math_number" id="#Z/o*-RGnE^a*8nt.^c6">
        <field name="NUM">1</field>
        <block type="math_number" id="~:$7cg{rAHv)4.)r690.">
        <field name="NUM">-1</field>
        <block type="control_ex" id="=rMO5FVMV?b/_XS5kFg6">
        <field name="TYPE">true</field>
        <value name="OID">
        <shadow type="field_oid" id="SKL}a1FVhzk@,oP}(6!-">
        <field name="oid">0_userdata.0.Heizungen.Wohnzimmer_Boost_Restlaufzeit</field>
        <shadow type="logic_boolean" id="@|F?+NhxL$V*]ca-9E*P">
        <block type="variables_get" id="H6M#DI4DV!qp#15zW`a8">
        <value name="DELAY_MS">
        <shadow type="math_number" id="@{RP7TE^(gh?baCSZXnw">
                                                         <statement name="ELSE">
                                                           <block type="timeouts_clearinterval" id="D,*Qa(,Ii/sUC:X@64au">
                                                               <block type="variables_set" id="8yv})T/z2vwHVz[ZX{+Q">
        <block type="math_number" id="6IuBKArg@oQ:ItlHYu3o">
        <block type="control_ex" id="(jJX`QK=vd%1#AWC5D$f">
        <value name="OID">
        <shadow type="field_oid" id=":Pqf]rOtun/K3t^!YRSD">
        <shadow type="logic_boolean" id="3QcamcLkHl-|Nb4~s7S0">
        <block type="math_number" id="%w-|9rM}a/IF$eSdDfNs">
        <shadow type="math_number" id="J*r/h74]MyX#W:;b)]65">
                                          EDIT: Blockly geändert....
                                          s.bormann dirk1962 2 Replies Last reply Reply Quote 0
                                          • s.bormann
                                            @dslraser zusammen mit @Einstein2002 haben wir die Github-Version für HmIP aktualisiert. Ich muss jetzt weg, deswegen haben wir die Autocreate-Funktion noch nicht testen können, aber für manuell angelegte Thermostate geht jetzt alles, bis auf den PARTY-Mode - ohne, dass man noch irgendwas ändern müsste an den Datenpunkten.
                                            Zum Party-Mode: Das scheint irgendwie - laut Forum - auch nicht zu gehen, dass man das von ioBroker aus einstellt. Die HmIP-Implementation scheint mir irgendwie ziemlich buggy zu sein (fehlende Einheiten, fehlende Value-Lists, ...) - ein ziemlicher Rückschritt verglichen mit dem alten Homematic... Falls aber jemand hier mehr weiß, gerne her mit den Infos!
                                            dslraser E 5 Replies Last reply Reply Quote 1
                                            296
                                            7637
                                            6951034
