    4. PH-Messung
    PH-Messung
      A Former User @apollon77 last edited by
      @apollon77
      Discover PH803W devices ... CTRL-C to quit
        ph803w:discovery Listen for local PH803W devices on port 12414 +0ms
        ph803w:discovery Send broadcast message 0000000303000003 +1ms
        ph803w:discovery Parsing discovered device: 192.168.0.118:12414 - 000000036800000400166b624538384a6772685a7930794e4a6f6e503961624b000640f5202c849300000020326433643935346439626237343162346131396261313135333130343933326200000000000000026170692e67697a776974732e636f6d3a383000342e302e3800 +30ms
        ph803w:discovery Discovered device: {"ip":"192.168.0.118","id":"kbE88JgrhZy0yNJonP9abK","data1":"40f5202c8493","data2":"","data3":"2d3d954d9bb741b4a19ba1153104932b","apiServer":"api.gizwits.com:80","version":"4.0.8"} +2ms
      PH803W Device discovered on 192.168.0.118
      • coyote
        coyote Most Active @apollon77 last edited by
        @apollon77
        root@debian:/home/coyote/ph803w/node_modules/node-ph803w/example# DEBUG=ph803w*        node discovery
          ph803w:discovery Send broadcast message 0000000303000003 +0ms
          ph803w:discovery Parsing discovered device: 192.168.66.56:12414 - 000000036800        00040016434671704a5453796d434539504c6c703144706268590006483fda87dc47000000203264        33643935346439626237343162346131396261313135333130343933326200000000000000026170        692e67697a776974732e636f6d3a383000342e302e3800 +4ms
          ph803w:discovery Discovered device: {"ip":"192.168.66.56","id":"CFqpJTSymCE9PL        lp1DpbhY","data1":"483fda87dc47","data2":"","data3":"2d3d954d9bb741b4a19ba115310        4932b","apiServer":"api.gizwits.com:80","version":"4.0.8"} +0ms
        PH803W Device discovered on 192.168.66.56
        {"ip":"192.168.66.56","id":"CFqpJTSymCE9PLlp1DpbhY","data1":"483fda87dc47","data        2":"","data3":"2d3d954d9bb741b4a19ba1153104932b","apiServer":"api.gizwits.com:80        ","version":"4.0.8"}
          ph803w:discovery Ignore data package because invalid message type 26: 000000034500001a0016434671704a5453796d434539504c6c703144706268590006483fda87dc4700203264336439353464396262373431623461313962613131353331303439333262 +29s
        ERROR: Ignore data package because invalid message type 26
        ^C
          skinni @apollon77 last edited by
          @apollon77
          pi@iobroker:~/node_modules/node-ph803w/example $ DEBUG=ph803w* node discovery
            ph803w:discovery Send broadcast message 0000000303000003 +2ms
            ph803w:discovery Parsing discovered device: 192.168.88.128:12414 - 00000003780000040016327471526138384667615553354178674152565975670006e8db848c4b17000830343032303033410020326433643935346439626237343162346131396261313135333130343933326200000000000000026170692e67697a776974732e636f6d3a383000342e312e32003033303330303030 +53ms
            ph803w:discovery Discovered device: {"ip":"192.168.88.128","id":"2tqRa88FgaUS5AxgARVYug","data1":"e8db848c4b17","data2":"3034303230303341","data3":"2d3d954d9bb741b4a19ba1153104932b","apiServer":"api.gizwits.com:80","version":"4.1.2"} +2ms
          PH803W Device discovered on 192.168.88.128
            ph803w:discovery Parsing discovered device: 192.168.88.128:12414 - 00000003780000040016327471526138384667615553354178674152565975670006e8db848c4b17000830343032303033410020326433643935346439626237343162346131396261313135333130343933326200000000000000026170692e67697a776974732e636f6d3a383000342e312e32003033303330303030 +91ms
            ph803w:discovery Discovered device: {"ip":"192.168.88.128","id":"2tqRa88FgaUS5AxgARVYug","data1":"e8db848c4b17","data2":"3034303230303341","data3":"2d3d954d9bb741b4a19ba1153104932b","apiServer":"api.gizwits.com:80","version":"4.1.2"} +0ms
            ph803w:discovery Ignore data package because invalid message type 145: 000000031400009106e8db848c4b17040202c60a5400000000 +27s
          ERROR: Ignore data package because invalid message type 145
            ph803w:discovery Ignore data package because invalid message type 145: 000000031400009106e8db848c4b17040202c60a5300000000 +6s
            Ok, ich denke die weitere Pakete die da kommen sind soweit egal 🙂
            Damit geht Discovery auch. Dann kann ich vllt doch ohne mein Gerät mal am Adapter basteln
              apollon77 last edited by apollon77
              Ich hab an Discovery nochmal bissl rumgeschraubt. Könnt Ihr bitte nochmal checken ob es noch tut? Am besten (falls jemand früher gemacht hat): Nach 11:10 🙂
              S ? 2 Replies Last reply Reply Quote 0
                @apollon77
                Discovering PH803W devices ... CTRL-C to quit
                  ph803w:discovery Parsing discovered device: 192.168.88.128:12414 - 00000003780000040016327471526138384667615553354178674152565975670006e8db848c4b17000830343032303033410020326433643935346439626237343162346131396261313135333130343933326200000000000000026170692e67697a776974732e636f6d3a383000342e312e32003033303330303030 +82ms
                  ph803w:discovery Discovered device: {"ip":"192.168.88.128","id":"2tqRa88FgaUS5AxgARVYug","data1":"e8db848c4b17","data2":"3034303230303341","data3":"2d3d954d9bb741b4a19ba1153104932b","apiServer":"api.gizwits.com:80","version":"4.1.2"} +1ms
                  ph803w:discovery Parsing discovered device: 192.168.88.128:12414 - 00000003780000040016327471526138384667615553354178674152565975670006e8db848c4b17000830343032303033410020326433643935346439626237343162346131396261313135333130343933326200000000000000026170692e67697a776974732e636f6d3a383000342e312e32003033303330303030 +3ms
                ^C
                  @apollon77 hier die neue Version
                    ph803w:discovery Parsing discovered device: 192.168.0.118:12414 - 000000036800000400166b624538384a6772685a7930794e4a6f6e503961624b000640f5202c849300000020326433643935346439626237343162346131396261313135333130343933326200000000000000026170692e67697a776974732e636f6d3a383000342e302e3800 +305ms
                    ph803w:discovery Ignore data package because invalid message type 26: 000000034500001a00166b624538384a6772685a7930794e4a6f6e503961624b000640f5202c849300203264336439353464396262373431623461313962613131353331303439333262 +29s
                    Hat jemand ne Idee was ich für ein Adapter-Bild/Icon nehmen könnte? Jemand "grafisch begabt"? 😉
                      skinni last edited by skinni
                      Einfach sowas? Transparenten Hintergrund kann ich bei Bedarf auch noch machen, falls das in die richtige Richtung geht
                      Egal wie du dich entscheidest, hier mit transparentem Hintergrund
                      • I
                        I-Punkt @apollon77 last edited by
                        @apollon77
                        Gedanklich bin ich bei solchen Messungen immer gleich bei Pipette oder Reagenzglas.
                        09bcfa1b-5a3c-49fc-a8f2-0f63740dc286-image.png 1fe197ed-15d8-4e41-8123-e19bf3d124e8-image.png
                        • opossum
                          opossum @Chaosbrother last edited by
                          @chaosbrother ,
                          werden die beiden Messsonden mitgeliefert oder muss ich die extra bei Ali bestellen oder reicht Dein Link zum Bestellen aus?
                            da es hier um das pH803w geht, finde ich ein Kleinbild davon eigentlich am sinnvollsten.
                            Ansonsten wirft die Suche einiges aus:
                            wenn wir davon irgenwas in Lizenz haben, wäre das auch noch denkbar.
                            • coyote
                              coyote Most Active @opossum last edited by coyote
                              @opossum ich antworte mal auf deine Frage.
                              Die beiden Sonden, die auf dem Bild des Links sind, sind mit dabei. Wenn du aber ne Messzelle verbaust, passen diese nicht in die Verschraubungen rein.
                              Da müsstest du dir entweder extra ein Gewindeadapter basteln oder andere neue zylinderförmige Messsonden mit 12mm Durchmesser kaufen ( so hab ich es gemacht, kosten ja nicht die Welt bei Ali)
                              Zum Icon, bin da bei @Homoran @skinni . Entweder einfach ein Kleinbild des ph803w oder ein Icon aus seinem Screenshot
                                weimaraner @coyote last edited by
                                @all ich lese hier seit Tagen mit. Es ist echt der Wahnsinn, was ihr hier alle in wenigen Tagen auf die Beine gestellt habt. Das las sich, wie ein Krimi. Technisch habe ich keinen Plan, was @apollon77 hier gezaubert hat, aber es war trotzdem spannend mitzuverfolgen, wie ihr dem Ziel immer näher gekommen seid. 😁 Hut ab!
                                Ich würde übrigens dieses icon gut finden
                                  apollon77 @weimaraner last edited by
                                  @weimaraner Ich wäre bei dem zwei drunter nur in nem Dunklen Blau anstelle dem schwarz? Kann mir das einer als PNG geben?
                                    apollon77 @I-Punkt last edited by
                                    @i-punkt Die sind generell gut, aber mit für diesen Fall - geht ja quasi um ein spezifisches Gerät, den PH803W zu allgemein. Denke das Icon sollte schon Farblich und "aussehen" was damit zu tun haben.
                                    Für die Readme kann man auch durch aus noch ein größeres ausgeschnittenes und freigestellte echtes PH803W machen - das ist dann nur nix als Icon
                                      Hey, na, noch jemand wach?? Jemand er einen PH803W und ioBroker hat? Jemand dessen PH803W an ist? jemand der nen Adapter testen will? ;-))
                                      Bitte Adapter von https://github.com/Apollon77/ioBroker.ph803w/ installieren ... EInstellungen braucht es aktuell keine. Discovery per UDP - PH803W muss also im gleichen netzwerk sein wie der ioBroker Rechner
                                      coyote 3 Replies Last reply Reply Quote 1
                                      • coyote
                                        @apollon77 teste gleich, gib mir noch paar Minuten 😉
                                        • coyote
                                          @apollon77 tja, was soll ich sagen Ingo 🙂
                                          Wer kann, der kann...👏 👏 Vielen dank
                                          • coyote
                                            @apollon77 wie deinstalliere ich denn jetzt am Besten das Testscript von dir?
                                            432
                                            102919
