    4. ZigBee neue Version 1.5.x
      arteck Developer Most Active @gosund last edited by
      @gosund hättest den Adapter nicht löschen müssen.. zumindest nicht aus der GUI raus
      hintenrum hätte auch gereicht und dir blieben alle Objekte erhalten
        gosund @arteck last edited by
        @arteck
        Zu früh gefreut. Der 1.5.6 Adapter kommt nicht mehr hoch:
        zigbee.0
        2021-06-09 16:15:12.631 info Try to reconnect. 1 attempts left
        zigbee.0
        2021-06-09 16:15:02.627 error Error herdsman start
        zigbee.0
        2021-06-09 16:15:02.626 error Failed to start Zigbee
        zigbee.0
        2021-06-09 16:15:02.624 error Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
        zigbee.0
        2021-06-09 16:14:43.017 info Installed Version: iobroker.zigbee@1.5.6
        zigbee.0
        2021-06-09 16:14:42.721 info Starting Zigbee npm ...
        zigbee.0
        2021-06-09 16:14:42.627 info starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.3.12
        zigbee.0
        2021-06-09 16:14:37.116 error Cannot read property 'getEntries' of null
        zigbee.0
        2021-06-09 16:14:37.115 error TypeError: Cannot read property 'getEntries' of null at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:220:55) at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:240:16) at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:303:31) at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:228:49) at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:222:43) at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:214:42) at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:385:20) at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:696:41) at runMicrotasks (<anonymous>) at processTicksAndRejections (internal/process/task_queues.js:97:5)
        zigbee.0
        2021-06-09 16:14:37.113 error unhandled promise rejection: Cannot read property 'getEntries' of null
        zigbee.0
        2021-06-09 16:14:37.112 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          gosund @gosund last edited by gosund
          @artek
          Was hat es eigentlich mit der PAN Id nach dem Update auf sich?
          Ich hatte diese unverändert auf 6754. Nach den ersten Problemen mit der 1.5.6 und dem Einspielen des Backups behauptete der Adapter im Log, die PAN wäre 6755. Nachdem ich umgestellt hatte, ging es -zumindest für ein paar Stunden.
          Nach der neuerlichen Aktion mit Downgrade auf 1.4.1 und jetzt wieder Update auf 1.5.6 behauptet der Adapter, die PAN Id wäre ist die 6756
          • Asgothian
            Asgothian Developer @gosund last edited by
            @gosund
            Hast du zufällig die verschiedenen nvbackup.json Dateien von den Versionen, in denen erkennbar ist das die panID hochgezählt wird ? Ich gehe davon aus das da etwas in der Konfiguration im Herdsman passiert - Wir brauchen dafür aber die Möglichkeit das nachzustellen.
            Ich kann verstehen wenn Du das mit deinem "live" Zigbee Netz nicht tun willst. In diesem Fall müsstest Du erst einmal auf die 1.4.1 zurück gehen. Ich hoffe immer noch darauf eine zigbee-herdsman version zu finden die
            • mit der 1.5.6 läuft
            • das Problem nicht hat.
            Sobald ich da etwas gefunden habe werde ich einen Link zur Testinstallation bereitstellen.
            A.
              ente34 @Asgothian last edited by
              @asgothian
              Nach Stromausfall kommt zigbee nicht mehr hoch:
              zigbee.0	2021-06-09 19:29:22.325	warn	(3443) Read-only state "zigbee.0.info.pairingMessage" has been written without ack-flag with value "Error: Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null at Function.l
              zigbee.0	2021-06-09 19:29:22.311	error	(3443) Cannot read property 'getEntries' of null
              zigbee.0	2021-06-09 19:29:22.310	error	(3443) TypeError: Cannot read property 'getEntries' of null at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:216:55) at Funct
              zigbee.0	2021-06-09 19:29:22.306	error	(3443) unhandled promise rejection: Cannot read property 'getEntries' of null
              zigbee.0	2021-06-09 19:29:22.305	error	(3443) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              zigbee.0	2021-06-09 19:29:22.304	warn	(3443) Terminated (UNCAUGHT_EXCEPTION): Without reason
              zigbee.0	2021-06-09 19:29:22.302	info	(3443) terminating
              zigbee.0	2021-06-09 19:29:22.300	error	(3443) Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.j
              zigbee.0	2021-06-09 19:29:22.296	info	(3443) Zigbee: disabling joining new devices.
              zigbee.0	2021-06-09 19:29:22.289	info	(3443) cleaned everything up...
              zigbee.0	2021-06-09 19:29:22.279	error	(3443) Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2218746-if00'
              zigbee.0	2021-06-09 19:29:22.278	error	(3443) Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2218746-if00' at Drive
              zigbee.0	2021-06-09 19:29:22.277	error	(3443) unhandled promise rejection: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2218
              zigbee.0	2021-06-09 19:29:22.275	error	(3443) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              zigbee.0	2021-06-09 19:29:01.519	warn	(3443) Read-only state "zigbee.0.info.connection" has been written without ack-flag with value "false"
              zigbee.0	2021-06-09 19:29:01.509	error	(3443) Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2218746-if00' at Drive
              zigbee.0	2021-06-09 19:29:01.508	error	(3443) Failed to start Zigbee
              zigbee.0	2021-06-09 19:29:01.326	info	(3443) Installed Version: iobroker.zigbee@1.5.6
              zigbee.0	2021-06-09 19:29:01.283	info	(3443) Starting Zigbee npm ...
              zigbee.0	2021-06-09 19:29:01.281	info	(3443) Try to reconnect. 1 attempts left
              zigbee.0	2021-06-09 19:28:51.283	warn	(3443) Read-only state "zigbee.0.info.connection" has been written without ack-flag with value "false"
              zigbee.0	2021-06-09 19:28:51.281	error	(3443) Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2218746-if00' at Drive
              zigbee.0	2021-06-09 19:28:51.279	error	(3443) Failed to start Zigbee
              zigbee.0	2021-06-09 19:28:51.106	info	(3443) Installed Version: iobroker.zigbee@1.5.6
              zigbee.0	2021-06-09 19:28:51.101	warn	(3443) Read-only state "zigbee.0.info.connection" has been written without ack-flag with value "false"
              zigbee.0	2021-06-09 19:28:50.914	info	(3443) Starting Zigbee npm ...
              zigbee.0	2021-06-09 19:28:50.821	info	(3443) starting. Version 1.4.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.3.11
              zigbee.0	2021-06-09 19:28:17.833	warn	(3367) Read-only state "zigbee.0.info.pairingMessage" has been written without ack-flag with value "Error: Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null at Function.l
              zigbee.0	2021-06-09 19:28:17.822	error	(3367) Cannot read property 'getEntries' of null
              zigbee.0	2021-06-09 19:28:17.821	error	(3367) TypeError: Cannot read property 'getEntries' of null at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:216:55) at Funct
              zigbee.0	2021-06-09 19:28:17.817	error	(3367) unhandled promise rejection: Cannot read property 'getEntries' of null
              zigbee.0	2021-06-09 19:28:17.816	error	(3367) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              zigbee.0	2021-06-09 19:28:17.815	warn	(3367) Terminated (UNCAUGHT_EXCEPTION): Without reason
              zigbee.0	2021-06-09 19:28:17.813	info	(3367) terminating
              zigbee.0	2021-06-09 19:28:17.808	error	(3367) Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.j
              zigbee.0	2021-06-09 19:28:17.804	info	(3367) Zigbee: disabling joining new devices.
              zigbee.0	2021-06-09 19:28:17.797	info	(3367) cleaned everything up...
              zigbee.0	2021-06-09 19:28:17.783	error	(3367) Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2218746-if00'
              zigbee.0	2021-06-09 19:28:17.782	error	(3367) Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2218746-if00' at Drive
              zigbee.0	2021-06-09 19:28:17.781	error	(3367) unhandled promise rejection: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2218
              zigbee.0	2021-06-09 19:28:17.779	error	(3367) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              zigbee.0	2021-06-09 19:27:57.012	warn	(3367) Read-only state "zigbee.0.info.connection" has been written without ack-flag with value "false"
              zigbee.0	2021-06-09 19:27:57.008	error	(3367) Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2218746-if00' at Drive
              zigbee.0	2021-06-09 19:27:57.007	error	(3367) Failed to start Zigbee
              zigbee.0	2021-06-09 19:27:56.797	info	(3367) Installed Version: iobroker.zigbee@1.5.6
              zigbee.0	2021-06-09 19:27:56.777	info	(3367) Starting Zigbee npm ...
              zigbee.0	2021-06-09 19:27:56.776	info	(3367) Try to reconnect. 1 attempts left
              zigbee.0	2021-06-09 19:27:46.778	warn	(3367) Read-only state "zigbee.0.info.connection" has been written without ack-flag with value "false"
              zigbee.0	2021-06-09 19:27:46.775	error	(3367) Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2218746-if00' at Drive
              zigbee.0	2021-06-09 19:27:46.773	error	(3367) Failed to start Zigbee
              zigbee.0	2021-06-09 19:27:46.630	info	(3367) Installed Version: iobroker.zigbee@1.5.6
              zigbee.0	2021-06-09 19:27:46.626	warn	(3367) Read-only state "zigbee.0.info.connection" has been written without ack-flag with value "false"
              zigbee.0	2021-06-09 19:27:46.394	info	(3367) Starting Zigbee npm ...
              zigbee.0	2021-06-09 19:27:46.294	info	(3367) starting. Version 1.4.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.3.11
              zigbee.0	2021-06-09 19:27:13.360	warn	(3289) Read-only state "zigbee.0.info.pairingMessage" has been written without ack-flag with value "Error: Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null at Function.l
              zigbee.0	2021-06-09 19:27:13.349	error	(3289) Cannot read property 'getEntries' of null
              zigbee.0	2021-06-09 19:27:13.348	error	(3289) TypeError: Cannot read property 'getEntries' of null at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:216:55) at Funct
              zigbee.0	2021-06-09 19:27:13.342	error	(3289) unhandled promise rejection: Cannot read property 'getEntries' of null
              zigbee.0	2021-06-09 19:27:13.341	error	(3289) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              zigbee.0	2021-06-09 19:27:13.340	warn	(3289) Terminated (UNCAUGHT_EXCEPTION): Without reason
              zigbee.0	2021-06-09 19:27:13.338	info	(3289) terminating
              zigbee.0	2021-06-09 19:27:13.336	error	(3289) Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.j
              zigbee.0	2021-06-09 19:27:13.332	info	(3289) Zigbee: disabling joining new devices.
              zigbee.0	2021-06-09 19:27:13.326	info	(3289) cleaned everything up...
              • Asgothian
                Asgothian Developer @ente34 last edited by Asgothian
                @ente34 sagte in ZigBee neue Version 1.5.x:
                Entweder fehlt am Anfang des Logs noch einiges oder der Zigbee Stick ist seit dem Stromausfall defekt:
                Nebenbei hast du mindestens 2 unterschiedliche Zigbee Versionen in deinem Log.
                • Welche version hattest du vor dem Stromausfall aktiv (und am laufen?)
                • Warum hast du gedacht das nach einem Stromausfall ein Update / Downgrade des Zigbee Adapters irgend etwas bewirkt ?
                A.
                  ente34 @Asgothian last edited by ente34
                  @asgothian
                  Habe versuchweise einen Downgrade durchgeführt.
                  Bin jetzt wieder bei 1.5.6
                  Nach reboot mit deaktiviertem Zigbee und dann nachdem alles hochgelaufen ist zigbee aktiviert:
                  zigbee.0	2021-06-09 19:41:24.425	warn	(1903) Read-only state "zigbee.0.info.connection" has been written without ack-flag with value "false"
                  zigbee.0	2021-06-09 19:41:24.423	error	(1903) Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2218746-if00' at Drive
                  zigbee.0	2021-06-09 19:41:24.421	error	(1903) Failed to start Zigbee
                  zigbee.0	2021-06-09 19:41:24.264	info	(1903) Installed Version: iobroker.zigbee@1.5.6
                  zigbee.0	2021-06-09 19:41:24.258	warn	(1903) Read-only state "zigbee.0.info.connection" has been written without ack-flag with value "false"
                  zigbee.0	2021-06-09 19:41:24.053	info	(1903) Starting Zigbee npm ...
                  zigbee.0	2021-06-09 19:41:23.960	info	(1903) starting. Version 1.4.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.3.11
                  host.raspi-iobroker	2021-06-09 19:41:21.617	info	instance system.adapter.zigbee.0 started with pid 1903
                  host.raspi-iobroker	2021-06-09 19:40:51.545	info	Restart adapter system.adapter.zigbee.0 because enabled
                  host.raspi-iobroker	2021-06-09 19:40:51.544	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                  zigbee.0	2021-06-09 19:40:50.950	warn	(1827) Read-only state "zigbee.0.info.pairingMessage" has been written without ack-flag with value "Error: Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null at Function.l
                  zigbee.0	2021-06-09 19:40:50.939	error	(1827) Cannot read property 'getEntries' of null
                  zigbee.0	2021-06-09 19:40:50.938	error	(1827) TypeError: Cannot read property 'getEntries' of null at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:216:55) at Funct
                  zigbee.0	2021-06-09 19:40:50.931	error	(1827) unhandled promise rejection: Cannot read property 'getEntries' of null
                  zigbee.0	2021-06-09 19:40:50.928	error	(1827) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  zigbee.0	2021-06-09 19:40:50.926	warn	(1827) Terminated (UNCAUGHT_EXCEPTION): Without reason
                  zigbee.0	2021-06-09 19:40:50.924	info	(1827) terminating
                  zigbee.0	2021-06-09 19:40:50.922	error	(1827) Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.j
                  zigbee.0	2021-06-09 19:40:50.918	info	(1827) Zigbee: disabling joining new devices.
                  zigbee.0	2021-06-09 19:40:50.912	info	(1827) cleaned everything up...
                  zigbee.0	2021-06-09 19:40:50.901	error	(1827) Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2218746-if00'
                  zigbee.0	2021-06-09 19:40:50.900	error	(1827) Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2218746-if00' at Drive
                  zigbee.0	2021-06-09 19:40:50.899	error	(1827) unhandled promise rejection: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2218
                  zigbee.0	2021-06-09 19:40:50.897	error	(1827) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  zigbee.0	2021-06-09 19:40:30.083	warn	(1827) Read-only state "zigbee.0.info.connection" has been written without ack-flag with value "false"
                  zigbee.0	2021-06-09 19:40:30.078	error	(1827) Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2218746-if00' at Drive
                  zigbee.0	2021-06-09 19:40:30.077	error	(1827) Failed to start Zigbee
                  zigbee.0	2021-06-09 19:40:29.922	info	(1827) Installed Version: iobroker.zigbee@1.5.6
                  zigbee.0	2021-06-09 19:40:29.893	info	(1827) Starting Zigbee npm ...
                  zigbee.0	2021-06-09 19:40:29.892	info	(1827) Try to reconnect. 1 attempts left
                  zigbee.0	2021-06-09 19:40:19.893	warn	(1827) Read-only state "zigbee.0.info.connection" has been written without ack-flag with value "false"
                  zigbee.0	2021-06-09 19:40:19.891	error	(1827) Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2218746-if00' at Drive
                  zigbee.0	2021-06-09 19:40:19.890	error	(1827) Failed to start Zigbee
                  zigbee.0	2021-06-09 19:40:19.728	info	(1827) Installed Version: iobroker.zigbee@1.5.6
                  zigbee.0	2021-06-09 19:40:19.724	warn	(1827) Read-only state "zigbee.0.info.connection" has been written without ack-flag with value "false"
                  zigbee.0	2021-06-09 19:40:19.492	info	(1827) Starting Zigbee npm ...
                  zigbee.0	2021-06-09 19:40:19.377	info	(1827) starting. Version 1.4.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.3.11
                  host.raspi-iobroker	2021-06-09 19:40:16.846	info	instance system.adapter.zigbee.0 started with pid 1827
                  host.raspi-iobroker	2021-06-09 19:40:16.799	info	"system.adapter.zigbee.0" enabled
                  • Asgothian
                    @asgothian
                    Um dem Problem auf den Grund zu gehen musst du heraus bekommen warum der serielle Port nicht mehr verfügbar ist. Das Log sagt eindeutig das symlink nicht existiert.
                    Insbesondere bei Stromausfällen / RaspberryPi Abstürzen / Proxxmox Updates die plötzlich einen laufenden Zigbee Adapter zerlegen ist zu 95% ein Problem mit der Verbindung zum Koordinator die Ursache.
                    A.
                    Nachtrag: Oh Wunder, auch in diesem Log findet sich bei jedem Startversuch die gleiche Meldung:
                    Der Stick wird also immer noch nicht erkannt.
                    E 2 Replies Last reply Reply Quote 0
                      @asgothian
                      Habe einen neuen link 'serial1'
                      pi@raspi-iobroker:~ $ ls -l /dev/serial1
                      lrwxrwxrwx 1 root root 7 Jun  9 19:36 /dev/serial1 -> ttyAMA0
                        @asgothian
                        Erst mal vielen Dank für den schnellen Support!
                          @asgothian
                          @artek
                          Schlechte Nachrichten: Das komplette löschen, installieren und neu Anlernen hat nichts gebracht.
                          Wie die letzten Tage auch hat sich der Adapter wieder innerhalb eines Tages aufgehängt. Ich mußte den Pi wieder komplett rebooten, damit es wieder geht.
                          Hilfe, ich weiß mir absolut nicht mehr zu helfen. Was kann ich noch versuchen?
                            rewenode @gosund last edited by
                            Ich weis echt nicht mehr weiter.
                            Bekomme einfach nicht das Update vom 1.5.5 auf 1.5.6 hin.
                            iob im Docker Container mit 4gb auf einem Rock64
                            node.js - v12.18.3
                            npm - 6.14.6
                            zigbee stick CC2538 + CC2592 von dimaiv
                            Bisher gab es nie die geringsten zigbee Updateprobleme. Nur die 1.5.6 bekomme ich nicht installiert.
                            Hier das Log:
                             01:23:20.786 - info: zigbee.0 (3129) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.3, js-controller: 3.2.16
                            2021-06-11 01:23:21.151 - info: zigbee.0 (3129) Starting Zigbee npm ...
                            2021-06-11 01:23:22.084 - info: zigbee.0 (3129) Installed Version: iobroker.zigbee@1.5.6
                            2021-06-11 01:23:23.678 - error: zigbee.0 (3129) Configuration is not consistent with adapter state/backup!
                            2021-06-11 01:23:23.681 - error: zigbee.0 (3129) - PAN ID: configured=6754, adapter=65535
                            2021-06-11 01:23:23.683 - error: zigbee.0 (3129) - Extended PAN ID: configured=00124b001940c0ba, adapter=0000000000000000
                            2021-06-11 01:23:23.685 - error: zigbee.0 (3129) - Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
                            2021-06-11 01:23:23.686 - error: zigbee.0 (3129) - Channel List: configured=11, adapter=
                            2021-06-11 01:23:23.688 - error: zigbee.0 (3129) Please update configuration to prevent further issues.
                            2021-06-11 01:23:23.689 - error: zigbee.0 (3129) If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
                            2021-06-11 01:23:23.691 - error: zigbee.0 (3129) Re-commissioning your network will require re-pairing of all devices!
                            2021-06-11 01:23:23.694 - error: zigbee.0 (3129) Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
                            2021-06-11 01:23:23.695 - error: zigbee.0 (3129) Failed to start Zigbee
                            2021-06-11 01:23:23.697 - error: zigbee.0 (3129) Error herdsman start
                            2021-06-11 01:23:33.700 - info: zigbee.0 (3129) Try to reconnect. 1 attempts left
                            2021-06-11 01:23:33.702 - info: zigbee.0 (3129) Starting Zigbee npm ...
                            2021-06-11 01:23:33.735 - info: zigbee.0 (3129) Installed Version: iobroker.zigbee@1.5.6
                            2021-06-11 01:23:33.980 - error: zigbee.0 (3129) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                            2021-06-11 01:23:33.982 - error: zigbee.0 (3129) Failed to start Zigbee
                            2021-06-11 01:23:33.984 - error: zigbee.0 (3129) Error herdsman start
                            2021-06-11 01:25:09.693 - info: host.iobroker stopInstance system.adapter.zigbee.0 (force=false, process=true)
                            2021-06-11 01:25:09.717 - info: mqtt.0 (705) send2Server system.adapter.zigbee.0.sigKill[iob/system/adapter/zigbee/0/sigKill]
                            2021-06-11 01:25:09.718 - info: zigbee.0 (3129) Got terminate signal TERMINATE_YOURSELF
                            2021-06-11 01:25:09.723 - info: zigbee.0 (3129) cleaned everything up...
                            2021-06-11 01:25:09.730 - info: zigbee.0 (3129) Zigbee: disabling joining new devices.
                            2021-06-11 01:25:09.733 - warn: zigbee.0 (3129) Failed to stop zigbee during startup
                            2021-06-11 01:25:09.735 - info: zigbee.0 (3129) terminating
                            2021-06-11 01:25:09.737 - info: zigbee.0 (3129) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            2021-06-11 01:25:09.739 - error: zigbee.0 (3129) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            2021-06-11 01:25:09.740 - error: zigbee.0 (3129) unhandled promise rejection: Cannot read property 'getEntries' of null
                            2021-06-11 01:25:09.743 - error: zigbee.0 (3129) TypeError: Cannot read property 'getEntries' of null
                            at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/device.js:220:55)
                            at Function.all (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/device.js:240:16)
                            at Controller.getDevices (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/controller.js:303:31)
                            Was kann ich noch tun ?
                              arteck Developer Most Active @rewenode last edited by
                              @rewenode geh auf version 1.4.1 und dann wieder auf die 1.5.6 gehts dann ?
                                rewenode @arteck last edited by
                                @arteck Reicht da ein Downgrade adapter->Bestimmte version installieren -> 1.4.1 ?
                                Oder muss erst den Adapter (1.5.5) löschen?
                                Und falls löschen, wie kann ich alle meine Geräte behalten ohne alle neu anlernen zu müssen?
                                Sry wenn die Fragen etwas naiv sein sollten. Ich sag ja, bisher reichte ein Knopfdruck und alles neu anlernen wäre hier ziemlich mit Arbeit verbunden bei kleinem Zeitfenster.
                                Jedenfalls schonmal danke für deine Hilfe.
                                  gosund @rewenode last edited by
                                  @arteck @Asgothian
                                  FYI: Hatte gestern Abend auf die 1.5.5 herunter gegraded. Das Problem besteht immer noch: nach ziemlich genau 24 Stunden hängt sich der Adapter auf. Ich mußte den Pi gerade eben wieder booten.
                                  Irgend eine Idee, was ich noch machen kann?
                                  Und nochwas: Seit dem Downgrade bekomme ich ständig folgende Meldung im Log:
                                  zigbee.0 (1671) Failed to DeviceConfigure.onZigbeeEvent (Error: 'LED1623G12' has no configure
                                      at Object.getConfigureKey (/opt/iobroker/node_modules/zigbee-herdsman-converters/lib/configureKey.js:20:15)
                                      at DeviceConfigure.shouldConfigure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:33:38)
                                      at DeviceConfigure.onZigbeeEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:76:22)
                                      at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:196:42)
                                      at ZigbeeController.handleMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:560:14))
                                  Woher kommt LED1623G12? Ich habe alle Devices umbenannt, kann also nicht sagen, welches er meint. Irgend eine Idee?
                                    Rushmed Most Active last edited by Rushmed
                                    ich komme gerade vom Ikea Einkauf und habe zwei kleine Probleme.
                                    Die Fernbedienung STYRBAR wird vom Adapter als W2094 erkannt. Auf dem Gerät steht aber W2044 und in der Anleitung E2002. Das ist erstmal kein Problem für mich, allerdings funktionieren Druck und langer Druck nur bei den links/rechts Tasten. Die anderen beiden Tasten funktionieren garnicht. f750e091-c6d7-4da2-af97-ba27597956bb-grafik.png
                                    Wenn ich STYRBAR direkt mit einer Lampe kopple geht alles.
                                    Wenn ich den Adapter auf debug stelle kommen Tastendrücke an:
                                    zigbee.0	2021-06-12 19:09:59.315	debug	(18506) Publish {"action":"brightness_stop","action_group":901} to "842e14fffe471ae1"
                                    zigbee.0	2021-06-12 19:09:59.300	debug	(18506) Type commandStopWithOnOff device {"type":"device","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"p
                                    zigbee.0	2021-06-12 19:09:59.299	debug	(18506) Received Zigbee message from '0x842e14fffe471ae1', type 'commandStopWithOnOff', cluster 'genLevelCtrl', data '{}' from endpoint 1 with groupID 901
                                    zigbee.0	2021-06-12 19:09:59.297	debug	(18506) handleMessage. {"type":"commandStopWithOnOff","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profi
                                    zigbee.0	2021-06-12 19:09:58.939	debug	(18506) Publish {"action":"brightness_move_down","action_rate":83,"action_group":901} to "842e14fffe471ae1"
                                    zigbee.0	2021-06-12 19:09:58.926	debug	(18506) Type commandMove device {"type":"device","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID"
                                    zigbee.0	2021-06-12 19:09:58.926	debug	(18506) Received Zigbee message from '0x842e14fffe471ae1', type 'commandMove', cluster 'genLevelCtrl', data '{"movemode":1,"rate":83}' from endpoint 1 with groupID 901
                                    zigbee.0	2021-06-12 19:09:58.924	debug	(18506) handleMessage. {"type":"commandMove","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260
                                    zigbee.0	2021-06-12 19:09:57.127	debug	(18506) Publish {"action":"brightness_stop","action_group":901} to "842e14fffe471ae1"
                                    zigbee.0	2021-06-12 19:09:57.116	debug	(18506) Type commandStopWithOnOff device {"type":"device","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"p
                                    zigbee.0	2021-06-12 19:09:57.114	debug	(18506) Received Zigbee message from '0x842e14fffe471ae1', type 'commandStopWithOnOff', cluster 'genLevelCtrl', data '{}' from endpoint 1 with groupID 901
                                    zigbee.0	2021-06-12 19:09:57.113	debug	(18506) handleMessage. {"type":"commandStopWithOnOff","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profi
                                    zigbee.0	2021-06-12 19:09:56.660	debug	(18506) Publish {"action":"brightness_move_up","action_rate":83,"action_group":901} to "842e14fffe471ae1"
                                    zigbee.0	2021-06-12 19:09:56.644	debug	(18506) Type commandMoveWithOnOff device {"type":"device","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"p
                                    zigbee.0	2021-06-12 19:09:56.643	debug	(18506) Received Zigbee message from '0x842e14fffe471ae1', type 'commandMoveWithOnOff', cluster 'genLevelCtrl', data '{"movemode":0,"rate":83}' from endpoint 1 with groupID 901
                                    zigbee.0	2021-06-12 19:09:56.640	debug	(18506) handleMessage. {"type":"commandMoveWithOnOff","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profi
                                    zigbee.0	2021-06-12 19:09:54.926	debug	(18506) Publish {"action":"on","action_group":901} to "842e14fffe471ae1"
                                    zigbee.0	2021-06-12 19:09:54.917	debug	(18506) Type commandOn device {"type":"device","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":2
                                    zigbee.0	2021-06-12 19:09:54.916	debug	(18506) Received Zigbee message from '0x842e14fffe471ae1', type 'commandOn', cluster 'genOnOff', data '{}' from endpoint 1 with groupID 901
                                    zigbee.0	2021-06-12 19:09:54.915	debug	(18506) handleMessage. {"type":"commandOn","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260,"
                                    zigbee.0	2021-06-12 19:09:53.737	debug	(18506) Publish {"action":"arrow_right_click"} to "842e14fffe471ae1"
                                    zigbee.0	2021-06-12 19:09:53.720	debug	(18506) Type commandTradfriArrowSingle device {"type":"device","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID"
                                    zigbee.0	2021-06-12 19:09:53.719	debug	(18506) Received Zigbee message from '0x842e14fffe471ae1', type 'commandTradfriArrowSingle', cluster 'genScenes', data '{"value":256,"value2":13}' from endpoint 1 with groupID 901
                                    zigbee.0	2021-06-12 19:09:53.715	debug	(18506) handleMessage. {"type":"commandTradfriArrowSingle","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"
                                    zigbee.0	2021-06-12 19:09:52.576	debug	(18506) Publish {"action":"off","action_group":901} to "842e14fffe471ae1"
                                    zigbee.0	2021-06-12 19:09:52.563	debug	(18506) Type commandOff device {"type":"device","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":
                                    zigbee.0	2021-06-12 19:09:52.561	debug	(18506) Received Zigbee message from '0x842e14fffe471ae1', type 'commandOff', cluster 'genOnOff', data '{}' from endpoint 1 with groupID 901
                                    zigbee.0	2021-06-12 19:09:52.558	debug	(18506) handleMessage. {"type":"commandOff","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260,
                                    zigbee.0	2021-06-12 19:09:51.208	debug	(18506) Publish {"action":"arrow_left_click"} to "842e14fffe471ae1"
                                    zigbee.0	2021-06-12 19:09:51.199	debug	(18506) Type commandTradfriArrowSingle device {"type":"device","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID"
                                    zigbee.0	2021-06-12 19:09:51.196	debug	(18506) Received Zigbee message from '0x842e14fffe471ae1', type 'commandTradfriArrowSingle', cluster 'genScenes', data '{"value":257,"value2":13}' from endpoint 1 with groupID 901
                                    zigbee.0	2021-06-12 19:09:51.194	debug	(18506) handleMessage. {"type":"commandTradfriArrowSingle","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"
                                    Der Timeout für die Erkennung des langen Drucks ist mit ca. 3 s auch sehr lang, kann man das irgendwo verstellen? Das ist zum Beispiel bei E1743 nur ca. 1 s, was viel besser passt.
                                    Dann habe ich noch eine LED1924G9, die funktioniert soweit, außer die Effekte. Da tut sich garnichts.
                                    Hat da jemand einen Tipp für mich?
                                    L arteck 2 Replies Last reply Reply Quote 0
                                      locito09 @Rushmed last edited by
                                      @rushmed
                                      hast du probiert das Gerät auszuschliessen?
                                        Rushmed Most Active @locito09 last edited by Rushmed
                                        @locito09 Wie ausschließen? Im Adapter? Nein.
                                        Edit: Habs probiert, geht nicht.
                                          @gosund da sist der Technische name .. nicht dein umbenanntess.das kannst du in der Kachel sehen ..wenn du die umdrehst
                                            Frank579 @arteck last edited by
                                            @Asgothian
                                            Habe gerade mein bastelsystem hochgezogen auf Admin5.
                                            Er spuckt mir jetzt für einige Geräte
                                            zigbee.0
                                            2021-06-13 09:52:06.290	warn	State value to set for "zigbee.0.0017880108279caf.link_quality" has value "255" greater than max "254"
                                            ins Log.
                                            Ist das schon bekannt?
                                            31.7k
                                            79.9k
                                            579
                                            111076
