    4. Asterisk bringt "Error while dialing (2). Error: {}"
    • V
      varg @Thomas Braun last edited by varg
      @thomas-braun said in Asterisk bringt "Error while dialing (2). Error: {}":
      sudo apt upgrade
      pi@pio4gb:~ $ sudo apt upgrade
      Reading package lists... Done
      Building dependency tree
      Calculating upgrade... Done
      The following packages were automatically installed and are no longer required:
        asterisk-config asterisk-core-sounds-en asterisk-core-sounds-en-gsm asterisk-modules asterisk-moh-opsound-gsm freetds-common libgmime-3.0-0 libgpgme11 libical3 libiksemel3 libjansson4 liblua5.1-0 libmariadb3 libneon27-gnutls libodbc1
        libpq5 libradcli4 libresample1 libsnmp-base libsnmp30 libspandsp2 libspeexdsp1 libsrtp2-1 libsybdb5 libunbound8 liburiparser1 libxslt1.1 mariadb-common mysql-common
      Use 'sudo apt autoremove' to remove them.
      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      pi@pio4gb:~ $
      trotzdem "sudo apt install asterisk" ?
        Thomas Braun Most Active @varg last edited by
        @varg
        Ja, das ist sauber. Versuch jetzt mal
        • V
          @Thomas-Braun
          pi@pio4gb:~ $ sudo apt install asterisk
          The following additional packages will be installed:
            asterisk-voicemail
          Suggested packages:
            asterisk-dahdi asterisk-dev asterisk-doc asterisk-ooh323 asterisk-opus asterisk-vpb
          The following NEW packages will be installed:
            asterisk asterisk-voicemail
          0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
          Need to get 0 B/3,127 kB of archives.
          After this operation, 7,841 kB of additional disk space will be used.
          Do you want to continue? [Y/n] Y
          Selecting previously unselected package asterisk.
          (Reading database ... 52068 files and directories currently installed.)
          Preparing to unpack .../asterisk_1%3a16.2.1~dfsg-1+deb10u2_armhf.deb ...
          Unpacking asterisk (1:16.2.1~dfsg-1+deb10u2) ...
          Selecting previously unselected package asterisk-voicemail.
          Preparing to unpack .../asterisk-voicemail_1%3a16.2.1~dfsg-1+deb10u2_armhf.deb ...
          Unpacking asterisk-voicemail (1:16.2.1~dfsg-1+deb10u2) ...
          Setting up asterisk (1:16.2.1~dfsg-1+deb10u2) ...
          Adding system user for Asterisk
          Adding user `asterisk' to group `dialout' ...
          Adding user asterisk to group dialout
          Done.
          Adding user `asterisk' to group `audio' ...
          Adding user asterisk to group audio
          Done.
          Created symlink /etc/systemd/system/multi-user.target.wants/asterisk.service → /lib/systemd/system/asterisk.service.
          Job for asterisk.service failed because the control process exited with error code.
          See "systemctl status asterisk.service" and "journalctl -xe" for details.
          invoke-rc.d: initscript asterisk, action "start" failed.
          ● asterisk.service - Asterisk PBX
             Loaded: loaded (/lib/systemd/system/asterisk.service; enabled; vendor preset: enabled)
             Active: activating (auto-restart) (Result: exit-code) since Sun 2021-06-06 15:40:40 CEST; 44ms ago
               Docs: man:asterisk(8)
            Process: 5501 ExecStart=/usr/sbin/asterisk -g -f -p -U asterisk (code=exited, status=1/FAILURE)
           Main PID: 5501 (code=exited, status=1/FAILURE)
          dpkg: error processing package asterisk (--configure):
           installed asterisk package post-installation script subprocess returned error exit status 1
          dpkg: dependency problems prevent configuration of asterisk-voicemail:
           asterisk-voicemail depends on asterisk (= 1:16.2.1~dfsg-1+deb10u2); however:
            Package asterisk is not configured yet.
          dpkg: error processing package asterisk-voicemail (--configure):
           dependency problems - leaving unconfigured
          Processing triggers for systemd (241-7~deb10u7+rpi1) ...
          Processing triggers for man-db (2.8.5-2) ...
          Processing triggers for libc-bin (2.28-10+rpi1) ...
          Errors were encountered while processing:
           asterisk
           asterisk-voicemail
          E: Sub-process /usr/bin/dpkg returned an error code (1)
          pi@pio4gb:~ $
            Thomas Braun Most Active @varg last edited by Thomas Braun
            @varg sagte in Asterisk bringt "Error while dialing (2). Error: {}":
            Komisch.
            sudo apt install -f
            sudo dpkg --configure -a
            • V
              pi@pio4gb:~ $ sudo dpkg --configure -a
                 Active: activating (auto-restart) (Result: exit-code) since Sun 2021-06-06 15:44:04 CEST; 49ms ago
                Process: 7376 ExecStart=/usr/sbin/asterisk -g -f -p -U asterisk (code=exited, status=1/FAILURE)
               Main PID: 7376 (code=exited, status=1/FAILURE)
              Jun 06 15:44:04 pio4gb systemd[1]: Failed to start Asterisk PBX.
               asterisk
               asterisk-voicemail
              pi@pio4gb:~ $
                @varg
                sudo apt install -f
                V 2 Replies Last reply Reply Quote 0
                • V
                  pi@pio4gb:~ $ sudo apt install -f
                  2 not fully installed or removed.
                  After this operation, 0 B of additional disk space will be used.
                     Active: activating (auto-restart) (Result: exit-code) since Sun 2021-06-06 15:45:02 CEST; 21ms ago
                    Process: 8065 ExecStart=/usr/sbin/asterisk -g -f -p -U asterisk (code=exited, status=1/FAILURE)
                   Main PID: 8065 (code=exited, status=1/FAILURE)
                   asterisk
                   asterisk-voicemail
                     Active: activating (auto-restart) (Result: exit-code) since Sun 2021-06-06 15:45:16 CEST; 49ms ago
                    Process: 8398 ExecStart=/usr/sbin/asterisk -g -f -p -U asterisk (code=exited, status=1/FAILURE)
                   Main PID: 8398 (code=exited, status=1/FAILURE)
                   asterisk
                   asterisk-voicemail
                  pi@pio4gb:~ $
                  • V
                    hatte ganz zuvor mit folgenden Befehlen versucht asterisk komplett zu löschen, vielleicht hats ja auch damit zu tun
                    sudo apt-get remove  asterisk
                    Following command is used to remove the asterisk package along with its dependencies:
                    sudo apt-get remove --auto-remove asterisk
                    This will remove asterisk and all its dependent packages which is no longer needed in the system.
                    Completely removing asterisk with all configuration files:
                    Following command should be used with care as it deletes all the configuration files and data:
                    sudo apt-get purge asterisk
                    or you can use following command also:
                    sudo apt-get purge --auto-remove asterisk
                    habe noch nen pi4 hier rumliegen, werde mal bei gelegenheit versuchen es da zu installieren
                      @varg
                      Hast du die alle verwendet?
                      Schau mal was das macht:
                      sudo sh -x /var/lib/dpkg/info/asterisk.postinst configure 1:16.2.1~dfsg-1+deb10u2
                      oder auch
                      sudo dpkg --configure -D 777 asterisk
                      • V
                        ja alle commands reingeprügelt
                        pi@pio4gb:~ $ sudo sh -x /var/lib/dpkg/info/asterisk.postinst configure 1:16.2.1~dfsg-1+deb10u2        + set -e
                        + getent passwd asterisk
                        + groups asterisk
                        + grep -w -q -v dialout
                        + groups asterisk
                        + grep -w -q -v audio
                        + find /var/log/asterisk /var/lib/asterisk -type d
                        + read dir
                        + dpkg-statoverride --list /var/log/asterisk
                        + chown asterisk: /var/log/asterisk
                        + read dir
                        + dpkg-statoverride --list /var/log/asterisk/cdr-custom
                        + chown asterisk: /var/log/asterisk/cdr-custom
                        + read dir
                        + dpkg-statoverride --list /var/log/asterisk/cdr-csv
                        + chown asterisk: /var/log/asterisk/cdr-csv
                        + read dir
                        + dpkg-statoverride --list /var/lib/asterisk
                        + chown asterisk: /var/lib/asterisk
                        + read dir
                        + dpkg-statoverride --list /var/lib/asterisk/moh
                        + chown asterisk: /var/lib/asterisk/moh
                        + read dir
                        + dpkg-statoverride --list /var/lib/asterisk/sounds
                        + chown asterisk: /var/lib/asterisk/sounds
                        + read dir
                        + dpkg-statoverride --list /var/lib/asterisk/sounds/custom
                        + chown asterisk: /var/lib/asterisk/sounds/custom
                        + read dir
                        + dpkg-statoverride --list /var/lib/asterisk/priv-callerintros
                        + chown asterisk: /var/lib/asterisk/priv-callerintros
                        + read dir
                        + dpkg-statoverride --list /etc/asterisk
                        + chown asterisk: /etc/asterisk
                        + find /var/spool/asterisk -type d
                        + read dir
                        + dpkg-statoverride --list /var/spool/asterisk
                        + chown asterisk: /var/spool/asterisk
                        + chmod 750 /var/spool/asterisk
                        + read dir
                        + dpkg-statoverride --list /var/spool/asterisk/monitor
                        + chown asterisk: /var/spool/asterisk/monitor
                        + chmod 750 /var/spool/asterisk/monitor
                        + read dir
                        + dpkg-statoverride --list /var/spool/asterisk/tmp
                        + chown asterisk: /var/spool/asterisk/tmp
                        + chmod 750 /var/spool/asterisk/tmp
                        + read dir
                        + dpkg-statoverride --list /var/spool/asterisk/dictate
                        + chown asterisk: /var/spool/asterisk/dictate
                        + chmod 750 /var/spool/asterisk/dictate
                        + read dir
                        + dpkg-statoverride --list /var/spool/asterisk/outgoing
                        + chown asterisk: /var/spool/asterisk/outgoing
                        + chmod 750 /var/spool/asterisk/outgoing
                        + read dir
                        + dpkg-statoverride --list /var/spool/asterisk/meetme
                        + chown asterisk: /var/spool/asterisk/meetme
                        + chmod 750 /var/spool/asterisk/meetme
                        + read dir
                        + dpkg-statoverride --list /var/spool/asterisk/voicemail
                        + chown asterisk: /var/spool/asterisk/voicemail
                        + chmod 750 /var/spool/asterisk/voicemail
                        + read dir
                        + dpkg-statoverride --list /var/spool/asterisk/system
                        + chown asterisk: /var/spool/asterisk/system
                        + chmod 750 /var/spool/asterisk/system
                        + read dir
                        + [ ! -e /usr/local/share/asterisk/sounds ]
                        + set +e
                        + dpkg-query -W -f=${Package}\t${Provides}\n
                        + sed -nr s/(.*)\tasterisk-config-custom|(asterisk-config)(\t.*)?/\1\2/p
                        + ASTERISK_CONFIG=asterisk-config
                        + dpkg-query -W -f=${Conffiles}\n asterisk-config
                        + sed -nr -e s; (/etc/asterisk/.*) [0-9a-f]*;\1;p
                        + read conffile
                        + chown asterisk: /etc/asterisk/acl.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/adsi.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/agents.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/alarmreceiver.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/alsa.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/amd.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/app_mysql.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/app_skel.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/ari.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/ast_debug_tools.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/asterisk.adsi
                        + read conffile
                        + chown asterisk: /etc/asterisk/asterisk.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/calendar.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/ccss.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/cdr.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/cdr_adaptive_odbc.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/cdr_beanstalkd.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/cdr_custom.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/cdr_manager.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/cdr_mysql.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/cdr_odbc.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/cdr_pgsql.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/cdr_sqlite3_custom.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/cdr_syslog.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/cdr_tds.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/cel.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/cel_beanstalkd.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/cel_custom.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/cel_odbc.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/cel_pgsql.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/cel_sqlite3_custom.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/cel_tds.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/chan_dahdi.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/chan_mobile.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/cli.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/cli_aliases.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/cli_permissions.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/codecs.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/confbridge.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/config_test.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/console.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/dbsep.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/dnsmgr.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/dsp.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/enum.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/extconfig.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/extensions.ael
                        + read conffile
                        + chown asterisk: /etc/asterisk/extensions.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/extensions.lua
                        + read conffile
                        + chown asterisk: /etc/asterisk/extensions_minivm.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/features.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/festival.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/followme.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/func_odbc.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/hep.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/http.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/iax.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/iaxprov.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/indications.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/logger.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/manager.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/manager.d/README.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/meetme.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/minivm.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/misdn.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/modules.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/motif.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/musiconhold.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/muted.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/ooh323.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/osp.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/oss.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/phone.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/phoneprov.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/pjproject.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/pjsip.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/pjsip_notify.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/pjsip_wizard.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/queuerules.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/queues.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/res_config_mysql.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/res_config_sqlite.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/res_config_sqlite3.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/res_corosync.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/res_curl.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/res_fax.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/res_ldap.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/res_odbc.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/res_parking.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/res_pgsql.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/res_pktccops.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/res_snmp.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/res_stun_monitor.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/resolver_unbound.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/rtp.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/say.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/sip.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/sip_notify.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/sla.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/smdi.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/sorcery.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/ss7.timers
                        + read conffile
                        + chown asterisk: /etc/asterisk/stasis.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/statsd.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/telcordia-1.adsi
                        + read conffile
                        + chown asterisk: /etc/asterisk/test_sorcery.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/udptl.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/users.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/voicemail.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/vpb.conf
                        + read conffile
                        + chown asterisk: /etc/asterisk/xmpp.conf
                        + read conffile
                        + + read STAT
                        dpkg-statoverride --quiet --list /etc/asterisk/*
                        + set -e
                        + [ configure = configure ]
                        + deb-systemd-helper unmask asterisk.service
                        /usr/bin/deb-systemd-helper was not called from dpkg. Exiting.
                        + true
                        + deb-systemd-helper --quiet was-enabled asterisk.service
                        + deb-systemd-helper update-state asterisk.service
                        + true
                        + [ -x /etc/init.d/asterisk ]
                        + update-rc.d asterisk defaults
                        + [ -n 1:16.2.1~dfsg-1+deb10u2 ]
                        + _dh_action=restart
                        + invoke-rc.d asterisk restart
                        invoke-rc.d: initscript asterisk, action "restart" failed.
                           Active: activating (auto-restart) (Result: exit-code) since Sun 2021-06-06 15:58:51 CEST; 48ms ago
                          Process: 14893 ExecStart=/usr/sbin/asterisk -g -f -p -U asterisk (code=exited, status=1/FAILURE)
                         Main PID: 14893 (code=exited, status=1/FAILURE)
                        + exit 1
                        pi@pio4gb:~ $
                        pi@pio4gb:~ $ sudo dpkg --configure -D 777 asterisk
                        D000001: ensure_diversions: new, (re)loading
                        D000001: process queue pkg asterisk:armhf queue.len 0 progress 1, try 1
                        D000040: checking dependencies of asterisk:armhf (- <none>)
                        D000400:   checking group ...
                        D000400:     checking possibility  -> adduser
                        D000400:       checking non-provided pkg adduser:all
                        D000400:       is installed, ok and found
                        D000400:     found 3
                        D000400:   found 3 matched 0 possfixbytrig -
                        D000400:     checking possibility  -> asterisk-config
                        D000400:       checking non-provided pkg asterisk-config:all
                        D000400:     found 3
                        D000400:     checking possibility  -> asterisk-core-sounds-en
                        D000400:       checking non-provided pkg asterisk-core-sounds-en:all
                        D000400:     found 3
                        D000400:     checking possibility  -> asterisk-modules
                        D000400:       checking non-provided pkg asterisk-modules:armhf
                        D000400:     found 3
                        D000400:     checking possibility  -> lsb-base
                        D000400:       checking non-provided pkg lsb-base:all
                        D000400:     found 3
                        D000400:     checking possibility  -> libc6
                        D000400:       checking non-provided pkg libc6:armhf
                        D000400:     found 3
                        D000400:     checking possibility  -> libcap2
                        D000400:       checking non-provided pkg libcap2:armhf
                        D000400:     found 3
                        D000400:     checking possibility  -> libedit2
                        D000400:       checking non-provided pkg libedit2:armhf
                        D000400:     found 3
                        D000400:     checking possibility  -> libgcc1
                        D000400:       checking non-provided pkg libgcc1:armhf
                        D000400:     found 3
                        D000400:     checking possibility  -> libjansson4
                        D000400:       checking non-provided pkg libjansson4:armhf
                        D000400:     found 3
                        D000400:     checking possibility  -> libpopt0
                        D000400:       checking non-provided pkg libpopt0:armhf
                        D000400:     found 3
                        D000400:     checking possibility  -> libsqlite3-0
                        D000400:       checking non-provided pkg libsqlite3-0:armhf
                        D000400:     found 3
                        D000400:     checking possibility  -> libssl1.1
                        D000400:       checking non-provided pkg libssl1.1:armhf
                        D000400:     found 3
                        D000400:     checking possibility  -> libsystemd0
                        D000400:       checking non-provided pkg libsystemd0:armhf
                        D000400:     found 3
                        D000400:     checking possibility  -> liburiparser1
                        D000400:       checking non-provided pkg liburiparser1:armhf
                        D000400:     found 3
                        D000400:     checking possibility  -> libuuid1
                        D000400:       checking non-provided pkg libuuid1:armhf
                        D000400:     found 3
                        D000400:     checking possibility  -> libxml2
                        D000400:       checking non-provided pkg libxml2:armhf
                        D000400:     found 3
                        D000400:     checking possibility  -> libxslt1.1
                        D000400:       checking non-provided pkg libxslt1.1:armhf
                        D000400:     found 3
                        D000040: ok 2 msgs >><<
                        D000040:     checking Breaks
                        D000400:      checking virtbroken asterisk-1fb7f5c06d7a2052e38d021b3d8ca151
                        D000002: fork/exec /var/lib/dpkg/info/asterisk.postinst ( configure  )
                           Active: activating (auto-restart) (Result: exit-code) since Sun 2021-06-06 15:59:56 CEST; 23ms ago
                          Process: 15558 ExecStart=/usr/sbin/asterisk -g -f -p -U asterisk (code=exited, status=1/FAILURE)
                         Main PID: 15558 (code=exited, status=1/FAILURE)
                        D000001: ensure_diversions: same, skipping
                        D000040: checking dependencies of libc-bin:armhf (- <none>)
                        D000400:     found 3
                        D000400:     found 3
                        D000002: fork/exec /var/lib/dpkg/info/libc-bin.postinst ( triggered ldconfig )
                         asterisk
                        pi@pio4gb:~ $
                          @varg
                          ls -l /var/lib/dpkg/info | grep -i asterisk
                            @varg
                            sudo mv /var/lib/dpkg/info/asterisk* /tmp
                            Dann
                            sudo apt update
                            • V
                              pi@pio4gb:~ $ ls -l /var/lib/dpkg/info | grep -i asterisk
                              -rw-r--r-- 1 root root      69 Aug 27  2020 asterisk.conffiles
                              -rw-r--r-- 1 root root    3137 Aug 27  2020 asterisk-config.conffiles
                              -rw-r--r-- 1 root root   13720 Jun  6 15:22 asterisk-config.list
                              -rw-r--r-- 1 root root   14680 Aug 27  2020 asterisk-config.md5sums
                              -rwxr-xr-x 1 root root    1325 Aug 27  2020 asterisk-config.postinst
                              -rwxr-xr-x 1 root root    1409 Aug 27  2020 asterisk-config.preinst
                              -rw-r--r-- 1 root root   35380 Jun  6 15:22 asterisk-core-sounds-en-gsm.list
                              -rw-r--r-- 1 root root   53716 Dec 20  2018 asterisk-core-sounds-en-gsm.md5sums
                              -rwxr-xr-x 1 root root     352 Dec 20  2018 asterisk-core-sounds-en-gsm.preinst
                              -rw-r--r-- 1 root root     347 Jun  6 15:22 asterisk-core-sounds-en.list
                              -rw-r--r-- 1 root root     439 Dec 20  2018 asterisk-core-sounds-en.md5sums
                              -rwxr-xr-x 1 root root    1050 Dec 20  2018 asterisk-core-sounds-en.postinst
                              -rwxr-xr-x 1 root root     245 Dec 20  2018 asterisk-core-sounds-en.prerm
                              -rw-r--r-- 1 root root   10731 Jun  6 15:40 asterisk.list
                              -rw-r--r-- 1 root root   15583 Aug 27  2020 asterisk.md5sums
                              -rw-r--r-- 1 root root   14460 Jun  6 15:22 asterisk-modules.list
                              -rw-r--r-- 1 root root   24919 Aug 27  2020 asterisk-modules.md5sums
                              -rw-r--r-- 1 root root     480 Jun  6 15:22 asterisk-moh-opsound-gsm.list
                              -rw-r--r-- 1 root root     593 Jun 28  2010 asterisk-moh-opsound-gsm.md5sums
                              -rwxr-xr-x 1 root root    4642 Aug 27  2020 asterisk.postinst
                              -rwxr-xr-x 1 root root     731 Aug 27  2020 asterisk.postrm
                              -rwxr-xr-x 1 root root     321 Aug 27  2020 asterisk.prerm
                              -rw-r--r-- 1 root root      25 Aug 27  2020 asterisk.shlibs
                              -rw-r--r-- 1 root root      67 Aug 27  2020 asterisk.triggers
                              -rw-r--r-- 1 root root     358 Jun  6 15:40 asterisk-voicemail.list
                              -rw-r--r-- 1 root root     402 Aug 27  2020 asterisk-voicemail.md5sums
                              pi@pio4gb:~ $
                              pi@pio4gb:~ $ sudo mv /var/lib/dpkg/info/asterisk* /tmp
                              pi@pio4gb:~ $
                              pi@pio4gb:~ $ sudo apt update
                              Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                              Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                              Hit:3 https://deb.nodesource.com/node_12.x buster InRelease
                              All packages are up to date.
                              asterisk is already the newest version (1:16.2.1~dfsg-1+deb10u2).
                              Setting up asterisk-voicemail (1:16.2.1~dfsg-1+deb10u2) ...
                              Installationsverzeichnis /etc/asterisk/ scheint immernoch tot
                                @varg
                                Mehr nicht?
                                Da sollte eigentlich mehr kommen.
                                Bitte ggf. auch das login prompt posten, dann kann man sehen ob alles durch ist.
                                • V
                                  habe alles was putty hergibt kopiert, mehr war hier nicht zu sehen.
                                  ...und vielen Dank für Deine Unterstützung
                                  • V
                                    varg @varg last edited by varg
                                    @varg
                                    habe mal aus neugier auf einem anderen gerät iobroker komplett neu aufgesetzt und asterisk installiert:
                                    das Problem bleibt bestehen:
                                    @Thomas-Braun die installationsroutine verlief auf dem neuen system fehlerfrei
                                    asterisk.0	2021-06-06 22:47:53.763	error	(1084) Error while Converting File: {}
                                    asterisk.0	2021-06-06 22:47:53.229	silly	(1084) States user redis pmessage asterisk.0.*/asterisk.0.dialin.callerid:{"val":"","ack":true,"ts":1623012473225,"q":0,"from":"system.adapter.asterisk.0","user":"system.user.admin","lc":1623012039437
                                    asterisk.0	2021-06-06 22:47:53.223	silly	(1084) States user redis pmessage asterisk.0.*/asterisk.0.dialin.dtmf:{"val":"","ack":true,"ts":1623012473173,"q":0,"from":"system.adapter.asterisk.0","user":"system.user.admin","lc":1623012039466}
                                    asterisk.0	2021-06-06 22:47:53.164	info	(1084) Connected to Asterisk Manager
                                    asterisk.0	2021-06-06 22:47:53.154	info	(1084) Starting Adapter asterisk.0 in version 1.0.6 with transcoder ffmpeg and language DE
                                    asterisk.0	2021-06-06 22:47:53.142	silly	(1084) States system redis pmessage system.adapter.asterisk.0.logLevel/system.adapter.asterisk.0.logLevel:{"val":"silly","ack":true,"ts":1623012473124,"q":0,"from":"system.adapter.asterisk.0","lc":162
                                    asterisk.0	2021-06-06 22:47:53.092	info	(1084) starting. Version 1.0.6 in /opt/iobroker/node_modules/iobroker.asterisk, node: v14.17.0, js-controller: 3.2.16
                                    host.piholeblack	2021-06-06 22:47:51.619	info	instance system.adapter.asterisk.0 started with pid 1084
                                    host.piholeblack	2021-06-06 22:47:49.157	info	instance system.adapter.asterisk.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    asterisk.0	2021-06-06 22:47:48.587	info	(1067) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    asterisk.0	2021-06-06 22:47:48.585	info	(1067) terminating
                                    asterisk.0	2021-06-06 22:47:48.582	info	(1067) Closing Asterisk Adapter
                                    host.piholeblack	2021-06-06 22:47:48.582	info	stopInstance system.adapter.asterisk.0 send kill signal
                                      TemPeck last edited by
                                      Bin eben auf den Thread gestoßen und hab auch gleich mal nen Testanruf angestoßen - gleicher Fehler.
                                      Kann jetzt natürlich nicht sagen seit wann. Ich erhalte die Anrufe nur bei Auslösung der Rauchmelder oder bei Einbruchmeldung - also nicht alle Tage.
                                      Sicher dass es nicht an der Node-Version liegt? Ich wüsste sonst auch nicht, was ich noch so verändert hätte...
                                      Ich schaue nächste Woche sonst mal ob ich noch ein ganz altes Backup finde...
                                      • V
                                        varg @TemPeck last edited by
                                        @tempeck
                                        habe den Fehler auf node 12 und 14
                                          boeskij last edited by
                                          ich vermute Google hat etwas an der verwendeten Text-To-Speech API verändert, sodass nur noch eine bestimmte Anzahl Wandlungen in einem Zeitraum möglich sind (wenn überhaupt noch)...
                                          Ich habe es jetzt so gelöst, dass im Skript "umzu" mit lokalem PicoTTS wav-Dateien erzeugt und mit sox zur gsm konvertiert werden.
                                          Problem ist, dass beim Starten des Adapters der Dial-In-Text an Google geschickt wird und natürlich nicht gewandelt wird...
                                          Als Konsequenz daraus startet dann der Adapter nicht korrekt (kein DTMF mehr möglich)
                                          Um dies quick and dirty zu beheben habe ich in der asterisk.js die Zeilen 757 und 788 auskommentiert...
                                          Der Teil dazwischen wurde sonst nicht ausgeführt...
                                          757:	/* convertDialInFile(parameter, () => { */
                                          788:	/* }); */
                                          Wäre natürlich toll, wenn jemand den Adapter so umbauen könnte, dass eine andere TTS-Engine genutzt wird...
                                          bahnuhr Z 3 Replies Last reply Reply Quote 0
                                          • bahnuhr
                                            bahnuhr Forum Testing Most Active @boeskij last edited by
                                            @boeskij sagte in Asterisk bringt "Error while dialing (2). Error: {}":
                                            Könntest du dies mal näher erläutern.
                                            116
                                            11029
