    4. BackItUp für InfluxDB
    • simatec
      simatec Developer Most Active @MassiveAttack last edited by
      @massiveattack Was ist denn in der Backupdatei alles drin?
      MassiveAttack 1 Reply Last reply Reply Quote 0
      • MassiveAttack
        MassiveAttack @simatec last edited by
        @simatec
        es wird keine erstellt
        • simatec
          @massiveattack
          Was geben folgenden Konsolenbefehle bei dir aus?
           curl -k -H "Authorization: Bearer deinAPIKey" http://deineIP:3000/api/search
           curl -s "http://deineIP:3000/api/datasources" -u admin:deinPasswort
          • MassiveAttack
            @simatec said in BackItUp für InfluxDB:
            @massiveattack
            [{"id":6,"uid":"H0MPaYZRz","title":"ENERGY","uri":"db/energy","url":"/d/H0MPaYZRz/energy","slug":"","type":"dash-db","tags":[],"isStarred":false,"sortMeta":0},{"id":4,"uid":"92wFUskRz","title":"HEATPUMP","uri":"db/heatpump","url":"/d/92wFUskRz/heatpump","slug":"","type":"dash-db","tags":[],"isStarred":false,"sortMeta":0},{"id":5,"uid":"bJgHQszRk","title":"WEATHER","uri":"db/weather","url":"/d/bJgHQszRk/weather","slug":"","type":"dash-db","tags":[],"isStarred":false,"sortMeta":0}]
            [{"id":1,"uid":"21vzeokgz","orgId":1,"name":"ioBroker","type":"influxdb","typeName":"InfluxDB","typeLogoUrl":"public/app/plugins/datasource/influxdb/img/influxdb_logo.svg","access":"proxy","url":"http://192.168.0.80:8086","password":"","user":"root","database":"iobroker","basicAuth":false,"isDefault":true,"jsonData":{},"readOnly":false},{"id":2,"uid":"KeyuCGRRz","orgId":1,"name":"MetaQueries","type":"goshposh-metaqueries-datasource","typeName":"goshposh-metaqueries-datasource","typeLogoUrl":"public/img/icn-datasource.svg","access":"proxy","url":"","password":"","user":"","database":"","basicAuth":false,"isDefault":false,"jsonData":{},"readOnly":false}]
            MassiveAttack simatec 2 Replies Last reply Reply Quote 0
            • MassiveAttack
              MassiveAttack @MassiveAttack last edited by
              curl -H "Authorization: Bearer eyJrIjoiU3Zmd0p0N2h5VVhGZW1OSDk2MmJJSjhreWJpNDgyNloiLCJuIjoiYWRtaW4iLCJpZCI6MX0=" http://192.168.0.10
              :3000/api/dashboards/home
              {"meta":{"isHome":true,"canSave":false,"canEdit":true,"canAdmin":false,"canStar":false,"slug":"","url":"","expires":"0001-01-01T00:00:00Z","created":"0001-01-01T00:00:00Z","updated":"0001-01-01T00:00:00Z","updatedBy":"","createdBy":"","version":0,"hasAcl":false,"isFolder":false,"folderId":0,"folderUid":"","folderTitle":"General","folderUrl":"","provisioned":false,"provisionedExternalId":""},"dashboard":{"links":[],"panels":[{"datasource":null,"gridPos":{"h":3,"w":24,"x":0,"y":0},"id":1,"title":"","transparent":false,"type":"welcome"},{"datasource":null,"folderId":0,"gridPos":{"h":15,"w":12,"x":0,"y":4},"headings":true,"id":3,"limit":30,"links":[],"options":{},"query":"","recent":true,"search":false,"starred":true,"tags":[],"title":"Dashboards","type":"dashlist"},{"datasource":null,"gridPos":{"h":15,"w":12,"x":12,"y":4},"id":4,"links":[],"options":{"feedUrl":"https://grafana.com/blog/news.xml"},"title":"Latest from the blog","type":"news"},{"gridPos":{"h":9,"w":24,"x":0,"y":3},"id":123123,"type":"gettingstarted"}],"schemaVersion":22,"tags":[],"templating":{"list":[]},"time":{"from":"now-6h","to":"now"},"timepicker":{"hidden":true,"refresh_intervals":["5s","10s","30s","1m","5m","15m","30m","1h","2h","1d"],"time_options":["5m","15m","1h","6h","12h","24h","2d","7d","30d"],"type":"timepicker"},"timezone":"browser","title":"Home"}}
              • simatec
                @massiveattack sagte in BackItUp für InfluxDB:
                energy
                Was gibt folgender Befehl aus?
                curl -k -H "Authorization: Bearer deinAPIKEY" http://deineIP/api/dashboards/db/energy
                • MassiveAttack
                  @simatec
                  {"message":"Not found"}
                  • simatec
                    @massiveattack
                    sorry Port vergessen
                    curl -k -H "Authorization: Bearer deinAPIKEY" http://deineIP:3000/api/dashboards/db/energy
                    • MassiveAttack
                      @simatec
                      ich habe es eh richtig abgefragt mit port, er findet nix
                      • simatec
                        @massiveattack
                        Dann liegt dein Problem in Grafana selber.
                        Mit dem Befehl solltest du die json deines energy Dashboard als Ausgabe bekommen
                        • MassiveAttack
                          @simatec
                          ja, aber was genau ist der fehler? ist es ein berechtigungsproblem? kann er die db nicht finde? wo müsste das liegen?
                          • MassiveAttack
                            @massiveattack
                            sollte eigentlich richtig in var/lib/grafana/ liegen. braucht das file spezielle zugriffsrechte?
                            • simatec
                              @massiveattack Ich habe mir die API von Grafana 8 mal angeschaut.
                              Da wurde etwas geändert, so dass ein Zugriff auf die Dashboards nur noch per "uid" möglich ist.
                              Die Backitup Version 2.1.13 ist darauf angepasst und kommt gerade ins latest.
                              • MassiveAttack
                                @simatec
                                ahh vielen dank 🙂
                                werde ich testen sobald verfügbar
                                • MassiveAttack
                                  @massiveattack
                                  test erfolgreich 🙂
                                  danke nochmals
                                  • simatec
                                    @massiveattack Kein Problem 😉
                                      Mike Hellracer @simatec last edited by
                                      der Standard Backup der influxdb funktioniert bei mir ohne Probleme.
                                      Da ich jedoch mehrere DB und der influxdb Instanz sichern wollte habe ich die versucht die Option 'mehrere Systeme' zu verwenden. Leider habe ich es scheinbar nicht geschafft den Pfad richtig anzugeben.
                                      Mein Pfad zu den DB auf dem lokalen System ist: /var/lib/influxdb/data/<nane der db>
                                      Was muss ich unter "vollständiger Pfad" angeben damit das geht?
                                      • simatec
                                        simatec Developer Most Active @Mike Hellracer last edited by
                                        @mike-hellracer
                                        Den Pfad kannst du normalerweise freilassen. Der ist nur dafür gedacht, falls deine influxd nicht in /usr/bin installiert ist. Also Standard ist einfach leer lassen. Das hat nichts mit einem Pfad zur DB zu tun
                                        M G 2 Replies Last reply Reply Quote 0
                                          @simatec
                                          Ja, soweit funktioniert es ja auch.
                                          Aber ich habe 2 Datenbanken, welche ich sichern will.
                                          Was muss ich nach dem aktivieren von 'mehrere Systeme' unter Pfad angeben?
                                          • simatec
                                            @mike-hellracer
                                            Wie schon im letzten Post geschrieben musst du nichts eintragen. Das ist optional. Nur den DB Namen musst du eintragen und wenn Remote Backup, dann noch IP und Port
                                            backitup influxdb
                                            32
                                            273
                                            46324
