    4. Test Adapter Mihome-vacuum v3.1.6 Next Generarition
    • Meistertr
      Meistertr Developer @Frank579 last edited by
      @frank579 welches modell? bitte einen debug logauszug vom start
        Frank579 @Meistertr last edited by
        @meistertr
        Beide Instanzen S5 Max einer geht der andere Läd die räume einfach nicht Hab ihn auch schon mal komplett saugen lassen ... Log kommt gleich
          @meistertr
          Hier noch den Log 🙂
          2021-06-03 20:28:51.080 - debug: mihome-vacuum.0 (4034) Redis Objects: Use Redis connection: 127.0.0.1:9001
          2021-06-03 20:28:51.108 - debug: mihome-vacuum.0 (4034) Objects client ready ... initialize now
          2021-06-03 20:28:51.110 - debug: mihome-vacuum.0 (4034) Objects create System PubSub Client
          2021-06-03 20:28:51.118 - debug: mihome-vacuum.0 (4034) Objects create User PubSub Client
          2021-06-03 20:28:51.118 - debug: mihome-vacuum.0 (4034) Objects client initialize lua scripts
          2021-06-03 20:28:51.126 - debug: mihome-vacuum.0 (4034) Objects connected to redis: 127.0.0.1:9001
          2021-06-03 20:28:51.129 - debug: mihome-vacuum.0 (4034) objectDB connected
          2021-06-03 20:28:51.130 - debug: mihome-vacuum.0 (4034) Redis States: Use Redis connection: 127.0.0.1:9000
          2021-06-03 20:28:51.134 - debug: mihome-vacuum.0 (4034) States create System PubSub Client
          2021-06-03 20:28:51.134 - debug: mihome-vacuum.0 (4034) States create User PubSub Client
          2021-06-03 20:28:51.139 - debug: mihome-vacuum.0 (4034) States connected to redis: 127.0.0.1:9000
          2021-06-03 20:28:51.140 - debug: mihome-vacuum.0 (4034) statesDB connected
          2021-06-03 20:28:51.338 - debug: mihome-vacuum.0 (4034) Plugin sentry Initialize Plugin (enabled=true)
          2021-06-03 20:28:51.423 - info: mihome-vacuum.0 (4034) starting. Version 3.2.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.22.1, js-controller: 3.2.16
          2021-06-03 20:28:51.529 - info: mihome-vacuum.0 (4034) check user admin pw iobroker: true
          2021-06-03 20:28:51.531 - info: mihome-vacuum.0 (4034) check group user admin group admin: false
          2021-06-03 20:28:51.542 - debug: mihome-vacuum.0 (4034) load Map creator... true
          2021-06-03 20:28:51.545 - debug: mihome-vacuum.0 (4034) Create State for deviceInfomac
          2021-06-03 20:28:51.546 - debug: mihome-vacuum.0 (4034) Create State for deviceInfomodel
          2021-06-03 20:28:51.546 - debug: mihome-vacuum.0 (4034) Create State for deviceInfofw_ver
          2021-06-03 20:28:51.546 - debug: mihome-vacuum.0 (4034) Create State for deviceInfowifi_signal
          2021-06-03 20:28:51.546 - debug: mihome-vacuum.0 (4034) MIIO: Config: ip:192.168.50.41 token: XXXXXXXXX
          2021-06-03 20:28:51.548 - info: mihome-vacuum.0 (4034) IOT disabled, delete state
          2021-06-03 20:28:51.549 - debug: mihome-vacuum.0 (4034) server started on 0.0.0.0:53421
          2021-06-03 20:28:51.557 - debug: mihome-vacuum.0 (4034) Receive <<< Helo <<< 2131002000000000131824dc60b91f63ffffffffffffffffffffffffffffffff
          2021-06-03 20:28:51.557 - debug: mihome-vacuum.0 (4034) MAIN: Connected to device, try to get model..
          2021-06-03 20:28:51.560 - debug: mihome-vacuum.0 (4034) GETMODELFROMAPI: objModel: {"val":"roborock.vacuum.s5e","ack":true,"ts":1622744524482,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1622713779552}
          2021-06-03 20:28:51.560 - debug: mihome-vacuum.0 (4034) Message= {"id":1,"method":"miIO.info"}
          2021-06-03 20:28:51.566 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"partner_id":"","id":1,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_1410","ap":{"ssid":"SmartHome","bssid":"e2:63:da:6e:c7:8d","rssi":-83},"netif":{"localIp":"192.168.50.41","mask":"255.255.255.0","gw":"192.168.50.1"},"miio_ver":"miio-client 3.5.8","model":"roborock.vacuum.s5e","mac":"64:90:C1:02:20:BF","token":"XXXXXXXXXXXXXXX","life":62521}}
          2021-06-03 20:28:51.566 - debug: mihome-vacuum.0 (4034) GETMODELFROMAPI:Data: {"partner_id":"","id":1,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_1410","ap":{"ssid":"SmartHome","bssid":"e2:63:da:6e:c7:8d","rssi":-83},"netif":{"localIp":"192.168.50.41","mask":"255.255.255.0","gw":"192.168.50.1"},"miio_ver":"miio-client 3.5.8","model":"roborock.vacuum.s5e","mac":"64:90:C1:02:20:BF","token":"XXXXXXXXXXXX","life":62521}}
          2021-06-03 20:28:51.566 - debug: mihome-vacuum.0 (4034) Get Device data..0
          2021-06-03 20:28:51.566 - debug: mihome-vacuum.0 (4034) Get Device data from robot..
          2021-06-03 20:28:51.567 - debug: mihome-vacuum.0 (4034) DeviceModel selected to: roborock.vacuum.s5e
          2021-06-03 20:28:51.567 - info: mihome-vacuum.0 (4034) select standard vacuum protocol....
          2021-06-03 20:28:51.569 - debug: mihome-vacuum.0 (4034) Xiaomi Cloud: Logging in
          2021-06-03 20:28:51.603 - debug: mihome-vacuum.0 (4034) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
          2021-06-03 20:28:52.074 - info: mihome-vacuum.0 (4034) settest next timer: not available
          2021-06-03 20:28:52.658 - debug: mihome-vacuum.0 (4034) Login step1: &&&START&&&{"result":"error","serviceParam":"{\"checkSafePhone\":false,\"checkSafeAddress\":false,\"lsrp_score\":0.0}","qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","code":70016,"captchaUrl":null,"callback":"https://sts.api.io.mi.com/sts","location":"https://account.xiaomi.com/fe/service/login?_json=true&sid=xiaomiio&qs=%253Fsid%253Dxiaomiio%2526_json%253Dtrue&callback=https%3A%2F%2Fsts.api.io.mi.com%2Fsts&_sign=0psXfr43eNI0IX6q9Suk3qWbRqU%3D&serviceParam=%7B%22checkSafePhone%22%3Afalse%2C%22checkSafeAddress%22%3Afalse%2C%22lsrp_score%22%3A0.0%7D&showActiveX=false&theme=&needTheme=false&bizDeviceType=","securityStatus":0,"pwd":0,"_sign":"0psXfr43eNI0IX6q9Suk3qWbRqU=","sid":"xiaomiio","desc":"登录验证失败"}
          2021-06-03 20:28:53.535 - debug: mihome-vacuum.0 (4034) Login step2: &&&START&&&{"qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","ssecurity":"o3W5w1oCXFHVd1aHvZNi3Q==","code":0,"passToken":"V1:bVc+HLNQkn0wITZpdR20IOLv1XQtV1PICexQU7S61KGti5bw/7h3oYzN/j+L5+9zp10jf/8sxzW0rGLKEhXYPwpua4SIjFmOm17RxnV1GiPsIZ2z97jAtSepjnTJ1kgGrO79ZZv9s7+eTQ7kxY+oPJGl1ptFHmy9lyPX0rsRwZOtkAoBEsGMaC5XrQPc9eTM8IYKvL1rlKD2u81VRQyA+j7HqPZV/tpXWdCGfSWAcbFXtRRR0CDsEi9YhQAq4O9f8UFazaQhBNJD/PQqxAzo3TUXFgzjQiMu4t7i9UxKPYU=","securityStatus":0,"nonce":4582086323101018112,"userId":6353965320,"cUserId":"2Xh3BEW_HsDJAdUD4fg6WPU8B0A","result":"ok","psecurity":"Kp+ASNrVyl7bjsWoDxRmPw==","captchaUrl":null,"location":"https://sts.api.io.mi.com/sts?d=rpadrj&ticket=0&pwd=1&p_ts=1622744933000&fid=0&p_lm=1&auth=at58%2FopYpD2bVeqpJ3C6bhdjUAG6Of72aRZiSaz%2BOXbxfC%2F8H9ffGwzKqaYi6WRY1C1u5RMqcig%2Bl0QUSTZZy5stz%2F%2BoKun12OecRFSi7XdMkbhXZEY1IofUhqLzD3mKOLO6%2BMB3ocXRq%2BLNy4T5c6RNwi1tsI14MUJvKq%2FWJgE%3D&m=1&tsl=0&nonce=9pCgOu31CK4BnK90&_ssign=0pV2Q70xZSwecm1Qdu7eHxtblCk%3D","pwd":1,"desc":"成功"}
          2021-06-03 20:28:53.665 - debug: mihome-vacuum.0 (4034) Login step3: [{"key":"userId","value":"6353965320","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2021-06-03T18:28:53.654Z","lastAccessed":"2021-06-03T18:28:53.665Z"},{"key":"cUserId","value":"2Xh3BEW_HsDJAdUD4fg6WPU8B0A","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2021-06-03T18:28:53.660Z","lastAccessed":"2021-06-03T18:28:53.665Z"},{"key":"serviceToken","value":"u4XTQ/K8NyjIh6l2H9fTFPpzG4cKaMMHxXbqDwMz4GPBGFXvl3E4RB7R2RVOJ5l/vzz1LzxuEWvHxXa7wRGB9UZhqIKm5pZQO2FpjJZMcc4HWHK7nnOzXaXZe8YoB+MN94ZnL85roewPeIZxNDwm8d3Zn/DcSKel5StGAUTUpBM=","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2021-06-03T18:28:53.662Z","lastAccessed":"2021-06-03T18:28:53.665Z"}]
          2021-06-03 20:28:53.665 - debug: mihome-vacuum.0 (4034) Xiaomi Cloud: Login successful
          2021-06-03 20:28:53.670 - debug: mihome-vacuum.0 (4034) Create State for deviceInfoundefined
          2021-06-03 20:28:53.671 - debug: mihome-vacuum.0 (4034) Create State for deviceInfoundefined
          2021-06-03 20:28:53.672 - debug: mihome-vacuum.0 (4034) Create State for deviceInfoundefined
          2021-06-03 20:28:53.683 - debug: mihome-vacuum.0 (4034) Create State for stockInfoundefined
          2021-06-03 20:28:53.686 - debug: mihome-vacuum.0 (4034) Create State for stockInfoundefined
          2021-06-03 20:28:53.687 - debug: mihome-vacuum.0 (4034) Create State for stockInfoundefined
          2021-06-03 20:28:53.690 - debug: mihome-vacuum.0 (4034) Create State for stockConsumableundefined
          2021-06-03 20:28:53.691 - debug: mihome-vacuum.0 (4034) Create State for stockConsumableundefined
          2021-06-03 20:28:53.697 - debug: mihome-vacuum.0 (4034) Create State for stockHistoryundefined
          2021-06-03 20:28:53.698 - debug: mihome-vacuum.0 (4034) Create State for stockHistoryundefined
          2021-06-03 20:28:53.702 - debug: mihome-vacuum.0 (4034) Create State for Queue: queue
          2021-06-03 20:28:53.702 - debug: mihome-vacuum.0 (4034) Create State for Queue: clearQueue
          2021-06-03 20:28:53.704 - debug: mihome-vacuum.0 (4034) Create State for enableResumeZoneundefined
          2021-06-03 20:28:53.704 - info: mihome-vacuum.0 (4034) Map selected create states...
          2021-06-03 20:28:53.708 - debug: mihome-vacuum.0 (4034) Create State for map: map64
          2021-06-03 20:28:53.708 - debug: mihome-vacuum.0 (4034) Create State for map: actualMap
          2021-06-03 20:28:53.708 - debug: mihome-vacuum.0 (4034) Create State for map: mapStatus
          2021-06-03 20:28:53.708 - debug: mihome-vacuum.0 (4034) Create State for map: mapURL
          2021-06-03 20:28:53.708 - debug: mihome-vacuum.0 (4034) Create State for map: loadMap
          2021-06-03 20:28:53.708 - debug: mihome-vacuum.0 (4034) Create State done!
          2021-06-03 20:28:53.709 - debug: mihome-vacuum.0 (4034) get params for stock Vacuum
          2021-06-03 20:28:53.709 - debug: mihome-vacuum.0 (4034) Message= {"id":2,"method":"get_status"}
          2021-06-03 20:28:53.717 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":3367,"state":8,"battery":100,"clean_time":332,"clean_area":5422500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"fan_power":106,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":204,"water_box_carriage_status":1,"mop_forbidden_enable":1}],"id":2}
          2021-06-03 20:28:53.717 - debug: mihome-vacuum.0 (4034) setGetStatus {"msg_ver":2,"msg_seq":3367,"state":8,"battery":100,"clean_time":332,"clean_area":5422500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"fan_power":106,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":204,"water_box_carriage_status":1,"mop_forbidden_enable":1,"error_text":"No error"}
          2021-06-03 20:28:53.717 - info: mihome-vacuum.0 (4034) change states from State control.fan_power
          2021-06-03 20:28:53.729 - info: mihome-vacuum.0 (4034) create states for water box
          2021-06-03 20:28:53.730 - info: mihome-vacuum.0 (4034) create states for water box mode
          2021-06-03 20:28:53.731 - info: mihome-vacuum.0 (4034) create states for mop
          2021-06-03 20:28:53.793 - debug: mihome-vacuum.0 (4034) Message= {"id":3,"method":"get_map_v1"}
          2021-06-03 20:28:53.801 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":["retry"],"id":3}
          2021-06-03 20:28:54.101 - debug: mihome-vacuum.0 (4034) Message= {"id":4,"method":"get_map_v1"}
          2021-06-03 20:28:54.108 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":["retry"],"id":4}
          2021-06-03 20:28:54.408 - debug: mihome-vacuum.0 (4034) Message= {"id":5,"method":"get_map_v1"}
          2021-06-03 20:28:54.415 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":["rubyslite%2F320349404%2F7"],"id":5}
          2021-06-03 20:28:54.416 - debug: mihome-vacuum.0 (4034) Mappointer_updated
          2021-06-03 20:28:54.416 - debug: mihome-vacuum.0 (4034) update_Map Mimap enabled
          2021-06-03 20:28:54.416 - debug: mihome-vacuum.0 (4034) update_Map need new mapurl
          2021-06-03 20:28:54.418 - debug: mihome-vacuum.0 (4034) Message= {"id":6,"method":"get_room_mapping"}
          2021-06-03 20:28:54.427 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[],"id":6}
          2021-06-03 20:28:54.427 - debug: mihome-vacuum.0 (4034) Message= {"id":7,"method":"get_consumable"}
          2021-06-03 20:28:54.428 - debug: mihome-vacuum.0 (4034) Message= {"id":8,"method":"get_network_info"}
          2021-06-03 20:28:54.437 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[{"main_brush_work_time":69237,"side_brush_work_time":69237,"filter_work_time":69237,"filter_element_work_time":59372,"sensor_dirty_time":69219}],"id":7}
          2021-06-03 20:28:54.437 - debug: mihome-vacuum.0 (4034) Message= {"id":9,"method":"get_clean_summary"}
          2021-06-03 20:28:54.454 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":{"ssid":"SmartHome","ip":"192.168.50.41","mac":"64:90:c1:02:20:bf","bssid":"e2:63:da:6e:c7:8d","rssi":-81},"id":8}
          2021-06-03 20:28:54.459 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[69219,1176440000,49,[1622711457,1622709889,1621759219,1621757141,1621754893,1621158710,1620568308,1619975461,1619949343,1618733615,1616845998,1615721681,1615127170,1614445195,1613896540,1612608025,1612000844,1611384765,1610874479,1610280635]],"id":9}
          2021-06-03 20:28:54.460 - debug: mihome-vacuum.0 (4034) Message= {"id":10,"method":"get_clean_record","params":[1622711457]}
          2021-06-03 20:28:54.464 - debug: mihome-vacuum.0 (4034) Message= {"id":11,"method":"get_sound_volume"}
          2021-06-03 20:28:54.472 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1622711457,1622711789,332,5422500,0,1,2,3,56]],"id":10}
          2021-06-03 20:28:54.472 - debug: mihome-vacuum.0 (4034) Message= {"id":12,"method":"get_clean_record","params":[1622709889]}
          2021-06-03 20:28:54.473 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[62],"id":11}
          2021-06-03 20:28:54.473 - debug: mihome-vacuum.0 (4034) Message= {"id":13,"method":"get_multi_maps_list"}
          2021-06-03 20:28:54.482 - debug: mihome-vacuum.0 (4034) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubyslite/320349404/7?Expires=1622746734000&GalaxyAccessKeyId=5271733786445&Signature=W1R8N53zTY3P7ZdS+Emboe4UQmA=
          2021-06-03 20:28:54.482 - debug: mihome-vacuum.0 (4034) update_Map got new expires:1622746734
          2021-06-03 20:28:54.482 - debug: mihome-vacuum.0 (4034) update_Map got new time:1622744934
          2021-06-03 20:28:54.489 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1622709889,1622710194,305,5252500,0,1,2,3,56]],"id":12}
          2021-06-03 20:28:54.489 - debug: mihome-vacuum.0 (4034) Message= {"id":14,"method":"get_clean_record","params":[1621759219]}
          2021-06-03 20:28:54.490 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[{"max_multi_map":4,"max_bak_map":0,"multi_map_count":1,"map_info":[{"mapFlag":0,"add_time":1621757005,"length":12,"name":"Obergeschoss","bak_maps":[]}]}],"id":13}
          2021-06-03 20:28:54.490 - debug: mihome-vacuum.0 (4034) States for 1 Map: [{"mapFlag":0,"add_time":1621757005,"length":12,"name":"Obergeschoss","bak_maps":[]}]
          2021-06-03 20:28:54.490 - debug: mihome-vacuum.0 (4034) States for Map: {"0":"Obergeschoss"}
          2021-06-03 20:28:54.491 - debug: mihome-vacuum.0 (4034) Startup: getMultiMapsList Anser: true
          2021-06-03 20:28:54.491 - debug: mihome-vacuum.0 (4034) Startup: Delete getMultiMapsList
          2021-06-03 20:28:54.491 - debug: mihome-vacuum.0 (4034) Message= {"id":15,"method":"get_clean_summary"}
          2021-06-03 20:28:54.497 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1621759219,1621759912,693,6577500,0,1,2,3,56]],"id":14}
          2021-06-03 20:28:54.497 - debug: mihome-vacuum.0 (4034) Message= {"id":16,"method":"get_clean_record","params":[1621757141]}
          2021-06-03 20:28:54.511 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[69219,1176440000,49,[1622711457,1622709889,1621759219,1621757141,1621754893,1621158710,1620568308,1619975461,1619949343,1618733615,1616845998,1615721681,1615127170,1614445195,1613896540,1612608025,1612000844,1611384765,1610874479,1610280635]],"id":15}
          2021-06-03 20:28:54.511 - debug: mihome-vacuum.0 (4034) Startup: setGetCleanSummary Anser: true
          2021-06-03 20:28:54.511 - debug: mihome-vacuum.0 (4034) Startup: Delete setGetCleanSummary
          2021-06-03 20:28:54.511 - debug: mihome-vacuum.0 (4034) Message= {"id":17,"method":"get_consumable"}
          2021-06-03 20:28:54.512 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1621757141,1621757598,457,8490000,0,1,2,3,56]],"id":16}
          2021-06-03 20:28:54.512 - debug: mihome-vacuum.0 (4034) Message= {"id":18,"method":"get_clean_record","params":[1621754893]}
          2021-06-03 20:28:54.522 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[{"main_brush_work_time":69237,"side_brush_work_time":69237,"filter_work_time":69237,"filter_element_work_time":59372,"sensor_dirty_time":69219}],"id":17}
          2021-06-03 20:28:54.525 - debug: mihome-vacuum.0 (4034) Startup: setGetConsumable Anser: true
          2021-06-03 20:28:54.526 - debug: mihome-vacuum.0 (4034) Startup: Delete setGetConsumable
          2021-06-03 20:28:54.526 - debug: mihome-vacuum.0 (4034) Message= {"id":19,"method":"get_map_v1"}
          2021-06-03 20:28:54.526 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1621754893,1621756979,2086,35620000,0,1,2,1,52]],"id":18}
          2021-06-03 20:28:54.526 - debug: mihome-vacuum.0 (4034) Message= {"id":20,"method":"get_clean_record","params":[1621158710]}
          2021-06-03 20:28:54.534 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":["rubyslite%2F320349404%2F7"],"id":19}
          2021-06-03 20:28:54.535 - debug: mihome-vacuum.0 (4034) Mappointer_updated
          2021-06-03 20:28:54.535 - debug: mihome-vacuum.0 (4034) update_Map Mimap enabled
          2021-06-03 20:28:54.535 - debug: mihome-vacuum.0 (4034) update_Map use old mapurl
          2021-06-03 20:28:54.535 - debug: mihome-vacuum.0 (4034) Message= {"id":21,"method":"get_carpet_mode"}
          2021-06-03 20:28:54.536 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1621158710,1621160901,2191,35707500,0,1,2,1,52]],"id":20}
          2021-06-03 20:28:54.536 - debug: mihome-vacuum.0 (4034) Message= {"id":22,"method":"get_clean_record","params":[1620568308]}
          2021-06-03 20:28:54.551 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":21}
          2021-06-03 20:28:54.551 - info: mihome-vacuum.0 (4034) create state for carpet_mode
          2021-06-03 20:28:54.551 - debug: mihome-vacuum.0 (4034) Message= {"id":23,"method":"get_carpet_mode"}
          2021-06-03 20:28:54.552 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1620568308,1620570593,2285,36180000,0,1,2,1,52]],"id":22}
          2021-06-03 20:28:54.552 - debug: mihome-vacuum.0 (4034) Message= {"id":24,"method":"get_clean_record","params":[1619975461]}
          2021-06-03 20:28:54.565 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":23}
          2021-06-03 20:28:54.566 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1619975461,1619975962,501,6510000,0,1,2,3,56]],"id":24}
          2021-06-03 20:28:54.566 - debug: mihome-vacuum.0 (4034) Message= {"id":25,"method":"get_clean_record","params":[1619949343]}
          2021-06-03 20:28:54.574 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1619949343,1619951478,2135,35587500,0,1,2,1,52]],"id":25}
          2021-06-03 20:28:54.575 - debug: mihome-vacuum.0 (4034) Message= {"id":26,"method":"get_clean_record","params":[1618733615]}
          2021-06-03 20:28:54.582 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1618733615,1618735576,1961,35317500,0,1,2,1,52]],"id":26}
          2021-06-03 20:28:54.584 - debug: mihome-vacuum.0 (4034) Message= {"id":27,"method":"get_clean_record","params":[1616845998]}
          2021-06-03 20:28:54.649 - debug: mihome-vacuum.0 (4034) 25401
          2021-06-03 20:28:54.787 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1616845998,1616848181,2183,36225000,0,1,2,1,52]],"id":27}
          2021-06-03 20:28:54.787 - debug: mihome-vacuum.0 (4034) Message= {"id":28,"method":"get_clean_record","params":[1615721681]}
          2021-06-03 20:28:54.800 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1615721681,1615723823,2142,36732500,0,1,2,1,52]],"id":28}
          2021-06-03 20:28:54.800 - debug: mihome-vacuum.0 (4034) Message= {"id":29,"method":"get_clean_record","params":[1615127170]}
          2021-06-03 20:28:54.810 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1615127170,1615129241,2071,36080000,0,1,2,1,52]],"id":29}
          2021-06-03 20:28:54.811 - debug: mihome-vacuum.0 (4034) Message= {"id":30,"method":"get_clean_record","params":[1614445195]}
          2021-06-03 20:28:54.816 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1614445195,1614447210,2015,35935000,0,1,2,1,52]],"id":30}
          2021-06-03 20:28:54.817 - debug: mihome-vacuum.0 (4034) Message= {"id":31,"method":"get_clean_record","params":[1613896540]}
          2021-06-03 20:28:54.825 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1613896540,1613898735,2195,36522500,0,1,2,1,52]],"id":31}
          2021-06-03 20:28:54.825 - debug: mihome-vacuum.0 (4034) Message= {"id":32,"method":"get_clean_record","params":[1612608025]}
          2021-06-03 20:28:54.891 - debug: mihome-vacuum.0 (4034) 25401
          2021-06-03 20:28:55.030 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1612608025,1612610154,2129,36230000,0,1,2,1,52]],"id":32}
          2021-06-03 20:28:55.030 - debug: mihome-vacuum.0 (4034) Message= {"id":33,"method":"get_clean_record","params":[1612000844]}
          2021-06-03 20:28:55.051 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1612000844,1612002933,2089,36487500,0,1,2,1,52]],"id":33}
          2021-06-03 20:28:55.051 - debug: mihome-vacuum.0 (4034) Message= {"id":34,"method":"get_clean_record","params":[1611384765]}
          2021-06-03 20:28:55.057 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1611384765,1611386844,2079,36262500,0,1,2,1,52]],"id":34}
          2021-06-03 20:28:55.057 - debug: mihome-vacuum.0 (4034) Message= {"id":35,"method":"get_clean_record","params":[1610874479]}
          2021-06-03 20:28:55.066 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1610874479,1610877149,2670,35790000,0,1,2,1,52]],"id":35}
          2021-06-03 20:28:55.066 - debug: mihome-vacuum.0 (4034) Message= {"id":36,"method":"get_clean_record","params":[1610280635]}
          2021-06-03 20:28:55.072 - debug: mihome-vacuum.0 (4034) MIIO RECIVE: {"result":[[1610280635,1610280980,345,6717500,0,1,2,3,56]],"id":36}
          2021-06-03 20:28:55.073 - debug: mihome-vacuum.0 (4034) finish logs all [{"Datum":"3.6","Start":"11:10","Saugzeit":"6 min","Fläche":"5.42 m²","Error":0,"Ende":true},{"Datum":"3.6","Start":"10:44","Saugzeit":"5 min","Fläche":"5.25 m²","Error":0,"Ende":true},{"Datum":"23.5","Start":"10:40","Saugzeit":"12 min","Fläche":"6.58 m²","Error":0,"Ende":true},{"Datum":"23.5","Start":"10:05","Saugzeit":"8 min","Fläche":"8.49 m²","Error":0,"Ende":true},{"Datum":"23.5","Start":"09:28","Saugzeit":"35 min","Fläche":"35.62 m²","Error":0,"Ende":true},{"Datum":"16.5","Start":"11:51","Saugzeit":"37 min","Fläche":"35.71 m²","Error":0,"Ende":true},{"Datum":"9.5","Start":"15:51","Saugzeit":"38 min","Fläche":"36.18 m²","Error":0,"Ende":true},{"Datum":"2.5","Start":"19:11","Saugzeit":"8 min","Fläche":"6.51 m²","Error":0,"Ende":true},{"Datum":"2.5","Start":"11:55","Saugzeit":"36 min","Fläche":"35.59 m²","Error":0,"Ende":true},{"Datum":"18.4","Start":"10:13","Saugzeit":"33 min","Fläche":"35.32 m²","Error":0,"Ende":true},{"Datum":"27.3","Start":"12:53","Saugzeit":"36 min","Fläche":"36.23 m²","Error":0,"Ende":true},{"Datum":"14.3","Start":"12:34","Saugzeit":"36 min","Fläche":"36.73 m²","Error":0,"Ende":true},{"Datum":"7.3","Start":"15:26","Saugzeit":"35 min","Fläche":"36.08 m²","Error":0,"Ende":true},{"Datum":"27.2","Start":"17:59","Saugzeit":"34 min","Fläche":"35.94 m²","Error":0,"Ende":true},{"Datum":"21.2","Start":"09:35","Saugzeit":"37 min","Fläche":"36.52 m²","Error":0,"Ende":true},{"Datum":"6.2","Start":"11:40","Saugzeit":"35 min","Fläche":"36.23 m²","Error":0,"Ende":true},{"Datum":"30.1","Start":"11:00","Saugzeit":"35 min","Fläche":"36.49 m²","Error":0,"Ende":true},{"Datum":"23.1","Start":"07:52","Saugzeit":"35 min","Fläche":"36.26 m²","Error":0,"Ende":true},{"Datum":"17.1","Start":"10:07","Saugzeit":"45 min","Fläche":"35.79 m²","Error":0,"Ende":true},{"Datum":"10.1","Start":"13:10","Saugzeit":"6 min","Fläche":"6.72 m²","Error":0,"Ende":true}]
          2021-06-03 20:29:01.561 - debug: mihome-vacuum.0 (4034) Receive <<< Helo <<< 2131002000000000131824dc60b91f6dffffffffffffffffffffffffffffffff
          2021-06-03 20:29:11.567 - debug: mihome-vacuum.0 (4034) Receive <<< Helo <<< 2131002000000000131824dc60b91f77ffffffffffffffffffffffffffffffff
          2021-06-03 20:29:12.816 - info: mihome-vacuum.0 (4034) Got terminate signal TERMINATE_YOURSELF
          2021-06-03 20:29:12.816 - info: mihome-vacuum.0 (4034) terminating
          2021-06-03 20:29:12.816 - debug: mihome-vacuum.0 (4034) Plugin sentry destroyed
          2021-06-03 20:29:12.817 - info: mihome-vacuum.0 (4034) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            saeft_2003 Most Active @Meistertr last edited by
            @meistertr sagte in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
            @saeft_2003 ich kann nur immer wieder betonen, dass die liste lang ist die ich umsetzten will,. also kann es in ein paar Wochen oder Monaten kommen
            Alles klar das verstehe ich natürlich. Falls ich bei irgendwelchen simplen Sachen helfen kann was dazu hilft den Zyklus zu integrieren, dann sag Bescheid.
            • U
              UHT last edited by
              gibt es das vis widget nicht mehr?
              • Ronny Gerndt
                Ronny Gerndt last edited by
                hab seit letzter Wochen einen Roborock S7 und wollte den mit iobroker verbinden.
                Die Verbindung bekomme ich soweit auch hin. Token usw. hat geklappt.
                Ich habe Version 3.20 am laufen und bekomme in endlosschleife diese Log Ausgaben.
                mihome-vacuum.0	2021-06-07 10:11:32.591	debug	(17421) Helo message Timeout
                mihome-vacuum.0	2021-06-07 10:11:20.589	debug	(17421) Time difference between Mihome Vacuum and ioBroker: -1623027974 sec
                mihome-vacuum.0	2021-06-07 10:11:20.588	debug	(17421) Receive <<< Helo <<< 213100200000000018cf43ce000063a2ffffffffffffffffffffffffffffffff
                mihome-vacuum.0	2021-06-07 10:11:19.784	debug	(17421) MIIO RECIVE: {"id":326,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":100}
                mihome-vacuum.0	2021-06-07 10:11:19.576	debug	(17421) Message= {"id":326,"method":"get_carpet_mode"}
                mihome-vacuum.0	2021-06-07 10:11:19.575	debug	(17421) MIIO RECIVE: {"id":325,"result":[90],"exe_time":200}
                mihome-vacuum.0	2021-06-07 10:11:19.285	debug	(17421) Message= {"id":325,"method":"get_sound_volume"}
                mihome-vacuum.0	2021-06-07 10:11:19.274	debug	(17421) MIIO RECIVE: {"id":324,"result":{"ssid":"Familie-Gerndt","ip":"192.168.178.70","mac":"b0:4a:39:15:75:03","bssid":"2c:91:ab:a5:2f:9a","rssi":-47},"exe_time":100}
                mihome-vacuum.0	2021-06-07 10:11:19.085	debug	(17421) Message= {"id":324,"method":"get_network_info"}
                mihome-vacuum.0	2021-06-07 10:11:19.083	debug	(17421) setGetStatus {"msg_ver":2,"msg_seq":609,"state":8,"battery":90,"clean_time":2399,"clean_area":30630000,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1
                mihome-vacuum.0	2021-06-07 10:11:19.082	debug	(17421) MIIO RECIVE: {"id":323,"result":[{"msg_ver":2,"msg_seq":609,"state":8,"battery":90,"clean_time":2399,"clean_area":30630000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_f
                mihome-vacuum.0	2021-06-07 10:11:18.814	debug	(17421) Message= {"id":323,"method":"get_status"}
                mihome-vacuum.0	2021-06-07 10:11:18.813	debug	(17421) get params for stock Vacuum
                mihome-vacuum.0	2021-06-07 10:11:10.583	debug	(17421) Time difference between Mihome Vacuum and ioBroker: -1623027974 sec
                mihome-vacuum.0	2021-06-07 10:11:10.582	debug	(17421) Receive <<< Helo <<< 213100200000000018cf43ce00006398ffffffffffffffffffffffffffffffff
                mihome-vacuum.0	2021-06-07 10:11:00.533	debug	(17421) Helo message Timeout
                mihome-vacuum.0	2021-06-07 10:10:58.811	debug	(17421) MIIO Receive Timeout<<<
                mihome-vacuum.0	2021-06-07 10:10:56.809	debug	(17421) Message= {"id":322,"method":"get_carpet_mode"}
                mihome-vacuum.0	2021-06-07 10:10:56.809	debug	(17421) ERROR at setGetSoundVolume: MESSAGE TIMEOUT
                mihome-vacuum.0	2021-06-07 10:10:56.807	debug	(17421) MIIO Receive Timeout<<<
                mihome-vacuum.0	2021-06-07 10:10:54.805	debug	(17421) Message= {"id":321,"method":"get_sound_volume"}
                mihome-vacuum.0	2021-06-07 10:10:54.797	debug	(17421) MIIO RECIVE: {"id":320,"result":{"ssid":"Familie-Gerndt","ip":"192.168.178.70","mac":"b0:4a:39:15:75:03","bssid":"2c:91:ab:a5:2f:9a","rssi":-52},"exe_time":101}
                mihome-vacuum.0	2021-06-07 10:10:53.045	debug	(17421) Message= {"id":320,"method":"get_network_info"}
                mihome-vacuum.0	2021-06-07 10:10:53.043	debug	(17421) setGetStatus {"msg_ver":2,"msg_seq":607,"state":8,"battery":89,"clean_time":2399,"clean_area":30630000,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1
                mihome-vacuum.0	2021-06-07 10:10:53.030	debug	(17421) MIIO RECIVE: {"id":319,"result":[{"msg_ver":2,"msg_seq":607,"state":8,"battery":89,"clean_time":2399,"clean_area":30630000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_f
                mihome-vacuum.0	2021-06-07 10:10:52.839	debug	(17421) Message= {"id":319,"method":"get_status"}
                mihome-vacuum.0	2021-06-07 10:10:52.838	debug	(17421) get params for stock Vacuum
                Es kommt also ständig ein Timeout und das es eine Zeitdifferenz gibt. Kann man da was dagegen tun?
                Danke und Grüße
                Ronny
                  tobitobsta last edited by
                  hat irgendwer die 3.2.0 Version mit einem S5 am Laufen? Ich habe ihn nicht zum Laufen bekommen hinsichtlich "load rooms" - zurück auf 2.5.5 funktioniert wieder alles einwandfrei.
                  Im debug protokoll ist mir aufgefallen, dass er bei 3.2.0 irgendwas mit "unknown device model" sagte...
                  und Frage 2: funktioniert beim S5 die Detektion der Wischeinheit? bei mir bleibt der "water_box" Datenpunkt immer auf false - mag aber sein, dass das der S5 das gar nicht kann.
                    Thomas Braun Most Active @Ronny Gerndt last edited by
                    @ronny-gerndt
                    Hast du den Sauger mal in einer der Apps mihome oder roborock konfiguriert?
                    Ronny Gerndt 1 Reply Last reply Reply Quote 0
                    • Ronny Gerndt
                      Ronny Gerndt @Thomas Braun last edited by Ronny Gerndt
                      @thomas-braun said in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
                      @ronny-gerndt
                      Ja klar. Hatte erst die Roborock drauf und bin dann auf MiHome gewechselt. Da funzt auch alles.
                      Die Anbindung funktioniert inzwischen auch grundsätzlich. Mir fehlt noch die Raumliste. Die wird immer als leer angezeigt.
                      • haselchen
                        haselchen Most Active @UHT last edited by haselchen
                        @Meistertr
                        Ich habe über die 2.1.1 die 3.2.0 installiert (update über Admin Oberfläche).
                        Bei GetDevices bekomme ich permanent einen Error: LOG IN FAILED.
                        Runter auf die 2.1.1 geht wieder alles (bis auf die Karte, deswegen wollte ich updaten)
                        Ist ein Robo S5 2.GEN.
                        (ich habe noch einen V1 deswegen die 1. Instanz zusätzlich)
                        mihome-vacuum.0	2021-06-13 13:50:46.231	info	(8576) create state for carpet_mode
                        mihome-vacuum.0	2021-06-13 13:50:45.416	info	(8576) create states for water box
                        mihome-vacuum.0	2021-06-13 13:50:45.375	info	(8576) change states from State control.fan_power
                        mihome-vacuum.0	2021-06-13 13:50:45.258	info	(8576) Map selected create states...
                        mihome-vacuum.1	2021-06-13 13:50:44.889	info	(8582) create state for carpet_mode
                        mihome-vacuum.0	2021-06-13 13:50:44.873	warn	(8576) Login failed
                        mihome-vacuum.1	2021-06-13 13:50:44.421	info	(8582) Map selected create states...
                        mihome-vacuum.1	2021-06-13 13:50:44.191	warn	(8582) Login failed
                        mihome-vacuum.0	2021-06-13 13:50:43.462	info	(8576) settest next timer: not available
                        mihome-vacuum.0	2021-06-13 13:50:42.897	info	(8576) select standard vacuum protocol....
                        mihome-vacuum.0	2021-06-13 13:50:42.853	info	(8576) IOT disabled, delete state
                        mihome-vacuum.1	2021-06-13 13:50:42.777	info	(8582) settest next timer: not available
                        mihome-vacuum.0	2021-06-13 13:50:42.683	info	(8576) check group user admin group admin: false
                        mihome-vacuum.0	2021-06-13 13:50:42.626	info	(8576) check user admin pw iobroker: true
                        mihome-vacuum.0	2021-06-13 13:50:42.166	info	(8576) starting. Version 3.2.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.22.1, js-controller: 3.2.16
                        mihome-vacuum.1	2021-06-13 13:50:42.152	info	(8582) select standard vacuum protocol....
                        mihome-vacuum.1	2021-06-13 13:50:42.124	info	(8582) IOT disabled, delete state
                        mihome-vacuum.0	2021-06-13 13:50:42.012	info	(8576) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                        mihome-vacuum.1	2021-06-13 13:50:41.881	info	(8582) check group user admin group admin: false
                        mihome-vacuum.1	2021-06-13 13:50:41.765	info	(8582) check user admin pw iobroker: true
                        mihome-vacuum.1	2021-06-13 13:50:41.285	info	(8582) starting. Version 3.2.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.22.1, js-controller: 3.2.16
                        mihome-vacuum.1	2021-06-13 13:50:41.174	info	(8582) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                        Meistertr 1 Reply Last reply Reply Quote 0
                        • Meistertr
                          Meistertr Developer @haselchen last edited by Meistertr
                          @haselchen du musst das passwort neu eingeben. Steht auch im changelog
                          haselchen F 3 Replies Last reply Reply Quote 0
                          • haselchen
                            haselchen Most Active @Meistertr last edited by
                            @meistertr
                            Als wenn ich das nicht nach so einer Meldung machen würde 😉
                            Ergebnis blieb und bleibt das Gleiche.
                            Warum bekomme ich mit der 2.1.1 eigentlich die Map nicht mehr angezeigt bzw. ausgelesen?
                              @meistertr konntest du dir meinen log schon ansehen ? Sind noch immer keine Räume da 😔
                              • haselchen
                                @meistertr
                                Habe alles nochmal neu aufgesetzt in der Mihome App.
                                Dann nochmal über die 2.1.1 die 3.2.0 installiert.
                                Hab noch nicht alles getestet, aber Verbindung ist da und die Datenpunkte werden aktualisiert.
                                Auch von mir ein Danke, dass Du Deine Freizeit diesem Projekt widmest!
                                  tobitobsta @haselchen last edited by
                                  @haselchen bei map hat sich der Datenpunkt geändert - dennoch hab ich es noch nicht bis ins VIS geschafft - aber die URL konnte ich bereits laden und die Map auch sehen.
                                  das Thema Problem mit den Räumen habe ich auch (siehe ein paar Posts weiter oben). Habe auch den S5 - kann es daran tatsächlich liegen?
                                  VG
                                  • haselchen
                                    haselchen Most Active last edited by
                                    @tobitobsta
                                    Soweit läuft alles wieder bei mir.
                                    Durch das drüber installieren sind die alten Einstellungen geblieben.
                                    Map hat er geladen und erscheint auch in der VIS.
                                      saeft_2003 Most Active last edited by saeft_2003
                                      @Meistertr
                                      Ich habe jetzt das regelmäßig der Adapter (version 3.2.0) crasht. Weißt du an was das liegen könnte?
                                      Heute:
                                      host.iobroker	2021-06-25 15:13:59.568	error	instance system.adapter.mihome-vacuum.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                      host.iobroker	2021-06-25 15:13:59.567	error	Caught by controller[0]: at UDP.onMessage (dgram.js:921:8)
                                      host.iobroker	2021-06-25 15:13:59.567	error	Caught by controller[0]: at Socket.EventEmitter.emit (domain.js:483:12)
                                      host.iobroker	2021-06-25 15:13:59.567	error	Caught by controller[0]: at Socket.emit (events.js:326:22)
                                      host.iobroker	2021-06-25 15:13:59.567	error	Caught by controller[0]: at Socket.checkAnswer (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/miio.js:146:62)
                                      host.iobroker	2021-06-25 15:13:59.567	error	Caught by controller[0]: at _Packet.getPlainData (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/miio.js:310:19)
                                      host.iobroker	2021-06-25 15:13:59.567	error	Caught by controller[0]: at Decipheriv.final (internal/crypto/cipher.js:172:29)
                                      host.iobroker	2021-06-25 15:13:59.567	error	Caught by controller[0]: at Object.final (<anonymous>)
                                      host.iobroker	2021-06-25 15:13:59.565	error	Caught by controller[0]: Error: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
                                      mihome-vacuum.0	2021-06-25 15:13:59.281	error	(15936) Exception-Code: ERR_OSSL_EVP_BAD_DECRYPT: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
                                      mihome-vacuum.0	2021-06-25 15:13:59.281	error	at UDP.onMessage (dgram.js:921:8)
                                      mihome-vacuum.0	2021-06-25 15:13:59.281	error	at Socket.EventEmitter.emit (domain.js:483:12)
                                      mihome-vacuum.0	2021-06-25 15:13:59.281	error	at Socket.emit (events.js:326:22)
                                      mihome-vacuum.0	2021-06-25 15:13:59.281	error	at Socket.checkAnswer (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/miio.js:146:62)
                                      mihome-vacuum.0	2021-06-25 15:13:59.281	error	at _Packet.getPlainData (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/miio.js:310:19)
                                      mihome-vacuum.0	2021-06-25 15:13:59.281	error	at Decipheriv.final (internal/crypto/cipher.js:172:29)
                                      mihome-vacuum.0	2021-06-25 15:13:59.281	error	at Object.final (<anonymous>)
                                      mihome-vacuum.0	2021-06-25 15:13:59.281	error	(15936) Error: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
                                      mihome-vacuum.0	2021-06-25 15:13:59.277	error	(15936) uncaught exception: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
                                      Gestern:
                                      2021-06-24 16:30:54.310 - error: mihome-vacuum.0 (10285) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      2021-06-24 16:30:54.319 - error: mihome-vacuum.0 (10285) unhandled promise rejection: undefined
                                      2021-06-24 16:30:54.319 - error: mihome-vacuum.0 (10285) undefined
                                      2021-06-24 16:30:54.937 - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                      2021-06-24 16:30:54.938 - error: host.iobroker Caught by controller[1]: MESSAGE TIMEOUT
                                      2021-06-24 16:30:54.939 - error: host.iobroker instance system.adapter.mihome-vacuum.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                      @ all
                                      Habt ihr crashs?
                                        Thomas Braun Most Active @saeft_2003 last edited by
                                        @saeft_2003 Hier crasht nix.
                                        Wann passiert es denn bei dir? Wenn der Roboter aktiv ist?
                                          saeft_2003 Most Active @Thomas Braun last edited by
                                          Ja nur wenn er aktiv ist sonst nicht.
                                            @thomas-braun @Meistertr
                                            Gerade war er aktiv und es gab wieder einen crash. Ich kann mir nicht erklären an was das liegt?
                                            host.iobroker	2021-06-29 08:44:16.591	error	instance system.adapter.mihome-vacuum.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                            host.iobroker	2021-06-29 08:44:16.591	error	Caught by controller[0]: at UDP.onMessage (dgram.js:921:8)
                                            host.iobroker	2021-06-29 08:44:16.591	error	Caught by controller[0]: at Socket.EventEmitter.emit (domain.js:483:12)
                                            host.iobroker	2021-06-29 08:44:16.591	error	Caught by controller[0]: at Socket.emit (events.js:326:22)
                                            host.iobroker	2021-06-29 08:44:16.590	error	Caught by controller[0]: at Socket.checkAnswer (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/miio.js:146:62)
                                            host.iobroker	2021-06-29 08:44:16.590	error	Caught by controller[0]: at _Packet.getPlainData (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/miio.js:310:19)
                                            host.iobroker	2021-06-29 08:44:16.590	error	Caught by controller[0]: at Decipheriv.final (internal/crypto/cipher.js:172:29)
                                            host.iobroker	2021-06-29 08:44:16.590	error	Caught by controller[0]: at Object.final (<anonymous>)
                                            host.iobroker	2021-06-29 08:44:16.588	error	Caught by controller[0]: Error: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
                                            mihome-vacuum.0	2021-06-29 08:44:16.287	error	(27481) Exception-Code: ERR_OSSL_EVP_BAD_DECRYPT: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
                                            mihome-vacuum.0	2021-06-29 08:44:16.287	error	at UDP.onMessage (dgram.js:921:8)
                                            mihome-vacuum.0	2021-06-29 08:44:16.287	error	at Socket.EventEmitter.emit (domain.js:483:12)
                                            mihome-vacuum.0	2021-06-29 08:44:16.287	error	at Socket.emit (events.js:326:22)
                                            mihome-vacuum.0	2021-06-29 08:44:16.287	error	at Socket.checkAnswer (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/miio.js:146:62)
                                            mihome-vacuum.0	2021-06-29 08:44:16.287	error	at _Packet.getPlainData (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/miio.js:310:19)
                                            mihome-vacuum.0	2021-06-29 08:44:16.287	error	at Decipheriv.final (internal/crypto/cipher.js:172:29)
                                            mihome-vacuum.0	2021-06-29 08:44:16.287	error	at Object.final (<anonymous>)
                                            mihome-vacuum.0	2021-06-29 08:44:16.287	error	(27481) Error: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
                                            mihome-vacuum.0	2021-06-29 08:44:16.284	error	(27481) uncaught exception: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
                                            Thomas Braun Meistertr apollon77 3 Replies Last reply Reply Quote 0
                                            1198
                                            361609
