    4. Asterisk bringt "Error while dialing (2). Error: {}"
      Thomas Braun Most Active @varg last edited by
      @varg
      ls -l /var/lib/dpkg/info | grep -i asterisk
        @varg
        sudo mv /var/lib/dpkg/info/asterisk* /tmp
        Dann
        sudo apt update
        sudo apt install asterisk
        • V
          varg @Thomas Braun last edited by varg
          pi@pio4gb:~ $ ls -l /var/lib/dpkg/info | grep -i asterisk
          -rw-r--r-- 1 root root      69 Aug 27  2020 asterisk.conffiles
          -rw-r--r-- 1 root root    3137 Aug 27  2020 asterisk-config.conffiles
          -rw-r--r-- 1 root root   13720 Jun  6 15:22 asterisk-config.list
          -rw-r--r-- 1 root root   14680 Aug 27  2020 asterisk-config.md5sums
          -rwxr-xr-x 1 root root    1325 Aug 27  2020 asterisk-config.postinst
          -rwxr-xr-x 1 root root    1409 Aug 27  2020 asterisk-config.preinst
          -rw-r--r-- 1 root root   35380 Jun  6 15:22 asterisk-core-sounds-en-gsm.list
          -rw-r--r-- 1 root root   53716 Dec 20  2018 asterisk-core-sounds-en-gsm.md5sums
          -rwxr-xr-x 1 root root     352 Dec 20  2018 asterisk-core-sounds-en-gsm.preinst
          -rw-r--r-- 1 root root     347 Jun  6 15:22 asterisk-core-sounds-en.list
          -rw-r--r-- 1 root root     439 Dec 20  2018 asterisk-core-sounds-en.md5sums
          -rwxr-xr-x 1 root root    1050 Dec 20  2018 asterisk-core-sounds-en.postinst
          -rwxr-xr-x 1 root root     245 Dec 20  2018 asterisk-core-sounds-en.prerm
          -rw-r--r-- 1 root root   10731 Jun  6 15:40 asterisk.list
          -rw-r--r-- 1 root root   15583 Aug 27  2020 asterisk.md5sums
          -rw-r--r-- 1 root root   14460 Jun  6 15:22 asterisk-modules.list
          -rw-r--r-- 1 root root   24919 Aug 27  2020 asterisk-modules.md5sums
          -rw-r--r-- 1 root root     480 Jun  6 15:22 asterisk-moh-opsound-gsm.list
          -rw-r--r-- 1 root root     593 Jun 28  2010 asterisk-moh-opsound-gsm.md5sums
          -rwxr-xr-x 1 root root    4642 Aug 27  2020 asterisk.postinst
          -rwxr-xr-x 1 root root     731 Aug 27  2020 asterisk.postrm
          -rwxr-xr-x 1 root root     321 Aug 27  2020 asterisk.prerm
          -rw-r--r-- 1 root root      25 Aug 27  2020 asterisk.shlibs
          -rw-r--r-- 1 root root      67 Aug 27  2020 asterisk.triggers
          -rw-r--r-- 1 root root     358 Jun  6 15:40 asterisk-voicemail.list
          -rw-r--r-- 1 root root     402 Aug 27  2020 asterisk-voicemail.md5sums
          pi@pio4gb:~ $
          pi@pio4gb:~ $ sudo mv /var/lib/dpkg/info/asterisk* /tmp
          pi@pio4gb:~ $
          pi@pio4gb:~ $ sudo apt update
          Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
          Hit:2 http://archive.raspberrypi.org/debian buster InRelease
          Hit:3 https://deb.nodesource.com/node_12.x buster InRelease
          Reading package lists... Done
          Building dependency tree
          All packages are up to date.
          pi@pio4gb:~ $ sudo apt install asterisk
          asterisk is already the newest version (1:16.2.1~dfsg-1+deb10u2).
          0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
          2 not fully installed or removed.
          After this operation, 0 B of additional disk space will be used.
          Do you want to continue? [Y/n] Y
          Setting up asterisk (1:16.2.1~dfsg-1+deb10u2) ...
          Setting up asterisk-voicemail (1:16.2.1~dfsg-1+deb10u2) ...
          Installationsverzeichnis /etc/asterisk/ scheint immernoch tot
            @varg
            Mehr nicht?
            Da sollte eigentlich mehr kommen.
            Bitte ggf. auch das login prompt posten, dann kann man sehen ob alles durch ist.
            • V
              habe alles was putty hergibt kopiert, mehr war hier nicht zu sehen.
              ...und vielen Dank für Deine Unterstützung
              • V
                varg @varg last edited by varg
                @varg
                habe mal aus neugier auf einem anderen gerät iobroker komplett neu aufgesetzt und asterisk installiert:
                das Problem bleibt bestehen:
                @Thomas-Braun die installationsroutine verlief auf dem neuen system fehlerfrei
                asterisk.0	2021-06-06 22:47:53.763	error	(1084) Error while Converting File: {}
                asterisk.0	2021-06-06 22:47:53.229	silly	(1084) States user redis pmessage asterisk.0.*/asterisk.0.dialin.callerid:{"val":"","ack":true,"ts":1623012473225,"q":0,"from":"system.adapter.asterisk.0","user":"system.user.admin","lc":1623012039437
                asterisk.0	2021-06-06 22:47:53.223	silly	(1084) States user redis pmessage asterisk.0.*/asterisk.0.dialin.dtmf:{"val":"","ack":true,"ts":1623012473173,"q":0,"from":"system.adapter.asterisk.0","user":"system.user.admin","lc":1623012039466}
                asterisk.0	2021-06-06 22:47:53.164	info	(1084) Connected to Asterisk Manager
                asterisk.0	2021-06-06 22:47:53.154	info	(1084) Starting Adapter asterisk.0 in version 1.0.6 with transcoder ffmpeg and language DE
                asterisk.0	2021-06-06 22:47:53.142	silly	(1084) States system redis pmessage system.adapter.asterisk.0.logLevel/system.adapter.asterisk.0.logLevel:{"val":"silly","ack":true,"ts":1623012473124,"q":0,"from":"system.adapter.asterisk.0","lc":162
                asterisk.0	2021-06-06 22:47:53.092	info	(1084) starting. Version 1.0.6 in /opt/iobroker/node_modules/iobroker.asterisk, node: v14.17.0, js-controller: 3.2.16
                host.piholeblack	2021-06-06 22:47:51.619	info	instance system.adapter.asterisk.0 started with pid 1084
                host.piholeblack	2021-06-06 22:47:49.157	info	instance system.adapter.asterisk.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                asterisk.0	2021-06-06 22:47:48.587	info	(1067) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                asterisk.0	2021-06-06 22:47:48.585	info	(1067) terminating
                asterisk.0	2021-06-06 22:47:48.582	info	(1067) Closing Asterisk Adapter
                host.piholeblack	2021-06-06 22:47:48.582	info	stopInstance system.adapter.asterisk.0 send kill signal
                  TemPeck last edited by
                  Bin eben auf den Thread gestoßen und hab auch gleich mal nen Testanruf angestoßen - gleicher Fehler.
                  Kann jetzt natürlich nicht sagen seit wann. Ich erhalte die Anrufe nur bei Auslösung der Rauchmelder oder bei Einbruchmeldung - also nicht alle Tage.
                  Sicher dass es nicht an der Node-Version liegt? Ich wüsste sonst auch nicht, was ich noch so verändert hätte...
                  Ich schaue nächste Woche sonst mal ob ich noch ein ganz altes Backup finde...
                  • V
                    varg @TemPeck last edited by
                    @tempeck
                    habe den Fehler auf node 12 und 14
                      boeskij last edited by
                      ich vermute Google hat etwas an der verwendeten Text-To-Speech API verändert, sodass nur noch eine bestimmte Anzahl Wandlungen in einem Zeitraum möglich sind (wenn überhaupt noch)...
                      Ich habe es jetzt so gelöst, dass im Skript "umzu" mit lokalem PicoTTS wav-Dateien erzeugt und mit sox zur gsm konvertiert werden.
                      Problem ist, dass beim Starten des Adapters der Dial-In-Text an Google geschickt wird und natürlich nicht gewandelt wird...
                      Als Konsequenz daraus startet dann der Adapter nicht korrekt (kein DTMF mehr möglich)
                      Um dies quick and dirty zu beheben habe ich in der asterisk.js die Zeilen 757 und 788 auskommentiert...
                      Der Teil dazwischen wurde sonst nicht ausgeführt...
                      757:	/* convertDialInFile(parameter, () => { */
                      788:	/* }); */
                      Wäre natürlich toll, wenn jemand den Adapter so umbauen könnte, dass eine andere TTS-Engine genutzt wird...
                      bahnuhr Z 3 Replies Last reply Reply Quote 0
                      • bahnuhr
                        bahnuhr Forum Testing Most Active @boeskij last edited by
                        @boeskij sagte in Asterisk bringt "Error while dialing (2). Error: {}":
                        Könntest du dies mal näher erläutern.
                          boeskij @bahnuhr last edited by boeskij
                          @bahnuhr
                          Hoffe das hier hilft:
                          let msg = "Dieser Text wird vorgelesen."
                          exec('pico2wave -w /tmp/ttsdatei.wav -l de-DE "' + msg + '"', function (error, stdout, stderr) {
                                                  /* wav erstellt */
                                                  exec('sox /tmp/ttsdatei.wav -r 8000 -c 1 /tmp/ttsdatei.gsm', function (error, stdout, stderr) {
                                                      /* gsm erstellt */
                                                      exec('rm /tmp/ttsdatei.wav', function (error, stdout, stderr) {
                                                          /* wav gelöscht, sonst wurde beim folgenden Anruf ggf. die falsche Datei aufgerufen... */
                                                              sendTo('asterisk.0', "dial", { telnr: callNumber, callerid: callerId, audiofile: '/tmp/ttsdatei.gsm'},  (res) => {
        console.log('Result: ' + JSON.stringify(res));
        exec('cp /tmp/ttsdatei.gsm /tmp/asterisk_dtmf.gsm', function (error, stdout, stderr) {
        /* Die asterisk_dtmf.gsm wird für Dial-In Anrufe verwendet... Hier wird dann einfach der letzte Anruf nochmal wiedergegeben */
        /* Das folgende Löschen führte bei mir zu Problemen, also bleibt die Datei liegen.. wird ja eh überschrieben */
        /* exec('rm /tmp/ttsdatei.gsm', function (error, stdout, stderr) { console.log('Telefonalamierung: gsm gelöscht'); }); */
                          bahnuhr stek 2 Replies Last reply Reply Quote 0
                          • bahnuhr
                            pico2wave
                            Kenn ich bisher nicht.
                            Muss man dies installieren?
                              @bahnuhr
                              ja, wird auch im sayit-Adapter verwendet:
                              PicoTTS (linux only): English, German, Italian, Spanish, French For PicoTTS it is necessary to install the following packages: libttspico-utils and lame. Installation command: 'sudo apt-get install libttspico-utils lame'
                              bahnuhr 2 Replies Last reply Reply Quote 0
                              • bahnuhr
                                @boeskij
                                Habe mal das Script gekürzt um zu sehen ob eine wav erzeugt wird.
                                    exec('pico2wave -w /tmp/ttsifixalarm.wav -l de-DE "' + msg + '"', function (error, stdout, stderr) {
                                        log (error);
                                        log (stdout);
                                        log (stderr);
                                Datei wird nicht erzeugt. Und im log steht:
                                Pico wird nicht gefunden. Muss ich doch etwas installieren. Habe auch mal "pico2wave" eingegeben in der JS instanz. Da kamen dann aber nur Fehlermeldungen.
                                  Thomas Braun Most Active @bahnuhr last edited by
                                  @bahnuhr
                                  pico TTS muss noch nachinstalliert werden. Ist etwas komplexer, je nach vorhandenem System:
                                  https://cstan.io/?p=11840&lang=en
                                  • bahnuhr
                                    oben stand, dass pico bei sayit dabei ist.
                                    Dem ist dann nicht so ?
                                      @bahnuhr
                                      es wird dort verwendet... ist aber nicht dabei...
                                      wie oben im Zitat geschrieben:
                                      • bahnuhr
                                        tut mir leid, aber diesen Satz verstehe ich nicht.
                                        Wenn es verwendet wird, muss es doch auch installiert sein.
                                        Denn wenn nicht installiert, dann kann es auch nicht verwendet werden.
                                        Ist aber auch egal, ich probier dies einmal.
                                        Melde mich dann wieder.
                                        • bahnuhr
                                          @boeskij
                                          das:
                                          funktioniert nicht.
                                          Benutze debian auf proxmox in einer VM
                                          Und da kommt:
                                          root@VM-iobroker:/opt/iobroker# sudo apt-get install libttspico-utils lame
                                          Paket libttspico-utils ist nicht verfügbar, wird aber von einem anderen Paket
                                          referenziert. Das kann heißen, dass das Paket fehlt, dass es abgelöst
                                          wurde oder nur aus einer anderen Quelle verfügbar ist.
                                          E: Für Paket »libttspico-utils« existiert kein Installationskandidat.
                                            @bahnuhr
                                            https://forum.iobroker.net/topic/38883/sayit-mit-tts-pico/2?_=1623260824757
                                            116
                                            11029
