    4. Asterisk bringt "Error while dialing (2). Error: {}"
      Thomas Braun Most Active @andiber last edited by
      @andiber
      Was stand jetzt als Rückmeldung im Terminal?
        andiber @Thomas Braun last edited by
        @thomas-braun Gar nichts, beide Befehle sind ohne Fehlermeldung durchgelaufen, es endete jeweils mit der normalen Eigabeaufforderung.
          @andiber
          Dann mal ein
          sudo apt install --reinstall asterisk
          • V
            varg @Thomas Braun last edited by varg
            Installation anhand dieser Anleitung Git
            Befehle ergeben:
            pi@pio4gb:/ $ sudo dpkg-reconfigure --priority=low asterisk-voicemail
            /usr/sbin/dpkg-reconfigure: asterisk-voicemail is broken or not fully installed
            /usr/sbin/dpkg-reconfigure: asterisk is broken or not fully installed
            pi@pio4gb:/ $ ^C
            Installation sieht immer noch so aus:
            i@pio4gb:/ $ sudo apt install asterisk
            Reading package lists... Done
            Building dependency tree
            The following additional packages will be installed:
              asterisk-config asterisk-core-sounds-en asterisk-core-sounds-en-gsm
              asterisk-modules asterisk-moh-opsound-gsm asterisk-voicemail freetds-common
              libgmime-3.0-0 libgpgme11 libical3 libiksemel3 libjansson4 liblua5.1-0
              libmariadb3 libneon27-gnutls libodbc1 libpq5 libradcli4 libresample1
              libsnmp-base libsnmp30 libspandsp2 libspeexdsp1 libsrtp2-1 libsybdb5
              libunbound8 liburiparser1 libxslt1.1 mariadb-common mysql-common
            Suggested packages:
              asterisk-dahdi asterisk-dev asterisk-doc asterisk-ooh323 asterisk-opus
              asterisk-vpb libmyodbc odbc-postgresql tdsodbc unixodbc-bin
              snmp-mibs-downloader
            The following NEW packages will be installed:
              asterisk asterisk-config asterisk-core-sounds-en asterisk-core-sounds-en-gsm
            0 upgraded, 31 newly installed, 0 to remove and 0 not upgraded.
            Need to get 0 B/18.6 MB of archives.
            After this operation, 39.2 MB of additional disk space will be used.
            Do you want to continue? [Y/n] Y
            Extracting templates from packages: 100%
            Selecting previously unselected package asterisk-config.
            (Reading database ... 50667 files and directories currently installed.)
            Preparing to unpack .../00-asterisk-config_1%3a16.2.1~dfsg-1+deb10u2_all.deb ...
            Unpacking asterisk-config (1:16.2.1~dfsg-1+deb10u2) ...
            Selecting previously unselected package asterisk-core-sounds-en-gsm.
            Preparing to unpack .../01-asterisk-core-sounds-en-gsm_1.6.1-1_all.deb ...
            Unpacking asterisk-core-sounds-en-gsm (1.6.1-1) ...
            Selecting previously unselected package asterisk-core-sounds-en.
            Preparing to unpack .../02-asterisk-core-sounds-en_1.6.1-1_all.deb ...
            Unpacking asterisk-core-sounds-en (1.6.1-1) ...
            Selecting previously unselected package libgpgme11:armhf.
            Preparing to unpack .../03-libgpgme11_1.12.0-6_armhf.deb ...
            Unpacking libgpgme11:armhf (1.12.0-6) ...
            Selecting previously unselected package libgmime-3.0-0:armhf.
            Preparing to unpack .../04-libgmime-3.0-0_3.2.1-1_armhf.deb ...
            Unpacking libgmime-3.0-0:armhf (3.2.1-1) ...
            Selecting previously unselected package libical3:armhf.
            Preparing to unpack .../05-libical3_3.0.4-3_armhf.deb ...
            Unpacking libical3:armhf (3.0.4-3) ...
            Selecting previously unselected package libiksemel3:armhf.
            Preparing to unpack .../06-libiksemel3_1.4-3+b1_armhf.deb ...
            Unpacking libiksemel3:armhf (1.4-3+b1) ...
            Selecting previously unselected package liblua5.1-0:armhf.
            Preparing to unpack .../07-liblua5.1-0_5.1.5-8.1+b1_armhf.deb ...
            Unpacking liblua5.1-0:armhf (5.1.5-8.1+b1) ...
            Selecting previously unselected package libneon27-gnutls:armhf.
            Preparing to unpack .../08-libneon27-gnutls_0.30.2-3_armhf.deb ...
            Unpacking libneon27-gnutls:armhf (0.30.2-3) ...
            Selecting previously unselected package libodbc1:armhf.
            Preparing to unpack .../09-libodbc1_2.3.6-0.1_armhf.deb ...
            Unpacking libodbc1:armhf (2.3.6-0.1) ...
            Selecting previously unselected package libpq5:armhf.
            Preparing to unpack .../10-libpq5_11.12-0+deb10u1_armhf.deb ...
            Unpacking libpq5:armhf (11.12-0+deb10u1) ...
            Selecting previously unselected package libradcli4.
            Preparing to unpack .../11-libradcli4_1.2.6-4_armhf.deb ...
            Unpacking libradcli4 (1.2.6-4) ...
            Selecting previously unselected package libresample1.
            Preparing to unpack .../12-libresample1_0.1.3-4_armhf.deb ...
            Unpacking libresample1 (0.1.3-4) ...
            Selecting previously unselected package mysql-common.
            Preparing to unpack .../13-mysql-common_5.8+1.0.5_all.deb ...
            Unpacking mysql-common (5.8+1.0.5) ...
            Selecting previously unselected package mariadb-common.
            Preparing to unpack .../14-mariadb-common_1%3a10.3.27-0+deb10u1_all.deb ...
            Unpacking mariadb-common (1:10.3.27-0+deb10u1) ...
            Selecting previously unselected package libmariadb3:armhf.
            Preparing to unpack .../15-libmariadb3_1%3a10.3.27-0+deb10u1_armhf.deb ...
            Unpacking libmariadb3:armhf (1:10.3.27-0+deb10u1) ...
            Selecting previously unselected package libsnmp-base.
            Preparing to unpack .../16-libsnmp-base_5.7.3+dfsg-5+deb10u2_all.deb ...
            Unpacking libsnmp-base (5.7.3+dfsg-5+deb10u2) ...
            Selecting previously unselected package libsnmp30:armhf.
            Preparing to unpack .../17-libsnmp30_5.7.3+dfsg-5+deb10u2_armhf.deb ...
            Unpacking libsnmp30:armhf (5.7.3+dfsg-5+deb10u2) ...
            Selecting previously unselected package libspandsp2:armhf.
            Preparing to unpack .../18-libspandsp2_0.0.6+dfsg-2_armhf.deb ...
            Unpacking libspandsp2:armhf (0.0.6+dfsg-2) ...
            Selecting previously unselected package libspeexdsp1:armhf.
            Preparing to unpack .../19-libspeexdsp1_1.2~rc1.2-1+b2_armhf.deb ...
            Unpacking libspeexdsp1:armhf (1.2~rc1.2-1+b2) ...
            Selecting previously unselected package libsrtp2-1:armhf.
            Preparing to unpack .../20-libsrtp2-1_2.2.0-1_armhf.deb ...
            Unpacking libsrtp2-1:armhf (2.2.0-1) ...
            Selecting previously unselected package freetds-common.
            Preparing to unpack .../21-freetds-common_1.00.104-1+deb10u1_all.deb ...
            Unpacking freetds-common (1.00.104-1+deb10u1) ...
            Selecting previously unselected package libsybdb5:armhf.
            Preparing to unpack .../22-libsybdb5_1.00.104-1+deb10u1_armhf.deb ...
            Unpacking libsybdb5:armhf (1.00.104-1+deb10u1) ...
            Selecting previously unselected package libunbound8:armhf.
            Preparing to unpack .../23-libunbound8_1.9.0-2+deb10u2_armhf.deb ...
            Unpacking libunbound8:armhf (1.9.0-2+deb10u2) ...
            Selecting previously unselected package asterisk-modules.
            Preparing to unpack .../24-asterisk-modules_1%3a16.2.1~dfsg-1+deb10u2_armhf.deb ...
            Unpacking asterisk-modules (1:16.2.1~dfsg-1+deb10u2) ...
            Selecting previously unselected package libjansson4:armhf.
            Preparing to unpack .../25-libjansson4_2.12-1_armhf.deb ...
            Unpacking libjansson4:armhf (2.12-1) ...
            Selecting previously unselected package liburiparser1:armhf.
            Preparing to unpack .../26-liburiparser1_0.9.1-1_armhf.deb ...
            Unpacking liburiparser1:armhf (0.9.1-1) ...
            Selecting previously unselected package libxslt1.1:armhf.
            Preparing to unpack .../27-libxslt1.1_1.1.32-2.2~deb10u1_armhf.deb ...
            Unpacking libxslt1.1:armhf (1.1.32-2.2~deb10u1) ...
            Selecting previously unselected package asterisk.
            Preparing to unpack .../28-asterisk_1%3a16.2.1~dfsg-1+deb10u2_armhf.deb ...
            Unpacking asterisk (1:16.2.1~dfsg-1+deb10u2) ...
            Selecting previously unselected package asterisk-voicemail.
            Preparing to unpack .../29-asterisk-voicemail_1%3a16.2.1~dfsg-1+deb10u2_armhf.deb ...
            Unpacking asterisk-voicemail (1:16.2.1~dfsg-1+deb10u2) ...
            Selecting previously unselected package asterisk-moh-opsound-gsm.
            Preparing to unpack .../30-asterisk-moh-opsound-gsm_2.03-1_all.deb ...
            Unpacking asterisk-moh-opsound-gsm (2.03-1) ...
            Setting up mysql-common (5.8+1.0.5) ...
            update-alternatives: using /etc/mysql/my.cnf.fallback to provide /etc/mysql/my.cnf (my.cnf) in auto mode
            Setting up asterisk-core-sounds-en-gsm (1.6.1-1) ...
            Setting up libsnmp-base (5.7.3+dfsg-5+deb10u2) ...
            Setting up libsrtp2-1:armhf (2.2.0-1) ...
            Setting up libpq5:armhf (11.12-0+deb10u1) ...
            Setting up libgpgme11:armhf (1.12.0-6) ...
            Setting up libspandsp2:armhf (0.0.6+dfsg-2) ...
            Setting up libjansson4:armhf (2.12-1) ...
            Setting up mariadb-common (1:10.3.27-0+deb10u1) ...
            update-alternatives: using /etc/mysql/mariadb.cnf to provide /etc/mysql/my.cnf (my.cnf) in auto mode
            Setting up libunbound8:armhf (1.9.0-2+deb10u2) ...
            Setting up libradcli4 (1.2.6-4) ...
            Setting up asterisk-config (1:16.2.1~dfsg-1+deb10u2) ...
            Setting up libneon27-gnutls:armhf (0.30.2-3) ...
            Setting up libmariadb3:armhf (1:10.3.27-0+deb10u1) ...
            Setting up libodbc1:armhf (2.3.6-0.1) ...
            Setting up asterisk-core-sounds-en (1.6.1-1) ...
            update-alternatives: using /usr/share/asterisk/sounds/en_US_f_Allison to provide /usr/share/asterisk/sounds/en (asterisk-prompt-en) in auto mode
            update-alternatives: using /usr/share/asterisk/sounds/en_US_f_Allison to provide /usr/share/asterisk/sounds/en_US (asterisk-prompt-en-us) in auto mode
            Setting up libiksemel3:armhf (1.4-3+b1) ...
            Setting up liburiparser1:armhf (0.9.1-1) ...
            Setting up asterisk-moh-opsound-gsm (2.03-1) ...
            Setting up libspeexdsp1:armhf (1.2~rc1.2-1+b2) ...
            Setting up liblua5.1-0:armhf (5.1.5-8.1+b1) ...
            Setting up libxslt1.1:armhf (1.1.32-2.2~deb10u1) ...
            Setting up libical3:armhf (3.0.4-3) ...
            Setting up libresample1 (0.1.3-4) ...
            Setting up freetds-common (1.00.104-1+deb10u1) ...
            Setting up libgmime-3.0-0:armhf (3.2.1-1) ...
            Setting up libsybdb5:armhf (1.00.104-1+deb10u1) ...
            Setting up libsnmp30:armhf (5.7.3+dfsg-5+deb10u2) ...
            Setting up asterisk-modules (1:16.2.1~dfsg-1+deb10u2) ...
            Setting up asterisk (1:16.2.1~dfsg-1+deb10u2) ...
            Adding system user for Asterisk
            Adding user `asterisk' to group `dialout' ...
            Adding user asterisk to group dialout
            Done.
            Adding user `asterisk' to group `audio' ...
            Adding user asterisk to group audio
            Done.
            Created symlink /etc/systemd/system/multi-user.target.wants/asterisk.service → /lib/systemd/system/asterisk.service.
            Job for asterisk.service failed because the control process exited with error code.
            See "systemctl status asterisk.service" and "journalctl -xe" for details.
            invoke-rc.d: initscript asterisk, action "start" failed.
            ● asterisk.service - Asterisk PBX
               Loaded: loaded (/lib/systemd/system/asterisk.service; enabled; vendor preset: enabled)
               Active: activating (auto-restart) (Result: exit-code) since Sun 2021-06-06 15:22:33 CEST; 40ms ago
                 Docs: man:asterisk(8)
              Process: 31195 ExecStart=/usr/sbin/asterisk -g -f -p -U asterisk (code=exited, status=1/FAILURE)
             Main PID: 31195 (code=exited, status=1/FAILURE)
            dpkg: error processing package asterisk (--configure):
             installed asterisk package post-installation script subprocess returned error exit status 1
            dpkg: dependency problems prevent configuration of asterisk-voicemail:
             asterisk-voicemail depends on asterisk (= 1:16.2.1~dfsg-1+deb10u2); however:
              Package asterisk is not configured yet.
            dpkg: error processing package asterisk-voicemail (--configure):
             dependency problems - leaving unconfigured
            Processing triggers for systemd (241-7~deb10u7+rpi1) ...
            Processing triggers for man-db (2.8.5-2) ...
            Processing triggers for libc-bin (2.28-10+rpi1) ...
            Errors were encountered while processing:
             asterisk
             asterisk-voicemail
            E: Sub-process /usr/bin/dpkg returned an error code (1)
            Reinstall gibt dies aus:
            pi@pio4gb:/ $ sudo apt install --reinstall asterisk
            0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
            2 not fully installed or removed.
            After this operation, 0 B of additional disk space will be used.
            E: Internal Error, No file name for asterisk:armhf
            pi@pio4gb:/ $
            im installationsordner unter /etc/asterisk waren früher immer zahlreich dateien vorhanden. Nach den letzten Versuchen tut sich da aber nichts mehr
              Thomas Braun Most Active @varg last edited by
              @varg sagte in Asterisk bringt "Error while dialing (2). Error: {}":
              Irgendwie ist dein System krumm.
              cd ~
              sudo apt update
              sudo apt dist-upgrade
              • V
                @thomas-braun said in Asterisk bringt "Error while dialing (2). Error: {}":
                pi@pio4gb:~ $ sudo apt update
                Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                Get:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
                Hit:3 https://deb.nodesource.com/node_12.x buster InRelease
                Fetched 15.0 kB in 1s (13.9 kB/s)
                All packages are up to date.
                pi@pio4gb:~ $ sudo apt dist-upgrade
                Calculating upgrade... Done
                0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                See "systemctl status asterisk.service" and "journalctl -xe" for details....]
                   Active: activating (auto-restart) (Result: exit-code) since Sun 2021-06-06 15:31:53 CEST; 46ms ago
                  Process: 3229 ExecStart=/usr/sbin/asterisk -g -f -p -U asterisk (code=exited, status=1/FAILURE)
                 Main PID: 3229 (code=exited, status=1/FAILURE)
                 asterisk
                 asterisk-voicemail
                pi@pio4gb:~ $
                  @varg
                  sudo apt remove asterisk asterisk-voicemail --purge
                  • V
                    pi@pio4gb:~ $ sudo apt remove asterisk asterisk-voicemail --purge
                    The following packages were automatically installed and are no longer required:
                      asterisk-config asterisk-core-sounds-en asterisk-core-sounds-en-gsm asterisk-modules asterisk-moh-opsound-gsm freetds-common libgmime-3.0-0 libgpgme11 libical3 libiksemel3 libjansson4 liblua5.1-0 libmariadb3 libneon27-gnutls libodbc1
                      libpq5 libradcli4 libresample1 libsnmp-base libsnmp30 libspandsp2 libspeexdsp1 libsrtp2-1 libsybdb5 libunbound8 liburiparser1 libxslt1.1 mariadb-common mysql-common
                    Use 'sudo apt autoremove' to remove them.
                    The following packages will be REMOVED:
                      asterisk* asterisk-voicemail*
                    0 upgraded, 0 newly installed, 2 to remove and 0 not upgraded.
                    After this operation, 7,841 kB disk space will be freed.
                    (Reading database ... 52306 files and directories currently installed.)
                    Removing asterisk-voicemail (1:16.2.1~dfsg-1+deb10u2) ...
                    Removing asterisk (1:16.2.1~dfsg-1+deb10u2) ...
                    (Reading database ... 52072 files and directories currently installed.)
                    Purging configuration files for asterisk (1:16.2.1~dfsg-1+deb10u2) ...
                    pi@pio4gb:~ $
                      @varg
                      sudo apt update
                      sudo apt upgrade
                      Wenn sauber dann
                      • V
                        sudo apt upgrade
                        pi@pio4gb:~ $ sudo apt upgrade
                        pi@pio4gb:~ $
                        trotzdem "sudo apt install asterisk" ?
                          @varg
                          Ja, das ist sauber. Versuch jetzt mal
                          • V
                            @Thomas-Braun
                            pi@pio4gb:~ $ sudo apt install asterisk
                              asterisk-voicemail
                            Suggested packages:
                              asterisk-dahdi asterisk-dev asterisk-doc asterisk-ooh323 asterisk-opus asterisk-vpb
                            0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
                            Need to get 0 B/3,127 kB of archives.
                            After this operation, 7,841 kB of additional disk space will be used.
                            (Reading database ... 52068 files and directories currently installed.)
                            Preparing to unpack .../asterisk_1%3a16.2.1~dfsg-1+deb10u2_armhf.deb ...
                            Preparing to unpack .../asterisk-voicemail_1%3a16.2.1~dfsg-1+deb10u2_armhf.deb ...
                            Done.
                            Done.
                               Active: activating (auto-restart) (Result: exit-code) since Sun 2021-06-06 15:40:40 CEST; 44ms ago
                              Process: 5501 ExecStart=/usr/sbin/asterisk -g -f -p -U asterisk (code=exited, status=1/FAILURE)
                             Main PID: 5501 (code=exited, status=1/FAILURE)
                             asterisk
                             asterisk-voicemail
                            pi@pio4gb:~ $
                              Thomas Braun Most Active @varg last edited by Thomas Braun
                              Komisch.
                              sudo apt install -f
                              sudo dpkg --configure -a
                              • V
                                pi@pio4gb:~ $ sudo dpkg --configure -a
                                   Active: activating (auto-restart) (Result: exit-code) since Sun 2021-06-06 15:44:04 CEST; 49ms ago
                                  Process: 7376 ExecStart=/usr/sbin/asterisk -g -f -p -U asterisk (code=exited, status=1/FAILURE)
                                 Main PID: 7376 (code=exited, status=1/FAILURE)
                                Jun 06 15:44:04 pio4gb systemd[1]: Failed to start Asterisk PBX.
                                 asterisk
                                 asterisk-voicemail
                                pi@pio4gb:~ $
                                  @varg
                                  sudo apt install -f
                                  V 2 Replies Last reply Reply Quote 0
                                  • V
                                    pi@pio4gb:~ $ sudo apt install -f
                                       Active: activating (auto-restart) (Result: exit-code) since Sun 2021-06-06 15:45:02 CEST; 21ms ago
                                      Process: 8065 ExecStart=/usr/sbin/asterisk -g -f -p -U asterisk (code=exited, status=1/FAILURE)
                                     Main PID: 8065 (code=exited, status=1/FAILURE)
                                     asterisk
                                     asterisk-voicemail
                                       Active: activating (auto-restart) (Result: exit-code) since Sun 2021-06-06 15:45:16 CEST; 49ms ago
                                      Process: 8398 ExecStart=/usr/sbin/asterisk -g -f -p -U asterisk (code=exited, status=1/FAILURE)
                                     Main PID: 8398 (code=exited, status=1/FAILURE)
                                     asterisk
                                     asterisk-voicemail
                                    pi@pio4gb:~ $
                                    • V
                                      hatte ganz zuvor mit folgenden Befehlen versucht asterisk komplett zu löschen, vielleicht hats ja auch damit zu tun
                                      sudo apt-get remove  asterisk
                                      Following command is used to remove the asterisk package along with its dependencies:
                                      sudo apt-get remove --auto-remove asterisk
                                      This will remove asterisk and all its dependent packages which is no longer needed in the system.
                                      Completely removing asterisk with all configuration files:
                                      Following command should be used with care as it deletes all the configuration files and data:
                                      sudo apt-get purge asterisk
                                      or you can use following command also:
                                      sudo apt-get purge --auto-remove asterisk
                                      habe noch nen pi4 hier rumliegen, werde mal bei gelegenheit versuchen es da zu installieren
                                        @varg
                                        Hast du die alle verwendet?
                                        Schau mal was das macht:
                                        sudo sh -x /var/lib/dpkg/info/asterisk.postinst configure 1:16.2.1~dfsg-1+deb10u2
                                        oder auch
                                        sudo dpkg --configure -D 777 asterisk
                                        • V
                                          ja alle commands reingeprügelt
                                          pi@pio4gb:~ $ sudo sh -x /var/lib/dpkg/info/asterisk.postinst configure 1:16.2.1~dfsg-1+deb10u2        + set -e
                                          + getent passwd asterisk
                                          + groups asterisk
                                          + grep -w -q -v dialout
                                          + groups asterisk
                                          + grep -w -q -v audio
                                          + find /var/log/asterisk /var/lib/asterisk -type d
                                          + read dir
                                          + dpkg-statoverride --list /var/log/asterisk
                                          + chown asterisk: /var/log/asterisk
                                          + read dir
                                          + dpkg-statoverride --list /var/log/asterisk/cdr-custom
                                          + chown asterisk: /var/log/asterisk/cdr-custom
                                          + read dir
                                          + dpkg-statoverride --list /var/log/asterisk/cdr-csv
                                          + chown asterisk: /var/log/asterisk/cdr-csv
                                          + read dir
                                          + dpkg-statoverride --list /var/lib/asterisk
                                          + chown asterisk: /var/lib/asterisk
                                          + read dir
                                          + dpkg-statoverride --list /var/lib/asterisk/moh
                                          + chown asterisk: /var/lib/asterisk/moh
                                          + read dir
                                          + dpkg-statoverride --list /var/lib/asterisk/sounds
                                          + chown asterisk: /var/lib/asterisk/sounds
                                          + read dir
                                          + dpkg-statoverride --list /var/lib/asterisk/sounds/custom
                                          + chown asterisk: /var/lib/asterisk/sounds/custom
                                          + read dir
                                          + dpkg-statoverride --list /var/lib/asterisk/priv-callerintros
                                          + chown asterisk: /var/lib/asterisk/priv-callerintros
                                          + read dir
                                          + dpkg-statoverride --list /etc/asterisk
                                          + chown asterisk: /etc/asterisk
                                          + find /var/spool/asterisk -type d
                                          + read dir
                                          + dpkg-statoverride --list /var/spool/asterisk
                                          + chown asterisk: /var/spool/asterisk
                                          + chmod 750 /var/spool/asterisk
                                          + read dir
                                          + dpkg-statoverride --list /var/spool/asterisk/monitor
                                          + chown asterisk: /var/spool/asterisk/monitor
                                          + chmod 750 /var/spool/asterisk/monitor
                                          + read dir
                                          + dpkg-statoverride --list /var/spool/asterisk/tmp
                                          + chown asterisk: /var/spool/asterisk/tmp
                                          + chmod 750 /var/spool/asterisk/tmp
                                          + read dir
                                          + dpkg-statoverride --list /var/spool/asterisk/dictate
                                          + chown asterisk: /var/spool/asterisk/dictate
                                          + chmod 750 /var/spool/asterisk/dictate
                                          + read dir
                                          + dpkg-statoverride --list /var/spool/asterisk/outgoing
                                          + chown asterisk: /var/spool/asterisk/outgoing
                                          + chmod 750 /var/spool/asterisk/outgoing
                                          + read dir
                                          + dpkg-statoverride --list /var/spool/asterisk/meetme
                                          + chown asterisk: /var/spool/asterisk/meetme
                                          + chmod 750 /var/spool/asterisk/meetme
                                          + read dir
                                          + dpkg-statoverride --list /var/spool/asterisk/voicemail
                                          + chown asterisk: /var/spool/asterisk/voicemail
                                          + chmod 750 /var/spool/asterisk/voicemail
                                          + read dir
                                          + dpkg-statoverride --list /var/spool/asterisk/system
                                          + chown asterisk: /var/spool/asterisk/system
                                          + chmod 750 /var/spool/asterisk/system
                                          + read dir
                                          + [ ! -e /usr/local/share/asterisk/sounds ]
                                          + set +e
                                          + dpkg-query -W -f=${Package}\t${Provides}\n
                                          + sed -nr s/(.*)\tasterisk-config-custom|(asterisk-config)(\t.*)?/\1\2/p
                                          + ASTERISK_CONFIG=asterisk-config
                                          + dpkg-query -W -f=${Conffiles}\n asterisk-config
                                          + sed -nr -e s; (/etc/asterisk/.*) [0-9a-f]*;\1;p
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/acl.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/adsi.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/agents.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/alarmreceiver.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/alsa.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/amd.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/app_mysql.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/app_skel.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/ari.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/ast_debug_tools.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/asterisk.adsi
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/asterisk.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/calendar.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/ccss.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/cdr.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/cdr_adaptive_odbc.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/cdr_beanstalkd.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/cdr_custom.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/cdr_manager.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/cdr_mysql.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/cdr_odbc.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/cdr_pgsql.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/cdr_sqlite3_custom.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/cdr_syslog.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/cdr_tds.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/cel.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/cel_beanstalkd.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/cel_custom.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/cel_odbc.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/cel_pgsql.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/cel_sqlite3_custom.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/cel_tds.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/chan_dahdi.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/chan_mobile.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/cli.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/cli_aliases.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/cli_permissions.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/codecs.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/confbridge.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/config_test.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/console.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/dbsep.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/dnsmgr.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/dsp.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/enum.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/extconfig.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/extensions.ael
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/extensions.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/extensions.lua
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/extensions_minivm.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/features.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/festival.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/followme.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/func_odbc.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/hep.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/http.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/iax.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/iaxprov.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/indications.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/logger.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/manager.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/manager.d/README.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/meetme.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/minivm.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/misdn.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/modules.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/motif.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/musiconhold.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/muted.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/ooh323.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/osp.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/oss.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/phone.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/phoneprov.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/pjproject.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/pjsip.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/pjsip_notify.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/pjsip_wizard.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/queuerules.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/queues.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/res_config_mysql.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/res_config_sqlite.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/res_config_sqlite3.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/res_corosync.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/res_curl.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/res_fax.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/res_ldap.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/res_odbc.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/res_parking.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/res_pgsql.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/res_pktccops.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/res_snmp.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/res_stun_monitor.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/resolver_unbound.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/rtp.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/say.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/sip.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/sip_notify.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/sla.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/smdi.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/sorcery.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/ss7.timers
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/stasis.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/statsd.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/telcordia-1.adsi
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/test_sorcery.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/udptl.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/users.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/voicemail.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/vpb.conf
                                          + read conffile
                                          + chown asterisk: /etc/asterisk/xmpp.conf
                                          + read conffile
                                          + + read STAT
                                          dpkg-statoverride --quiet --list /etc/asterisk/*
                                          + set -e
                                          + [ configure = configure ]
                                          + deb-systemd-helper unmask asterisk.service
                                          /usr/bin/deb-systemd-helper was not called from dpkg. Exiting.
                                          + true
                                          + deb-systemd-helper --quiet was-enabled asterisk.service
                                          + deb-systemd-helper update-state asterisk.service
                                          + true
                                          + [ -x /etc/init.d/asterisk ]
                                          + update-rc.d asterisk defaults
                                          + [ -n 1:16.2.1~dfsg-1+deb10u2 ]
                                          + _dh_action=restart
                                          + invoke-rc.d asterisk restart
                                          invoke-rc.d: initscript asterisk, action "restart" failed.
                                             Active: activating (auto-restart) (Result: exit-code) since Sun 2021-06-06 15:58:51 CEST; 48ms ago
                                            Process: 14893 ExecStart=/usr/sbin/asterisk -g -f -p -U asterisk (code=exited, status=1/FAILURE)
                                           Main PID: 14893 (code=exited, status=1/FAILURE)
                                          + exit 1
                                          pi@pio4gb:~ $
                                          pi@pio4gb:~ $ sudo dpkg --configure -D 777 asterisk
                                          D000001: ensure_diversions: new, (re)loading
                                          D000001: process queue pkg asterisk:armhf queue.len 0 progress 1, try 1
                                          D000040: checking dependencies of asterisk:armhf (- <none>)
                                          D000400:   checking group ...
                                          D000400:     checking possibility  -> adduser
                                          D000400:       checking non-provided pkg adduser:all
                                          D000400:       is installed, ok and found
                                          D000400:     found 3
                                          D000400:   found 3 matched 0 possfixbytrig -
                                          D000400:     checking possibility  -> asterisk-config
                                          D000400:       checking non-provided pkg asterisk-config:all
                                          D000400:     found 3
                                          D000400:     checking possibility  -> asterisk-core-sounds-en
                                          D000400:       checking non-provided pkg asterisk-core-sounds-en:all
                                          D000400:     found 3
                                          D000400:     checking possibility  -> asterisk-modules
                                          D000400:       checking non-provided pkg asterisk-modules:armhf
                                          D000400:     found 3
                                          D000400:     checking possibility  -> lsb-base
                                          D000400:       checking non-provided pkg lsb-base:all
                                          D000400:     found 3
                                          D000400:     checking possibility  -> libc6
                                          D000400:       checking non-provided pkg libc6:armhf
                                          D000400:     found 3
                                          D000400:     checking possibility  -> libcap2
                                          D000400:       checking non-provided pkg libcap2:armhf
                                          D000400:     found 3
                                          D000400:     checking possibility  -> libedit2
                                          D000400:       checking non-provided pkg libedit2:armhf
                                          D000400:     found 3
                                          D000400:     checking possibility  -> libgcc1
                                          D000400:       checking non-provided pkg libgcc1:armhf
                                          D000400:     found 3
                                          D000400:     checking possibility  -> libjansson4
                                          D000400:       checking non-provided pkg libjansson4:armhf
                                          D000400:     found 3
                                          D000400:     checking possibility  -> libpopt0
                                          D000400:       checking non-provided pkg libpopt0:armhf
                                          D000400:     found 3
                                          D000400:     checking possibility  -> libsqlite3-0
                                          D000400:       checking non-provided pkg libsqlite3-0:armhf
                                          D000400:     found 3
                                          D000400:     checking possibility  -> libssl1.1
                                          D000400:       checking non-provided pkg libssl1.1:armhf
                                          D000400:     found 3
                                          D000400:     checking possibility  -> libsystemd0
                                          D000400:       checking non-provided pkg libsystemd0:armhf
                                          D000400:     found 3
                                          D000400:     checking possibility  -> liburiparser1
                                          D000400:       checking non-provided pkg liburiparser1:armhf
                                          D000400:     found 3
                                          D000400:     checking possibility  -> libuuid1
                                          D000400:       checking non-provided pkg libuuid1:armhf
                                          D000400:     found 3
                                          D000400:     checking possibility  -> libxml2
                                          D000400:       checking non-provided pkg libxml2:armhf
                                          D000400:     found 3
                                          D000400:     checking possibility  -> libxslt1.1
                                          D000400:       checking non-provided pkg libxslt1.1:armhf
                                          D000400:     found 3
                                          D000040: ok 2 msgs >><<
                                          D000040:     checking Breaks
                                          D000400:      checking virtbroken asterisk-1fb7f5c06d7a2052e38d021b3d8ca151
                                          D000002: fork/exec /var/lib/dpkg/info/asterisk.postinst ( configure  )
                                             Active: activating (auto-restart) (Result: exit-code) since Sun 2021-06-06 15:59:56 CEST; 23ms ago
                                            Process: 15558 ExecStart=/usr/sbin/asterisk -g -f -p -U asterisk (code=exited, status=1/FAILURE)
                                           Main PID: 15558 (code=exited, status=1/FAILURE)
                                          D000001: ensure_diversions: same, skipping
                                          D000040: checking dependencies of libc-bin:armhf (- <none>)
                                          D000400:     found 3
                                          D000400:     found 3
                                          D000002: fork/exec /var/lib/dpkg/info/libc-bin.postinst ( triggered ldconfig )
                                           asterisk
                                          pi@pio4gb:~ $
                                            @varg
                                            ls -l /var/lib/dpkg/info | grep -i asterisk
                                            116
                                            11033
