    4. ZigBee neue Version 1.5.x
      ente34 @Asgothian last edited by ente34
      @asgothian
      Habe versuchweise einen Downgrade durchgeführt.
      Bin jetzt wieder bei 1.5.6
      Nach reboot mit deaktiviertem Zigbee und dann nachdem alles hochgelaufen ist zigbee aktiviert:
      zigbee.0	2021-06-09 19:41:24.425	warn	(1903) Read-only state "zigbee.0.info.connection" has been written without ack-flag with value "false"
      zigbee.0	2021-06-09 19:41:24.423	error	(1903) Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2218746-if00' at Drive
      zigbee.0	2021-06-09 19:41:24.421	error	(1903) Failed to start Zigbee
      zigbee.0	2021-06-09 19:41:24.264	info	(1903) Installed Version: iobroker.zigbee@1.5.6
      zigbee.0	2021-06-09 19:41:24.258	warn	(1903) Read-only state "zigbee.0.info.connection" has been written without ack-flag with value "false"
      zigbee.0	2021-06-09 19:41:24.053	info	(1903) Starting Zigbee npm ...
      zigbee.0	2021-06-09 19:41:23.960	info	(1903) starting. Version 1.4.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.3.11
      host.raspi-iobroker	2021-06-09 19:41:21.617	info	instance system.adapter.zigbee.0 started with pid 1903
      host.raspi-iobroker	2021-06-09 19:40:51.545	info	Restart adapter system.adapter.zigbee.0 because enabled
      host.raspi-iobroker	2021-06-09 19:40:51.544	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      zigbee.0	2021-06-09 19:40:50.950	warn	(1827) Read-only state "zigbee.0.info.pairingMessage" has been written without ack-flag with value "Error: Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null at Function.l
      zigbee.0	2021-06-09 19:40:50.939	error	(1827) Cannot read property 'getEntries' of null
      zigbee.0	2021-06-09 19:40:50.938	error	(1827) TypeError: Cannot read property 'getEntries' of null at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:216:55) at Funct
      zigbee.0	2021-06-09 19:40:50.931	error	(1827) unhandled promise rejection: Cannot read property 'getEntries' of null
      zigbee.0	2021-06-09 19:40:50.928	error	(1827) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      zigbee.0	2021-06-09 19:40:50.926	warn	(1827) Terminated (UNCAUGHT_EXCEPTION): Without reason
      zigbee.0	2021-06-09 19:40:50.924	info	(1827) terminating
      zigbee.0	2021-06-09 19:40:50.922	error	(1827) Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.j
      zigbee.0	2021-06-09 19:40:50.918	info	(1827) Zigbee: disabling joining new devices.
      zigbee.0	2021-06-09 19:40:50.912	info	(1827) cleaned everything up...
      zigbee.0	2021-06-09 19:40:50.901	error	(1827) Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2218746-if00'
      zigbee.0	2021-06-09 19:40:50.900	error	(1827) Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2218746-if00' at Drive
      zigbee.0	2021-06-09 19:40:50.899	error	(1827) unhandled promise rejection: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2218
      zigbee.0	2021-06-09 19:40:50.897	error	(1827) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      zigbee.0	2021-06-09 19:40:30.083	warn	(1827) Read-only state "zigbee.0.info.connection" has been written without ack-flag with value "false"
      zigbee.0	2021-06-09 19:40:30.078	error	(1827) Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2218746-if00' at Drive
      zigbee.0	2021-06-09 19:40:30.077	error	(1827) Failed to start Zigbee
      zigbee.0	2021-06-09 19:40:29.922	info	(1827) Installed Version: iobroker.zigbee@1.5.6
      zigbee.0	2021-06-09 19:40:29.893	info	(1827) Starting Zigbee npm ...
      zigbee.0	2021-06-09 19:40:29.892	info	(1827) Try to reconnect. 1 attempts left
      zigbee.0	2021-06-09 19:40:19.893	warn	(1827) Read-only state "zigbee.0.info.connection" has been written without ack-flag with value "false"
      zigbee.0	2021-06-09 19:40:19.891	error	(1827) Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2218746-if00' at Drive
      zigbee.0	2021-06-09 19:40:19.890	error	(1827) Failed to start Zigbee
      zigbee.0	2021-06-09 19:40:19.728	info	(1827) Installed Version: iobroker.zigbee@1.5.6
      zigbee.0	2021-06-09 19:40:19.724	warn	(1827) Read-only state "zigbee.0.info.connection" has been written without ack-flag with value "false"
      zigbee.0	2021-06-09 19:40:19.492	info	(1827) Starting Zigbee npm ...
      zigbee.0	2021-06-09 19:40:19.377	info	(1827) starting. Version 1.4.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.3.11
      host.raspi-iobroker	2021-06-09 19:40:16.846	info	instance system.adapter.zigbee.0 started with pid 1827
      host.raspi-iobroker	2021-06-09 19:40:16.799	info	"system.adapter.zigbee.0" enabled
      • Asgothian
        Asgothian Developer @ente34 last edited by Asgothian
        @ente34 sagte in ZigBee neue Version 1.5.x:
        @asgothian
        Um dem Problem auf den Grund zu gehen musst du heraus bekommen warum der serielle Port nicht mehr verfügbar ist. Das Log sagt eindeutig das symlink nicht existiert.
        Insbesondere bei Stromausfällen / RaspberryPi Abstürzen / Proxxmox Updates die plötzlich einen laufenden Zigbee Adapter zerlegen ist zu 95% ein Problem mit der Verbindung zum Koordinator die Ursache.
        A.
        Nachtrag: Oh Wunder, auch in diesem Log findet sich bei jedem Startversuch die gleiche Meldung:
        Der Stick wird also immer noch nicht erkannt.
        E 2 Replies Last reply Reply Quote 0
          @asgothian
          Habe einen neuen link 'serial1'
          pi@raspi-iobroker:~ $ ls -l /dev/serial1
          lrwxrwxrwx 1 root root 7 Jun  9 19:36 /dev/serial1 -> ttyAMA0
            @asgothian
            Erst mal vielen Dank für den schnellen Support!
              gosund last edited by
              @asgothian
              @artek
              Schlechte Nachrichten: Das komplette löschen, installieren und neu Anlernen hat nichts gebracht.
              Wie die letzten Tage auch hat sich der Adapter wieder innerhalb eines Tages aufgehängt. Ich mußte den Pi wieder komplett rebooten, damit es wieder geht.
              Hilfe, ich weiß mir absolut nicht mehr zu helfen. Was kann ich noch versuchen?
                rewenode @gosund last edited by
                Ich weis echt nicht mehr weiter.
                Bekomme einfach nicht das Update vom 1.5.5 auf 1.5.6 hin.
                iob im Docker Container mit 4gb auf einem Rock64
                node.js - v12.18.3
                npm - 6.14.6
                zigbee stick CC2538 + CC2592 von dimaiv
                Bisher gab es nie die geringsten zigbee Updateprobleme. Nur die 1.5.6 bekomme ich nicht installiert.
                Hier das Log:
                 01:23:20.786 - info: zigbee.0 (3129) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.3, js-controller: 3.2.16
                2021-06-11 01:23:21.151 - info: zigbee.0 (3129) Starting Zigbee npm ...
                2021-06-11 01:23:22.084 - info: zigbee.0 (3129) Installed Version: iobroker.zigbee@1.5.6
                2021-06-11 01:23:23.678 - error: zigbee.0 (3129) Configuration is not consistent with adapter state/backup!
                2021-06-11 01:23:23.681 - error: zigbee.0 (3129) - PAN ID: configured=6754, adapter=65535
                2021-06-11 01:23:23.683 - error: zigbee.0 (3129) - Extended PAN ID: configured=00124b001940c0ba, adapter=0000000000000000
                2021-06-11 01:23:23.685 - error: zigbee.0 (3129) - Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
                2021-06-11 01:23:23.686 - error: zigbee.0 (3129) - Channel List: configured=11, adapter=
                2021-06-11 01:23:23.688 - error: zigbee.0 (3129) Please update configuration to prevent further issues.
                2021-06-11 01:23:23.689 - error: zigbee.0 (3129) If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
                2021-06-11 01:23:23.691 - error: zigbee.0 (3129) Re-commissioning your network will require re-pairing of all devices!
                2021-06-11 01:23:23.694 - error: zigbee.0 (3129) Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
                2021-06-11 01:23:23.695 - error: zigbee.0 (3129) Failed to start Zigbee
                2021-06-11 01:23:23.697 - error: zigbee.0 (3129) Error herdsman start
                2021-06-11 01:23:33.700 - info: zigbee.0 (3129) Try to reconnect. 1 attempts left
                2021-06-11 01:23:33.702 - info: zigbee.0 (3129) Starting Zigbee npm ...
                2021-06-11 01:23:33.735 - info: zigbee.0 (3129) Installed Version: iobroker.zigbee@1.5.6
                2021-06-11 01:23:33.980 - error: zigbee.0 (3129) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                2021-06-11 01:23:33.982 - error: zigbee.0 (3129) Failed to start Zigbee
                2021-06-11 01:23:33.984 - error: zigbee.0 (3129) Error herdsman start
                2021-06-11 01:25:09.693 - info: host.iobroker stopInstance system.adapter.zigbee.0 (force=false, process=true)
                2021-06-11 01:25:09.717 - info: mqtt.0 (705) send2Server system.adapter.zigbee.0.sigKill[iob/system/adapter/zigbee/0/sigKill]
                2021-06-11 01:25:09.718 - info: zigbee.0 (3129) Got terminate signal TERMINATE_YOURSELF
                2021-06-11 01:25:09.723 - info: zigbee.0 (3129) cleaned everything up...
                2021-06-11 01:25:09.730 - info: zigbee.0 (3129) Zigbee: disabling joining new devices.
                2021-06-11 01:25:09.733 - warn: zigbee.0 (3129) Failed to stop zigbee during startup
                2021-06-11 01:25:09.735 - info: zigbee.0 (3129) terminating
                2021-06-11 01:25:09.737 - info: zigbee.0 (3129) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2021-06-11 01:25:09.739 - error: zigbee.0 (3129) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                2021-06-11 01:25:09.740 - error: zigbee.0 (3129) unhandled promise rejection: Cannot read property 'getEntries' of null
                2021-06-11 01:25:09.743 - error: zigbee.0 (3129) TypeError: Cannot read property 'getEntries' of null
                at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/device.js:220:55)
                at Function.all (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/device.js:240:16)
                at Controller.getDevices (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/controller.js:303:31)
                at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:228:49)
                at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:222:43)
                at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:214:42)
                at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:385:20)
                at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:696:41)
                at processTicksAndRejections (internal/process/task_queues.js:97:5)
                Was kann ich noch tun ?
                  arteck Developer Most Active @rewenode last edited by
                  @rewenode geh auf version 1.4.1 und dann wieder auf die 1.5.6 gehts dann ?
                    rewenode @arteck last edited by
                    @arteck Reicht da ein Downgrade adapter->Bestimmte version installieren -> 1.4.1 ?
                    Oder muss erst den Adapter (1.5.5) löschen?
                    Und falls löschen, wie kann ich alle meine Geräte behalten ohne alle neu anlernen zu müssen?
                    Sry wenn die Fragen etwas naiv sein sollten. Ich sag ja, bisher reichte ein Knopfdruck und alles neu anlernen wäre hier ziemlich mit Arbeit verbunden bei kleinem Zeitfenster.
                    Jedenfalls schonmal danke für deine Hilfe.
                      gosund @rewenode last edited by
                      @arteck @Asgothian
                      FYI: Hatte gestern Abend auf die 1.5.5 herunter gegraded. Das Problem besteht immer noch: nach ziemlich genau 24 Stunden hängt sich der Adapter auf. Ich mußte den Pi gerade eben wieder booten.
                      Irgend eine Idee, was ich noch machen kann?
                      Und nochwas: Seit dem Downgrade bekomme ich ständig folgende Meldung im Log:
                      zigbee.0 (1671) Failed to DeviceConfigure.onZigbeeEvent (Error: 'LED1623G12' has no configure
                          at Object.getConfigureKey (/opt/iobroker/node_modules/zigbee-herdsman-converters/lib/configureKey.js:20:15)
                          at DeviceConfigure.shouldConfigure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:33:38)
                          at DeviceConfigure.onZigbeeEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:76:22)
                          at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:196:42)
                          at ZigbeeController.handleMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:560:14))
                      Woher kommt LED1623G12? Ich habe alle Devices umbenannt, kann also nicht sagen, welches er meint. Irgend eine Idee?
                        Rushmed Most Active last edited by Rushmed
                        ich komme gerade vom Ikea Einkauf und habe zwei kleine Probleme.
                        Die Fernbedienung STYRBAR wird vom Adapter als W2094 erkannt. Auf dem Gerät steht aber W2044 und in der Anleitung E2002. Das ist erstmal kein Problem für mich, allerdings funktionieren Druck und langer Druck nur bei den links/rechts Tasten. Die anderen beiden Tasten funktionieren garnicht. f750e091-c6d7-4da2-af97-ba27597956bb-grafik.png
                        Wenn ich STYRBAR direkt mit einer Lampe kopple geht alles.
                        Wenn ich den Adapter auf debug stelle kommen Tastendrücke an:
                        zigbee.0	2021-06-12 19:09:59.315	debug	(18506) Publish {"action":"brightness_stop","action_group":901} to "842e14fffe471ae1"
                        zigbee.0	2021-06-12 19:09:59.300	debug	(18506) Type commandStopWithOnOff device {"type":"device","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"p
                        zigbee.0	2021-06-12 19:09:59.299	debug	(18506) Received Zigbee message from '0x842e14fffe471ae1', type 'commandStopWithOnOff', cluster 'genLevelCtrl', data '{}' from endpoint 1 with groupID 901
                        zigbee.0	2021-06-12 19:09:59.297	debug	(18506) handleMessage. {"type":"commandStopWithOnOff","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profi
                        zigbee.0	2021-06-12 19:09:58.939	debug	(18506) Publish {"action":"brightness_move_down","action_rate":83,"action_group":901} to "842e14fffe471ae1"
                        zigbee.0	2021-06-12 19:09:58.926	debug	(18506) Type commandMove device {"type":"device","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID"
                        zigbee.0	2021-06-12 19:09:58.926	debug	(18506) Received Zigbee message from '0x842e14fffe471ae1', type 'commandMove', cluster 'genLevelCtrl', data '{"movemode":1,"rate":83}' from endpoint 1 with groupID 901
                        zigbee.0	2021-06-12 19:09:58.924	debug	(18506) handleMessage. {"type":"commandMove","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260
                        zigbee.0	2021-06-12 19:09:57.127	debug	(18506) Publish {"action":"brightness_stop","action_group":901} to "842e14fffe471ae1"
                        zigbee.0	2021-06-12 19:09:57.116	debug	(18506) Type commandStopWithOnOff device {"type":"device","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"p
                        zigbee.0	2021-06-12 19:09:57.114	debug	(18506) Received Zigbee message from '0x842e14fffe471ae1', type 'commandStopWithOnOff', cluster 'genLevelCtrl', data '{}' from endpoint 1 with groupID 901
                        zigbee.0	2021-06-12 19:09:57.113	debug	(18506) handleMessage. {"type":"commandStopWithOnOff","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profi
                        zigbee.0	2021-06-12 19:09:56.660	debug	(18506) Publish {"action":"brightness_move_up","action_rate":83,"action_group":901} to "842e14fffe471ae1"
                        zigbee.0	2021-06-12 19:09:56.644	debug	(18506) Type commandMoveWithOnOff device {"type":"device","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"p
                        zigbee.0	2021-06-12 19:09:56.643	debug	(18506) Received Zigbee message from '0x842e14fffe471ae1', type 'commandMoveWithOnOff', cluster 'genLevelCtrl', data '{"movemode":0,"rate":83}' from endpoint 1 with groupID 901
                        zigbee.0	2021-06-12 19:09:56.640	debug	(18506) handleMessage. {"type":"commandMoveWithOnOff","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profi
                        zigbee.0	2021-06-12 19:09:54.926	debug	(18506) Publish {"action":"on","action_group":901} to "842e14fffe471ae1"
                        zigbee.0	2021-06-12 19:09:54.917	debug	(18506) Type commandOn device {"type":"device","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":2
                        zigbee.0	2021-06-12 19:09:54.916	debug	(18506) Received Zigbee message from '0x842e14fffe471ae1', type 'commandOn', cluster 'genOnOff', data '{}' from endpoint 1 with groupID 901
                        zigbee.0	2021-06-12 19:09:54.915	debug	(18506) handleMessage. {"type":"commandOn","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260,"
                        zigbee.0	2021-06-12 19:09:53.737	debug	(18506) Publish {"action":"arrow_right_click"} to "842e14fffe471ae1"
                        zigbee.0	2021-06-12 19:09:53.720	debug	(18506) Type commandTradfriArrowSingle device {"type":"device","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID"
                        zigbee.0	2021-06-12 19:09:53.719	debug	(18506) Received Zigbee message from '0x842e14fffe471ae1', type 'commandTradfriArrowSingle', cluster 'genScenes', data '{"value":256,"value2":13}' from endpoint 1 with groupID 901
                        zigbee.0	2021-06-12 19:09:53.715	debug	(18506) handleMessage. {"type":"commandTradfriArrowSingle","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"
                        zigbee.0	2021-06-12 19:09:52.576	debug	(18506) Publish {"action":"off","action_group":901} to "842e14fffe471ae1"
                        zigbee.0	2021-06-12 19:09:52.563	debug	(18506) Type commandOff device {"type":"device","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":
                        zigbee.0	2021-06-12 19:09:52.561	debug	(18506) Received Zigbee message from '0x842e14fffe471ae1', type 'commandOff', cluster 'genOnOff', data '{}' from endpoint 1 with groupID 901
                        zigbee.0	2021-06-12 19:09:52.558	debug	(18506) handleMessage. {"type":"commandOff","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":260,
                        zigbee.0	2021-06-12 19:09:51.208	debug	(18506) Publish {"action":"arrow_left_click"} to "842e14fffe471ae1"
                        zigbee.0	2021-06-12 19:09:51.199	debug	(18506) Type commandTradfriArrowSingle device {"type":"device","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID"
                        zigbee.0	2021-06-12 19:09:51.196	debug	(18506) Received Zigbee message from '0x842e14fffe471ae1', type 'commandTradfriArrowSingle', cluster 'genScenes', data '{"value":257,"value2":13}' from endpoint 1 with groupID 901
                        zigbee.0	2021-06-12 19:09:51.194	debug	(18506) handleMessage. {"type":"commandTradfriArrowSingle","device":{"ID":33,"_type":"EndDevice","_ieeeAddr":"0x842e14fffe471ae1","_networkAddress":24375,"_manufacturerID":4476,"_endpoints":[{"ID":1,"
                        Der Timeout für die Erkennung des langen Drucks ist mit ca. 3 s auch sehr lang, kann man das irgendwo verstellen? Das ist zum Beispiel bei E1743 nur ca. 1 s, was viel besser passt.
                        Dann habe ich noch eine LED1924G9, die funktioniert soweit, außer die Effekte. Da tut sich garnichts.
                        Hat da jemand einen Tipp für mich?
                        L arteck 2 Replies Last reply Reply Quote 0
                          locito09 @Rushmed last edited by
                          @rushmed
                          hast du probiert das Gerät auszuschliessen?
                            Rushmed Most Active @locito09 last edited by Rushmed
                            @locito09 Wie ausschließen? Im Adapter? Nein.
                            Edit: Habs probiert, geht nicht.
                              arteck Developer Most Active @gosund last edited by
                              @gosund da sist der Technische name .. nicht dein umbenanntess.das kannst du in der Kachel sehen ..wenn du die umdrehst
                                Frank579 @arteck last edited by
                                @Asgothian
                                Habe gerade mein bastelsystem hochgezogen auf Admin5.
                                Er spuckt mir jetzt für einige Geräte
                                zigbee.0
                                2021-06-13 09:52:06.290	warn	State value to set for "zigbee.0.0017880108279caf.link_quality" has value "255" greater than max "254"
                                ins Log.
                                Ist das schon bekannt?
                                  arteck Developer Most Active @Frank579 last edited by arteck
                                  @frank579 ohh Danke..habs korrigiert
                                    arteck Developer Most Active @Rushmed last edited by
                                    @rushmed zeigma die Kachel
                                      Rushmed Most Active @arteck last edited by
                                      @arteck Prego!
                                      arteck R D 3 Replies Last reply Reply Quote 0
                                        arteck Developer Most Active @Rushmed last edited by arteck
                                        @rushmed der Button meldet sich als W2049. ist so
                                        https://github.com/Koenkk/zigbee2mqtt/issues/7655
                                        njordan77 created this issue in Koenkk/zigbee2mqtt
                                        closed Ikea Tradfri E2044 - not supported (?) #7655
                                          @arteck Ja ok, stört mich auch nicht. Mein Problem ist dass nur die Hälfte der Tasten (als Objekte) gehen aber im debug LOG doch auch die anderen irgendwie ankommen wie in meinem Post geschrieben.
                                          Im verlinkten Issue ist das Pairing das Problem, nicht dass die Tasten nur teilweise funktionieren.
                                            Rushmed Most Active @Rushmed last edited by Rushmed
                                            @rushmed sagte in ZigBee neue Version 1.5.x:
                                            Hat hierzu keiner weiter eine Idee. Hab ich vll. an der falschen Stelle gepostet?
                                            31.7k
                                            79.9k
                                            579
                                            111170
