    4. Asterisk bringt "Error while dialing (2). Error: {}"
    • V
      varg @Thomas Braun last edited by varg
      habe alles was putty hergibt kopiert, mehr war hier nicht zu sehen.
      ...und vielen Dank für Deine Unterstützung
      • V
        varg @varg last edited by varg
        @varg
        habe mal aus neugier auf einem anderen gerät iobroker komplett neu aufgesetzt und asterisk installiert:
        das Problem bleibt bestehen:
        @Thomas-Braun die installationsroutine verlief auf dem neuen system fehlerfrei
        asterisk.0	2021-06-06 22:47:53.763	error	(1084) Error while Converting File: {}
        asterisk.0	2021-06-06 22:47:53.229	silly	(1084) States user redis pmessage asterisk.0.*/asterisk.0.dialin.callerid:{"val":"","ack":true,"ts":1623012473225,"q":0,"from":"system.adapter.asterisk.0","user":"system.user.admin","lc":1623012039437
        asterisk.0	2021-06-06 22:47:53.223	silly	(1084) States user redis pmessage asterisk.0.*/asterisk.0.dialin.dtmf:{"val":"","ack":true,"ts":1623012473173,"q":0,"from":"system.adapter.asterisk.0","user":"system.user.admin","lc":1623012039466}
        asterisk.0	2021-06-06 22:47:53.164	info	(1084) Connected to Asterisk Manager
        asterisk.0	2021-06-06 22:47:53.154	info	(1084) Starting Adapter asterisk.0 in version 1.0.6 with transcoder ffmpeg and language DE
        asterisk.0	2021-06-06 22:47:53.142	silly	(1084) States system redis pmessage system.adapter.asterisk.0.logLevel/system.adapter.asterisk.0.logLevel:{"val":"silly","ack":true,"ts":1623012473124,"q":0,"from":"system.adapter.asterisk.0","lc":162
        asterisk.0	2021-06-06 22:47:53.092	info	(1084) starting. Version 1.0.6 in /opt/iobroker/node_modules/iobroker.asterisk, node: v14.17.0, js-controller: 3.2.16
        host.piholeblack	2021-06-06 22:47:51.619	info	instance system.adapter.asterisk.0 started with pid 1084
        host.piholeblack	2021-06-06 22:47:49.157	info	instance system.adapter.asterisk.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        asterisk.0	2021-06-06 22:47:48.587	info	(1067) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        asterisk.0	2021-06-06 22:47:48.585	info	(1067) terminating
        asterisk.0	2021-06-06 22:47:48.582	info	(1067) Closing Asterisk Adapter
        host.piholeblack	2021-06-06 22:47:48.582	info	stopInstance system.adapter.asterisk.0 send kill signal
          TemPeck last edited by
          Bin eben auf den Thread gestoßen und hab auch gleich mal nen Testanruf angestoßen - gleicher Fehler.
          Kann jetzt natürlich nicht sagen seit wann. Ich erhalte die Anrufe nur bei Auslösung der Rauchmelder oder bei Einbruchmeldung - also nicht alle Tage.
          Sicher dass es nicht an der Node-Version liegt? Ich wüsste sonst auch nicht, was ich noch so verändert hätte...
          Ich schaue nächste Woche sonst mal ob ich noch ein ganz altes Backup finde...
          • V
            varg @TemPeck last edited by
            @tempeck
            habe den Fehler auf node 12 und 14
              boeskij last edited by
              ich vermute Google hat etwas an der verwendeten Text-To-Speech API verändert, sodass nur noch eine bestimmte Anzahl Wandlungen in einem Zeitraum möglich sind (wenn überhaupt noch)...
              Ich habe es jetzt so gelöst, dass im Skript "umzu" mit lokalem PicoTTS wav-Dateien erzeugt und mit sox zur gsm konvertiert werden.
              Problem ist, dass beim Starten des Adapters der Dial-In-Text an Google geschickt wird und natürlich nicht gewandelt wird...
              Als Konsequenz daraus startet dann der Adapter nicht korrekt (kein DTMF mehr möglich)
              Um dies quick and dirty zu beheben habe ich in der asterisk.js die Zeilen 757 und 788 auskommentiert...
              Der Teil dazwischen wurde sonst nicht ausgeführt...
              757:	/* convertDialInFile(parameter, () => { */
              788:	/* }); */
              Wäre natürlich toll, wenn jemand den Adapter so umbauen könnte, dass eine andere TTS-Engine genutzt wird...
              bahnuhr Z 3 Replies Last reply Reply Quote 0
              • bahnuhr
                bahnuhr Forum Testing Most Active @boeskij last edited by
                @boeskij sagte in Asterisk bringt "Error while dialing (2). Error: {}":
                Könntest du dies mal näher erläutern.
                  boeskij @bahnuhr last edited by boeskij
                  @bahnuhr
                  Hoffe das hier hilft:
                  let msg = "Dieser Text wird vorgelesen."
                  exec('pico2wave -w /tmp/ttsdatei.wav -l de-DE "' + msg + '"', function (error, stdout, stderr) {
                                          /* wav erstellt */
                                          exec('sox /tmp/ttsdatei.wav -r 8000 -c 1 /tmp/ttsdatei.gsm', function (error, stdout, stderr) {
                                              /* gsm erstellt */
                                              exec('rm /tmp/ttsdatei.wav', function (error, stdout, stderr) {
                                                  /* wav gelöscht, sonst wurde beim folgenden Anruf ggf. die falsche Datei aufgerufen... */
                                                      sendTo('asterisk.0', "dial", { telnr: callNumber, callerid: callerId, audiofile: '/tmp/ttsdatei.gsm'},  (res) => {
                                                          console.log('Result: ' + JSON.stringify(res));
                                                          exec('cp /tmp/ttsdatei.gsm /tmp/asterisk_dtmf.gsm', function (error, stdout, stderr) {
                                                              /* Die asterisk_dtmf.gsm wird für Dial-In Anrufe verwendet... Hier wird dann einfach der letzte Anruf nochmal wiedergegeben */
                                                              /* Das folgende Löschen führte bei mir zu Problemen, also bleibt die Datei liegen.. wird ja eh überschrieben */
                                                              /* exec('rm /tmp/ttsdatei.gsm', function (error, stdout, stderr) { console.log('Telefonalamierung: gsm gelöscht'); }); */
                  bahnuhr stek 2 Replies Last reply Reply Quote 0
                  • bahnuhr
                    pico2wave
                    Kenn ich bisher nicht.
                    Muss man dies installieren?
                      @bahnuhr
                      ja, wird auch im sayit-Adapter verwendet:
                      PicoTTS (linux only): English, German, Italian, Spanish, French For PicoTTS it is necessary to install the following packages: libttspico-utils and lame. Installation command: 'sudo apt-get install libttspico-utils lame'
                      bahnuhr 2 Replies Last reply Reply Quote 0
                      • bahnuhr
                        @boeskij
                        Habe mal das Script gekürzt um zu sehen ob eine wav erzeugt wird.
                            exec('pico2wave -w /tmp/ttsifixalarm.wav -l de-DE "' + msg + '"', function (error, stdout, stderr) {
                                log (error);
                                log (stdout);
                                log (stderr);
                        Datei wird nicht erzeugt. Und im log steht:
                        Pico wird nicht gefunden. Muss ich doch etwas installieren. Habe auch mal "pico2wave" eingegeben in der JS instanz. Da kamen dann aber nur Fehlermeldungen.
                          Thomas Braun Most Active @bahnuhr last edited by
                          @bahnuhr
                          pico TTS muss noch nachinstalliert werden. Ist etwas komplexer, je nach vorhandenem System:
                          https://cstan.io/?p=11840&lang=en
                          • bahnuhr
                            oben stand, dass pico bei sayit dabei ist.
                            Dem ist dann nicht so ?
                              @bahnuhr
                              es wird dort verwendet... ist aber nicht dabei...
                              wie oben im Zitat geschrieben:
                              • bahnuhr
                                tut mir leid, aber diesen Satz verstehe ich nicht.
                                Wenn es verwendet wird, muss es doch auch installiert sein.
                                Denn wenn nicht installiert, dann kann es auch nicht verwendet werden.
                                Ist aber auch egal, ich probier dies einmal.
                                Melde mich dann wieder.
                                • bahnuhr
                                  @boeskij
                                  das:
                                  funktioniert nicht.
                                  Benutze debian auf proxmox in einer VM
                                  Und da kommt:
                                  root@VM-iobroker:/opt/iobroker# sudo apt-get install libttspico-utils lame
                                  Paket libttspico-utils ist nicht verfügbar, wird aber von einem anderen Paket
                                  referenziert. Das kann heißen, dass das Paket fehlt, dass es abgelöst
                                  wurde oder nur aus einer anderen Quelle verfügbar ist.
                                  E: Für Paket »libttspico-utils« existiert kein Installationskandidat.
                                    @bahnuhr
                                    https://forum.iobroker.net/topic/38883/sayit-mit-tts-pico/2?_=1623260824757
                                      Thomas Braun Most Active @boeskij last edited by
                                      @boeskij
                                      Lol, wusste gar nicht das ich mich damit schon mal beschäftigt hatte.
                                      • bahnuhr
                                        bahnuhr Forum Testing Most Active last edited by bahnuhr
                                        @boeskij
                                        @Thomas-Braun
                                        So, Installation hat geklappt.
                                        Dann das Script von @boeskij laufen gelassen.
                                        Und es kommt:
                                        javascript.0 (1132) script.js.Scripte.test6: Result: {"result":{"parameter":{"telnr":"017647101234","callerid":"066512345","audiofile":"/tmp/ttsifixalarm","extension":"123456789"},"options":{"action":"originate","channel":"SIP/123456789/017647112324","context":"ael-ansage","exten":"017647103713","priority":1,"timeout":60000,"variable":{"repeat":5,"file":"/tmp/ttsifixalarm","del":""},"callerid":"0665123543"},"guid":"0d47baf8-3fad-b4c3-4ec1-86f81a5d8ad6","result":{"response":"Error","actionid":"0d47baf8-3fad-b4c3-4ec1-86f81a5d8ad6","message":"Originate failed"}},"error":{"response":"Error","actionid":"0d47baf8-3fad-b4c3-4ec1-86f81a5d8ad6","message":"Originate failed"}}
                                        Anruf erfolgte nicht.
                                        Tel. habe ich geändert.
                                        Muss ich jetzt noch deine Auskommentierung machen ?
                                        • bahnuhr
                                          So, habe auch mal die Zeilen auskommentiert.
                                          Aber gleiches Ergebnis.
                                          Test "Originate failed"
                                          -> was immer das zu sagen hat.
                                          Tel. wurde nicht getätigt.
                                            @bahnuhr
                                            Der Anruf sollte normalerweise trotzdem rausgehen.
                                            Was nicht funktionierte waren nur die DTMF-Reaktionen.
                                            116
                                            11029
