    4. PH-Messung
    PH-Messung
      skinni @apollon77 last edited by
      @apollon77
      pi@iobroker:~/node_modules/node-ph803w/example $ DEBUG=ph803w* node discovery
      Discovering PH803W devices ... CTRL-C to quit
        ph803w:discovery Listen for local PH803W devices on port 12414 +0ms
        ph803w:discovery Send broadcast message 0000000303000003 +2ms
        ph803w:discovery Parsing discovered device: 192.168.88.128:12414 - 00000003780000040016327471526138384667615553354178674152565975670006e8db848c4b17000830343032303033410020326433643935346439626237343162346131396261313135333130343933326200000000000000026170692e67697a776974732e636f6d3a383000342e312e32003033303330303030 +82ms
        ph803w:discovery Discovered device: {"ip":"192.168.88.128","id":"2tqRa88FgaUS5AxgARVYug","data1":"e8db848c4b17","data2":"3034303230303341","data3":"2d3d954d9bb741b4a19ba1153104932b","apiServer":"api.gizwits.com:80","version":"4.1.2"} +1ms
      PH803W Device discovered on 192.168.88.128
        ph803w:discovery Parsing discovered device: 192.168.88.128:12414 - 00000003780000040016327471526138384667615553354178674152565975670006e8db848c4b17000830343032303033410020326433643935346439626237343162346131396261313135333130343933326200000000000000026170692e67697a776974732e636f6d3a383000342e312e32003033303330303030 +3ms
      ^C
        A Former User @apollon77 last edited by
        @apollon77 hier die neue Version
          ph803w:discovery Send broadcast message 0000000303000003 +1ms
          ph803w:discovery Parsing discovered device: 192.168.0.118:12414 - 000000036800000400166b624538384a6772685a7930794e4a6f6e503961624b000640f5202c849300000020326433643935346439626237343162346131396261313135333130343933326200000000000000026170692e67697a776974732e636f6d3a383000342e302e3800 +305ms
          ph803w:discovery Discovered device: {"ip":"192.168.0.118","id":"kbE88JgrhZy0yNJonP9abK","data1":"40f5202c8493","data2":"","data3":"2d3d954d9bb741b4a19ba1153104932b","apiServer":"api.gizwits.com:80","version":"4.0.8"} +2ms
        PH803W Device discovered on 192.168.0.118
          ph803w:discovery Ignore data package because invalid message type 26: 000000034500001a00166b624538384a6772685a7930794e4a6f6e503961624b000640f5202c849300203264336439353464396262373431623461313962613131353331303439333262 +29s
          Hat jemand ne Idee was ich für ein Adapter-Bild/Icon nehmen könnte? Jemand "grafisch begabt"? 😉
            skinni last edited by skinni
            Einfach sowas? Transparenten Hintergrund kann ich bei Bedarf auch noch machen, falls das in die richtige Richtung geht
            Egal wie du dich entscheidest, hier mit transparentem Hintergrund
            • I
              I-Punkt @apollon77 last edited by
              @apollon77
              Gedanklich bin ich bei solchen Messungen immer gleich bei Pipette oder Reagenzglas.
              09bcfa1b-5a3c-49fc-a8f2-0f63740dc286-image.png 1fe197ed-15d8-4e41-8123-e19bf3d124e8-image.png
              • opossum
                opossum @Chaosbrother last edited by
                @chaosbrother ,
                werden die beiden Messsonden mitgeliefert oder muss ich die extra bei Ali bestellen oder reicht Dein Link zum Bestellen aus?
                  da es hier um das pH803w geht, finde ich ein Kleinbild davon eigentlich am sinnvollsten.
                  Ansonsten wirft die Suche einiges aus:
                  wenn wir davon irgenwas in Lizenz haben, wäre das auch noch denkbar.
                  • coyote
                    coyote Most Active @opossum last edited by coyote
                    @opossum ich antworte mal auf deine Frage.
                    Die beiden Sonden, die auf dem Bild des Links sind, sind mit dabei. Wenn du aber ne Messzelle verbaust, passen diese nicht in die Verschraubungen rein.
                    Da müsstest du dir entweder extra ein Gewindeadapter basteln oder andere neue zylinderförmige Messsonden mit 12mm Durchmesser kaufen ( so hab ich es gemacht, kosten ja nicht die Welt bei Ali)
                    Zum Icon, bin da bei @Homoran @skinni . Entweder einfach ein Kleinbild des ph803w oder ein Icon aus seinem Screenshot
                      weimaraner @coyote last edited by
                      @all ich lese hier seit Tagen mit. Es ist echt der Wahnsinn, was ihr hier alle in wenigen Tagen auf die Beine gestellt habt. Das las sich, wie ein Krimi. Technisch habe ich keinen Plan, was @apollon77 hier gezaubert hat, aber es war trotzdem spannend mitzuverfolgen, wie ihr dem Ziel immer näher gekommen seid. 😁 Hut ab!
                      Ich würde übrigens dieses icon gut finden
                        apollon77 @weimaraner last edited by
                        @weimaraner Ich wäre bei dem zwei drunter nur in nem Dunklen Blau anstelle dem schwarz? Kann mir das einer als PNG geben?
                          apollon77 @I-Punkt last edited by
                          @i-punkt Die sind generell gut, aber mit für diesen Fall - geht ja quasi um ein spezifisches Gerät, den PH803W zu allgemein. Denke das Icon sollte schon Farblich und "aussehen" was damit zu tun haben.
                          Für die Readme kann man auch durch aus noch ein größeres ausgeschnittenes und freigestellte echtes PH803W machen - das ist dann nur nix als Icon
                            apollon77 last edited by apollon77
                            Hey, na, noch jemand wach?? Jemand er einen PH803W und ioBroker hat? Jemand dessen PH803W an ist? jemand der nen Adapter testen will? ;-))
                            Bitte Adapter von https://github.com/Apollon77/ioBroker.ph803w/ installieren ... EInstellungen braucht es aktuell keine. Discovery per UDP - PH803W muss also im gleichen netzwerk sein wie der ioBroker Rechner
                            coyote 3 Replies Last reply Reply Quote 1
                            • coyote
                              coyote Most Active @apollon77 last edited by
                              @apollon77 teste gleich, gib mir noch paar Minuten 😉
                              • coyote
                                @apollon77 tja, was soll ich sagen Ingo 🙂
                                Wer kann, der kann...👏 👏 Vielen dank
                                • coyote
                                  @apollon77 wie deinstalliere ich denn jetzt am Besten das Testscript von dir?
                                    apollon77 @coyote last edited by
                                    @coyote einfach das Verzeichnis was du dafür angelegt hast löschen.
                                    • I
                                      ioUser 0 last edited by
                                      irgendwie haut die Installation im ioBroker bei mir nicht hin.
                                      Eine kurze Newbie-Erklärung für die Installation und was man alles benötigt wäre toll.
                                      • Marc R
                                        Marc R last edited by
                                        Mein Kumpel half mir @apollon77's script via MQTT auf Home Assistant zu portieren. Falls interessiert, findet Ihr den Source Code hier: https://github.com/cellerich/ph803w_2_mqtt
                                        Danke für Eure Arbeit!
                                          skinni @ioUser 0 last edited by skinni
                                          @iouser-0 in iobroker wählst du "adapter installieren aus eigener URL", gehst auf "Benutzerdefiniert" als Quelle und gibst als URL https://github.com/Apollon77/ioBroker.ph803w ein
                                          Anschließend musst du noch eine Instanz erstellen.
                                          @apollon77 Installation hat geklappt, Werte werden angezeigt und aktualisiert. Mir ist aufgefallen unter connection state steht false
                                          I apollon77 2 Replies Last reply Reply Quote 0
                                          • I
                                            ioUser 0 @skinni last edited by
                                            @skinni
                                            Instanz erstellen war das Zauberwort. Herzlichen Dank!!!
                                            432
                                            102925
