    4. Asterisk bringt "Error while dialing (2). Error: {}"
    • bahnuhr
      bahnuhr Forum Testing Most Active last edited by bahnuhr
      Im debug kommt:
      asterisk.0	2021-06-09 20:23:57.572	debug	(11448) sendTo "dial" to system.adapter.javascript.0 from system.adapter.asterisk.0
      asterisk.0	2021-06-09 20:23:57.571	debug	(11448) Calling callback function: (res, err) => { adapter.sendTo(msg.from, msg.command, { result: res, error: err }, msg.callback); }
      asterisk.0	2021-06-09 20:23:57.570	error	(11448) Error while dialing (1). Error: {"response":"Error","actionid":"9ef349c2-d53f-ca4e-1a24-caa343e23b19","message":"Originate failed"}, Result: {"parameter":{"telnr":"0176471123123","callerid":"06
      asterisk.0	2021-06-09 20:23:56.563	info	(11448) Start dialing
      asterisk.0	2021-06-09 20:23:56.563	debug	(11448) Got GSM audio file /tmp/ttsifixalarm.gsm
      asterisk.0	2021-06-09 20:23:56.562	debug	(11448) Parameter: {"telnr":"017sdfsdf","callerid":"066512313","audiofile":"/tmp/ttsifixalarm","extension":"123456789"}
      asterisk.0	2021-06-09 20:23:56.561	debug	(11448) Dial Command
      asterisk.0	2021-06-09 20:23:56.560	debug	(11448) Message: {"telnr":"017sdfsdfsdf","callerid":"0665123123","audiofile":"/tmp/ttsifixalarm.gsm"}
      asterisk.0	2021-06-09 20:23:56.558	debug	(11448) Connected to Asterisk
      Tel.Nr. wieder geändert.
      • bahnuhr
        Über putty kam dies:
        root@VM-iobroker:/opt/iobroker# asterisk -rvvvvvv
        Asterisk 16.2.1~dfsg-1+deb10u2, Copyright (C) 1999 - 2018, Digium, Inc. and others.
        Created by Mark Spencer <markster@digium.com>
        Asterisk comes with ABSOLUTELY NO WARRANTY; type 'core show warranty' for details.
        This is free software, with components licensed under the GNU General Public
        License version 2 and other licenses; you are welcome to redistribute it under
        certain conditions. Type 'core show license' for details.
        Connected to Asterisk 16.2.1~dfsg-1+deb10u2 currently running on VM-iobroker (pid = 402)
          == Manager 'manager' logged off from 192.168.243.12
          == Manager 'manager' logged on from 192.168.243.12
        [Jun  9 20:23:56] WARNING[11463]: chan_sip.c:6331 create_addr: Purely numeric hostname (123456789), and not a peer--rejecting!
            -- Executing [failed@ael-ansage:1] Answer("OutgoingSpoolFailed", "") in new stack
            -- Executing [failed@ael-ansage:2] Wait("OutgoingSpoolFailed", "1") in new stack
            -- Executing [failed@ael-ansage:3] Read("OutgoingSpoolFailed", "dtmf,/tmp/ttsifixalarm&beep,0,s,5,1") in new stack
            -- Executing [failed@ael-ansage:4] GotoIf("OutgoingSpoolFailed", "0?5:6") in new stack
            -- Goto (ael-ansage,failed,6)
            -- Executing [failed@ael-ansage:6] NoOp("OutgoingSpoolFailed", "Finish if_ael-ansage_1") in new stack
            -- Executing [failed@ael-ansage:7] Hangup("OutgoingSpoolFailed", "") in new stack
          == Spawn extension (ael-ansage, failed, 7) exited non-zero on 'OutgoingSpoolFailed'
            -- Executing [h@ael-ansage:1] GotoIf("OutgoingSpoolFailed", "0?2:4") in new stack
            -- Goto (ael-ansage,h,4)
            -- Executing [h@ael-ansage:4] NoOp("OutgoingSpoolFailed", "Finish if_ael-ansage_2") in new stack
            -- Executing [h@ael-ansage:5] SayDigits("OutgoingSpoolFailed", "") in new stack
            -- Executing [h@ael-ansage:6] NoOp("OutgoingSpoolFailed", "Finish if_ael-ansage_1") in new stack
            -- Executing [h@ael-ansage:7] Hangup("OutgoingSpoolFailed", "") in new stack
          == Spawn extension (ael-ansage, h, 7) exited non-zero on 'OutgoingSpoolFailed'
        VM-iobroker*CLI>
        Thomas Braun B 2 Replies Last reply Reply Quote 0
          Thomas Braun Most Active @bahnuhr last edited by Thomas Braun
          @bahnuhr
          Du solltest keine root shell offen haben.
            boeskij @bahnuhr last edited by
            @bahnuhr
            nun bin ich raus...
            die Asterisk-Instanz hat aber schon mal gelaufen?
            Die CallerId im Schnippsel stimmt?
            sendTo('asterisk.0', "dial", { telnr: TELNR, callerid: CALLERID, audiofile: AUDIOFILE},  (res) => { ...
            • bahnuhr
              bahnuhr Forum Testing Most Active @boeskij last edited by
              @boeskij sagte in Asterisk bringt "Error while dialing (2). Error: {}":
              Nein
              ich lass diese mal weg.
              • bahnuhr
                so, keine Veränderung.
                Es kommt immer:
                "Originate failed"
                  @bahnuhr
                  Angebunden nach Anleitung an eine Fritzbox?
                  Beantwortet der iobroker einen eingehenden Anruf (wenn auch nur mit "beep" da die TTS-Datei nicht erzeugt werden kann)?
                  • bahnuhr
                    Ich denke schon, manager ist logged on
                    Weiß ich jetzt nicht, wie und was ich da machen soll.
                      @bahnuhr
                      Für den Asterisk musste auf der Fritzbox eine SIP-Nebenstelle eingerichtet werden.
                      Diese hat mindestens eine interne Rufnummer, ggf. auch eine externe Rufnummer.
                      Die einfach mal anrufen und schauen was passiert
                      • bahnuhr
                        @bahnuhr
                        Ja, sip nach Anleitung.
                        Nummer hab ich mit meinem Handy mal angerufen.
                        Alle Telefone klingeln.
                        Der Fritzbox Adapter reagiert.
                        Aber Astersik nicht.
                          @bahnuhr
                          dann würde ich mal behaupten passt da etwas in deiner Konfig nicht...
                          das "Manager logged on/off" bedeutet nur, dass der Asterisk-Adapter sich mit dem Asterisk verbunden hat.
                          Vorher muss sich der Asterisk ja noch mit der Fritzbox verbinden, vermutlich tut er das gar nicht
                          Am besten nochmal alles kontrollieren, die Konfig-Dateien neu erzeugen und ganz wichtig: Asterisk neustarten und danach den Asterist-Adapter neustarten
                          • bahnuhr
                            @boeskij
                            Oh je, das hab ich schon mehrfach gemacht.
                            Aber ich gehe es nochmal durch.
                            Langsam weiß ich nicht mehr weiter.
                            mfg
                            • bahnuhr
                              So, erst einmal Danke für eure Unterstützung.
                              Aber, ich bekomme es nicht hin.
                              Alles nochmal durchgegangen.
                              Irgendwo ist was falsch.
                              Ich finde es aber nicht.
                              mfg
                              Dieter
                                @bahnuhr sagte in Asterisk bringt "Error while dialing (2). Error: {}":
                                Ja, dein login prompt.
                                bahnuhr 1 Reply Last reply Reply Quote 1
                                  boeskij last edited by boeskij
                                  So sollte das iobroker-Log beim Starten des Asterisk-Adapters aussehen:
                                  asterisk.0	2021-06-09 21:10:23.889	error	(2005) Error while Converting File: {}
                                  asterisk.0	2021-06-09 21:10:23.107	info	(2005) Connected to Asterisk Manager
                                  asterisk.0	2021-06-09 21:10:23.075	info	(2005) Starting Adapter asterisk.0 in version 1.0.6 with transcoder ffmpeg and language DE
                                  asterisk.0	2021-06-09 21:10:22.956	info	(2005) starting. Version 1.0.6 in /opt/iobroker/node_modules/iobroker.asterisk, node: v10.24.0, js-controller: 3.2.16
                                  Die Meldung "Error while Converting File: {}" ist das angesprochene Problem, dass beim Starten versucht wird die asterisk_dtmf für Dial-In-Calls zu erzeugen
                                  Bei einem eingehenden Anruf (ich habs über die interne Rufnummer versucht) sehe ich im putty mit "asterisk -rvvvvv"
                                    == Using SIP RTP CoS mark 5
                                         > 0x28e2bc8 -- Strict RTP learning after remote address set to: 192.168.178.20:7080
                                      -- Executing [1000@default:1] Goto("SIP/iobroker-00000002", "ael-antwort,s,1") in new stack
                                      -- Goto (ael-antwort,s,1)
                                      -- Executing [s@ael-antwort:1] Answer("SIP/iobroker-00000002", "") in new stack
                                         > 0x28e2bc8 -- Strict RTP switching to RTP target address 192.168.178.20:7080 as source
                                      -- Executing [s@ael-antwort:2] Wait("SIP/iobroker-00000002", "1") in new stack
                                      -- Executing [s@ael-antwort:3] Set("SIP/iobroker-00000002", "repeat=5") in new stack
                                      -- Executing [s@ael-antwort:4] Read("SIP/iobroker-00000002", "dtmf,/tmp//asterisk_dtmf&beep,0,s,5,1") in new stack
                                  [Jun  9 21:23:43] WARNING[2329][C-00000002]: file.c:774 ast_openstream_full: File /tmp//asterisk_dtmf does not exist in any format
                                  [Jun  9 21:23:43] WARNING[2329][C-00000002]: file.c:1247 ast_streamfile: Unable to open /tmp//asterisk_dtmf (format (ulaw)): No such file or directory
                                      -- <SIP/iobroker-00000002> Playing 'beep.gsm' (language 'en')
                                         > 0x28e2bc8 -- Strict RTP learning complete - Locking on source address 192.168.178.20:7080
                                      -- User entered nothing, 4 chances left
                                  [Jun  9 21:23:44] WARNING[2329][C-00000002]: file.c:774 ast_openstream_full: File /tmp//asterisk_dtmf does not exist in any format
                                  [Jun  9 21:23:44] WARNING[2329][C-00000002]: file.c:1247 ast_streamfile: Unable to open /tmp//asterisk_dtmf (format (ulaw)): No such file or directory
                                      -- User entered nothing, 3 chances left
                                  [Jun  9 21:23:46] WARNING[2329][C-00000002]: file.c:774 ast_openstream_full: File /tmp//asterisk_dtmf does not exist in any format
                                  [Jun  9 21:23:46] WARNING[2329][C-00000002]: file.c:1247 ast_streamfile: Unable to open /tmp//asterisk_dtmf (format (ulaw)): No such file or directory
                                      -- User entered nothing, 2 chances left
                                  [Jun  9 21:23:47] WARNING[2329][C-00000002]: file.c:774 ast_openstream_full: File /tmp//asterisk_dtmf does not exist in any format
                                  [Jun  9 21:23:47] WARNING[2329][C-00000002]: file.c:1247 ast_streamfile: Unable to open /tmp//asterisk_dtmf (format (ulaw)): No such file or directory
                                      -- User entered nothing, 1 chance left
                                  [Jun  9 21:23:49] WARNING[2329][C-00000002]: file.c:774 ast_openstream_full: File /tmp//asterisk_dtmf does not exist in any format
                                  [Jun  9 21:23:49] WARNING[2329][C-00000002]: file.c:1247 ast_streamfile: Unable to open /tmp//asterisk_dtmf (format (ulaw)): No such file or directory
                                      -- User entered nothing.
                                      -- Executing [s@ael-antwort:5] GotoIf("SIP/iobroker-00000002", "0?6:7") in new stack
                                      -- Goto (ael-antwort,s,7)
                                      -- Executing [s@ael-antwort:7] NoOp("SIP/iobroker-00000002", "Finish if_ael-antwort_9") in new stack
                                      -- Executing [s@ael-antwort:8] Hangup("SIP/iobroker-00000002", "") in new stack
                                    == Spawn extension (ael-antwort, s, 8) exited non-zero on 'SIP/iobroker-00000002'
                                      -- Executing [h@ael-antwort:1] Goto("SIP/iobroker-00000002", "ael-antwort,s,1") in new stack
                                    == Spawn extension (ael-antwort, s, 1) exited non-zero on 'SIP/iobroker-00000002'
                                  raspberrypi*CLI>
                                  Da die Datei nicht erzeugt wurde kann sie natürlich auch nicht gefunden und abgespielt werden, also hört man nur das "beep"
                                  Die sip.conf sieht bei mir so aus:
                                  [general]                               ; Do not change
                                  port = 5060                             ; Do not change
                                  bindaddr = 0.0.0.0                      ; Do not change
                                  context = default                       ; Do not change
                                  subscribecontext = default              ; Do not change
                                  register => iobroker:einPasswort@192.168.178.20/1000 ; Username, Password and IP address of Fritzbox WLAN/LAN telephone
                                  [iobroker]                              ; Change to username of Fritzbox WLAN/LAN telephone
                                  type = friend                           ; Do not change
                                  username = iobroker                     ; Change to username of Fritzbox WLAN/LAN telephone
                                  host = 192.168.178.20                   ; Change hostname / IP address of Fritzbox
                                  secret = einPasswort         ; Change password of Fritzbox WLAN/LAN telephone
                                  fromdomain =  192.168.178.20            ; Change hostname / IP address of Fritzbox
                                  fromuser = iobroker             ; Change username of Fritzbox WLAN/LAN telephone
                                  • bahnuhr
                                    bahnuhr Forum Testing Most Active @Thomas Braun last edited by
                                    @thomas-braun sagte in Asterisk bringt "Error while dialing (2). Error: {}":
                                    Lt. Anleitung stolpere ich immer über diesen Punkt
                                    Was heißt das ?
                                    Muss ich einen neuen Benutzer anlegen mit einer Zahl.
                                    Geht aber in meiner FB7490 nicht (diese verlangt am Anfang einen Buchstaben).
                                    Könnte dies das Problem sein ?
                                    • bahnuhr
                                      Start Adapter:
                                      asterisk.0	2021-06-09 21:35:58.998	error	(13563) Error while Converting File: {}
                                      asterisk.0	2021-06-09 21:35:58.388	info	(13563) Connected to Asterisk Manager
                                      asterisk.0	2021-06-09 21:35:58.373	info	(13563) Starting Adapter asterisk.0 in version 1.0.6 with transcoder ffmpeg and language DE
                                      asterisk.0	2021-06-09 21:35:58.287	info	(13563) starting. Version 1.0.6 in /opt/iobroker/node_modules/iobroker.asterisk, node: v12.21.0, js-controller: 3.2.16
                                      passt mit deinem überein.
                                      • bahnuhr
                                        Nachtrag:
                                        Wenn ich mit meinem Fritzfon die interne Nr. anrufen kommt:
                                        ...keine Verbindung...
                                        Und in putty wird auch nichts angezeigt.
                                          @bahnuhr said in Asterisk bringt "Error while dialing (2). Error: {}":
                                          Bei mir funktioniert es mit einem Benutzernamen der nur aus Buchstaben besteht...
                                          zeig mal deine sip.conf
                                          • bahnuhr
                                            Ich habe 2
                                            • sip.conf
                                            • sip_fritzbox.conf
                                            Zeigen aber beide das gleiche:
                                            register => 123456789:abcde16@192.168.243.1/1000 ; Username, Password and IP address of Fritzbox WLAN/LAN telephone
                                            [123456789]               		; Change to username of Fritzbox WLAN/LAN telephone
                                            username = 123456789      		; Change to username of Fritzbox WLAN/LAN telephone
                                            host = 192.168.243.1          		; Change hostname / IP address of Fritzbox
                                            secret = abcde16         ; Change password of Fritzbox WLAN/LAN telephone
                                            fromdomain =  192.168.243.1  		; Change hostname / IP address of Fritzbox
                                            fromuser = 123456789   	  	; Change username of Fritzbox WLAN/LAN telephone
                                            116
                                            11033
