    4. Asterisk bringt "Error while dialing (2). Error: {}"
      boeskij last edited by boeskij
      So sollte das iobroker-Log beim Starten des Asterisk-Adapters aussehen:
      asterisk.0	2021-06-09 21:10:23.889	error	(2005) Error while Converting File: {}
      asterisk.0	2021-06-09 21:10:23.107	info	(2005) Connected to Asterisk Manager
      asterisk.0	2021-06-09 21:10:23.075	info	(2005) Starting Adapter asterisk.0 in version 1.0.6 with transcoder ffmpeg and language DE
      asterisk.0	2021-06-09 21:10:22.956	info	(2005) starting. Version 1.0.6 in /opt/iobroker/node_modules/iobroker.asterisk, node: v10.24.0, js-controller: 3.2.16
      Die Meldung "Error while Converting File: {}" ist das angesprochene Problem, dass beim Starten versucht wird die asterisk_dtmf für Dial-In-Calls zu erzeugen
      Bei einem eingehenden Anruf (ich habs über die interne Rufnummer versucht) sehe ich im putty mit "asterisk -rvvvvv"
        == Using SIP RTP CoS mark 5
             > 0x28e2bc8 -- Strict RTP learning after remote address set to: 192.168.178.20:7080
          -- Executing [1000@default:1] Goto("SIP/iobroker-00000002", "ael-antwort,s,1") in new stack
          -- Goto (ael-antwort,s,1)
          -- Executing [s@ael-antwort:1] Answer("SIP/iobroker-00000002", "") in new stack
             > 0x28e2bc8 -- Strict RTP switching to RTP target address 192.168.178.20:7080 as source
          -- Executing [s@ael-antwort:2] Wait("SIP/iobroker-00000002", "1") in new stack
          -- Executing [s@ael-antwort:3] Set("SIP/iobroker-00000002", "repeat=5") in new stack
          -- Executing [s@ael-antwort:4] Read("SIP/iobroker-00000002", "dtmf,/tmp//asterisk_dtmf&beep,0,s,5,1") in new stack
      [Jun  9 21:23:43] WARNING[2329][C-00000002]: file.c:774 ast_openstream_full: File /tmp//asterisk_dtmf does not exist in any format
      [Jun  9 21:23:43] WARNING[2329][C-00000002]: file.c:1247 ast_streamfile: Unable to open /tmp//asterisk_dtmf (format (ulaw)): No such file or directory
          -- <SIP/iobroker-00000002> Playing 'beep.gsm' (language 'en')
             > 0x28e2bc8 -- Strict RTP learning complete - Locking on source address 192.168.178.20:7080
          -- User entered nothing, 4 chances left
      [Jun  9 21:23:44] WARNING[2329][C-00000002]: file.c:774 ast_openstream_full: File /tmp//asterisk_dtmf does not exist in any format
      [Jun  9 21:23:44] WARNING[2329][C-00000002]: file.c:1247 ast_streamfile: Unable to open /tmp//asterisk_dtmf (format (ulaw)): No such file or directory
          -- User entered nothing, 3 chances left
      [Jun  9 21:23:46] WARNING[2329][C-00000002]: file.c:774 ast_openstream_full: File /tmp//asterisk_dtmf does not exist in any format
      [Jun  9 21:23:46] WARNING[2329][C-00000002]: file.c:1247 ast_streamfile: Unable to open /tmp//asterisk_dtmf (format (ulaw)): No such file or directory
          -- User entered nothing, 2 chances left
      [Jun  9 21:23:47] WARNING[2329][C-00000002]: file.c:774 ast_openstream_full: File /tmp//asterisk_dtmf does not exist in any format
      [Jun  9 21:23:47] WARNING[2329][C-00000002]: file.c:1247 ast_streamfile: Unable to open /tmp//asterisk_dtmf (format (ulaw)): No such file or directory
          -- User entered nothing, 1 chance left
      [Jun  9 21:23:49] WARNING[2329][C-00000002]: file.c:774 ast_openstream_full: File /tmp//asterisk_dtmf does not exist in any format
      [Jun  9 21:23:49] WARNING[2329][C-00000002]: file.c:1247 ast_streamfile: Unable to open /tmp//asterisk_dtmf (format (ulaw)): No such file or directory
          -- User entered nothing.
          -- Executing [s@ael-antwort:5] GotoIf("SIP/iobroker-00000002", "0?6:7") in new stack
          -- Goto (ael-antwort,s,7)
          -- Executing [s@ael-antwort:7] NoOp("SIP/iobroker-00000002", "Finish if_ael-antwort_9") in new stack
          -- Executing [s@ael-antwort:8] Hangup("SIP/iobroker-00000002", "") in new stack
        == Spawn extension (ael-antwort, s, 8) exited non-zero on 'SIP/iobroker-00000002'
          -- Executing [h@ael-antwort:1] Goto("SIP/iobroker-00000002", "ael-antwort,s,1") in new stack
        == Spawn extension (ael-antwort, s, 1) exited non-zero on 'SIP/iobroker-00000002'
      raspberrypi*CLI>
      Da die Datei nicht erzeugt wurde kann sie natürlich auch nicht gefunden und abgespielt werden, also hört man nur das "beep"
      Die sip.conf sieht bei mir so aus:
      [general]                               ; Do not change
      port = 5060                             ; Do not change
      bindaddr = 0.0.0.0                      ; Do not change
      context = default                       ; Do not change
      subscribecontext = default              ; Do not change
      register => iobroker:einPasswort@192.168.178.20/1000 ; Username, Password and IP address of Fritzbox WLAN/LAN telephone
      [iobroker]                              ; Change to username of Fritzbox WLAN/LAN telephone
      type = friend                           ; Do not change
      username = iobroker                     ; Change to username of Fritzbox WLAN/LAN telephone
      host = 192.168.178.20                   ; Change hostname / IP address of Fritzbox
      secret = einPasswort         ; Change password of Fritzbox WLAN/LAN telephone
      fromdomain =  192.168.178.20            ; Change hostname / IP address of Fritzbox
      fromuser = iobroker             ; Change username of Fritzbox WLAN/LAN telephone
      • bahnuhr
        bahnuhr Forum Testing Most Active @Thomas Braun last edited by
        @thomas-braun sagte in Asterisk bringt "Error while dialing (2). Error: {}":
        @bahnuhr sagte in Asterisk bringt "Error while dialing (2). Error: {}":
        Irgendwo ist was falsch.
        Ja, dein login prompt.
        Lt. Anleitung stolpere ich immer über diesen Punkt
        Was heißt das ?
        Muss ich einen neuen Benutzer anlegen mit einer Zahl.
        Geht aber in meiner FB7490 nicht (diese verlangt am Anfang einen Buchstaben).
        Könnte dies das Problem sein ?
        • bahnuhr
          Start Adapter:
          asterisk.0	2021-06-09 21:35:58.998	error	(13563) Error while Converting File: {}
          asterisk.0	2021-06-09 21:35:58.388	info	(13563) Connected to Asterisk Manager
          asterisk.0	2021-06-09 21:35:58.373	info	(13563) Starting Adapter asterisk.0 in version 1.0.6 with transcoder ffmpeg and language DE
          asterisk.0	2021-06-09 21:35:58.287	info	(13563) starting. Version 1.0.6 in /opt/iobroker/node_modules/iobroker.asterisk, node: v12.21.0, js-controller: 3.2.16
          passt mit deinem überein.
          • bahnuhr
            Nachtrag:
            Wenn ich mit meinem Fritzfon die interne Nr. anrufen kommt:
            ...keine Verbindung...
            Und in putty wird auch nichts angezeigt.
              boeskij @bahnuhr last edited by
              @bahnuhr said in Asterisk bringt "Error while dialing (2). Error: {}":
              Bei mir funktioniert es mit einem Benutzernamen der nur aus Buchstaben besteht...
              zeig mal deine sip.conf
              • bahnuhr
                bahnuhr Forum Testing Most Active @boeskij last edited by
                @boeskij sagte in Asterisk bringt "Error while dialing (2). Error: {}":
                Ich habe 2
                • sip.conf
                • sip_fritzbox.conf
                Zeigen aber beide das gleiche:
                register => 123456789:abcde16@192.168.243.1/1000 ; Username, Password and IP address of Fritzbox WLAN/LAN telephone
                [123456789]               		; Change to username of Fritzbox WLAN/LAN telephone
                username = 123456789      		; Change to username of Fritzbox WLAN/LAN telephone
                host = 192.168.243.1          		; Change hostname / IP address of Fritzbox
                secret = abcde16         ; Change password of Fritzbox WLAN/LAN telephone
                fromdomain =  192.168.243.1  		; Change hostname / IP address of Fritzbox
                fromuser = 123456789   	  	; Change username of Fritzbox WLAN/LAN telephone
                • bahnuhr
                  Und in der FB hab ich dies:
                  Und dies habe ich auch im Adapter eingegeben.
                    @bahnuhr Das sieht erstmal nicht verkehrt aus...
                    ggf. sonst mal einen Benutzernamen aus Buchstaben versuchen? Bei mir funktioniert es ja damit...
                    Ich habe 2
                    • sip.conf
                    • sip_fritzbox.conf
                    Warum 2?
                    Die erstellte sip_fritzbox.conf wird laut Anleitung verschoben und umbenannt:
                    sudo mv /tmp/sip_fritzbox.conf /etc/asterisk/sip.conf
                    Das Kopieren und das Neustarten wurden auch nach Anleitung gemacht?
                    • bahnuhr
                      @boeskij
                      Ichprobier das morgen mal aus.
                      Muss nun in Bett.
                      mfg
                      • bahnuhr
                        So, habe in der sip.conf mal
                        register => iobroker:abcde16@192.168.243.1/1000 ; Username, Password and IP address of Fritzbox WLAN/LAN telephone
                        eingegeben.
                        Wenn ich die Instanz neu starte sind man in putty, dass versucht wird eine Verbindung aufzubauen.
                        Connected to Asterisk 16.2.1~dfsg-1+deb10u2 currently running on VM-iobroker (pid = 14402)
                        [Jun  9 22:05:01] NOTICE[14463]: chan_sip.c:15981 sip_reg_timeout:    -- Registration for 'iobroker@192.168.243.1' timed out, trying again (Attempt #9)
                          == Manager 'manager' logged off from 192.168.243.12
                          == Manager 'manager' logged on from 192.168.243.12
                        [Jun  9 22:05:21] NOTICE[14463]: chan_sip.c:15981 sip_reg_timeout:    -- Registration for 'iobroker@192.168.243.1' timed out, trying again (Attempt #10)
                        [Jun  9 22:05:41] NOTICE[14463]: chan_sip.c:15981 sip_reg_timeout:    -- Registration for 'iobroker@192.168.243.1' timed out, trying again (Attempt #11)
                        [Jun  9 22:06:01] NOTICE[14463]: chan_sip.c:15981 sip_reg_timeout:    -- Registration for 'iobroker@192.168.243.1' timed out, trying again (Attempt #12)
                        [Jun  9 22:06:21] NOTICE[14463]: chan_sip.c:15981 sip_reg_timeout:    -- Registration for 'iobroker@192.168.243.1' timed out, trying again (Attempt #13)
                        [Jun  9 22:06:41] NOTICE[14463]: chan_sip.c:15981 sip_reg_timeout:    -- Registration for 'iobroker@192.168.243.1' timed out, trying again (Attempt #14)
                        [Jun  9 22:07:01] NOTICE[14463]: chan_sip.c:15981 sip_reg_timeout:    -- Registration for 'iobroker@192.168.243.1' timed out, trying again (Attempt #15)
                        [Jun  9 22:07:21] NOTICE[14463]: chan_sip.c:15981 sip_reg_timeout:    -- Registration for 'iobroker@192.168.243.1' timed out, trying again (Attempt #16)
                        [Jun  9 22:07:41] NOTICE[14463]: chan_sip.c:15981 sip_reg_timeout:    -- Registration for 'iobroker@192.168.243.1' timed out, trying again (Attempt #17)
                        [Jun  9 22:08:01] NOTICE[14463]: chan_sip.c:15981 sip_reg_timeout:    -- Registration for 'iobroker@192.168.243.1' timed out, trying again (Attempt #18)
                        Und dies klappt wohl nicht.
                        Aber warum ?
                          @bahnuhr weil der Username noch an weiteren Stellen in der sip.conf steht und natürlich auch in der Fritzbox angepasst werden muss
                          • bahnuhr
                            So, mal kurze Rückinfo von mir.
                            Ich habe nun alle möglichen Konstellationen probiert.
                            Asterisk kann sich wohl nicht an der FB7490 anmelden.
                            Für mich ist nun Schluss.
                            Ich bekomme dies nicht hin.
                            Trotzdem Danke für die Mühe.
                            Vielleicht könnte sich ja doch mal der Entwickler dazu bewegen, dass dies vernünftig läuft.
                            mfg
                            Dieter
                            • bahnuhr
                              Jaaaaaaaaaaaaa.
                              Es klappt.
                              Habe mehrere threads gelesen und viel gegoogelt.
                              Irgendwo hat einer geschrieben, dass man die Fritzbox mal neu starten soll.
                              Und dies war die Lösung.
                              Lag letztendlich an der FB.
                              Aber egal, jetzt läuft es.
                              Nochmals danke für die Inputs.
                              • V
                                varg @bahnuhr last edited by varg
                                @bahnuhr
                                also rein der fritz box neustart hat bei mir nichts gebracht (image backup wurde eingespielt so dass die ursprüngliche Installation und config wieder da war)
                                • bahnuhr
                                  bahnuhr Forum Testing Most Active @varg last edited by
                                  @varg sagte in Asterisk bringt "Error while dialing (2). Error: {}":
                                  @bahnuhr
                                  Erzeugts du die Datei jetzt auch mit pico2wave ?
                                  Ich hatte wohl mehrere Probleme:
                                  • Datei wurde nicht erzeugt : Lösung war pico2wave
                                    Hier muss der Entwickler dran !
                                  • Login hatte nicht gepasst: Lösung war manuell Datei sip.conf geändert
                                  • Fritzbox wollte nicht: Lösung war neustart der FB
                                  mfg
                                  Dieter
                                  stek 1 Reply Last reply Reply Quote 0
                                  • stek
                                    stek @bahnuhr last edited by
                                    @bahnuhr
                                    wie hast du diese problem gelöst.
                                    bei mir habe ich alles neu istalliert aber ich bekomme immer das Fehler:
                                    Meine allarmirung hat diese funktion verwendet und jetz funktioniert nicht mehr...
                                    Ich brauche eine lösung voice meldungen von Iobroker zu senden
                                    Stefano
                                    • bahnuhr
                                      bahnuhr Forum Testing Most Active @stek last edited by
                                      @stek sagte in Asterisk bringt "Error while dialing (2). Error: {}":
                                      steht genau 1 Beitrag vor deinem.
                                      • Z
                                        zaggul last edited by
                                        Wow, ihr seid genial!
                                        Ich war zwischenzeitlich aus privaten Gründen hier nicht mehr aktiv und hatte es nicht verfolgt. Mit der Lösung via pico2wave läuft es nun astrein!
                                        Merke: Je weniger externe Abhängigkeiten, desto besser 😉
                                        Vielen vielen Dank!
                                        • V
                                          @bahnuhr
                                          hantiere hier gerade mit einem testsystem rum. zeilen hab ich ausgeklammert. connected to manager passt auch ohne error.
                                          Nur dann will er bei der nummer string. Steh ich auf dem Schlauch ?
                                          Plattform: linux
                                          RAM: 1.8 GB
                                          Node.js: v14.17.1
                                          NPM: 6.14.13
                                          Admin ist die neueste beta
                                          host ist 3.3.12
                                          sterisk.0	2021-06-19 05:36:43.988	info	(948) State value to set for "asterisk.0.dialout.telnr" has to be type "string" but received type "number"
                                          • stek
                                            stek @boeskij last edited by
                                            @boeskij
                                            Das Einfügen dieses Codes (und die Installation von pico2wave) wird mit jeder anderen Modifikation funktionieren.
                                            Danke für die Tipps, jetzt funktioniert der Hausalarm wieder...für alle, die es ausprobieren wollen 😉
                                            on({id: 'asterisk.0.dialout.call'}, function (obj) {
                                                let msg = getState('asterisk.0.dialout.text').val;
                                                let tnr = getState('asterisk.0.dialout.telnr').val;
                                                let cid = getState('asterisk.0.dialout.callerid').val;
                                                exec('pico2wave -w /tmp/ttsdatei.wav -l it-IT "' + msg + '"', function (error, stdout, stderr) {
        /* wav erstellt */
        exec('sox /tmp/ttsdatei.wav -r 8000 -c 1 /tmp/ttsdatei.gsm', function (error, stdout, stderr) {
        /* gsm erstellt */
        exec('rm /tmp/ttsdatei.wav', function (error, stdout, stderr) {
        /* wav gelöscht, sonst wurde beim folgenden Anruf ggf. die falsche Datei aufgerufen... */
        sendTo('asterisk.0', "dial", { telnr: tnr , callerid: cid, audiofile: '/tmp/ttsdatei.gsm'},  (res) => {
        console.log('Result: ' + JSON.stringify(res));
        exec('cp /tmp/ttsdatei.gsm /tmp/asterisk_dtmf.gsm', function (error, stdout, stderr) {
        /* Die asterisk_dtmf.gsm wird für Dial-In Anrufe verwendet... Hier wird dann einfach der letzte Anruf nochmal wiedergegeben */
        /* Das folgende Löschen führte bei mir zu Problemen, also bleibt die Datei liegen.. wird ja eh überschrieben */
        /* exec('rm /tmp/ttsdatei.gsm', function (error, stdout, stderr) { console.log('Telefonalamierung: gsm gelöscht'); }); */
                                            116
                                            11030
