    4. PH-Messung
    PH-Messung
      apollon77 last edited by
      Ok, dann bitte nochmal von GitHub aktualisieren, jetzt sollte auch das Format von @skinni verarbeitet werden ... bitte nochmal Ausgabe posten
      S coyote 2 Replies Last reply Reply Quote 0
        skinni @apollon77 last edited by
        @apollon77
        pi@iobroker:~/node_modules/node-ph803w/example $ DEBUG=ph803w* node discovery
        Discover PH803W devices ... CTRL-C to quit
          ph803w:discovery Listen for local PH803W devices on port 12414 +0ms
          ph803w:discovery Send broadcast message 0000000303000003 +1ms
          ph803w:discovery Parsing discovered device: 192.168.88.128:12414 - 00000003780000040016327471526138384667615553354178674152565975670006e8db848c4b17000830343032303033410020326433643935346439626237343162346131396261313135333130343933326200000000000000026170692e67697a776974732e636f6d3a383000342e312e32003033303330303030 +48ms
          ph803w:discovery Discovered device: {"ip":"192.168.88.128","id":"2tqRa88FgaUS5AxgARVYug","data1":"e8db848c4b17","data2":"3034303230303341","data3":"2d3d954d9bb741b4a19ba1153104932b","apiServer":"api.gizwits.com:80","version":"4.1.2"} +1ms
        PH803W Device discovered on 192.168.88.128
          ph803w:discovery Parsing discovered device: 192.168.88.128:12414 - 00000003780000040016327471526138384667615553354178674152565975670006e8db848c4b17000830343032303033410020326433643935346439626237343162346131396261313135333130343933326200000000000000026170692e67697a776974732e636f6d3a383000342e312e32003033303330303030 +93ms
          ph803w:discovery Ignore data package because invalid message type 145: ��ۄ�K�
          ph803w:discovery ` +1s
        ERROR: Ignore data package because invalid message type 145
          ph803w:discovery _ +6s
        • coyote
          coyote Most Active @apollon77 last edited by
          @apollon77 bei mir schauts dann so aus:
          root@debian:/home/coyote/ph803w/node_modules/node-ph803w/example# DEBUG=ph803w*        node discovery
            ph803w:discovery Send broadcast message 0000000303000003 +0ms
            ph803w:discovery Parsing discovered device: 192.168.66.56:12414 - 000000036800        00040016434671704a5453796d434539504c6c703144706268590006483fda87dc47000000203264        33643935346439626237343162346131396261313135333130343933326200000000000000026170        692e67697a776974732e636f6d3a383000342e302e3800 +6ms
            ph803w:discovery Discovered device: {"ip":"192.168.66.56","id":"CFqpJTSymCE9PL        lp1DpbhY","data1":"483fda87dc47","data2":"","data3":"2d3d954d9bb741b4a19ba115310        4932b","apiServer":"api.gizwits.com:80","version":"4.0.8"} +1ms
          PH803W Device discovered on 192.168.66.56
          {"ip":"192.168.66.56","id":"CFqpJTSymCE9PLlp1DpbhY","data1":"483fda87dc47","data        2":"","data3":"2d3d954d9bb741b4a19ba1153104932b","apiServer":"api.gizwits.com:80        ","version":"4.0.8"}
            ph803w:discovery Ignore data package because invalid message type 26: ECFqpJTSymCE9PLlp1DpbhYH?ڇ�G 2d3d954d9bb741b4a19ba1153104932b +29s
          ERROR: Ignore data package because invalid message type 26
            A Former User last edited by
            @apollon77 bei mir ist es so
              ph803w:discovery Parsing discovered device: 192.168.0.118:12414 - 000000036800000400166b624538384a6772685a7930794e4a6f6e503961624b000640f5202c849300000020326433643935346439626237343162346131396261313135333130343933326200000000000000026170692e67697a776974732e636f6d3a383000342e302e3800 +306ms
              ph803w:discovery Discovered device: {"ip":"192.168.0.118","id":"kbE88JgrhZy0yNJonP9abK","data1":"40f5202c8493","data2":"","data3":"2d3d954d9bb741b4a19ba1153104932b","apiServer":"api.gizwits.com:80","version":"4.0.8"} +1ms
            PH803W Device discovered on 192.168.0.118
              Cool, updated Ihr bitte nochmal - vor allem @skinni und @coyote und postet die Ausgabe nochmal ... ich will sehen was bei euch diese "unbekannten Pakete" sind 🙂 habe das Logging angepasst. Danke
              (und @coyote bei dir wars irgendwie abgeschnitten) ...
              Aber denke auf der Basis haben wir was
              ? coyote S 3 Replies Last reply Reply Quote 0
                A Former User @apollon77 last edited by
                @apollon77
                  ph803w:discovery Parsing discovered device: 192.168.0.118:12414 - 000000036800000400166b624538384a6772685a7930794e4a6f6e503961624b000640f5202c849300000020326433643935346439626237343162346131396261313135333130343933326200000000000000026170692e67697a776974732e636f6d3a383000342e302e3800 +30ms
                  ph803w:discovery Discovered device: {"ip":"192.168.0.118","id":"kbE88JgrhZy0yNJonP9abK","data1":"40f5202c8493","data2":"","data3":"2d3d954d9bb741b4a19ba1153104932b","apiServer":"api.gizwits.com:80","version":"4.0.8"} +2ms
                • coyote
                  @apollon77
                    ph803w:discovery Parsing discovered device: 192.168.66.56:12414 - 000000036800        00040016434671704a5453796d434539504c6c703144706268590006483fda87dc47000000203264        33643935346439626237343162346131396261313135333130343933326200000000000000026170        692e67697a776974732e636f6d3a383000342e302e3800 +4ms
                    ph803w:discovery Discovered device: {"ip":"192.168.66.56","id":"CFqpJTSymCE9PL        lp1DpbhY","data1":"483fda87dc47","data2":"","data3":"2d3d954d9bb741b4a19ba115310        4932b","apiServer":"api.gizwits.com:80","version":"4.0.8"} +0ms
                    ph803w:discovery Ignore data package because invalid message type 26: 000000034500001a0016434671704a5453796d434539504c6c703144706268590006483fda87dc4700203264336439353464396262373431623461313962613131353331303439333262 +29s
                  ^C
                    @apollon77
                      ph803w:discovery Send broadcast message 0000000303000003 +2ms
                      ph803w:discovery Parsing discovered device: 192.168.88.128:12414 - 00000003780000040016327471526138384667615553354178674152565975670006e8db848c4b17000830343032303033410020326433643935346439626237343162346131396261313135333130343933326200000000000000026170692e67697a776974732e636f6d3a383000342e312e32003033303330303030 +53ms
                      ph803w:discovery Discovered device: {"ip":"192.168.88.128","id":"2tqRa88FgaUS5AxgARVYug","data1":"e8db848c4b17","data2":"3034303230303341","data3":"2d3d954d9bb741b4a19ba1153104932b","apiServer":"api.gizwits.com:80","version":"4.1.2"} +2ms
                      ph803w:discovery Parsing discovered device: 192.168.88.128:12414 - 00000003780000040016327471526138384667615553354178674152565975670006e8db848c4b17000830343032303033410020326433643935346439626237343162346131396261313135333130343933326200000000000000026170692e67697a776974732e636f6d3a383000342e312e32003033303330303030 +91ms
                      ph803w:discovery Discovered device: {"ip":"192.168.88.128","id":"2tqRa88FgaUS5AxgARVYug","data1":"e8db848c4b17","data2":"3034303230303341","data3":"2d3d954d9bb741b4a19ba1153104932b","apiServer":"api.gizwits.com:80","version":"4.1.2"} +0ms
                      ph803w:discovery Ignore data package because invalid message type 145: 000000031400009106e8db848c4b17040202c60a5400000000 +27s
                      ph803w:discovery Ignore data package because invalid message type 145: 000000031400009106e8db848c4b17040202c60a5300000000 +6s
                      Ok, ich denke die weitere Pakete die da kommen sind soweit egal 🙂
                      Damit geht Discovery auch. Dann kann ich vllt doch ohne mein Gerät mal am Adapter basteln
                        apollon77 last edited by apollon77
                        Ich hab an Discovery nochmal bissl rumgeschraubt. Könnt Ihr bitte nochmal checken ob es noch tut? Am besten (falls jemand früher gemacht hat): Nach 11:10 🙂
                        S ? 2 Replies Last reply Reply Quote 0
                          @apollon77
                          Discovering PH803W devices ... CTRL-C to quit
                            ph803w:discovery Parsing discovered device: 192.168.88.128:12414 - 00000003780000040016327471526138384667615553354178674152565975670006e8db848c4b17000830343032303033410020326433643935346439626237343162346131396261313135333130343933326200000000000000026170692e67697a776974732e636f6d3a383000342e312e32003033303330303030 +82ms
                            ph803w:discovery Parsing discovered device: 192.168.88.128:12414 - 00000003780000040016327471526138384667615553354178674152565975670006e8db848c4b17000830343032303033410020326433643935346439626237343162346131396261313135333130343933326200000000000000026170692e67697a776974732e636f6d3a383000342e312e32003033303330303030 +3ms
                          ^C
                            @apollon77 hier die neue Version
                              ph803w:discovery Parsing discovered device: 192.168.0.118:12414 - 000000036800000400166b624538384a6772685a7930794e4a6f6e503961624b000640f5202c849300000020326433643935346439626237343162346131396261313135333130343933326200000000000000026170692e67697a776974732e636f6d3a383000342e302e3800 +305ms
                              ph803w:discovery Ignore data package because invalid message type 26: 000000034500001a00166b624538384a6772685a7930794e4a6f6e503961624b000640f5202c849300203264336439353464396262373431623461313962613131353331303439333262 +29s
                              Hat jemand ne Idee was ich für ein Adapter-Bild/Icon nehmen könnte? Jemand "grafisch begabt"? 😉
                                skinni last edited by skinni
                                Einfach sowas? Transparenten Hintergrund kann ich bei Bedarf auch noch machen, falls das in die richtige Richtung geht
                                Egal wie du dich entscheidest, hier mit transparentem Hintergrund
                                • I
                                  I-Punkt @apollon77 last edited by
                                  @apollon77
                                  Gedanklich bin ich bei solchen Messungen immer gleich bei Pipette oder Reagenzglas.
                                  09bcfa1b-5a3c-49fc-a8f2-0f63740dc286-image.png 1fe197ed-15d8-4e41-8123-e19bf3d124e8-image.png
                                  • opossum
                                    opossum @Chaosbrother last edited by
                                    @chaosbrother ,
                                    werden die beiden Messsonden mitgeliefert oder muss ich die extra bei Ali bestellen oder reicht Dein Link zum Bestellen aus?
                                      da es hier um das pH803w geht, finde ich ein Kleinbild davon eigentlich am sinnvollsten.
                                      Ansonsten wirft die Suche einiges aus:
                                      wenn wir davon irgenwas in Lizenz haben, wäre das auch noch denkbar.
                                      • coyote
                                        coyote Most Active @opossum last edited by coyote
                                        @opossum ich antworte mal auf deine Frage.
                                        Die beiden Sonden, die auf dem Bild des Links sind, sind mit dabei. Wenn du aber ne Messzelle verbaust, passen diese nicht in die Verschraubungen rein.
                                        Da müsstest du dir entweder extra ein Gewindeadapter basteln oder andere neue zylinderförmige Messsonden mit 12mm Durchmesser kaufen ( so hab ich es gemacht, kosten ja nicht die Welt bei Ali)
                                        Zum Icon, bin da bei @Homoran @skinni . Entweder einfach ein Kleinbild des ph803w oder ein Icon aus seinem Screenshot
                                          weimaraner @coyote last edited by
                                          @all ich lese hier seit Tagen mit. Es ist echt der Wahnsinn, was ihr hier alle in wenigen Tagen auf die Beine gestellt habt. Das las sich, wie ein Krimi. Technisch habe ich keinen Plan, was @apollon77 hier gezaubert hat, aber es war trotzdem spannend mitzuverfolgen, wie ihr dem Ziel immer näher gekommen seid. 😁 Hut ab!
                                          Ich würde übrigens dieses icon gut finden
                                            apollon77 @weimaraner last edited by
                                            @weimaraner Ich wäre bei dem zwei drunter nur in nem Dunklen Blau anstelle dem schwarz? Kann mir das einer als PNG geben?
                                            432
                                            102900
