    4. Parkside Zigbee Bewässerung an CC25x2r1
      cb187 @1rfsNet last edited by cb187
      würde gerne mein Blockly Script mit euch teilen.
       <variables>
         <variable type="interval" id="Bewaesserung_aktiv_halten">Bewaesserung_aktiv_halten</variable>
         <variable type="timeout" id="Abschalten_nach_5Min">Abschalten_nach_5Min</variable>
       </variables>
       <block type="on_ext" id="L!t)ZIeJ.`_yCE3P_2;N" x="-512" y="-587">
         <field name="CONDITION">gt</field>
         <value name="OID0">
           <shadow type="field_oid" id="5kIK6In2H_?Co|uB:vOB">
             <field name="oid">0_userdata.0.Gartenbeäwsserung_Zeit</field>
           <block type="control" id="*{x9axfQ0]m(gB2Z$%=P">
             <field name="OID">zigbee.0.847127fffed0ba2f.state</field>
               <block type="logic_boolean" id="w:k9-;jmiYrAD(ixZPcO">
               <block type="timeouts_setinterval" id="SP#kQBqvPQdt/QV2N]dT">
                 <field name="NAME">Bewaesserung_aktiv_halten</field>
                 <field name="INTERVAL">45</field>
                   <block type="control" id="nhLn+Rnd#A-mjcS|4zSs">
                       <block type="logic_boolean" id="ne_X7~0.OJUZ[EXyGnu$">
                       <block type="telegram" id="ApD6l-8)Ato/m|B.,[G~">
                         <field name="INSTANCE">.0</field>
                         <field name="LOG"></field>
                         <value name="MESSAGE">
                           <shadow type="text" id="AO-{/JU5}l]*U_Svn@O,">
                             <field name="TEXT">Bewässerung wurde angestellt</field>
                   <block type="timeouts_settimeout" id="_Af{pHLypAKuDUrVk.Xi">
                     <field name="NAME">Abschalten_nach_5Min</field>
                     <field name="DELAY">2</field>
                       <block type="timeouts_clearinterval" id="Se*D3Imy7%,D,E`~CsT7">
                           <block type="control" id="t@X#Vt#bCA`(8=mCszkl">
                               <block type="logic_boolean" id="Ju?m,1Ogaw~!$u1U,yL6">
                               <block type="control" id="B~gYklRPS)En/5AinKDh">
                                 <field name="OID">0_userdata.0.Gartenbeäwsserung_Zeit</field>
                                   <block type="logic_boolean" id="-*TG.(B;#.#H_P9uu+v7">
                                   <block type="telegram" id="`_hQ8-5V2*]$jh$dY+t_">
                                       <shadow type="text" id="kfe]:A|Yt01.I(!s/;rR">
                                         <field name="TEXT">Bewässerung wurde abgestellt</field>
           <block type="on_ext" id="hYow-GWJ?.47n6^Q*]no">
             <field name="CONDITION">lt</field>
             <value name="OID0">
               <shadow type="field_oid" id="84MJ61Cb2zroB2-/E}/R">
               <block type="timeouts_clearinterval" id="xokQebBIW)9q?gb~a[Q-">
                   <block type="timeouts_cleartimeout" id=":k,m?e%!!,6(~%#L(aSH">
                       <block type="control" id="J;%$39nbdTzxo`JYBqxS">
                           <block type="logic_boolean" id="b.fpKT0gAW#nb)J+}/[:">
                           <block type="telegram" id=",{l!A=Va`WjtVp48m~NE">
                               <shadow type="text" id="S;HXA43ZDP2I;0bN[p8f">
      • Asgothian
        Asgothian Developer @cb187 last edited by
        @cb187 Pack das doch mal bitte sauber in Code Tags (</>) damit man das auch kopieren kann.
        A.
          cb187 @Asgothian last edited by cb187
          @asgothian
          ka wie das geht:-)
          Habs:)
          • Asgothian
            @cb187 danke.
              arteck Developer Most Active @1rfsNet last edited by
              @1rfsnet die datei MUSS
              woox.js
              heissen
              ich seh gerade bei speichern aus dem forum hier wird eine nummer davor generiert.. was falsch ist
              C 1rfsNet 2 Replies Last reply Reply Quote 0
                cb187 @arteck last edited by
                Sniffert eigentlich schon wer die Befehle vom Parkside mit?
                • 1rfsNet
                  1rfsNet @arteck last edited by
                  @arteck Ja das ist mir auch schon aufgefallen, aber das habe ich vorher umbenannt. Ich habe folgendes gemacht:
                  • iobroker stop
                  • /opt/iobroker/node_modules/zigbee-herdsman-converters/devices/woox.js geändert
                  • iobroker fix
                  • iobroker start
                  • Gerät angelernt
                  Mehr ist es doch eigentlich nicht oder?
                  • Asgothian
                    @cb187 Unwahrscheinlich. Dazu müsste jemand den Parkside am original Gateway betreiben.
                    A.
                      @asgothian
                      Können ja alle zusammen schmeissen kostet doch glaub nur 19€.
                      Oder es kauft den einer fängt zwei tage die daten ab und tauscht das ding wieder um😁
                        Ryan last edited by
                        Hallo, lese schon länger mit 🙂 hab auch 2 von den Bewässerungen hier liegen. Hab Ich richtig gelesen das dieses Gateway 19euro kostet und man mit diesen die Komplette Unterstützung in Zigbee bekomm würde?
                        • Asgothian
                          Asgothian Developer @Ryan last edited by
                          @ryan sagte in Parkside Zigbee Bewässerung an CC25x2r1:
                          Bedingt. Die Unterstützung läuft dann nicht über den ioBroker sondern über die LIDL Cloud - die interessanterweise in China angesiedelt zu sein scheint.
                          A.
                            Ryan @Asgothian last edited by
                            @asgothian verstehe,danke für die Info 🙂 Wollte es mir einfach machen und den Spendieren wenn es geholfen hätte die Dinger in ioBroker einzubinden:)
                            C Asgothian 2 Replies Last reply Reply Quote 0
                              cb187 @Ryan last edited by
                              @ryan
                              Wäre schon ne feine Sache.Xiaomi usw laufen ja auch über china cloud oder nicht?
                              • Asgothian
                                @ryan Danke für das Angebot. Ich hab im Moment etwas zu viel um die Ohren um da im Detail ran zu gehen. Wenn ich weniger stress habe kann ich schauen ob die klassische "TuYa" Zeitschalte auch von dem Gerät unterstützt wird. Dazu kann ich euch dann einen Code Schnipsel zum testen besorgen.
                                Das wird aber noch 2 Wochen dauern, sorry.
                                A.
                                  Ryan last edited by
                                  @asgothian das wäre klasse 🙂
                                  Kein ding alles mit der Ruhe 🙂
                                    Ryan @cb187 last edited by
                                    @cb187 normal schon soweit ich weiß, betreue aber alles ohne Cloud 🙂
                                      wartet doch mal ab...die jungs von z2m sind schon dran.. da kommt bestimmt die Tage was
                                      • 1rfsNet
                                        1rfsNet @chrizzel last edited by
                                        @chrizzel said in Parkside Zigbee Bewässerung an CC25x2r1:
                                        OT, aber falls es jemandem als Alternative hilft:
                                        Ich habe das Teil als "sonstiges" an einen Echo Show, 2. Gen. angemeldet bekommen. Wird als Schalter erkannt. Über IOBroker kann man ihn triggern. Details muss ich noch testen.
                                        Grüße,
                                        Schade funktioniert bei mir leider auch nicht 😕
                                          Ente @1rfsNet last edited by
                                          @all,
                                          das Geräte gibt es - leider - nicht mehr bei Lidl. Wollte mir evtl. ein 2. holen.
                                          Viele Grüße
                                          Christian
                                          1rfsNet C 2 Replies Last reply Reply Quote 0
                                          • 1rfsNet
                                            1rfsNet @Ente last edited by
                                            @ente bestimmt haben wir alle aufgekauft 😂
                                            246
                                            40202
