    4. Asterisk bringt "Error while dialing (2). Error: {}"
      andiber @Thomas Braun last edited by
      @thomas-braun Gar nichts, beide Befehle sind ohne Fehlermeldung durchgelaufen, es endete jeweils mit der normalen Eigabeaufforderung.
        Thomas Braun Most Active @andiber last edited by
        @andiber
        Dann mal ein
        sudo apt install --reinstall asterisk
        • V
          varg @Thomas Braun last edited by varg
          Installation anhand dieser Anleitung Git
          Befehle ergeben:
          pi@pio4gb:/ $ sudo dpkg-reconfigure --priority=low asterisk-voicemail
          /usr/sbin/dpkg-reconfigure: asterisk-voicemail is broken or not fully installed
          /usr/sbin/dpkg-reconfigure: asterisk is broken or not fully installed
          pi@pio4gb:/ $ ^C
          Installation sieht immer noch so aus:
          i@pio4gb:/ $ sudo apt install asterisk
          Reading package lists... Done
          Building dependency tree
          The following additional packages will be installed:
            asterisk-config asterisk-core-sounds-en asterisk-core-sounds-en-gsm
            asterisk-modules asterisk-moh-opsound-gsm asterisk-voicemail freetds-common
            libgmime-3.0-0 libgpgme11 libical3 libiksemel3 libjansson4 liblua5.1-0
            libmariadb3 libneon27-gnutls libodbc1 libpq5 libradcli4 libresample1
            libsnmp-base libsnmp30 libspandsp2 libspeexdsp1 libsrtp2-1 libsybdb5
            libunbound8 liburiparser1 libxslt1.1 mariadb-common mysql-common
          Suggested packages:
            asterisk-dahdi asterisk-dev asterisk-doc asterisk-ooh323 asterisk-opus
            asterisk-vpb libmyodbc odbc-postgresql tdsodbc unixodbc-bin
            snmp-mibs-downloader
          The following NEW packages will be installed:
            asterisk asterisk-config asterisk-core-sounds-en asterisk-core-sounds-en-gsm
          0 upgraded, 31 newly installed, 0 to remove and 0 not upgraded.
          Need to get 0 B/18.6 MB of archives.
          After this operation, 39.2 MB of additional disk space will be used.
          Do you want to continue? [Y/n] Y
          Extracting templates from packages: 100%
          Selecting previously unselected package asterisk-config.
          (Reading database ... 50667 files and directories currently installed.)
          Preparing to unpack .../00-asterisk-config_1%3a16.2.1~dfsg-1+deb10u2_all.deb ...
          Unpacking asterisk-config (1:16.2.1~dfsg-1+deb10u2) ...
          Selecting previously unselected package asterisk-core-sounds-en-gsm.
          Preparing to unpack .../01-asterisk-core-sounds-en-gsm_1.6.1-1_all.deb ...
          Unpacking asterisk-core-sounds-en-gsm (1.6.1-1) ...
          Selecting previously unselected package asterisk-core-sounds-en.
          Preparing to unpack .../02-asterisk-core-sounds-en_1.6.1-1_all.deb ...
          Unpacking asterisk-core-sounds-en (1.6.1-1) ...
          Selecting previously unselected package libgpgme11:armhf.
          Preparing to unpack .../03-libgpgme11_1.12.0-6_armhf.deb ...
          Unpacking libgpgme11:armhf (1.12.0-6) ...
          Selecting previously unselected package libgmime-3.0-0:armhf.
          Preparing to unpack .../04-libgmime-3.0-0_3.2.1-1_armhf.deb ...
          Unpacking libgmime-3.0-0:armhf (3.2.1-1) ...
          Selecting previously unselected package libical3:armhf.
          Preparing to unpack .../05-libical3_3.0.4-3_armhf.deb ...
          Unpacking libical3:armhf (3.0.4-3) ...
          Selecting previously unselected package libiksemel3:armhf.
          Preparing to unpack .../06-libiksemel3_1.4-3+b1_armhf.deb ...
          Unpacking libiksemel3:armhf (1.4-3+b1) ...
          Selecting previously unselected package liblua5.1-0:armhf.
          Preparing to unpack .../07-liblua5.1-0_5.1.5-8.1+b1_armhf.deb ...
          Unpacking liblua5.1-0:armhf (5.1.5-8.1+b1) ...
          Selecting previously unselected package libneon27-gnutls:armhf.
          Preparing to unpack .../08-libneon27-gnutls_0.30.2-3_armhf.deb ...
          Unpacking libneon27-gnutls:armhf (0.30.2-3) ...
          Selecting previously unselected package libodbc1:armhf.
          Preparing to unpack .../09-libodbc1_2.3.6-0.1_armhf.deb ...
          Unpacking libodbc1:armhf (2.3.6-0.1) ...
          Selecting previously unselected package libpq5:armhf.
          Preparing to unpack .../10-libpq5_11.12-0+deb10u1_armhf.deb ...
          Unpacking libpq5:armhf (11.12-0+deb10u1) ...
          Selecting previously unselected package libradcli4.
          Preparing to unpack .../11-libradcli4_1.2.6-4_armhf.deb ...
          Unpacking libradcli4 (1.2.6-4) ...
          Selecting previously unselected package libresample1.
          Preparing to unpack .../12-libresample1_0.1.3-4_armhf.deb ...
          Unpacking libresample1 (0.1.3-4) ...
          Selecting previously unselected package mysql-common.
          Preparing to unpack .../13-mysql-common_5.8+1.0.5_all.deb ...
          Unpacking mysql-common (5.8+1.0.5) ...
          Selecting previously unselected package mariadb-common.
          Preparing to unpack .../14-mariadb-common_1%3a10.3.27-0+deb10u1_all.deb ...
          Unpacking mariadb-common (1:10.3.27-0+deb10u1) ...
          Selecting previously unselected package libmariadb3:armhf.
          Preparing to unpack .../15-libmariadb3_1%3a10.3.27-0+deb10u1_armhf.deb ...
          Unpacking libmariadb3:armhf (1:10.3.27-0+deb10u1) ...
          Selecting previously unselected package libsnmp-base.
          Preparing to unpack .../16-libsnmp-base_5.7.3+dfsg-5+deb10u2_all.deb ...
          Unpacking libsnmp-base (5.7.3+dfsg-5+deb10u2) ...
          Selecting previously unselected package libsnmp30:armhf.
          Preparing to unpack .../17-libsnmp30_5.7.3+dfsg-5+deb10u2_armhf.deb ...
          Unpacking libsnmp30:armhf (5.7.3+dfsg-5+deb10u2) ...
          Selecting previously unselected package libspandsp2:armhf.
          Preparing to unpack .../18-libspandsp2_0.0.6+dfsg-2_armhf.deb ...
          Unpacking libspandsp2:armhf (0.0.6+dfsg-2) ...
          Selecting previously unselected package libspeexdsp1:armhf.
          Preparing to unpack .../19-libspeexdsp1_1.2~rc1.2-1+b2_armhf.deb ...
          Unpacking libspeexdsp1:armhf (1.2~rc1.2-1+b2) ...
          Selecting previously unselected package libsrtp2-1:armhf.
          Preparing to unpack .../20-libsrtp2-1_2.2.0-1_armhf.deb ...
          Unpacking libsrtp2-1:armhf (2.2.0-1) ...
          Selecting previously unselected package freetds-common.
          Preparing to unpack .../21-freetds-common_1.00.104-1+deb10u1_all.deb ...
          Unpacking freetds-common (1.00.104-1+deb10u1) ...
          Selecting previously unselected package libsybdb5:armhf.
          Preparing to unpack .../22-libsybdb5_1.00.104-1+deb10u1_armhf.deb ...
          Unpacking libsybdb5:armhf (1.00.104-1+deb10u1) ...
          Selecting previously unselected package libunbound8:armhf.
          Preparing to unpack .../23-libunbound8_1.9.0-2+deb10u2_armhf.deb ...
          Unpacking libunbound8:armhf (1.9.0-2+deb10u2) ...
          Selecting previously unselected package asterisk-modules.
          Preparing to unpack .../24-asterisk-modules_1%3a16.2.1~dfsg-1+deb10u2_armhf.deb ...
          Unpacking asterisk-modules (1:16.2.1~dfsg-1+deb10u2) ...
          Selecting previously unselected package libjansson4:armhf.
          Preparing to unpack .../25-libjansson4_2.12-1_armhf.deb ...
          Unpacking libjansson4:armhf (2.12-1) ...
          Selecting previously unselected package liburiparser1:armhf.
          Preparing to unpack .../26-liburiparser1_0.9.1-1_armhf.deb ...
          Unpacking liburiparser1:armhf (0.9.1-1) ...
          Selecting previously unselected package libxslt1.1:armhf.
          Preparing to unpack .../27-libxslt1.1_1.1.32-2.2~deb10u1_armhf.deb ...
          Unpacking libxslt1.1:armhf (1.1.32-2.2~deb10u1) ...
          Selecting previously unselected package asterisk.
          Preparing to unpack .../28-asterisk_1%3a16.2.1~dfsg-1+deb10u2_armhf.deb ...
          Unpacking asterisk (1:16.2.1~dfsg-1+deb10u2) ...
          Selecting previously unselected package asterisk-voicemail.
          Preparing to unpack .../29-asterisk-voicemail_1%3a16.2.1~dfsg-1+deb10u2_armhf.deb ...
          Unpacking asterisk-voicemail (1:16.2.1~dfsg-1+deb10u2) ...
          Selecting previously unselected package asterisk-moh-opsound-gsm.
          Preparing to unpack .../30-asterisk-moh-opsound-gsm_2.03-1_all.deb ...
          Unpacking asterisk-moh-opsound-gsm (2.03-1) ...
          Setting up mysql-common (5.8+1.0.5) ...
          update-alternatives: using /etc/mysql/my.cnf.fallback to provide /etc/mysql/my.cnf (my.cnf) in auto mode
          Setting up asterisk-core-sounds-en-gsm (1.6.1-1) ...
          Setting up libsnmp-base (5.7.3+dfsg-5+deb10u2) ...
          Setting up libsrtp2-1:armhf (2.2.0-1) ...
          Setting up libpq5:armhf (11.12-0+deb10u1) ...
          Setting up libgpgme11:armhf (1.12.0-6) ...
          Setting up libspandsp2:armhf (0.0.6+dfsg-2) ...
          Setting up libjansson4:armhf (2.12-1) ...
          Setting up mariadb-common (1:10.3.27-0+deb10u1) ...
          update-alternatives: using /etc/mysql/mariadb.cnf to provide /etc/mysql/my.cnf (my.cnf) in auto mode
          Setting up libunbound8:armhf (1.9.0-2+deb10u2) ...
          Setting up libradcli4 (1.2.6-4) ...
          Setting up asterisk-config (1:16.2.1~dfsg-1+deb10u2) ...
          Setting up libneon27-gnutls:armhf (0.30.2-3) ...
          Setting up libmariadb3:armhf (1:10.3.27-0+deb10u1) ...
          Setting up libodbc1:armhf (2.3.6-0.1) ...
          Setting up asterisk-core-sounds-en (1.6.1-1) ...
          update-alternatives: using /usr/share/asterisk/sounds/en_US_f_Allison to provide /usr/share/asterisk/sounds/en (asterisk-prompt-en) in auto mode
          update-alternatives: using /usr/share/asterisk/sounds/en_US_f_Allison to provide /usr/share/asterisk/sounds/en_US (asterisk-prompt-en-us) in auto mode
          Setting up libiksemel3:armhf (1.4-3+b1) ...
          Setting up liburiparser1:armhf (0.9.1-1) ...
          Setting up asterisk-moh-opsound-gsm (2.03-1) ...
          Setting up libspeexdsp1:armhf (1.2~rc1.2-1+b2) ...
          Setting up liblua5.1-0:armhf (5.1.5-8.1+b1) ...
          Setting up libxslt1.1:armhf (1.1.32-2.2~deb10u1) ...
          Setting up libical3:armhf (3.0.4-3) ...
          Setting up libresample1 (0.1.3-4) ...
          Setting up freetds-common (1.00.104-1+deb10u1) ...
          Setting up libgmime-3.0-0:armhf (3.2.1-1) ...
          Setting up libsybdb5:armhf (1.00.104-1+deb10u1) ...
          Setting up libsnmp30:armhf (5.7.3+dfsg-5+deb10u2) ...
          Setting up asterisk-modules (1:16.2.1~dfsg-1+deb10u2) ...
          Setting up asterisk (1:16.2.1~dfsg-1+deb10u2) ...
          Adding system user for Asterisk
          Adding user `asterisk' to group `dialout' ...
          Adding user asterisk to group dialout
          Done.
          Adding user `asterisk' to group `audio' ...
          Adding user asterisk to group audio
          Done.
          Created symlink /etc/systemd/system/multi-user.target.wants/asterisk.service → /lib/systemd/system/asterisk.service.
          Job for asterisk.service failed because the control process exited with error code.
          See "systemctl status asterisk.service" and "journalctl -xe" for details.
          invoke-rc.d: initscript asterisk, action "start" failed.
          ● asterisk.service - Asterisk PBX
             Loaded: loaded (/lib/systemd/system/asterisk.service; enabled; vendor preset: enabled)
             Active: activating (auto-restart) (Result: exit-code) since Sun 2021-06-06 15:22:33 CEST; 40ms ago
               Docs: man:asterisk(8)
            Process: 31195 ExecStart=/usr/sbin/asterisk -g -f -p -U asterisk (code=exited, status=1/FAILURE)
           Main PID: 31195 (code=exited, status=1/FAILURE)
          dpkg: error processing package asterisk (--configure):
           installed asterisk package post-installation script subprocess returned error exit status 1
          dpkg: dependency problems prevent configuration of asterisk-voicemail:
           asterisk-voicemail depends on asterisk (= 1:16.2.1~dfsg-1+deb10u2); however:
            Package asterisk is not configured yet.
          dpkg: error processing package asterisk-voicemail (--configure):
           dependency problems - leaving unconfigured
          Processing triggers for systemd (241-7~deb10u7+rpi1) ...
          Processing triggers for man-db (2.8.5-2) ...
          Processing triggers for libc-bin (2.28-10+rpi1) ...
          Errors were encountered while processing:
           asterisk
           asterisk-voicemail
          E: Sub-process /usr/bin/dpkg returned an error code (1)
          Reinstall gibt dies aus:
          pi@pio4gb:/ $ sudo apt install --reinstall asterisk
          0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
          2 not fully installed or removed.
          After this operation, 0 B of additional disk space will be used.
          E: Internal Error, No file name for asterisk:armhf
          pi@pio4gb:/ $
          im installationsordner unter /etc/asterisk waren früher immer zahlreich dateien vorhanden. Nach den letzten Versuchen tut sich da aber nichts mehr
            Thomas Braun Most Active @varg last edited by
            @varg sagte in Asterisk bringt "Error while dialing (2). Error: {}":
            Irgendwie ist dein System krumm.
            cd ~
            sudo apt update
            sudo apt dist-upgrade
            • V
              @thomas-braun said in Asterisk bringt "Error while dialing (2). Error: {}":
              pi@pio4gb:~ $ sudo apt update
              Hit:1 http://archive.raspberrypi.org/debian buster InRelease
              Get:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
              Hit:3 https://deb.nodesource.com/node_12.x buster InRelease
              Fetched 15.0 kB in 1s (13.9 kB/s)
              All packages are up to date.
              pi@pio4gb:~ $ sudo apt dist-upgrade
              Calculating upgrade... Done
              0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
              See "systemctl status asterisk.service" and "journalctl -xe" for details....]
                 Active: activating (auto-restart) (Result: exit-code) since Sun 2021-06-06 15:31:53 CEST; 46ms ago
                Process: 3229 ExecStart=/usr/sbin/asterisk -g -f -p -U asterisk (code=exited, status=1/FAILURE)
               Main PID: 3229 (code=exited, status=1/FAILURE)
               asterisk
               asterisk-voicemail
              pi@pio4gb:~ $
                @varg
                sudo apt remove asterisk asterisk-voicemail --purge
                • V
                  pi@pio4gb:~ $ sudo apt remove asterisk asterisk-voicemail --purge
                  The following packages were automatically installed and are no longer required:
                    asterisk-config asterisk-core-sounds-en asterisk-core-sounds-en-gsm asterisk-modules asterisk-moh-opsound-gsm freetds-common libgmime-3.0-0 libgpgme11 libical3 libiksemel3 libjansson4 liblua5.1-0 libmariadb3 libneon27-gnutls libodbc1
                    libpq5 libradcli4 libresample1 libsnmp-base libsnmp30 libspandsp2 libspeexdsp1 libsrtp2-1 libsybdb5 libunbound8 liburiparser1 libxslt1.1 mariadb-common mysql-common
                  Use 'sudo apt autoremove' to remove them.
                  The following packages will be REMOVED:
                    asterisk* asterisk-voicemail*
                  0 upgraded, 0 newly installed, 2 to remove and 0 not upgraded.
                  After this operation, 7,841 kB disk space will be freed.
                  (Reading database ... 52306 files and directories currently installed.)
                  Removing asterisk-voicemail (1:16.2.1~dfsg-1+deb10u2) ...
                  Removing asterisk (1:16.2.1~dfsg-1+deb10u2) ...
                  (Reading database ... 52072 files and directories currently installed.)
                  Purging configuration files for asterisk (1:16.2.1~dfsg-1+deb10u2) ...
                  pi@pio4gb:~ $
                    @varg
                    sudo apt update
                    sudo apt upgrade
                    Wenn sauber dann
                    • V
                      sudo apt upgrade
                      pi@pio4gb:~ $ sudo apt upgrade
                      pi@pio4gb:~ $
                      trotzdem "sudo apt install asterisk" ?
                        @varg
                        Ja, das ist sauber. Versuch jetzt mal
                        • V
                          @Thomas-Braun
                          pi@pio4gb:~ $ sudo apt install asterisk
                            asterisk-voicemail
                          Suggested packages:
                            asterisk-dahdi asterisk-dev asterisk-doc asterisk-ooh323 asterisk-opus asterisk-vpb
                          0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
                          Need to get 0 B/3,127 kB of archives.
                          After this operation, 7,841 kB of additional disk space will be used.
                          (Reading database ... 52068 files and directories currently installed.)
                          Preparing to unpack .../asterisk_1%3a16.2.1~dfsg-1+deb10u2_armhf.deb ...
                          Preparing to unpack .../asterisk-voicemail_1%3a16.2.1~dfsg-1+deb10u2_armhf.deb ...
                          Done.
                          Done.
                             Active: activating (auto-restart) (Result: exit-code) since Sun 2021-06-06 15:40:40 CEST; 44ms ago
                            Process: 5501 ExecStart=/usr/sbin/asterisk -g -f -p -U asterisk (code=exited, status=1/FAILURE)
                           Main PID: 5501 (code=exited, status=1/FAILURE)
                           asterisk
                           asterisk-voicemail
                          pi@pio4gb:~ $
                            Thomas Braun Most Active @varg last edited by Thomas Braun
                            Komisch.
                            sudo apt install -f
                            sudo dpkg --configure -a
                            • V
                              pi@pio4gb:~ $ sudo dpkg --configure -a
                                 Active: activating (auto-restart) (Result: exit-code) since Sun 2021-06-06 15:44:04 CEST; 49ms ago
                                Process: 7376 ExecStart=/usr/sbin/asterisk -g -f -p -U asterisk (code=exited, status=1/FAILURE)
                               Main PID: 7376 (code=exited, status=1/FAILURE)
                              Jun 06 15:44:04 pio4gb systemd[1]: Failed to start Asterisk PBX.
                               asterisk
                               asterisk-voicemail
                              pi@pio4gb:~ $
                                @varg
                                sudo apt install -f
                                V 2 Replies Last reply Reply Quote 0
                                • V
                                  pi@pio4gb:~ $ sudo apt install -f
                                     Active: activating (auto-restart) (Result: exit-code) since Sun 2021-06-06 15:45:02 CEST; 21ms ago
                                    Process: 8065 ExecStart=/usr/sbin/asterisk -g -f -p -U asterisk (code=exited, status=1/FAILURE)
                                   Main PID: 8065 (code=exited, status=1/FAILURE)
                                   asterisk
                                   asterisk-voicemail
                                     Active: activating (auto-restart) (Result: exit-code) since Sun 2021-06-06 15:45:16 CEST; 49ms ago
                                    Process: 8398 ExecStart=/usr/sbin/asterisk -g -f -p -U asterisk (code=exited, status=1/FAILURE)
                                   Main PID: 8398 (code=exited, status=1/FAILURE)
                                   asterisk
                                   asterisk-voicemail
                                  pi@pio4gb:~ $
                                  • V
                                    hatte ganz zuvor mit folgenden Befehlen versucht asterisk komplett zu löschen, vielleicht hats ja auch damit zu tun
                                    sudo apt-get remove  asterisk
                                    Following command is used to remove the asterisk package along with its dependencies:
                                    sudo apt-get remove --auto-remove asterisk
                                    This will remove asterisk and all its dependent packages which is no longer needed in the system.
                                    Completely removing asterisk with all configuration files:
                                    Following command should be used with care as it deletes all the configuration files and data:
                                    sudo apt-get purge asterisk
                                    or you can use following command also:
                                    sudo apt-get purge --auto-remove asterisk
                                    habe noch nen pi4 hier rumliegen, werde mal bei gelegenheit versuchen es da zu installieren
                                      @varg
                                      Hast du die alle verwendet?
                                      Schau mal was das macht:
                                      sudo sh -x /var/lib/dpkg/info/asterisk.postinst configure 1:16.2.1~dfsg-1+deb10u2
                                      oder auch
                                      sudo dpkg --configure -D 777 asterisk
                                      • V
                                        ja alle commands reingeprügelt
                                        pi@pio4gb:~ $ sudo sh -x /var/lib/dpkg/info/asterisk.postinst configure 1:16.2.1~dfsg-1+deb10u2        + set -e
                                        + getent passwd asterisk
                                        + groups asterisk
                                        + grep -w -q -v dialout
                                        + groups asterisk
                                        + grep -w -q -v audio
                                        + find /var/log/asterisk /var/lib/asterisk -type d
                                        + read dir
                                        + dpkg-statoverride --list /var/log/asterisk
                                        + chown asterisk: /var/log/asterisk
                                        + read dir
                                        + dpkg-statoverride --list /var/log/asterisk/cdr-custom
                                        + chown asterisk: /var/log/asterisk/cdr-custom
                                        + read dir
                                        + dpkg-statoverride --list /var/log/asterisk/cdr-csv
                                        + chown asterisk: /var/log/asterisk/cdr-csv
                                        + read dir
                                        + dpkg-statoverride --list /var/lib/asterisk
                                        + chown asterisk: /var/lib/asterisk
                                        + read dir
                                        + dpkg-statoverride --list /var/lib/asterisk/moh
                                        + chown asterisk: /var/lib/asterisk/moh
                                        + read dir
                                        + dpkg-statoverride --list /var/lib/asterisk/sounds
                                        + chown asterisk: /var/lib/asterisk/sounds
                                        + read dir
                                        + dpkg-statoverride --list /var/lib/asterisk/sounds/custom
                                        + chown asterisk: /var/lib/asterisk/sounds/custom
                                        + read dir
                                        + dpkg-statoverride --list /var/lib/asterisk/priv-callerintros
                                        + chown asterisk: /var/lib/asterisk/priv-callerintros
                                        + read dir
                                        + dpkg-statoverride --list /etc/asterisk
                                        + chown asterisk: /etc/asterisk
                                        + find /var/spool/asterisk -type d
                                        + read dir
                                        + dpkg-statoverride --list /var/spool/asterisk
                                        + chown asterisk: /var/spool/asterisk
                                        + chmod 750 /var/spool/asterisk
                                        + read dir
                                        + dpkg-statoverride --list /var/spool/asterisk/monitor
                                        + chown asterisk: /var/spool/asterisk/monitor
                                        + chmod 750 /var/spool/asterisk/monitor
                                        + read dir
                                        + dpkg-statoverride --list /var/spool/asterisk/tmp
                                        + chown asterisk: /var/spool/asterisk/tmp
                                        + chmod 750 /var/spool/asterisk/tmp
                                        + read dir
                                        + dpkg-statoverride --list /var/spool/asterisk/dictate
                                        + chown asterisk: /var/spool/asterisk/dictate
                                        + chmod 750 /var/spool/asterisk/dictate
                                        + read dir
                                        + dpkg-statoverride --list /var/spool/asterisk/outgoing
                                        + chown asterisk: /var/spool/asterisk/outgoing
                                        + chmod 750 /var/spool/asterisk/outgoing
                                        + read dir
                                        + dpkg-statoverride --list /var/spool/asterisk/meetme
                                        + chown asterisk: /var/spool/asterisk/meetme
                                        + chmod 750 /var/spool/asterisk/meetme
                                        + read dir
                                        + dpkg-statoverride --list /var/spool/asterisk/voicemail
                                        + chown asterisk: /var/spool/asterisk/voicemail
                                        + chmod 750 /var/spool/asterisk/voicemail
                                        + read dir
                                        + dpkg-statoverride --list /var/spool/asterisk/system
                                        + chown asterisk: /var/spool/asterisk/system
                                        + chmod 750 /var/spool/asterisk/system
                                        + read dir
                                        + [ ! -e /usr/local/share/asterisk/sounds ]
                                        + set +e
                                        + dpkg-query -W -f=${Package}\t${Provides}\n
                                        + sed -nr s/(.*)\tasterisk-config-custom|(asterisk-config)(\t.*)?/\1\2/p
                                        + ASTERISK_CONFIG=asterisk-config
                                        + dpkg-query -W -f=${Conffiles}\n asterisk-config
                                        + sed -nr -e s; (/etc/asterisk/.*) [0-9a-f]*;\1;p
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/acl.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/adsi.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/agents.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/alarmreceiver.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/alsa.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/amd.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/app_mysql.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/app_skel.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/ari.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/ast_debug_tools.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/asterisk.adsi
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/asterisk.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/calendar.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/ccss.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/cdr.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/cdr_adaptive_odbc.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/cdr_beanstalkd.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/cdr_custom.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/cdr_manager.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/cdr_mysql.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/cdr_odbc.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/cdr_pgsql.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/cdr_sqlite3_custom.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/cdr_syslog.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/cdr_tds.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/cel.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/cel_beanstalkd.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/cel_custom.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/cel_odbc.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/cel_pgsql.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/cel_sqlite3_custom.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/cel_tds.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/chan_dahdi.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/chan_mobile.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/cli.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/cli_aliases.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/cli_permissions.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/codecs.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/confbridge.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/config_test.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/console.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/dbsep.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/dnsmgr.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/dsp.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/enum.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/extconfig.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/extensions.ael
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/extensions.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/extensions.lua
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/extensions_minivm.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/features.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/festival.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/followme.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/func_odbc.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/hep.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/http.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/iax.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/iaxprov.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/indications.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/logger.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/manager.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/manager.d/README.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/meetme.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/minivm.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/misdn.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/modules.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/motif.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/musiconhold.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/muted.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/ooh323.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/osp.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/oss.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/phone.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/phoneprov.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/pjproject.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/pjsip.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/pjsip_notify.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/pjsip_wizard.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/queuerules.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/queues.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/res_config_mysql.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/res_config_sqlite.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/res_config_sqlite3.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/res_corosync.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/res_curl.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/res_fax.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/res_ldap.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/res_odbc.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/res_parking.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/res_pgsql.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/res_pktccops.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/res_snmp.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/res_stun_monitor.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/resolver_unbound.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/rtp.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/say.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/sip.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/sip_notify.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/sla.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/smdi.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/sorcery.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/ss7.timers
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/stasis.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/statsd.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/telcordia-1.adsi
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/test_sorcery.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/udptl.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/users.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/voicemail.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/vpb.conf
                                        + read conffile
                                        + chown asterisk: /etc/asterisk/xmpp.conf
                                        + read conffile
                                        + + read STAT
                                        dpkg-statoverride --quiet --list /etc/asterisk/*
                                        + set -e
                                        + [ configure = configure ]
                                        + deb-systemd-helper unmask asterisk.service
                                        /usr/bin/deb-systemd-helper was not called from dpkg. Exiting.
                                        + true
                                        + deb-systemd-helper --quiet was-enabled asterisk.service
                                        + deb-systemd-helper update-state asterisk.service
                                        + true
                                        + [ -x /etc/init.d/asterisk ]
                                        + update-rc.d asterisk defaults
                                        + [ -n 1:16.2.1~dfsg-1+deb10u2 ]
                                        + _dh_action=restart
                                        + invoke-rc.d asterisk restart
                                        invoke-rc.d: initscript asterisk, action "restart" failed.
                                           Active: activating (auto-restart) (Result: exit-code) since Sun 2021-06-06 15:58:51 CEST; 48ms ago
                                          Process: 14893 ExecStart=/usr/sbin/asterisk -g -f -p -U asterisk (code=exited, status=1/FAILURE)
                                         Main PID: 14893 (code=exited, status=1/FAILURE)
                                        + exit 1
                                        pi@pio4gb:~ $
                                        pi@pio4gb:~ $ sudo dpkg --configure -D 777 asterisk
                                        D000001: ensure_diversions: new, (re)loading
                                        D000001: process queue pkg asterisk:armhf queue.len 0 progress 1, try 1
                                        D000040: checking dependencies of asterisk:armhf (- <none>)
                                        D000400:   checking group ...
                                        D000400:     checking possibility  -> adduser
                                        D000400:       checking non-provided pkg adduser:all
                                        D000400:       is installed, ok and found
                                        D000400:     found 3
                                        D000400:   found 3 matched 0 possfixbytrig -
                                        D000400:     checking possibility  -> asterisk-config
                                        D000400:       checking non-provided pkg asterisk-config:all
                                        D000400:     found 3
                                        D000400:     checking possibility  -> asterisk-core-sounds-en
                                        D000400:       checking non-provided pkg asterisk-core-sounds-en:all
                                        D000400:     found 3
                                        D000400:     checking possibility  -> asterisk-modules
                                        D000400:       checking non-provided pkg asterisk-modules:armhf
                                        D000400:     found 3
                                        D000400:     checking possibility  -> lsb-base
                                        D000400:       checking non-provided pkg lsb-base:all
                                        D000400:     found 3
                                        D000400:     checking possibility  -> libc6
                                        D000400:       checking non-provided pkg libc6:armhf
                                        D000400:     found 3
                                        D000400:     checking possibility  -> libcap2
                                        D000400:       checking non-provided pkg libcap2:armhf
                                        D000400:     found 3
                                        D000400:     checking possibility  -> libedit2
                                        D000400:       checking non-provided pkg libedit2:armhf
                                        D000400:     found 3
                                        D000400:     checking possibility  -> libgcc1
                                        D000400:       checking non-provided pkg libgcc1:armhf
                                        D000400:     found 3
                                        D000400:     checking possibility  -> libjansson4
                                        D000400:       checking non-provided pkg libjansson4:armhf
                                        D000400:     found 3
                                        D000400:     checking possibility  -> libpopt0
                                        D000400:       checking non-provided pkg libpopt0:armhf
                                        D000400:     found 3
                                        D000400:     checking possibility  -> libsqlite3-0
                                        D000400:       checking non-provided pkg libsqlite3-0:armhf
                                        D000400:     found 3
                                        D000400:     checking possibility  -> libssl1.1
                                        D000400:       checking non-provided pkg libssl1.1:armhf
                                        D000400:     found 3
                                        D000400:     checking possibility  -> libsystemd0
                                        D000400:       checking non-provided pkg libsystemd0:armhf
                                        D000400:     found 3
                                        D000400:     checking possibility  -> liburiparser1
                                        D000400:       checking non-provided pkg liburiparser1:armhf
                                        D000400:     found 3
                                        D000400:     checking possibility  -> libuuid1
                                        D000400:       checking non-provided pkg libuuid1:armhf
                                        D000400:     found 3
                                        D000400:     checking possibility  -> libxml2
                                        D000400:       checking non-provided pkg libxml2:armhf
                                        D000400:     found 3
                                        D000400:     checking possibility  -> libxslt1.1
                                        D000400:       checking non-provided pkg libxslt1.1:armhf
                                        D000400:     found 3
                                        D000040: ok 2 msgs >><<
                                        D000040:     checking Breaks
                                        D000400:      checking virtbroken asterisk-1fb7f5c06d7a2052e38d021b3d8ca151
                                        D000002: fork/exec /var/lib/dpkg/info/asterisk.postinst ( configure  )
                                           Active: activating (auto-restart) (Result: exit-code) since Sun 2021-06-06 15:59:56 CEST; 23ms ago
                                          Process: 15558 ExecStart=/usr/sbin/asterisk -g -f -p -U asterisk (code=exited, status=1/FAILURE)
                                         Main PID: 15558 (code=exited, status=1/FAILURE)
                                        D000001: ensure_diversions: same, skipping
                                        D000040: checking dependencies of libc-bin:armhf (- <none>)
                                        D000400:     found 3
                                        D000400:     found 3
                                        D000002: fork/exec /var/lib/dpkg/info/libc-bin.postinst ( triggered ldconfig )
                                         asterisk
                                        pi@pio4gb:~ $
                                          @varg
                                          ls -l /var/lib/dpkg/info | grep -i asterisk
                                            @varg
                                            sudo mv /var/lib/dpkg/info/asterisk* /tmp
                                            Dann
                                            sudo apt update
                                            116
                                            9029
