    4. Asterisk bringt "Error while dialing (2). Error: {}"
      Thomas Braun Most Active @varg last edited by Thomas Braun
      @varg sagte in Asterisk bringt "Error while dialing (2). Error: {}":
      Komisch.
      sudo apt install -f
      sudo dpkg --configure -a
      • V
        varg @Thomas Braun last edited by
        @thomas-braun said in Asterisk bringt "Error while dialing (2). Error: {}":
        pi@pio4gb:~ $ sudo dpkg --configure -a
        Setting up asterisk (1:16.2.1~dfsg-1+deb10u2) ...
        Job for asterisk.service failed because the control process exited with error code.
        See "systemctl status asterisk.service" and "journalctl -xe" for details.
        invoke-rc.d: initscript asterisk, action "start" failed.
        ● asterisk.service - Asterisk PBX
           Loaded: loaded (/lib/systemd/system/asterisk.service; enabled; vendor preset: enabled)
           Active: activating (auto-restart) (Result: exit-code) since Sun 2021-06-06 15:44:04 CEST; 49ms ago
             Docs: man:asterisk(8)
          Process: 7376 ExecStart=/usr/sbin/asterisk -g -f -p -U asterisk (code=exited, status=1/FAILURE)
         Main PID: 7376 (code=exited, status=1/FAILURE)
        Jun 06 15:44:04 pio4gb systemd[1]: Failed to start Asterisk PBX.
        dpkg: error processing package asterisk (--configure):
         installed asterisk package post-installation script subprocess returned error exit status 1
        dpkg: dependency problems prevent configuration of asterisk-voicemail:
         asterisk-voicemail depends on asterisk (= 1:16.2.1~dfsg-1+deb10u2); however:
          Package asterisk is not configured yet.
        dpkg: error processing package asterisk-voicemail (--configure):
         dependency problems - leaving unconfigured
        Processing triggers for libc-bin (2.28-10+rpi1) ...
        Errors were encountered while processing:
         asterisk
         asterisk-voicemail
        pi@pio4gb:~ $
          @varg
          sudo apt install -f
          V 2 Replies Last reply Reply Quote 0
          • V
            pi@pio4gb:~ $ sudo apt install -f
            Reading package lists... Done
            Building dependency tree
            0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
            2 not fully installed or removed.
            After this operation, 0 B of additional disk space will be used.
               Active: activating (auto-restart) (Result: exit-code) since Sun 2021-06-06 15:45:02 CEST; 21ms ago
              Process: 8065 ExecStart=/usr/sbin/asterisk -g -f -p -U asterisk (code=exited, status=1/FAILURE)
             Main PID: 8065 (code=exited, status=1/FAILURE)
             asterisk
             asterisk-voicemail
            E: Sub-process /usr/bin/dpkg returned an error code (1)
               Active: activating (auto-restart) (Result: exit-code) since Sun 2021-06-06 15:45:16 CEST; 49ms ago
              Process: 8398 ExecStart=/usr/sbin/asterisk -g -f -p -U asterisk (code=exited, status=1/FAILURE)
             Main PID: 8398 (code=exited, status=1/FAILURE)
             asterisk
             asterisk-voicemail
            pi@pio4gb:~ $
            • V
              varg @Thomas Braun last edited by varg
              hatte ganz zuvor mit folgenden Befehlen versucht asterisk komplett zu löschen, vielleicht hats ja auch damit zu tun
              sudo apt-get remove  asterisk
              Following command is used to remove the asterisk package along with its dependencies:
              sudo apt-get remove --auto-remove asterisk
              This will remove asterisk and all its dependent packages which is no longer needed in the system.
              Completely removing asterisk with all configuration files:
              Following command should be used with care as it deletes all the configuration files and data:
              sudo apt-get purge asterisk
              or you can use following command also:
              sudo apt-get purge --auto-remove asterisk
              habe noch nen pi4 hier rumliegen, werde mal bei gelegenheit versuchen es da zu installieren
                @varg
                Hast du die alle verwendet?
                Schau mal was das macht:
                sudo sh -x /var/lib/dpkg/info/asterisk.postinst configure 1:16.2.1~dfsg-1+deb10u2
                oder auch
                sudo dpkg --configure -D 777 asterisk
                • V
                  ja alle commands reingeprügelt
                  pi@pio4gb:~ $ sudo sh -x /var/lib/dpkg/info/asterisk.postinst configure 1:16.2.1~dfsg-1+deb10u2        + set -e
                  + getent passwd asterisk
                  + groups asterisk
                  + grep -w -q -v dialout
                  + groups asterisk
                  + grep -w -q -v audio
                  + find /var/log/asterisk /var/lib/asterisk -type d
                  + read dir
                  + dpkg-statoverride --list /var/log/asterisk
                  + chown asterisk: /var/log/asterisk
                  + read dir
                  + dpkg-statoverride --list /var/log/asterisk/cdr-custom
                  + chown asterisk: /var/log/asterisk/cdr-custom
                  + read dir
                  + dpkg-statoverride --list /var/log/asterisk/cdr-csv
                  + chown asterisk: /var/log/asterisk/cdr-csv
                  + read dir
                  + dpkg-statoverride --list /var/lib/asterisk
                  + chown asterisk: /var/lib/asterisk
                  + read dir
                  + dpkg-statoverride --list /var/lib/asterisk/moh
                  + chown asterisk: /var/lib/asterisk/moh
                  + read dir
                  + dpkg-statoverride --list /var/lib/asterisk/sounds
                  + chown asterisk: /var/lib/asterisk/sounds
                  + read dir
                  + dpkg-statoverride --list /var/lib/asterisk/sounds/custom
                  + chown asterisk: /var/lib/asterisk/sounds/custom
                  + read dir
                  + dpkg-statoverride --list /var/lib/asterisk/priv-callerintros
                  + chown asterisk: /var/lib/asterisk/priv-callerintros
                  + read dir
                  + dpkg-statoverride --list /etc/asterisk
                  + chown asterisk: /etc/asterisk
                  + find /var/spool/asterisk -type d
                  + read dir
                  + dpkg-statoverride --list /var/spool/asterisk
                  + chown asterisk: /var/spool/asterisk
                  + chmod 750 /var/spool/asterisk
                  + read dir
                  + dpkg-statoverride --list /var/spool/asterisk/monitor
                  + chown asterisk: /var/spool/asterisk/monitor
                  + chmod 750 /var/spool/asterisk/monitor
                  + read dir
                  + dpkg-statoverride --list /var/spool/asterisk/tmp
                  + chown asterisk: /var/spool/asterisk/tmp
                  + chmod 750 /var/spool/asterisk/tmp
                  + read dir
                  + dpkg-statoverride --list /var/spool/asterisk/dictate
                  + chown asterisk: /var/spool/asterisk/dictate
                  + chmod 750 /var/spool/asterisk/dictate
                  + read dir
                  + dpkg-statoverride --list /var/spool/asterisk/outgoing
                  + chown asterisk: /var/spool/asterisk/outgoing
                  + chmod 750 /var/spool/asterisk/outgoing
                  + read dir
                  + dpkg-statoverride --list /var/spool/asterisk/meetme
                  + chown asterisk: /var/spool/asterisk/meetme
                  + chmod 750 /var/spool/asterisk/meetme
                  + read dir
                  + dpkg-statoverride --list /var/spool/asterisk/voicemail
                  + chown asterisk: /var/spool/asterisk/voicemail
                  + chmod 750 /var/spool/asterisk/voicemail
                  + read dir
                  + dpkg-statoverride --list /var/spool/asterisk/system
                  + chown asterisk: /var/spool/asterisk/system
                  + chmod 750 /var/spool/asterisk/system
                  + read dir
                  + [ ! -e /usr/local/share/asterisk/sounds ]
                  + set +e
                  + dpkg-query -W -f=${Package}\t${Provides}\n
                  + sed -nr s/(.*)\tasterisk-config-custom|(asterisk-config)(\t.*)?/\1\2/p
                  + ASTERISK_CONFIG=asterisk-config
                  + dpkg-query -W -f=${Conffiles}\n asterisk-config
                  + sed -nr -e s; (/etc/asterisk/.*) [0-9a-f]*;\1;p
                  + read conffile
                  + chown asterisk: /etc/asterisk/acl.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/adsi.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/agents.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/alarmreceiver.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/alsa.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/amd.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/app_mysql.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/app_skel.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/ari.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/ast_debug_tools.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/asterisk.adsi
                  + read conffile
                  + chown asterisk: /etc/asterisk/asterisk.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/calendar.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/ccss.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/cdr.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/cdr_adaptive_odbc.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/cdr_beanstalkd.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/cdr_custom.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/cdr_manager.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/cdr_mysql.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/cdr_odbc.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/cdr_pgsql.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/cdr_sqlite3_custom.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/cdr_syslog.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/cdr_tds.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/cel.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/cel_beanstalkd.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/cel_custom.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/cel_odbc.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/cel_pgsql.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/cel_sqlite3_custom.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/cel_tds.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/chan_dahdi.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/chan_mobile.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/cli.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/cli_aliases.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/cli_permissions.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/codecs.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/confbridge.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/config_test.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/console.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/dbsep.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/dnsmgr.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/dsp.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/enum.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/extconfig.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/extensions.ael
                  + read conffile
                  + chown asterisk: /etc/asterisk/extensions.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/extensions.lua
                  + read conffile
                  + chown asterisk: /etc/asterisk/extensions_minivm.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/features.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/festival.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/followme.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/func_odbc.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/hep.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/http.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/iax.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/iaxprov.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/indications.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/logger.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/manager.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/manager.d/README.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/meetme.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/minivm.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/misdn.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/modules.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/motif.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/musiconhold.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/muted.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/ooh323.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/osp.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/oss.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/phone.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/phoneprov.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/pjproject.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/pjsip.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/pjsip_notify.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/pjsip_wizard.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/queuerules.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/queues.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/res_config_mysql.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/res_config_sqlite.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/res_config_sqlite3.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/res_corosync.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/res_curl.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/res_fax.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/res_ldap.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/res_odbc.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/res_parking.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/res_pgsql.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/res_pktccops.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/res_snmp.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/res_stun_monitor.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/resolver_unbound.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/rtp.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/say.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/sip.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/sip_notify.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/sla.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/smdi.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/sorcery.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/ss7.timers
                  + read conffile
                  + chown asterisk: /etc/asterisk/stasis.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/statsd.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/telcordia-1.adsi
                  + read conffile
                  + chown asterisk: /etc/asterisk/test_sorcery.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/udptl.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/users.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/voicemail.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/vpb.conf
                  + read conffile
                  + chown asterisk: /etc/asterisk/xmpp.conf
                  + read conffile
                  + + read STAT
                  dpkg-statoverride --quiet --list /etc/asterisk/*
                  + set -e
                  + [ configure = configure ]
                  + deb-systemd-helper unmask asterisk.service
                  /usr/bin/deb-systemd-helper was not called from dpkg. Exiting.
                  + true
                  + deb-systemd-helper --quiet was-enabled asterisk.service
                  + deb-systemd-helper update-state asterisk.service
                  + true
                  + [ -x /etc/init.d/asterisk ]
                  + update-rc.d asterisk defaults
                  + [ -n 1:16.2.1~dfsg-1+deb10u2 ]
                  + _dh_action=restart
                  + invoke-rc.d asterisk restart
                  invoke-rc.d: initscript asterisk, action "restart" failed.
                     Active: activating (auto-restart) (Result: exit-code) since Sun 2021-06-06 15:58:51 CEST; 48ms ago
                    Process: 14893 ExecStart=/usr/sbin/asterisk -g -f -p -U asterisk (code=exited, status=1/FAILURE)
                   Main PID: 14893 (code=exited, status=1/FAILURE)
                  + exit 1
                  pi@pio4gb:~ $
                  pi@pio4gb:~ $ sudo dpkg --configure -D 777 asterisk
                  D000001: ensure_diversions: new, (re)loading
                  D000001: process queue pkg asterisk:armhf queue.len 0 progress 1, try 1
                  D000040: checking dependencies of asterisk:armhf (- <none>)
                  D000400:   checking group ...
                  D000400:     checking possibility  -> adduser
                  D000400:       checking non-provided pkg adduser:all
                  D000400:       is installed, ok and found
                  D000400:     found 3
                  D000400:   found 3 matched 0 possfixbytrig -
                  D000400:     checking possibility  -> asterisk-config
                  D000400:       checking non-provided pkg asterisk-config:all
                  D000400:     found 3
                  D000400:     checking possibility  -> asterisk-core-sounds-en
                  D000400:       checking non-provided pkg asterisk-core-sounds-en:all
                  D000400:     found 3
                  D000400:     checking possibility  -> asterisk-modules
                  D000400:       checking non-provided pkg asterisk-modules:armhf
                  D000400:     found 3
                  D000400:     checking possibility  -> lsb-base
                  D000400:       checking non-provided pkg lsb-base:all
                  D000400:     found 3
                  D000400:     checking possibility  -> libc6
                  D000400:       checking non-provided pkg libc6:armhf
                  D000400:     found 3
                  D000400:     checking possibility  -> libcap2
                  D000400:       checking non-provided pkg libcap2:armhf
                  D000400:     found 3
                  D000400:     checking possibility  -> libedit2
                  D000400:       checking non-provided pkg libedit2:armhf
                  D000400:     found 3
                  D000400:     checking possibility  -> libgcc1
                  D000400:       checking non-provided pkg libgcc1:armhf
                  D000400:     found 3
                  D000400:     checking possibility  -> libjansson4
                  D000400:       checking non-provided pkg libjansson4:armhf
                  D000400:     found 3
                  D000400:     checking possibility  -> libpopt0
                  D000400:       checking non-provided pkg libpopt0:armhf
                  D000400:     found 3
                  D000400:     checking possibility  -> libsqlite3-0
                  D000400:       checking non-provided pkg libsqlite3-0:armhf
                  D000400:     found 3
                  D000400:     checking possibility  -> libssl1.1
                  D000400:       checking non-provided pkg libssl1.1:armhf
                  D000400:     found 3
                  D000400:     checking possibility  -> libsystemd0
                  D000400:       checking non-provided pkg libsystemd0:armhf
                  D000400:     found 3
                  D000400:     checking possibility  -> liburiparser1
                  D000400:       checking non-provided pkg liburiparser1:armhf
                  D000400:     found 3
                  D000400:     checking possibility  -> libuuid1
                  D000400:       checking non-provided pkg libuuid1:armhf
                  D000400:     found 3
                  D000400:     checking possibility  -> libxml2
                  D000400:       checking non-provided pkg libxml2:armhf
                  D000400:     found 3
                  D000400:     checking possibility  -> libxslt1.1
                  D000400:       checking non-provided pkg libxslt1.1:armhf
                  D000400:     found 3
                  D000040: ok 2 msgs >><<
                  D000040:     checking Breaks
                  D000400:      checking virtbroken asterisk-1fb7f5c06d7a2052e38d021b3d8ca151
                  D000002: fork/exec /var/lib/dpkg/info/asterisk.postinst ( configure  )
                     Active: activating (auto-restart) (Result: exit-code) since Sun 2021-06-06 15:59:56 CEST; 23ms ago
                    Process: 15558 ExecStart=/usr/sbin/asterisk -g -f -p -U asterisk (code=exited, status=1/FAILURE)
                   Main PID: 15558 (code=exited, status=1/FAILURE)
                  D000001: ensure_diversions: same, skipping
                  D000040: checking dependencies of libc-bin:armhf (- <none>)
                  D000400:     found 3
                  D000400:     found 3
                  D000002: fork/exec /var/lib/dpkg/info/libc-bin.postinst ( triggered ldconfig )
                   asterisk
                  pi@pio4gb:~ $
                    @varg
                    ls -l /var/lib/dpkg/info | grep -i asterisk
                      @varg
                      sudo mv /var/lib/dpkg/info/asterisk* /tmp
                      Dann
                      sudo apt update
                      sudo apt install asterisk
                      • V
                        pi@pio4gb:~ $ ls -l /var/lib/dpkg/info | grep -i asterisk
                        -rw-r--r-- 1 root root      69 Aug 27  2020 asterisk.conffiles
                        -rw-r--r-- 1 root root    3137 Aug 27  2020 asterisk-config.conffiles
                        -rw-r--r-- 1 root root   13720 Jun  6 15:22 asterisk-config.list
                        -rw-r--r-- 1 root root   14680 Aug 27  2020 asterisk-config.md5sums
                        -rwxr-xr-x 1 root root    1325 Aug 27  2020 asterisk-config.postinst
                        -rwxr-xr-x 1 root root    1409 Aug 27  2020 asterisk-config.preinst
                        -rw-r--r-- 1 root root   35380 Jun  6 15:22 asterisk-core-sounds-en-gsm.list
                        -rw-r--r-- 1 root root   53716 Dec 20  2018 asterisk-core-sounds-en-gsm.md5sums
                        -rwxr-xr-x 1 root root     352 Dec 20  2018 asterisk-core-sounds-en-gsm.preinst
                        -rw-r--r-- 1 root root     347 Jun  6 15:22 asterisk-core-sounds-en.list
                        -rw-r--r-- 1 root root     439 Dec 20  2018 asterisk-core-sounds-en.md5sums
                        -rwxr-xr-x 1 root root    1050 Dec 20  2018 asterisk-core-sounds-en.postinst
                        -rwxr-xr-x 1 root root     245 Dec 20  2018 asterisk-core-sounds-en.prerm
                        -rw-r--r-- 1 root root   10731 Jun  6 15:40 asterisk.list
                        -rw-r--r-- 1 root root   15583 Aug 27  2020 asterisk.md5sums
                        -rw-r--r-- 1 root root   14460 Jun  6 15:22 asterisk-modules.list
                        -rw-r--r-- 1 root root   24919 Aug 27  2020 asterisk-modules.md5sums
                        -rw-r--r-- 1 root root     480 Jun  6 15:22 asterisk-moh-opsound-gsm.list
                        -rw-r--r-- 1 root root     593 Jun 28  2010 asterisk-moh-opsound-gsm.md5sums
                        -rwxr-xr-x 1 root root    4642 Aug 27  2020 asterisk.postinst
                        -rwxr-xr-x 1 root root     731 Aug 27  2020 asterisk.postrm
                        -rwxr-xr-x 1 root root     321 Aug 27  2020 asterisk.prerm
                        -rw-r--r-- 1 root root      25 Aug 27  2020 asterisk.shlibs
                        -rw-r--r-- 1 root root      67 Aug 27  2020 asterisk.triggers
                        -rw-r--r-- 1 root root     358 Jun  6 15:40 asterisk-voicemail.list
                        -rw-r--r-- 1 root root     402 Aug 27  2020 asterisk-voicemail.md5sums
                        pi@pio4gb:~ $
                        pi@pio4gb:~ $ sudo mv /var/lib/dpkg/info/asterisk* /tmp
                        pi@pio4gb:~ $
                        pi@pio4gb:~ $ sudo apt update
                        Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                        Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                        Hit:3 https://deb.nodesource.com/node_12.x buster InRelease
                        All packages are up to date.
                        pi@pio4gb:~ $ sudo apt install asterisk
                        asterisk is already the newest version (1:16.2.1~dfsg-1+deb10u2).
                        Do you want to continue? [Y/n] Y
                        Setting up asterisk-voicemail (1:16.2.1~dfsg-1+deb10u2) ...
                        Installationsverzeichnis /etc/asterisk/ scheint immernoch tot
                          @varg
                          Mehr nicht?
                          Da sollte eigentlich mehr kommen.
                          Bitte ggf. auch das login prompt posten, dann kann man sehen ob alles durch ist.
                          • V
                            habe alles was putty hergibt kopiert, mehr war hier nicht zu sehen.
                            ...und vielen Dank für Deine Unterstützung
                            • V
                              varg @varg last edited by varg
                              @varg
                              habe mal aus neugier auf einem anderen gerät iobroker komplett neu aufgesetzt und asterisk installiert:
                              das Problem bleibt bestehen:
                              @Thomas-Braun die installationsroutine verlief auf dem neuen system fehlerfrei
                              asterisk.0	2021-06-06 22:47:53.763	error	(1084) Error while Converting File: {}
                              asterisk.0	2021-06-06 22:47:53.229	silly	(1084) States user redis pmessage asterisk.0.*/asterisk.0.dialin.callerid:{"val":"","ack":true,"ts":1623012473225,"q":0,"from":"system.adapter.asterisk.0","user":"system.user.admin","lc":1623012039437
                              asterisk.0	2021-06-06 22:47:53.223	silly	(1084) States user redis pmessage asterisk.0.*/asterisk.0.dialin.dtmf:{"val":"","ack":true,"ts":1623012473173,"q":0,"from":"system.adapter.asterisk.0","user":"system.user.admin","lc":1623012039466}
                              asterisk.0	2021-06-06 22:47:53.164	info	(1084) Connected to Asterisk Manager
                              asterisk.0	2021-06-06 22:47:53.154	info	(1084) Starting Adapter asterisk.0 in version 1.0.6 with transcoder ffmpeg and language DE
                              asterisk.0	2021-06-06 22:47:53.142	silly	(1084) States system redis pmessage system.adapter.asterisk.0.logLevel/system.adapter.asterisk.0.logLevel:{"val":"silly","ack":true,"ts":1623012473124,"q":0,"from":"system.adapter.asterisk.0","lc":162
                              asterisk.0	2021-06-06 22:47:53.092	info	(1084) starting. Version 1.0.6 in /opt/iobroker/node_modules/iobroker.asterisk, node: v14.17.0, js-controller: 3.2.16
                              host.piholeblack	2021-06-06 22:47:51.619	info	instance system.adapter.asterisk.0 started with pid 1084
                              host.piholeblack	2021-06-06 22:47:49.157	info	instance system.adapter.asterisk.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              asterisk.0	2021-06-06 22:47:48.587	info	(1067) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              asterisk.0	2021-06-06 22:47:48.585	info	(1067) terminating
                              asterisk.0	2021-06-06 22:47:48.582	info	(1067) Closing Asterisk Adapter
                              host.piholeblack	2021-06-06 22:47:48.582	info	stopInstance system.adapter.asterisk.0 send kill signal
                                TemPeck last edited by
                                Bin eben auf den Thread gestoßen und hab auch gleich mal nen Testanruf angestoßen - gleicher Fehler.
                                Kann jetzt natürlich nicht sagen seit wann. Ich erhalte die Anrufe nur bei Auslösung der Rauchmelder oder bei Einbruchmeldung - also nicht alle Tage.
                                Sicher dass es nicht an der Node-Version liegt? Ich wüsste sonst auch nicht, was ich noch so verändert hätte...
                                Ich schaue nächste Woche sonst mal ob ich noch ein ganz altes Backup finde...
                                • V
                                  varg @TemPeck last edited by
                                  @tempeck
                                  habe den Fehler auf node 12 und 14
                                    boeskij last edited by
                                    ich vermute Google hat etwas an der verwendeten Text-To-Speech API verändert, sodass nur noch eine bestimmte Anzahl Wandlungen in einem Zeitraum möglich sind (wenn überhaupt noch)...
                                    Ich habe es jetzt so gelöst, dass im Skript "umzu" mit lokalem PicoTTS wav-Dateien erzeugt und mit sox zur gsm konvertiert werden.
                                    Problem ist, dass beim Starten des Adapters der Dial-In-Text an Google geschickt wird und natürlich nicht gewandelt wird...
                                    Als Konsequenz daraus startet dann der Adapter nicht korrekt (kein DTMF mehr möglich)
                                    Um dies quick and dirty zu beheben habe ich in der asterisk.js die Zeilen 757 und 788 auskommentiert...
                                    Der Teil dazwischen wurde sonst nicht ausgeführt...
                                    757:	/* convertDialInFile(parameter, () => { */
                                    788:	/* }); */
                                    Wäre natürlich toll, wenn jemand den Adapter so umbauen könnte, dass eine andere TTS-Engine genutzt wird...
                                    bahnuhr Z 3 Replies Last reply Reply Quote 0
                                    • bahnuhr
                                      bahnuhr Forum Testing Most Active @boeskij last edited by
                                      @boeskij sagte in Asterisk bringt "Error while dialing (2). Error: {}":
                                      Könntest du dies mal näher erläutern.
                                        boeskij @bahnuhr last edited by boeskij
                                        @bahnuhr
                                        Hoffe das hier hilft:
                                        let msg = "Dieser Text wird vorgelesen."
                                        exec('pico2wave -w /tmp/ttsdatei.wav -l de-DE "' + msg + '"', function (error, stdout, stderr) {
        /* wav erstellt */
        exec('sox /tmp/ttsdatei.wav -r 8000 -c 1 /tmp/ttsdatei.gsm', function (error, stdout, stderr) {
        /* gsm erstellt */
        exec('rm /tmp/ttsdatei.wav', function (error, stdout, stderr) {
        /* wav gelöscht, sonst wurde beim folgenden Anruf ggf. die falsche Datei aufgerufen... */
        sendTo('asterisk.0', "dial", { telnr: callNumber, callerid: callerId, audiofile: '/tmp/ttsdatei.gsm'},  (res) => {
        console.log('Result: ' + JSON.stringify(res));
        exec('cp /tmp/ttsdatei.gsm /tmp/asterisk_dtmf.gsm', function (error, stdout, stderr) {
        /* Die asterisk_dtmf.gsm wird für Dial-In Anrufe verwendet... Hier wird dann einfach der letzte Anruf nochmal wiedergegeben */
        /* Das folgende Löschen führte bei mir zu Problemen, also bleibt die Datei liegen.. wird ja eh überschrieben */
        /* exec('rm /tmp/ttsdatei.gsm', function (error, stdout, stderr) { console.log('Telefonalamierung: gsm gelöscht'); }); */
                                        bahnuhr stek 2 Replies Last reply Reply Quote 0
                                        • bahnuhr
                                          pico2wave
                                          Kenn ich bisher nicht.
                                          Muss man dies installieren?
                                            @bahnuhr
                                            ja, wird auch im sayit-Adapter verwendet:
                                            PicoTTS (linux only): English, German, Italian, Spanish, French For PicoTTS it is necessary to install the following packages: libttspico-utils and lame. Installation command: 'sudo apt-get install libttspico-utils lame'
                                            bahnuhr 2 Replies Last reply Reply Quote 0
                                            116
                                            11029
